JED523-3.3V-C
JED523-3.3V-C
    JDTFUSE(集电通)
JED523-3.3V-C 数据手册
PRODUCT DATASHEET Electro-Static Discharge JED523-3.3V-C ESD JED523-3.3V-C ESD Applications Features ● Package: SOD-523 ● Protects one data line ● Cellular Handsets and Accessories ● Ultra low leakage: nA level ● Operating voltage: 3.3V ● Notebooks and Handhelds ● Personal Digital Assistants ● Portable Instrumentation ● Ultra low clamping voltage ● Complies with following standards: ● Digital Cameras ● Peripherals – IEC 61000-4-2 (ESD) immunity test ● Audio Players Air discharge: ±30kV ● Keypads, Side Keys, LCD Displays Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 8A (8/20μs) ● RoHS compliant Schematic Diagram Pin Description XX Limiting Values(TA = 25 °C, unless otherwise specified) Symbol Parameter VESD Electrostatic Discharge Voltage PPp Peak Pulse Power IPP Peak Pulse Current TJ Operating Temperature Range Tstg Storage Temperature Range Value Unit IEC 61000-4-2;Contact Discharge ±30 kV IEC 61000-4-2;Air Discharge ±30 kV tP=8/20μs 80 W tP=8/20μs 8 A - -55 to +125 °C - -55 to +150 °C Conditions Electrical Characteristics(TA = 25 °C, unless otherwise specified) Symbol Parameter VRWM Reverse Working Voltage TA=25°C VPT Punch-Through Voltage VSB Min Typ. Max Unit - - 3.3 V IT=2μA 3.8 - - V Snap-Back Voltage IT=50mA 3.5 - - V IR Reverse Leakage Current VRWM=3.3V;TA=25°C - 0.01 0.2 μA VC Clamping Voltage IPP=1A(8 x 20µs pulse) - - 6 V VC Clamping Voltage IPP=5A(8 x 20µs pulse) - - 8 V VC Clamping Voltage IPP=8A(8 x 20µs pulse) - - 10 V CJ Junction Capacitance VR=0V,f=1 MHZ - 12.5 25 pF JDT Fuse Industrial Co., Ltd www.jdtfuse.com Conditions Page 1/4 Revised 01/19/22 JED523-3.3V-C ESD Typical Characteristics Junction Capacitance vs. Reverse Voltage Clamping Voltage vs. Peak Pulse Current (tp = 8/20us) Peak Pulse Power vs. Pulse Time Power Derating Curve % of P eak P uls e C urrent 100 80 60 40 20 0 0 20 40 60 Time_t(μs) 8 X 20μs Pulse Waveform JDT Fuse Industrial Co., Ltd www.jdtfuse.com 80 ESD Clamping Voltage 8 kV Contact per IEC61000-4-2 Page 2/4 Revised 01/19/22 JED523-3.3V-C ESD Physical Dimensions(mm.) b D E2 E A1 - + E1 c L A Symbol Dimensions In Millimeters Dimensions In Inches Min Nom Max Min Nom Max A 0.51 -- 0.77 0.020 -- 0.031 A1 0.50 -- 0.70 0.020 -- 0.028 b 0.25 -- 0.35 0.010 -- 0.014 c 0.08 -- 0.15 0.003 -- 0.006 D 0.75 -- 0.85 0.030 -- 0.033 E 1.10 -- 1.30 0.043 -- 0.051 E1 1.50 -- 1.70 0.059 -- 0.067 E2 L 0.008REF 0.20REF 0.01 - -- 0.07 0.001 -- 0.003 7°REF 7°REF Suggested Land Pattern 0.60 Unit:mm 0.70 1.42 Packaging Quantity Part Number Delivery Form Delivery Quantity JED523-3.3V-C 7”T&R 3,000 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 3/4 Revised 01/19/22 JED523-3.3V-C ESD Soldering Parameters tP TP Critical Zone TL to TP Ramp-up TL tL Temperature (°C ) TS(max) Preheat TS(min) Ramp-down ts 25 time to peak temperatue Time t 25°C to peak Reflow Condition Pre-heat Pb-Free Assembly -Temperature Min(Ts(min)) +150°C -Temperature Max(Ts(max)) +200°C -Time(Min to Max)(ts) 60~180 secs. Average ramp up rate (Liquid us Temp(TL) to peak) 3°C/sec. Max Ts(max) to TL - Ramp-up Rate 3°C/sec. Max Reflow -Temperature(TL)(Liquid us) +217°C -Temperature (tL) 60~150 secs. Peak Temp (Tp) +260(+0/-5)°C Time within 5°C of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6°C/sec. Max xTime 25°C to Peak Temp (TP) 8 min. Max Do not exceed +260°C Part Number System JE D523 - 3.3V - C C=Bi-directional Blank=Uni-directional Working Voltage: 3.3V SOD-523 JDT ESD JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 4/4 Revised 01/19/22
JED523-3.3V-C 价格&库存
很抱歉,暂时无法提供与“JED523-3.3V-C”相匹配的价格&库存,您可以联系我们找货
