-Original Multi-purpose High-pin-count Miniature
Waterproof Connectors
RM-W Series
Assembly type (straight plug/RM15W)
Ø23
Ø21.5
57
(Low-height plug)
Cable
Ø21.5
Overview
RM-W series connectors originally developed by
Hirose offer miniature waterproof connectors to
satisfy the requirements of high-capability in a small
package.
The locking structure adopts a thread coupling style,
showing superior waterproof reliability.
Cable
Fig.1
Assembly type (right-angled plug/RM15W)
41
Cable
Features
Plugs :
Available in 3 types - straight plug, straight lowheight plug, and right-angled plug.
Receptacles :
Fixing methods :
Available in 2 types-Jam nut type and screw
tightening type with square flange. The Jam nut
types offer a front or back mount application.
Available numbers of contacts :
2, 4, 8, 10, 12, 15, 20, 40 contacts in 2 contact
plating types: gold or silver.
Ø23
Flexible cable arrangements
Cable
In RM-W series, you can select an optimal product
for your application through different kinds of both
plugs and receptacles.
360
1. Rich variation
40
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
48
Fig.2
2. Waterproof structure
When fully mated, the connectors meet the
waterproof requirements of IP68.
3. Flexible cable arrangements
The assembly type right-angled plugs permit
exiting of the cable over a 360-degree range in
any direction.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.10⑥
1
RM-W Series●
-Original Multi-purpose High-pin-count Miniature Waterproof Connectors
Product Specifications (RM15WT size products)
Voltage rating
600V AC, 840V DC (2 pos.)
500V AC, 700V DC (4, 8 pos.)
350V AC, 490V DC (10 pos.)
350V AC, 490V DC (12 pos.)
Current rating
10A (2, 4 pos.)
5A (8, 10, 12 pos.)
Operating temperature (Note 1)
-25ç to +85ç
Storage temperature range (Note 2)
-10ç to +60ç
Rating
Characteristic
Specification
1. Contact resistance
2mø max. (2, 4 pos.)
4mø max. (8, 10, 12 pos.)
2. Insulation resistance
1,000Mø min
Conditions
1A DC
3. Withstanding voltage No flashover or insulation breakdown.
500V DC
1,800V AC/1 minute (2 pos.)
1,500V AC/1 minute (4, 8 pos.)
1,000V AC/1 minute (10, 12 pos.)
Frequency : 10 to 55 to 10Hz, single amplitude of
0.75mm, 10 cycles in 3 axis.
4. Vibration
No electrical discontinuity for 10µs max.
5. Shock
Acceleration of 490m/s2, 11ms duration, sine half-wave,
3 cycles in each of the 6 axis.
6. Durability
(insertion/withdrawal)
4mø max. (2, 4 pos.)
8mø max. (8, 10, 12 pos.)
2,000 cycles
7. Temperature cycle
Insulation resistance : 100Mø min.
Temperature : -55ç ➝ Room temperature ➝ +85ç ➝ Room temperature
Time
: 30 ➝ 10 to 15 ➝ 30 ➝ 10 to 15 (Minutes) 5 cycles
8. Humidity
Insulation resistance : 100Mø min. (Dry)
96 hours at temperature of 40ç and humidity of 90% to 95%.
9. Water protection
When mated with corresponding connector.
No water penetration when submerged for 48 hours at
the depth of 1.8 meter.
Note 1 : Includes temperature rise caused by the current flow.
Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating temperature range
covers non-conducting condition of installed connectors in storage, shipment or during transportation.
Materials / Finish
Item
Material
Finish
Remarks
Body
Zinc alloy, brass
Chrome plated or nickel plated
Insulator
Diallyl phthalate resin, or PPS
UL94V-0 (Color : Black)
Contacts
Brass, phosphor bronze, or copper alloy
Silver plated or gold plated
Packing
SIR (black or red), or NBR (gray)
Note : Do not mix different contact plating.
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Connector
Cap
RM 15 W T P** - 2 P (**)
RM 15 T P - C (**)
1
2
1
3
4
5
6
7
1 Series Name : RM-W
5 No. of Pos.
2 Shell Size
6 Contact Type
P : Male Contact
S : Female Contact
3 Lock Type
T : Screw Lock
4 Connector Type
P : Plug
LP : Plug (Right angle)
R : Receptacle
2
3
4
8
7 Other Specifications
A two-digit number is added to indicate other specifications.
8 Accessory Type
C : Cap
Note : The cap of the RM-W series is the same as that of the RM series. It can be used as a waterproof cap.
2
7
RM-W Series●
Wrench opening dimension
of 18mm
Plugs - Straight Long Back Shell
M20∞0.75
M19∞1
13
Ø21.5
2
Ø15.2
RM15WTPZA-10S(71)
45.3
(Representative example)
Part No.
HRS No.
RM15WTPZA-2P(7*)
109-1734-5 7*
2
RM15WTPZA-4P(7*)
109-1735-8 7*
4
RM15WTPZA-8P(7*)
Part No.
HRS No.
43g
RM15WTPZA-2S(7*)
109-1729-5 7*
2
44g
RM15WTPZA-4S(8*)
109-1730-4 8*
4
43g
RM15WTPZA-8S(7*)
No. of contacts Weight
109-1736-0 7*
8
RM15WTPZA-10P(7*) 109-1737-3 7*
10
RM15WTPZA-12P(7*) 109-1738-6 7*
12
44g
109-1731-7 7*
8
RM15WTPZA-10S(7*) 109-1732-0 7*
10
RM15WTPZA-12S(7*) 109-1733-2 7*
12
45g
Applicable Strain Reliefs
External cable clamp + internal, self-tightening
JR16WCC-10(72)
M20∞0.75
Ø23
of 21mm
A
Drive screw(2)
17.5
Part No.
HRS No.
A
JR16WCC-4(72)
114-2052-6 72
4
JR16WCC-6(72)
114-2053-9 72
6
JR16WCC-8(72)
114-2054-1 72
8
Weight
17.5g
Part No.
HRS No.
A
JR16WCC-10(72)
114-2055-4 72
10
JR16WCC-11(72)
114-2154-6 72
11
JR16WCC-12(72)
114-2056-7 72
12
Weight
17.5g
Internal, self tightening
JR16WCCA-10(72)
M20∞0.75
Ø23
of 21mm
A
[Specification number]
(76)(81) : Silver plated contacts
(77)(82) : Gold plated contacts
8
Part No.
HRS No.
A
JR16WCCA-4(72)
114-2076-4 72
4
JR16WCCA-6(72)
114-2077-7 72
6
JR16WCCA-8(72)
114-2078-0 72
8
Weight
16g
Part No.
HRS No.
A
JR16WCCA-10(72)
114-2079-2 72
10
JR16WCCA-11(72)
114-2155-9 72
11
JR16WCCA-12(72)
114-2080-1 72
12
Weight
16g
Note 1 : Cable jacket diameter : Use A ± 0.2mm
Note 2 : When using the self-tightening strain relief verify the cable pull force requirements.
3
RM-W Series●
of 18mm
Plugs - Straight Short Back Shell
M16∞0.75
M19∞1
13
Ø21.5
2
Ø15.2
RM15WTPZ-10S(71)
36.3
Part No.
HRS No.
RM15WTPZ-2P(7*)
109-1616-9 7*
2
RM15WTPZ-4P(7*)
109-1617-1 7*
4
RM15WTPZ-8P(7*)
Part No.
HRS No.
32g
RM15WTPZ-2S(7*)
109-1611-5 7*
2
33g
RM15WTPZ-4S(8*)
109-1612-8 8*
4
32g
RM15WTPZ-8S(7*)
109-1618-4 7*
8
RM15WTPZ-10P(7*) 109-1619-7 7*
10
RM15WTPZ-12P(7*) 109-1620-6 7*
12
33g
109-1613-0 7*
8
RM15WTPZ-10S(7*) 109-1614-3 7*
10
RM15WTPZ-12S(7*) 109-1615-6 7*
12
34g
JR13WCC-10(72)
of 17mm
A
Ø20
M16∞0.75
17
Drive screw(2)
Part No.
HRS No.
A
JR13WCC-4(72)
114-2045-0 72
4
JR13WCC-5(72)
114-2046-3 72
5
JR13WCC-6(72)
114-2047-6 72
6
Weight
17g
Part No.
HRS No.
A
JR13WCC-7(72)
114-2048-9 72
7
JR13WCC-8(72)
114-2049-1 72
8
JR13WCC-9(72)
114-2050-0 72
9
JR13WCC-10(72)
114-2051-3 72
10
Weight
17g
JR13WCCA-10(72)
M16∞0.75
A
Ø20
of 17mm
7.5
Part No.
HRS No.
A
JR13WCCA-4(72)
114-2069-9 72
4
JR13WCCA-5(72)
114-2070-8 72
5
JR13WCCA-6(72)
114-2071-0 72
6
Weight
12g
Part No.
A
JR13WCCA-7(72)
114-2072-3 72
7
JR13WCCA-8(72)
114-2073-6 72
8
JR13WCCA-9(72)
114-2074-9 72
9
JR13WCCA-10(72) 114-2075-1 72
10
4
HRS No.
Weight
12g
RM-W Series●
Plugs - Right Angle
of 21.8mm
RM15WTLP-10S(31)
M16∞0.75
Ø23
Ø15.2
19.15
Set screw(2)
Hexagonal hole
opposite side
1.27mm
(1.27HEX)
M19∞1
39.5
Part No.
RM15WTLP-4P(33)
RM15WTLP-4S(34)
RM15WTLP-8P(33)
RM15WTLP-8S(34)
HRS No.
No. of contacts
109-1886-3 33
4
109-1888-9 34
109-1887-6 33
8
109-1889-1 34
Weight
60.6g
61.6g
61.5g
63.2g
Part No.
RM15WTLP-10P(33)
RM15WTLP-10S(33)
RM15WTLP-12P(33)
RM15WTLP-12S(33)
HRS No.
No. of contacts
109-0020-0 33
10
109-0999-4 33
109-0997-9 33
12
109-1911-9 33
Weight
62.1g
63.1g
62.3g
64.3g
Note 1 : Packing material : NBR, body plating : nickel
Note 2 : HRS recommended tool : 1.27mm Hex Wrench
Note 3 : Recommended set screw tightening torque : 0.2 to 0.3N•m.
M16∞0.75
Ø20
of 17mm
JR13WCC-10(72)
A
Drive screw(2)
17
Part No.
JR13WCC-4(72)
JR13WCC-5(72)
JR13WCC-6(72)
HRS No.
114-2045-0 72
114-2046-3 72
114-2047-6 72
A
4
5
6
Weight
17g
Part No.
JR13WCC-7(72)
JR13WCC-8(72)
JR13WCC-9(72)
JR13WCC-10(72)
HRS No.
114-2048-9 72
114-2049-1 72
114-2050-0 72
114-2051-3 72
A
7
8
9
10
Weight
A
7
8
9
10
Weight
17g
JR13WCCA-10(72)
M16∞0.75
Ø20
of 17mm
A
(33) : Silver plated contacts
(34) : Gold plated contacts
7.5
Part No.
JR13WCCA-4(72)
JR13WCCA-5(72)
JR13WCCA-6(72)
HRS No.
114-2069-9 72
114-2070-8 72
114-2071-0 72
A
4
5
6
Weight
12g
Part No.
JR13WCCA-7(72)
JR13WCCA-8(72)
JR13WCCA-9(72)
JR13WCCA-10(72)
HRS No.
114-2072-3 72
114-2073-6 72
114-2074-9 72
114-2075-1 72
12g
5
RM-W Series●
Receptacles
Front panel mount
RM15WTRZ-10S(71)
2
A
6
Wrench opening
dimension of 18mm
1
1
2
Ø22
2
9
M19∞1
Part No.
HRS No.
No. of contacts
RM15WTRZ-2P(7*)
109-1631-2 7*
2
RM15WTRZ-4P(7*)
109-1633-8 7*
4
RM15WTRZ-8P(7*)
109-1634-0 7*
8
RM15WTRZ-10P(7*) 109-1635-3 7*
10
RM15WTRZ-12P(7*) 109-1636-6 7*
12
A
21
20.65
Weight
Part No.
HRS No.
No. of contacts
13g
RM15WTRZ-2S(7*)
109-1637-9 7*
2
14g
RM15WTRZ-4S(8*)
109-1639-4 8*
4
13g
RM15WTRZ-8S(7*)
109-1640-3 7*
8
RM15WTRZ-10S(7*) 109-1641-6 7*
10
RM15WTRZ-12S(7*) 109-1642-9 7*
12
14g
A
Weight
21.75
15g
21.6
Note : Recommended nut tightening torque : 3N•m
Rear panel mount
RM15WTRZA-10S(71)
A
2
Ø27
24(HEX)
13
6.5
M19∞1
M21∞1
Part No.
HRS No.
No. of contacts
RM15WTRZA-2P(7*)
109-1651-0 7*
2
RM15WTRZA-4P(7*)
109-1653-5 7*
4
RM15WTRZA-8P(7*)
109-1654-8 7*
8
RM15WTRZA-10P(7*) 109-1655-0 7*
10
RM15WTRZA-12P(7*) 109-1656-3 7*
12
6
A
21
20.65
Weight
Part No.
HRS No.
No. of contacts
22g
RM15WTRZA-2S(7*)
109-1657-6 7*
2
23g
RM15WTRZA-4S(8*)
109-1659-1 8*
4
22g
RM15WTRZA-8S(7*)
23g
109-1660-0 7*
8
RM15WTRZA-10S(7*) 109-1661-3 7*
10
RM15WTRZA-12S(7*) 109-1662-6 7*
12
A
Weight
21.75
24g
21.6
RM-W Series●
Receptacles (Square flange)
Waterproof (When mated with corresponding plug)
9
2
A
6
3
Ø3
.6
2
.9
Ø1
4-
1
1
Ø19
2
28
20.6
28
20.6
3
RM15WTRZB-10S(71)
M19∞1
Part No.
HRS No.
No. of contacts
RM15WTRZB-2P(7*)
109-1671-7 7*
2
RM15WTRZB-4P(7*)
109-1673-2 7*
4
RM15WTRZB-8P(7*)
109-1674-5 7*
8
RM15WTRZB-10P(7*) 109-1675-8 7*
10
RM15WTRZB-12P(7*) 109-1676-0 7*
12
A
Weight
Part No.
HRS No.
No. of contacts
19g
RM15WTRZB-2S(7*)
109-1677-3 7*
2
20g
RM15WTRZB-4S(8*)
109-1679-9 8*
4
19g
RM15WTRZB-8S(7*)
109-1680-8 7*
8
RM15WTRZB-10S(7*) 109-1681-0 7*
10
RM15WTRZB-12S(7*) 109-1682-3 7*
12
21
20.65
20g
A
Weight
21.75
21g
21.6
Note 1 : Screw size : M3
Note 2 : Recommended nut tightening torque : 0.3 to 0.35N•m
Cap
Plug cap
100
Ø6
Part No.
RM15TP-C(71)
HRS No.
109-0079-6 71
ØA
21.5
B
M19×1
C
12
D
16.5
D
C
φ3.3
B
ØA
Receptacle cap
100
Ø6
D
Ø 3.3
C
B
Part No.
RM15TR-C(31)
HRS No.
109-0080-5 31
ØA
21.5
B
M19×1
C
9
D
13.5
ØA
7
RM-W Series●
Plug -- Disassembly / Assembly
Clamp
Gasket
Tightening collar
Insulator body (P)
3 min
Contacts
Screw
Washer
Cable jacket
Conductors Wires
A
Coupling
Back shell
Strain relief clamp
Cable
Back shell
Tightening ring
Cable
B
Part No.
Table 1
No. of contacts
RM15WTPZA-**
2,4,8,10,12
RM15WTPZ-**
2,4,8,10,12
RM15WTLP-**
10,12
A
B
21mm
3mm
12mm
25mm
Set screw(2)
Disassembly
1Fix the plug in the assembly fixture (RM15TP-T01 (HRS No.150-0098-0)), then remove the insulator body (P) and the back shell.
1.
Right-angle plugs have set screws in the tightening ring at 2 locations. Loosen the set screws before removing the back shell.
2 Remove the 2 screws of the strain relief clamp, and then remove the clamp from the tightening collar.
Wiring
1 Assure that the cable outer diameter will fit the strain relief clamp, and is prepared as recommended in Table 1.
It is recommended that the exposed conductors be pre-soldered, to assure easier insertion in the soldering cup.
2. 2 Pass the parts over the cable in the order of: tightening collar, washer, bushing, back shell, and coupling. Refer to the
drawings (above) for assembly orientation of all components.
3Solder the wires to the contacts of the insulator body (P).
Use of heat-shrink tubing or another insulating media between the soldered contacts is suggested.
Connector Assembly
Straight Plugs
1 Place the completely wired insulator body (P) in the assembly fixture secured in a vise. Insert in the coupling, then back
shell. The back shell should be tightened to a torque of 3N•m.
Right-angle Plugs
1 Place the completely wired insulator body (P) in an assembly fixture secured by a vise. Insert in the coupling, then back
shell (with tightening ring). When attaching the back shell, orient the cable in the desired direction and fasten the tightening
ring to the insulator body (P) with a torque of 3N•m. After this, tighten and fix the 2 sets crews with a torque of 0.2 to 0.25N•m.
3.
Additional assembly recommendations :
In applications where continuous extremely high vibrations may be encountered it is recommended that a thread locking
compound be applied to male threads prior to assembly (Loctite 263 manufactured by Henkel Japan K.K. or equivalent)
2Assemble in the following order : gasket then washer, then the tightening-collar. During assembly, make sure to keep
the tip of the cable sheath at least 3mm from the gasket, as shown in the figure (above).
3To prevent loosening of the male threads, apply Loctite 263 (Henkel Japan K.K. or equivalent) to the male threads of
the back shell. Then tighten the tightening-collar to a torque of 3N•m with the clamp and the cable so that the cable
cannot rotate. (Screw-tightening torque : 0.65 to 0.70N•m)
4.
Points to be checked
1This connector has a waterproof feature. Please verify that the assembled connector is waterproof by conducting the
test described below.
2Because the force required to secure the strain relief clamp differs with the cable structure, please check the connector
assembly before use to make sure there is no rotation.
(Test verification of waterproof capability)
Apply air pressure of 17.6kPa for 30 seconds from the mating end of the plug connector. No air should leak from inside
the connector.
Precautions
5. The waterproof capability may be impaired if the cable sheath or gasket is damaged or contaminated when performing
the assembly. Please handle carefully.
8
RM-W Series●
Receptacle - recommended panel cut-outs
Rear mounting, front nut
Square flange, screw mounting
20.6±0.05
+0.1
Ø24 +0.1
Ø7.6 +0.1
Ø19.65 +0.05
Ø21
20.6±0.05
.1
+0
Ø17
4-M3∞0.5
Ø19.2 +0.1
Front mounting, rear nut
1.4±0.05
Panel thickness : 0.5 to 2mm
Panel thickness : 0.5 to 2.5mm
For RM15WTRZ receptacles
For RM15WTRZA receptacles
Panel thickness : 2.5 to 4mm
For RM15WTRZB receptacles
Note 1 : When attaching the receptacle to the panel, be certain to check that the gasket is in place in the groove. Do not pinch the gasket.
Note 2 : The view of the above diagrams is from the receptacle mating side.
Note 3 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles.
Contact Arrangement and Specifications
Shell size : 15
Contact
arrangement
No. of contacts
2
4
Withstanding voltage 1,800V AC / 1 minute
Current rating
8
1,500V AC / 1 minute
10A
10
12
1,000V AC / 1 minute
5A
1,000Mø min.
Contact resistance
2mø max.
4mø max.
Solder pot inner diameter
1.7mm
1.1mm
Note 1 : The contact configuration as viewed from the wiring side.
Note 2 : The ▼ symbol in the above diagrams indicates the coupling guide position of the receptacles.
Note 3 : Withstanding voltages indicate test voltage values.
Precautions
1. Switch off the power of the circuit before disconnecting or plugging- in the connectors.
2. Use a connectors with socket contacts at the power side of the circuit.
3. Make sure that the coupling is in completely cocked position.
4. Use correct plug / receptacle to assure water protection.
9
RM-W Series●
Product Specifications (RM21WT to RM31WT size products)
Rating
Voltage rating
600V AC, 840V DC (40 pos.)
500V AC, 700V DC (15, 55 pos.)
350V AC, 490V DC (20 pos.)
Current rating
5A
Operating temperature range (Note 1)
-25ç to +85ç
-10ç to +60ç
Characteristic
Specification
Conditions
4mø max.
1A DC
1,000Mø min
500V DC
1,800V AC/1 minute (40 pos.)
1,500V AC/1 minute (15, 55 pos.)
1,000V AC/1 minute (20 pos.)
4. Vibration
No electrical discontinuity for 10μs max.
5. Shock
6. Durability
8mø max.
2,000 cycles
Time
8. Humidity
9. Water protection
Materials / Finish
Item
Material
Finish
Remarks
Body
Brass
Insulator
Contacts
Brass, copper alloy
Silver plated
Packing
Chloroprene rubber or SIR
(Color : Black)
Connector
Cap
RM 31 W T P** - 40 S (**)
RM 21 T P - C (**)
1
2
1
4
3
5
6
7
2
3
4
8
7
Strain Relief
RM 21 W T P - CP (10) (**)
1
2
1
3
4
8
9
7
5 No. of Pos.
2 Shell Size
3 Lock Type
T : Screw Lock
4 Connector Type
P : Plug
R : Receptacle
6 Contact Type
P : Male Contact
S : Female Contact
8 Accessory Type
C : Cap
CP : Strain Relief
9 CP Type and Applicable Cable Diameter
With ( )
: External Cable Clamp
Without ( ) : Internal Cable Clamp
Numbers : Cable Diameter
10
RM-W Series●
D
Set screw
E
8
RM21WTP-15P(31)
9
7
15
11
1
13
10
14
ØB
ØA
Y
6
12
5
2
3
Z
4
C
Part No.
RM21WTP-15S(31)
RM21WTP-15P(33)
RM21WTP-20S(31)
RM21WTP-20P(33)
RM31WTP-40P(33)
HRS No.
109-1401-2 31
109-1403-8 33
109-1402-5 31
109-1404-0 33
109-1573-8 33
No. of contacts
ØA
ØB
C
E
F
21
32
37.5
TM25∞2
M20∞0.75
30.8
42
52
TM35∞2
M28∞0.75
15
Weight
86g
85g
88g
85g
149g
Remarks
Silver
plated
only
JR16WCC-10(72)
ØA
ØB
E
Wrench opening dimension D
C
Part No.
JR16WCC-4(72)
JR16WCC-6(72)
JR16WCC-8(72)
JR16WCC-10(72)
JR16WCC-11(72)
JR16WCC-12(72)
HRS No.
114-2052-6 72
114-2053-9 72
114-2054-1 72
114-2055-4 72
114-2154-6 72
114-2056-7 72
ØA
4
6
8
10
11
12
ØB
C
D
E
Weight
Remarks
23
17.5
21
M20∞0.75
17.5g
For RM21WT
(No locking
screw attached)
Note 1 : Cable jacket diameter : Use A ± 0.2mm.
Note 3 : Recommended set screw tightening torque : 0.3 to 0.4N•m.
E
RM21WTP-CP(8)(71)
Set screw
ØB
ØA
Note : Recommended set screw tightening torque : 0.2 to 0.3 N•m.
D
C
Part No.
RM21WTP-CP(8)(71)
RM21WTP-CP(10)(71)
RM21WTP-CP(12)(71)
RM31WTP-CP(10)(71)
RM31WTP-CP(12)(71)
RM31WTP-CP(14)(71)
RM31WTP-CP(16)(71)
RM31WTP-CP(18)(71)
HRS No.
109-1405-3 71
109-1406-6 71
109-1407-9 71
109-1575-3 71
109-1576-6 71
109-1579-4 71
109-1577-9 71
109-1578-1 71
ØA
8
10
12
10
12
14
16
18
ØB
C
D
E
23
38
7.5
M20∞0.75
Weight
22.5g
22g
21.5g
Remarks
For RM21WT
46g
31
42
12
M28∞0.75
45g
43.5g
42g
For RM31WT
Note 2 : Code cramp No. should be the same as connector shell No.
Note 3 : When using the self-tightening strain relief verify the cable pull force requirements.
Note 4 : Recommended set screw tightening torque : 0.2 to 0.3N•m.
11
RM-W Series●
Receptacles
Front panel mount
2
Z
14
15
7
9
Y
Y
7
9
6
14
10
13
5
10
12
1
15
1
11
13
ØA
5
12
11
4
2
4
6
Z
3
3
RM21WTR-15P(31)
8
8
F
C
D
B
E
Part No.
HRS No.
No. of contacts
RM21WTR-15P(33)
109-1445-8 33
15
RM21WTR-20P(33)
109-1446-0 33
RM31WTR-40S(33)
109-1527-0 33
40
ØA
31
B
C
D
21
6.5
2.5
41
E
F
23.5
TM25∞2
34
TM35∞2
Weight
Remarks
28g
Silver
plated
only
31.5g
52g
Cap
Plug cap
100
Ø6
Part No.
RM21TP-C(71)
HRS No.
109-0353-6 71
ØA
28
B
TM25×2
C
17.5
D
22
D
C
φ3.3
B
ØA
Receptacle cap
100
Ø6
B
Part No.
RM21TR-C(31)
12
HRS No.
109-0354-9 31
ØA
28
B
TM25×2
C
8
D
12.5
ØA
D
C
Ø 3.3
RM-W Series●
Part No.
R
C
ØA
B
ØA
B
RC
For RM21WTR
22.1
12.75
0.8
For RM31WTR
32.1
17.75
0.85
Note : Tolelance is +0.1/0.
For RM**WTR receptacles
Shell size : 21
Contact arrangement
9
10
1
15
11
2
3
13
6
9
17
8
16
12
14
Number of contacts
Current rating
Contact resistance
10
8
7
Shell size : 31
4
5
15
7
15
6
18
19
1
11 2
12 3
18
13 4
5
5A
1,000Mø min.
4mø max.
1.1mm
17
16
15
14
31
30
29
13
19
32
39
1
2
21
34
40
38
35
37
28
12 27
26
11
10
36
25
9
3
4
22
5
23
24
6
7
8
40
Precautions
3. Make sure that the coupling is in completely locked position.
4. Use correct plug / receptacle to assure dust and water protection.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 10/2021. Contents are subject to change without notice for the purpose of improvements.
13
