nRF52832-QFAA-T
nRF52832-QFAA-T
    NORDIC(北欧)
    QFN48_6X6MM
    RF System on a Chip - SoC BLE ANT/ANT+ 2.4GHz SOC
nRF52832-QFAA-T 数据手册
nRF52832 Product Specification v1.4 Key features • 2.4 GHz transceiver • • -96 dBm sensitivity in Bluetooth® low energy mode • Supported data rates: 1 Mbps, 2 Mbps Bluetooth® low energy mode • -20 to +4 dBm TX power, configurable in 4 dB steps • On-chip balun (single-ended RF) • 5.3 mA peak current in TX (0 dBm) • 5.4 mA peak current in RX • RSSI (1 dB resolution) ARM® Cortex®-M4 32-bit processor with FPU, 64 MHz • • • • • • • • • • • • • • • • • • • • • • • • • • • • Applications • Internet of Things (IoT) • Home automation • Sensor networks • Building automation • Industrial • Retail Personal area networks • 215 EEMBC CoreMark® score running from flash memory 58 μA/MHz running from flash memory 51.6 μA/MHz running from RAM • Data watchpoint and trace (DWT), embedded trace macrocell (ETM), and instrumentation trace macrocell (ITM) • Serial wire debug (SWD) • • Trace port • Flexible power management • • 1.7 V–3.6 V supply voltage range • • Fully automatic LDO and DC/DC regulator system • Fast wake-up using 64 MHz internal oscillator • 0.3 μA at 3 V in System OFF mode • 0.7 μA at 3 V in System OFF mode with full 64 kB RAM retention • 1.9 μA at 3 V in System ON mode, no RAM retention, wake on RTC Memory • Health/fitness sensor and monitor devices • Medical devices • Key fobs and wrist watches Interactive entertainment devices • Remote controls • Gaming controllers Beacons A4WP wireless chargers and devices Remote control toys Computer peripherals and I/O devices • • • • Mouse Keyboard Multi-touch trackpad Gaming • 512 kB flash/64 kB RAM • 256 kB flash/32 kB RAM Nordic SoftDevice ready Support for concurrent multi-protocol Type 2 near field communication (NFC-A) tag with wakeup-on-field and touchto-pair capabilities 12-bit, 200 ksps ADC - 8 configurable channels with programmable gain 64 level comparator 15 level low power comparator with wakeup from System OFF mode Temperature sensor 32 general purpose I/O pins 3x 4-channel pulse width modulator (PWM) unit with EasyDMA Digital microphone interface (PDM) 5x 32-bit timer with counter mode Up to 3x SPI master/slave with EasyDMA Up to 2x I2C compatible 2-wire master/slave I2S with EasyDMA UART (CTS/RTS) with EasyDMA Programmable peripheral interconnect (PPI) Quadrature decoder (QDEC) AES HW encryption with EasyDMA Autonomous peripheral operation without CPU intervention using PPI and EasyDMA 3x real-time counter (RTC) Single crystal operation Package variants • • QFN48 package, 6 × 6 mm WLCSP package, 3.0 × 3.2 mm All rights reserved. Reproduction in whole or in part is prohibited without the prior written permission of the copyright holder. 2017-10-10 Contents Contents 1 Revision history................................................................................... 9 2 About this document............................................................................................ 10 2.1 2.2 2.3 2.4 Document naming and status............................................................................................... 10 Peripheral naming and abbreviations................................................................................... 10 Register tables...................................................................................................................... 10 Registers............................................................................................................................... 11 3 Block diagram........................................................................................................12 4 Pin assignments.................................................................................................... 13 4.1 QFN48 pin assignments....................................................................................................... 13 4.2 WLCSP ball assignments..................................................................................................... 15 4.3 GPIO usage restrictions........................................................................................................17 5 Absolute maximum ratings.................................................................................. 19 6 Recommended operating conditions.................................................................. 20 6.1 WLCSP light sensitivity......................................................................................................... 20 7 CPU......................................................................................................................... 21 7.1 Floating point interrupt.......................................................................................................... 21 7.2 Electrical specification........................................................................................................... 21 7.3 CPU and support module configuration................................................................................22 8 Memory................................................................................................................... 23 8.1 8.2 8.3 8.4 RAM - Random access memory...........................................................................................23 Flash - Non-volatile memory.................................................................................................24 Memory map......................................................................................................................... 24 Instantiation........................................................................................................................... 24 9 AHB multilayer.......................................................................................................26 9.1 AHB multilayer priorities........................................................................................................26 10 EasyDMA.............................................................................................................. 27 10.1 EasyDMA array list............................................................................................................. 28 11 NVMC — Non-volatile memory controller......................................................... 29 11.1 11.2 11.3 11.4 11.5 11.6 11.7 11.8 Writing to Flash...................................................................................................................29 Erasing a page in Flash..................................................................................................... 29 Writing to user information configuration registers (UICR)................................................. 29 Erasing user information configuration registers (UICR).................................................... 29 Erase all.............................................................................................................................. 30 Cache.................................................................................................................................. 30 Registers............................................................................................................................. 30 Electrical specification......................................................................................................... 33 12 BPROT — Block protection................................................................................34 12.1 Registers............................................................................................................................. 34 13 FICR — Factory information configuration registers.......................................43 13.1 Registers............................................................................................................................. 43 14 UICR — User information configuration registers........................................... 54 14.1 Registers............................................................................................................................. 54 15 Peripheral interface............................................................................................. 68 15.1 15.2 15.3 15.4 15.5 15.6 Peripheral ID....................................................................................................................... 68 Peripherals with shared ID..................................................................................................68 Peripheral registers............................................................................................................. 69 Bit set and clear..................................................................................................................69 Tasks................................................................................................................................... 69 Events..................................................................................................................................70 Page 2 Contents 15.7 Shortcuts............................................................................................................................. 70 15.8 Interrupts............................................................................................................................. 70 16 Debug and trace.................................................................................................. 72 16.1 16.2 16.3 16.4 16.5 DAP - Debug Access Port.................................................................................................. 72 CTRL-AP - Control Access Port......................................................................................... 73 Debug interface mode.........................................................................................................74 Real-time debug.................................................................................................................. 74 Trace................................................................................................................................... 75 17 Power and clock management...........................................................................76 17.1 Current consumption scenarios.......................................................................................... 76 18 POWER — Power supply....................................................................................78 18.1 Regulators........................................................................................................................... 78 18.2 System OFF mode..............................................................................................................79 18.3 System ON mode............................................................................................................... 80 18.4 Power supply supervisor.....................................................................................................80 18.5 RAM sections...................................................................................................................... 82 18.6 Reset................................................................................................................................... 82 18.7 Retained registers............................................................................................................... 83 18.8 Reset behavior.................................................................................................................... 83 18.9 Registers............................................................................................................................. 83 18.10 Electrical specification....................................................................................................... 99 19 CLOCK — Clock control...................................................................................101 19.1 19.2 19.3 19.4 HFCLK clock controller..................................................................................................... 101 LFCLK clock controller......................................................................................................103 Registers........................................................................................................................... 105 Electrical specification....................................................................................................... 109 20 GPIO — General purpose input/output........................................................... 111 20.1 20.2 20.3 20.4 Pin configuration............................................................................................................... 111 GPIO located near the RADIO......................................................................................... 113 Registers........................................................................................................................... 113 Electrical specification....................................................................................................... 154 21 GPIOTE — GPIO tasks and events..................................................................157 21.1 21.2 21.3 21.4 21.5 Pin events and tasks........................................................................................................ 157 Port event..........................................................................................................................158 Tasks and events pin configuration.................................................................................. 158 Registers........................................................................................................................... 158 Electrical specification....................................................................................................... 167 22 PPI — Programmable peripheral interconnect............................................... 168 22.1 Pre-programmed channels................................................................................................169 22.2 Registers........................................................................................................................... 169 23 RADIO — 2.4 GHz Radio.................................................................................. 205 23.1 EasyDMA...........................................................................................................................205 23.2 Packet configuration..........................................................................................................206 23.3 Maximum packet length.................................................................................................... 207 23.4 Address configuration........................................................................................................207 23.5 Data whitening.................................................................................................................. 207 23.6 CRC...................................................................................................................................208 23.7 Radio states...................................................................................................................... 209 23.8 Transmit sequence............................................................................................................209 23.9 Receive sequence.............................................................................................................211 23.10 Received Signal Strength Indicator (RSSI).....................................................................212 23.11 Interframe spacing...........................................................................................................212 23.12 Device address match.................................................................................................... 213 23.13 Bit counter....................................................................................................................... 213 23.14 Registers......................................................................................................................... 214 23.15 Electrical specification..................................................................................................... 230 24 TIMER — Timer/counter....................................................................................234 Page 3 Contents 24.1 24.2 24.3 24.4 24.5 24.6 Capture..............................................................................................................................235 Compare............................................................................................................................235 Task delays....................................................................................................................... 235 Task priority.......................................................................................................................235 Registers........................................................................................................................... 235 Electrical specification....................................................................................................... 241 25 RTC — Real-time counter.................................................................................242 25.1 Clock source..................................................................................................................... 242 25.2 Resolution versus overflow and the PRESCALER........................................................... 242 25.3 COUNTER register............................................................................................................243 25.4 Overflow features.............................................................................................................. 243 25.5 TICK event........................................................................................................................ 243 25.6 Event control feature.........................................................................................................244 25.7 Compare feature............................................................................................................... 244 25.8 TASK and EVENT jitter/delay........................................................................................... 246 25.9 Reading the COUNTER register.......................................................................................248 25.10 Registers......................................................................................................................... 248 25.11 Electrical specification..................................................................................................... 254 26 RNG — Random number generator................................................................ 255 26.1 26.2 26.3 26.4 Bias correction.................................................................................................................. 255 Speed................................................................................................................................ 255 Registers........................................................................................................................... 255 Electrical specification....................................................................................................... 257 27 TEMP — Temperature sensor.......................................................................... 258 27.1 Registers........................................................................................................................... 258 27.2 Electrical specification....................................................................................................... 263 28 ECB — AES electronic codebook mode encryption...................................... 264 28.1 28.2 28.3 28.4 28.5 Shared resources.............................................................................................................. 264 EasyDMA...........................................................................................................................264 ECB data structure............................................................................................................264 Registers........................................................................................................................... 265 Electrical specification....................................................................................................... 266 29 CCM — AES CCM mode encryption................................................................267 29.1 29.2 29.3 29.4 29.5 29.6 29.7 29.8 29.9 Shared resources.............................................................................................................. 268 Encryption..........................................................................................................................268 Decryption......................................................................................................................... 268 AES CCM and RADIO concurrent operation.................................................................... 269 Encrypting packets on-the-fly in radio transmit mode.......................................................269 Decrypting packets on-the-fly in radio receive mode........................................................270 CCM data structure...........................................................................................................271 EasyDMA and ERROR event........................................................................................... 272 Registers........................................................................................................................... 272 30 AAR — Accelerated address resolver.............................................................276 30.1 Shared resources.............................................................................................................. 276 30.2 EasyDMA...........................................................................................................................276 30.3 Resolving a resolvable address........................................................................................276 30.4 Use case example for chaining RADIO packet reception with address resolution using AAR.......................................................................................................................................277 30.5 IRK data structure............................................................................................................. 277 30.6 Registers........................................................................................................................... 278 30.7 Electrical specification....................................................................................................... 280 31 SPIM — Serial peripheral interface master with EasyDMA............................281 31.1 31.2 31.3 31.4 31.5 Shared resources.............................................................................................................. 281 EasyDMA...........................................................................................................................282 SPI master transaction sequence..................................................................................... 283 Low power.........................................................................................................................284 Master mode pin configuration......................................................................................... 284 Page 4 Contents 31.6 Registers........................................................................................................................... 285 31.7 Electrical specification....................................................................................................... 290 32 SPIS — Serial peripheral interface slave with EasyDMA...............................292 32.1 32.2 32.3 32.4 32.5 32.6 Shared resources.............................................................................................................. 292 EasyDMA...........................................................................................................................292 SPI slave operation...........................................................................................................293 Pin configuration............................................................................................................... 294 Registers........................................................................................................................... 295 Electrical specification....................................................................................................... 303 2 33 TWIM — I C compatible two-wire interface master with EasyDMA...............305 33.1 33.2 33.3 33.4 33.5 33.6 33.7 33.8 33.9 Shared resources.............................................................................................................. 306 EasyDMA...........................................................................................................................306 Master write sequence......................................................................................................307 Master read sequence...................................................................................................... 308 Master repeated start sequence....................................................................................... 309 Low power.........................................................................................................................310 Master mode pin configuration......................................................................................... 310 Registers........................................................................................................................... 310 Electrical specification....................................................................................................... 317 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA.................. 319 34.1 Shared resources.............................................................................................................. 321 34.2 EasyDMA...........................................................................................................................321 34.3 TWI slave responding to a read command.......................................................................321 34.4 TWI slave responding to a write command...................................................................... 322 34.5 Master repeated start sequence....................................................................................... 323 34.6 Terminating an ongoing TWI transaction..........................................................................324 34.7 Low power.........................................................................................................................324 34.8 Slave mode pin configuration........................................................................................... 324 34.9 Registers........................................................................................................................... 325 34.10 Electrical specification..................................................................................................... 331 35 UARTE — Universal asynchronous receiver/transmitter with EasyDMA.... 333 35.1 Shared resources.............................................................................................................. 333 35.2 EasyDMA...........................................................................................................................333 35.3 Transmission..................................................................................................................... 334 35.4 Reception.......................................................................................................................... 334 35.5 Error conditions................................................................................................................. 336 35.6 Using the UARTE without flow control............................................................................. 336 35.7 Parity configuration............................................................................................................336 35.8 Low power.........................................................................................................................336 35.9 Pin configuration............................................................................................................... 337 35.10 Registers......................................................................................................................... 337 35.11 Electrical specification..................................................................................................... 345 36 QDEC — Quadrature decoder.......................................................................... 347 36.1 36.2 36.3 36.4 36.5 36.6 36.7 36.8 Sampling and decoding.................................................................................................... 347 LED output........................................................................................................................ 348 Debounce filters................................................................................................................ 348 Accumulators.....................................................................................................................349 Output/input pins............................................................................................................... 349 Pin configuration............................................................................................................... 349 Registers........................................................................................................................... 350 Electrical specification....................................................................................................... 356 37 SAADC — Successive approximation analog-to-digital converter............... 357 37.1 37.2 37.3 37.4 37.5 Shared resources.............................................................................................................. 357 Overview............................................................................................................................357 Digital output..................................................................................................................... 358 Analog inputs and channels..............................................................................................359 Operation modes...............................................................................................................359 Page 5 Contents 37.6 EasyDMA...........................................................................................................................361 37.7 Resistor ladder.................................................................................................................. 362 37.8 Reference.......................................................................................................................... 363 37.9 Acquisition time................................................................................................................. 363 37.10 Limits event monitoring................................................................................................... 364 37.11 Registers......................................................................................................................... 365 37.12 Electrical specification..................................................................................................... 389 37.13 Performance factors........................................................................................................ 391 38 COMP — Comparator........................................................................................392 38.1 38.2 38.3 38.4 Differential mode............................................................................................................... 393 Single-ended mode........................................................................................................... 394 Registers........................................................................................................................... 396 Electrical specification....................................................................................................... 401 39 LPCOMP — Low power comparator................................................................402 39.1 39.2 39.3 39.4 Shared resources.............................................................................................................. 403 Pin configuration............................................................................................................... 403 Registers........................................................................................................................... 404 Electrical specification....................................................................................................... 408 40 WDT — Watchdog timer................................................................................... 409 40.1 40.2 40.3 40.4 40.5 Reload criteria................................................................................................................... 409 Temporarily pausing the watchdog................................................................................... 409 Watchdog reset................................................................................................................. 409 Registers........................................................................................................................... 410 Electrical specification....................................................................................................... 414 41 SWI — Software interrupts...............................................................................415 41.1 Registers........................................................................................................................... 415 42 NFCT — Near field communication tag...........................................................416 42.1 Overview............................................................................................................................416 42.2 Pin configuration............................................................................................................... 418 42.3 EasyDMA...........................................................................................................................418 42.4 Collision resolution............................................................................................................ 419 42.5 Frame timing controller..................................................................................................... 420 42.6 Frame assembler.............................................................................................................. 421 42.7 Frame disassembler..........................................................................................................422 42.8 Antenna interface.............................................................................................................. 423 42.9 NFCT antenna recommendations..................................................................................... 423 42.10 Battery protection............................................................................................................ 423 42.11 References...................................................................................................................... 424 42.12 Registers......................................................................................................................... 424 42.13 Electrical specification..................................................................................................... 435 43 PDM — Pulse density modulation interface................................................... 436 2 43.1 43.2 43.3 43.4 43.5 43.6 43.7 43.8 Master clock generator..................................................................................................... 436 Module operation.............................................................................................................. 436 Decimation filter................................................................................................................ 437 EasyDMA...........................................................................................................................437 Hardware example............................................................................................................ 438 Pin configuration............................................................................................................... 438 Registers........................................................................................................................... 439 Electrical specification....................................................................................................... 443 44 I S — Inter-IC sound interface......................................................................... 445 44.1 44.2 44.3 44.4 44.5 44.6 44.7 Mode..................................................................................................................................445 Transmitting and receiving................................................................................................ 445 Left right clock (LRCK)..................................................................................................... 446 Serial clock (SCK).............................................................................................................446 Master clock (MCK).......................................................................................................... 447 Width, alignment and format.............................................................................................447 EasyDMA...........................................................................................................................449 Page 6 Contents 44.8 Module operation.............................................................................................................. 451 44.9 Pin configuration............................................................................................................... 452 44.10 Registers......................................................................................................................... 453 44.11 Electrical specification..................................................................................................... 460 45 MWU — Memory watch unit.............................................................................461 45.1 Registers........................................................................................................................... 461 46 EGU — Event generator unit............................................................................488 46.1 Registers........................................................................................................................... 488 46.2 Electrical specification....................................................................................................... 494 47 PWM — Pulse width modulation..................................................................... 495 47.1 47.2 47.3 47.4 47.5 47.6 Wave counter.................................................................................................................... 495 Decoder with EasyDMA.................................................................................................... 498 Limitations......................................................................................................................... 503 Pin configuration............................................................................................................... 503 Registers........................................................................................................................... 504 Electrical specification....................................................................................................... 512 48 SPI — Serial peripheral interface master........................................................513 48.1 Functional description....................................................................................................... 513 48.2 Registers........................................................................................................................... 516 48.3 Electrical specification....................................................................................................... 519 2 49 TWI — I C compatible two-wire interface....................................................... 521 49.1 49.2 49.3 49.4 49.5 49.6 49.7 49.8 49.9 Functional description....................................................................................................... 521 Master mode pin configuration......................................................................................... 521 Shared resources.............................................................................................................. 522 Master write sequence......................................................................................................522 Master read sequence...................................................................................................... 523 Master repeated start sequence....................................................................................... 524 Low power.........................................................................................................................525 Registers........................................................................................................................... 525 Electrical specification....................................................................................................... 529 50 UART — Universal asynchronous receiver/transmitter................................. 531 50.1 Functional description....................................................................................................... 531 50.2 Pin configuration............................................................................................................... 531 50.3 Shared resources.............................................................................................................. 532 50.4 Transmission..................................................................................................................... 532 50.5 Reception.......................................................................................................................... 532 50.6 Suspending the UART...................................................................................................... 533 50.7 Error conditions................................................................................................................. 533 50.8 Using the UART without flow control................................................................................534 50.9 Parity configuration............................................................................................................534 50.10 Registers......................................................................................................................... 534 50.11 Electrical specification..................................................................................................... 539 51 Mechanical specifications................................................................................ 540 51.1 QFN48 6 x 6 mm package............................................................................................... 540 51.2 WLCSP package............................................................................................................... 541 52 Ordering information.........................................................................................542 52.1 52.2 52.3 52.4 52.5 IC marking.........................................................................................................................542 Box labels..........................................................................................................................542 Order code........................................................................................................................ 543 Code ranges and values...................................................................................................543 Product options................................................................................................................. 544 53 Reference circuitry............................................................................................ 545 53.1 Schematic QFAA and QFAB QFN48 with internal LDO setup......................................... 545 53.2 Schematic QFAA and QFAB QFN48 with DC/DC regulator setup................................... 546 53.3 Schematic QFAA and QFAB QFN48 with DC/DC regulator and NFC setup.................... 547 53.4 Schematic CIAA WLCSP with internal LDO setup........................................................... 548 53.5 Schematic CIAA WLCSP with DC/DC regulator setup..................................................... 549 Page 7 Contents 53.6 Schematic CIAA WLCSP with DC/DC regulator and NFC setup......................................550 53.7 PCB guidelines..................................................................................................................550 53.8 PCB layout example......................................................................................................... 551 54 Liability disclaimer............................................................................................ 553 54.1 RoHS and REACH statement...........................................................................................553 54.2 Life support applications................................................................................................... 553 Page 8 1 Revision history 1 Revision history Date October 2017 Version 1.4 Description The following content has been added or updated: Recommended operating conditions on page 20: Added WLCSP light sensitivity information. • FICR — Factory information configuration registers on page 43: Added registers PARTNO, HWREVISION and PRODUCTIONREVISION. • UICR — User information configuration registers on page 54: Changed width of PSELRESETn port fields. • SPIM: Polarity in SPI mode table corrected. • COMP — Comparator on page 392: Documentation structure improvements/changes. • Liability disclaimer updated: Directive 2011/65/EU (RoHS 2). The following content has been added or updated: • February 2017 1.3 RADIO — 2.4 GHz Radio on page 205: Introduced 2 Mbps Bluetooth® low energy mode. • FICR — Factory information configuration registers on page 43: Updated INFO.PACKAGE register (new package added). • UARTE: Corrected the pin configuration table. • PPI — Programmable peripheral interconnect on page 168: Timing information corrected. • Updated the liability disclaimer. Updated the following: • September 2016 1.2 Power and clock management, Current consumption: Ultra-low power on page 77. • Power, Current consumption, sleep on page 99 Added documentation for nRF52832 CIAA WLCSP. • July 2016 1.1 Added or updated the following content: Cover: Added Key features. Pin assignments on page 13: Added WLCSP ball assignments. Moved GPIO usage restrictions here from GPIO/Notes on usage and restrictions. • Absolute maximum ratings on page 19: Added environmental information for WLCSP to the table. • Memory on page 23: Added QFAB and CIAA information to the table. • FICR — Factory information configuration registers on page 43: Updated INFO.PACKAGE register. • UICR — User information configuration registers on page 54: Updated APPROTECT register. • Debug and trace on page 72: Updated DAP Debug access port. • POWER — Power supply on page 78: Updated Pin reset. • CLOCK — Clock control on page 101: Updated information on external 32 kHz clock support. • GPIO — General purpose input/output on page 111: Added GPIO located near the RADIO. • RADIO — 2.4 GHz Radio on page 205: Updated Figure 29 and Interframe spacing. • CCM: Updated SCRATCHPTR register. • SPIM: Updated Master mode pin configuration. • UARTE: Added RXDRDY and TXDRDY events. • NFCT: Updated Electrical specifications. • PWM — Pulse width modulation on page 495: Updated SEQ[1].REFRESH register. • Mechanical specifications on page 540: Added WLCSP package. • Ordering information on page 542: Updated with CIAA and QFAB information. • Reference circuitry on page 545: QFAB information added. CIAA WLCSP schematics added. First release. • • February 2016 1.0 Page 9 2 About this document 2 About this document This product specification is organized into chapters based on the modules and peripherals that are available in this IC. The peripheral descriptions are divided into separate sections that include the following information: • • • A detailed functional description of the peripheral Register configuration for the peripheral Electrical specification tables, containing performance data which apply for the operating conditions described in Recommended operating conditions on page 20. 2.1 Document naming and status Nordic uses three distinct names for this document, which are reflecting the maturity and the status of the document and its content. Table 1: Defined document names Document name Objective Product Specification (OPS) Description Applies to document versions up to 0.7. Preliminary Product Specification (PPS) This product specification contains target specifications for product development. Applies to document versions 0.7 and up to 1.0. Product Specification (PS) This product specification contains preliminary data. Supplementary data may be published from Nordic Semiconductor ASA later. Applies to document versions 1.0 and higher. This product specification contains final product specifications. Nordic Semiconductor ASA reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. 2.2 Peripheral naming and abbreviations Every peripheral has a unique capitalized name or an abbreviation of its name, e.g. TIMER, used for identification and reference. This name is used in chapter headings and references, and it will appear in the ARM® Cortex® Microcontroller Software Interface Standard (CMSIS) hardware abstraction layer to identify the peripheral. The peripheral instance name, which is different from the peripheral name, is constructed using the peripheral name followed by a numbered postfix, starting with 0, for example, TIMER0. A postfix is normally only used if a peripheral can be instantiated more than once. The peripheral instance name is also used in the CMSIS to identify the peripheral instance. 2.3 Register tables Individual registers are described using register tables. These tables are built up of two sections. The first three colored rows describe the position and size of the different fields in the register. The following rows describe the fields in more detail. 2.3.1 Fields and values The Id (Field Id) row specifies the bits that belong to the different fields in the register. If a field has enumerated values, then every value will be identified with a unique value id in the Value Id column. A blank space means that the field is reserved and read as undefined, and it also must be written as 0 to secure forward compatibility. If a register is divided into more than one field, a unique field name is specified for each field in the Field column. The Value Id may be omitted in the single-bit bit fields when values can be substituted with a Boolean type enumerator range, e.g. true/false, disable(d)/enable(d), on/off, and so on. Page 10 2 About this document Values are usually provided as decimal or hexadecimal. Hexadecimal values have a 0x prefix, decimal values have no prefix. The Value column can be populated in the following ways: • • • Individual enumerated values, for example 1, 3, 9. Range of values, e.g. [0..4], indicating all values from and including 0 and 4. Implicit values. If no values are indicated in the Value column, all bit combinations are supported, or alternatively the field's translation and limitations are described in the text instead. If two or more fields are closely related, the Value Id, Value, and Description may be omitted for all but the first field. Subsequent fields will indicate inheritance with '..'. A feature marked Deprecated should not be used for new designs. 2.4 Registers Table 2: Register Overview Register Offset Description DUMMY 0x514 Example of a register controlling a dummy feature 2.4.1 DUMMY Address offset: 0x514 Example of a register controlling a dummy feature Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D Reset 0x00050002 Id RW Field A RW FIELD_A B C D 0 C C C B A A 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 Value Id Value Description Disabled 0 The example feature is disabled NormalMode 1 The example feature is enabled in normal mode ExtendedMode 2 The example feature is enabled along with extra functionality Disabled 0 The override feature is disabled Enabled 1 The override feature is enabled ValidRange [2..7] Example of a field with several enumerated values RW FIELD_B Example of a deprecated field RW FIELD_C Example of a field with a valid range of values Example of allowed values for this field RW FIELD_D Example of a field with no restriction on the values Page 11 Deprecated 3 Block diagram 3 Block diagram This block diagram illustrates the overall system. Arrows with white heads indicate signals that share physical pins with other signals. SWCLK RAM7 GPIO P0 (P0.0 – P0.31) slave RAM6 slave RAM5 slave slave RAM4 slave RAM3 slave RAM2 slave TPIU RAM1 slave TP RAM0 slave nRF52832 SW-DP ETM slave slave slave master AHB-AP slave AHB Multi-Layer CTRL-AP slave SWDIO I-Cache AHB TO APB BRIDGE CPU FICR UICR Flash ARM CORTEX-M4 NVIC nRESET NVMC SysTick RNG POWER RTC [0..2] TIMER [0..4] WDT TEMP PPI XC1 XC2 XL1 ECB CLOCK EasyDMA master XL2 CCM ANT2 EasyDMA NFC2 NFC1 NFCT EasyDMA master ma s master master OUT0 – OUT3 PWM[0..3] SDA SCL SDA EasyDMA RTS CTS TXD RXD master master EasyDMA CSN I2S SPIS [0..2] MISO MOSI SCK EasyDMA CLK DIN TWIM [0..1] master SCL EasyDMA UARTE [0] EasyDMA MCK LRCK SCL SDOUT SDIN master SAADC QDEC EasyDMA TWIS [0..1] master MOSI MISO master LPCOMP LED A B AAR EasyDMA SCK COMP EasyDMA ter SPIM [0..2] GPIOTE AIN0 – AIN7 EasyDMA master RADIO APB0 ANT1 master PDM EasyDMA master Figure 1: Block diagram Page 12 master EasyDMA 4 Pin assignments 4 Pin assignments Here we cover the pin assignments for each variant of the chip. 4.1 QFN48 pin assignments P0.25 P0.26 P0.27 P0.28/AIN4 P0.29/AIN5 P0.30/AIN6 P0.31/AIN7 NC VSS DEC4 DCC VDD 37 38 39 40 41 42 43 44 46 45 48 47 DEC1 P0.00/XL1 P0.01/XL2 P0.02/AIN0 P0.03/AIN1 P0.04/AIN2 P0.05/AIN3 P0.06 P0.07 P0.08 NFC1/P0.09 NFC2/P0.10 1 36 2 35 3 34 4 33 5 32 nRF5102 N52832 QFN48 QFN48 6 7 8 31 30 29 9 28 10 27 exposed die pad 11 26 12 25 VDD XC2 XC1 DEC3 DEC2 VSS ANT P0.24 P0.23 P0.22 SWDIO SWDCLK 24 23 22 21 20 19 18 17 16 15 14 13 P0.21/nRESET P0.20/TRACECLK P0.19 P0.18/TRACEDATA[0]/SWO P0.17 P0.16/TRACEDATA[1] P0.15/TRACEDATA[2] P0.14/TRACEDATA[3] P0.13 P0.12 P0.11 VDD Figure 2: QFN48 pin assignments, top view Table 3: QFN48 pin assignments Pin Name Type Description 1 DEC1 Power 0.9 V regulator digital supply decoupling 2 P0.00 Digital I/O General purpose I/O XL1 Analog input Connection for 32.768 kHz crystal (LFXO) P0.01 Digital I/O General purpose I/O XL2 Analog input Connection for 32.768 kHz crystal (LFXO) P0.02 Digital I/O General purpose I/O AIN0 Analog input SAADC/COMP/LPCOMP input P0.03 Digital I/O General purpose I/O AIN1 Analog input SAADC/COMP/LPCOMP input P0.04 Digital I/O General purpose I/O AIN2 Analog input SAADC/COMP/LPCOMP input P0.05 Digital I/O General purpose I/O Left Side of chip 3 4 5 6 7 AIN3 Analog input SAADC/COMP/LPCOMP input 8 P0.06 Digital I/O General purpose I/O 9 P0.07 Digital I/O General purpose I/O Page 13 4 Pin assignments Pin Name Type Description 10 P0.08 Digital I/O General purpose I/O 11 NFC1 NFC input NFC antenna connection P0.09 Digital I/O General purpose I/O1 NFC2 NFC input NFC antenna connection P0.10 Digital I/O General purpose I/O1 13 VDD Power Power supply 14 P0.11 Digital I/O General purpose I/O 15 P0.12 Digital I/O General purpose I/O 16 P0.13 Digital I/O General purpose I/O 17 P0.14 Digital I/O General purpose I/O 12 Bottom side of chip TRACEDATA[3] 18 P0.15 Trace port output Digital I/O TRACEDATA[2] 19 P0.16 General purpose I/O Trace port output Digital I/O TRACEDATA[1] General purpose I/O Trace port output 20 P0.17 Digital I/O General purpose I/O 21 P0.18 Digital I/O General purpose I/O TRACEDATA[0] / SWO Single wire output Trace port output 22 P0.19 Digital I/O General purpose I/O 23 P0.20 Digital I/O General purpose I/O TRACECLK 24 P0.21 Trace port clock output Digital I/O nRESET General purpose I/O Configurable as pin reset Right Side of chip 25 SWDCLK Digital input Serial wire debug clock input for debug 26 SWDIO Digital I/O 27 P0.22 Digital I/O General purpose I/O2 28 P0.23 Digital I/O General purpose I/O2 29 P0.24 Digital I/O General purpose I/O2 30 ANT RF Single-ended radio antenna connection 31 VSS Power Ground (Radio supply) 32 DEC2 Power 1.3 V regulator supply decoupling (Radio 33 DEC3 Power Power supply decoupling 34 XC1 Analog input Connection for 32 MHz crystal 35 XC2 Analog input Connection for 32 MHz crystal 36 VDD Power Power supply 37 P0.25 Digital I/O General purpose I/O2 38 P0.26 Digital I/O General purpose I/O2 39 P0.27 Digital I/O General purpose I/O2 40 P0.28 Digital I/O General purpose I/O2 AIN4 Analog input SAADC/COMP/LPCOMP input P0.29 Digital I/O General purpose I/O2 AIN5 Analog input SAADC/COMP/LPCOMP input P0.30 Digital I/O General purpose I/O2 AIN6 Analog input SAADC/COMP/LPCOMP input P0.31 Digital I/O General purpose I/O pin2 AIN7 Analog input SAADC/COMP/LPCOMP input and programming Serial wire debug I/O for debug and programming supply) Top side of chip 41 42 43 Page 14 4 Pin assignments Pin Name 44 NC Type Description 45 VSS Power Ground 46 DEC4 Power 1.3 V regulator supply decoupling No connect Leave unconnected Input from DC/DC regulator Output from 1.3 V LDO 47 DCC Power DC/DC regulator output 48 VDD Power Power supply VSS Power Ground pad Bottom of chip Die pad Exposed die pad must be connected to ground (VSS) for proper device operation. 4.2 WLCSP ball assignments 1 2 3 4 5 6 7 A B C D E F N52832 CIAAHP YYWWLL G H Figure 3: WLCSP ball assignments, top view Table 4: WLCSP ball assignments Ball Name A1 XC2 Analog input Description Connection for 32 MHz crystal A2 DEC2 Power 1.3 V regulator supply decoupling (Radio A3 P0.28 Digital I/O General purpose I/O3 AIN4 Analog input SAADC/COMP/LPCOMP input P0.29 Digital I/O General purpose I/O3 AIN5 Analog input SAADC/COMP/LPCOMP input P0.30 Digital I/O General purpose I/O3 AIN6 Analog input SAADC/COMP/LPCOMP input DEC4 Power 1.3 V regulator supply decoupling supply) A4 A5 A6 Input from DC/DC converter. Output from 1.3 V LDO A7 VDD Power Power supply B2 XC1 Analog input Connection for 32 MHz crystal B3 P0.25 Digital I/O General purpose I/O3 1 2 See GPIO located near the radio on page 17 for more information. See NFC antenna pins on page 17 for more information. Page 15 4 Pin assignments Ball Name B4 P0.27 Digital I/O Description General purpose I/O3 B5 P0.31 Digital I/O General purpose I/O3 AIN7 Analog input SAADC/COMP/LPCOMP input B6 DCC Power DC/DC converter output B7 DEC1 Power 0.9 V regulator digital supply decoupling C2 DEC3 Power Power supply decoupling C3 NC N/A Not connected C4 VSS Power Ground C5 VSS Power Ground C6 P0.02 Digital I/O General purpose I/O AIN0 Analog input SAADC/COMP/LPCOMP input P0.01 Digital I/O General purpose I/O C7 XL2 Analog input Connection for 32.768 kHz crystal (LFXO) D1 ANT RF Single-ended radio antenna connection D2 VSS_PA Power Ground (Radio supply) D3 P0.26 Digital I/O General purpose I/O 3 D6 P0.03 Digital I/O General purpose I/O AIN1 Analog input SAADC/COMP/LPCOMP input P0.00 Digital I/O General purpose I/O D7 XL1 Analog input Connection for 32.768 kHz crystal (LFXO) E1 P0.24 Digital I/O General purpose I/O3 E2 P0.23 Digital I/O General purpose I/O3 E3 VSS Power Ground E6 P0.04 Digital I/O General purpose I/O AIN2 Analog input SAADC/COMP/LPCOMP input P0.05 Digital I/O General purpose I/O E7 AIN3 Analog input SAADC/COMP/LPCOMP input F1 SWDCLK Digital input Serial wire debug clock input for debug F2 P0.22 Digital I/O General purpose I/O3 F3 P0.19 Digital I/O General purpose I/O F4 P0.11 Digital I/O General purpose I/O F5 VSS Power Ground F6 P0.07 Digital I/O General purpose I/O F7 P0.06 Digital I/O General purpose I/O G1 SWDIO Digital I/O Serial wire debug I/O for debug and G2 P0.20 Digital I/O and programming programming TRACECLK General purpose I/O Trace port clock output G3 P0.17 Digital I/O General purpose I/O G4 P0.13 Digital I/O General purpose I/O G5 NFC2 NFC input NFC antenna connection P0.10 Digital I/O General purpose I/O4 NFC1 NFC input NFC antenna connection P0.09 Digital I/O General purpose I/O4 G7 P0.08 Digital I/O General purpose I/O H1 P0.21 Digital I/O General purpose I/O G6 nRESET H2 P0.18 Configurable as pin reset Digital I/O TRACEDATA[0] H3 P0.16 Trace port output Digital I/O TRACEDATA[1] H4 P0.15 General purpose I/O General purpose I/O Trace port output Digital I/O Page 16 General purpose I/O 4 Pin assignments Ball Name Description TRACEDATA[2] H5 P0.14 Trace port output Digital I/O TRACEDATA[3] General purpose I/O Trace port output H6 P0.12 Digital I/O General purpose I/O H7 VDD Power Power supply 4.3 GPIO usage restrictions 4.3.1 GPIO located near the radio Radio performance parameters, such as sensitivity, may be affected by high frequency digital I/O with large sink/source current close to the Radio power supply and antenna pins. Table 5: GPIO recommended usage for QFN48 package on page 17 and Table 6: GPIO recommended usage for WLCSP package on page 17 identify some GPIO that have recommended usage guidelines to maximize radio performance in an application. Table 5: GPIO recommended usage for QFN48 package Pin 27 28 29 37 38 39 40 41 42 43 GPIO P0.22 P0.23 P0.24 P0.25 P0.26 P0.27 P0.28 P0.29 P0.30 P0.31 Recommended usage Low drive, low frequency I/O only. Table 6: GPIO recommended usage for WLCSP package Pin F2 E2 E1 B3 D3 B4 A3 A4 A5 B5 GPIO P0.22 P0.23 P0.24 P0.25 P0.26 P0.27 P0.28 P0.29 P0.30 P0.31 Recommended usage Low drive, low frequency I/O only. 4.3.2 NFC antenna pins Two physical pins can be configured either as NFC antenna pins (factory default), or as GPIOs, as shown below. Table 7: GPIO pins used by NFC NFC pad name NFC1 NFC2 GPIO P0.09 P0.10 When configured as NFC antenna pins, the GPIOs on those pins will automatically be set to DISABLE state and a protection circuit will be enabled preventing the chip from being damaged in the presence of a strong NFC field. The protection circuit will short the two pins together if voltage difference exceeds approximately 2 V. 3 4 See GPIO located near the radio on page 17 for more information. See NFC antenna pins on page 17 for more information. Page 17 4 Pin assignments For information on how to configure these pins as normal GPIOs, see NFCT — Near field communication tag on page 416 and UICR — User information configuration registers on page 54. Note that the device will not be protected against strong NFC field damage if the pins are configured as GPIO and an NFC antenna is connected to the device. The pins will always be configured as NFC pins during power-on reset until the configuration is set according to the UICR register. These two pins will have some limitations when configured as GPIO. The pin capacitance will be higher on these pins, and there is some current leakage between the two pins if they are driven to different logical values. To avoid leakage between the pins when configured as GPIO, these GPIOs should always be at the same logical value whenever entering one of the device power saving modes. See Electrical specification. Page 18 5 Absolute maximum ratings 5 Absolute maximum ratings Maximum ratings are the extreme limits to which the chip can be exposed for a limited amount of time without permanently damaging it. Exposure to absolute maximum ratings for prolonged periods of time may affect the reliability of the device. Table 8: Absolute maximum ratings Supply voltages VDD VSS I/O pin voltage VI/O, VDD ≤3.6 V VI/O, VDD >3.6 V NFC antenna pin current INFC1/2 Radio RF input level Environmental QFN48, 6×6 mm package Storage temperature MSL (moisture sensitivity level) ESD HBM (human body model) ESD CDM (charged device model) Environmental WLCSP, 3.0×3.2 mm package Storage temperature MSL ESD HBM ESD CDM Flash memory Endurance Retention Min. Max. Unit -0.3 +3.9 0 V V -0.3 -0.3 VDD + 0.3 V 3.9 V V V 80 mA 10 dBm +125 2 4 1000 °C +125 1 2 500 °C -40 -40 10 000 10 years at 40°C Page 19 kV V kV V Write/erase cycles 6 Recommended operating conditions 6 Recommended operating conditions The operating conditions are the physical parameters that the chip can operate within. Table 9: Recommended operating conditions Symbol VDD tR_VDD TA Parameter Supply voltage, independent of DCDC enable Supply rise time (0 V to 1.7 V) Operating temperature Notes Min. 1.7 Nom. 3.0 -40 25 Max. 3.6 60 85 Units V ms °C Important: The on-chip power-on reset circuitry may not function properly for rise times longer than the specified maximum. 6.1 WLCSP light sensitivity All WLCSP package variants are sensitive to visible and close-range infrared light. This means that a final product design must shield the chip properly, either by final product encapsulation or by shielding/coating of the WLCSP device. Page 20 7 CPU 7 CPU The ARM® Cortex®-M4 processor with floating-point unit (FPU) has a 32-bit instruction set (Thumb®-2 technology) that implements a superset of 16 and 32-bit instructions to maximize code density and performance. This processor implements several features that enable energy-efficient arithmetic and high-performance signal processing including: • • • • • Digital signal processing (DSP) instructions Single-cycle multiply and accumulate (MAC) instructions Hardware divide 8 and 16-bit single instruction multiple data (SIMD) instructions Single-precision floating-point unit (FPU) The ARM Cortex Microcontroller Software Interface Standard (CMSIS) hardware abstraction layer for the ARM Cortex processor series is implemented and available for the M4 CPU. Real-time execution is highly deterministic in thread mode, to and from sleep modes, and when handling events at configurable priority levels via the Nested Vectored Interrupt Controller (NVIC). Executing code from flash will have a wait state penalty on the nRF52 Series. An instruction cache can be enabled to minimize flash wait states when fetching instructions. For more information on cache, see Cache on page 30. The section Electrical specification on page 21 shows CPU performance parameters including wait states in different modes, CPU current and efficiency, and processing power and efficiency based on the CoreMark® benchmark. 7.1 Floating point interrupt The floating point unit (FPU) may generate exceptions when used due to e.g. overflow or underflow. These exceptions will trigger the FPU interrupt (see Instantiation on page 24). To clear the IRQ line when an exception has occurred, the relevant exception bit within the FPSCR register needs to be cleared. For more information about the FPSCR or other FPU registers, see Cortex-M4 Devices Generic User Guide. 7.2 Electrical specification 7.2.1 CPU performance The CPU clock speed is 64 MHz. Current and efficiency data is taken when in System ON and the CPU is executing the CoreMark™ benchmark. It includes power regulator and clock base currents. All other blocks are IDLE. Symbol Description Min. WFLASH CPU wait states, running from flash, cache disabled 0 Typ. Max. 2 Units WFLASHCACHE CPU wait states, running from flash, cache enabled 0 3 WRAM CPU wait states, running from RAM IDDFLASHCACHE CPU current, running from flash, cache enabled, LDO 7.4 mA IDDFLASHCACHEDCDC CPU current, running from flash, cache enabled, DCDC 3V 3.7 mA IDDFLASH CPU current, running from flash, cache disabled, LDO 8.0 mA IDDFLASHDCDC CPU current, running from flash, cache disabled, DCDC 3V 3.9 mA IDDRAM CPU current, running from RAM, LDO 6.7 mA IDDRAMDCDC CPU current, running from RAM, DCDC 3V 3.3 mA IDDFLASH/MHz CPU efficiency, running from flash, cache enabled, LDO 125 µA/ IDDFLASHDCDC/MHz CPU efficiency, running from flash, cache enabled, DCDC 3V 58 0 MHz µA/ MHz Page 21 7 CPU Symbol Description CMFLASH CoreMark5, running from flash, cache enabled Min. Typ. 215 Max. Units CoreMark CMFLASH/MHz CoreMark per MHz, running from flash, cache enabled 3.36 CoreMark/ CMFLASH/mA CoreMark per mA, running from flash, cache enabled, DCDC 3V 58 MHz CoreMark/ mA 7.3 CPU and support module configuration The ARM® Cortex®-M4 processor has a number of CPU options and support modules implemented on the device. Option / Module Core options NVIC PRIORITIES WIC Endianness Bit Banding DWT SysTick Modules MPU FPU DAP ETM ITM TPIU ETB FPB HTM 5 Description Implemented Nested Vector Interrupt Controller Priority bits Wakeup Interrupt Controller Memory system endianness Bit banded memory Data Watchpoint and Trace System tick timer 37 vectors 3 NO Little endian NO YES YES Memory protection unit Floating point unit Debug Access Port Embedded Trace Macrocell Instrumentation Trace Macrocell Trace Port Interface Unit Embedded Trace Buffer Flash Patch and Breakpoint Unit AHB Trace Macrocell YES YES YES YES YES YES NO YES NO Using IAR v6.50.1.4452 with flags --endian=little --cpu=Cortex-M4 -e --fpu=VFPv4_sp –Ohs --no_size_constraints Page 22 8 Memory 8 Memory The nRF52832 contains flash and RAM that can be used for code and data storage. The amount of RAM and flash will vary depending on variant, see Table 10: Memory variants on page 23. Table 10: Memory variants Device name nRF52832-QFAA nRF52832-QFAB nRF52832-CIAA RAM 64 kB 32 kB 64 kB Flash 512 kB 256 kB 512 kB Comments The CPU and the EasyDMA can access memory via the AHB multilayer interconnect. The CPU is also able to access peripherals via the AHB multilayer interconnect, as illustrated in Figure 4: Memory layout on page 23. Data RAM System APB ICODE AHB DCODE AHB multilayer interconnect Section 0 0x0080 F000 0x2000 E000 0x0080 E000 RAM6 AHB slave Section 1 0x2000 D000 0x0080 D000 Section 0 0x2000 C000 0x0080 C000 RAM5 AHB slave Section 1 0x2000 B000 0x0080 B000 Section 0 0x2000 A000 0x0080 A000 RAM4 AHB slave Section 1 0x2000 9000 0x0080 9000 Section 0 0x2000 8000 0x0080 8000 RAM3 AHB slave Section 1 0x2000 7000 0x0080 7000 0x2000 6000 0x0080 6000 RAM2 AHB slave Section 1 0x2000 5000 0x0080 5000 Section 0 0x2000 4000 0x0080 4000 RAM1 AHB slave Section 1 0x2000 3000 0x0080 3000 Section 0 0x2000 2000 0x0080 2000 RAM0 AHB slave Section 1 0x2100 1000 0x0080 1000 Section 0 0x2000 0000 0x0080 0000 I-Cache System bus ICODE DCODE EasyDMA DMA bus DMA bus EasyDMA Peripheral Code RAM ICODE/DCODE 0x2000 F000 Section 0 Page 127 NVMC ARM Cortex-M4 Peripheral Section 1 AHB slave CPU RAM7 AHB slave AHB slave AHB2APB Flash ICODE/DCODE 0x0007 F000 Page 3..126 0x0000 3000 Page 2 Page 1 Page 0 0x0000 2000 0x0000 1000 Block 7 0x0000 0E00 Block 2..6 0x0000 0400 Block 1 0x0000 0200 Block 0 0x0000 0000 Figure 4: Memory layout See AHB multilayer on page 26 and EasyDMA on page 27 for more information about the AHB multilayer interconnect and the EasyDMA. The same physical RAM is mapped to both the Data RAM region and the Code RAM region. It is up to the application to partition the RAM within these regions so that one does not corrupt the other. 8.1 RAM - Random access memory The RAM interface is divided into multiple RAM AHB slaves. Each RAM AHB slave is connected to two 4-kilobyte RAM sections, see Section 0 and Section 1 in Figure 4: Memory layout on page 23. Each of the RAM sections have separate power control for System ON and System OFF mode operation, which is configured via RAM register (see the POWER — Power supply on page 78). Page 23 8 Memory 8.2 Flash - Non-volatile memory The Flash can be read an unlimited number of times by the CPU, but it has restrictions on the number of times it can be written and erased and also on how it can be written. Writing to Flash is managed by the Non-volatile memory controller (NVMC), see NVMC — Non-volatile memory controller on page 29. The Flash is divided into multiple pages that can be accessed by the CPU via both the ICODE and DCODE buses as shown in, Figure 4: Memory layout on page 23. Each page is divided into 8 blocks. 8.3 Memory map The complete memory map is shown in Figure 5: Memory map on page 24. As described in Memory on page 23, Code RAM and the Data RAM are the same physical RAM. nRF52832 Address Map 0xE010 0000 0xE0FF 0000 0xE004 2000 0xE004 1000 0xE004 0000 ROM Table External PPB ETM TPIU 0xE004 0000 0xE000 F000 0xE000 E000 0xE000 3000 0xE000 2000 0xE000 1000 0xE000 0000 Reserved SCS Reserved FPB DWT ITM 0x2000 0000 0x1000 1000 0x1000 0000 0xFFFF FFFF Cortex M4 System Address Map Private Peripheral Bus - External Private Peripheral Bus - Internal 0x6000 0000 External device 1.0GB Reserved AHB peripherals Reserved 0xA000 0000 0x5000 0000 APB peripherals Reserved UICR Reserved FICR External RAM 1.0GB Peripheral 0.5GB SRAM 0.5GB Reserved 0x0081 0000 nRF52832 Address Map System Code RAM 0x0080 0000 0x4000 0000 0x4000 0000 Reserved Reserved 0x0008 0000 Data RAM Flash Code 0.5GB 0x2001 0000 0x2000 0000 0x0000 0000 Figure 5: Memory map 8.4 Instantiation Table 11: Instantiation table ID Base Address Peripheral Instance Description 0 0x40000000 CLOCK CLOCK Clock control 0 0x40000000 POWER POWER Power control 0 0x40000000 BPROT BPROT Block Protect 1 0x40001000 RADIO RADIO 2.4 GHz radio 2 0x40002000 UARTE UARTE0 Universal Asynchronous Receiver/Transmitter with EasyDMA 2 0x40002000 UART UART0 Universal Asynchronous Receiver/Transmitter 3 0x40003000 SPIM SPIM0 SPI master 0 3 0x40003000 SPIS SPIS0 SPI slave 0 3 0x40003000 TWIM TWIM0 Two-wire interface master 0 3 0x40003000 TWI TWI0 Two-wire interface master 0 Deprecated 3 0x40003000 SPI SPI0 SPI master 0 Deprecated Page 24 Deprecated 8 Memory ID Base Address Peripheral Instance Description 3 0x40003000 TWIS TWIS0 Two-wire interface slave 0 4 0x40004000 SPIM SPIM1 SPI master 1 4 0x40004000 TWI TWI1 Two-wire interface master 1 4 0x40004000 SPIS SPIS1 SPI slave 1 4 0x40004000 TWIS TWIS1 Two-wire interface slave 1 4 0x40004000 TWIM TWIM1 Two-wire interface master 1 4 0x40004000 SPI SPI1 SPI master 1 5 0x40005000 NFCT NFCT Near Field Communication Tag 6 0x40006000 GPIOTE GPIOTE GPIO Tasks and Events 7 0x40007000 SAADC SAADC Analog to digital converter 8 0x40008000 TIMER TIMER0 Timer 0 9 0x40009000 TIMER TIMER1 Timer 1 10 0x4000A000 TIMER TIMER2 Timer 2 11 0x4000B000 RTC RTC0 Real-time counter 0 12 0x4000C000 TEMP TEMP Temperature sensor 13 0x4000D000 RNG RNG Random number generator 14 0x4000E000 ECB ECB AES Electronic Code Book (ECB) mode block encryption 15 0x4000F000 CCM CCM AES CCM Mode Encryption 15 0x4000F000 AAR AAR Acelerated Address Resolver 16 0x40010000 WDT WDT Watchdog timer 17 0x40011000 RTC RTC1 Real-time counter 1 18 0x40012000 QDEC QDEC Quadrature decoder 19 0x40013000 LPCOMP LPCOMP Low power comparator 19 0x40013000 COMP COMP General purpose comparator 20 0x40014000 SWI SWI0 Software interrupt 0 20 0x40014000 EGU EGU0 Event Generator Unit 0 21 0x40015000 EGU EGU1 Event Generator Unit 1 21 0x40015000 SWI SWI1 Software interrupt 1 22 0x40016000 SWI SWI2 Software interrupt 2 22 0x40016000 EGU EGU2 Event Generator Unit 2 23 0x40017000 SWI SWI3 Software interrupt 3 23 0x40017000 EGU EGU3 Event Generator Unit 3 24 0x40018000 EGU EGU4 Event Generator Unit 4 24 0x40018000 SWI SWI4 Software interrupt 4 25 0x40019000 SWI SWI5 Software interrupt 5 25 0x40019000 EGU EGU5 Event Generator Unit 5 26 0x4001A000 TIMER TIMER3 Timer 3 27 0x4001B000 TIMER TIMER4 Timer 4 28 0x4001C000 PWM PWM0 Pulse Width Modulation Unit 0 29 0x4001D000 PDM PDM Pulse Density Modulation (Digital Microphone Interface) 30 0x4001E000 NVMC NVMC Non-Volatile Memory Controller 31 0x4001F000 PPI PPI Programmable Peripheral Interconnect 32 0x40020000 MWU MWU Memory Watch Unit 33 0x40021000 PWM PWM1 Pulse Width Modulation Unit 1 34 0x40022000 PWM PWM2 Pulse Width Modulation Unit 2 35 0x40023000 SPI SPI2 SPI master 2 35 0x40023000 SPIS SPIS2 SPI slave 2 35 0x40023000 SPIM SPIM2 SPI master 2 36 0x40024000 RTC RTC2 Real-time counter 2 37 0x40025000 I2S I2S Inter-IC Sound Interface 38 0x40026000 FPU FPU FPU interrupt 0 0x50000000 GPIO GPIO General purpose input and output 0 0x50000000 GPIO P0 General purpose input and output N/A 0x10000000 FICR FICR Factory Information Configuration N/A 0x10001000 UICR UICR User Information Configuration Page 25 Deprecated Deprecated Deprecated Deprecated 9 AHB multilayer 9 AHB multilayer The CPU and all of the EasyDMAs are AHB bus masters on the AHB multilayer, while the RAM and various other modules are AHB slaves. See Block diagram on page 12 for an overview of which peripherals implement EasyDMA. The CPU has exclusive access to all AHB slaves except for the RAM that can also be accessed by the EasyDMA. Access rights to each of the RAM AHB slaves are resolved using the priority of the different bus masters in the system See AHB multilayer priorities on page 26 for information about the priority of the different AHB bus masters in the system. It is possible for two or more bus masters to have the same priority in cases where it is guaranteed by design that the related masters will never be able to access the same slave at the same time. 9.1 AHB multilayer priorities Each master connected to the AHB multilayer is assigned a priority. Table 12: AHB bus masters Bus master name CPU SPIS1 RADIO CCM/ECB/AAR SAADC UARTE SERIAL0 SERIAL2 NFCT I2S PDM PWM Priority Highest priority Description Applies to SPIM1, SPIS1, TWIM1, TWIS1 Applies to SPIM0, SPIS0, TWIM0, TWIS0 Applies to SPIM2, SPIS2 I2S PDM Applies to PWM0, PWM1, PWM2 Lowest priority Page 26 10 EasyDMA 10 EasyDMA EasyDMA is an easy-to-use direct memory access module that some peripherals implement to gain direct access to Data RAM. The EasyDMA is an AHB bus master similar to the CPU and it is connected to the AHB multilayer interconnect for direct access to the Data RAM. The EasyDMA is not able to access the Flash. A peripheral can implement multiple EasyDMA instances, for example to provide a dedicated channel for reading data from RAM into the peripheral at the same time as a second channel is dedicated for writing data to the RAM from the peripheral. This concept is illustrated in Figure 6: EasyDMA example on page 27 RAM AHB Multilayer Peripheral READER RAM RAM AHB EasyDMA WRITER AHB Peripheral Core EasyDMA Figure 6: EasyDMA example An EasyDMA channel is usually exposed to the user in the form illustrated below, but some variations may occur: READERBUFFER_SIZE 5 WRITERBUFFER_SIZE 6 uint8_t readerBuffer[READERBUFFER_SIZE] uint8_t writerBuffer[WRITERBUFFER_SIZE] __at__ 0x20000000; __at__ 0x20000005; // Configuring the READER channel MYPERIPHERAL->READER.MAXCNT = READERBUFFER_SIZE; MYPERIPHERAL->READER.PTR = &readerBuffer; // Configure the WRITER channel MYPERIPHERAL->WRITER.MAXCNT = WRITEERBUFFER_SIZE; MYPERIPHERAL->WRITER.PTR = &writerBuffer; This example shows a peripheral called MYPERIPHERAL that implements two EasyDMA channels, one for reading, called READER, and one for writing, called WRITER. When the peripheral is started, it is here assumed that the peripheral will read 5 bytes from the readerBuffer located in RAM at address 0x20000000, process the data and then write no more than 6 bytes back to the writerBuffer located in RAM at address 0x20000005. The memory layout of these buffers is illustrated in Figure 7: EasyDMA memory layout on page 28. Page 27 10 EasyDMA 0x20000000 readerBuffer[0] readerBuffer[1] readerBuffer[2] readerBuffer[3] 0x20000004 readerBuffer[4] writerBuffer[0] writerBuffer[1] writerBuffer[2] 0x20000008 writerBuffer[3] writerBuffer[4] writerBuffer[5] Figure 7: EasyDMA memory layout The EasyDMA channel's MAXCNT register cannot be specified larger than the actual size of the buffer. If, for example, the WRITER.MAXCNT register is specified larger than the size of the writerBuffer, the WRITER EasyDMA channel may overflow the writerBuffer. After the peripheral has completed the EasyDMA transfer, the CPU can read the EasyDMA channel's AMOUNT register to see how many bytes that were transferred, e.g. it is possible for the CPU to read the MYPERIPHERAL->WRITER.AMOUNT register to see how many bytes the WRITER wrote to RAM. 10.1 EasyDMA array list The EasyDMA is able to operate in a mode called array list. The EasyDMA array list can be represented by the data structure ArrayList_type illustrated in the code example below. This data structure includes only a buffer with size equal to READER.MAXCNT. EasyDMA will use the READER.MAXCNT register to determine when the buffer is full. This array list does not provide a mechanism to explicitly specify where the next item in the list is located. Instead, it assumes that the list is organized as a linear array where items are located one after the other in RAM. #define BUFFER_SIZE 4 typedef struct ArrayList { uint8_t buffer[BUFFER_SIZE]; } ArrayList_type; ArrayList_type ReaderList[3]; READER.MAXCNT = BUFFER_SIZE; READER.PTR = &ReaderList; READER.PTR = &ReaderList 0x20000000 : ReaderList[0] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000004 : ReaderList[1] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000008 : ReaderList[2] buffer[0] buffer[1] buffer[2] buffer[3] Figure 8: EasyDMA array list Page 28 11 NVMC — Non-volatile memory controller 11 NVMC — Non-volatile memory controller The Non-volatile memory controller (NVMC) is used for writing and erasing the internal Flash memory and the UICR. Before a write can be performed, the NVMC must be enabled for writing in CONFIG.WEN. Similarly, before an erase can be performed, the NVMC must be enabled for erasing in CONFIG.EEN, see CONFIG on page 31. The user must make sure that writing and erasing are not enabled at the same time. Failing to do so may result in unpredictable behavior. 11.1 Writing to Flash When writing is enabled, the Flash is written by writing a full 32-bit word to a word-aligned address in the Flash. The NVMC is only able to write '0' to bits in the Flash that are erased, that is, set to '1'. It cannot write back a bit to '1'. As illustrated in Memory on page 23, the Flash is divided into multiple pages that are further divided into multiple blocks. The same block in the Flash can only be written nWRITE number of times before an erase must be performed using ERASEPAGE or ERASEALL. See the memory size and organization in Memory on page 23 for block size. Only full 32-bit words can be written to Flash using the NVMC interface. To write less than 32 bits to Flash, write the data as a word, and set all the bits that should remain unchanged in the word to '1'. Note that the restriction about the number of writes (see above) still applies in this case. The time it takes to write a word to the Flash is specified by tWRITE. The CPU is halted while the NVMC is writing to the Flash. Only word-aligned writes are allowed. Byte or half-word-aligned writes will result in a hard fault. 11.2 Erasing a page in Flash When erase is enabled, the Flash can be erased page by page using the ERASEPAGE register. After erasing a Flash page, all bits in the page are set to '1'. The time it takes to erase a page is specified by tERASEPAGE. The CPU is halted while the NVMC performs the erase operation. 11.3 Writing to user information configuration registers (UICR) User information configuration registers (UICR) are written in the same way as Flash. After UICR has been written, the new UICR configuration will only take effect after a reset. UICR can only be written nWRITE number of times before an erase must be performed using ERASEUICR or ERASEALL. The time it takes to write a word to the UICR is specified by tWRITE. The CPU is halted while the NVMC is writing to the UICR. 11.4 Erasing user information configuration registers (UICR) When erase is enabled, UICR can be erased using the ERASEUICR register. After erasing UICR all bits in UICR are set to '1'. The time it takes to erase UICR is specified by tERASEPAGE. The CPU is halted while the NVMC performs the erase operation. Page 29 11 NVMC — Non-volatile memory controller 11.5 Erase all When erase is enabled, the whole Flash and UICR can be erased in one operation by using the ERASEALL register. ERASEALL will not erase the factory information configuration registers (FICR). The time it takes to perform an ERASEALL command is specified by tERASEALL The CPU is halted while the NVMC performs the erase operation. 11.6 Cache An instruction cache (I-Cache) can be enabled for the ICODE bus in the NVMC. See the Memory map in Memory map on page 24 for the location of Flash. A cache hit is an instruction fetch from the cache, and it has a 0 wait-state delay. The number of wait-states for a cache miss, where the instruction is not available in the cache and needs to be fetched from Flash, depends on the processor frequency and is shown in CPU on page 21 Enabling the cache can increase CPU performance and reduce power consumption by reducing the number of wait cycles and the number of flash accesses. This will depend on the cache hit rate. Cache will use some current when enabled. If the reduction in average current due to reduced flash accesses is larger than the cache power requirement, the average current to execute the program code will reduce. When disabled, the cache does not use current and does not retain its content. It is possible to enable cache profiling to analyze the performance of the cache for your program using the ICACHECNF register. When profiling is enabled, the IHIT and IMISS registers are incremented for every instruction cache hit or miss respectively. The hit and miss profiling registers do not wrap around after reaching the maximum value. If the maximum value is reached, consider profiling for a shorter duration to get correct numbers. 11.7 Registers Table 13: Instances Base address Peripheral Instance Description 0x4001E000 NVMC NVMC Non-Volatile Memory Controller Configuration Table 14: Register Overview Register Offset Description READY 0x400 Ready flag CONFIG 0x504 Configuration register ERASEPAGE 0x508 Register for erasing a page in Code area ERASEPCR1 0x508 Register for erasing a page in Code area. Equivalent to ERASEPAGE. ERASEALL 0x50C Register for erasing all non-volatile user memory ERASEPCR0 0x510 Register for erasing a page in Code area. Equivalent to ERASEPAGE. ERASEUICR 0x514 Register for erasing User Information Configuration Registers ICACHECNF 0x540 I-Code cache configuration register. IHIT 0x548 I-Code cache hit counter. IMISS 0x54C I-Code cache miss counter. 11.7.1 READY Address offset: 0x400 Ready flag Page 30 Deprecated Deprecated 11 NVMC — Non-volatile memory controller Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Busy 0 NVMC is busy (on-going write or erase operation) Ready 1 NVMC is ready READY NVMC is ready or busy 11.7.2 CONFIG Address offset: 0x504 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A Reset 0x00000000 Id RW Field A RW WEN 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Program memory access mode. It is strongly recommended to only activate erase and write modes when they are actively used. Enabling write or erase will invalidate the cache and keep it invalidated. Ren 0 Read only access Wen 1 Write Enabled Een 2 Erase enabled 11.7.3 ERASEPAGE Address offset: 0x508 Register for erasing a page in Code area Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW ERASEPAGE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Register for starting erase of a page in Code area The value is the address to the page to be erased. (Addresses of first word in page). Note that code erase has to be enabled by CONFIG.EEN before the page can be erased. Attempts to erase pages that are outside the code area may result in undesirable behaviour, e.g. the wrong page may be erased. 11.7.4 ERASEPCR1 ( Deprecated ) Address offset: 0x508 Register for erasing a page in Code area. Equivalent to ERASEPAGE. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW ERASEPCR1 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Register for erasing a page in Code area. Equivalent to ERASEPAGE. 11.7.5 ERASEALL Address offset: 0x50C Register for erasing all non-volatile user memory Page 31 11 NVMC — Non-volatile memory controller Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ERASEALL 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Erase all non-volatile memory including UICR registers. Note that code erase has to be enabled by CONFIG.EEN before the UICR can be erased. NoOperation 0 No operation Erase 1 Start chip erase 11.7.6 ERASEPCR0 ( Deprecated ) Address offset: 0x510 Register for erasing a page in Code area. Equivalent to ERASEPAGE. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW ERASEPCR0 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Register for starting erase of a page in Code area. Equivalent to ERASEPAGE. 11.7.7 ERASEUICR Address offset: 0x514 Register for erasing User Information Configuration Registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ERASEUICR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Register starting erase of all User Information Configuration Registers. Note that code erase has to be enabled by CONFIG.EEN before the UICR can be erased. NoOperation 0 No operation Erase 1 Start erase of UICR 11.7.8 ICACHECNF Address offset: 0x540 I-Code cache configuration register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B Reset 0x00000000 Id RW Field A RW CACHEEN B 0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable cache. Invalidates all cache entries. Enabled 1 Enable cache Disabled 0 Disable cache profiling Enabled 1 Enable cache profiling Cache enable RW CACHEPROFEN Cache profiling enable 11.7.9 IHIT Address offset: 0x548 I-Code cache hit counter. Page 32 11 NVMC — Non-volatile memory controller Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW HITS 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Number of cache hits 11.7.10 IMISS Address offset: 0x54C I-Code cache miss counter. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW MISSES 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Number of cache misses 11.8 Electrical specification 11.8.1 Flash programming Symbol Description nWRITE,BLOCK Amount of writes allowed in a block between erase Min. Typ. Max. Units tWRITE Time to write one word 67.5 338 µs tERASEPAGE Time to erase one page 2.05 89.7 ms tERASEALL Time to erase all flash 6.72 295.3 ms Max. Units 181 11.8.2 Cache size Symbol Description SizeICODE I-Code cache size Min. Typ. 2048 Page 33 Bytes 12 BPROT — Block protection 12 BPROT — Block protection The mechanism for protecting non-volatile memory can be used to prevent application code from erasing or writing to protected blocks. Non-volatile memory can be protected from erases and writes depending on the settings in the CONFIG registers. One bit in a CONFIG register represents one protected block of 4 kB. There are four CONFIG registers of 32 bits, which means there are 128 protectable blocks in total. Important: If an erase or write to a protected block is detected, the CPU will hard fault. If an ERASEALL operation is attempted from the CPU while any block is protected, it will be blocked and the CPU will hard fault. On reset, all the protection bits are cleared. To ensure safe operation, the first task after reset must be to set the protection bits. The only way of clearing protection bits is by resetting the device from any reset source. The protection mechanism is turned off when in debug interface mode (a debugger is connected) and the DISABLEINDEBUG register is set to disable. For more information, see Debug and trace on page 72. Program Memory 127 126 125 l 31 CONFIG[3] 0 ... 2 1 0 0x00000000 l 31 CONFIG[0] 0 Figure 9: Protected regions of program memory 12.1 Registers Table 15: Instances Base address Peripheral Instance Description 0x40000000 BPROT BPROT Block Protect Configuration Table 16: Register Overview Register Offset Description CONFIG0 0x600 Block protect configuration register 0 CONFIG1 0x604 Block protect configuration register 1 DISABLEINDEBUG 0x608 Disable protection mechanism in debug interface mode 0x60C Reserved CONFIG2 0x610 Block protect configuration register 2 CONFIG3 0x614 Block protect configuration register 3 Page 34 12 BPROT — Block protection 12.1.1 CONFIG0 Address offset: 0x600 Block protect configuration register 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW REGION0 B C D E F G H I J K L M N O P Q Value Id Value Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 I H G F E D C B A Description Enable protection for region 0. Write '0' has no effect. RW REGION1 Enable protection for region 1. Write '0' has no effect. RW REGION2 Enable protection for region 2. Write '0' has no effect. RW REGION3 Enable protection for region 3. Write '0' has no effect. RW REGION4 Enable protection for region 4. Write '0' has no effect. RW REGION5 Enable protection for region 5. Write '0' has no effect. RW REGION6 Enable protection for region 6. Write '0' has no effect. RW REGION7 Enable protection for region 7. Write '0' has no effect. RW REGION8 Enable protection for region 8. Write '0' has no effect. RW REGION9 Enable protection for region 9. Write '0' has no effect. RW REGION10 Enable protection for region 10. Write '0' has no effect. RW REGION11 Enable protection for region 11. Write '0' has no effect. RW REGION12 Enable protection for region 12. Write '0' has no effect. RW REGION13 Enable protection for region 13. Write '0' has no effect. RW REGION14 Enable protection for region 14. Write '0' has no effect. RW REGION15 Enable protection for region 15. Write '0' has no effect. RW REGION16 Enable protection for region 16. Write '0' has no effect. Protection disabled Page 35 12 BPROT — Block protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id R S T U V W X Y Z a b c d e f RW Field Value Id Value Description Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable Disabled 0 Protection disabled Enabled 1 Protection enable RW REGION17 I H G F E D C B A Enable protection for region 17. Write '0' has no effect. RW REGION18 Enable protection for region 18. Write '0' has no effect. RW REGION19 Enable protection for region 19. Write '0' has no effect. RW REGION20 Enable protection for region 20. Write '0' has no effect. RW REGION21 Enable protection for region 21. Write '0' has no effect. RW REGION22 Enable protection for region 22. Write '0' has no effect. RW REGION23 Enable protection for region 23. Write '0' has no effect. RW REGION24 Enable protection for region 24. Write '0' has no effect. RW REGION25 Enable protection for region 25. Write '0' has no effect. RW REGION26 Enable protection for region 26. Write '0' has no effect. RW REGION27 Enable protection for region 27. Write '0' has no effect. RW REGION28 Enable protection for region 28. Write '0' has no effect. RW REGION29 Enable protection for region 29. Write '0' has no effect. RW REGION30 Enable protection for region 30. Write '0' has no effect. RW REGION31 Enable protection for region 31. Write '0' has no effect. 12.1.2 CONFIG1 Address offset: 0x604 Block protect configuration register 1 Page 36 12 BPROT — Block protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW REGION32 B C D E F G H I J K L M N O P Q R S Value Id Value Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled I H G F E D C B A Description Enable protection for region 32. Write '0' has no effect. RW REGION33 Enable protection for region 33. Write '0' has no effect. RW REGION34 Enable protection for region 34. Write '0' has no effect. RW REGION35 Enable protection for region 35. Write '0' has no effect. RW REGION36 Enable protection for region 36. Write '0' has no effect. RW REGION37 Enable protection for region 37. Write '0' has no effect. RW REGION38 Enable protection for region 38. Write '0' has no effect. RW REGION39 Enable protection for region 39. Write '0' has no effect. RW REGION40 Enable protection for region 40. Write '0' has no effect. RW REGION41 Enable protection for region 41. Write '0' has no effect. RW REGION42 Enable protection for region 42. Write '0' has no effect. RW REGION43 Enable protection for region 43. Write '0' has no effect. RW REGION44 Enable protection for region 44. Write '0' has no effect. RW REGION45 Enable protection for region 45. Write '0' has no effect. RW REGION46 Enable protection for region 46. Write '0' has no effect. RW REGION47 Enable protection for region 47. Write '0' has no effect. RW REGION48 Enable protection for region 48. Write '0' has no effect. RW REGION49 Enable protection for region 49. Write '0' has no effect. RW REGION50 Enable protection for region 50. Write '0' has no effect. Page 37 12 BPROT — Block protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id T U V W X Y Z a b c d e f RW Field Value Id Value Description Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled RW REGION51 I H G F E D C B A Enable protection for region 51. Write '0' has no effect. RW REGION52 Enable protection for region 52. Write '0' has no effect. RW REGION53 Enable protection for region 53. Write '0' has no effect. RW REGION54 Enable protection for region 54. Write '0' has no effect. RW REGION55 Enable protection for region 55. Write '0' has no effect. RW REGION56 Enable protection for region 56. Write '0' has no effect. RW REGION57 Enable protection for region 57. Write '0' has no effect. RW REGION58 Enable protection for region 58. Write '0' has no effect. RW REGION59 Enable protection for region 59. Write '0' has no effect. RW REGION60 Enable protection for region 60. Write '0' has no effect. RW REGION61 Enable protection for region 61. Write '0' has no effect. RW REGION62 Enable protection for region 62. Write '0' has no effect. RW REGION63 Enable protection for region 63. Write '0' has no effect. 12.1.3 DISABLEINDEBUG Address offset: 0x608 Disable protection mechanism in debug interface mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000001 Id RW Field A RW DISABLEINDEBUG 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Description Disable the protection mechanism for NVM regions while in debug interface mode. This register will only disable the protection mechanism if the device is in debug interface mode. Disabled 1 Disable in debug Page 38 12 BPROT — Block protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000001 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Description Enabled 0 Enable in debug 12.1.4 CONFIG2 Address offset: 0x610 Block protect configuration register 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW REGION64 B C D E F G H I J K L M N O Value Id Value Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 I H G F E D C B A Description Enable protection for region 64. Write '0' has no effect. RW REGION65 Enable protection for region 65. Write '0' has no effect. RW REGION66 Enable protection for region 66. Write '0' has no effect. RW REGION67 Enable protection for region 67. Write '0' has no effect. RW REGION68 Enable protection for region 68. Write '0' has no effect. RW REGION69 Enable protection for region 69. Write '0' has no effect. RW REGION70 Enable protection for region 70. Write '0' has no effect. RW REGION71 Enable protection for region 71. Write '0' has no effect. RW REGION72 Enable protection for region 72. Write '0' has no effect. RW REGION73 Enable protection for region 73. Write '0' has no effect. RW REGION74 Enable protection for region 74. Write '0' has no effect. RW REGION75 Enable protection for region 75. Write '0' has no effect. RW REGION76 Enable protection for region 76. Write '0' has no effect. RW REGION77 Enable protection for region 77. Write '0' has no effect. RW REGION78 Enable protection for region 78. Write '0' has no effect. Protection disabled Page 39 12 BPROT — Block protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id P Q R S T U V W X Y Z a b c d e f RW Field Value Id Value Description Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled RW REGION79 I H G F E D C B A Enable protection for region 79. Write '0' has no effect. RW REGION80 Enable protection for region 80. Write '0' has no effect. RW REGION81 Enable protection for region 81. Write '0' has no effect. RW REGION82 Enable protection for region 82. Write '0' has no effect. RW REGION83 Enable protection for region 83. Write '0' has no effect. RW REGION84 Enable protection for region 84. Write '0' has no effect. RW REGION85 Enable protection for region 85. Write '0' has no effect. RW REGION86 Enable protection for region 86. Write '0' has no effect. RW REGION87 Enable protection for region 87. Write '0' has no effect. RW REGION88 Enable protection for region 88. Write '0' has no effect. RW REGION89 Enable protection for region 89. Write '0' has no effect. RW REGION90 Enable protection for region 90. Write '0' has no effect. RW REGION91 Enable protection for region 91. Write '0' has no effect. RW REGION92 Enable protection for region 92. Write '0' has no effect. RW REGION93 Enable protection for region 93. Write '0' has no effect. RW REGION94 Enable protection for region 94. Write '0' has no effect. RW REGION95 Enable protection for region 95. Write '0' has no effect. Page 40 12 BPROT — Block protection 12.1.5 CONFIG3 Address offset: 0x614 Block protect configuration register 3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW REGION96 B C D E F G H I J K L M N O P Q Value Id Value Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 I H G F E D C B A Description Enable protection for region 96. Write '0' has no effect. RW REGION97 Enable protection for region 97. Write '0' has no effect. RW REGION98 Enable protection for region 98. Write '0' has no effect. RW REGION99 Enable protection for region 99. Write '0' has no effect. RW REGION100 Enable protection for region 100. Write '0' has no effect. RW REGION101 Enable protection for region 101. Write '0' has no effect. RW REGION102 Enable protection for region 102. Write '0' has no effect. RW REGION103 Enable protection for region 103. Write '0' has no effect. RW REGION104 Enable protection for region 104. Write '0' has no effect. RW REGION105 Enable protection for region 105. Write '0' has no effect. RW REGION106 Enable protection for region 106. Write '0' has no effect. RW REGION107 Enable protection for region 107. Write '0' has no effect. RW REGION108 Enable protection for region 108. Write '0' has no effect. RW REGION109 Enable protection for region 109. Write '0' has no effect. RW REGION110 Enable protection for region 110. Write '0' has no effect. RW REGION111 Enable protection for region 111. Write '0' has no effect. RW REGION112 Enable protection for region 112. Write '0' has no effect. Protection disabled Page 41 12 BPROT — Block protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id R S T U V W X Y Z a b c d e f RW Field Value Id Value Description Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled Disabled 0 Protection disabled Enabled 1 Protection enabled RW REGION113 I H G F E D C B A Enable protection for region 113. Write '0' has no effect. RW REGION114 Enable protection for region 114. Write '0' has no effect. RW REGION115 Enable protection for region 115. Write '0' has no effect. RW REGION116 Enable protection for region 116. Write '0' has no effect. RW REGION117 Enable protection for region 117. Write '0' has no effect. RW REGION118 Enable protection for region 118. Write '0' has no effect. RW REGION119 Enable protection for region 119. Write '0' has no effect. RW REGION120 Enable protection for region 120. Write '0' has no effect. RW REGION121 Enable protection for region 121. Write '0' has no effect. RW REGION122 Enable protection for region 122. Write '0' has no effect. RW REGION123 Enable protection for region 123. Write '0' has no effect. RW REGION124 Enable protection for region 124. Write '0' has no effect. RW REGION125 Enable protection for region 125. Write '0' has no effect. RW REGION126 Enable protection for region 126. Write '0' has no effect. RW REGION127 Enable protection for region 127. Write '0' has no effect. Page 42 13 FICR — Factory information configuration registers 13 FICR — Factory information configuration registers Factory information configuration registers (FICR) are pre-programmed in factory and cannot be erased by the user. These registers contain chip-specific information and configuration. 13.1 Registers Table 17: Instances Base address Peripheral Instance Description 0x10000000 FICR FICR Factory Information Configuration Configuration Table 18: Register Overview Register Offset Description CODEPAGESIZE 0x010 Code memory page size CODESIZE 0x014 Code memory size DEVICEID[0] 0x060 Device identifier DEVICEID[1] 0x064 Device identifier ER[0] 0x080 Encryption Root, word 0 ER[1] 0x084 Encryption Root, word 1 ER[2] 0x088 Encryption Root, word 2 ER[3] 0x08C Encryption Root, word 3 IR[0] 0x090 Identity Root, word 0 IR[1] 0x094 Identity Root, word 1 IR[2] 0x098 Identity Root, word 2 IR[3] 0x09C Identity Root, word 3 DEVICEADDRTYPE 0x0A0 Device address type DEVICEADDR[0] 0x0A4 Device address 0 DEVICEADDR[1] 0x0A8 Device address 1 INFO.PART 0x100 Part code INFO.VARIANT 0x104 Part Variant, Hardware version and Production configuration INFO.PACKAGE 0x108 Package option INFO.RAM 0x10C RAM variant INFO.FLASH 0x110 Flash variant 0x114 Reserved 0x118 Reserved 0x11C Reserved TEMP.A0 0x404 Slope definition A0. TEMP.A1 0x408 Slope definition A1. TEMP.A2 0x40C Slope definition A2. TEMP.A3 0x410 Slope definition A3. TEMP.A4 0x414 Slope definition A4. TEMP.A5 0x418 Slope definition A5. TEMP.B0 0x41C y-intercept B0. TEMP.B1 0x420 y-intercept B1. TEMP.B2 0x424 y-intercept B2. TEMP.B3 0x428 y-intercept B3. TEMP.B4 0x42C y-intercept B4. TEMP.B5 0x430 y-intercept B5. TEMP.T0 0x434 Segment end T0. TEMP.T1 0x438 Segment end T1. TEMP.T2 0x43C Segment end T2. TEMP.T3 0x440 Segment end T3. TEMP.T4 0x444 Segment end T4. Page 43 13 FICR — Factory information configuration registers Register Offset Description NFC.TAGHEADER0 0x450 Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFC.TAGHEADER1 0x454 NFC.TAGHEADER2 0x458 NFC.TAGHEADER3 0x45C NFCID1_2ND_LAST and NFCID1_LAST. Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFCID1_2ND_LAST and NFCID1_LAST. Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFCID1_2ND_LAST and NFCID1_LAST. Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFCID1_2ND_LAST and NFCID1_LAST. 13.1.1 CODEPAGESIZE Address offset: 0x010 Code memory page size Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description CODEPAGESIZE Code memory page size 13.1.2 CODESIZE Address offset: 0x014 Code memory size Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description CODESIZE Code memory size in number of pages Total code space is: CODEPAGESIZE * CODESIZE 13.1.3 DEVICEID[0] Address offset: 0x060 Device identifier Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description DEVICEID 64 bit unique device identifier DEVICEID[0] contains the least significant bits of the device identifier. DEVICEID[1] contains the most significant bits of the device identifier. 13.1.4 DEVICEID[1] Address offset: 0x064 Device identifier Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description DEVICEID 64 bit unique device identifier Page 44 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description DEVICEID[0] contains the least significant bits of the device identifier. DEVICEID[1] contains the most significant bits of the device identifier. 13.1.5 ER[0] Address offset: 0x080 Encryption Root, word 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description ER Encryption Root, word n 13.1.6 ER[1] Address offset: 0x084 Encryption Root, word 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description ER Encryption Root, word n 13.1.7 ER[2] Address offset: 0x088 Encryption Root, word 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description ER Encryption Root, word n 13.1.8 ER[3] Address offset: 0x08C Encryption Root, word 3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description ER Encryption Root, word n 13.1.9 IR[0] Address offset: 0x090 Identity Root, word 0 Page 45 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description IR Identity Root, word n 13.1.10 IR[1] Address offset: 0x094 Identity Root, word 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description IR Identity Root, word n 13.1.11 IR[2] Address offset: 0x098 Identity Root, word 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description IR Identity Root, word n 13.1.12 IR[3] Address offset: 0x09C Identity Root, word 3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description IR Identity Root, word n 13.1.13 DEVICEADDRTYPE Address offset: 0x0A0 Device address type Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0xFFFFFFFF Id RW Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Description Public 0 Public address Random 1 Random address DEVICEADDRTYPE Device address type 13.1.14 DEVICEADDR[0] Address offset: 0x0A4 Device address 0 Page 46 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description DEVICEADDR 48 bit device address DEVICEADDR[0] contains the least significant bits of the device address. DEVICEADDR[1] contains the most significant bits of the device address. Only bits [15:0] of DEVICEADDR[1] are used. 13.1.15 DEVICEADDR[1] Address offset: 0x0A8 Device address 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A R 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description DEVICEADDR 48 bit device address DEVICEADDR[0] contains the least significant bits of the device address. DEVICEADDR[1] contains the most significant bits of the device address. Only bits [15:0] of DEVICEADDR[1] are used. 13.1.16 INFO.PART Address offset: 0x100 Part code Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00052832 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 1 0 1 0 0 0 0 0 1 1 0 0 1 0 Value Id Value Description N52832 0x52832 nRF52832 Unspecified 0xFFFFFFFF Unspecified PART Part code 13.1.17 INFO.VARIANT Address offset: 0x104 Part Variant, Hardware version and Production configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x41414142 Id RW Field A R 0 Value Id 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 0 1 0 0 0 0 0 1 0 1 0 0 0 0 1 0 Value Description VARIANT Part Variant, Hardware version and Production configuration, encoded as ASCII AAAA 0x41414141 AAAA AAAB 0x41414142 AAAB AABA 0x41414241 AABA AABB 0x41414242 AABB AAB0 0x41414230 AAB0 AAE0 0x41414530 AAE0 Unspecified 0xFFFFFFFF Unspecified 13.1.18 INFO.PACKAGE Address offset: 0x108 Package option Page 47 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00002000 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description QF 0x2000 QFxx - 48-pin QFN CH 0x2001 CHxx - 7x8 WLCSP 56 balls CI 0x2002 CIxx - 7x8 WLCSP 56 balls CK 0x2005 CKxx - 7x8 WLCSP 56 balls with backside coating for light Unspecified 0xFFFFFFFF PACKAGE Package option protection Unspecified 13.1.19 INFO.RAM Address offset: 0x10C RAM variant Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000040 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 Value Id Value Description K16 0x10 16 kByte RAM K32 0x20 32 kByte RAM K64 0x40 64 kByte RAM Unspecified 0xFFFFFFFF Unspecified RAM RAM variant 13.1.20 INFO.FLASH Address offset: 0x110 Flash variant Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000200 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 Value Id Value Description K128 0x80 128 kByte FLASH K256 0x100 256 kByte FLASH K512 0x200 512 kByte FLASH Unspecified 0xFFFFFFFF Unspecified FLASH Flash variant 13.1.21 TEMP.A0 Address offset: 0x404 Slope definition A0. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A Reset 0x00000320 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 1 0 0 0 0 0 Value Description A A (slope definition) register. 13.1.22 TEMP.A1 Address offset: 0x408 Slope definition A1. Page 48 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A Reset 0x00000343 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 1 0 0 0 0 1 1 Value Description A A (slope definition) register. 13.1.23 TEMP.A2 Address offset: 0x40C Slope definition A2. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A Reset 0x0000035D Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 1 0 1 1 1 0 1 Value Description A A (slope definition) register. 13.1.24 TEMP.A3 Address offset: 0x410 Slope definition A3. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A Reset 0x00000400 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 Value Description A A (slope definition) register. 13.1.25 TEMP.A4 Address offset: 0x414 Slope definition A4. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A Reset 0x00000452 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 1 0 1 0 0 1 0 Value Description A A (slope definition) register. 13.1.26 TEMP.A5 Address offset: 0x418 Slope definition A5. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A Reset 0x0000037B Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 1 1 1 1 0 1 1 Value Description A A (slope definition) register. 13.1.27 TEMP.B0 Address offset: 0x41C y-intercept B0. Page 49 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A Reset 0x00003FCC Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 1 1 0 0 Value Description B B (y-intercept) 13.1.28 TEMP.B1 Address offset: 0x420 y-intercept B1. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A Reset 0x00003F98 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 0 0 1 1 0 0 0 Value Description B B (y-intercept) 13.1.29 TEMP.B2 Address offset: 0x424 y-intercept B2. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A Reset 0x00003F98 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 0 0 1 1 0 0 0 Value Description B B (y-intercept) 13.1.30 TEMP.B3 Address offset: 0x428 y-intercept B3. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A Reset 0x00000012 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 0 Value Description B B (y-intercept) 13.1.31 TEMP.B4 Address offset: 0x42C y-intercept B4. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A Reset 0x0000004D Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 1 0 1 Value Description B B (y-intercept) 13.1.32 TEMP.B5 Address offset: 0x430 y-intercept B5. Page 50 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A Reset 0x00003E10 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 0 0 0 0 1 0 0 0 0 Value Description B B (y-intercept) 13.1.33 TEMP.T0 Address offset: 0x434 Segment end T0. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x000000E2 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 0 0 0 1 0 Value Description T T (segment end)register. 13.1.34 TEMP.T1 Address offset: 0x438 Segment end T1. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description T T (segment end)register. 13.1.35 TEMP.T2 Address offset: 0x43C Segment end T2. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000014 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 Value Description T T (segment end)register. 13.1.36 TEMP.T3 Address offset: 0x440 Segment end T3. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000019 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 1 Value Description T T (segment end)register. 13.1.37 TEMP.T4 Address offset: 0x444 Segment end T4. Page 51 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000050 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 Value Description T T (segment end)register. 13.1.38 NFC.TAGHEADER0 Address offset: 0x450 Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFCID1_2ND_LAST and NFCID1_LAST. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0xFFFFFF5F 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 1 1 Id RW Field Value A R MFGID Description B R UD1 Unique identifier byte 1 C R UD2 Unique identifier byte 2 D R UD3 Unique identifier byte 3 Default Manufacturer ID: Nordic Semiconductor ASA has ICM 0x5F 13.1.39 NFC.TAGHEADER1 Address offset: 0x454 Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFCID1_2ND_LAST and NFCID1_LAST. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0xFFFFFFFF 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field Value A R UD4 Description Unique identifier byte 4 B R UD5 Unique identifier byte 5 C R UD6 Unique identifier byte 6 D R UD7 Unique identifier byte 7 13.1.40 NFC.TAGHEADER2 Address offset: 0x458 Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFCID1_2ND_LAST and NFCID1_LAST. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0xFFFFFFFF 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field Value A R UD8 Description Unique identifier byte 8 B R UD9 Unique identifier byte 9 C R UD10 Unique identifier byte 10 D R UD11 Unique identifier byte 11 13.1.41 NFC.TAGHEADER3 Address offset: 0x45C Default header for NFC Tag. Software can read these values to populate NFCID1_3RD_LAST, NFCID1_2ND_LAST and NFCID1_LAST. Page 52 13 FICR — Factory information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0xFFFFFFFF 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field Value A R UD12 Description Unique identifier byte 12 B R UD13 Unique identifier byte 13 C R UD14 Unique identifier byte 14 D R UD15 Unique identifier byte 15 Page 53 14 UICR — User information configuration registers 14 UICR — User information configuration registers The user information configuration registers (UICRs) are non-volatile memory (NVM) registers for configuring user specific settings. For information on writing UICR registers, see the NVMC — Non-volatile memory controller on page 29 and Memory on page 23 chapters. 14.1 Registers Table 19: Instances Base address Peripheral Instance Description 0x10001000 UICR UICR User Information Configuration Configuration Table 20: Register Overview Register Offset Description 0x000 Reserved 0x004 Reserved 0x008 Reserved 0x010 Reserved NRFFW[0] 0x014 Reserved for Nordic firmware design NRFFW[1] 0x018 Reserved for Nordic firmware design NRFFW[2] 0x01C Reserved for Nordic firmware design NRFFW[3] 0x020 Reserved for Nordic firmware design NRFFW[4] 0x024 Reserved for Nordic firmware design NRFFW[5] 0x028 Reserved for Nordic firmware design NRFFW[6] 0x02C Reserved for Nordic firmware design NRFFW[7] 0x030 Reserved for Nordic firmware design NRFFW[8] 0x034 Reserved for Nordic firmware design NRFFW[9] 0x038 Reserved for Nordic firmware design NRFFW[10] 0x03C Reserved for Nordic firmware design NRFFW[11] 0x040 Reserved for Nordic firmware design NRFFW[12] 0x044 Reserved for Nordic firmware design NRFFW[13] 0x048 Reserved for Nordic firmware design NRFFW[14] 0x04C Reserved for Nordic firmware design NRFHW[0] 0x050 Reserved for Nordic hardware design NRFHW[1] 0x054 Reserved for Nordic hardware design NRFHW[2] 0x058 Reserved for Nordic hardware design NRFHW[3] 0x05C Reserved for Nordic hardware design NRFHW[4] 0x060 Reserved for Nordic hardware design NRFHW[5] 0x064 Reserved for Nordic hardware design NRFHW[6] 0x068 Reserved for Nordic hardware design NRFHW[7] 0x06C Reserved for Nordic hardware design NRFHW[8] 0x070 Reserved for Nordic hardware design NRFHW[9] 0x074 Reserved for Nordic hardware design NRFHW[10] 0x078 Reserved for Nordic hardware design NRFHW[11] 0x07C Reserved for Nordic hardware design CUSTOMER[0] 0x080 Reserved for customer CUSTOMER[1] 0x084 Reserved for customer CUSTOMER[2] 0x088 Reserved for customer CUSTOMER[3] 0x08C Reserved for customer CUSTOMER[4] 0x090 Reserved for customer CUSTOMER[5] 0x094 Reserved for customer CUSTOMER[6] 0x098 Reserved for customer Page 54 14 UICR — User information configuration registers Register Offset Description CUSTOMER[7] 0x09C Reserved for customer CUSTOMER[8] 0x0A0 Reserved for customer CUSTOMER[9] 0x0A4 Reserved for customer CUSTOMER[10] 0x0A8 Reserved for customer CUSTOMER[11] 0x0AC Reserved for customer CUSTOMER[12] 0x0B0 Reserved for customer CUSTOMER[13] 0x0B4 Reserved for customer CUSTOMER[14] 0x0B8 Reserved for customer CUSTOMER[15] 0x0BC Reserved for customer CUSTOMER[16] 0x0C0 Reserved for customer CUSTOMER[17] 0x0C4 Reserved for customer CUSTOMER[18] 0x0C8 Reserved for customer CUSTOMER[19] 0x0CC Reserved for customer CUSTOMER[20] 0x0D0 Reserved for customer CUSTOMER[21] 0x0D4 Reserved for customer CUSTOMER[22] 0x0D8 Reserved for customer CUSTOMER[23] 0x0DC Reserved for customer CUSTOMER[24] 0x0E0 Reserved for customer CUSTOMER[25] 0x0E4 Reserved for customer CUSTOMER[26] 0x0E8 Reserved for customer CUSTOMER[27] 0x0EC Reserved for customer CUSTOMER[28] 0x0F0 Reserved for customer CUSTOMER[29] 0x0F4 Reserved for customer CUSTOMER[30] 0x0F8 Reserved for customer CUSTOMER[31] 0x0FC Reserved for customer PSELRESET[0] 0x200 Mapping of the nRESET function (see POWER chapter for details) PSELRESET[1] 0x204 Mapping of the nRESET function (see POWER chapter for details) APPROTECT 0x208 Access Port protection NFCPINS 0x20C Setting of pins dedicated to NFC functionality: NFC antenna or GPIO 14.1.1 NRFFW[0] Address offset: 0x014 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.2 NRFFW[1] Address offset: 0x018 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.3 NRFFW[2] Address offset: 0x01C Reserved for Nordic firmware design Page 55 14 UICR — User information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.4 NRFFW[3] Address offset: 0x020 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.5 NRFFW[4] Address offset: 0x024 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.6 NRFFW[5] Address offset: 0x028 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.7 NRFFW[6] Address offset: 0x02C Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.8 NRFFW[7] Address offset: 0x030 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design Page 56 14 UICR — User information configuration registers 14.1.9 NRFFW[8] Address offset: 0x034 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.10 NRFFW[9] Address offset: 0x038 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.11 NRFFW[10] Address offset: 0x03C Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.12 NRFFW[11] Address offset: 0x040 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.13 NRFFW[12] Address offset: 0x044 Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.14 NRFFW[13] Address offset: 0x048 Reserved for Nordic firmware design Page 57 14 UICR — User information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.15 NRFFW[14] Address offset: 0x04C Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFFW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic firmware design 14.1.16 NRFHW[0] Address offset: 0x050 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.17 NRFHW[1] Address offset: 0x054 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.18 NRFHW[2] Address offset: 0x058 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.19 NRFHW[3] Address offset: 0x05C Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design Page 58 14 UICR — User information configuration registers 14.1.20 NRFHW[4] Address offset: 0x060 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.21 NRFHW[5] Address offset: 0x064 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.22 NRFHW[6] Address offset: 0x068 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.23 NRFHW[7] Address offset: 0x06C Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.24 NRFHW[8] Address offset: 0x070 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.25 NRFHW[9] Address offset: 0x074 Reserved for Nordic hardware design Page 59 14 UICR — User information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.26 NRFHW[10] Address offset: 0x078 Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.27 NRFHW[11] Address offset: 0x07C Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW NRFHW 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for Nordic hardware design 14.1.28 CUSTOMER[0] Address offset: 0x080 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.29 CUSTOMER[1] Address offset: 0x084 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.30 CUSTOMER[2] Address offset: 0x088 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer Page 60 14 UICR — User information configuration registers 14.1.31 CUSTOMER[3] Address offset: 0x08C Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.32 CUSTOMER[4] Address offset: 0x090 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.33 CUSTOMER[5] Address offset: 0x094 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.34 CUSTOMER[6] Address offset: 0x098 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.35 CUSTOMER[7] Address offset: 0x09C Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.36 CUSTOMER[8] Address offset: 0x0A0 Reserved for customer Page 61 14 UICR — User information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.37 CUSTOMER[9] Address offset: 0x0A4 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.38 CUSTOMER[10] Address offset: 0x0A8 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.39 CUSTOMER[11] Address offset: 0x0AC Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.40 CUSTOMER[12] Address offset: 0x0B0 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.41 CUSTOMER[13] Address offset: 0x0B4 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer Page 62 14 UICR — User information configuration registers 14.1.42 CUSTOMER[14] Address offset: 0x0B8 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.43 CUSTOMER[15] Address offset: 0x0BC Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.44 CUSTOMER[16] Address offset: 0x0C0 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.45 CUSTOMER[17] Address offset: 0x0C4 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.46 CUSTOMER[18] Address offset: 0x0C8 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.47 CUSTOMER[19] Address offset: 0x0CC Reserved for customer Page 63 14 UICR — User information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.48 CUSTOMER[20] Address offset: 0x0D0 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.49 CUSTOMER[21] Address offset: 0x0D4 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.50 CUSTOMER[22] Address offset: 0x0D8 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.51 CUSTOMER[23] Address offset: 0x0DC Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.52 CUSTOMER[24] Address offset: 0x0E0 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer Page 64 14 UICR — User information configuration registers 14.1.53 CUSTOMER[25] Address offset: 0x0E4 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.54 CUSTOMER[26] Address offset: 0x0E8 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.55 CUSTOMER[27] Address offset: 0x0EC Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.56 CUSTOMER[28] Address offset: 0x0F0 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.57 CUSTOMER[29] Address offset: 0x0F4 Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.58 CUSTOMER[30] Address offset: 0x0F8 Reserved for customer Page 65 14 UICR — User information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.59 CUSTOMER[31] Address offset: 0x0FC Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW CUSTOMER 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Reserved for customer 14.1.60 PSELRESET[0] Address offset: 0x200 Mapping of the nRESET function (see POWER chapter for details) All PSELRESET registers have to contain the same value for a pin mapping to be valid. If they don't, there will be no nRESET function exposed on a GPIO, and the device will always start independently of the levels present on any of the GPIOs. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description 21 GPIO number P0.n onto which Reset is exposed Connection Disconnected 1 Disconnect Connected 0 Connect 14.1.61 PSELRESET[1] Address offset: 0x204 Mapping of the nRESET function (see POWER chapter for details) All PSELRESET registers have to contain the same value for a pin mapping to be valid. If they don't, there will be no nRESET function exposed on a GPIO, and the device will always start independently of the levels present on any of the GPIOs. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description 21 GPIO number P0.n onto which Reset is exposed Connection Disconnected 1 Disconnect Connected 0 Connect 14.1.62 APPROTECT Address offset: 0x208 Access Port protection Page 66 14 UICR — User information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PALL 1 Value Id 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Enable or disable Access Port protection. Any other value than 0xFF being written to this field will enable protection. See Debug and trace on page 72 for more information. Disabled 0xFF Disable Enabled 0x00 Enable 14.1.63 NFCPINS Address offset: 0x20C Setting of pins dedicated to NFC functionality: NFC antenna or GPIO Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0xFFFFFFFF Id RW Field A RW PROTECT 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Description Disabled 0 Operation as GPIO pins. Same protection as normal GPIO pins NFC 1 Operation as NFC antenna pins. Configures the protection for Setting of pins dedicated to NFC functionality NFC operation Page 67 15 Peripheral interface 15 Peripheral interface Peripherals are controlled by the CPU by writing to configuration registers and task registers. Peripheral events are indicated to the CPU by event registers and interrupts if they are configured for a given event. Task signal from PPI Peripheral TASK write k OR SHORTS task Peripheral core event INTEN m EVENT m IRQ signal to NVIC Event signal to PPI Figure 10: Tasks, events, shortcuts, and interrupts 15.1 Peripheral ID Every peripheral is assigned a fixed block of 0x1000 bytes of address space, which is equal to 1024 x 32 bit registers. See Instantiation on page 24 for more information about which peripherals are available and where they are located in the address map. There is a direct relationship between the peripheral ID and base address. For example, a peripheral with base address 0x40000000 is assigned ID=0, a peripheral with base address 0x40001000 is assigned ID=1, and a peripheral with base address 0x4001F000 is assigned ID=31. Peripherals may share the same ID, which may impose one or more of the following limitations: • • • Some peripherals share some registers or other common resources. Operation is mutually exclusive. Only one of the peripherals can be used at a time. Switching from one peripheral to another must follow a specific pattern (disable the first, then enable the second peripheral). 15.2 Peripherals with shared ID In general, and with the exception of ID 0, peripherals sharing an ID and base address may not be used simultaneously. The user can only enable one at the time on this specific ID. When switching between two peripherals that share an ID, the user should do the following to prevent unwanted behavior: • Disable the previously used peripheral Page 68 15 Peripheral interface • • • • Remove any PPI connections set up for the peripheral that is being disabled Clear all bits in the INTEN register, i.e. INTENCLR = 0xFFFFFFFF. Explicitly configure the peripheral that you enable and do not rely on configuration values that may be inherited from the peripheral that was disabled. Enable the now configured peripheral. For each of the rows in the following table, the instance ID listed is shared by the peripherals in the same row. Table 21: Peripherals sharing an ID Instance ID 2 (0x40002000) ID 3 (0x40003000) ID 4 (0x40004000) ID 35 (0x40023000) ID 15 (0x4000F000) ID 19 (0x40013000) ID 20 (0x40014000) ID 21 (0x40015000) ID 22 (0x40016000) ID 23 (0x40017000) ID 24 (0x40018000) ID 25 (0x40019000) UARTE UART SPIM SPIM SPIM SPIS SPIS SPIS AAR CCM COMP LPCOMP SWI SWI SWI SWI SWI SWI EGU EGU EGU EGU EGU EGU SPI SPI SPI TWIM TWIM TWIS TWIS TWI TWI 15.3 Peripheral registers Most peripherals feature an ENABLE register. Unless otherwise specified in the relevant chapter, the peripheral registers (in particular the PSEL registers) must be configured before enabling the peripheral. Note that the peripheral must be enabled before tasks and events can be used. 15.4 Bit set and clear Registers with multiple single-bit bit fields may implement the "set-and-clear" pattern. This pattern enables firmware to set and clear individual bits in a register without having to perform a read-modify-write operation on the main register. This pattern is implemented using three consecutive addresses in the register map where the main register is followed by a dedicated SET and CLR register in that order. The SET register is used to set individual bits in the main register while the CLR register is used to clear individual bits in the main register. Writing a '1' to a bit in the SET or CLR register will set or clear the same bit in the main register respectively. Writing a '0' to a bit in the SET or CLR register has no effect. Reading the SET or CLR registers returns the value of the main register. Restriction: The main register may not be visible and hence not directly accessible in all cases. 15.5 Tasks Tasks are used to trigger actions in a peripheral, for example, to start a particular behavior. A peripheral can implement multiple tasks with each task having a separate register in that peripheral's task register group. A task is triggered when firmware writes a '1' to the task register or when the peripheral itself or another peripheral toggles the corresponding task signal. See Figure 10: Tasks, events, shortcuts, and interrupts on page 68. Page 69 15 Peripheral interface 15.6 Events Events are used to notify peripherals and the CPU about events that have happened, for example, a state change in a peripheral. A peripheral may generate multiple events with each event having a separate register in that peripheral’s event register group. An event is generated when the peripheral itself toggles the corresponding event signal, and the event register is updated to reflect that the event has been generated. See Figure 10: Tasks, events, shortcuts, and interrupts on page 68. An event register is only cleared when firmware writes a '0' to it. Events can be generated by the peripheral even when the event register is set to '1'. 15.7 Shortcuts A shortcut is a direct connection between an event and a task within the same peripheral. If a shortcut is enabled, its associated task is automatically triggered when its associated event is generated. Using a shortcut is the equivalent to making the same connection outside the peripheral and through the PPI. However, the propagation delay through the shortcut is usually shorter than the propagation delay through the PPI. Shortcuts are predefined, which means their connections cannot be configured by firmware. Each shortcut can be individually enabled or disabled through the shortcut register, one bit per shortcut, giving a maximum of 32 shortcuts for each peripheral. 15.8 Interrupts All peripherals support interrupts. Interrupts are generated by events. A peripheral only occupies one interrupt, and the interrupt number follows the peripheral ID. For example, the peripheral with ID=4 is connected to interrupt number 4 in the Nested Vectored Interrupt Controller (NVIC). Using the INTEN, INTENSET and INTENCLR registers, every event generated by a peripheral can be configured to generate that peripheral’s interrupt. Multiple events can be enabled to generate interrupts simultaneously. To resolve the correct interrupt source, the event registers in the event group of peripheral registers will indicate the source. Some peripherals implement only INTENSET and INTENCLR, and the INTEN register is not available on those peripherals. Refer to the individual chapters for details. In all cases, however, reading back the INTENSET or INTENCLR register returns the same information as in INTEN. Each event implemented in the peripheral is associated with a specific bit position in the INTEN, INTENSET and INTENCLR registers. The relationship between tasks, events, shortcuts, and interrupts is shown in Figure 10: Tasks, events, shortcuts, and interrupts on page 68. 15.8.1 Interrupt clearing When clearing an interrupt by writing "0" to an event register, or disabling an interrupt using the INTENCLR register, it can take up to four CPU clock cycles to take effect. This means that an interrupt may reoccur immediatelly even if a new event has not come, if the program exits an interrupt handler after the interrupt is cleared or disabled, but before four clock cycles have passed. Important: To avoid an interrupt reoccurring before a new event has come, the program should perform a read from one of the peripheral registers, for example, the event register that has been cleared, or the INTENCLR register that has been used to disable the interrupt. This will cause a one to three-cycle delay and ensure the interrupt is cleared before exiting the interrupt handler. Care should be taken to ensure the compiler does not remove the read operation as an optimization. If the program can guarantee a four-cycle delay after event clear or interrupt disable another way, then a read of a register is not required. Page 70 15 Peripheral interface Page 71 16 Debug and trace 16 Debug and trace The debug and trace system offers a flexible and powerful mechanism for non-intrusive debugging. nRF52832 DAP SWDCLK External Debugger CTRL-AP NVMC SW-DP SWDIO APPROTECT.PALL UICR DAP bus interconnect AHB AHB-AP CxxxPWRUPREQ CxxxPWRUPRACK POWER RAM & Flash CPU Power ARM Cortex-M4 TRACECLK Trace TRACEDATA[0] / SWO APB/AHB ETM Peripherals TRACEDATA[1] TRACEDATA[2] TPIU TRACEDATA[3] Trace ITM Figure 11: Debug and trace overview The main features of the debug and trace system are: • • Two-pin Serial Wire Debug (SWD) interface Flash Patch and Breakpoint Unit (FPB) supports: • • Two literal comparators • Six instruction comparators Data Watchpoint and Trace Unit (DWT) • • • • Four comparators Instrumentation Trace Macrocell (ITM) Embedded Trace Macrocell (ETM) Trace Port Interface Unit (TPIU) • • 4-bit parallel trace of ITM and ETM trace data Serial Wire Output (SWO) trace of ITM data 16.1 DAP - Debug Access Port An external debugger can access the device via the DAP. The DAP implements a standard ARM® CoreSight™ Serial Wire Debug Port (SW-DP). The SW-DP implements the Serial Wire Debug protocol (SWD) that is a two-pin serial interface, see SWDCLK and SWDIO in Figure 11: Debug and trace overview on page 72. In addition to the default access port in the CPU (AHB-AP), the DAP includes a custom Control Access Port (CTRL-AP). The CTRL-AP is described in more detail in CTRL-AP - Control Access Port on page 73. Important: • • The SWDIO line has an internal pull-up resistor. The SWDCLK line has an internal pull-down resistor. Page 72 16 Debug and trace 16.2 CTRL-AP - Control Access Port The Control Access Port (CTRL-AP) is a custom access port that enables control of the device even if the other access ports in the DAP are being disabled by the access port protection. Access port protection blocks the debugger from read and write access to all CPU registers and memorymapped addresses. See the UICR register APPROTECT on page 66 for more information about enabling access port protection. This access port enables the following features: • • Soft reset, see Reset on page 82 for more information Disable access port protection Access port protection can only be disabled by issuing an ERASEALL command via CTRL-AP. This command will erase the Flash, UICR, and RAM. 16.2.1 Registers Table 22: Register Overview Register Offset Description RESET 0x000 Soft reset triggered through CTRL-AP ERASEALL 0x004 Erase all ERASEALLSTATUS 0x008 Status register for the ERASEALL operation APPROTECTSTATUS 0x00C Status register for access port protection IDR 0x0FC CTRL-AP Identification Register, IDR RESET Address offset: 0x000 Soft reset triggered through CTRL-AP Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW RESET 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Soft reset triggered through CTRL-AP. See Reset Behaviour in POWER chapter for more details. NoReset 0 Reset is not active Reset 1 Reset is active. Device is held in reset ERASEALL Address offset: 0x004 Erase all Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NoOperation 0 No operation Erase 1 Erase all FLASH and RAM ERASEALL Erase all FLASH and RAM ERASEALLSTATUS Address offset: 0x008 Status register for the ERASEALL operation Page 73 16 Debug and trace Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Ready 0 ERASEALL is ready Busy 1 ERASEALL is busy (on-going) ERASEALLSTATUS Status register for the ERASEALL operation APPROTECTSTATUS Address offset: 0x00C Status register for access port protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 0 Access port protection enabled Disabled 1 Access port protection not enabled APPROTECTSTATUS Status register for access port protection IDR Address offset: 0x0FC CTRL-AP Identification Register, IDR Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E E E E D D D D C C C C C C C B B B B Reset 0x02880000 0 0 0 0 0 0 1 0 1 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A R APID B R CLASS Value Id Value A A A A A A A A Description AP Identification Access Port (AP) class NotDefined 0x0 No defined class MEMAP 0x8 Memory Access Port C R JEP106ID JEDEC JEP106 identity code D R JEP106CONT JEDEC JEP106 continuation code E R REVISION Revision 16.3 Debug interface mode Before the external debugger can access the CPU's access port (AHB-AP) or the Control Access Port (CTRL-AP), the debugger must first request the device to power up via CxxxPWRUPREQ in the SWJ-DP. As long as the debugger is requesting power via CxxxPWRUPREQ, the device will be in debug interface mode. If the debugger is not requesting power via CxxxPWRUPREQ, the device will be in normal mode. Some peripherals will behave differently in debug interface mode compared to normal mode. These differences are described in more detail in the chapters of the peripherals that are affected. When a debug session is over, the external debugger must make sure to put the device back into normal mode since the overall power consumption will be higher in debug interface mode compared to normal mode. For details on how to use the debug capabilities please read the debug documentation of your IDE. If the device is in System OFF when power is requested via CxxxPWRUPREQ, the system will wake up and the DIF flag in RESETREAS on page 85 will be set. 16.4 Real-time debug The nRF52832 supports real-time debugging. Page 74 16 Debug and trace Real-time debugging will allow interrupts to execute to completion in real time when breakpoints are set in Thread mode or lower priority interrupts. This enables the developer to set a breakpoint and singlestep through their code without a failure of the real-time event-driven threads running at higher priority. For example, this enables the device to continue to service the high-priority interrupts of an external controller or sensor without failure or loss of state synchronization while the developer steps through code in a low-priority thread. 16.5 Trace The device supports ETM and ITM trace. Trace data from the ETM and the ITM is sent to an external debugger via a 4-bit wide parallel trace port (TPIU), see TRACEDATA[0] through TRACEDATA[3] and TRACECLK in Figure 11: Debug and trace overview on page 72. In addition to parallel trace, the TPIU supports serial trace via the Serial Wire Output (SWO) trace protocol. Parallel and serial trace cannot be used at the same time. ETM trace is only supported in parallel trace mode while ITM trace is supported in both parallel and serial trace modes. For details on how to use the trace capabilities, please read the debug documentation of your IDE. TPIU's trace pins are multiplexed with GPIOs, and SWO and TRACEDATA[0] use the same GPIO, see Pin assignments on page 13 for more information. Trace speed is configured in the TRACECONFIG on page 108 register. The speed of the trace pins depends on the DRIVE setting of the GPIOs that the trace pins are multiplexed with, see PIN_CNF[14] on page 142, PIN_CNF[15] on page 143, PIN_CNF[16] on page 144, PIN_CNF[18] on page 145 and PIN_CNF[20] on page 146. Only S0S1 and H0H1 drives are suitable for debugging. S0S1 is the default DRIVE at reset. If parallel or serial trace port signals are not fast enough in the debugging conditions, all GPIOs in use for tracing should be set to high drive (H0H1). The user shall make sure that these GPIOs' DRIVE is not overwritten by software during the debugging session. 16.5.1 Electrical specification Trace port Symbol Description Min. Tcyc Clock period, as defined by ARM (See ARM Infocenter, 62.5 Embedded Trace Macrocell Architecture Specification, Trace Port Physical Interface, Timing specifications) Page 75 Typ. Max. Units 500 ns 17 Power and clock management 17 Power and clock management Power and clock management in nRF52832 is optimized for ultra-low power applications. The core of the power and clock management system is the Power Management Unit (PMU) illustrated in Figure 12: Power Management Unit on page 76. MCU CPU External Power sources Internal voltage regulators PMU Memory External crystals Internal oscillators Peripheral Figure 12: Power Management Unit The user application is not required to actively control power and clock, since the PMU is able to automatically detect which resources are required by the different components in the system at any given time. The PMU will continuously optimize the system based on this information to achieve the lowest power consumption possible without user interaction. 17.1 Current consumption scenarios As the system is being constantly tuned by the PMU, estimating the energy consumption of an application can be challenging if the designer is not able to do measurements on the hardware directly. See Electrical specification on page 76 for application scenarios showing average current drawn from the VDD supply. Each scenario specifies a set of active operations and conditions applying to the given scenario. Table 23: Current consumption scenarios, common conditions on page 76 shows the conditions used for a scenario unless otherwise is stated in the scenario description. Table 23: Current consumption scenarios, common conditions Condition VDD Temperature CPU Peripherals Clock Regulator Value 3V 25°C WFI/WFE sleep All idle Not running DCDC 17.1.1 Electrical specification Current consumption: Radio Symbol Description IRADIO_TX0 0 dBm TX @ 1 Mb/s Bluetooth Low Energy mode, Clock = HFXO Min. Typ. 7.1 Max. Units mA IRADIO_TX1 -40 dBm TX @ 1 Mb/s Bluetooth Low Energy mode, Clock = 4.1 mA 6.5 mA HFXO IRADIO_RX0 Radio RX @ 1 Mb/s Bluetooth Low Energy mode, Clock = HFXO Page 76 17 Power and clock management Current consumption: Radio protocol configurations Symbol Description IS0 CPU running CoreMark from Flash, Radio 0 dBm TX @ 1 Mb/s Min. Typ. Max. Units 9.2 mA 9.2 mA Bluetooth Low Energy mode, Clock = HFXO, Cache enabled IS1 CPU running CoreMark from Flash, Radio RX @ 1 Mb/s Bluetooth Low Energy mode, Clock = HFXO, Cache enabled Current consumption: Ultra-low power Symbol Description ION_RAMOFF_EVENT System ON, No RAM retention, Wake on any event Min. 1.2 µA ION_RAMON_EVENT System ON, Full RAM retention, Wake on any event 1.5 µA ION_RAMOFF_RTC System ON, No RAM retention, Wake on RTC 1.9 µA IOFF_RAMOFF_RESET System OFF, No RAM retention, Wake on reset 0.3 µA IOFF_RAMOFF_GPIO System OFF, No RAM retention, Wake on GPIO 0.3 µA IOFF_RAMOFF_LPCOMP System OFF, No RAM retention, Wake on LPCOMP 1.9 µA IOFF_RAMOFF_NFC System OFF, No RAM retention, Wake on NFC field 0.7 µA IOFF_RAMON_RESET System OFF, Full 64 kB RAM retention, Wake on reset 0.7 µA Page 77 Typ. Max. Units 18 POWER — Power supply 18 POWER — Power supply This device has the following power supply features: • • • • • • • On-chip LDO and DC/DC regulators Global System ON/OFF modes Individual RAM section power control for all system modes Analog or digital pin wakeup from System OFF Supervisor HW to manage power on reset, brownout, and power fail Auto-controlled refresh modes for LDO and DC/DC regulators to maximize efficiency Automatic switching between LDO and DC/DC regulator based on load to maximize efficiency Note: Two additional external passive components are required to use the DC/DC regulator. 18.1 Regulators The following internal power regulator alternatives are supported: • • Internal LDO regulator Internal DC/DC regulator The LDO is the default regulator. The DC/DC regulator can be used as an alternative to the LDO regulator and is enabled through the DCDCEN on page 88 register. Using the DC/DC regulator will reduce current consumption compared to when using the LDO regulator, but the DC/DC regulator requires an external LC filter to be connected, as shown in Figure 14: DC/DC regulator setup on page 79. POWER DCDCEN REG Supply LDO 1.3V System power VDD DC/DC DCC Figure 13: LDO regulator setup Page 78 DEC4 GND 18 POWER — Power supply POWER DCDCEN REG Supply LDO 1.3V System power VDD DC/DC DCC DEC4 GND Figure 14: DC/DC regulator setup 18.2 System OFF mode System OFF is the deepest power saving mode the system can enter. In this mode, the system’s core functionality is powered down and all ongoing tasks are terminated. The device can be put into System OFF mode using the POWER register interface. When in System OFF mode, the device can be woken up through one of the following signals: 1. 2. 3. 4. The DETECT signal, optionally generated by the GPIO peripheral The ANADETECT signal, optionally generated by the LPCOMP module The SENSE signal, optionally generated by the NFC module to “wake-on-field” A reset When the system wakes up from System OFF mode, it gets reset. For more details, see Reset behavior on page 83. One or more RAM sections can be retained in System OFF mode depending on the settings in the RAM[n].POWER registers. RAM[n].POWER are retained registers, see Reset behavior. Note that these registers are usually overwritten by the startup code provided with the nRF application examples. Before entering System OFF mode, the user must make sure that all on-going EasyDMA transactions have been completed. This is usually accomplished by making sure that the EasyDMA enabled peripheral is not active when entering System OFF. 18.2.1 Emulated System OFF mode If the device is in debug interface mode, System OFF will be emulated to secure that all required resources needed for debugging are available during System OFF. See Debug and trace on page 72 for more information. Required resources needed for debugging include the following key components: Debug and trace on page 72, CLOCK — Clock control on page 101, POWER — Power supply on page 78, NVMC — Non-volatile memory controller on page 29, CPU, Flash, and RAM. Since the CPU is kept on in an emulated System OFF mode, it is recommended to add an infinite loop directly after entering System OFF, to prevent the CPU from executing code that normally should not be executed. Page 79 18 POWER — Power supply 18.3 System ON mode System ON is the default state after power-on reset. In System ON, all functional blocks such as the CPU or peripherals, can be in IDLE or RUN mode, depending on the configuration set by the software and the state of the application executing. Register RESETREAS on page 85 provides information about the source that caused the wakeup or reset. The system can switch on and off the appropriate internal power sources, depending on how much power is needed at any given time. The power requirement of a peripheral is directly related to its activity level, and the activity level of a peripheral is usually raised and lowered when specific tasks are triggered or events are generated. 18.3.1 Sub power modes In System ON mode, when both the CPU and all the peripherals are in IDLE mode, the system can reside in one of the two sub power modes. The sub power modes are: • • Constant latency Low power In constant latency mode the CPU wakeup latency and the PPI task response will be constant and kept at a minimum. This is secured by forcing a set of base resources on while in sleep. The advantage of having a constant and predictable latency will be at the cost of having increased power consumption. The constant latency mode is selected by triggering the CONSTLAT task. In low power mode the automatic power management system, described in System ON mode on page 80, ensures the most efficient supply option is chosen to save the most power. The advantage of having the lowest power possible will be at the cost of having varying CPU wakeup latency and PPI task response. The low power mode is selected by triggering the LOWPWR task. When the system enters System ON mode, it will, by default, reside in the low power sub-power mode. 18.4 Power supply supervisor The power supply supervisor initializes the system at power-on and provides an early warning of impending power failure. In addition, the power supply supervisor puts the system in a reset state if the supply voltage is too low for safe operation (brownout). The power supply supervisor is illustrated in Figure 15: Power supply supervisor on page 81. Page 80 18 POWER — Power supply VDD C Power on reset R VBOR POFCON Brownout reset 1.7V ........... MUX POFWARN Vpof 2.8V Figure 15: Power supply supervisor 18.4.1 Power-fail comparator The power-fail comparator (POF) can provide the CPU with an early warning of impending power failure. It will not reset the system, but give the CPU time to prepare for an orderly power-down. The comparator features a hysteresis of VHYST, as illustrated in Figure 16: Power-fail comparator (BOR = Brownout reset) on page 81. The threshold VPOF is set in register POFCON on page 86. If the POF is enabled and the supply voltage falls below VPOF, the POFWARN event will be generated. This event will also be generated if the supply voltage is already below VPOF at the time the POF is enabled, or if VPOF is reconfigured to a level above the supply voltage. If power-fail warning is enabled and the supply voltage is below VPOF the power-fail comparator will prevent the NVMC from performing write operations to the NVM. See NVMC — Non-volatile memory controller on page 29 for more information about the NVMC. VDD VPOF+VHYST VPOF 1.7V POFWARN POFWARN MCU t BOR Figure 16: Power-fail comparator (BOR = Brownout reset) To save power, the power-fail comparator is not active in System OFF or in System ON when HFCLK is not running. Page 81 18 POWER — Power supply 18.5 RAM sections RAM section power control is used for retention in System OFF mode and for powering down unused sections in System ON mode. Each RAM section can power up and down independently in both System ON and System OFF mode. See chapter Memory on page 23 for more information on RAM sections. 18.6 Reset There are multiple sources that may trigger a reset. After a reset has occurred, register RESETREAS can be read to determine which source generated the reset. 18.6.1 Power-on reset The power-on reset generator initializes the system at power-on. The system is held in reset state until the supply has reached the minimum operating voltage and the internal voltage regulators have started. A step increase in supply voltage of 300 mV or more, with rise time of 300 ms or less, within the valid supply range, may result in a system reset. 18.6.2 Pin reset A pin reset is generated when the physical reset pin on the device is asserted. Pin reset is configured via the PSELRESET[0] and PSELRESET[1] registers. Note: Pin reset is not available on all pins. 18.6.3 Wakeup from System OFF mode reset The device is reset when it wakes up from System OFF mode. The DAP is not reset following a wake up from System OFF mode if the device is in debug interface mode. Refer to chapter Debug and trace on page 72 for more information. 18.6.4 Soft reset A soft reset is generated when the SYSRESETREQ bit of the Application Interrupt and Reset Control Register (AIRCR register) in the ARM® core is set. Refer to ARM documentation for more details. A soft reset can also be generated via the RESET on page 73 register in the CTRL-AP. 18.6.5 Watchdog reset A Watchdog reset is generated when the watchdog times out. Refer to chapter WDT — Watchdog timer on page 409 for more information. 18.6.6 Brown-out reset The brown-out reset generator puts the system in reset state if the supply voltage drops below the brownout reset (BOR) threshold. Refer to section Power fail comparator on page 99 for more information. Page 82 18 POWER — Power supply 18.7 Retained registers A retained register is a register that will retain its value in System OFF mode and through a reset, depending on reset source. See individual peripheral chapters for information of which registers are retained for the various peripherals. 18.8 Reset behavior Reset source 6 CPU lockup Soft reset Wakeup from System OFF mode reset Watchdog reset 9 Pin reset Brownout reset Power on reset Reset target CPU Peripherals GPIO x x x x x x x x x x x x x x x x x x x x Debuga SWJ-DP RAM x7 x8 x x x x x x x x x x WDT Retained registers x x x x x x x x RESETREAS x x Note: The RAM is never reset, but depending on reset source, RAM content may be corrupted. 18.9 Registers Table 24: Instances Base address Peripheral Instance Description 0x40000000 POWER POWER Power control Configuration Table 25: Register Overview Register Offset Description TASKS_CONSTLAT 0x078 Enable constant latency mode TASKS_LOWPWR 0x07C Enable low power mode (variable latency) EVENTS_POFWARN 0x108 Power failure warning EVENTS_SLEEPENTER 0x114 CPU entered WFI/WFE sleep EVENTS_SLEEPEXIT 0x118 CPU exited WFI/WFE sleep INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt RESETREAS 0x400 Reset reason RAMSTATUS 0x428 RAM status register SYSTEMOFF 0x500 System OFF register POFCON 0x510 Power failure comparator configuration GPREGRET 0x51C General purpose retention register GPREGRET2 0x520 General purpose retention register RAMON 0x524 RAM on/off register (this register is retained) Deprecated RAMONB 0x554 RAM on/off register (this register is retained) Deprecated DCDCEN 0x578 DC/DC enable register RAM[0].POWER 0x900 RAM0 power control register a 6 7 8 9 Deprecated All debug components excluding SWJ-DP. See Debug and trace on page 72 chapter for more information about the different debug components in the system. Reset from CPU lockup is disabled if the device is in debug interface mode. CPU lockup is not possible in System OFF. The Debug components will not be reset if the device is in debug interface mode. RAM is not reset on wakeup from OFF mode, but depending on settings in the RAM register parts, or the whole RAM, may not be retained after the device has entered System OFF mode. Watchdog reset is not available in System OFF. Page 83 18 POWER — Power supply Register Offset Description RAM[0].POWERSET 0x904 RAM0 power control set register RAM[0].POWERCLR 0x908 RAM0 power control clear register RAM[1].POWER 0x910 RAM1 power control register RAM[1].POWERSET 0x914 RAM1 power control set register RAM[1].POWERCLR 0x918 RAM1 power control clear register RAM[2].POWER 0x920 RAM2 power control register RAM[2].POWERSET 0x924 RAM2 power control set register RAM[2].POWERCLR 0x928 RAM2 power control clear register RAM[3].POWER 0x930 RAM3 power control register RAM[3].POWERSET 0x934 RAM3 power control set register RAM[3].POWERCLR 0x938 RAM3 power control clear register RAM[4].POWER 0x940 RAM4 power control register RAM[4].POWERSET 0x944 RAM4 power control set register RAM[4].POWERCLR 0x948 RAM4 power control clear register RAM[5].POWER 0x950 RAM5 power control register RAM[5].POWERSET 0x954 RAM5 power control set register RAM[5].POWERCLR 0x958 RAM5 power control clear register RAM[6].POWER 0x960 RAM6 power control register RAM[6].POWERSET 0x964 RAM6 power control set register RAM[6].POWERCLR 0x968 RAM6 power control clear register RAM[7].POWER 0x970 RAM7 power control register RAM[7].POWERSET 0x974 RAM7 power control set register RAM[7].POWERCLR 0x978 RAM7 power control clear register 18.9.1 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B Reset 0x00000000 Id RW Field A RW POFWARN 0 Value Id Value Description Write '1' to Enable interrupt for POFWARN event See EVENTS_POFWARN B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SLEEPENTER Write '1' to Enable interrupt for SLEEPENTER event See EVENTS_SLEEPENTER C A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SLEEPEXIT Write '1' to Enable interrupt for SLEEPEXIT event See EVENTS_SLEEPEXIT Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 18.9.2 INTENCLR Address offset: 0x308 Disable interrupt Page 84 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B Reset 0x00000000 Id RW Field A RW POFWARN 0 Value Id A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for POFWARN event See EVENTS_POFWARN B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SLEEPENTER Write '1' to Disable interrupt for SLEEPENTER event See EVENTS_SLEEPENTER C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SLEEPEXIT Write '1' to Disable interrupt for SLEEPEXIT event See EVENTS_SLEEPEXIT Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 18.9.3 RESETREAS Address offset: 0x400 Reset reason Unless cleared, the RESETREAS register will be cumulative. A field is cleared by writing '1' to it. If none of the reset sources are flagged, this indicates that the chip was reset from the on-chip reset generator, which will indicate a power-on-reset or a brownout reset. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E Reset 0x00000000 Id RW Field A RW RESETPIN B C D E 0 Value Id Value Description NotDetected 0 Not detected Detected 1 Detected NotDetected 0 Not detected Detected 1 Detected NotDetected 0 Not detected Detected 1 Detected NotDetected 0 Not detected Detected 1 Detected Reset from pin-reset detected RW DOG Reset from watchdog detected RW SREQ Reset from soft reset detected RW LOCKUP Reset from CPU lock-up detected RW OFF Reset due to wake up from System OFF mode when wakeup is triggered from DETECT signal from GPIO F NotDetected 0 Not detected Detected 1 Detected RW LPCOMP Reset due to wake up from System OFF mode when wakeup is triggered from ANADETECT signal from LPCOMP G D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 NotDetected 0 Not detected Detected 1 Detected RW DIF Reset due to wake up from System OFF mode when wakeup is triggered from entering into debug interface mode NotDetected 0 Not detected Detected 1 Detected Page 85 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E Reset 0x00000000 Id RW Field H RW NFC 0 Value Id D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Reset due to wake up from System OFF mode by NFC field detect NotDetected 0 Not detected Detected 1 Detected 18.9.4 RAMSTATUS ( Deprecated ) Address offset: 0x428 RAM status register Since this register is deprecated the following substitutions have been made: RAM block 0 is equivalent to a block comprising RAM0.S0 and RAM1.S0, RAM block 1 is equivalent to a block comprising RAM2.S0 and RAM3.S0, RAM block 2 is equivalent to a block comprising RAM4.S0 and RAM5.S0 and RAM block 3 is equivalent to a block comprising RAM6.S0 and RAM7.S0. A RAM block field will indicate ON as long as any of the RAM sections associated with a block are on. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C B A Reset 0x00000000 Id RW Field A R B C D R R R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RAMBLOCK0 RAM block 0 is on or off/powering up RAMBLOCK1 RAM block 1 is on or off/powering up RAMBLOCK2 RAM block 2 is on or off/powering up RAMBLOCK3 RAM block 3 is on or off/powering up 18.9.5 SYSTEMOFF Address offset: 0x500 System OFF register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Enter 1 Description SYSTEMOFF Enable System OFF mode Enable System OFF mode 18.9.6 POFCON Address offset: 0x510 Power failure comparator configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B A Reset 0x00000000 Id RW Field A RW POF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Disabled 0 Description Enable or disable power failure comparator Disable Page 86 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B A Reset 0x00000000 Id B RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Enable V17 4 Set threshold to 1.7 V V18 5 Set threshold to 1.8 V V19 6 Set threshold to 1.9 V V20 7 Set threshold to 2.0 V V21 8 Set threshold to 2.1 V V22 9 Set threshold to 2.2 V V23 10 Set threshold to 2.3 V V24 11 Set threshold to 2.4 V V25 12 Set threshold to 2.5 V V26 13 Set threshold to 2.6 V V27 14 Set threshold to 2.7 V V28 15 Set threshold to 2.8 V RW THRESHOLD Power failure comparator threshold setting 18.9.7 GPREGRET Address offset: 0x51C General purpose retention register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW GPREGRET 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description General purpose retention register This register is a retained register 18.9.8 GPREGRET2 Address offset: 0x520 General purpose retention register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW GPREGRET 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description General purpose retention register This register is a retained register 18.9.9 RAMON ( Deprecated ) Address offset: 0x524 RAM on/off register (this register is retained) Since this register is deprecated the following substitutions have been made: RAM block 0 is equivalent to a block comprising RAM0.S0 and RAM0.S1 and RAM block 1 is equivalent to a block comprising RAM1.S0 and RAM1.S1. For new designs it is recommended to use the POWER.RAM-0.POWER and its sibling registers instead. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x00000003 Id RW Field A RW ONRAM0 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 Value Id Value RAM0Off 0 Description Keep RAM block 0 on or off in system ON Mode Off Page 87 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x00000003 Id B C D RW Field 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 Value Id Value Description RAM0On 1 On RAM1Off 0 Off RAM1On 1 On RAM0Off 0 Off RAM0On 1 On RAM1Off 0 Off RAM1On 1 On RW ONRAM1 Keep RAM block 1 on or off in system ON Mode RW OFFRAM0 Keep retention on RAM block 0 when RAM block is switched off RW OFFRAM1 Keep retention on RAM block 1 when RAM block is switched off 18.9.10 RAMONB ( Deprecated ) Address offset: 0x554 RAM on/off register (this register is retained) Since this register is deprecated the following substitutions have been made: RAM block 2 is equivalent to a block comprising RAM2.S0 and RAM2.S1 and RAM block 3 is equivalent to a block comprising RAM3.S0 and RAM3.S1. For new designs it is recommended to use the POWER.RAM-0.POWER and its sibling registers instead. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x00000003 Id RW Field A RW ONRAM2 B C D 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 Value Id Value Description RAM2Off 0 Off RAM2On 1 On RAM3Off 0 Off RAM3On 1 On RAM2Off 0 Off RAM2On 1 On RAM3Off 0 Off RAM3On 1 On Keep RAM block 2 on or off in system ON Mode RW ONRAM3 Keep RAM block 3 on or off in system ON Mode RW OFFRAM2 Keep retention on RAM block 2 when RAM block is switched off RW OFFRAM3 Keep retention on RAM block 3 when RAM block is switched off 18.9.11 DCDCEN Address offset: 0x578 DC/DC enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW DCDCEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable DC/DC converter 18.9.12 RAM[0].POWER Address offset: 0x900 RAM0 power control register Page 88 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Keep RAM section S0 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF 18.9.13 RAM[0].POWERSET Address offset: 0x904 RAM0 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM0 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM0 on or off in System ON mode On S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On D W 1 On S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On 1 On 18.9.14 RAM[0].POWERCLR Address offset: 0x908 RAM0 power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Off 1 Description S0POWER Keep RAM section S0 of RAM0 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM0 on or off in System ON mode Page 89 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id C RW Field W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Description Off 1 Off S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off 1 Off 18.9.15 RAM[1].POWER Address offset: 0x910 RAM1 power control register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Keep RAM section S0 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF 18.9.16 RAM[1].POWERSET Address offset: 0x914 RAM1 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM1 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM1 on or off in System ON mode On S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 On Page 90 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field D W 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On 1 On 18.9.17 RAM[1].POWERCLR Address offset: 0x918 RAM1 power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Off 1 Off 1 Description S0POWER Keep RAM section S0 of RAM1 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM1 on or off in System ON mode Off S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off 1 Off 18.9.18 RAM[2].POWER Address offset: 0x920 RAM2 power control register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id Value Description Keep RAM section S0 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF Page 91 18 POWER — Power supply 18.9.19 RAM[2].POWERSET Address offset: 0x924 RAM2 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM2 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM2 on or off in System ON mode On S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On D W 1 On S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On 1 On 18.9.20 RAM[2].POWERCLR Address offset: 0x928 RAM2 power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Off 1 Off 1 Description S0POWER Keep RAM section S0 of RAM2 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM2 on or off in System ON mode Off S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off 1 Off 18.9.21 RAM[3].POWER Address offset: 0x930 RAM3 power control register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id Value Description Keep RAM section S0 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. Page 92 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF 18.9.22 RAM[3].POWERSET Address offset: 0x934 RAM3 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM3 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM3 on or off in System ON mode On S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On D W 1 On S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On 1 On 18.9.23 RAM[3].POWERCLR Address offset: 0x938 RAM3 power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 Value Id Value Off 1 Off 1 Description S0POWER Keep RAM section S0 of RAM3 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM3 on or off in System ON mode Off S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Off Page 93 18 POWER — Power supply 18.9.24 RAM[4].POWER Address offset: 0x940 RAM4 power control register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Keep RAM section S0 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF 18.9.25 RAM[4].POWERSET Address offset: 0x944 RAM4 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM4 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM4 on or off in System ON mode On S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On D W 1 On S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 On 18.9.26 RAM[4].POWERCLR Address offset: 0x948 RAM4 power control clear register When read, this register will return the value of the POWER register. Page 94 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Off 1 Off 1 Description S0POWER Keep RAM section S0 of RAM4 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM4 on or off in System ON mode Off S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off 1 Off 18.9.27 RAM[5].POWER Address offset: 0x950 RAM5 power control register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Keep RAM section S0 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF 18.9.28 RAM[5].POWERSET Address offset: 0x954 RAM5 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM5 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM5 on or off in System ON mode On Page 95 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field C W 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On D W 1 On S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On 1 On 18.9.29 RAM[5].POWERCLR Address offset: 0x958 RAM5 power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Off 1 Off 1 Description S0POWER Keep RAM section S0 of RAM5 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM5 on or off in System ON mode Off S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off 1 Off 18.9.30 RAM[6].POWER Address offset: 0x960 RAM6 power control register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id Value Description Keep RAM section S0 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Off 0 Off On 1 On Off 0 Off On 1 On Off 0 RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF Off Page 96 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Description On 1 On 18.9.31 RAM[6].POWERSET Address offset: 0x964 RAM6 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM6 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM6 on or off in System ON mode On S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On D W 1 On S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On 1 On 18.9.32 RAM[6].POWERCLR Address offset: 0x968 RAM6 power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Off 1 Off 1 Description S0POWER Keep RAM section S0 of RAM6 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM6 on or off in System ON mode Off S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off 1 Off 18.9.33 RAM[7].POWER Address offset: 0x970 RAM7 power control register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A RW S0POWER 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description Keep RAM section S0 ON or OFF in System ON mode. Page 97 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S0RETENTION. All RAM sections will be OFF in System OFF mode. B Off 0 Off On 1 On RW S1POWER Keep RAM section S1 ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in S1RETENTION. All RAM sections will be OFF in System OFF mode. C D Off 0 Off On 1 On Off 0 Off On 1 On Off 0 Off On 1 On RW S0RETENTION Keep retention on RAM section S0 when RAM section is in OFF RW S1RETENTION Keep retention on RAM section S1 when RAM section is in OFF 18.9.34 RAM[7].POWERSET Address offset: 0x974 RAM7 power control set register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B C W W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value On 1 On 1 Description S0POWER Keep RAM section S0 of RAM7 on or off in System ON mode On S1POWER Keep RAM section S1 of RAM7 on or off in System ON mode On S0RETENTION Keep retention on RAM section S0 when RAM section is switched off On D W 1 On S1RETENTION Keep retention on RAM section S1 when RAM section is switched off On 1 On 18.9.35 RAM[7].POWERCLR Address offset: 0x978 RAM7 power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field A W B W 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Id Value Off 1 Off 1 Description S0POWER Keep RAM section S0 of RAM7 on or off in System ON mode Off S1POWER Keep RAM section S1 of RAM7 on or off in System ON mode Off Page 98 18 POWER — Power supply Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x0000FFFF Id RW Field C W 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description S0RETENTION Keep retention on RAM section S0 when RAM section is switched off Off D W 1 Off S1RETENTION Keep retention on RAM section S1 when RAM section is switched off Off 1 Off 18.10 Electrical specification 18.10.1 Current consumption, sleep Symbol Description IOFF System OFF current, no RAM retention Min. Typ. 0.3 Max. Units µA ION System ON base current, no RAM retention 1.2 µA IRAM Additional RAM retention current per 4 KB RAM section 20 nA 18.10.2 Device startup times Symbol Description tPOR Time in Power on Reset after VDD reaches 1.7 V for all supply Min. Typ. Max. Units voltages and temperatures. Dependent on supply rise time. 10 tPOR,10us VDD rise time 10us 1 ms tPOR,10ms VDD rise time 10ms 9 ms tPOR,60ms VDD rise time 60ms 23 ms tPINR If a GPIO pin is configured as reset, the maximum time taken to pull up the pin and release reset after power on reset. Dependent on the pin capacitive load (C)11: t=5RC, R = 13kOhm tPINR,500nF C = 500nF 32.5 ms tPINR,10uF C = 10uF 650 ms tR2ON Time from reset to ON (CPU execute) tR2ON,NOTCONF If reset pin not configured tPOR ms tR2ON,CONF If reset pin configured tPOR + ms tPINR tOFF2ON Time from OFF to CPU execute 16.5 µs tIDLE2CPU Time from IDLE to CPU execute 3.0 µs tEVTSET,CL1 Time from HW event to PPI event in Constant Latency System 0.0625 µs 0.0625 µs ON mode tEVTSET,CL0 Time from HW event to PPI event in Low Power System ON mode 18.10.3 Power fail comparator Symbol Description IPOF Current consumption when enabled12 Min. VPOF Nominal power level warning thresholds (falling supply voltage). Typ. Max. =0] / PAYLOAD DISABLED / DISABLED RXDISABLE RXEN RXRU Packet received / END Ramp-up complete / READY Address received [Address match] / ADDRESS START RXIDLE RX STOP Payload received [payload length >=0] / PAYLOAD DISABLE Figure 34: Radio states 23.8 Transmit sequence Before the RADIO is able to transmit a packet, it must first ramp-up in TX mode. See TXRU in Figure 34: Radio states on page 209 and Figure 35: Transmit sequence on page 210. A TXRU ramp-up sequence is initiated when the TXEN task is triggered. After the radio has successfully ramped up it will generate the READY event indicating that a packet transmission can be initiate. A packet transmission is initiated by triggering the START task. As illustrated in Figure 34: Radio states on page 209 the START task can first be triggered after the RADIO has entered into the TXIDLE state. Figure 35: Transmit sequence on page 210 illustrates a single packet transmission where the CPU manually triggers the different tasks needed to control the flow of the RADIO, i.e. no shortcuts are used. If shortcuts are not used, a certain amount of delay caused by CPU execution is expected between READY and START, and between END and DISABLE. As illustrated in Figure 35: Transmit sequence on page 210 Page 209 23 RADIO — 2.4 GHz Radio TX PAYLOAD CRC ADDRESS S0 L S1 (carrier) 2 DISABLE 3 START 1 TXEN Lifeline READY A TXDISABLE END P (carrier) TXIDLE DISABLED TXIDLE Transmitter TXRU PAYLOAD State the RADIO will by default transmit '1's between READY and START, and between END and DISABLED. What is transmitted can be programmed through the DTX field in the MODECNF0 register. Figure 35: Transmit sequence TX S0 L S1 PAYLOAD PAYLOAD CRC (carrier) DISABLED A TXDISABLE 1 DISABLE 2 START TXEN Lifeline READY P ADDRESS Transmitter TXRU END State A slightly modified version of the transmit sequence from Figure 35: Transmit sequence on page 210 is illustrated in Figure 36: Transmit sequence using shortcuts to avoid delays on page 210 where the RADIO is configured to use shortcuts between READY and START, and between END and DISABLE, which means that no delay is introduced. Figure 36: Transmit sequence using shortcuts to avoid delays The RADIO is able to send multiple packets one after the other without having to disable and re-enable the RADIO between packets, this is illustrated in Figure 37: Transmission of multiple packets on page 211. Page 210 PAYLOAD CRC (carrier) P A S0 L S1 PAYLOAD (carrier) START TXEN 3 DISABLE 2 START 1 CRC DISABLED PAYLOAD PAYLOAD S0 L S1 TXDISABLE TX ADDRESS A ADDRESS Lifeline READY P TXIDLE END TX Transmitter TXRU END State 23 RADIO — 2.4 GHz Radio Figure 37: Transmission of multiple packets 23.9 Receive sequence Before the RADIO is able to receive a packet, it must first ramp up in RX mode See RXRU in Figure 34: Radio states on page 209 and Figure 38: Receive sequence on page 211. An RXRU ramp-up sequence is initiated when the RXEN task is triggered. After the radio has successfully ramped up it will generate the READY event indicating that a packet reception can be initiated. A packet reception is initiated by triggering the START task. As illustrated in Figure 34: Radio states on page 209 the START task can, first be triggered after the RADIO has entered into the RXIDLE state. RX S0 L S1 2 PAYLOAD RXDISABLE CRC DISABLED A ADDRESS P DISABLE 3 START 1 RXEN Lifeline READY ’X’ RXIDLE END RXIDLE Reception RXRU PAYLOAD State Figure 38: Receive sequence on page 211 illustrates a single packet reception where the CPU manually triggers the different tasks needed to control the flow of the RADIO, i.e. no shortcuts are used. If shortcuts are not used, a certain amount of delay, caused by CPU execution, is expected between READY and START, and between END and DISABLE. As illustrated Figure 38: Receive sequence on page 211 the RADIO will be listening and possibly receiving undefined data, illustrated with an 'X', from START and until a packet with valid preamble (P) is received. Figure 38: Receive sequence A slightly modified version of the receive sequence from Figure 38: Receive sequence on page 211 is illustrated in Figure 39: Receive sequence using shortcuts to avoid delays on page 212 where the the RADIO is configured to use shortcuts between READY and START, and between END and DISABLE, which means that no delay is introduced. Page 211 RX A PAYLOAD ADDRESS Lifeline S0 L S1 CRC DISABLED P READY ’X’ RXDISABLE PAYLOAD Reception RXRU END State 23 RADIO — 2.4 GHz Radio 1 DISABLE RXEN START 2 Figure 39: Receive sequence using shortcuts to avoid delays ’X’ P A S0 L S1 PAYLOAD CRC DISABLED CRC END PAYLOAD ADDRESS S0 L S1 RXDISABLE RX END A START 3 DISABLE 2 START 1 RXEN Lifeline READY ’X’ P RXIDLE PAYLOAD RX ADDRESS Receiver RXRU PAYLOAD State The RADIO is able to receive multiple packets one after the other without having to disable and re-enable the RADIO between packets, this is illustrated Figure 40: Reception of multiple packets on page 212. Figure 40: Reception of multiple packets 23.10 Received Signal Strength Indicator (RSSI) The radio implements a mechanism for measuring the power in the received radio signal. This feature is called Received Signal Strength Indicator (RSSI). Sampling of the received signal strength is started by using the RSSISTART task. The sample can be read from the RSSISAMPLE register. The sample period of the RSSI is defined by RSSIPERIOD, see the device product specification for details. The RSSI sample will hold the average received signal strength during this sample period. For the RSSI sample to be valid the radio has to be enabled in receive mode (RXEN task) and the reception has to be started (READY event followed by START task). 23.11 Interframe spacing Interframe spacing is the time interval between two consecutive packets. It is defined as the time, in micro seconds, from the end of the last bit of the previous packet received and to the start of the first bit of the subsequent packet that is transmitted. The RADIO is able to enforce this Page 212 23 RADIO — 2.4 GHz Radio interval as specified in the TIFS register as long as TIFS is not specified to be shorter than the RADIO’s turnaround time, i.e. the time needed to switch off the receiver, and switch back on the transmitter. TIFS is only enforced if END_DISABLE and DISABLED_TXEN or END_DISABLE and DISABLED_RXEN shortcuts are enabled. TIFS is only qualified for use in BLE_1MBIT mode, and default ramp-up mode. 23.12 Device address match The device address match feature is tailored for address white listing in a Bluetooth Smart and similar implementations. This feature enables on-the-fly device address matching while receiving a packet on air. This feature only works in receive mode and as long as RADIO is configured for little endian, see PCNF1.ENDIAN. The Device Address match unit assumes that the 48 first bits of the payload is the device address and that bit number 6 in S0 is the TxAdd bit. See the Bluetooth Core Specification for more information about device addresses, TxAdd and whitelisting. The RADIO is able to listen for eight different device addresses at the same time. These addresses are specified in a DAB/DAP register pair, one pair per address, in addition to a TxAdd bit configured in the DACNF register. The DAB register specifies the 32 least significant bits of the device address, while the DAP register specifies the 16 most significant bits of the device address. Each of the device addresses can be individually included or excluded from the matching mechanism. This is configured in the DACNF register. 23.13 Bit counter The RADIO implements a simple counter that can be configured to generate an event after a specific number of bits have been transmitted or received. By using shortcuts, this counter can be started from different events generated by the RADIO and hence count relative to these. The bit counter is started by triggering the BCSTART task, and stopped by triggering the BCSTOP task. A BCMATCH event will be generated when the bit counter has counted the number of bits specified in the BCC register. The bit counter will continue to count bits until the DISABLED event is generated or until the BCSTOP task is triggered. The CPU can therefore, after a BCMATCH event, reconfigure the BCC value for new BCMATCH events within the same packet. The bit counter can only be started after the RADIO has received the ADDRESS event. The bit counter will stop and reset on BCSTOP, STOP, END and DISABLE tasks. The figure below illustrates how the bit counter can be used to generate a BCMATCH event in the beginning of the packet payload, and again generate a second BCMATCH event after sending 2 bytes (16 bits) of the payload. Page 213 RX DISABLED CRC 3 DISABLE BCC = 12 + 16 BCSTART START BCMATCH BCMATCH READY 2 BCC = 12 2 PAYLOAD 1 RXEN 1 S0 L S1 PAYLOAD Lifeline This example assumes that the combined length of S0, Length (L) and S1 is 12 bits. A ADDRESS Reception 0 ’X’ P RXDISABLE END RXRU BCSTOP State 23 RADIO — 2.4 GHz Radio Figure 41: Bit counter example 23.14 Registers Table 41: Instances Base address Peripheral Instance Description 0x40001000 RADIO RADIO 2.4 GHz radio Configuration Table 42: Register Overview Register Offset Description TASKS_TXEN 0x000 Enable RADIO in TX mode TASKS_RXEN 0x004 Enable RADIO in RX mode TASKS_START 0x008 Start RADIO TASKS_STOP 0x00C Stop RADIO TASKS_DISABLE 0x010 Disable RADIO TASKS_RSSISTART 0x014 Start the RSSI and take one single sample of the receive signal strength. TASKS_RSSISTOP 0x018 Stop the RSSI measurement TASKS_BCSTART 0x01C Start the bit counter TASKS_BCSTOP 0x020 Stop the bit counter EVENTS_READY 0x100 RADIO has ramped up and is ready to be started EVENTS_ADDRESS 0x104 Address sent or received EVENTS_PAYLOAD 0x108 Packet payload sent or received EVENTS_END 0x10C Packet sent or received EVENTS_DISABLED 0x110 RADIO has been disabled EVENTS_DEVMATCH 0x114 A device address match occurred on the last received packet EVENTS_DEVMISS 0x118 No device address match occurred on the last received packet EVENTS_RSSIEND 0x11C Sampling of receive signal strength complete. EVENTS_BCMATCH 0x128 Bit counter reached bit count value. EVENTS_CRCOK 0x130 Packet received with CRC ok EVENTS_CRCERROR 0x134 Packet received with CRC error SHORTS 0x200 Shortcut register INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt CRCSTATUS 0x400 CRC status RXMATCH 0x408 Received address RXCRC 0x40C CRC field of previously received packet Page 214 23 RADIO — 2.4 GHz Radio Register Offset Description DAI 0x410 Device address match index PACKETPTR 0x504 Packet pointer FREQUENCY 0x508 Frequency TXPOWER 0x50C Output power MODE 0x510 Data rate and modulation PCNF0 0x514 Packet configuration register 0 PCNF1 0x518 Packet configuration register 1 BASE0 0x51C Base address 0 BASE1 0x520 Base address 1 PREFIX0 0x524 Prefixes bytes for logical addresses 0-3 PREFIX1 0x528 Prefixes bytes for logical addresses 4-7 TXADDRESS 0x52C Transmit address select RXADDRESSES 0x530 Receive address select CRCCNF 0x534 CRC configuration CRCPOLY 0x538 CRC polynomial CRCINIT 0x53C CRC initial value 0x540 Reserved TIFS 0x544 Inter Frame Spacing in us RSSISAMPLE 0x548 RSSI sample STATE 0x550 Current radio state DATAWHITEIV 0x554 Data whitening initial value BCC 0x560 Bit counter compare DAB[0] 0x600 Device address base segment 0 DAB[1] 0x604 Device address base segment 1 DAB[2] 0x608 Device address base segment 2 DAB[3] 0x60C Device address base segment 3 DAB[4] 0x610 Device address base segment 4 DAB[5] 0x614 Device address base segment 5 DAB[6] 0x618 Device address base segment 6 DAB[7] 0x61C Device address base segment 7 DAP[0] 0x620 Device address prefix 0 DAP[1] 0x624 Device address prefix 1 DAP[2] 0x628 Device address prefix 2 DAP[3] 0x62C Device address prefix 3 DAP[4] 0x630 Device address prefix 4 DAP[5] 0x634 Device address prefix 5 DAP[6] 0x638 Device address prefix 6 DAP[7] 0x63C Device address prefix 7 DACNF 0x640 Device address match configuration MODECNF0 0x650 Radio mode configuration register 0 POWER 0xFFC Peripheral power control 23.14.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H Reset 0x00000000 Id RW Field A RW READY_START 0 Value Id Value Description Shortcut between READY event and START task See EVENTS_READY and TASKS_START B G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW END_DISABLE Shortcut between END event and DISABLE task See EVENTS_END and TASKS_DISABLE Page 215 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H Reset 0x00000000 Id C RW Field 0 G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW DISABLED_TXEN Shortcut between DISABLED event and TXEN task See EVENTS_DISABLED and TASKS_TXEN D Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW DISABLED_RXEN Shortcut between DISABLED event and RXEN task See EVENTS_DISABLED and TASKS_RXEN E Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW ADDRESS_RSSISTART Shortcut between ADDRESS event and RSSISTART task See EVENTS_ADDRESS and TASKS_RSSISTART F Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW END_START Shortcut between END event and START task See EVENTS_END and TASKS_START G Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW ADDRESS_BCSTART Shortcut between ADDRESS event and BCSTART task See EVENTS_ADDRESS and TASKS_BCSTART H Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW DISABLED_RSSISTOP Shortcut between DISABLED event and RSSISTOP task See EVENTS_DISABLED and TASKS_RSSISTOP Disabled 0 Disable shortcut Enabled 1 Enable shortcut 23.14.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K Reset 0x00000000 Id RW Field A RW READY 0 Value Id I Value Description Write '1' to Enable interrupt for READY event See EVENTS_READY B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ADDRESS Write '1' to Enable interrupt for ADDRESS event See EVENTS_ADDRESS C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PAYLOAD Write '1' to Enable interrupt for PAYLOAD event See EVENTS_PAYLOAD D H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to Enable interrupt for END event Page 216 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K Reset 0x00000000 Id RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_END E RW DISABLED Write '1' to Enable interrupt for DISABLED event See EVENTS_DISABLED F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DEVMATCH Write '1' to Enable interrupt for DEVMATCH event See EVENTS_DEVMATCH G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DEVMISS Write '1' to Enable interrupt for DEVMISS event See EVENTS_DEVMISS H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RSSIEND Write '1' to Enable interrupt for RSSIEND event See EVENTS_RSSIEND I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW BCMATCH Write '1' to Enable interrupt for BCMATCH event See EVENTS_BCMATCH K Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CRCOK Write '1' to Enable interrupt for CRCOK event See EVENTS_CRCOK L Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CRCERROR Write '1' to Enable interrupt for CRCERROR event See EVENTS_CRCERROR Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 23.14.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K Reset 0x00000000 Id RW Field A RW READY 0 Value Id I Value Description Write '1' to Disable interrupt for READY event See EVENTS_READY Clear H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Disable Page 217 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K Reset 0x00000000 Id B RW Field 0 I Value Id Value Description Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ADDRESS Write '1' to Disable interrupt for ADDRESS event See EVENTS_ADDRESS C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PAYLOAD Write '1' to Disable interrupt for PAYLOAD event See EVENTS_PAYLOAD D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to Disable interrupt for END event See EVENTS_END E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DISABLED Write '1' to Disable interrupt for DISABLED event See EVENTS_DISABLED F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DEVMATCH Write '1' to Disable interrupt for DEVMATCH event See EVENTS_DEVMATCH G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DEVMISS Write '1' to Disable interrupt for DEVMISS event See EVENTS_DEVMISS H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RSSIEND Write '1' to Disable interrupt for RSSIEND event See EVENTS_RSSIEND I Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW BCMATCH Write '1' to Disable interrupt for BCMATCH event See EVENTS_BCMATCH K Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CRCOK Write '1' to Disable interrupt for CRCOK event See EVENTS_CRCOK L H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CRCERROR Write '1' to Disable interrupt for CRCERROR event See EVENTS_CRCERROR Clear 1 Disable Disabled 0 Read: Disabled Page 218 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K Reset 0x00000000 Id RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Read: Enabled 23.14.4 CRCSTATUS Address offset: 0x400 CRC status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description CRCError 0 Packet received with CRC error CRCOk 1 Packet received with CRC ok CRCSTATUS CRC status of packet received 23.14.5 RXMATCH Address offset: 0x408 Received address Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RXMATCH Received address Logical address of which previous packet was received 23.14.6 RXCRC Address offset: 0x40C CRC field of previously received packet Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RXCRC CRC field of previously received packet CRC field of previously received packet 23.14.7 DAI Address offset: 0x410 Device address match index Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description DAI Device address match index Index (n) of device address, see DAB[n] and DAP[n], that got an address match. 23.14.8 PACKETPTR Address offset: 0x504 Page 219 23 RADIO — 2.4 GHz Radio Packet pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PACKETPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Packet pointer Packet address to be used for the next transmission or reception. When transmitting, the packet pointed to by this address will be transmitted and when receiving, the received packet will be written to this address. This address is a byte aligned ram address. 23.14.9 FREQUENCY Address offset: 0x508 Frequency Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B Reset 0x00000002 Id RW Field A RW FREQUENCY B RW MAP 0 Value Id A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 Value Description [0..100] Radio channel frequency Frequency = 2400 + FREQUENCY (MHz). Channel map selection. Default 0 Low 1 Channel map between 2400 MHZ .. 2500 MHz Frequency = 2400 + FREQUENCY (MHz) Channel map between 2360 MHZ .. 2460 MHz Frequency = 2360 + FREQUENCY (MHz) 23.14.10 TXPOWER Address offset: 0x50C Output power Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW TXPOWER 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RADIO output power. Output power in number of dBm, i.e. if the value -20 is specified the output power will be set to -20dBm. Pos4dBm 0x04 +4 dBm Pos3dBm 0x03 +3 dBm 0dBm 0x00 0 dBm Neg4dBm 0xFC -4 dBm Neg8dBm 0xF8 -8 dBm Neg12dBm 0xF4 -12 dBm Neg16dBm 0xF0 -16 dBm Neg20dBm 0xEC -20 dBm Neg30dBm 0xD8 -40 dBm Neg40dBm 0xD8 -40 dBm 23.14.11 MODE Address offset: 0x510 Data rate and modulation Page 220 Deprecated 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW MODE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Radio data rate and modulation setting. The radio supports Frequency-shift Keying (FSK) modulation. Nrf_1Mbit 0 1 Mbit/s Nordic proprietary radio mode Nrf_2Mbit 1 2 Mbit/s Nordic proprietary radio mode Nrf_250Kbit 2 250 kbit/s Nordic proprietary radio mode Ble_1Mbit 3 1 Mbit/s Bluetooth Low Energy Ble_2Mbit 4 2 Mbit/s Bluetooth Low Energy Deprecated 23.14.12 PCNF0 Address offset: 0x514 Packet configuration register 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00000000 0 Id RW Field A RW LFLEN Length on air of LENGTH field in number of bits. C RW S0LEN Length on air of S0 field in number of bytes. E RW S1LEN Length on air of S1 field in number of bits. F RW S1INCL G Value Id F E E E E C A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Include or exclude S1 field in RAM Automatic 0 Include S1 field in RAM only if S1LEN > 0 Include 1 Always include S1 field in RAM independent of S1LEN 8bit 0 8-bit preamble 16bit 1 16-bit preamble RW PLEN Length of preamble on air. Decision point: TASKS_START task 23.14.13 PCNF1 Address offset: 0x518 Packet configuration register 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E D Reset 0x00000000 Id RW Field A RW MAXLEN 0 Value Id C C C B B B B B B B B A A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..255] Maximum length of packet payload. If the packet payload is larger than MAXLEN, the radio will truncate the payload to MAXLEN. B RW STATLEN [0..255] Static length in number of bytes The static length parameter is added to the total length of the payload when sending and receiving packets, e.g. if the static length is set to N the radio will receive or send N bytes more than what is defined in the LENGTH field of the packet. C RW BALEN [2..4] Base address length in number of bytes The address field is composed of the base address and the one byte long address prefix, e.g. set BALEN=2 to get a total address of 3 bytes. D RW ENDIAN On air endianness of packet, this applies to the S0, LENGTH, S1 and the PAYLOAD fields. E Little 0 Least Significant bit on air first Big 1 Most significant bit on air first Disabled 0 RW WHITEEN Enable or disable packet whitening Disable Page 221 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E D Reset 0x00000000 Id RW Field 0 C C C B B B B B B B B A A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Enable 23.14.14 BASE0 Address offset: 0x51C Base address 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW BASE0 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Base address 0 Radio base address 0. 23.14.15 BASE1 Address offset: 0x520 Base address 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW BASE1 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Base address 1 Radio base address 1. 23.14.16 PREFIX0 Address offset: 0x524 Prefixes bytes for logical addresses 0-3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field Value A RW AP0 Description Address prefix 0. B RW AP1 Address prefix 1. C RW AP2 Address prefix 2. D RW AP3 Address prefix 3. 23.14.17 PREFIX1 Address offset: 0x528 Prefixes bytes for logical addresses 4-7 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field Value A RW AP4 Description Address prefix 4. B RW AP5 Address prefix 5. C RW AP6 Address prefix 6. D RW AP7 Address prefix 7. Page 222 23 RADIO — 2.4 GHz Radio 23.14.18 TXADDRESS Address offset: 0x52C Transmit address select Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A RW TXADDRESS 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Transmit address select Logical address to be used when transmitting a packet. 23.14.19 RXADDRESSES Address offset: 0x530 Receive address select Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E D C B A Reset 0x00000000 Id RW Field A RW ADDR0 B C D E F G H 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Enable or disable reception on logical address 0. RW ADDR1 Enable or disable reception on logical address 1. RW ADDR2 Enable or disable reception on logical address 2. RW ADDR3 Enable or disable reception on logical address 3. RW ADDR4 Enable or disable reception on logical address 4. RW ADDR5 Enable or disable reception on logical address 5. RW ADDR6 Enable or disable reception on logical address 6. RW ADDR7 Enable or disable reception on logical address 7. 23.14.20 CRCCNF Address offset: 0x534 CRC configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B Reset 0x00000000 Id RW Field A RW LEN 0 Value Id A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [1..3] CRC length in number of bytes. Disabled 0 CRC length is zero and CRC calculation is disabled One 1 CRC length is one byte and CRC calculation is enabled Two 2 CRC length is two bytes and CRC calculation is enabled Page 223 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B Reset 0x00000000 Id B RW Field 0 A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Three 3 CRC length is three bytes and CRC calculation is enabled Include 0 CRC calculation includes address field Skip 1 CRC calculation does not include address field. The CRC RW SKIPADDR Include or exclude packet address field out of CRC calculation. calculation will start at the first byte after the address. 23.14.21 CRCPOLY Address offset: 0x538 CRC polynomial Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CRCPOLY 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description CRC polynomial Each term in the CRC polynomial is mapped to a bit in this register which index corresponds to the term's exponent. The least significant term/bit is hard-wired internally to 1, and bit number 0 of the register content is ignored by the hardware. The following example is for an 8 bit CRC polynomial: x8 + x7 + x3 + x2 + 1 = 1 1000 1101 . 23.14.22 CRCINIT Address offset: 0x53C CRC initial value Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CRCINIT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description CRC initial value Initial value for CRC calculation. 23.14.23 TIFS Address offset: 0x544 Inter Frame Spacing in us Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW TIFS 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Inter Frame Spacing in us Inter frame space is the time interval between two consecutive packets. It is defined as the time, in micro seconds, from the end of the last bit of the previous packet to the start of the first bit of the subsequent packet. 23.14.24 RSSISAMPLE Address offset: 0x548 RSSI sample Page 224 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id RSSISAMPLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..127] RSSI sample RSSI sample result. The value of this register is read as a positive value while the actual received signal strength is a negative value. Actual received signal strength is therefore as follows: received signal strength = -A dBm 23.14.25 STATE Address offset: 0x550 Current radio state Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 RADIO is in the Disabled state RxRu 1 RADIO is in the RXRU state RxIdle 2 RADIO is in the RXIDLE state Rx 3 RADIO is in the RX state RxDisable 4 RADIO is in the RXDISABLED state TxRu 9 RADIO is in the TXRU state TxIdle 10 RADIO is in the TXIDLE state Tx 11 RADIO is in the TX state TxDisable 12 RADIO is in the TXDISABLED state STATE Current radio state 23.14.26 DATAWHITEIV Address offset: 0x554 Data whitening initial value Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A Reset 0x00000040 Id RW Field A RW DATAWHITEIV 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 Value Description Data whitening initial value. Bit 6 is hard-wired to '1', writing '0' to it has no effect, and it will always be read back and used by the device as '1'. Bit 0 corresponds to Position 6 of the LSFR, Bit 1 to Position 5, etc. 23.14.27 BCC Address offset: 0x560 Bit counter compare Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW BCC 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Bit counter compare Bit counter compare register Page 225 23 RADIO — 2.4 GHz Radio 23.14.28 DAB[0] Address offset: 0x600 Device address base segment 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 0 23.14.29 DAB[1] Address offset: 0x604 Device address base segment 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 1 23.14.30 DAB[2] Address offset: 0x608 Device address base segment 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 2 23.14.31 DAB[3] Address offset: 0x60C Device address base segment 3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 3 23.14.32 DAB[4] Address offset: 0x610 Device address base segment 4 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 4 23.14.33 DAB[5] Address offset: 0x614 Device address base segment 5 Page 226 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 5 23.14.34 DAB[6] Address offset: 0x618 Device address base segment 6 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 6 23.14.35 DAB[7] Address offset: 0x61C Device address base segment 7 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAB 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address base segment 7 23.14.36 DAP[0] Address offset: 0x620 Device address prefix 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 0 23.14.37 DAP[1] Address offset: 0x624 Device address prefix 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 1 23.14.38 DAP[2] Address offset: 0x628 Device address prefix 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 2 Page 227 23 RADIO — 2.4 GHz Radio 23.14.39 DAP[3] Address offset: 0x62C Device address prefix 3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 3 23.14.40 DAP[4] Address offset: 0x630 Device address prefix 4 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 4 23.14.41 DAP[5] Address offset: 0x634 Device address prefix 5 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 5 23.14.42 DAP[6] Address offset: 0x638 Device address prefix 6 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 6 23.14.43 DAP[7] Address offset: 0x63C Device address prefix 7 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW DAP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Device address prefix 7 23.14.44 DACNF Address offset: 0x640 Device address match configuration Page 228 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id RW Field A RW ENA0 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable device address matching using device address 0 B Disabled 0 Disabled Enabled 1 Enabled RW ENA1 Enable or disable device address matching using device address 1 C Disabled 0 Disabled Enabled 1 Enabled RW ENA2 Enable or disable device address matching using device address 2 D Disabled 0 Disabled Enabled 1 Enabled RW ENA3 Enable or disable device address matching using device address 3 E Disabled 0 Disabled Enabled 1 Enabled RW ENA4 Enable or disable device address matching using device address 4 F Disabled 0 Disabled Enabled 1 Enabled RW ENA5 Enable or disable device address matching using device address 5 G Disabled 0 Disabled Enabled 1 Enabled RW ENA6 Enable or disable device address matching using device address 6 H Disabled 0 Disabled Enabled 1 Enabled RW ENA7 Enable or disable device address matching using device address 7 Disabled 0 Disabled Enabled 1 Enabled I RW TXADD0 TxAdd for device address 0 J RW TXADD1 TxAdd for device address 1 K RW TXADD2 TxAdd for device address 2 L RW TXADD3 TxAdd for device address 3 M RW TXADD4 TxAdd for device address 4 N RW TXADD5 TxAdd for device address 5 O RW TXADD6 TxAdd for device address 6 P RW TXADD7 TxAdd for device address 7 23.14.45 MODECNF0 Address offset: 0x650 Radio mode configuration register 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C C Reset 0x00000200 Id RW Field A RW RU 0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 Value Id Value Default 0 Fast 1 Description Radio ramp-up time Default ramp-up time (tRXEN), compatible with firmware written for nRF51 Fast ramp-up (tRXEN,FAST), see electrical specification for more information Page 229 23 RADIO — 2.4 GHz Radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C C Reset 0x00000200 Id RW Field C RW DTX 0 Value Id A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 Value Description Default TX value Specifies what the RADIO will transmit when it is not started, i.e. between: RADIO.EVENTS_READY and RADIO.TASKS_START RADIO.EVENTS_END and RADIO.TASKS_START RADIO.EVENTS_END and RADIO.EVENTS_DISABLED B1 0 Transmit '1' B0 1 Transmit '0' Center 2 Transmit center frequency When tuning the crystal for centre frequency, the RADIO must be set in DTX = Center mode to be able to achieve the expected accuracy. 23.14.46 POWER Address offset: 0xFFC Peripheral power control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000001 Id RW Field A RW POWER 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Description Peripheral power control. The peripheral and its registers will be reset to its initial state by switching the peripheral off and then back on again. Disabled 0 Peripheral is powered off Enabled 1 Peripheral is powered on 23.15 Electrical specification 23.15.1 General Radio Characteristics Symbol Description Min. fOP Operating frequencies 2360 Typ. fPLL,PROG,RES PLL programming resolution 2 kHz fPLL,CH,SP PLL channel spacing 1 MHz fDELTA,1M Frequency deviation @ 1 Msps ±170 kHz fDELTA,BLE,1M Frequency deviation @ BLE 1Msps ±250 kHz fDELTA,2M Frequency deviation @ 2 Msps ±320 kHz fDELTA,BLE,2M Frequency deviation @ BLE 2 Msps ±500 fskSPS On-the-air data rate 1 Max. Units 2500 MHz kHz 2 Msps Max. Units 23.15.2 Radio current consumption (Transmitter) Symbol Description ITX,PLUS4dBM,DCDC TX only run current (DCDC, 3V) PRF =+4 dBm Min. 7.5 mA ITX,PLUS4dBM TX only run current PRF = +4 dBm 16.6 mA ITX,0dBM,DCDC TX only run current (DCDC, 3V)PRF = 0dBm 5.3 mA ITX,0dBM TX only run current PRF = 0dBm 11.6 mA ITX,MINUS4dBM,DCDC TX only run current DCDC, 3V PRF = -4dBm 4.2 mA ITX,MINUS4dBM TX only run current PRF = -4 dBm 9.3 mA ITX,MINUS8dBM,DCDC TX only run current DCDC, 3V PRF = -8 dBm 3.8 mA Page 230 Typ. 23 RADIO — 2.4 GHz Radio Symbol Description ITX,MINUS8dBM TX only run current PRF = -8 dBm Min. Typ. 8.4 Max. Units mA ITX,MINUS12dBM,DCDC TX only run current DCDC, 3V PRF = -12 dBm 3.5 mA ITX,MINUS12dBM TX only run current PRF = -12 dBm 7.7 mA ITX,MINUS16dBM,DCDC TX only run current DCDC, 3V PRF = -16 dBm 3.3 mA ITX,MINUS16dBM TX only run current PRF = -16 dBm 7.3 mA ITX,MINUS20dBM,DCDC TX only run current DCDC, 3V PRF = -20 dBm 3.2 mA ITX,MINUS20dBM TX only run current PRF = -20 dBm 7.0 mA ITX,MINUS40dBM,DCDC TX only run current DCDC, 3V PRF = -40 dBm 2.7 mA ITX,MINUS40dBM TX only run current PRF = -40 dBm 5.9 mA ISTART,TX,DCDC TX start-up current DCDC, 3V, PRF = 4 dBm 4.0 mA ISTART,TX TX start-up current, PRF = 4 dBm 8.8 mA 23.15.3 Radio current consumption (Receiver) Symbol Description IRX,1M,DCDC RX only run current (DCDC, 3V) 1Msps / 1Msps BLE Min. Typ. 5.4 Max. Units mA IRX,1M RX only run current 1Msps / 1Msps BLE 11.7 mA IRX,2M,DCDC RX only run current (DCDC, 3V) 2Msps / 2Msps BLE 5.8 mA IRX,2M RX only run current 2Msps / 2Msps BLE 12.9 mA ISTART,RX,DCDC RX start-up current (DCDC 3V) 3.5 mA ISTART,RX,LDO RX start-up current (LDO 3V) 7.5 mA 23.15.4 Transmitter specification Symbol Description Typ. Max. Units PRF Maximum output power Min. 4 6 dBm PRFC RF power control range 24 PRFCR RF power accuracy PRF1,1 1st Adjacent Channel Transmit Power 1 MHz (1 Msps Nordic dB ±4 dB -25 dBc -50 dBc -25 dBc -50 dBc proprietary mode) PRF2,1 2nd Adjacent Channel Transmit Power 2 MHz (1 Msps Nordic proprietary mode) PRF1,2 1st Adjacent Channel Transmit Power 2 MHz (2 Msps Nordic proprietary mode) PRF2,2 2nd Adjacent Channel Transmit Power 4 MHz (2 Msps Nordic proprietary mode) PRF1,2,BLE 1st Adjacent Channel Transmit Power 2 MHz (2 Msps BLE mode) -20 dBc PRF2,2,BLE 2nd Adjacent Channel Transmit Power 4 MHz (2 Msps BLE -50 dBc mode) 23.15.5 Receiver operation Symbol Description PRX,MAX Maximum received signal strength at < 0.1% BER Min. Typ. 0 Max. Units dBm PSENS,IT,1M Sensitivity, 1Msps nRF mode16 -93 dBm PSENS,IT,SP,1M,BLE Sensitivity, 1Msps BLE ideal transmitter, =128 bytes BER=1E-4 -95 dBm -89 dBm 18 PSENS,IT,2M 16 17 18 19 Sensitivity, 2Msps nRF mode19 Typical sensitivity applies when ADDR0 is used for receiver address correlation. When ADDR[1...7] are used for receiver address correlation, the typical sensitivity for this mode is degraded by 3dB. As defined in the Bluetooth Core Specification v4.0 Volume 6: Core System Package (Low Energy Controller Volume) Equivalent BER limit < 10E-04 Typical sensitivity applies when ADDR0 is used for receiver address correlation. When ADDR[1...7] are used for receiver address correlation, the typical sensitivity for this mode is degraded by 3dB. Page 231 23 RADIO — 2.4 GHz Radio Symbol Description PSENS,IT,SP,2M,BLE Sensitivity, 2Msps BLE ideal transmitter, Packet length Min. Typ. Max. Units -93 dBm -93 dBm = -92 dBm 128bytes 23.15.6 RX selectivity 20 RX selectivity with equal modulation on interfering signal Symbol Description C/I1M,co-channel 1Msps mode, Co-Channel interference Min. Typ. 9 Max. Units dB C/I1M,-1MHz 1 Msps mode, Adjacent (-1 MHz) interference -2 dB C/I1M,+1MHz 1 Msps mode, Adjacent (+1 MHz) interference -10 dB C/I1M,-2MHz 1 Msps mode, Adjacent (-2 MHz) interference -19 dB C/I1M,+2MHz 1 Msps mode, Adjacent (+2 MHz) interference -42 dB C/I1M,-3MHz 1 Msps mode, Adjacent (-3 MHz) interference -38 dB C/I1M,+3MHz 1 Msps mode, Adjacent (+3 MHz) interference -48 dB C/I1M,±6MHz 1 Msps mode, Adjacent (≥6 MHz) interference -50 dB C/I1MBLE,co-channel 1 Msps BLE mode, Co-Channel interference 6 dB C/I1MBLE,-1MHz 1 Msps BLE mode, Adjacent (-1 MHz) interference -2 dB C/I1MBLE,+1MHz 1 Msps BLE mode, Adjacent (+1 MHz) interference -9 dB C/I1MBLE,-2MHz 1 Msps BLE mode, Adjacent (-2 MHz) interference -22 dB C/I1MBLE,+2MHz 1 Msps BLE mode, Adjacent (+2 MHz) interference -46 dB C/I1MBLE,>3MHz 1 Msps BLE mode, Adjacent (≥3 MHz) interference -50 dB C/I1MBLE,image Image frequency Interference -22 dB C/I1MBLE,image,1MHz Adjacent (1 MHz) interference to in-band image frequency -35 dB C/I2M,co-channel 2Msps mode, Co-Channel interference 10 dB C/I2M,-2MHz 2 Msps mode, Adjacent (-2 MHz) interference 6 dB C/I2M,+2MHz 2 Msps mode, Adjacent (+2 MHz) interference -14 dB C/I2M,-4MHz 2 Msps mode, Adjacent (-4 MHz) interference -20 dB C/I2M,+4MHz 2 Msps mode, Adjacent (+4 MHz) interference -44 dB C/I2M,-6MHz 2 Msps mode, Adjacent (-6 MHz) interference -42 dB C/I2M,+6MHz 2 Msps mode, Adjacent (+6 MHz) interference -47 dB C/I2M,≥12MHz 2 Msps mode, Adjacent (≥12 MHz) interference -52 dB C/I2MBLE,co-channel 2 Msps BLE mode, Co-Channel interference 7 dB C/I2MBLE,±2MHz 2 Msps BLE mode, Adjacent (±2 MHz) interference 0 dB C/I2MBLE,±4MHz 2 Msps BLE mode, Adjacent (±4 MHz) interference -47 dB C/I2MBLE,≥6MHz 2 Msps BLE mode, Adjacent (≥6 MHz) interference -49 dB C/I2MBLE,image Image frequency Interference -21 dB C/I2MBLE,image, 2MHz Adjacent (2 MHz) interference to in-band image frequency -36 dB 23.15.7 RX intermodulation 21 RX intermodulation Symbol Description PIMD,1M IMD performance, 1 Msps (3 MHz, 4 MHz, and 5 MHz offset) Min. Typ. -33 Max. Units dBm PIMD,1M,BLE IMD performance, BLE 1 Msps (3 MHz, 4 MHz, and 5 MHz -30 dBm -33 dBm offset) PIMD,2M 20 21 IMD performance, 2 Msps (6 MHz, 8 MHz, and 10 MHz offset) Wanted signal level at PIN = -67 dBm. One interferer is used, having equal modulation as the wanted signal. The input power of the interferer where the sensitivity equals BER = 0.1% is presented Wanted signal level at PIN = -64 dBm. Two interferers with equal input power are used. The interferer closest in frequency is not modulated, the other interferer is modulated equal with the wanted signal. The input power of the interferers where the sensitivity equals BER = 0.1% is presented. Page 232 23 RADIO — 2.4 GHz Radio Symbol Description PIMD,2M,BLE IMD performance, BLE 2 Msps (6 MHz, 8 MHz, and 10 MHz Min. Typ. Max. -32 Units dBm offset) 23.15.8 Radio timing Symbol Description tTXEN Time between TXEN task and READY event after channel Min. Typ. Max. Units 140 us 40 us 6 us 4 us 140 us 40 us 20 us 0 us FREQUENCY configured tTXEN,FAST Time between TXEN task and READY event after channel FREQUENCY configured (Fast Mode) tTXDISABLE Time between DISABLE task and DISABLED event when the radio was in TX and mode is set to 1Msps tTXDISABLE,2M Time between DISABLE task and DISABLED event when the radio was in TX and mode is set to 2Msps tRXEN Time between the RXEN task and READY event after channel FREQUENCY configured in default mode tRXEN,FAST Time between the RXEN task and READY event after channel FREQUENCY configured in fast mode tSWITCH The minimum time taken to switch from RX to TX or TX to RX (channel FREQUENCY unchanged) tRXDISABLE Time between DISABLE task and DISABLED event when the radio was in RX tTXCHAIN TX chain delay 0.6 us tRXCHAIN RX chain delay 9.4 us tRXCHAIN,2M RX chain delay in 2Msps mode 5 us 23.15.9 Received Signal Strength Indicator (RSSI) specifications Symbol Description RSSIACC RSSI Accuracy Valid range -90 to -20 dBm Min. Typ. ±2 Max. Units dB RSSIRESOLUTION RSSI resolution 1 dB RSSIPERIOD Sample period 0.25 us 23.15.10 Jitter Symbol Description tDISABLEDJITTER Jitter on DISABLED event relative to END event when shortcut Min. Typ. Max. Units 0.25 us 0.25 us between END and DISABLE is enabled. tREADYJITTER Jitter on READY event relative to TXEN and RXEN task. 23.15.11 Delay when disabling the RADIO Symbol Description tTXDISABLE,1M Disable delay from TX. Min. Typ. Max. Units 6 us 0 us Delay between DISABLE and DISABLED for MODE = Nrf_1Mbit and MODE = Ble_1Mbit tRXDISABLE,1M Disable delay from RX. Delay between DISABLE and DISABLED for MODE = Nrf_1Mbit and MODE = Ble_1Mbit Page 233 24 TIMER — Timer/counter 24 TIMER — Timer/counter The TIMER can operate in two modes: timer and counter. CLEAR CAPTURE[0..n] STOP START COUNT TIMER TIMER Core Increment BITMODE Counter PCLK1M Prescaler PCLK16M fTIMER PRESCALER CC[0..n] MODE COMPARE[0..n] Figure 42: Block schematic for timer/counter The timer/counter runs on the high-frequency clock source (HFCLK) and includes a four-bit (1/2X) prescaler that can divide the timer input clock from the HFCLK controller. Clock source selection between PCLK16M and PCLK1M is automatic according to TIMER base frequency set by the prescaler. The TIMER base frequency is always given as 16 MHz divided by the prescaler value. The PPI system allows a TIMER event to trigger a task of any other system peripheral of the device. The PPI system also enables the TIMER task/event features to generate periodic output and PWM signals to any GPIO. The number of input/outputs used at the same time is limited by the number of GPIOTE channels. The TIMER can operate in two modes, Timer mode and Counter mode. In both modes, the TIMER is started by triggering the START task, and stopped by triggering the STOP task. After the timer is stopped the timer can resume timing/counting by triggering the START task again. When timing/counting is resumed, the timer will continue from the value it had prior to being stopped. In Timer mode, the TIMER's internal Counter register is incremented by one for every tick of the timer frequency fTIMER as illustrated in Figure 42: Block schematic for timer/counter on page 234. The timer frequency is derived from PCLK16M as shown below, using the values specified in the PRESCALER register: fTIMER = 16 MHz / (2PRESCALER) When fTIMER 62.5 ns CC[0] X N+2 COMPARE[0] • 0 1 Figure 50: Timing diagram - COMPARE_N+2 If the COUNTER is N, writing N or N+1 to a CC register may not trigger a COMPARE event. SysClk LFClk PRESC COUNTER 0x000 N-2 N-1 N+1 >= 0 CC[0] X N+1 COMPARE[0] • N 0 Figure 51: Timing diagram - COMPARE_N+1 If the COUNTER is N and the current CC register value is N+1 or N+2 when a new CC value is written, a match may trigger on the previous CC value before the new value takes effect. If the current CC value greater than N+2 when the new value is written, there will be no event due to the old value. SysClk LFClk PRESC COUNTER CC[0] 0x000 N-2 N-1 N N+1 >= 0 N COMPARE[0] X 0 1 Figure 52: Timing diagram - COMPARE_N-1 25.8 TASK and EVENT jitter/delay Jitter or delay in the RTC is due to the peripheral clock being a low frequency clock (LFCLK) which is not synchronous to the faster PCLK16M. Registers in the peripheral interface, part of the PCLK16M domain, have a set of mirrored registers in the LFCLK domain. For example, the COUNTER value accessible from the CPU is in the PCLK16M domain and is latched on read from an internal register called COUNTER in the LFCLK domain. COUNTER is the register which is actually modified each time the RTC ticks. These registers must be synchronised between clock domains (PCLK16M and LFCLK). The following is a summary of the jitter introduced on tasks and events. Figures illustrating jitter follow. Page 246 25 RTC — Real-time counter Table 46: RTC jitter magnitudes on tasks Task CLEAR, STOP, START, TRIGOVRFLOW Delay +15 to 46 μs Table 47: RTC jitter magnitudes on events Operation/Function START to COUNTER increment COMPARE to COMPARE 22 Jitter +/- 15 μs +/- 62.5 ns 1. CLEAR and STOP (and TRIGOVRFLW; not shown) will be delayed as long as it takes for the peripheral to clock a falling edge and rising of the LFCLK. This is between 15.2585 µs and 45.7755 µs – rounded to 15 µs and 46 µs for the remainder of the section. SysClk CLEAR LFClk PRESC COUNTER CLEARa 0x000 X X+1 0x000000 0x000001 0 or more SysClk after = ~15 us 1 or more SysClk before CLEARb Figure 53: Timing diagram - DELAY_CLEAR SysClk STOP LFClk PRESC COUNTER STOPa STOPb 0x000 X X+1 0 or more SysClk after = ~15 us 1 or more SysClk before Figure 54: Timing diagram - DELAY_STOP 2. The START task will start the RTC. Assuming that the LFCLK was previously running and stable, the first increment of COUNTER (and instance of TICK event) will be typically after 30.5 µs +/-15 µs. In some cases, in particular if the RTC is STARTed before the LFCLK is running, that timing can be up to ~250 µs. The software should therefore wait for the first TICK if it has to make sure the RTC is running. Sending a TRIGOVRFLW task sets the COUNTER to a value close to overflow. However, since the update of COUNTER relies on a stable LFCLK, sending this task while LFCLK is not running will start LFCLK, but the update will then be delayed by the same amount of time of up to ~250 us. The figures show the smallest and largest delays to on the START task which appears as a +/-15 µs jitter on the first COUNTER increment. 22 Assumes RTC runs continuously between these events. Note: 32.768 kHz clock jitter is additional to the numbers provided above. Page 247 25 RTC — Real-time counter SysClk First tick LFClk PRESC COUNTER START 0x000 X X+1 X+2 X+3 >= ~15 us 0 or more SysClk before Figure 55: Timing diagram - JITTER_STARTSysClk First tick LFClk PRESC COUNTER 0x000 X X+1 X+2 MODE.DATARATE Length of address (32 bit) Length of CRC (24 bit) 29.5 Encrypting packets on-the-fly in radio transmit mode When the AES CCM is encrypting a packet on-the-fly at the same time as the RADIO is transmitting it, the RADIO must read the encrypted packet from the same memory location as the AES CCM is writing to. The OUTPTR pointer in the AES CCM must therefore point to the same memory location as the PACKETPTR pointer in the RADIO, see Figure 62: Configuration of on-the-fly encryption on page 269. SCRATCHPTR INPTR Unencrypted packet OUTPTR & PACKETPTR H L RFU MODE = ENCRYPTION Encrypted packet H L+4 RFU Scratch area PL EPL AES CCM H: Header (S0) L: Length RFU: reserved for future use (S1) PL: unencrypted payload EPL: encrypted payload CCM data structure MIC CNFPTR To remote receiver RADIO TXEN Figure 62: Configuration of on-the-fly encryption In order to match the RADIO’s timing, the KSGEN task must be triggered no later than when the START task in the RADIO is triggered, in addition the shortcut between the ENDKSGEN event and the CRYPT task must be enabled. This use-case is illustrated in Figure 63: On-the-fly encryption using a PPI connection on page 270 using a PPI connection between the READY event in the RADIO and the KSGEN task in the AES CCM. Page 269 29 CCM — AES CCM mode encryption SHORTCUT ENDKSGEN CRYPT key-stream generation AES CCM encryption KSGEN ENDCRYPT PPI READY RADIO RU P A H L RFU EPL MIC CRC TXEN END READY RU: Ramp-up of RADIO P: Preamble A: Address START SHORTCUT H: Header (S0) L: Length RFU: reserved for future use (S1) EPL: encrypted payload Figure 63: On-the-fly encryption using a PPI connection 29.6 Decrypting packets on-the-fly in radio receive mode When the AES CCM is decrypting a packet on-the-fly at the same time as the RADIO is receiving it, the AES CCM must read the encrypted packet from the same memory location as the RADIO is writing to. The INPTR pointer in the AES CCM must therefore point to the same memory location as the PACKETPTR pointer in the RADIO, see Figure 64: Configuration of on-the-fly decryption on page 270. SCRATCHPTR OUTPTR Unencrypted packet INPTR & PACKETPTR H L H L+4 RFU AES CCM MODE = DECRYPTION Encrypted packet RFU Scratch area PL EPL H: Header (S0) L: Length RFU: reserved for future use (S1) PL: unencrypted payload EPL: encrypted payload CCM data structure MIC CNFPTR From remote transmitter RADIO RXEN Figure 64: Configuration of on-the-fly decryption In order to match the RADIO’s timing, the KSGEN task must be triggered no later than when the START task in the RADIO is triggered. In addition, the CRYPT task must be triggered no earlier than when the ADDRESS event is generated by the RADIO. If the CRYPT task is triggered exactly at the same time as the ADDRESS event is generated by the RADIO, the AES CCM will guarantee that the decryption is completed no later than when the END event in the RADIO is generated. This use-case is illustrated in Figure 65: On-the-fly decryption using a PPI connection between the READY event in the RADIO and the KSGEN task in the AES CCM on page 271 using a PPI connection between the ADDRESS event in the RADIO and the CRYPT task in the AES CCM. The KSGEN task is triggered from the READY event in the RADIO through a PPI connection. Page 270 29 CCM — AES CCM mode encryption key-stream generation AES CCM KSGEN decryption CRYPT ENDKSGEN ENDCRYPT PPI PPI READY RADIO ADDRESS RU P A H L RFU EPL MIC RXEN CRC END READY RU: Ramp-up of RADIO P: Preamble A: Address START SHORTCUT H: Header (S0) L: Length RFU: reserved for future use (S1) EPL: encrypted payload : RADIO receiving noise Figure 65: On-the-fly decryption using a PPI connection between the READY event in the RADIO and the KSGEN task in the AES CCM 29.7 CCM data structure The CCM data structure is located in Data RAM at the memory location specified by the CNFPTR pointer register. Table 58: CCM data structure overview Property Address offset Description KEY 0 16 byte AES key PKTCTR 16 Octet0 (LSO) of packet counter 17 Octet1 of packet counter 18 Octet2 of packet counter 19 Octet3 of packet counter 20 Bit 6 – Bit 0: Octet4 (7 most significant bits of packet counter, with Bit 6 being the most significant bit) Bit7: Ignored IV 21 Ignored 22 Ignored 23 Ignored 24 Bit 0: Direction bit Bit 7 – Bit 1: Zero padded 25 8 byte initialization vector (IV) Octet0 (LSO) of IV, Octet1 of IV, … , Octet7 (MSO) of IV The NONCE vector (as specified by the Bluetooth Core Specification) will be generated by hardware based on the information specified in the CCM data structure from Table 58: CCM data structure overview on page 271 . Table 59: Data structure for unencrypted packet Property Address offset Description HEADER 0 Packet Header LENGTH 1 Number of bytes in unencrypted payload RFU 2 Reserved Future Use PAYLOAD 3 Unencrypted payload Table 60: Data structure for encrypted packet Property Address offset Description HEADER 0 Packet Header LENGTH 1 Number of bytes in encrypted payload including length of MIC Important: LENGTH will be 0 for empty packets since the MIC is not added to empty packets RFU 2 Reserved Future Use PAYLOAD 3 Encrypted payload MIC 3 + payload length ENCRYPT: 4 bytes encrypted MIC Page 271 29 CCM — AES CCM mode encryption Property Address offset Description Important: MIC is not added to empty packets 29.8 EasyDMA and ERROR event The CCM implements an EasyDMA mechanism for reading and writing to the RAM. In some scenarios where the CPU and other DMA enabled peripherals are accessing the RAM at the same time, the CCM DMA could experience some bus conflicts which may also result in an error during encryption. If this happens, the ERROR event will be generated. The EasyDMA will have finished accessing the RAM when the ENDKSGEN and ENDCRYPT events are generated. If the CNFPTR, SCRATCHPTR, INPTR and the OUTPTR are not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. 29.9 Registers Table 61: Instances Base address Peripheral Instance Description 0x4000F000 CCM CCM AES CCM Mode Encryption Configuration Table 62: Register Overview Register Offset Description TASKS_KSGEN 0x000 Start generation of key-stream. This operation will stop by itself when completed. TASKS_CRYPT 0x004 Start encryption/decryption. This operation will stop by itself when completed. TASKS_STOP 0x008 Stop encryption/decryption EVENTS_ENDKSGEN 0x100 Key-stream generation complete EVENTS_ENDCRYPT 0x104 Encrypt/decrypt complete EVENTS_ERROR 0x108 CCM error event SHORTS 0x200 Shortcut register INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt MICSTATUS 0x400 MIC check result ENABLE 0x500 Enable MODE 0x504 Operation mode CNFPTR 0x508 Pointer to data structure holding AES key and NONCE vector INPTR 0x50C Input pointer OUTPTR 0x510 Output pointer SCRATCHPTR 0x514 Pointer to data area used for temporary storage 29.9.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ENDKSGEN_CRYPT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between ENDKSGEN event and CRYPT task See EVENTS_ENDKSGEN and TASKS_CRYPT Disabled 0 Disable shortcut Enabled 1 Enable shortcut Page 272 29 CCM — AES CCM mode encryption 29.9.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW ENDKSGEN 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for ENDKSGEN event See EVENTS_ENDKSGEN B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDCRYPT Write '1' to Enable interrupt for ENDCRYPT event See EVENTS_ENDCRYPT C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Enable interrupt for ERROR event See EVENTS_ERROR Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 29.9.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW ENDKSGEN 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for ENDKSGEN event See EVENTS_ENDKSGEN B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDCRYPT Write '1' to Disable interrupt for ENDCRYPT event See EVENTS_ENDCRYPT C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Disable interrupt for ERROR event See EVENTS_ERROR Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 29.9.4 MICSTATUS Address offset: 0x400 MIC check result Page 273 29 CCM — AES CCM mode encryption Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description MICSTATUS The result of the MIC check performed during the previous decryption operation CheckFailed 0 MIC check failed CheckPassed 1 MIC check passed 29.9.5 ENABLE Address offset: 0x500 Enable Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 2 Enable Enable or disable CCM 29.9.6 MODE Address offset: 0x504 Operation mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C Reset 0x00000001 Id RW Field A RW MODE B C 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Description Encryption 0 AES CCM packet encryption mode Decryption 1 AES CCM packet decryption mode 1Mbit 0 In synch with 1 Mbit data rate 2Mbit 1 In synch with 2 Mbit data rate Default 0 Default length. Effective length of LENGTH field is 5-bit Extended 1 Extended length. Effective length of LENGTH field is 8-bit The mode of operation to be used RW DATARATE Data rate that the CCM shall run in synch with RW LENGTH Packet length configuration 29.9.7 CNFPTR Address offset: 0x508 Pointer to data structure holding AES key and NONCE vector Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CNFPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Pointer to the data structure holding the AES key and the CCM NONCE vector (see Table 1 CCM data structure overview) 29.9.8 INPTR Address offset: 0x50C Input pointer Page 274 29 CCM — AES CCM mode encryption Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW INPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Input pointer 29.9.9 OUTPTR Address offset: 0x510 Output pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW OUTPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Output pointer 29.9.10 SCRATCHPTR Address offset: 0x514 Pointer to data area used for temporary storage Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW SCRATCHPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Pointer to a scratch data area used for temporary storage during key-stream generation, MIC generation and encryption/ decryption. The scratch area is used for temporary storage of data during key-stream generation and encryption. A space of 43 bytes, or (16 + MAXPACKETSIZE) bytes, whatever is largest, must be reserved in RAM. Page 275 30 AAR — Accelerated address resolver 30 AAR — Accelerated address resolver Accelerated address resolver is a cryptographic support function for implementing the "Resolvable Private Address Resolution Procedure" described in the Bluetooth Core specification v4.0. "Resolvable private address generation" should be achieved using ECB and is not supported by AAR. The procedure allows two devices that share a secret key to generate and resolve a hash based on their device address. The AAR block enables real-time address resolution on incoming packets when configured as described in this chapter. This allows real-time packet filtering (whitelisting) using a list of known shared keys (Identity Resolving Keys (IRK) in Bluetooth). 30.1 Shared resources The AAR shares registers and other resources with the peripherals that have the same ID as the AAR. The user must therefore disable all peripherals that have the same ID as the AAR before the AAR can be configured and used. Disabling a peripheral that have the same ID as the AAR will not reset any of the registers that are shared with the AAR. It is therefore important to configure all relevant AAR registers explicitly to secure that it operates correctly. See the Instantiation table in Instantiation on page 24 for details on peripherals and their IDs. 30.2 EasyDMA The AAR implements EasyDMA for reading and writing to the RAM. The EasyDMA will have finished accessing the RAM when the END, RESOLVED, and NOTRESOLVED events are generated. If the IRKPTR, ADDRPTR and the SCRATCHPTR is not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. 30.3 Resolving a resolvable address As per Bluetooth specification, a private resolvable address is composed of six bytes. LSB MSB random hash (24-bit) 10 prand (24-bit) Figure 66: Resolvable address To resolve an address the ADDRPTR register must point to the start of packet. The resolver is started by triggering the START task. A RESOLVED event is generated when the AAR manages to resolve the address using one of the Identity Resolving Keys (IRK) found in the IRK data structure. The AAR will use the IRK specified in the register IRK0 to IRK15 starting from IRK0. How many to be used is specified by the NIRK register. The AAR module will generate a NOTRESOLVED event if it is not able to resolve the address using the specified list of IRKs. The AAR will go through the list of available IRKs in the IRK data structure and for each IRK try to resolve the address according to the Resolvable Private Address Resolution Procedure described in the Bluetooth 24 Specification . The time it takes to resolve an address may vary depending on where in the list the 24 Bluetooth Specification Version 4.0 [Vol 3] chapter 10.8.2.3. Page 276 30 AAR — Accelerated address resolver resolvable address is located. The resolution time will also be affected by RAM accesses performed by other peripherals and the CPU. See the Electrical specifications for more information about resolution time. The AAR will only do a comparison of the received address to those programmed in the module. And not check what type of address it actually is. The AAR will stop as soon as it has managed to resolve the address, or after trying to resolve the address using NIRK number of IRKs from the IRK data structure. The AAR will generate an END event after it has stopped. SCRATCHPTR ADDR: resolvable address START Scratch area ADDRPTR RESOLVED AAR S0 L S1 IRK data structure ADDR IRKPTR Figure 67: Address resolution with packet preloaded into RAM 30.4 Use case example for chaining RADIO packet reception with address resolution using AAR The AAR may be started as soon as the 6 bytes required by the AAR have been received by the RADIO and stored in RAM. The ADDRPTR pointer must point to the start of packet. SCRATCHPTR S0: S0 field of RADIO (optional) L: Length field of RADIO (optional) S1: S1 field of RADIO (optional) ADDR: resolvable address START PACKETPTR ADDRPTR Scratch area RESOLVED AAR S0 L S1 IRK data structure ADDR IRKPTR From remote transmitter RADIO RXEN Figure 68: Address resolution with packet loaded into RAM by the RADIO 30.5 IRK data structure The IRK data structure is located in RAM at the memory location specified by the CNFPTR pointer register. Table 63: IRK data structure overview Property IRK0 IRK1 .. IRK15 Address offset 0 16 .. 240 Description IRK number 0 (16 - byte) IRK number 1 (16 - byte) .. IRK number 15 (16 - byte) Page 277 30 AAR — Accelerated address resolver 30.6 Registers Table 64: Instances Base address Peripheral Instance Description 0x4000F000 AAR AAR Acelerated Address Resolver Configuration Table 65: Register Overview Register Offset Description TASKS_START 0x000 Start resolving addresses based on IRKs specified in the IRK data structure TASKS_STOP 0x008 Stop resolving addresses EVENTS_END 0x100 Address resolution procedure complete EVENTS_RESOLVED 0x104 Address resolved EVENTS_NOTRESOLVED 0x108 Address not resolved INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt STATUS 0x400 Resolution status ENABLE 0x500 Enable AAR NIRK 0x504 Number of IRKs IRKPTR 0x508 Pointer to IRK data structure ADDRPTR 0x510 Pointer to the resolvable address SCRATCHPTR 0x514 Pointer to data area used for temporary storage 30.6.1 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW END 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for END event See EVENTS_END B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RESOLVED Write '1' to Enable interrupt for RESOLVED event See EVENTS_RESOLVED C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW NOTRESOLVED Write '1' to Enable interrupt for NOTRESOLVED event See EVENTS_NOTRESOLVED Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 30.6.2 INTENCLR Address offset: 0x308 Disable interrupt Page 278 30 AAR — Accelerated address resolver Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW END 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for END event See EVENTS_END B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RESOLVED Write '1' to Disable interrupt for RESOLVED event See EVENTS_RESOLVED C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW NOTRESOLVED Write '1' to Disable interrupt for NOTRESOLVED event See EVENTS_NOTRESOLVED Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 30.6.3 STATUS Address offset: 0x400 Resolution status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A R 0 Value Id STATUS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..15] The IRK that was used last time an address was resolved 30.6.4 ENABLE Address offset: 0x500 Enable AAR Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 3 Enable Enable or disable AAR 30.6.5 NIRK Address offset: 0x504 Number of IRKs Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000001 Id RW Field A RW NIRK 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Description [1..16] Number of Identity root keys available in the IRK data structure 30.6.6 IRKPTR Address offset: 0x508 Page 279 30 AAR — Accelerated address resolver Pointer to IRK data structure Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW IRKPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Pointer to the IRK data structure 30.6.7 ADDRPTR Address offset: 0x510 Pointer to the resolvable address Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW ADDRPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Pointer to the resolvable address (6-bytes) 30.6.8 SCRATCHPTR Address offset: 0x514 Pointer to data area used for temporary storage Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 Id RW Field Value Id A RW SCRATCHPTR 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Pointer to a scratch data area used for temporary storage during resolution.A space of minimum 3 bytes must be reserved. 30.7 Electrical specification 30.7.1 AAR Electrical Specification Symbol Description tAAR,8 Time for address resolution of 8 IRKs Min. Typ. 48 Page 280 Max. Units µs 31 SPIM — Serial peripheral interface master with EasyDMA 31 SPIM — Serial peripheral interface master with EasyDMA The SPI master can communicate with multiple slaves using individual chip select signals for each of the slave devices attached to a bus. Listed here are the main features for the SPIM STOP Three SPIM instances SPI mode 0-3 EasyDMA direct transfer to/from RAM for both SPI Slave and SPI Master Individual selection of IO pin for each SPI signal START • • • • SPIM GPIO RAM PSEL.MOSI TXD.PTR buffer[0] buffer[1] MOSI Pin SCK Pin TXD+1 TXD buffer EasyDMA buffer[TXD.MAXCNT-1] PSEL.SCK buffer[0] buffer[1] MISO Pin RXD-1 EasyDMA PSEL.MISO RXD.PTR RXD buffer ENDRX ENDTX STARTED buffer[RXD.MAXCNT-1] Figure 69: SPIM — SPI master with EasyDMA The SPIM does not implement support for chip select directly. Therefore, the CPU must use available GPIOs to select the correct slave and control this independently of the SPI master. The SPIM supports SPI modes 0 through 3. The CONFIG register allows setting CPOL and CPHA appropriately. Table 66: SPI modes Mode Clock polarity CPOL SPI_MODE00 (Active High) SPI_MODE10 (Active High) SPI_MODE21 (Active Low) SPI_MODE31 (Active Low) Clock phase CPHA 0 (Leading) 1 (Trailing) 0 (Leading) 1 (Trailing) 31.1 Shared resources The SPI shares registers and other resources with other peripherals that have the same ID as the SPI. Therefore, the user must disable all peripherals that have the same ID as the SPI before the SPI can be configured and used. Page 281 31 SPIM — Serial peripheral interface master with EasyDMA Disabling a peripheral that has the same ID as the SPI will not reset any of the registers that are shared with the SPI. It is therefore important to configure all relevant SPI registers explicitly to secure that it operates correctly. See the Instantiation table in Instantiation on page 24 for details on peripherals and their IDs. 31.2 EasyDMA The SPI master implements EasyDMA for reading and writing of data packets from and to the DATA RAM without CPU involvement. The RXD.PTR and TXD.PTR point to the RXD buffer (receive buffer) and TXD buffer (transmit buffer) respectively, see Figure 69: SPIM — SPI master with EasyDMA on page 281. RXD.MAXCNT and TXD.MAXCNT specify the maximum number of bytes allocated to the buffers. The SPI master will automatically stop transmitting after TXD.MAXCNT bytes have been transmitted and RXD.MAXCNT bytes have been received. If TXD.MAXCNT is larger than RXD.MAXCNT, the superfluous received bytes will be ignored. If RXD.MAXCNT is larger than TXD.MAXCNT, the remaining transmitted bytes will contain the value defined in the ORC register. If the RXD.PTR and the TXD.PTR are not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. The .PTR and .MAXCNT registers are double-buffered. They can be updated and prepared for the next transmission immediately after having received the STARTED event. The ENDRX/ENDTX event indicate that EasyDMA has finished accessing respectively the RX/TX buffer in RAM. The END event gets generated when both RX and TX are finished accessing the buffers in RAM. 31.2.1 EasyDMA list EasyDMA supports one list type. The supported list type is: • Array list EasyDMA array list The EasyDMA array list can be represented by the data structure ArrayList_type. For illustration, see the code example below. This data structure includes only a buffer with size equal to Channel.MAXCNT. EasyDMA will use the Channel.MAXCNT register to determine when the buffer is full. Replace 'Channel' by the specific data channel you want to use, for instance 'NRF_SPIM->RXD', 'NRF_SPIM->TXD', 'NRF_TWIM->RXD', etc. The Channel.MAXCNT register cannot be specified larger than the actual size of the buffer. If Channel.MAXCNT is specified larger than the size of the buffer, the EasyDMA channel may overflow the buffer. This array list does not provide a mechanism to explicitly specify where the next item in the list is located. Instead, it assumes that the list is organized as a linear array where items are located one after the other in RAM. #define BUFFER_SIZE 4 typedef struct ArrayList { uint8_t buffer[BUFFER_SIZE]; } ArrayList_type; ArrayList_type MyArrayList[3]; Page 282 31 SPIM — Serial peripheral interface master with EasyDMA //replace 'Channel' below by the specific data channel you want to use, // for instance 'NRF_SPIM->RXD', 'NRF_TWIM->RXD', etc. Channel.MAXCNT = BUFFER_SIZE; Channel.PTR = &MyArrayList; Channel.PTR = &MyArrayList Note: addresses are assuming that sizeof(buffer[n]) is one byte 0x20000000 : MyArrayList[0] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000004 : MyArrayList[1] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000008 : MyArrayList[2] buffer[0] buffer[1] buffer[2] buffer[3] Figure 70: EasyDMA array list 31.3 SPI master transaction sequence An SPI master transaction consists of a sequence started by the START task followed by a number of events, and finally the STOP task. An SPI master transaction is started by triggering the START task. The ENDTX event will be generated when the transmitter has transmitted all bytes in the TXD buffer as specified in the TXD.MAXCNT register. The ENDRX event will be generated when the receiver has filled the RXD buffer, i.e. received the last possible byte as specified in the RXD.MAXCNT register. Following a START task, the SPI master will generate an END event when both ENDRX and ENDTX have been generated. The SPI master is stopped by triggering the STOP task. A STOPPED event is generated when the SPI master has stopped. If the ENDRX event has not already been generated when the SPI master has come to a stop, the SPI master will generate the ENDRX event explicitly even though the RX buffer is not full. If the ENDTX event has not already been generated when the SPI master has come to a stop, the SPI master will generate the ENDTX event explicitly even though all bytes in the TXD buffer, as specified in the TXD.MAXCNT register, have not been transmitted. The SPI master is a synchronous interface, and for every byte that is sent, a different byte will be received at the same time; this is illustrated in Figure 71: SPI master transaction on page 284. Page 283 31 SPIM — Serial peripheral interface master with EasyDMA CSN SCK MOSI 0 1 2 n ORC ORC MISO A B C m-2 m-1 m ENDRX ENDTX CPU 1 2 START Figure 71: SPI master transaction 31.4 Low power When putting the system in low power and the peripheral is not needed, lowest possible power consumption is achieved by stopping, and then disabling the peripheral. The STOP task may not be always needed (the peripheral might already be stopped), but if it is sent, software shall wait until the STOPPED event was received as a response before disabling the peripheral through the ENABLE register. 31.5 Master mode pin configuration The SCK, MOSI, and MISO signals associated with the SPI master are mapped to physical pins according to the configuration specified in the PSEL.SCK, PSEL.MOSI, and PSEL.MISO registers respectively. The PSEL.SCK, PSEL.MOSI, and PSEL.MISO registers and their configurations are only used as long as the SPI master is enabled, and retained only as long as the device is in ON mode. PSEL.SCK, PSEL.MOSI and PSEL.MISO must only be configured when the SPI master is disabled. To secure correct behavior in the SPI, the pins used by the SPI must be configured in the GPIO peripheral as described in Table 67: GPIO configuration on page 284 prior to enabling the SPI. This configuration must be retained in the GPIO for the selected IOs as long as the SPI is enabled. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. Table 67: GPIO configuration SPI master signal SCK MOSI MISO SPI master pin As specified in PSEL.SCK As specified in PSEL.MOSI As specified in PSEL.MISO Direction Output Output Input Output value Same as CONFIG.CPOL 0 Not applicable Page 284 Comments 31 SPIM — Serial peripheral interface master with EasyDMA 31.6 Registers Table 68: Instances Base address Peripheral Instance Description 0x40003000 SPIM SPIM0 SPI master 0 0x40004000 SPIM SPIM1 SPI master 1 0x40023000 SPIM SPIM2 SPI master 2 Configuration Table 69: Register Overview Register Offset Description TASKS_START 0x010 Start SPI transaction TASKS_STOP 0x014 Stop SPI transaction TASKS_SUSPEND 0x01C Suspend SPI transaction TASKS_RESUME 0x020 Resume SPI transaction EVENTS_STOPPED 0x104 SPI transaction has stopped EVENTS_ENDRX 0x110 End of RXD buffer reached EVENTS_END 0x118 End of RXD buffer and TXD buffer reached EVENTS_ENDTX 0x120 End of TXD buffer reached EVENTS_STARTED 0x14C Transaction started SHORTS 0x200 Shortcut register INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 Enable SPIM PSEL.SCK 0x508 Pin select for SCK PSEL.MOSI 0x50C Pin select for MOSI signal PSEL.MISO 0x510 Pin select for MISO signal FREQUENCY 0x524 SPI frequency. Accuracy depends on the HFCLK source selected. RXD.PTR 0x534 Data pointer RXD.MAXCNT 0x538 Maximum number of bytes in receive buffer RXD.AMOUNT 0x53C Number of bytes transferred in the last transaction RXD.LIST 0x540 EasyDMA list type TXD.PTR 0x544 Data pointer TXD.MAXCNT 0x548 Maximum number of bytes in transmit buffer TXD.AMOUNT 0x54C Number of bytes transferred in the last transaction TXD.LIST 0x550 EasyDMA list type CONFIG 0x554 Configuration register ORC 0x5C0 Over-read character. Character clocked out in case and over-read of the TXD buffer. 31.6.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW END_START 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between END event and START task See EVENTS_END and TASKS_START Disabled 0 Disable shortcut Enabled 1 Enable shortcut 31.6.2 INTENSET Address offset: 0x304 Enable interrupt Page 285 31 SPIM — Serial peripheral interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDRX Write '1' to Enable interrupt for ENDRX event See EVENTS_ENDRX C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to Enable interrupt for END event See EVENTS_END D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDTX Write '1' to Enable interrupt for ENDTX event See EVENTS_ENDTX E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STARTED Write '1' to Enable interrupt for STARTED event See EVENTS_STARTED Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 31.6.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id Value Description Write '1' to Disable interrupt for STOPPED event See EVENTS_STOPPED B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDRX Write '1' to Disable interrupt for ENDRX event See EVENTS_ENDRX C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to Disable interrupt for END event See EVENTS_END D D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDTX Write '1' to Disable interrupt for ENDTX event See EVENTS_ENDTX Page 286 31 SPIM — Serial peripheral interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E Reset 0x00000000 Id E RW Field 0 D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STARTED Write '1' to Disable interrupt for STARTED event See EVENTS_STARTED Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 31.6.4 ENABLE Address offset: 0x500 Enable SPIM Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable SPIM Enabled 7 Enable SPIM Enable or disable SPIM 31.6.5 PSEL.SCK Address offset: 0x508 Pin select for SCK Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 31.6.6 PSEL.MOSI Address offset: 0x50C Pin select for MOSI signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 31.6.7 PSEL.MISO Address offset: 0x510 Pin select for MISO signal Page 287 31 SPIM — Serial peripheral interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 31.6.8 FREQUENCY Address offset: 0x524 SPI frequency. Accuracy depends on the HFCLK source selected. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x04000000 Id RW Field A RW FREQUENCY 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description K125 0x02000000 125 kbps K250 0x04000000 250 kbps K500 0x08000000 500 kbps M1 0x10000000 1 Mbps M2 0x20000000 2 Mbps M4 0x40000000 4 Mbps M8 0x80000000 8 Mbps SPI master data rate 31.6.9 RXD.PTR Address offset: 0x534 Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Data pointer 31.6.10 RXD.MAXCNT Address offset: 0x538 Maximum number of bytes in receive buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in receive buffer 31.6.11 RXD.AMOUNT Address offset: 0x53C Number of bytes transferred in the last transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last transaction Page 288 31 SPIM — Serial peripheral interface master with EasyDMA 31.6.12 RXD.LIST Address offset: 0x540 EasyDMA list type Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A RW LIST 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable EasyDMA list ArrayList 1 Use array list List type 31.6.13 TXD.PTR Address offset: 0x544 Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Data pointer 31.6.14 TXD.MAXCNT Address offset: 0x548 Maximum number of bytes in transmit buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in transmit buffer 31.6.15 TXD.AMOUNT Address offset: 0x54C Number of bytes transferred in the last transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last transaction 31.6.16 TXD.LIST Address offset: 0x550 EasyDMA list type Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A RW LIST 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable EasyDMA list ArrayList 1 Use array list List type Page 289 31 SPIM — Serial peripheral interface master with EasyDMA 31.6.17 CONFIG Address offset: 0x554 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW ORDER B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description MsbFirst 0 Most significant bit shifted out first LsbFirst 1 Least significant bit shifted out first Leading 0 Trailing 1 Bit order RW CPHA Serial clock (SCK) phase Sample on leading edge of clock, shift serial data on trailing edge Sample on trailing edge of clock, shift serial data on leading edge C RW CPOL Serial clock (SCK) polarity ActiveHigh 0 Active high ActiveLow 1 Active low 31.6.18 ORC Address offset: 0x5C0 Over-read character. Character clocked out in case and over-read of the TXD buffer. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW ORC 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Over-read character. Character clocked out in case and overread of the TXD buffer. 31.7 Electrical specification 31.7.1 SPIM master interface electrical specifications Symbol Description fSPIM Bit rates for SPIM25 Min. ISPIM,2Mbps Run current for SPIM, 2 Mbps 50 µA ISPIM,8Mbps Run current for SPIM, 8 Mbps 50 µA ISPIM,IDLE Idle current for SPIM (STARTed, no CSN activity) 1 tSPIM,START Time from START task to transmission started .. Typ. .. Max. Units 826 Mbps µA .. µs 31.7.2 Serial Peripheral Interface Master (SPIM) timing specifications Symbol Description Min. Typ. Max. Units tSPIM,CSCK SCK period .. .. .. ns tSPIM,RSCK,LD SCK rise time, standard drivea tRF,25pF tSPIM,RSCK,HD SCK rise time, high drivea tHRF,25pF tSPIM,FSCK,LD SCK fall time, standard drivea tRF,25pF tSPIM,FSCK,HD SCK fall time, high drivea tSPIM,WHSCK SCK high timea tHRF,25pF (0.5*tCSCK) – tRSCK 25 26 a High bit rates may require GPIOs to be set as High Drive, see GPIO chapter for more details. The actual maximum data rate depends on the slave's CLK to MISO and MOSI setup and hold timings. At 25pF load, including GPIO pin capacitance, see GPIO spec. Page 290 31 SPIM — Serial peripheral interface master with EasyDMA Symbol Description Min. tSPIM,WLSCK SCK low timea (0.5*tCSCK) Typ. tSPIM,SUMI MISO to CLK edge setup time 19 tSPIM,HMI CLK edge to MISO hold time 18 tSPIM,VMO CLK edge to MOSI valid tSPIM,HMO MOSI hold time after CLK edge Max. Units – tFSCK ns ns 59 20 ns tCSCK SCK (out) CPOL=0 CPHA=0 tWHSCK tWLSCK CPOL=1 CPHA=0 tRSCK tFSCK CPOL=0 CPHA=1 CPOL=1 CPHA=1 tSUMI MISO (in) tHMI MSb tVMO MOSI (out) MSb LSb tHMO LSb Figure 72: SPIM timing diagram Page 291 ns 32 SPIS — Serial peripheral interface slave with EasyDMA 32 SPIS — Serial peripheral interface slave with EasyDMA SPI slave (SPIS) is implemented with EasyDMA support for ultra low power serial communication from an external SPI master. EasyDMA in conjunction with hardware-based semaphore mechanisms removes all real-time requirements associated with controlling the SPI slave from a low priority CPU execution context. PSEL.CSN PSEL.MISO PSEL.MOSI PSEL.SCK SPIS CSN MOSI MISO ACQUIRE SPI slave tranceiver RELEASE Semaphore ACQUIRED END DEF OVERREAD OVERFLOW TXD.PTR EasyDMA EasyDMA RXD.PTR RAM TXD RXD TXD+1 RXD+1 TXD+2 RXD+2 TXD+n RXD+n Figure 73: SPI slave The SPIS supports SPI modes 0 through 3. The CONFIG register allows setting CPOL and CPHA appropriately. Table 70: SPI modes Mode SPI_MODE0 SPI_MODE1 SPI_MODE2 SPI_MODE3 Clock polarity CPOL 0 (Leading) 0 (Leading) 1 (Trailing) 1 (Trailing) Clock phase CPHA 0 (Active High) 1 (Active Low) 0 (Active High) 1 (Active Low) 32.1 Shared resources The SPI slave shares registers and other resources with other peripherals that have the same ID as the SPI slave. Therefore, you must disable all peripherals that have the same ID as the SPI slave before the SPI slave can be configured and used. Disabling a peripheral that has the same ID as the SPI slave will not reset any of the registers that are shared with the SPI slave. It is important to configure all relevant SPI slave registers explicitly to secure that it operates correctly. The Instantiation table in Instantiation on page 24 shows which peripherals have the same ID as the SPI slave. 32.2 EasyDMA The SPI slave implements EasyDMA for reading and writing to and from the RAM. The END event indicates that EasyDMA has finished accessing the buffer in RAM. Page 292 32 SPIS — Serial peripheral interface slave with EasyDMA If the TXD.PTR and the RXD.PTR are not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. 32.3 SPI slave operation SPI slave uses two memory pointers, RXD.PTR and TXD.PTR, that point to the RXD buffer (receive buffer) and TXD buffer (transmit buffer) respectively. Since these buffers are located in RAM, which can be accessed by both the SPI slave and the CPU, a hardware based semaphore mechanism is implemented to enable safe sharing. See Figure 74: SPI transaction when shortcut between END and ACQUIRE is enabled on page 294. Before the CPU can safely update the RXD.PTR and TXD.PTR pointers it must first acquire the SPI semaphore. The CPU can acquire the semaphore by triggering the ACQUIRE task and then receiving the ACQUIRED event. When the CPU has updated the RXD.PTR and TXD.PTR pointers the CPU must release the semaphore before the SPI slave will be able to acquire it. The CPU releases the semaphore by triggering the RELEASE task. This is illustrated in Figure 74: SPI transaction when shortcut between END and ACQUIRE is enabled on page 294. Triggering the RELEASE task when the semaphore is not granted to the CPU will have no effect. The semaphore mechanism does not, at any time, prevent the CPU from performing read or write access to the RXD.PTR register, the TXD.PTR registers, or the RAM that these pointers are pointing to. The semaphore is only telling when these can be updated by the CPU so that safe sharing is achieved. The semaphore is by default assigned to the CPU after the SPI slave is enabled. No ACQUIRED event will be generated for this initial semaphore handover. An ACQUIRED event will be generated immediately if the ACQUIRE task is triggered while the semaphore is assigned to the CPU. The SPI slave will try to acquire the semaphore when CSN goes low. If the SPI slave does not manage to acquire the semaphore at this point, the transaction will be ignored. This means that all incoming data on MOSI will be discarded, and the DEF (default) character will be clocked out on the MISO line throughout the whole transaction. This will also be the case even if the semaphore is released by the CPU during the transaction. In case of a race condition where the CPU and the SPI slave try to acquire the semaphore at the same time, as illustrated in lifeline item 2 in Figure 74: SPI transaction when shortcut between END and ACQUIRE is enabled on page 294, the semaphore will be granted to the CPU. If the SPI slave acquires the semaphore, the transaction will be granted. The incoming data on MOSI will be stored in the RXD buffer and the data in the TXD buffer will be clocked out on MISO. When a granted transaction is completed and CSN goes high, the SPI slave will automatically release the semaphore and generate the END event. As long as the semaphore is available the SPI slave can be granted multiple transactions one after the other. If the CPU is not able to reconfigure the TXD.PTR and RXD.PTR between granted transactions, the same TX data will be clocked out and the RX buffers will be overwritten. To prevent this from happening, the END_ACQUIRE shortcut can be used. With this shortcut enabled the semaphore will be handed over to the CPU automatically after the granted transaction has completed, giving the CPU the ability to update the TXPTR and RXPTR between every granted transaction. If the CPU tries to acquire the semaphore while it is assigned to the SPI slave, an immediate handover will not be granted. However, the semaphore will be handed over to the CPU as soon as the SPI slave has released the semaphore after the granted transaction is completed. If the END_ACQUIRE shortcut is enabled and the CPU has triggered the ACQUIRE task during a granted transaction, only one ACQUIRE request will be served following the END event. The MAXRX register specifies the maximum number of bytes the SPI slave can receive in one granted transaction. If the SPI slave receives more than MAXRX number of bytes, an OVERFLOW will be indicated in the STATUS register and the incoming bytes will be discarded. The MAXTX parameter specifies the maximum number of bytes the SPI slave can transmit in one granted transaction. If the SPI slave is forced to transmit more than MAXTX number of bytes, an OVERREAD will be indicated in the STATUS register and the ORC character will be clocked out. Page 293 32 SPIS — Serial peripheral interface slave with EasyDMA The RXD.AMOUNT and TXD.AMOUNT registers are updated when a granted transaction is completed. The TXD.AMOUNT register indicates how many bytes were read from the TX buffer in the last transaction, that is, ORC (over-read) characters are not included in this number. Similarly, the RXD.AMOUNT register indicates how many bytes were written into the RX buffer in the last transaction. The ENDRX event is generated when the RX buffer has been filled. Transaction status SPI master can use the DEF character to stop the transaction as soon as possible if the transaction is not granted. Ignored Granted MOSI 0 1 2 0 1 2 DEF DEF DEF DEF A B C Free SPIS CPU CPU 4 3 ACQUIRE ACQUIRE 2 RELEASE ACQUIRE 1 RELEASE Lifeline CPUPENDING END & ACQUIRED Free ACQUIRED CPU ACQUIRED Semaphore assignment 0 MISO SCK CSN Ignored Figure 74: SPI transaction when shortcut between END and ACQUIRE is enabled 32.4 Pin configuration The CSN, SCK, MOSI, and MISO signals associated with the SPI slave are mapped to physical pins according to the configuration specified in the PSEL.CSN, PSEL.SCK, PSEL.MOSI, and PSEL.MISO registers respectively. If the CONNECT field of any of these registers is set to Disconnected, the associated SPI slave signal will not be connected to any physical pins. The PSEL.CSN, PSEL.SCK, PSEL.MOSI, and PSEL.MISO registers and their configurations are only used as long as the SPI slave is enabled, and retained only as long as the device is in System ON mode, see POWER — Power supply on page 78 chapter for more information about power modes. When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. PSEL.CSN, PSEL.SCK, PSEL.MOSI, and PSEL.MISO must only be configured when the SPI slave is disabled. To secure correct behavior in the SPI slave, the pins used by the SPI slave must be configured in the GPIO peripheral as described in Table 71: GPIO configuration before enabling peripheral on page 295 before enabling the SPI slave. This is to secure that the pins used by the SPI slave are driven correctly if the SPI Page 294 32 SPIS — Serial peripheral interface slave with EasyDMA slave itself is temporarily disabled, or if the device temporarily enters System OFF. This configuration must be retained in the GPIO for the selected I/Os as long as the SPI slave is to be recognized by an external SPI master. The MISO line is set in high impedance as long as the SPI slave is not selected with CSN. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. Table 71: GPIO configuration before enabling peripheral SPI signal CSN SCK MOSI MISO SPI pin As specified in PSEL.CSN As specified in PSEL.SCK As specified in PSEL.MOSI As specified in PSEL.MISO Direction Input Input Input Input Output value Not applicable Not applicable Not applicable Not applicable Comment Emulates that the SPI slave is not selected. 32.5 Registers Table 72: Instances Base address Peripheral Instance Description 0x40003000 SPIS SPIS0 SPI slave 0 0x40004000 SPIS SPIS1 SPI slave 1 0x40023000 SPIS SPIS2 SPI slave 2 Configuration Table 73: Register Overview Register Offset Description TASKS_ACQUIRE 0x024 Acquire SPI semaphore TASKS_RELEASE 0x028 Release SPI semaphore, enabling the SPI slave to acquire it EVENTS_END 0x104 Granted transaction completed EVENTS_ENDRX 0x110 End of RXD buffer reached EVENTS_ACQUIRED 0x128 Semaphore acquired SHORTS 0x200 Shortcut register INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt SEMSTAT 0x400 Semaphore status register STATUS 0x440 Status from last transaction ENABLE 0x500 Enable SPI slave PSELSCK 0x508 Pin select for SCK Deprecated PSELMISO 0x50C Pin select for MISO Deprecated PSELMOSI 0x510 Pin select for MOSI Deprecated PSELCSN 0x514 Pin select for CSN Deprecated PSEL.SCK 0x508 Pin select for SCK PSEL.MISO 0x50C Pin select for MISO signal PSEL.MOSI 0x510 Pin select for MOSI signal PSEL.CSN 0x514 Pin select for CSN signal RXDPTR 0x534 RXD data pointer Deprecated MAXRX 0x538 Maximum number of bytes in receive buffer Deprecated AMOUNTRX 0x53C Number of bytes received in last granted transaction Deprecated RXD.PTR 0x534 RXD data pointer RXD.MAXCNT 0x538 Maximum number of bytes in receive buffer RXD.AMOUNT 0x53C Number of bytes received in last granted transaction TXDPTR 0x544 TXD data pointer Deprecated MAXTX 0x548 Maximum number of bytes in transmit buffer Deprecated AMOUNTTX 0x54C Number of bytes transmitted in last granted transaction Deprecated TXD.PTR 0x544 TXD data pointer TXD.MAXCNT 0x548 Maximum number of bytes in transmit buffer TXD.AMOUNT 0x54C Number of bytes transmitted in last granted transaction CONFIG 0x554 Configuration register Page 295 32 SPIS — Serial peripheral interface slave with EasyDMA Register Offset Description DEF 0x55C Default character. Character clocked out in case of an ignored transaction. ORC 0x5C0 Over-read character 32.5.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW END_ACQUIRE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between END event and ACQUIRE task See EVENTS_END and TASKS_ACQUIRE Disabled 0 Disable shortcut Enabled 1 Enable shortcut 32.5.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C Reset 0x00000000 Id RW Field A RW END 0 Value Id B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for END event See EVENTS_END B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDRX Write '1' to Enable interrupt for ENDRX event See EVENTS_ENDRX C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ACQUIRED Write '1' to Enable interrupt for ACQUIRED event See EVENTS_ACQUIRED Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 32.5.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C Reset 0x00000000 Id RW Field A RW END 0 Value Id Value Description Write '1' to Disable interrupt for END event See EVENTS_END B B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDRX Write '1' to Disable interrupt for ENDRX event Page 296 32 SPIS — Serial peripheral interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C Reset 0x00000000 Id RW Field 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_ENDRX C RW ACQUIRED Write '1' to Disable interrupt for ACQUIRED event See EVENTS_ACQUIRED Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 32.5.4 SEMSTAT Address offset: 0x400 Semaphore status register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A Reset 0x00000001 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Description Free 0 Semaphore is free CPU 1 Semaphore is assigned to CPU SPIS 2 Semaphore is assigned to SPI slave CPUPending 3 Semaphore is assigned to SPI but a handover to the CPU is SEMSTAT Semaphore status pending 32.5.5 STATUS Address offset: 0x440 Status from last transaction Individual bits are cleared by writing a '1' to the bits that shall be cleared Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A Reset 0x00000000 Id RW Field A RW OVERREAD B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NotPresent 0 Read: error not present Present 1 Read: error present Clear 1 Write: clear error on writing '1' NotPresent 0 Read: error not present Present 1 Read: error present Clear 1 Write: clear error on writing '1' TX buffer over-read detected, and prevented RW OVERFLOW RX buffer overflow detected, and prevented 32.5.6 ENABLE Address offset: 0x500 Enable SPI slave Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW ENABLE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable SPI slave Page 297 32 SPIS — Serial peripheral interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable SPI slave Enabled 2 Enable SPI slave 32.5.7 PSELSCK ( Deprecated ) Address offset: 0x508 Pin select for SCK Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELSCK 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI SCK signal 0xFFFFFFFF Disconnect 32.5.8 PSELMISO ( Deprecated ) Address offset: 0x50C Pin select for MISO Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELMISO 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI MISO signal 0xFFFFFFFF Disconnect 32.5.9 PSELMOSI ( Deprecated ) Address offset: 0x510 Pin select for MOSI Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELMOSI 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI MOSI signal 0xFFFFFFFF Disconnect 32.5.10 PSELCSN ( Deprecated ) Address offset: 0x514 Pin select for CSN Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELCSN 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI CSN signal 0xFFFFFFFF Disconnect 32.5.11 PSEL.SCK Address offset: 0x508 Pin select for SCK Page 298 32 SPIS — Serial peripheral interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 32.5.12 PSEL.MISO Address offset: 0x50C Pin select for MISO signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 32.5.13 PSEL.MOSI Address offset: 0x510 Pin select for MOSI signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 32.5.14 PSEL.CSN Address offset: 0x514 Pin select for CSN signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 32.5.15 RXDPTR ( Deprecated ) Address offset: 0x534 RXD data pointer Page 299 32 SPIS — Serial peripheral interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW RXDPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RXD data pointer 32.5.16 MAXRX ( Deprecated ) Address offset: 0x538 Maximum number of bytes in receive buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXRX 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in receive buffer 32.5.17 AMOUNTRX ( Deprecated ) Address offset: 0x53C Number of bytes received in last granted transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNTRX Number of bytes received in the last granted transaction 32.5.18 RXD.PTR Address offset: 0x534 RXD data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RXD data pointer 32.5.19 RXD.MAXCNT Address offset: 0x538 Maximum number of bytes in receive buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in receive buffer 32.5.20 RXD.AMOUNT Address offset: 0x53C Number of bytes received in last granted transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes received in the last granted transaction Page 300 32 SPIS — Serial peripheral interface slave with EasyDMA 32.5.21 TXDPTR ( Deprecated ) Address offset: 0x544 TXD data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW TXDPTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description TXD data pointer 32.5.22 MAXTX ( Deprecated ) Address offset: 0x548 Maximum number of bytes in transmit buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXTX 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in transmit buffer 32.5.23 AMOUNTTX ( Deprecated ) Address offset: 0x54C Number of bytes transmitted in last granted transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNTTX Number of bytes transmitted in last granted transaction 32.5.24 TXD.PTR Address offset: 0x544 TXD data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description TXD data pointer 32.5.25 TXD.MAXCNT Address offset: 0x548 Maximum number of bytes in transmit buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in transmit buffer 32.5.26 TXD.AMOUNT Address offset: 0x54C Number of bytes transmitted in last granted transaction Page 301 32 SPIS — Serial peripheral interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transmitted in last granted transaction 32.5.27 CONFIG Address offset: 0x554 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW ORDER B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description MsbFirst 0 Most significant bit shifted out first LsbFirst 1 Least significant bit shifted out first Leading 0 Trailing 1 Bit order RW CPHA Serial clock (SCK) phase Sample on leading edge of clock, shift serial data on trailing edge Sample on trailing edge of clock, shift serial data on leading edge C RW CPOL Serial clock (SCK) polarity ActiveHigh 0 Active high ActiveLow 1 Active low 32.5.28 DEF Address offset: 0x55C Default character. Character clocked out in case of an ignored transaction. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW DEF 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Default character. Character clocked out in case of an ignored transaction. 32.5.29 ORC Address offset: 0x5C0 Over-read character Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW ORC 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Over-read character. Character clocked out after an over-read of the transmit buffer. Page 302 32 SPIS — Serial peripheral interface slave with EasyDMA 32.6 Electrical specification 32.6.1 SPIS slave interface electrical specifications Symbol Description fSPIS Bit rates for SPIS27 Min. Typ. Max. Units 828 ISPIS,2Mbps Run current for SPIS, 2 Mbps 45 Mbps µA ISPIS,8Mbps Run current for SPIS, 8 Mbps 45 µA ISPIS,IDLE Idle current for SPIS (STARTed, no CSN activity) 1 µA tSPIS,LP,START Time from RELEASE task to ready to receive/transmit (CSN tSPIS,CL,START µs active), Low power mode + tSTART_HFINT tSPIS,CL,START Time from RELEASE task to receive/transmit (CSN active), 0.125 µs Constant latency mode 32.6.2 Serial Peripheral Interface Slave (SPIS) timing specifications Symbol Description tSPIS,CSCKIN,8Mbps SCK input period at 8Mbps Min. Typ. 125 Max. Units ns tSPIS,CSCKIN,4Mbps SCK input period at 4Mbps 250 ns tSPIS,CSCKIN,2Mbps SCK input period at 2Mbps 500 tSPIS,RFSCKIN SCK input rise/fall time tSPIS,WHSCKIN SCK input high time 30 ns tSPIS,WLSCKIN SCK input low time 30 ns tSPIS,SUCSN,LP CSN to CLK setup time, Low power mode tSPIS,SUCSN,CL ns ns 30 ns + tSTART_HFINT tSPIS,SUCSN,CL CSN to CLK setup time, Constant latency mode 1000 tSPIS,HCSN CLK to CSN hold time 2000 ns tSPIS,ASO CSN to MISO drivena 1000 ns tSPIS,DISSO CSN to MISO disableda 68 ns tSPIS,CWH CSN inactive time tSPIS,VSO CLK edge to MISO valid tSPIS,HSO MISO hold time after CLK edge 1829 ns tSPIS,SUSI MOSI to CLK edge setup time 59 ns tSPIS,HSI CLK edge to MOSI hold time 20 ns ns 300 ns 19 ns CSN (in) SCK (in) tSUCSN CPOL=0 CPHA=0 tCSCKIN tWHSCKIN tWLSCKIN CPOL=1 CPHA=0 tASO tHSO tDISSO MSb tSUSI MOSI (in) tCWH tRSCKIN tFSCKIN tVSO MISO (out) tHCSN LSb tHSI MSb LSb Figure 75: SPIS timing diagram 27 28 a 29 Higher bit rates may require GPIOs to be set as High Drive, see GPIO chapter for more details. The actual maximum data rate depends on the master's CLK to MISO and MOSI setup and hold timings. At 25pF load, including GPIO capacitance, see GPIO spec. This is to ensure compatibility to SPI masters sampling MISO on the same edge as MOSI is output Page 303 32 SPIS — Serial peripheral interface slave with EasyDMA Master Slave CSN (in) SCK CPOL=0 CPHA=0 tSUCSN tCSCK tWHSCK tWLSCK CPOL=1 CPHA=0 tHCSN tRSCK tFSCK CPOL=0 CPHA=1 CPOL=1 CPHA=1 tSUMI tASO MISO (in) MISO (out) tHMI tVSO tDISSO MSb LSb tVMO tHSI tSUSI MOSI (out) MOSI (in) tHSO tHMO MSb LSb Figure 76: Common SPIM and SPIS timing diagram Page 304 2 33 TWIM — I C compatible two-wire interface master with EasyDMA 2 33 TWIM — I C compatible two-wire interface master with EasyDMA TWI master with EasyDMA (TWIM) is a two-wire half-duplex master which can communicate with multiple slave devices connected to the same bus Listed here are the main features for TWIM: • • • • 2 I C compatible 100 kbps, 250 kbps, or 400 kbps Support for clock stretching EasyDMA The two-wire interface can communicate with a bi-directional wired-AND bus with two lines (SCL, SDA). The protocol makes it possible to interconnect up to 127 individually addressable devices. TWIM is not compatible with CBUS. STOP RESUME SUSPEND STARTTX STARTRX The GPIOs used for each two-wire interface line can be chosen from any GPIO on the device and are independently configurable. This enables great flexibility in device pinout and efficient use of board space and signal routing. TWIM GPIO RAM PSEL.SDA TXD.PTR buffer[0] buffer[1] SDA Pin SCL Pin TXD+1 EasyDMA buffer[TXD.MAXCNT-1] RXD-1 EasyDMA buffer[0] TXD buffer buffer[1] RXD buffer PSEL.SCK RXD.PTR STOPPED ERROR SUSPENDED LASTTX LASTRX TXSTARTED RXSTARTED buffer[RXD.MAXCNT-1] Figure 77: TWI master with EasyDMA A typical TWI setup consists of one master and one or more slaves. For an example, see Figure 78: A typical TWI setup comprising one master and three slaves on page 306. This TWIM is only able to operate as a single master on the TWI bus. Multi-master bus configuration is not supported. Page 305 2 33 TWIM — I C compatible two-wire interface master with EasyDMA VDD VDD TWI master (TWIM) SDA SCL R R TWI slave (EEPROM) TWI slave (Sensor) TWI slave Address = b1011001 Address = b1011000 Address = b1011011 SCL SDA SCL SDA SCL SDA Figure 78: A typical TWI setup comprising one master and three slaves This TWI master supports clock stretching performed by the slaves. The TWI master is started by triggering the STARTTX or STARTRX tasks, and stopped by triggering the STOP task. The TWI master will generate a STOPPED event when it has stopped following a STOP task. The TWI master cannot get stopped while it is suspended, so the STOP task has to be issued after the TWI master has been resumed. After the TWI master is started, the STARTTX task or the STARTRX task should not be triggered again before the TWI master has stopped, i.e. following a LASTRX, LASTTX or STOPPED event. If a NACK is clocked in from the slave, the TWI master will generate an ERROR event. 33.1 Shared resources The TWI master shares registers and other resources with other peripherals that have the same ID as the TWI master. Therefore, you must disable all peripherals that have the same ID as the TWI master before the TWI master can be configured and used. Disabling a peripheral that has the same ID as the TWI master will not reset any of the registers that are shared with the TWI master. It is therefore important to configure all relevant registers explicitly to secure that the TWI master operates correctly. The Instantiation table in Instantiation on page 24 shows which peripherals have the same ID as the TWI. 33.2 EasyDMA The TWI master implements EasyDMA for reading and writing to and from the RAM. If the TXD.PTR and the RXD.PTR are not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. The .PTR and .MAXCNT registers are double-buffered. They can be updated and prepared for the next RX/ TX transmission immediately after having received the RXSTARTED/TXSTARTED event. The STOPPED event indicates that EasyDMA has finished accessing the buffer in RAM. 33.2.1 EasyDMA list EasyDMA supports one list type. The supported list type is: • Array list EasyDMA array list The EasyDMA array list can be represented by the data structure ArrayList_type. For illustration, see the code example below. This data structure includes only a buffer with size equal to Channel.MAXCNT. EasyDMA will use the Channel.MAXCNT register to determine when the buffer is full. Replace 'Channel' by the specific data channel you want to use, for instance 'NRF_SPIM->RXD', 'NRF_SPIM->TXD', 'NRF_TWIM->RXD', etc. Page 306 2 33 TWIM — I C compatible two-wire interface master with EasyDMA The Channel.MAXCNT register cannot be specified larger than the actual size of the buffer. If Channel.MAXCNT is specified larger than the size of the buffer, the EasyDMA channel may overflow the buffer. This array list does not provide a mechanism to explicitly specify where the next item in the list is located. Instead, it assumes that the list is organized as a linear array where items are located one after the other in RAM. #define BUFFER_SIZE 4 typedef struct ArrayList { uint8_t buffer[BUFFER_SIZE]; } ArrayList_type; ArrayList_type MyArrayList[3]; //replace 'Channel' below by the specific data channel you want to use, // for instance 'NRF_SPIM->RXD', 'NRF_TWIM->RXD', etc. Channel.MAXCNT = BUFFER_SIZE; Channel.PTR = &MyArrayList; Channel.PTR = &MyArrayList Note: addresses are assuming that sizeof(buffer[n]) is one byte 0x20000000 : MyArrayList[0] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000004 : MyArrayList[1] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000008 : MyArrayList[2] buffer[0] buffer[1] buffer[2] buffer[3] Figure 79: EasyDMA array list 33.3 Master write sequence A TWI master write sequence is started by triggering the STARTTX task. After the STARTTX task has been triggered, the TWI master will generate a start condition on the TWI bus, followed by clocking out the address and the READ/WRITE bit set to 0 (WRITE=0, READ=1). The address must match the address of the slave device that the master wants to write to. The READ/ WRITE bit is followed by an ACK/NACK bit (ACK=0 or NACK=1) generated by the slave. After receiving the ACK bit, the TWI master will clock out the data bytes found in the transmit buffer located in RAM at the address specified in the TXD.PTR register. Each byte clocked out from the master will be followed by an ACK/NACK bit clocked in from the slave. A typical TWI master write sequence is illustrated in Figure 80: TWI master writing data to a slave on page 308. Occurrence 2 in the figure illustrates clock stretching performed by the TWI master following a SUSPEND task. A SUSPENDED event indicates that the SUSPEND task has taken effect; this event can be used to synchronize the software. Page 307 2 33 TWIM — I C compatible two-wire interface master with EasyDMA STOPPED 4 STOP RESUME 3 SUSPEND STARTTX TXD.MAXCNT = N+1 LASTTX SUSPENDED TWI CPU Lifeline 2 N ACK 1 N-1 STOP 2 ACK Stretch ACK 1 ACK 0 ACK ACK WRITE START ADDR Figure 80: TWI master writing data to a slave The TWI master will generate a LASTTX event when it starts to transmit the last byte, this is illustrated in Figure 80: TWI master writing data to a slave on page 308 The TWI master is stopped by triggering the STOP task, this task should be triggered during the transmission of the last byte to secure that the TWI will stop as fast as possible after sending the last byte. It is safe to use the shortcut between LASTTX and STOP to accomplish this. Note that the TWI master does not stop by itself when the whole RAM buffer has been sent, or when an error occurs. The STOP task must be issued, through the use of a local or PPI shortcut, or in software as part of the error handler. The TWI master cannot get stopped while it is suspended, so the STOP task has to be issued after the TWI master has been resumed. 33.4 Master read sequence A TWI master read sequence is started by triggering the STARTRX task. After the STARTRX task has been triggered the TWI master will generate a start condition on the TWI bus, followed by clocking out the address and the READ/WRITE bit set to 1 (WRITE = 0, READ = 1). The address must match the address of the slave device that the master wants to read from. The READ/WRITE bit is followed by an ACK/NACK bit (ACK=0 or NACK = 1) generated by the slave. After having sent the ACK bit the TWI slave will send data to the master using the clock generated by the master. Data received will be stored in RAM at the address specified in the RXD.PTR register. The TWI master will generate an ACK after all but the last byte received from the slave. The TWI master will generate a NACK after the last byte received to indicate that the read sequence shall stop. A typical TWI master read sequence is illustrated in Figure 81: The TWI master reading data from a slave on page 309. Occurrence 2 in the figure illustrates clock stretching performed by the TWI master following a SUSPEND task. A SUSPENDED event indicates that the SUSPEND task has taken effect; this event can be used to synchronize the software. The TWI master will generate a LASTRX event when it is ready to receive the last byte, this is illustrated in Figure 81: The TWI master reading data from a slave on page 309. If RXD.MAXCNT > 1 the LASTRX event is generated after sending the ACK of the previously received byte. If RXD.MAXCNT = 1 the LASTRX event is generated after receiving the ACK following the address and READ bit. The TWI master is stopped by triggering the STOP task, this task must be triggered before the NACK bit is supposed to be transmitted. The STOP task can be triggered at any time during the reception of the last byte. It is safe to use the shortcut between LASTRX and STOP to accomplish this. Page 308 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Note that the TWI master does not stop by itself when the RAM buffer is full, or when an error occurs. The STOP task must be issued, through the use of a local or PPI shortcut, or in software as part of the error handler. The TWI master cannot get stopped while it is suspended, so the STOP task has to be issued after the TWI master has been resumed. LASTRX 3 4 STOP SUSPEND RESUME 2 STARTRX RXD.MAXCNT = M+1 CPU Lifeline 1 M STOPPED M-1 SUSPENDED TWI 2 STOP NACK Stretch ACK 1 ACK ACK 0 ACK ACK READ START ADDR Figure 81: The TWI master reading data from a slave 33.5 Master repeated start sequence A typical repeated start sequence is one in which the TWI master writes two bytes to the slave followed by reading four bytes from the slave. This example uses shortcuts to perform the simplest type of repeated start sequence, i.e. one write followed by one read. The same approach can be used to perform a repeated start sequence where the sequence is read followed by write. STOPPED LASTRX LASTTX STOP STARTRX 2 STARTTX TXD.MAXCNT = 2 RXD.MAXCNT = 4 CPU Lifeline STOP 1 3 NACK 2 ACK 1 ACK 0 ACK ADDR ACK READ 1 RESTART ACK 0 ACK ADDR ACK WRITE START CPU Lifeline The figure Figure 82: A repeated start sequence, where the TWI master writes two bytes followed by reading 4 bytes from the slave on page 309 illustrates this: Figure 82: A repeated start sequence, where the TWI master writes two bytes followed by reading 4 bytes from the slave If a more complex repeated start sequence is needed and the TWI firmware drive is serviced in a low priority interrupt it may be necessary to use the SUSPEND task and SUSPENDED event to guarantee that the correct tasks are generated at the correct time. This is illustrated in Figure 83: A double repeated start sequence using the SUSPEND task to secure safe operation in low priority interrupts on page 310. Page 309 2 33 TWIM — I C compatible two-wire interface master with EasyDMA STOPPED LASTTX 5 STOP STARTTX RESUME STARTRX TXD.MAXCNT = 2 SUSPEND RXD.MAXCNT = 1 STARTTX TXD.MAXCNT = 1 LASTRX SUSPENDED LASTTX TWI CPU Lifeline 4 ACK 3 1 STOP 0 ACK 2 ADDR ACK WRITE 1 0 NACK ADDR RESTART Stretch ACK READ 0 RESTART ACK ACK WRITE START ADDR Figure 83: A double repeated start sequence using the SUSPEND task to secure safe operation in low priority interrupts 33.6 Low power When putting the system in low power and the peripheral is not needed, lowest possible power consumption is achieved by stopping, and then disabling the peripheral. The STOP task may not be always needed (the peripheral might already be stopped), but if it is sent, software shall wait until the STOPPED event was received as a response before disabling the peripheral through the ENABLE register. 33.7 Master mode pin configuration The SCL and SDA signals associated with the TWI master are mapped to physical pins according to the configuration specified in the PSEL.SCL and PSEL.SDA registers respectively. The PSEL.SCL and PSEL.SDA registers and their configurations are only used as long as the TWI master is enabled, and retained only as long as the device is in ON mode. When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. PSEL.SCL, PSEL.SDA must only be configured when the TWI master is disabled. To secure correct signal levels on the pins used by the TWI master when the system is in OFF mode, and when the TWI master is disabled, these pins must be configured in the GPIO peripheral as described in Table 74: GPIO configuration before enabling peripheral on page 310. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. Table 74: GPIO configuration before enabling peripheral TWI master signal SCL SDA TWI master pin As specified in PSEL.SCL As specified in PSEL.SDA Direction Input Input Output value Not applicable Not applicable 33.8 Registers Table 75: Instances Base address Peripheral Instance Description 0x40003000 TWIM TWIM0 Two-wire interface master 0 0x40004000 TWIM TWIM1 Two-wire interface master 1 Page 310 Configuration Drive strength S0D1 S0D1 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Table 76: Register Overview Register Offset Description TASKS_STARTRX 0x000 Start TWI receive sequence TASKS_STARTTX 0x008 Start TWI transmit sequence TASKS_STOP 0x014 Stop TWI transaction. Must be issued while the TWI master is not suspended. TASKS_SUSPEND 0x01C Suspend TWI transaction TASKS_RESUME 0x020 Resume TWI transaction EVENTS_STOPPED 0x104 TWI stopped EVENTS_ERROR 0x124 TWI error EVENTS_SUSPENDED 0x148 Last byte has been sent out after the SUSPEND task has been issued, TWI traffic is now suspended. EVENTS_RXSTARTED 0x14C Receive sequence started EVENTS_TXSTARTED 0x150 Transmit sequence started EVENTS_LASTRX 0x15C Byte boundary, starting to receive the last byte EVENTS_LASTTX 0x160 Byte boundary, starting to transmit the last byte SHORTS 0x200 Shortcut register INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ERRORSRC 0x4C4 Error source ENABLE 0x500 Enable TWIM PSEL.SCL 0x508 Pin select for SCL signal PSEL.SDA 0x50C Pin select for SDA signal FREQUENCY 0x524 TWI frequency RXD.PTR 0x534 Data pointer RXD.MAXCNT 0x538 Maximum number of bytes in receive buffer RXD.AMOUNT 0x53C Number of bytes transferred in the last transaction RXD.LIST 0x540 EasyDMA list type TXD.PTR 0x544 Data pointer TXD.MAXCNT 0x548 Maximum number of bytes in transmit buffer TXD.AMOUNT 0x54C Number of bytes transferred in the last transaction TXD.LIST 0x550 EasyDMA list type ADDRESS 0x588 Address used in the TWI transfer 33.8.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id F Reset 0x00000000 Id RW Field A RW LASTTX_STARTRX 0 Value Id D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between LASTTX event and STARTRX task See EVENTS_LASTTX and TASKS_STARTRX B Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW LASTTX_SUSPEND Shortcut between LASTTX event and SUSPEND task See EVENTS_LASTTX and TASKS_SUSPEND C Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW LASTTX_STOP Shortcut between LASTTX event and STOP task See EVENTS_LASTTX and TASKS_STOP D Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW LASTRX_STARTTX Shortcut between LASTRX event and STARTTX task See EVENTS_LASTRX and TASKS_STARTTX Disabled 0 Disable shortcut Page 311 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id F Reset 0x00000000 Id F RW Field 0 D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Enable shortcut RW LASTRX_STOP Shortcut between LASTRX event and STOP task See EVENTS_LASTRX and TASKS_STOP Disabled 0 Disable shortcut Enabled 1 Enable shortcut 33.8.2 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id J Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id I H G F D Value Description Enable or disable interrupt for STOPPED event See EVENTS_STOPPED D Disabled 0 Disable Enabled 1 Enable RW ERROR Enable or disable interrupt for ERROR event See EVENTS_ERROR F Disabled 0 Disable Enabled 1 Enable RW SUSPENDED Enable or disable interrupt for SUSPENDED event See EVENTS_SUSPENDED G Disabled 0 Disable Enabled 1 Enable RW RXSTARTED Enable or disable interrupt for RXSTARTED event See EVENTS_RXSTARTED H Disabled 0 Disable Enabled 1 Enable RW TXSTARTED Enable or disable interrupt for TXSTARTED event See EVENTS_TXSTARTED I Disabled 0 Disable Enabled 1 Enable RW LASTRX Enable or disable interrupt for LASTRX event See EVENTS_LASTRX J A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Disabled 0 Disable Enabled 1 Enable RW LASTTX Enable or disable interrupt for LASTTX event See EVENTS_LASTTX Disabled 0 Disable Enabled 1 Enable 33.8.3 INTENSET Address offset: 0x304 Enable interrupt Page 312 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id J Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id I H G F D A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Enable interrupt for ERROR event See EVENTS_ERROR F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SUSPENDED Write '1' to Enable interrupt for SUSPENDED event See EVENTS_SUSPENDED G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXSTARTED Write '1' to Enable interrupt for RXSTARTED event See EVENTS_RXSTARTED H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTARTED Write '1' to Enable interrupt for TXSTARTED event See EVENTS_TXSTARTED I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW LASTRX Write '1' to Enable interrupt for LASTRX event See EVENTS_LASTRX J Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW LASTTX Write '1' to Enable interrupt for LASTTX event See EVENTS_LASTTX Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 33.8.4 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id J Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id I H G F Value Description Write '1' to Disable interrupt for STOPPED event See EVENTS_STOPPED D D A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Disable interrupt for ERROR event See EVENTS_ERROR Page 313 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id J Reset 0x00000000 Id F RW Field 0 I H G F D A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SUSPENDED Write '1' to Disable interrupt for SUSPENDED event See EVENTS_SUSPENDED G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXSTARTED Write '1' to Disable interrupt for RXSTARTED event See EVENTS_RXSTARTED H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTARTED Write '1' to Disable interrupt for TXSTARTED event See EVENTS_TXSTARTED I Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW LASTRX Write '1' to Disable interrupt for LASTRX event See EVENTS_LASTRX J Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW LASTTX Write '1' to Disable interrupt for LASTTX event See EVENTS_LASTTX Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 33.8.5 ERRORSRC Address offset: 0x4C4 Error source Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW OVERRUN 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Overrun error A new byte was received before previous byte got transferred into RXD buffer. (Previous data is lost) B C NotReceived 0 Error did not occur Received 1 Error occurred NotReceived 0 Error did not occur Received 1 Error occurred NotReceived 0 Error did not occur Received 1 Error occurred RW ANACK NACK received after sending the address (write '1' to clear) RW DNACK NACK received after sending a data byte (write '1' to clear) 33.8.6 ENABLE Address offset: 0x500 Page 314 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Enable TWIM Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable TWIM Enabled 6 Enable TWIM Enable or disable TWIM 33.8.7 PSEL.SCL Address offset: 0x508 Pin select for SCL signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 33.8.8 PSEL.SDA Address offset: 0x50C Pin select for SDA signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 33.8.9 FREQUENCY Address offset: 0x524 TWI frequency Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x04000000 Id RW Field A RW FREQUENCY 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description K100 0x01980000 100 kbps K250 0x04000000 250 kbps K400 0x06400000 400 kbps TWI master clock frequency 33.8.10 RXD.PTR Address offset: 0x534 Data pointer Page 315 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Data pointer 33.8.11 RXD.MAXCNT Address offset: 0x538 Maximum number of bytes in receive buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [1..255] Maximum number of bytes in receive buffer 33.8.12 RXD.AMOUNT Address offset: 0x53C Number of bytes transferred in the last transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last transaction. In case of NACK error, includes the NACK'ed byte. 33.8.13 RXD.LIST Address offset: 0x540 EasyDMA list type Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A RW LIST 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable EasyDMA list ArrayList 1 Use array list List type 33.8.14 TXD.PTR Address offset: 0x544 Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Data pointer 33.8.15 TXD.MAXCNT Address offset: 0x548 Maximum number of bytes in transmit buffer Page 316 2 33 TWIM — I C compatible two-wire interface master with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [1..255] Maximum number of bytes in transmit buffer 33.8.16 TXD.AMOUNT Address offset: 0x54C Number of bytes transferred in the last transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last transaction. In case of NACK error, includes the NACK'ed byte. 33.8.17 TXD.LIST Address offset: 0x550 EasyDMA list type Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A RW LIST 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable EasyDMA list ArrayList 1 Use array list List type 33.8.18 ADDRESS Address offset: 0x588 Address used in the TWI transfer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A Reset 0x00000000 Id RW Field A RW ADDRESS 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Address used in the TWI transfer 33.9 Electrical specification 33.9.1 TWIM interface electrical specifications Symbol Description Min. fTWIM Bit rates for TWIM30 100 Typ. Max. Units 400 ITWIM,100kbps Run current for TWIM, 100 kbps 50 kbps µA ITWIM,400kbps Run current for TWIM, 400 kbps 50 µA tTWIM,START,LP Time from STARTRX/STARTTX task to transmission started, Low tTWIM,START,CL µs power mode + tSTART_HFINT tTWIM,START,CL Time from STARTRX/STARTTX task to transmission started, 1.5 µs Constant latency mode 30 Higher bit rates or stronger pull-ups may require GPIOs to be set as High Drive, see GPIO chapter for more details. Page 317 2 33 TWIM — I C compatible two-wire interface master with EasyDMA 33.9.2 Two Wire Interface Master (TWIM) timing specifications Symbol Description fTWIM,SCL,100kbps SCL clock frequency, 100 kbps Min. Typ. 100 Max. Units kHz fTWIM,SCL,250kbps SCL clock frequency, 250 kbps 250 kHz fTWIM,SCL,400kbps SCL clock frequency, 400 kbps 400 kHz tTWIM,SU_DAT Data setup time before positive edge on SCL – all modes 300 ns tTWIM,HD_DAT Data hold time after negative edge on SCL – all modes 500 ns tTWIM,HD_STA,100kbps TWIM master hold time for START and repeated START 10000 ns 4000 ns 2500 ns 5000 ns 2000 ns 1250 ns 5800 ns 2700 ns 2100 ns condition, 100 kbps tTWIM,HD_STA,250kbps TWIM master hold time for START and repeated START condition, 250kbps tTWIM,HD_STA,400kbps TWIM master hold time for START and repeated START condition, 400 kbps tTWIM,SU_STO,100kbps TWIM master setup time from SCL high to STOP condition, 100 kbps tTWIM,SU_STO,250kbps TWIM master setup time from SCL high to STOP condition, 250 kbps tTWIM,SU_STO,400kbps TWIM master setup time from SCL high to STOP condition, 400 kbps tTWIM,BUF,100kbps TWIM master bus free time between STOP and START conditions, 100 kbps tTWIM,BUF,250kbps TWIM master bus free time between STOP and START conditions, 250 kbps tTWIM,BUF,400kbps TWIM master bus free time between STOP and START conditions, 400 kbps Figure 84: TWIM timing diagram, 1 byte transaction R [kΩ] 30 100 kbps 25 400 kbps 20 15 13 10 5 0 0 100 200 300 400 500 cap [pF] Figure 85: Recommended TWIM pullup value vs. line capacitance • • The I2C specification allows a line capacitance of 400 pF at most. The nRF52832 internal pullup has a fixed value of typ. 13 kOhm, see RPU in the GPIO chapter. Page 318 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA 2 TWI slave with EasyDMA (TWIS) is compatible with I C operating at 100 kHz and 400 kHz. The TWI transmitter and receiver implement EasyDMA. PSELSDA PSELSCK PSELSDA PREPARETX PREPARERX RXD (signal) STOPPED TXD (signal) SUSPEND RESUME EasyDMA RXD.PTR EasyDMA TXD.PTR WRITE READ RAM RXD TXD RXD+1 TXD+1 RXD+2 TXD+2 RXD+n TXD+n Figure 86: TWI slave with EasyDMA A typical TWI setup consists of one master and one or more slaves. For an example, see Figure 87: A typical TWI setup comprising one master and three slaves on page 319. TWIS is only able to operate with a single master on the TWI bus. VDD VDD TWI master SDA SCL R R TWI slave (EEPROM) TWI slave (Sensor) Address = b1011001 Address = b1011000 SCL SDA SCL SDA TWI slave (TWIS) Address = b1011011 SCL SDA Figure 87: A typical TWI setup comprising one master and three slaves The TWI slave state machine is illustrated in Figure 88: TWI slave state machine on page 320 and Table 77: TWI slave state machine symbols on page 320 is explaining the different symbols used in the state machine. Page 319 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA PREPARETX PREPARERX ENABLE / STOPPED Unprepare TX, Unprepare RX IDLE STOP [ READ && (TX prepared) ] [ WRITE && (RX prepared) ] Restart sequence Stop sequence TX RX entry / Unprepare TX entry / Unprepare RX entry / TXSTARTED entry / RXSTARTED Figure 88: TWI slave state machine Table 77: TWI slave state machine symbols Symbol ENABLE PREPARETX STOP PREPARERX STOPPED RXSTARTED TXSTARTED TX prepared RX prepared Unprepare TX Unprepare RX Stop sequence Restart sequence Type Register Task Task Task Event Event Event Internal Internal Internal Internal TWI protocol TWI protocol Description The TWI slave has been enabled via the ENABLE register The TASKS_PREPARETX task has been triggered The TASKS_STOP task has been triggered The TASKS_PREPARERX task has been triggered The EVENTS_STOPPED event was generated The EVENTS_RXSTARTED event was generated The EVENTS_TXSTARTED event was generated Internal flag indicating that a TASKS_PREPARETX task has been triggered. This flag is not visible to the user. Internal flag indicating that a TASKS_PREPARERX task has been triggered. This flag is not visible to the user. Clears the internal 'TX prepared' flag until next TASKS_PREPARETX task. Clears the internal 'RX prepared' flag until next TASKS_PREPARERX task. A TWI stop sequence was detected A TWI restart sequence was detected The TWI slave supports clock stretching performed by the master. The TWI slave operates in a low power mode while waiting for a TWI master to initiate a transfer. As long as the TWI slave is not addressed, it will remain in this low power mode. To secure correct behaviour of the TWI slave, PSEL.SCL, PSEL.SDA, CONFIG and the ADDRESS[n] registers, must be configured prior to enabling the TWI slave through the ENABLE register. Similarly, changing these settings must be performed while the TWI slave is disabled. Failing to do so may result in unpredictable behaviour. Page 320 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA 34.1 Shared resources The TWI slave shares registers and other resources with other peripherals that have the same ID as the TWI slave. Therefore, you must disable all peripherals that have the same ID as the TWI slave before the TWI slave can be configured and used. Disabling a peripheral that has the same ID as the TWI slave will not reset any of the registers that are shared with the TWI slave. It is therefore important to configure all relevant registers explicitly to secure that the TWI slave operates correctly. The Instantiation table in Instantiation on page 24 shows which peripherals have the same ID as the TWI slave. 34.2 EasyDMA The TWI slave implements EasyDMA for reading and writing to and from the RAM. The STOPPED event indicates that EasyDMA has finished accessing the buffer in RAM. If the TXD.PTR and the RXD.PTR are not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. 34.3 TWI slave responding to a read command Before the TWI slave can respond to a read command the TWI slave must be configured correctly and enabled via the ENABLE register. When enabled the TWI slave will be in its IDLE state where it will consume IIDLE . A read command is started when the TWI master generates a start condition on the TWI bus, followed by clocking out the address and the READ/WRITE bit set to 1 (WRITE=0, READ=1). The READ/WRITE bit is followed by an ACK/NACK bit (ACK=0 or NACK=1) response from the TWI slave. The TWI slave is able to listen for up to two addresses at the same time. Which addresses to listen for is configured in the ADDRESS registers and the CONFIG register. The TWI slave will only acknowledge (ACK) the read command if the address presented by the master matches one of the addresses the slave is configured to listen for. The TWI slave will generate a READ event when it acknowledges the read command. The TWI slave is only able to detect a read command from the IDLE state. The TWI slave will set an internal 'TX prepared' flag when the PREPARETX task is triggered. When the read command is received the TWI slave will enter the TX state if the internal 'TX prepared' flag is set. If the internal 'TX prepared' flag is not set when the read command is received, the TWI slave will stretch the master's clock until the PREPARETX task is triggered and the internal 'TX prepared' flag is set. The TWI slave will generate the TXSTARTED event and clear the 'TX prepared' flag ('unprepare TX') when it enters the TX state. In this state the TWI slave will send the data bytes found in the transmit buffer to the master using the master's clock. The TWI slave will consume ITX in this mode. The TWI slave will go back to the IDLE state if the TWI slave receives a restart command when it is in the TX state. The TWI slave is stopped when it receives the stop condition from the TWI master. A STOPPED event will be generated when the transaction has stopped. The TWI slave will clear the 'TX prepared' flag ('unprepare TX') and go back to the IDLE state when it has stopped. The transmit buffer is located in RAM at the address specified in the TXD.PTR register. The TWI slave will only be able to send TXD.MAXCNT bytes from the transmit buffer for each transaction. If the TWI master Page 321 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA forces the slave to send more than TXD.MAXCNT bytes, the slave will send the byte specified in the ORC register to the master instead. If this happens, an ERROR event will be generated. The EasyDMA configuration registers, see TXD.PTR etc., are latched when the TXSTARTED event is generated. The TWI slave can be forced to stop by triggering the STOP task. A STOPPED event will be generated when the TWI slave has stopped. The TWI slave will clear the 'TX prepared' flag and go back to the IDLE state when it has stopped, see also Terminating an ongoing TWI transaction on page 324. Each byte sent from the slave will be followed by an ACK/NACK bit sent from the master. The TWI master will generate a NACK following the last byte that it wants to receive to tell the slave to release the bus so that the TWI master can generate the stop condition. The TXD.AMOUNT register can be queried after a transaction to see how many bytes were sent. A typical TWI slave read command response is illustrated in Figure 89: The TWI slave responding to a read command on page 322. Occurrence 2 in the figure illustrates clock stretching performed by the TWI slave following a SUSPEND task. STOPPED READ 3 4 SUSPEND RESUME 2 PREPARETX TXD.MAXCNT >= N+1 TXD.PTR = 0x20000000 TXSTARTED TWI CPU Lifeline N STOP N-1 NACK 2 ACK Stretch ACK 1 ACK 1 0 ACK ACK READ START ADDR Figure 89: The TWI slave responding to a read command 34.4 TWI slave responding to a write command Before the TWI slave can respond to a write command the TWI slave must be configured correctly and enabled via the ENABLE register. When enabled the TWI slave will be in its IDLE state where it will consume IIDLE. A write command is started when the TWI master generates a start condition on the TWI bus, followed by clocking out the address and the READ/WRITE bit set to 0 (WRITE=0, READ=1). The READ/WRITE bit is followed by an ACK/NACK bit (ACK=0 or NACK=1) response from the slave. The TWI slave is able to listen for up to two addresses at the same time. Which addresses to listen for is configured in the ADDRESS registers and the CONFIG register. The TWI slave will only acknowledge (ACK) the write command if the address presented by the master matches one of the addresses the slave is configured to listen for. The TWI slave will generate a WRITE event if it acknowledges the write command. The TWI slave is only able to detect a write command from the IDLE state. The TWI slave will set an internal 'RX prepared' flag when the PREPARERX task is triggered. When the write command is received the TWI slave will enter the RX state if the internal 'RX prepared' flag is set. If the internal 'RX prepared' flag is not set when the write command is received, the TWI slave will stretch the master's clock until the PREPARERX task is triggered and the internal 'RX prepared' flag is set. Page 322 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA The TWI slave will generate the RXSTARTED event and clear the internal 'RX prepared' flag ('unprepare RX') when it enters the RX state. In this state the TWI slave will be able to receive the bytes sent by the TWI master. The TWI slave will consume IRX in this mode. The TWI slave will go back to the IDLE state if the TWI slave receives a restart command when it is in the RX state. The TWI slave is stopped when it receives the stop condition from the TWI master. A STOPPED event will be generated when the transaction has stopped. The TWI slave will clear the internal 'RX prepared' flag ('unprepare RX') and go back to the IDLE state when it has stopped. The receive buffer is located in RAM at the address specified in the TXD.PTR register. The TWI slave will only be able to receive as many bytes as specified in the RXD.MAXCNT register. If the TWI master tries to send more bytes to the slave than the slave is able to receive,these bytes will be discarded and the bytes will be NACKed by the slave. If this happens, an ERROR event will be generated. The EasyDMA configuration registers, see RXD.PTR etc., are latched when the RXSTARTED event is generated. The TWI slave can be forced to stop by triggering the STOP task. A STOPPED event will be generated when the TWI slave has stopped. The TWI slave will clear the internal 'RX prepared' flag and go back to the IDLE state when it has stopped, see also Terminating an ongoing TWI transaction on page 324. The TWI slave will generate an ACK after every byte received from the master. The RXD.AMOUNT register can be queried after a transaction to see how many bytes were received. A typical TWI slave write command response is illustrated in Figure 90: The TWI slave responding to a write command on page 323. Occurrence 2 in the figure illustrates clock stretching performed by the TWI slave following a SUSPEND task. M-1 M STOPPED 2 3 SUSPEND RESUME WRITE PREPARERX RXD.MAXCNT >= M+1 RXD.PTR = 0x20000000 RXSTARTED TWI CPU Lifeline 2 STOP ACK Stretch ACK 1 ACK ACK 1 0 ACK ACK WRITE START ADDR 4 Figure 90: The TWI slave responding to a write command 34.5 Master repeated start sequence An example of a repeated start sequence is one in which the TWI master writes two bytes to the slave followed by reading four bytes from the slave. This is illustrated in Figure 91: A repeated start sequence, where the TWI master writes two bytes followed by reading four bytes from the slave on page 324. It is here assumed that the receiver does not know in advance what the master wants to read, and that this information is provided in the first two bytes received in the write part of the repeated start sequence. To guarantee that the CPU is able to process the received data before the TWI slave starts to reply to the read command, the SUSPEND task is triggered via a shortcut from the READ event generated when the read command is received. When the CPU has processed the incoming data and prepared the correct data response, the CPU will resume the transaction by triggering the RESUME task. Page 323 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA STOPPED 3 RESUME TXD.MAXCNT = 4 PREPARETX SUSPEND TXD.PTR = 0x20000010 PREPARERX RXD.MAXCNT = 2 RXD.PTR = 0x20000000 TXSTARTED READ WRITE RXSTARTED TWI CPU Lifeline STOP 3 NACK 2 2 ACK 1 1 ACK 0 ACK ADDR ACK READ 1 RESTART ACK 0 ACK ACK WRITE START ADDR Figure 91: A repeated start sequence, where the TWI master writes two bytes followed by reading four bytes from the slave 34.6 Terminating an ongoing TWI transaction In some situations, e.g. if the external TWI master is not responding correctly, it may be required to terminate an ongoing transaction. This can be achieved by triggering the STOP task. In this situation a STOPPED event will be generated when the TWI has stopped independent of whether or not a STOP condition has been generated on the TWI bus. The TWI slave will release the bus when it has stopped and go back to its IDLE state. 34.7 Low power When putting the system in low power and the peripheral is not needed, lowest possible power consumption is achieved by stopping, and then disabling the peripheral. The STOP task may not be always needed (the peripheral might already be stopped), but if it is sent, software shall wait until the STOPPED event was received as a response before disabling the peripheral through the ENABLE register. 34.8 Slave mode pin configuration The SCL and SDA signals associated with the TWI slave are mapped to physical pins according to the configuration specified in the PSEL.SCL and PSEL.SDA registers respectively. The PSEL.SCL and PSEL.SDA registers and their configurations are only used as long as the TWI slave is enabled, and retained only as long as the device is in ON mode. When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. PSEL.SCL and PSEL.SDA must only be configured when the TWI slave is disabled. To secure correct signal levels on the pins used by the TWI slave when the system is in OFF mode, and when the TWI slave is disabled, these pins must be configured in the GPIO peripheral as described in Table 78: GPIO configuration before enabling peripheral on page 324. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. Table 78: GPIO configuration before enabling peripheral TWI slave signal SCL SDA TWI slave pin As specified in PSEL.SCL As specified in PSEL.SDA Direction Input Input Page 324 Output value Not applicable Not applicable Drive strength S0D1 S0D1 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA 34.9 Registers Table 79: Instances Base address Peripheral Instance Description 0x40003000 TWIS TWIS0 Two-wire interface slave 0 Configuration 0x40004000 TWIS TWIS1 Two-wire interface slave 1 Table 80: Register Overview Register Offset Description TASKS_STOP 0x014 Stop TWI transaction TASKS_SUSPEND 0x01C Suspend TWI transaction TASKS_RESUME 0x020 Resume TWI transaction TASKS_PREPARERX 0x030 Prepare the TWI slave to respond to a write command TASKS_PREPARETX 0x034 Prepare the TWI slave to respond to a read command EVENTS_STOPPED 0x104 TWI stopped EVENTS_ERROR 0x124 TWI error EVENTS_RXSTARTED 0x14C Receive sequence started EVENTS_TXSTARTED 0x150 Transmit sequence started EVENTS_WRITE 0x164 Write command received EVENTS_READ 0x168 Read command received SHORTS 0x200 Shortcut register INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ERRORSRC 0x4D0 Error source MATCH 0x4D4 Status register indicating which address had a match ENABLE 0x500 Enable TWIS PSEL.SCL 0x508 Pin select for SCL signal PSEL.SDA 0x50C Pin select for SDA signal RXD.PTR 0x534 RXD Data pointer RXD.MAXCNT 0x538 Maximum number of bytes in RXD buffer RXD.AMOUNT 0x53C Number of bytes transferred in the last RXD transaction TXD.PTR 0x544 TXD Data pointer TXD.MAXCNT 0x548 Maximum number of bytes in TXD buffer TXD.AMOUNT 0x54C Number of bytes transferred in the last TXD transaction ADDRESS[0] 0x588 TWI slave address 0 ADDRESS[1] 0x58C TWI slave address 1 CONFIG 0x594 Configuration register for the address match mechanism ORC 0x5C0 Over-read character. Character sent out in case of an over-read of the transmit buffer. 34.9.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A Reset 0x00000000 Id RW Field A RW WRITE_SUSPEND 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between WRITE event and SUSPEND task See EVENTS_WRITE and TASKS_SUSPEND B Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW READ_SUSPEND Shortcut between READ event and SUSPEND task See EVENTS_READ and TASKS_SUSPEND Page 325 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable shortcut Enabled 1 Enable shortcut 34.9.2 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id F E B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for STOPPED event See EVENTS_STOPPED B Disabled 0 Disable Enabled 1 Enable RW ERROR Enable or disable interrupt for ERROR event See EVENTS_ERROR E Disabled 0 Disable Enabled 1 Enable RW RXSTARTED Enable or disable interrupt for RXSTARTED event See EVENTS_RXSTARTED F Disabled 0 Disable Enabled 1 Enable RW TXSTARTED Enable or disable interrupt for TXSTARTED event See EVENTS_TXSTARTED G Disabled 0 Disable Enabled 1 Enable RW WRITE Enable or disable interrupt for WRITE event See EVENTS_WRITE H Disabled 0 Disable Enabled 1 Enable RW READ Enable or disable interrupt for READ event See EVENTS_READ Disabled 0 Disable Enabled 1 Enable 34.9.3 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id F E Value Description Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED B B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Enable interrupt for ERROR event Page 326 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G Reset 0x00000000 Id RW Field 0 F E B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_ERROR E RW RXSTARTED Write '1' to Enable interrupt for RXSTARTED event See EVENTS_RXSTARTED F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTARTED Write '1' to Enable interrupt for TXSTARTED event See EVENTS_TXSTARTED G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW WRITE Write '1' to Enable interrupt for WRITE event See EVENTS_WRITE H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW READ Write '1' to Enable interrupt for READ event See EVENTS_READ Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 34.9.4 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G Reset 0x00000000 Id RW Field A RW STOPPED 0 Value Id F E B Value Description Write '1' to Disable interrupt for STOPPED event See EVENTS_STOPPED B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Disable interrupt for ERROR event See EVENTS_ERROR E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXSTARTED Write '1' to Disable interrupt for RXSTARTED event See EVENTS_RXSTARTED F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTARTED Write '1' to Disable interrupt for TXSTARTED event See EVENTS_TXSTARTED Clear A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Disable Page 327 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G Reset 0x00000000 Id G RW Field 0 F E B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW WRITE Write '1' to Disable interrupt for WRITE event See EVENTS_WRITE H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW READ Write '1' to Disable interrupt for READ event See EVENTS_READ Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 34.9.5 ERRORSRC Address offset: 0x4D0 Error source Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B Reset 0x00000000 Id RW Field A RW OVERFLOW B C 0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NotDetected 0 Error did not occur Detected 1 Error occurred NotReceived 0 Error did not occur Received 1 Error occurred NotDetected 0 Error did not occur Detected 1 Error occurred RX buffer overflow detected, and prevented RW DNACK NACK sent after receiving a data byte RW OVERREAD TX buffer over-read detected, and prevented 34.9.6 MATCH Address offset: 0x4D4 Status register indicating which address had a match Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A R 0 Value Id MATCH 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..1] Which of the addresses in {ADDRESS} matched the incoming address 34.9.7 ENABLE Address offset: 0x500 Enable TWIS Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Disabled 0 Description Enable or disable TWIS Disable TWIS Page 328 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 9 Enable TWIS 34.9.8 PSEL.SCL Address offset: 0x508 Pin select for SCL signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 34.9.9 PSEL.SDA Address offset: 0x50C Pin select for SDA signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 34.9.10 RXD.PTR Address offset: 0x534 RXD Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RXD Data pointer 34.9.11 RXD.MAXCNT Address offset: 0x538 Maximum number of bytes in RXD buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in RXD buffer 34.9.12 RXD.AMOUNT Address offset: 0x53C Number of bytes transferred in the last RXD transaction Page 329 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last RXD transaction 34.9.13 TXD.PTR Address offset: 0x544 TXD Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description TXD Data pointer 34.9.14 TXD.MAXCNT Address offset: 0x548 Maximum number of bytes in TXD buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in TXD buffer 34.9.15 TXD.AMOUNT Address offset: 0x54C Number of bytes transferred in the last TXD transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last TXD transaction 34.9.16 ADDRESS[0] Address offset: 0x588 TWI slave address 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A Reset 0x00000000 Id RW Field A RW ADDRESS 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description TWI slave address 34.9.17 ADDRESS[1] Address offset: 0x58C TWI slave address 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A Reset 0x00000000 Id RW Field A RW ADDRESS 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description TWI slave address Page 330 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA 34.9.18 CONFIG Address offset: 0x594 Configuration register for the address match mechanism Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A Reset 0x00000001 Id RW Field A RW ADDRESS0 B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Description Disabled 0 Disabled Enabled 1 Enabled Disabled 0 Disabled Enabled 1 Enabled Enable or disable address matching on ADDRESS[0] RW ADDRESS1 Enable or disable address matching on ADDRESS[1] 34.9.19 ORC Address offset: 0x5C0 Over-read character. Character sent out in case of an over-read of the transmit buffer. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW ORC 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Over-read character. Character sent out in case of an over-read of the transmit buffer. 34.10 Electrical specification 34.10.1 TWIS slave interface electrical specifications Symbol Description Min. fTWIS Bit rates for TWIS31 100 ITWIS,100kbps Run current for TWIS (Average current to receive and transfer a Typ. Max. Units 400 kbps 45 µA 45 µA byte to RAM), 100 kbps ITWIS,400kbps Run current for TWIS (Average current to receive and transfer a byte to RAM), 400 kbps ITWIS,IDLE Idle current for TWIS 1 µA tTWIS,START,LP Time from PREPARERX/PREPARETX task to ready to receive/ tTWIS,START,CL µs transmit, Low power mode + tSTART_HFINT tTWIS,START,CL Time from PREPARERX/PREPARETX task to ready to receive/ 1.5 µs transmit, Constant latency mode 34.10.2 TWIS slave timing specifications Symbol Description fTWIS,SCL,400kbps SCL clock frequency, 400 kbps Min. Typ. Max. Units 400 tTWIS,SU_DAT Data setup time before positive edge on SCL – all modes 300 kHz ns tTWIS,HD_DAT Data hold time after negative edge on SCL – all modes 500 ns tTWIS,HD_STA,100kbps TWI slave hold time from for START condition (SDA low to SCL 5200 ns 1300 ns low), 100 kbps tTWIS,HD_STA,400kbps TWI slave hold time from for START condition (SDA low to SCL low), 400 kbps 31 Higher bit rates or stronger pull-ups may require GPIOs to be set as High Drive, see GPIO chapter for more details. Page 331 2 34 TWIS — I C compatible two-wire interface slave with EasyDMA Symbol Description Min. tTWIS,SU_STO,100kbps TWI slave setup time from SCL high to STOP condition, 100 kbps 5200 tTWIS,SU_STO,400kbps TWI slave setup time from SCL high to STOP condition, 400 kbps 1300 tTWIS,BUF,100kbps TWI slave bus free time between STOP and START conditions, Typ. Max. Units ns ns 4700 ns 1300 ns 100 kbps tTWIS,BUF,400kbps TWI slave bus free time between STOP and START conditions, 400 kbps Figure 92: TWIS timing diagram, 1 byte transaction Page 332 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA The Universal asynchronous receiver/transmitter with EasyDMA (UARTE) offers fast, full-duplex, asynchronous serial communication with built-in flow control (CTS, RTS) support in hardware at a rate up to 1 Mbps, and EasyDMA data transfer from/to RAM. Listed here are the main features for UARTE: • • • • • • • • Full-duplex operation Automatic hardware flow control th Parity checking and generation for the 9 data bit EasyDMA Up to 1 Mbps baudrate Return to IDLE between transactions supported (when using HW flow control) One stop bit Least significant bit (LSB) first PSELRXD STARTRX PSELCTS RXD (signal) STOPRX PSELRTS RXD.PTR TXD.PTR PSELTXD TXD (signal) STARTTX STOPTX SUSPEND RESUME RX FIFO RXTO ENDTX EasyDMA EasyDMA ENDRX CTS NCTS RAM RXD TXD RXD+1 TXD+1 RXD+2 TXD+2 RXD+n TXD+n Figure 93: UARTE configuration The GPIOs used for each UART interface can be chosen from any GPIO on the device and are independently configurable. This enables great flexibility in device pinout and efficient use of board space and signal routing. 35.1 Shared resources The UARTE shares registers and other resources with other peripherals that have the same ID as the UARTE. Therefore, you must disable all peripherals that have the same ID as the UARTE before the UARTE can be configured and used. Disabling a peripheral that has the same ID as the UARTE will not reset any of the registers that are shared with the UARTE. It is therefore important to configure all relevant UARTE registers explicitly to ensure that it operates correctly. See the Instantiation table in Instantiation on page 24 for details on peripherals and their IDs. 35.2 EasyDMA The UARTE implements EasyDMA for reading and writing to and from the RAM. If the TXD.PTR and the RXD.PTR are not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. Page 333 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA The .PTR and .MAXCNT registers are double-buffered. They can be updated and prepared for the next RX/ TX transmission immediately after having received the RXSTARTED/TXSTARTED event. The ENDRX/ENDTX event indicates that EasyDMA has finished accessing respectively the RX/TX buffer in RAM. 35.3 Transmission The first step of a DMA transmission is storing bytes in the transmit buffer and configuring EasyDMA. This is achieved by writing the initial address pointer to TXD.PTR, and the number of bytes in the RAM buffer to TXD.MAXCNT. The UARTE transmission is started by triggering the STARTTX task. After each byte has been sent over the TXD line, a TXDRDY event will be generated. When all bytes in the TXD buffer, as specified in the TXD.MAXCNT register, have been transmitted, the UARTE transmission will end automatically and an ENDTX event will be generated. A UARTE transmission sequence is stopped by triggering the STOPTX task, a TXSTOPPED event will be generated when the UARTE transmitter has stopped. If the ENDTX event has not already been generated when the UARTE transmitter has come to a stop, the UARTE will generate the ENDTX event explicitly even though all bytes in the TXD buffer, as specified in the TXD.MAXCNT register, have not been transmitted. N 2 ENDTX TXDRDY TXDRDY N-1 TXDRDY N-2 2 TXDRDY TXDRDY 1 STARTTX TXD.MAXCNT = N+1 1 TXSTARTED Lifeline 0 TXDRDY TXD CTS If flow control is enabled, a transmission will be automatically suspended when CTS is deactivated and resumed when CTS is activated again, as illustrated in Figure 94: UARTE transmission on page 334. A byte that is in transmission when CTS is deactivated will be fully transmitted before the transmission is suspended. Figure 94: UARTE transmission The UARTE transmitter will be in its lowest activity level, and consume the least amount of energy, when it is stopped, i.e. before it is started via STARTTX or after it has been stopped via STOPTX and the TXSTOPPED event has been generated. See POWER — Power supply on page 78 for more information about power modes. 35.4 Reception The UARTE receiver is started by triggering the STARTRX task. The UARTE receiver is using EasyDMA to store incoming data in an RX buffer in RAM. Page 334 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA The RX buffer is located at the address specified in the RXD.PTR register. The RXD.PTR register is doublebuffered and it can be updated and prepared for the next STARTRX task immediately after the RXSTARTED event is generated. The size of the RX buffer is specified in the RXD.MAXCNT register and the UARTE will generate an ENDRX event when it has filled up the RX buffer, see Figure 95: UARTE reception on page 335. For each byte received over the RXD line, an RXDRDY event will be generated. This event is likely to occur before the corresponding data has been transferred to Data RAM. The RXD.AMOUNT register can be queried following an ENDRX event to see how many new bytes have been transferred to the RX buffer in RAM since the previous ENDRX event. Data RAM 1 2 3 4 5 6 7 8 9 10 11 12 - 10 11 0x20000003 0x20000004 0x20000010 0x20000011 0x20000012 0x20000013 0x20000014 0x20000020 0x20000021 0x20000022 0x20000023 0x20000024 12 12 RXSTARTED RXDRDY RXD.PTR = 0x20000020 RXD.PTR = 0x20000030 4 STARTRX 3 0x20000001 0x20000002 RXDRDY 11 10 ENDRX 9 RXDRDY RXSTARTED 9 RXDRDY 8 8 RXDRDY 7 ENDRX 6 7 RXDRDY 6 RXDRDY 5 RXDRDY 4 5 STARTRX STARTRX RXD.MAXCNT = 5 RXD.PTR = 0x20000000 4 2 1 ENDRX_STARTRX = 1 3 RXD.PTR = 0x20000010 Lifeline 3 RXDRDY 2 RXSTARTED RXDRDY 1 2 RXDRDY RXD 1 RXDRDY EasyDMA - 0x20000000 Figure 95: UARTE reception The UARTE receiver is stopped by triggering the STOPRX task. An RXTO event is generated when the UARTE has stopped. The UARTE will make sure that an impending ENDRX event will be generated before the RXTO event is generated. This means that the UARTE will guarantee that no ENDRX event will be generated after RXTO, unless the UARTE is restarted or a FLUSHRX command is issued after the RXTO event is generated. Important: If the ENDRX event has not already been generated when the UARTE receiver has come to a stop, which implies that all pending content in the RX FIFO has been moved to the RX buffer, the UARTE will generate the ENDRX event explicitly even though the RX buffer is not full. In this scenario the ENDRX event will be generated before the RXTO event is generated. To be able to know how many bytes have actually been received into the RX buffer, the CPU can read the RXD.AMOUNT register following the ENDRX event or the RXTO event. The UARTE is able to receive up to four bytes after the STOPRX task has been triggered as long as these are sent in succession immediately after the RTS signal is deactivated. This is possible because after the RTS is deactivated the UARTE is able to receive bytes for an extended period equal to the time it takes to send 4 bytes on the configured baud rate. After the RXTO event is generated the internal RX FIFO may still contain data, and to move this data to RAM the FLUSHRX task must be triggered. To make sure that this data does not overwrite data in the RX buffer, the RX buffer should be emptied or the RXD.PTR should be updated before the FLUSHRX task is triggered. Page 335 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA 5 6 6 7 Lifeline 2 1 7 8 8 9 9 11, 12, 13, 14 10 10 11 12 13 3 14 ENDRX 4 5 RXTO 3 4 ENDRX 2 3 RXSTARTED 1 2 ENDRX RXD 1 RXSTARTED EasyDMA To make sure that all data in the RX FIFO is moved to the RX buffer, the RXD.MAXCNT register must be set to RXD.MAXCNT > 4, see Figure 96: UARTE reception with forced stop via STOPRX on page 336. The UARTE will generate the ENDRX event after completing the FLUSHRX task even if the RX FIFO was empty or if the RX buffer does not get filled up. To be able to know how many bytes have actually been received into the RX buffer in this case, the CPU can read the RXD.AMOUNT register following the ENDRX event. 3 4 5 FLUSHRX STOPRX ENDRX_STARTRX = 0 STARTRX RXD.PTR = C STARTRX RXD.PTR = B RXD.PTR = A RXD.MAXCNT = 5 ENDRX_STARTRX = 1 Timeout Figure 96: UARTE reception with forced stop via STOPRX If HW flow control is enabled the RTS signal will be deactivated when the receiver is stopped via the STOPRX task or when the UARTE is only able to receive four more bytes in its internal RX FIFO. With flow control disabled, the UARTE will function in the same way as when the flow control is enabled except that the RTS line will not be used. This means that no signal will be generated when the UARTE has reached the point where it is only able to receive four more bytes in its internal RX FIFO. Data received when the internal RX FIFO is filled up, will be lost. The UARTE receiver will be in its lowest activity level, and consume the least amount of energy, when it is stopped, i.e. before it is started via STARTRX or after it has been stopped via STOPRX and the RXTO event has been generated. See POWER — Power supply on page 78 for more information about power modes. 35.5 Error conditions An ERROR event, in the form of a framing error, will be generated if a valid stop bit is not detected in a frame. Another ERROR event, in the form of a break condition, will be generated if the RXD line is held active low for longer than the length of a data frame. Effectively, a framing error is always generated before a break condition occurs. An ERROR event will not stop reception. If the error was a parity error, the received byte will still be transferred into Data RAM, and so will following incoming bytes. If there was a framing error (wrong stop bit), that specific byte will NOT be stored into Data RAM, but following incoming bytes will. 35.6 Using the UARTE without flow control If flow control is not enabled, the interface will behave as if the CTS and RTS lines are kept active all the time. 35.7 Parity configuration When parity is enabled, the parity will be generated automatically from the even parity of TXD and RXD for transmission and reception respectively. 35.8 Low power When putting the system in low power and the peripheral is not needed, lowest possible power consumption is achieved by stopping, and then disabling the peripheral. Page 336 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA The STOPTX and STOPRX tasks may not be always needed (the peripheral might already be stopped), but if STOPTX and/or STOPRX is sent, software shall wait until the TXSTOPPED and/or RXTO event is received in response, before disabling the peripheral through the ENABLE register. 35.9 Pin configuration The different signals RXD, CTS (Clear To Send, active low), RTS (Request To Send, active low), and TXD associated with the UARTE are mapped to physical pins according to the configuration specified in the PSEL.RXD, PSEL.CTS, PSEL.RTS, and PSEL.TXD registers respectively. The PSEL.RXD, PSEL.CTS, PSEL.RTS, and PSEL.TXD registers and their configurations are only used as long as the UARTE is enabled, and retained only for the duration the device is in ON mode. PSEL.RXD, PSEL.RTS, PSEL.RTS and PSEL.TXD must only be configured when the UARTE is disabled. To secure correct signal levels on the pins by the UARTE when the system is in OFF mode, the pins must be configured in the GPIO peripheral as described in Table 81: GPIO configuration before enabling peripheral on page 337. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. Table 81: GPIO configuration before enabling peripheral UARTE signal RXD CTS RTS TXD UARTE pin As specified in PSEL.RXD As specified in PSEL.CTS As specified in PSEL.RTS As specified in PSEL.TXD Direction Input Input Output Output Output value Not applicable Not applicable 1 1 35.10 Registers Table 82: Instances Base address Peripheral Instance Description 0x40002000 UARTE UARTE0 Universal Asynchronous Receiver/ Configuration Transmitter with EasyDMA Table 83: Register Overview Register Offset Description TASKS_STARTRX 0x000 Start UART receiver TASKS_STOPRX 0x004 Stop UART receiver TASKS_STARTTX 0x008 Start UART transmitter TASKS_STOPTX 0x00C Stop UART transmitter TASKS_FLUSHRX 0x02C Flush RX FIFO into RX buffer EVENTS_CTS 0x100 CTS is activated (set low). Clear To Send. EVENTS_NCTS 0x104 CTS is deactivated (set high). Not Clear To Send. EVENTS_RXDRDY 0x108 Data received in RXD (but potentially not yet transferred to Data RAM) EVENTS_ENDRX 0x110 Receive buffer is filled up EVENTS_TXDRDY 0x11C Data sent from TXD EVENTS_ENDTX 0x120 Last TX byte transmitted EVENTS_ERROR 0x124 Error detected EVENTS_RXTO 0x144 Receiver timeout EVENTS_RXSTARTED 0x14C UART receiver has started EVENTS_TXSTARTED 0x150 UART transmitter has started EVENTS_TXSTOPPED 0x158 Transmitter stopped SHORTS 0x200 Shortcut register INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt Page 337 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Register Offset Description ERRORSRC 0x480 Error source ENABLE 0x500 Enable UART PSEL.RTS 0x508 Pin select for RTS signal PSEL.TXD 0x50C Pin select for TXD signal PSEL.CTS 0x510 Pin select for CTS signal PSEL.RXD 0x514 Pin select for RXD signal BAUDRATE 0x524 Baud rate. Accuracy depends on the HFCLK source selected. RXD.PTR 0x534 Data pointer RXD.MAXCNT 0x538 Maximum number of bytes in receive buffer RXD.AMOUNT 0x53C Number of bytes transferred in the last transaction TXD.PTR 0x544 Data pointer TXD.MAXCNT 0x548 Maximum number of bytes in transmit buffer TXD.AMOUNT 0x54C Number of bytes transferred in the last transaction CONFIG 0x56C Configuration of parity and hardware flow control 35.10.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x00000000 Id RW Field C RW ENDRX_STARTRX 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between ENDRX event and STARTRX task See EVENTS_ENDRX and TASKS_STARTRX D Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW ENDRX_STOPRX Shortcut between ENDRX event and STOPRX task See EVENTS_ENDRX and TASKS_STOPRX Disabled 0 Disable shortcut Enabled 1 Enable shortcut 35.10.2 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L Reset 0x00000000 Id RW Field A RW CTS 0 Value Id J I H Value Description Enable or disable interrupt for CTS event See EVENTS_CTS B Disabled 0 Disable Enabled 1 Enable RW NCTS Enable or disable interrupt for NCTS event See EVENTS_NCTS C Disabled 0 Disable Enabled 1 Enable RW RXDRDY Enable or disable interrupt for RXDRDY event See EVENTS_RXDRDY D G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Disabled 0 Disable Enabled 1 Enable RW ENDRX Enable or disable interrupt for ENDRX event See EVENTS_ENDRX Page 338 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L Reset 0x00000000 Id E RW Field 0 J I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable RW TXDRDY Enable or disable interrupt for TXDRDY event See EVENTS_TXDRDY F Disabled 0 Disable Enabled 1 Enable RW ENDTX Enable or disable interrupt for ENDTX event See EVENTS_ENDTX G Disabled 0 Disable Enabled 1 Enable RW ERROR Enable or disable interrupt for ERROR event See EVENTS_ERROR H Disabled 0 Disable Enabled 1 Enable RW RXTO Enable or disable interrupt for RXTO event See EVENTS_RXTO I Disabled 0 Disable Enabled 1 Enable RW RXSTARTED Enable or disable interrupt for RXSTARTED event See EVENTS_RXSTARTED J Disabled 0 Disable Enabled 1 Enable RW TXSTARTED Enable or disable interrupt for TXSTARTED event See EVENTS_TXSTARTED L Disabled 0 Disable Enabled 1 Enable RW TXSTOPPED Enable or disable interrupt for TXSTOPPED event See EVENTS_TXSTOPPED Disabled 0 Disable Enabled 1 Enable 35.10.3 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L Reset 0x00000000 Id RW Field A RW CTS 0 Value Id J I H G F E Value Description Write '1' to Enable interrupt for CTS event See EVENTS_CTS B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW NCTS Write '1' to Enable interrupt for NCTS event See EVENTS_NCTS C D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXDRDY Write '1' to Enable interrupt for RXDRDY event Page 339 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L Reset 0x00000000 Id RW Field 0 J I H G F E Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_RXDRDY D RW ENDRX Write '1' to Enable interrupt for ENDRX event See EVENTS_ENDRX E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXDRDY Write '1' to Enable interrupt for TXDRDY event See EVENTS_TXDRDY F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDTX Write '1' to Enable interrupt for ENDTX event See EVENTS_ENDTX G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Enable interrupt for ERROR event See EVENTS_ERROR H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXTO Write '1' to Enable interrupt for RXTO event See EVENTS_RXTO I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXSTARTED Write '1' to Enable interrupt for RXSTARTED event See EVENTS_RXSTARTED J Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTARTED Write '1' to Enable interrupt for TXSTARTED event See EVENTS_TXSTARTED L D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTOPPED Write '1' to Enable interrupt for TXSTOPPED event See EVENTS_TXSTOPPED Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 35.10.4 INTENCLR Address offset: 0x308 Disable interrupt Page 340 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L Reset 0x00000000 Id RW Field A RW CTS 0 Value Id J I H G F E Value Description Write '1' to Disable interrupt for CTS event See EVENTS_CTS B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW NCTS Write '1' to Disable interrupt for NCTS event See EVENTS_NCTS C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXDRDY Write '1' to Disable interrupt for RXDRDY event See EVENTS_RXDRDY D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDRX Write '1' to Disable interrupt for ENDRX event See EVENTS_ENDRX E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXDRDY Write '1' to Disable interrupt for TXDRDY event See EVENTS_TXDRDY F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDTX Write '1' to Disable interrupt for ENDTX event See EVENTS_ENDTX G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Disable interrupt for ERROR event See EVENTS_ERROR H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXTO Write '1' to Disable interrupt for RXTO event See EVENTS_RXTO I Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXSTARTED Write '1' to Disable interrupt for RXSTARTED event See EVENTS_RXSTARTED J Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTARTED Write '1' to Disable interrupt for TXSTARTED event See EVENTS_TXSTARTED L D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXSTOPPED Write '1' to Disable interrupt for TXSTOPPED event Page 341 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L Reset 0x00000000 Id RW Field 0 J I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_TXSTOPPED 35.10.5 ERRORSRC Address offset: 0x480 Error source Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C B A Reset 0x00000000 Id RW Field A RW OVERRUN 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Overrun error A start bit is received while the previous data still lies in RXD. (Previous data is lost.) B NotPresent 0 Read: error not present Present 1 Read: error present RW PARITY Parity error A character with bad parity is received, if HW parity check is enabled. C NotPresent 0 Read: error not present Present 1 Read: error present RW FRAMING Framing error occurred A valid stop bit is not detected on the serial data input after all bits in a character have been received. D NotPresent 0 Read: error not present Present 1 Read: error present RW BREAK Break condition The serial data input is '0' for longer than the length of a data frame. (The data frame length is 10 bits without parity bit, and 11 bits with parity bit.). NotPresent 0 Read: error not present Present 1 Read: error present 35.10.6 ENABLE Address offset: 0x500 Enable UART Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable UARTE Enabled 8 Enable UARTE Enable or disable UARTE 35.10.7 PSEL.RTS Address offset: 0x508 Pin select for RTS signal Page 342 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 35.10.8 PSEL.TXD Address offset: 0x50C Pin select for TXD signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 35.10.9 PSEL.CTS Address offset: 0x510 Pin select for CTS signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 35.10.10 PSEL.RXD Address offset: 0x514 Pin select for RXD signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 35.10.11 BAUDRATE Address offset: 0x524 Baud rate. Accuracy depends on the HFCLK source selected. Page 343 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x04000000 Id RW Field A RW BAUDRATE 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Baud1200 0x0004F000 1200 baud (actual rate: 1205) Baud2400 0x0009D000 2400 baud (actual rate: 2396) Baud4800 0x0013B000 4800 baud (actual rate: 4808) Baud9600 0x00275000 9600 baud (actual rate: 9598) Baud14400 0x003AF000 14400 baud (actual rate: 14401) Baud19200 0x004EA000 19200 baud (actual rate: 19208) Baud28800 0x0075C000 28800 baud (actual rate: 28777) Baud38400 0x009D0000 38400 baud (actual rate: 38369) Baud57600 0x00EB0000 57600 baud (actual rate: 57554) Baud76800 0x013A9000 76800 baud (actual rate: 76923) Baud115200 0x01D60000 115200 baud (actual rate: 115108) Baud230400 0x03B00000 230400 baud (actual rate: 231884) Baud250000 0x04000000 250000 baud Baud460800 0x07400000 460800 baud (actual rate: 457143) Baud921600 0x0F000000 921600 baud (actual rate: 941176) Baud1M 0x10000000 1Mega baud Baud rate 35.10.12 RXD.PTR Address offset: 0x534 Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Data pointer 35.10.13 RXD.MAXCNT Address offset: 0x538 Maximum number of bytes in receive buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in receive buffer 35.10.14 RXD.AMOUNT Address offset: 0x53C Number of bytes transferred in the last transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last transaction 35.10.15 TXD.PTR Address offset: 0x544 Data pointer Page 344 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Data pointer 35.10.16 TXD.MAXCNT Address offset: 0x548 Maximum number of bytes in transmit buffer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of bytes in transmit buffer 35.10.17 TXD.AMOUNT Address offset: 0x54C Number of bytes transferred in the last transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of bytes transferred in the last transaction 35.10.18 CONFIG Address offset: 0x56C Configuration of parity and hardware flow control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B A Reset 0x00000000 Id RW Field A RW HWFC B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disabled Enabled 1 Enabled Excluded 0x0 Exclude parity bit Included 0x7 Include parity bit Hardware flow control RW PARITY Parity 35.11 Electrical specification 35.11.1 UARTE electrical specification Symbol Description fUARTE Baud rate for UARTE32. IUARTE1M Run current at max baud rate. 55 µA IUARTE115k Run current at 115200 bps. 55 µA IUARTE1k2 Run current at 1200 bps. 55 µA IUARTE,IDLE Idle current for UARTE (STARTed, no XXX activity) 1 µA tUARTE,CTSH CTS high time 32 Min. Typ. Max. Units 1000 kbps 1 Higher baud rates may require GPIOs to be set as High Drive, see GPIO chapter for more details. Page 345 µs 35 UARTE — Universal asynchronous receiver/ transmitter with EasyDMA Symbol Description tUARTE,START,LP Time from STARTRX/STARTTX task to transmission started, low Min. Typ. tUARTE,START,CL Max. power mode + Units µs tSTART_HFINT tUARTE,START,CL Time from STARTRX/STARTTX task to transmission started, constant latency mode Page 346 1 µs 36 QDEC — Quadrature decoder 36 QDEC — Quadrature decoder The Quadrature decoder (QDEC) provides buffered decoding of quadrature-encoded sensor signals. It is suitable for mechanical and optical sensors. The sample period and accumulation are configurable to match application requirements. The QDEC provides the following: • • • • Decoding of digital waveform from off-chip quadrature encoder. Sample accumulation eliminating hard real-time requirements to be enforced on application. Optional input de-bounce filters. Optional LED output signal for optical encoders. ACCREAD ACCDBLREAD ACC ACCDBL + + SAMPLE Quadrature decoder IO router On-chip Off-chip Phase A Phase B LED Mechanical to electrical Mechanical device Quadrature Encoder Figure 97: Quadrature decoder configuration 36.1 Sampling and decoding The QDEC decodes the output from an incremental motion encoder by sampling the QDEC phase input pins (A and B). The off-chip quadrature encoder is an incremental motion encoder outputting two waveforms, phase A and phase B. The two output waveforms are always 90 degrees out of phase, meaning that one always changes level before the other. The direction of movement is indicated by which of these two waveforms that changes level first. Invalid transitions may occur, that is when the two waveforms switch simultaneously. This may occur if the wheel rotates too fast relative to the sample rate set for the decoder. Page 347 36 QDEC — Quadrature decoder The QDEC decodes the output from the off-chip encoder by sampling the QDEC phase input pins (A and B) at a fixed rate as specified in the SAMPLEPER register. If the SAMPLEPER value needs to be changed, the QDEC shall be stopped using the STOP task. SAMPLEPER can be then changed upon receiving the STOPPED event, and QDEC can be restarted using the START task. Failing to do so may result in unpredictable behaviour. It is good practice to change other registers (LEDPOL, REPORTPER, DBFEN and LEDPRE) only when the QDEC is stopped. When started, the decoder continuously samples the two input waveforms and decodes these by comparing the current sample pair (n) with the previous sample pair (n-1). The decoding of the sample pairs is described in the table below. Table 84: Sampled value encoding Previous sample pair(n - 1) A B 0 0 0 0 0 0 0 0 0 1 0 1 0 1 0 1 1 0 1 0 1 0 1 0 1 1 1 1 1 1 1 1 Current SAMPLE samples pair(n) register ACC operation ACCDBL operation Description A 0 0 1 1 0 0 1 1 0 0 1 1 0 0 1 1 No change Increment Decrement No change Decrement No change No change Increment Increment No change No change Decrement No change Decrement Increment No change No movement Movement in positive direction Movement in negative direction Error: Double transition Movement in negative direction No movement Error: Double transition Movement in positive direction Movement in positive direction Error: Double transition No movement Movement in negative direction Error: Double transition Movement in negative direction Movement in positive direction No movement B 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 0 1 -1 2 -1 0 2 1 1 2 0 -1 2 -1 1 0 No change No change No change Increment No change No change Increment No change No change Increment No change No change Increment No change No change No change 36.2 LED output The LED output follows the sample period, and the LED is switched on a given period before sampling and switched off immediately after the inputs are sampled. The period the LED is switched on before sampling is given in the LEDPRE register. The LED output pin polarity is specified in the LEDPOL register. For using off-chip mechanical encoders not requiring a LED, the LED output can be disabled by writing value 'Disconnected' to the CONNECT field of the PSEL.LED register. In this case the QDEC will not acquire access to a LED output pin and the pin can be used for other purposes by the CPU. 36.3 Debounce filters Each of the two-phase inputs have digital debounce filters. When enabled through the DBFEN register, the filter inputs are sampled at a fixed 1 MHz frequency during the entire sample period (which is specified in the SAMPLEPER register), and the filters require all of the samples within this sample period to equal before the input signal is accepted and transferred to the output of the filter. As a result, only input signal with a steady state longer than twice the period specified in SAMPLEPER are guaranteed to pass through the filter, and any signal with a steady state shorter than SAMPLEPER will always be suppressed by the filter. (This is assumed that the frequency during the debounce period never exceeds 500 kHz (as required by the Nyquist theorem when using a 1 MHz sample frequency). The LED will always be ON when the debounce filters are enabled, as the inputs in this case will be sampled continuously. Page 348 36 QDEC — Quadrature decoder Note that when when the debounce filters are enabled, displacements reported by the QDEC peripheral are delayed by one SAMPLEPER period. 36.4 Accumulators The quadrature decoder contains two accumulator registers, ACC and ACCDBL, that accumulate respectively valid motion sample values and the number of detected invalid samples (double transitions). The ACC register will accumulate all valid values (1/-1) written to the SAMPLE register. This can be useful for preventing hard real-time requirements from being enforced on the application. When using the ACC register the application does not need to read every single sample from the SAMPLE register, but can instead fetch the ACC register whenever it fits the application. The ACC register will always hold the relative movement of the external mechanical device since the previous clearing of the ACC register. Sample values indicating a double transition (2) will not be accumulated in the ACC register. An ACCOF event will be generated if the ACC receives a SAMPLE value that would cause the register to overflow or underflow. Any SAMPLE value that would cause an ACC overflow or underflow will be discarded, but any samples not causing the ACC to overflow or underflow will still be accepted. The accumulator ACCDBL accumulates the number of detected double transitions since the previous clearing of the ACCDBL register. The ACC and ACCDBL registers can be cleared by the READCLRACC and subsequently read using the ACCREAD and ACCDBLREAD registers. The ACC register can be separately cleared by the RDCLRACC and subsequently read using the ACCREAD registers. The ACCDBL register can be separately cleared by the RDCLRDBL and subsequently read using the ACCDBLREAD registers. The REPORTPER register allows automating the capture of several samples before it can send out a REPORTRDY event in case a non-null displacement has been captured and accumulated, and a DBLRDY event in case one or more double-displacements have been captured and accumulated. The REPORTPER field in this register selects after how many samples the accumulators contents are evaluated to send (or not) REPORTRDY and DBLRDY events. Using the RDCLRACC task (manually sent upon receiving the event, or using the DBLRDY_RDCLRACC shortcut), ACCREAD can then be read. In case at least one double transition has been captured and accumulated, a DBLRDY event is sent. Using the RDCLRDBL task (manually sent upon receiving the event, or using the DBLRDY_RDCLRDBL shortcut), ACCDBLREAD can then be read. 36.5 Output/input pins The QDEC uses a three-pin interface to the off-chip quadrature encoder. These pins will be acquired when the QDEC is enabled in the ENABLE register. The pins acquired by the QDEC cannot be written by the CPU, but they can still be read by the CPU. The pin numbers to be used for the QDEC are selected using the PSEL.n registers. 36.6 Pin configuration The Phase A, Phase B, and LED signals are mapped to physical pins according to the configuration specified in the PSEL.A, PSEL.B, and PSEL.LED registers respectively. If the CONNECT field value 'Disconnected' is specified in any of these registers, the associated signal will not be connected to any physical pin. The PSEL.A, PSEL.B, and PSEL.LED registers and their configurations are only used as long as the QDEC is enabled, and retained only as long as the device is in Page 349 36 QDEC — Quadrature decoder ON mode. When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. To secure correct behavior in the QDEC, the pins used by the QDEC must be configured in the GPIO peripheral as described in Table 85: GPIO configuration before enabling peripheral on page 350 before enabling the QDEC. This configuration must be retained in the GPIO for the selected IOs as long as the QDEC is enabled. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. Table 85: GPIO configuration before enabling peripheral QDEC signal Phase A Phase B LED QDEC pin As specified in PSEL.A As specified in PSEL.B As specified in PSEL.LED Direction Input Input Input Output value Not applicable Not applicable Not applicable Comment 36.7 Registers Table 86: Instances Base address Peripheral Instance Description 0x40012000 QDEC QDEC Quadrature decoder Configuration Table 87: Register Overview Register Offset Description TASKS_START 0x000 Task starting the quadrature decoder TASKS_STOP 0x004 Task stopping the quadrature decoder TASKS_READCLRACC 0x008 Read and clear ACC and ACCDBL TASKS_RDCLRACC 0x00C Read and clear ACC TASKS_RDCLRDBL 0x010 Read and clear ACCDBL EVENTS_SAMPLERDY 0x100 Event being generated for every new sample value written to the SAMPLE register EVENTS_REPORTRDY 0x104 Non-null report ready EVENTS_ACCOF 0x108 ACC or ACCDBL register overflow EVENTS_DBLRDY 0x10C Double displacement(s) detected EVENTS_STOPPED 0x110 QDEC has been stopped SHORTS 0x200 Shortcut register INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 Enable the quadrature decoder LEDPOL 0x504 LED output pin polarity SAMPLEPER 0x508 Sample period SAMPLE 0x50C Motion sample value REPORTPER 0x510 Number of samples to be taken before REPORTRDY and DBLRDY events can be generated ACC 0x514 Register accumulating the valid transitions ACCREAD 0x518 Snapshot of the ACC register, updated by the READCLRACC or RDCLRACC task PSEL.LED 0x51C Pin select for LED signal PSEL.A 0x520 Pin select for A signal PSEL.B 0x524 Pin select for B signal DBFEN 0x528 Enable input debounce filters LEDPRE 0x540 Time period the LED is switched ON prior to sampling ACCDBL 0x544 Register accumulating the number of detected double transitions ACCDBLREAD 0x548 Snapshot of the ACCDBL, updated by the READCLRACC or RDCLRDBL task 36.7.1 SHORTS Address offset: 0x200 Shortcut register Page 350 36 QDEC — Quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G F E D C B A Reset 0x00000000 Id RW Field A RW REPORTRDY_READCLRACC 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between REPORTRDY event and READCLRACC task See EVENTS_REPORTRDY and TASKS_READCLRACC B Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW SAMPLERDY_STOP Shortcut between SAMPLERDY event and STOP task See EVENTS_SAMPLERDY and TASKS_STOP C Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW REPORTRDY_RDCLRACC Shortcut between REPORTRDY event and RDCLRACC task See EVENTS_REPORTRDY and TASKS_RDCLRACC D Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW REPORTRDY_STOP Shortcut between REPORTRDY event and STOP task See EVENTS_REPORTRDY and TASKS_STOP E Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW DBLRDY_RDCLRDBL Shortcut between DBLRDY event and RDCLRDBL task See EVENTS_DBLRDY and TASKS_RDCLRDBL F Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW DBLRDY_STOP Shortcut between DBLRDY event and STOP task See EVENTS_DBLRDY and TASKS_STOP G Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW SAMPLERDY_READCLRACC Shortcut between SAMPLERDY event and READCLRACC task See EVENTS_SAMPLERDY and TASKS_READCLRACC Disabled 0 Disable shortcut Enabled 1 Enable shortcut 36.7.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E D C B A Reset 0x00000000 Id RW Field A RW SAMPLERDY 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for SAMPLERDY event See EVENTS_SAMPLERDY B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REPORTRDY Write '1' to Enable interrupt for REPORTRDY event See EVENTS_REPORTRDY C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ACCOF Write '1' to Enable interrupt for ACCOF event See EVENTS_ACCOF Set 1 Enable Page 351 36 QDEC — Quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E D C B A Reset 0x00000000 Id D RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DBLRDY Write '1' to Enable interrupt for DBLRDY event See EVENTS_DBLRDY E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 36.7.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E D C B A Reset 0x00000000 Id RW Field A RW SAMPLERDY 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for SAMPLERDY event See EVENTS_SAMPLERDY B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REPORTRDY Write '1' to Disable interrupt for REPORTRDY event See EVENTS_REPORTRDY C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ACCOF Write '1' to Disable interrupt for ACCOF event See EVENTS_ACCOF D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DBLRDY Write '1' to Disable interrupt for DBLRDY event See EVENTS_DBLRDY E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Disable interrupt for STOPPED event See EVENTS_STOPPED Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 36.7.4 ENABLE Address offset: 0x500 Enable the quadrature decoder Page 352 36 QDEC — Quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ENABLE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable the quadrature decoder When enabled the decoder pins will be active. When disabled the quadrature decoder pins are not active and can be used as GPIO . Disabled 0 Disable Enabled 1 Enable 36.7.5 LEDPOL Address offset: 0x504 LED output pin polarity Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW LEDPOL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description ActiveLow 0 Led active on output pin low ActiveHigh 1 Led active on output pin high LED output pin polarity 36.7.6 SAMPLEPER Address offset: 0x508 Sample period Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW SAMPLEPER 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Sample period. The SAMPLE register will be updated for every new sample 128us 0 128 us 256us 1 256 us 512us 2 512 us 1024us 3 1024 us 2048us 4 2048 us 4096us 5 4096 us 8192us 6 8192 us 16384us 7 16384 us 32ms 8 32768 us 65ms 9 65536 us 131ms 10 131072 us 36.7.7 SAMPLE Address offset: 0x50C Motion sample value Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R SAMPLE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [-1..2] Last motion sample Page 353 36 QDEC — Quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description The value is a 2's complement value, and the sign gives the direction of the motion. The value '2' indicates a double transition. 36.7.8 REPORTPER Address offset: 0x510 Number of samples to be taken before REPORTRDY and DBLRDY events can be generated Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW REPORTPER 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Specifies the number of samples to be accumulated in the ACC register before the REPORTRDY and DBLRDY events can be generated The report period in [us] is given as: RPUS = SP * RP Where RPUS is the report period in [us/report], SP is the sample period in [us/sample] specified in SAMPLEPER, and RP is the report period in [samples/report] specified in REPORTPER . 10Smpl 0 10 samples / report 40Smpl 1 40 samples / report 80Smpl 2 80 samples / report 120Smpl 3 120 samples / report 160Smpl 4 160 samples / report 200Smpl 5 200 samples / report 240Smpl 6 240 samples / report 280Smpl 7 280 samples / report 1Smpl 8 1 sample / report 36.7.9 ACC Address offset: 0x514 Register accumulating the valid transitions Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R ACC 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [-1024..1023] Register accumulating all valid samples (not double transition) read from the SAMPLE register Double transitions ( SAMPLE = 2 ) will not be accumulated in this register. The value is a 32 bit 2's complement value. If a sample that would cause this register to overflow or underflow is received, the sample will be ignored and an overflow event ( ACCOF ) will be generated. The ACC register is cleared by triggering the READCLRACC or the RDCLRACC task. 36.7.10 ACCREAD Address offset: 0x518 Snapshot of the ACC register, updated by the READCLRACC or RDCLRACC task Page 354 36 QDEC — Quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id ACCREAD 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [-1024..1023] Snapshot of the ACC register. The ACCREAD register is updated when the READCLRACC or RDCLRACC task is triggered 36.7.11 PSEL.LED Address offset: 0x51C Pin select for LED signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 36.7.12 PSEL.A Address offset: 0x520 Pin select for A signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 36.7.13 PSEL.B Address offset: 0x524 Pin select for B signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 36.7.14 DBFEN Address offset: 0x528 Enable input debounce filters Page 355 36 QDEC — Quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW DBFEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Debounce input filters disabled Enabled 1 Debounce input filters enabled Enable input debounce filters 36.7.15 LEDPRE Address offset: 0x540 Time period the LED is switched ON prior to sampling Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A Reset 0x00000010 Id RW Field A RW LEDPRE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 Value Description [1..511] Period in us the LED is switched on prior to sampling 36.7.16 ACCDBL Address offset: 0x544 Register accumulating the number of detected double transitions Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A R 0 Value Id ACCDBL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..15] Register accumulating the number of detected double or illegal transitions. ( SAMPLE = 2 ). When this register has reached its maximum value the accumulation of double / illegal transitions will stop. An overflow event ( ACCOF ) will be generated if any double or illegal transitions are detected after the maximum value was reached. This field is cleared by triggering the READCLRACC or RDCLRDBL task. 36.7.17 ACCDBLREAD Address offset: 0x548 Snapshot of the ACCDBL, updated by the READCLRACC or RDCLRDBL task Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A R 0 Value Id ACCDBLREAD 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..15] Snapshot of the ACCDBL register. This field is updated when the READCLRACC or RDCLRDBL task is triggered. 36.8 Electrical specification 36.8.1 QDEC Electrical Specification Symbol Description IQDEC Run current Min. Typ. Max. tSAMPLE Time between sampling signals from quadrature decoder 128 131072 µs tLED Time from LED is turned on to signals are sampled 0 511 µs 5 Page 356 Units µA 37 SAADC — Successive approximation analogto-digital converter 37 SAADC — Successive approximation analog-todigital converter The ADC is a differential successive approximation register (SAR) analog-to-digital converter. Listed here are the main features of SAADC: • • • • • • • • • • • • 8/10/12-bit resolution, 14-bit resolution with oversampling Up to eight input channels • One channel per single-ended input and two channels per differential input • Scan mode can be configured with both single-ended channels and differential channels. Full scale input range (0 to VDD) Sampling triggered via a task from software or a PPI channel for full flexibility on sample frequency source from low power 32.768kHz RTC or more accurate 1/16MHz Timers One-shot conversion mode to sample a single channel Scan mode to sample a series of channels in sequence. Sample delay between channels is tack + tconv which may vary between channels according to user configuration of tack. Support for direct sample transfer to RAM using EasyDMA Interrupts on single sample and full buffer events Samples stored as 16-bit 2’s complement values for differential and single-ended sampling Continuous sampling without the need of an external timer Internal resistor string Limit checking on the fly 37.1 Shared resources The ADC can coexist with COMP and other peripherals using one of AIN0-AIN7, provided these are assigned to different pins. It is not recommended to select the same analog input pin for both modules. 37.2 Overview The ADC supports up to eight external analog input channels, depending on package variant. It can be operated in a one-shot mode with sampling under software control, or a continuous conversion mode with a programmable sampling rate. The analog inputs can be configured as eight single-ended inputs, four differential inputs or a combination of these. Each channel can be configured to select AIN0 to AIN7 pins, or the VDD pin. Channels can be sampled individually in one-shot or continuous sampling modes, or, using scan mode, multiple channels can be sampled in sequence. Channels can also be oversampled to improve noise performance. Page 357 37 SAADC — Successive approximation analogto-digital converter PSEL_A PSEL_A PSEL_A PSEL_A PSEL_A PSEL_A CH[X].CONFIG PSEL_A PSEL_A PSEL_A PSEL_A PSEL_A PSEL_A CH[X].PSELP NC AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 VDD NC AIN0 AIN1 AIN2 AIN3 AIN4 AIN5 AIN6 AIN7 VDD ADC RAM MUX RESULT P RESP RESULT SAR core GAIN RESULT EasyDMA RESULT RESULT RESULT N RESN RESULT RESULT MUX RESULT.PTR START SAMPLE VDD Internal reference REFSEL STARTED END STOPPED STOP CH[X].PSELN PSEL_A PSEL_A PSEL_A PSEL_A PSEL_A PSEL_A Figure 98: Simplified ADC block diagram Internally, the ADC is always a differential analog-to-digital converter, but by default it is configured with single-ended input in the MODE field of the CH[n].CONFIG register. In single-ended mode, the negative input will be shorted to ground internally. The assumption in single-ended mode is that the internal ground of the ADC is the same as the external ground that the measured voltage is referred to. The ADC is thus sensitive to ground bounce on the PCB in single-ended mode. If this is a concern we recommend using differential measurement. 37.3 Digital output The output result of the ADC depends on the settings in the CH[n].CONFIG and RESOLUTION registers as follows: RESULT = [V(P) – V(N) ] * GAIN/REFERENCE * 2(RESOLUTION - m) where V(P) is the voltage at input P V(N) is the voltage at input N GAIN is the selected gain setting REFERENCE is the selected reference voltage and m=0 if CONFIG.MODE=SE, or m=1 if CONFIG.MODE=Diff. The result generated by the ADC will deviate from the expected due DC errors like offset, gain, differential non-linearity (DNL), and integral non-linearity (INL). See Electrical specification for details on these parameters. The result can also vary due to AC errors like non-linearities in the GAIN block, settling errors due to high source impedance and sampling jitter. For battery measurement the DC errors are most noticeable. Page 358 37 SAADC — Successive approximation analogto-digital converter The ADC has a wide selection of gains controlled in the GAIN field of the CH[n].CONFIG register. If CH[n].CONFIG.REFSEL=0, the input range of the ADC core is nominally ±0.6 V differential and the input must be scaled accordingly. The ADC has a temperature dependent offset. If the ADC is to operate over a large temperature range, we recommend running CALIBRATEOFFSET at regular intervals, a CALIBRATEDONE event will be fired when the calibration is complete 37.4 Analog inputs and channels Up to eight analog input channels, CH[n](n=0..7), can be configured. See Shared resources on page 357 for shared input with comparators. Any one of the available channels can be enabled for the ADC to operate in one-shot mode. If more than one CH[n] is configured, the ADC enters scan mode. An analog input is selected as a positive converter input if CH[n].PSELP is set, setting CH[n].PSELP also enables the particular channel. An analog input is selected as a negative converter input if CH[n].PSELN is set. The CH[n].PSELN register will have no effect unless differential mode is enabled, see MODE field in CH[n].CONFIG register. If more than one of the CH[n].PSELP registers is set, the device enters scan mode. Input selections in scan mode are controlled by the CH[n].PSELP and CH[n].PSELN registers, where CH[n].PSELN is only used if the particular scan channel is specified as differential, see MODE field in CH[n].CONFIG register. Important: Channels selected for COMP cannot be used at the same time for ADC sampling, though channels not selected for use by these blocks can be used by the ADC. Table 88: Legal connectivity CH[n] vs. analog input Channel input CH[n].PSELP CH[n].PSELP CH[n].PSELN CH[n].PSELN Source AIN0…AIN7 VDD AIN0…AIN7 VDD Connectivity Yes(any) Yes Yes(any) Yes 37.5 Operation modes The ADC input configuration supports one-shot mode, continuous mode and scan mode. Scan mode and oversampling cannot be combined. 37.5.1 One-shot mode One-shot operation is configured by enabling only one of the available channels defined by CH[n].PSELP, CH[n].PSELN, and CH[n].CONFIG registers. Upon a SAMPLE task, the ADC starts to sample the input voltage. The CH[n].CONFIG.TACQ controls the acquisition time. A DONE event signals that one sample has been taken. In this mode, the RESULTDONE event has the same meaning as DONE when no oversampling takes place. Note that both events may occur before the actual value has been transferred into RAM by EasyDMA. For more information, see EasyDMA on page 361. 37.5.2 Continuous mode Continuous sampling can be achieved by using the internal timer in the ADC, or triggering the SAMPLE task from one of the general purpose timers through the PPI. Care shall be taken to ensure that the sample rate fulfils the following criteria, depending on how many channels are active: fSAMPLE < 1/[tACQ + tconv] Page 359 37 SAADC — Successive approximation analogto-digital converter The SAMPLERATE register can be used as a local timer instead of triggering individual SAMPLE tasks. When SAMPLERATE.MODE is set to Timers, it is sufficient to trigger SAMPLE task only once in order to start the SAADC and triggering the STOP task will stop sampling. The SAMPLERATE.CC field controls the sample rate. The SAMPLERATE timer mode cannot be combined with SCAN mode, and only one channel can be enabled in this mode. A DONE event signals that one sample has been taken. In this mode, the RESULTDONE event has the same meaning as DONE when no oversampling takes place. Note that both events may occur before the actual value has been transferred into RAM by EasyDMA. 37.5.3 Oversampling An accumulator in the ADC can be used to average noise on the analog input. In general, oversampling improves the signal-to-noise ratio (SNR). Oversampling, however, does not improve the integral non-linearity (INL), or differential non-linearity (DNL). Oversampling and scan should not be combined, since oversampling and scan will average over input channels. The accumulator is controlled in the OVERSAMPLE register. The SAMPLE task must be set 2 number of times before the result is written to RAM. This can be achieved by: • • • OVERSAMPLE Configuring a fixed sampling rate using the local timer or a general purpose timer and PPI to trigger a SAMPLE task OVERSAMPLE Triggering SAMPLE 2 times from software Enabling BURST mode OVERSAMPLE CH[n].CONFIG.BURST can be enabled to avoid setting SAMPLE task 2 times. With OVERSAMPLE BURST = 1 the ADC will sample the input 2 times as fast as it can (actual timing: OVERSAMPLE = "number of channels enabled". See Scan mode on page 360 for more information about Scan mode. 37.7 Resistor ladder The ADC has an internal resistor string for positive and negative input. See Figure 102: Resistor ladder for positive input (negative input is equivalent, using RESN instead of RESP) on page 363. The resistors are controlled in the CH[n].CONFIG.RESP and CH[n].CONFIG.RESN registers. Page 362 37 SAADC — Successive approximation analogto-digital converter RESP = Pullup R Output Input R RESP = Pulldown Figure 102: Resistor ladder for positive input (negative input is equivalent, using RESN instead of RESP) 37.8 Reference The ADC can use two different references, controlled in the REFSEL field of the CH[n].CONFIG register. These are: • • Internal reference VDD as reference The internal reference results in an input range of ±0.6 V on the ADC core. VDD as reference results in an input range of ±VDD/4 on the ADC core. The gain block can be used to change the effective input range of the ADC. Input range = (+- 0.6 V or +-VDD/4)/Gain For example, choosing VDD as reference, single ended input (grounded negative input), and a gain of 1/4 the input range will be: Input range = (VDD/4)/(1/4) = VDD With internal reference, single ended input (grounded negative input), and a gain of 1/6 the input range will be: Input range = (0.6 V)/(1/6) = 3.6 V The AIN0-AIN7 inputs cannot exceed VDD, or be lower than VSS. 37.9 Acquisition time To sample the input voltage, the ADC connects a capacitor to the input. For illustration, see Figure 103: Simplified ADC sample network on page 364. The acquisition time indicates how long the capacitor is connected, see TACQ field in CH[n].CONFIG register. The required acquisition time depends on the source (Rsource) resistance. For high source resistance the acquisition time should be increased, see Table 89: Acquisition time on page 364. Page 363 37 SAADC — Successive approximation analogto-digital converter ADC Rsource TACQ Figure 103: Simplified ADC sample network Table 89: Acquisition time TACQ [µs] 3 5 10 15 20 40 Maximum source resistance [kOhm] 10 40 100 200 400 800 37.10 Limits event monitoring A channel can be event monitored by configuring limit register CH[n].LIMIT. If the conversion result is higher than the defined high limit, or lower than the defined low limit, the appropriate event will get fired. VIN CH[n].LIMIT.HIGH CH[n].LIMIT.LOW t EVENTS_CH[n].LIMITL EVENTS_CH[n].LIMITH EVENTS_CH[n].LIMITH EVENTS_CH[n].LIMITH events Figure 104: Example of limits monitoring on channel 'n' Note that when setting the limits, CH[n].LIMIT.HIGH shall always be higher than or equal to CH[n].LIMIT.LOW . In other words, an event can be fired only when the input signal has been sampled Page 364 37 SAADC — Successive approximation analogto-digital converter outside of the defined limits. It is not possible to fire an event when the input signal is inside a defined range by swapping high and low limits. The comparison to limits always takes place, there is no need to enable it. If comparison is not required on a channel, the software shall simply ignore the related events. In that situation, the value of the limits registers is irrelevant, so it does not matter if CH[n].LIMIT.LOW is lower than CH[n].LIMIT.HIGH or not. 37.11 Registers Table 90: Instances Base address Peripheral Instance Description 0x40007000 SAADC SAADC Analog to digital converter Configuration Table 91: Register Overview Register Offset Description TASKS_START 0x000 Start the ADC and prepare the result buffer in RAM TASKS_SAMPLE 0x004 Take one ADC sample, if scan is enabled all channels are sampled TASKS_STOP 0x008 Stop the ADC and terminate any on-going conversion TASKS_CALIBRATEOFFSET0x00C Starts offset auto-calibration EVENTS_STARTED 0x100 The ADC has started EVENTS_END 0x104 The ADC has filled up the Result buffer EVENTS_DONE 0x108 A conversion task has been completed. Depending on the mode, multiple conversions might be EVENTS_RESULTDONE 0x10C needed for a result to be transferred to RAM. A result is ready to get transferred to RAM. EVENTS_CALIBRATEDONE0x110 Calibration is complete EVENTS_STOPPED 0x114 The ADC has stopped EVENTS_CH[0].LIMITH 0x118 Last results is equal or above CH[0].LIMIT.HIGH EVENTS_CH[0].LIMITL 0x11C Last results is equal or below CH[0].LIMIT.LOW EVENTS_CH[1].LIMITH 0x120 Last results is equal or above CH[1].LIMIT.HIGH EVENTS_CH[1].LIMITL 0x124 Last results is equal or below CH[1].LIMIT.LOW EVENTS_CH[2].LIMITH 0x128 Last results is equal or above CH[2].LIMIT.HIGH EVENTS_CH[2].LIMITL 0x12C Last results is equal or below CH[2].LIMIT.LOW EVENTS_CH[3].LIMITH 0x130 Last results is equal or above CH[3].LIMIT.HIGH EVENTS_CH[3].LIMITL 0x134 Last results is equal or below CH[3].LIMIT.LOW EVENTS_CH[4].LIMITH 0x138 Last results is equal or above CH[4].LIMIT.HIGH EVENTS_CH[4].LIMITL 0x13C Last results is equal or below CH[4].LIMIT.LOW EVENTS_CH[5].LIMITH 0x140 Last results is equal or above CH[5].LIMIT.HIGH EVENTS_CH[5].LIMITL 0x144 Last results is equal or below CH[5].LIMIT.LOW EVENTS_CH[6].LIMITH 0x148 Last results is equal or above CH[6].LIMIT.HIGH EVENTS_CH[6].LIMITL 0x14C Last results is equal or below CH[6].LIMIT.LOW EVENTS_CH[7].LIMITH 0x150 Last results is equal or above CH[7].LIMIT.HIGH EVENTS_CH[7].LIMITL 0x154 Last results is equal or below CH[7].LIMIT.LOW INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt STATUS 0x400 Status ENABLE 0x500 Enable or disable ADC CH[0].PSELP 0x510 Input positive pin selection for CH[0] CH[0].PSELN 0x514 Input negative pin selection for CH[0] CH[0].CONFIG 0x518 Input configuration for CH[0] CH[0].LIMIT 0x51C High/low limits for event monitoring a channel CH[1].PSELP 0x520 Input positive pin selection for CH[1] CH[1].PSELN 0x524 Input negative pin selection for CH[1] CH[1].CONFIG 0x528 Input configuration for CH[1] CH[1].LIMIT 0x52C High/low limits for event monitoring a channel CH[2].PSELP 0x530 Input positive pin selection for CH[2] Page 365 37 SAADC — Successive approximation analogto-digital converter Register Offset Description CH[2].PSELN 0x534 Input negative pin selection for CH[2] CH[2].CONFIG 0x538 Input configuration for CH[2] CH[2].LIMIT 0x53C High/low limits for event monitoring a channel CH[3].PSELP 0x540 Input positive pin selection for CH[3] CH[3].PSELN 0x544 Input negative pin selection for CH[3] CH[3].CONFIG 0x548 Input configuration for CH[3] CH[3].LIMIT 0x54C High/low limits for event monitoring a channel CH[4].PSELP 0x550 Input positive pin selection for CH[4] CH[4].PSELN 0x554 Input negative pin selection for CH[4] CH[4].CONFIG 0x558 Input configuration for CH[4] CH[4].LIMIT 0x55C High/low limits for event monitoring a channel CH[5].PSELP 0x560 Input positive pin selection for CH[5] CH[5].PSELN 0x564 Input negative pin selection for CH[5] CH[5].CONFIG 0x568 Input configuration for CH[5] CH[5].LIMIT 0x56C High/low limits for event monitoring a channel CH[6].PSELP 0x570 Input positive pin selection for CH[6] CH[6].PSELN 0x574 Input negative pin selection for CH[6] CH[6].CONFIG 0x578 Input configuration for CH[6] CH[6].LIMIT 0x57C High/low limits for event monitoring a channel CH[7].PSELP 0x580 Input positive pin selection for CH[7] CH[7].PSELN 0x584 Input negative pin selection for CH[7] CH[7].CONFIG 0x588 Input configuration for CH[7] CH[7].LIMIT 0x58C High/low limits for event monitoring a channel RESOLUTION 0x5F0 Resolution configuration OVERSAMPLE 0x5F4 Oversampling configuration. OVERSAMPLE should not be combined with SCAN. The RESOLUTION is SAMPLERATE 0x5F8 Controls normal or continuous sample rate RESULT.PTR 0x62C Data pointer RESULT.MAXCNT 0x630 Maximum number of buffer words to transfer RESULT.AMOUNT 0x634 Number of buffer words transferred since last START applied before averaging, thus for high OVERSAMPLE a higher RESOLUTION should be used. 37.11.1 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id RW Field A RW STARTED 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for STARTED event See EVENTS_STARTED B Disabled 0 Disable Enabled 1 Enable RW END Enable or disable interrupt for END event See EVENTS_END C Disabled 0 Disable Enabled 1 Enable RW DONE Enable or disable interrupt for DONE event See EVENTS_DONE D Disabled 0 Disable Enabled 1 Enable RW RESULTDONE Enable or disable interrupt for RESULTDONE event See EVENTS_RESULTDONE Disabled 0 Disable Enabled 1 Enable Page 366 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id RW Field E RW CALIBRATEDONE 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for CALIBRATEDONE event See EVENTS_CALIBRATEDONE F Disabled 0 Disable Enabled 1 Enable RW STOPPED Enable or disable interrupt for STOPPED event See EVENTS_STOPPED G Disabled 0 Disable Enabled 1 Enable RW CH0LIMITH Enable or disable interrupt for CH[0].LIMITH event See EVENTS_CH[0].LIMITH H Disabled 0 Disable Enabled 1 Enable RW CH0LIMITL Enable or disable interrupt for CH[0].LIMITL event See EVENTS_CH[0].LIMITL I Disabled 0 Disable Enabled 1 Enable RW CH1LIMITH Enable or disable interrupt for CH[1].LIMITH event See EVENTS_CH[1].LIMITH J Disabled 0 Disable Enabled 1 Enable RW CH1LIMITL Enable or disable interrupt for CH[1].LIMITL event See EVENTS_CH[1].LIMITL K Disabled 0 Disable Enabled 1 Enable RW CH2LIMITH Enable or disable interrupt for CH[2].LIMITH event See EVENTS_CH[2].LIMITH L Disabled 0 Disable Enabled 1 Enable RW CH2LIMITL Enable or disable interrupt for CH[2].LIMITL event See EVENTS_CH[2].LIMITL M Disabled 0 Disable Enabled 1 Enable RW CH3LIMITH Enable or disable interrupt for CH[3].LIMITH event See EVENTS_CH[3].LIMITH N Disabled 0 Disable Enabled 1 Enable RW CH3LIMITL Enable or disable interrupt for CH[3].LIMITL event See EVENTS_CH[3].LIMITL O Disabled 0 Disable Enabled 1 Enable RW CH4LIMITH Enable or disable interrupt for CH[4].LIMITH event See EVENTS_CH[4].LIMITH P Disabled 0 Disable Enabled 1 Enable RW CH4LIMITL Enable or disable interrupt for CH[4].LIMITL event See EVENTS_CH[4].LIMITL Q Disabled 0 Disable Enabled 1 Enable RW CH5LIMITH Enable or disable interrupt for CH[5].LIMITH event See EVENTS_CH[5].LIMITH Page 367 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id R RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable RW CH5LIMITL Enable or disable interrupt for CH[5].LIMITL event See EVENTS_CH[5].LIMITL S Disabled 0 Disable Enabled 1 Enable RW CH6LIMITH Enable or disable interrupt for CH[6].LIMITH event See EVENTS_CH[6].LIMITH T Disabled 0 Disable Enabled 1 Enable RW CH6LIMITL Enable or disable interrupt for CH[6].LIMITL event See EVENTS_CH[6].LIMITL U Disabled 0 Disable Enabled 1 Enable RW CH7LIMITH Enable or disable interrupt for CH[7].LIMITH event See EVENTS_CH[7].LIMITH V Disabled 0 Disable Enabled 1 Enable RW CH7LIMITL Enable or disable interrupt for CH[7].LIMITL event See EVENTS_CH[7].LIMITL Disabled 0 Disable Enabled 1 Enable 37.11.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id RW Field A RW STARTED 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for STARTED event See EVENTS_STARTED B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to Enable interrupt for END event See EVENTS_END C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DONE Write '1' to Enable interrupt for DONE event See EVENTS_DONE D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RESULTDONE Write '1' to Enable interrupt for RESULTDONE event See EVENTS_RESULTDONE Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Page 368 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id RW Field E RW CALIBRATEDONE 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for CALIBRATEDONE event See EVENTS_CALIBRATEDONE F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH0LIMITH Write '1' to Enable interrupt for CH[0].LIMITH event See EVENTS_CH[0].LIMITH H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH0LIMITL Write '1' to Enable interrupt for CH[0].LIMITL event See EVENTS_CH[0].LIMITL I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH1LIMITH Write '1' to Enable interrupt for CH[1].LIMITH event See EVENTS_CH[1].LIMITH J Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH1LIMITL Write '1' to Enable interrupt for CH[1].LIMITL event See EVENTS_CH[1].LIMITL K Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH2LIMITH Write '1' to Enable interrupt for CH[2].LIMITH event See EVENTS_CH[2].LIMITH L Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH2LIMITL Write '1' to Enable interrupt for CH[2].LIMITL event See EVENTS_CH[2].LIMITL M Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH3LIMITH Write '1' to Enable interrupt for CH[3].LIMITH event See EVENTS_CH[3].LIMITH N Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH3LIMITL Write '1' to Enable interrupt for CH[3].LIMITL event See EVENTS_CH[3].LIMITL O Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH4LIMITH Write '1' to Enable interrupt for CH[4].LIMITH event Page 369 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_CH[4].LIMITH P RW CH4LIMITL Write '1' to Enable interrupt for CH[4].LIMITL event See EVENTS_CH[4].LIMITL Q Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH5LIMITH Write '1' to Enable interrupt for CH[5].LIMITH event See EVENTS_CH[5].LIMITH R Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH5LIMITL Write '1' to Enable interrupt for CH[5].LIMITL event See EVENTS_CH[5].LIMITL S Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH6LIMITH Write '1' to Enable interrupt for CH[6].LIMITH event See EVENTS_CH[6].LIMITH T Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH6LIMITL Write '1' to Enable interrupt for CH[6].LIMITL event See EVENTS_CH[6].LIMITL U Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH7LIMITH Write '1' to Enable interrupt for CH[7].LIMITH event See EVENTS_CH[7].LIMITH V Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH7LIMITL Write '1' to Enable interrupt for CH[7].LIMITL event See EVENTS_CH[7].LIMITL Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 37.11.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id RW Field A RW STARTED 0 Value Id Value Description Write '1' to Disable interrupt for STARTED event See EVENTS_STARTED Clear I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Disable Page 370 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id B RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to Disable interrupt for END event See EVENTS_END C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DONE Write '1' to Disable interrupt for DONE event See EVENTS_DONE D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RESULTDONE Write '1' to Disable interrupt for RESULTDONE event See EVENTS_RESULTDONE E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CALIBRATEDONE Write '1' to Disable interrupt for CALIBRATEDONE event See EVENTS_CALIBRATEDONE F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Disable interrupt for STOPPED event See EVENTS_STOPPED G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH0LIMITH Write '1' to Disable interrupt for CH[0].LIMITH event See EVENTS_CH[0].LIMITH H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH0LIMITL Write '1' to Disable interrupt for CH[0].LIMITL event See EVENTS_CH[0].LIMITL I Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH1LIMITH Write '1' to Disable interrupt for CH[1].LIMITH event See EVENTS_CH[1].LIMITH J Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH1LIMITL Write '1' to Disable interrupt for CH[1].LIMITL event See EVENTS_CH[1].LIMITL K Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH2LIMITH Write '1' to Disable interrupt for CH[2].LIMITH event See EVENTS_CH[2].LIMITH Clear 1 Disable Disabled 0 Read: Disabled Page 371 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id L RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Read: Enabled RW CH2LIMITL Write '1' to Disable interrupt for CH[2].LIMITL event See EVENTS_CH[2].LIMITL M Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH3LIMITH Write '1' to Disable interrupt for CH[3].LIMITH event See EVENTS_CH[3].LIMITH N Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH3LIMITL Write '1' to Disable interrupt for CH[3].LIMITL event See EVENTS_CH[3].LIMITL O Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH4LIMITH Write '1' to Disable interrupt for CH[4].LIMITH event See EVENTS_CH[4].LIMITH P Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH4LIMITL Write '1' to Disable interrupt for CH[4].LIMITL event See EVENTS_CH[4].LIMITL Q Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH5LIMITH Write '1' to Disable interrupt for CH[5].LIMITH event See EVENTS_CH[5].LIMITH R Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH5LIMITL Write '1' to Disable interrupt for CH[5].LIMITL event See EVENTS_CH[5].LIMITL S Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH6LIMITH Write '1' to Disable interrupt for CH[6].LIMITH event See EVENTS_CH[6].LIMITH T Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH6LIMITL Write '1' to Disable interrupt for CH[6].LIMITL event See EVENTS_CH[6].LIMITL U Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW CH7LIMITH Write '1' to Disable interrupt for CH[7].LIMITH event See EVENTS_CH[7].LIMITH Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Page 372 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id V U T S R Q P O N M L K J Reset 0x00000000 Id RW Field V RW CH7LIMITL 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for CH[7].LIMITL event See EVENTS_CH[7].LIMITL Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 37.11.4 STATUS Address offset: 0x400 Status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Ready 0 ADC is ready. No on-going conversion. Busy 1 ADC is busy. Conversion in progress. STATUS Status 37.11.5 ENABLE Address offset: 0x500 Enable or disable ADC Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable ADC Enabled 1 Enable ADC Enable or disable ADC When enabled, the ADC will acquire access to the analog input pins specified in the CH[n].PSELP and CH[n].PSELN registers. 37.11.6 CH[0].PSELP Address offset: 0x510 Input positive pin selection for CH[0] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog positive input channel Page 373 37 SAADC — Successive approximation analogto-digital converter 37.11.7 CH[0].PSELN Address offset: 0x514 Input negative pin selection for CH[0] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog negative input, enables differential channel 37.11.8 CH[0].CONFIG Address offset: 0x518 Input configuration for CH[0] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP B C D E 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Internal reference (0.6 V) VDD1_4 1 VDD/4 as reference Positive channel resistor control RW RESN Negative channel resistor control RW GAIN Gain control RW REFSEL Reference control RW TACQ Acquisition time, the time the ADC uses to sample the input voltage 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us Page 374 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id F RW Field 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description 40us 5 40 us SE 0 Diff 1 Disabled 0 Burst mode is disabled (normal operation) Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND G Differential RW BURST Enable burst mode samples as fast as it can, and sends the average to Data RAM. 37.11.9 CH[0].LIMIT Address offset: 0x51C High/low limits for event monitoring a channel Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.10 CH[1].PSELP Address offset: 0x520 Input positive pin selection for CH[1] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog positive input channel 37.11.11 CH[1].PSELN Address offset: 0x524 Input negative pin selection for CH[1] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 Analog negative input, enables differential channel Page 375 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD 37.11.12 CH[1].CONFIG Address offset: 0x528 Input configuration for CH[1] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP B C D E 0 F E E E D C C C Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Internal reference (0.6 V) VDD1_4 1 VDD/4 as reference Positive channel resistor control RW RESN Negative channel resistor control RW GAIN Gain control RW REFSEL Reference control RW TACQ Acquisition time, the time the ADC uses to sample the input voltage F 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us 40us 5 40 us SE 0 Diff 1 Disabled 0 RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND G B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Differential RW BURST Enable burst mode Burst mode is disabled (normal operation) Page 376 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of samples as fast as it can, and sends the average to Data RAM. 37.11.13 CH[1].LIMIT Address offset: 0x52C High/low limits for event monitoring a channel Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.14 CH[2].PSELP Address offset: 0x530 Input positive pin selection for CH[2] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog positive input channel 37.11.15 CH[2].PSELN Address offset: 0x534 Input negative pin selection for CH[2] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 Analog negative input, enables differential channel Page 377 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description VDD 9 VDD 37.11.16 CH[2].CONFIG Address offset: 0x538 Input configuration for CH[2] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP B C D E 0 F E E E D C C C B B Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Internal reference (0.6 V) VDD1_4 1 VDD/4 as reference Positive channel resistor control RW RESN Negative channel resistor control RW GAIN Gain control RW REFSEL Reference control RW TACQ Acquisition time, the time the ADC uses to sample the input voltage F 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us 40us 5 40 us SE 0 Diff 1 Disabled 0 Burst mode is disabled (normal operation) Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND G A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Differential RW BURST Enable burst mode samples as fast as it can, and sends the average to Data RAM. 37.11.17 CH[2].LIMIT Address offset: 0x53C High/low limits for event monitoring a channel Page 378 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.18 CH[3].PSELP Address offset: 0x540 Input positive pin selection for CH[3] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog positive input channel 37.11.19 CH[3].PSELN Address offset: 0x544 Input negative pin selection for CH[3] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog negative input, enables differential channel 37.11.20 CH[3].CONFIG Address offset: 0x548 Input configuration for CH[3] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP 0 Value Id F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Positive channel resistor control Page 379 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id B C D E RW Field 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Internal reference (0.6 V) VDD1_4 1 VDD/4 as reference RW RESN Negative channel resistor control RW GAIN Gain control RW REFSEL Reference control RW TACQ Acquisition time, the time the ADC uses to sample the input voltage F 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us 40us 5 40 us SE 0 Diff 1 Disabled 0 Burst mode is disabled (normal operation) Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND G Differential RW BURST Enable burst mode samples as fast as it can, and sends the average to Data RAM. 37.11.21 CH[3].LIMIT Address offset: 0x54C High/low limits for event monitoring a channel Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.22 CH[4].PSELP Address offset: 0x550 Input positive pin selection for CH[4] Page 380 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog positive input channel 37.11.23 CH[4].PSELN Address offset: 0x554 Input negative pin selection for CH[4] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog negative input, enables differential channel 37.11.24 CH[4].CONFIG Address offset: 0x558 Input configuration for CH[4] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP B C 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Positive channel resistor control RW RESN Negative channel resistor control RW GAIN Gain control Page 381 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id D E RW Field 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Internal reference (0.6 V) VDD1_4 1 VDD/4 as reference RW REFSEL Reference control RW TACQ Acquisition time, the time the ADC uses to sample the input voltage F 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us 40us 5 40 us SE 0 Diff 1 Disabled 0 Burst mode is disabled (normal operation) Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND G Differential RW BURST Enable burst mode samples as fast as it can, and sends the average to Data RAM. 37.11.25 CH[4].LIMIT Address offset: 0x55C High/low limits for event monitoring a channel Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.26 CH[5].PSELP Address offset: 0x560 Input positive pin selection for CH[5] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 Analog positive input channel Page 382 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD 37.11.27 CH[5].PSELN Address offset: 0x564 Input negative pin selection for CH[5] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog negative input, enables differential channel 37.11.28 CH[5].CONFIG Address offset: 0x568 Input configuration for CH[5] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP B C D 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Positive channel resistor control RW RESN Negative channel resistor control RW GAIN Gain control RW REFSEL Reference control Internal reference (0.6 V) Page 383 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id E RW Field 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description VDD1_4 1 VDD/4 as reference RW TACQ Acquisition time, the time the ADC uses to sample the input voltage F 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us 40us 5 40 us SE 0 Diff 1 Disabled 0 Burst mode is disabled (normal operation) Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND G Differential RW BURST Enable burst mode samples as fast as it can, and sends the average to Data RAM. 37.11.29 CH[5].LIMIT Address offset: 0x56C High/low limits for event monitoring a channel Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.30 CH[6].PSELP Address offset: 0x570 Input positive pin selection for CH[6] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog positive input channel 37.11.31 CH[6].PSELN Address offset: 0x574 Input negative pin selection for CH[6] Page 384 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog negative input, enables differential channel 37.11.32 CH[6].CONFIG Address offset: 0x578 Input configuration for CH[6] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP B C D E 0 F E E E D C C C Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Internal reference (0.6 V) VDD1_4 1 VDD/4 as reference Positive channel resistor control RW RESN Negative channel resistor control RW GAIN Gain control RW REFSEL Reference control RW TACQ Acquisition time, the time the ADC uses to sample the input voltage F B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us 40us 5 40 us SE 0 Diff 1 RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND Differential Page 385 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field G RW BURST 0 F E E E D C C C B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Burst mode is disabled (normal operation) Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of Enable burst mode samples as fast as it can, and sends the average to Data RAM. 37.11.33 CH[6].LIMIT Address offset: 0x57C High/low limits for event monitoring a channel Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.34 CH[7].PSELP Address offset: 0x580 Input positive pin selection for CH[7] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD Analog positive input channel 37.11.35 CH[7].PSELN Address offset: 0x584 Input negative pin selection for CH[7] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field A RW PSELN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description NC 0 Not connected AnalogInput0 1 AIN0 AnalogInput1 2 AIN1 AnalogInput2 3 AIN2 AnalogInput3 4 AIN3 AnalogInput4 5 AIN4 AnalogInput5 6 AIN5 Analog negative input, enables differential channel Page 386 37 SAADC — Successive approximation analogto-digital converter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description AnalogInput6 7 AIN6 AnalogInput7 8 AIN7 VDD 9 VDD 37.11.36 CH[7].CONFIG Address offset: 0x588 Input configuration for CH[7] Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id G Reset 0x00020000 Id RW Field A RW RESP B C D E 0 F E E E D C C C B B Value Id Value Description Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Bypass 0 Bypass resistor ladder Pulldown 1 Pull-down to GND Pullup 2 Pull-up to VDD VDD1_2 3 Set input at VDD/2 Gain1_6 0 1/6 Gain1_5 1 1/5 Gain1_4 2 1/4 Gain1_3 3 1/3 Gain1_2 4 1/2 Gain1 5 1 Gain2 6 2 Gain4 7 4 Internal 0 Internal reference (0.6 V) VDD1_4 1 VDD/4 as reference Positive channel resistor control RW RESN Negative channel resistor control RW GAIN Gain control RW REFSEL Reference control RW TACQ Acquisition time, the time the ADC uses to sample the input voltage F 3us 0 3 us 5us 1 5 us 10us 2 10 us 15us 3 15 us 20us 4 20 us 40us 5 40 us SE 0 Diff 1 Disabled 0 Burst mode is disabled (normal operation) Enabled 1 Burst mode is enabled. SAADC takes 2^OVERSAMPLE number of RW MODE Enable differential mode Single ended, PSELN will be ignored, negative input to ADC shorted to GND G A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Differential RW BURST Enable burst mode samples as fast as it can, and sends the average to Data RAM. 37.11.37 CH[7].LIMIT Address offset: 0x58C Page 387 37 SAADC — Successive approximation analogto-digital converter High/low limits for event monitoring a channel Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B B B B B B B B A A A A A A A A A A A A A A A A Reset 0x7FFF8000 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A B Value Id Value Description RW LOW [-32768 to +32767] Low level limit RW HIGH [-32768 to +32767] High level limit 37.11.38 RESOLUTION Address offset: 0x5F0 Resolution configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000001 Id RW Field A RW VAL 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Description Set the resolution 8bit 0 8 bit 10bit 1 10 bit 12bit 2 12 bit 14bit 3 14 bit 37.11.39 OVERSAMPLE Address offset: 0x5F4 Oversampling configuration. OVERSAMPLE should not be combined with SCAN. The RESOLUTION is applied before averaging, thus for high OVERSAMPLE a higher RESOLUTION should be used. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW OVERSAMPLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Bypass 0 Bypass oversampling Over2x 1 Oversample 2x Over4x 2 Oversample 4x Over8x 3 Oversample 8x Over16x 4 Oversample 16x Over32x 5 Oversample 32x Over64x 6 Oversample 64x Over128x 7 Oversample 128x Over256x 8 Oversample 256x Oversample control 37.11.40 SAMPLERATE Address offset: 0x5F8 Controls normal or continuous sample rate Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B Reset 0x00000000 Id RW Field A RW CC B RW MODE 0 Value Id A A A A A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [80..2047] Capture and compare value. Sample rate is 16 MHz/CC Select mode for sample rate control Task 0 Rate is controlled from SAMPLE task Timers 1 Rate is controlled from local timer (use CC to control the rate) Page 388 37 SAADC — Successive approximation analogto-digital converter 37.11.41 RESULT.PTR Address offset: 0x62C Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Data pointer 37.11.42 RESULT.MAXCNT Address offset: 0x630 Maximum number of buffer words to transfer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum number of buffer words to transfer 37.11.43 RESULT.AMOUNT Address offset: 0x634 Number of buffer words transferred since last START Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description AMOUNT Number of buffer words transferred since last START. This register can be read after an END or STOPPED event. 37.12 Electrical specification 37.12.1 SAADC Electrical Specification Symbol Description Min. Typ. DNL Differential non-linearity, 10-bit resolution -0.95 0) Figure 121: Frame disassemble illustration Page 422 b5 b6 b7 P CRC 2 (8 bit) P EoF 42 NFCT — Near field communication tag 42.8 Antenna interface In ACTIVATED state, an amplitude regulator will adjust the voltage swing on the antenna pins to a value that is within the Vswing limit. Refer to NFCT Electrical Specification on page 435. 42.9 NFCT antenna recommendations The NFCT antenna coil must be connected differential between NFC1 and NFC2 pins of the device. Two external capacitors should be used to tune the resonance of the antenna circuit to 13.56 MHz. Cp1 Ctune1 Cint1 NFC1 ANTENNA Lant Rin NFC2 Cp2 Ctune2 Cint2 Figure 122: NFCT antenna recommendations The required tuning capacitor value is given by the below equations: An antenna inductance of Lant = 2 µH will give tuning capacitors in the range of 130 pF on each pin. For good performance, match the total capacitance on NFC1 and NFC2. 42.10 Battery protection If the antenna is exposed to a strong NFC field, current may flow in the opposite direction on the supply due to parasitic diodes and ESD structures. If the battery used does not tolerate return current, a series diode must be placed between the battery and the device in order to protect the battery. Page 423 42 NFCT — Near field communication tag 42.11 References NFC Forum, NFC Analog Specification version 1.0, www.nfc-forum.org NFC Forum, NFC Digital Protocol Technical Specification version 1.1, www.nfc-forum.org NFC Forum, NFC Activity Technical Specification version 1.1, www.nfc-forum.org 42.12 Registers Table 100: Instances Base address Peripheral Instance Description 0x40005000 NFCT NFCT Near Field Communication Tag Configuration Table 101: Register Overview Register Offset Description TASKS_ACTIVATE 0x000 Activate NFC peripheral for incoming and outgoing frames, change state to activated TASKS_DISABLE 0x004 Disable NFC peripheral TASKS_SENSE 0x008 Enable NFC sense field mode, change state to sense mode TASKS_STARTTX 0x00C Start transmission of a outgoing frame, change state to transmit TASKS_ENABLERXDATA 0x01C Initializes the EasyDMA for receive. TASKS_GOIDLE 0x024 Force state machine to IDLE state TASKS_GOSLEEP 0x028 Force state machine to SLEEP_A state EVENTS_READY 0x100 The NFC peripheral is ready to receive and send frames EVENTS_FIELDDETECTED 0x104 Remote NFC field detected EVENTS_FIELDLOST Remote NFC field lost 0x108 EVENTS_TXFRAMESTART 0x10C Marks the start of the first symbol of a transmitted frame EVENTS_TXFRAMEEND Marks the end of the last transmitted on-air symbol of a frame 0x110 EVENTS_RXFRAMESTART 0x114 Marks the end of the first symbol of a received frame EVENTS_RXFRAMEEND 0x118 Received data have been checked (CRC, parity) and transferred to RAM, and EasyDMA has ended accessing the RX buffer EVENTS_ERROR 0x11C NFC error reported. The ERRORSTATUS register contains details on the source of the error. EVENTS_RXERROR 0x128 NFC RX frame error reported. The FRAMESTATUS.RX register contains details on the source of the EVENTS_ENDRX 0x12C RX buffer (as defined by PACKETPTR and MAXLEN) in Data RAM full. EVENTS_ENDTX 0x130 Transmission of data in RAM has ended, and EasyDMA has ended accessing the TX buffer error. EVENTS_AUTOCOLRESSTARTED 0x138 Auto collision resolution process has started EVENTS_COLLISION 0x148 NFC Auto collision resolution error reported. EVENTS_SELECTED 0x14C NFC Auto collision resolution successfully completed EVENTS_STARTED 0x150 EasyDMA is ready to receive or send frames. SHORTS 0x200 Shortcut register INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ERRORSTATUS 0x404 NFC Error Status register FRAMESTATUS.RX 0x40C Result of last incoming frames CURRENTLOADCTRL 0x430 Current value driven to the NFC Load Control FIELDPRESENT 0x43C Indicates the presence or not of a valid field FRAMEDELAYMIN 0x504 Minimum frame delay FRAMEDELAYMAX 0x508 Maximum frame delay FRAMEDELAYMODE 0x50C Configuration register for the Frame Delay Timer PACKETPTR 0x510 Packet pointer for TXD and RXD data storage in Data RAM MAXLEN 0x514 Size of allocated for TXD and RXD data storage buffer in Data RAM TXD.FRAMECONFIG 0x518 Configuration of outgoing frames TXD.AMOUNT 0x51C Size of outgoing frame RXD.FRAMECONFIG 0x520 Configuration of incoming frames Page 424 42 NFCT — Near field communication tag Register Offset Description RXD.AMOUNT 0x524 Size of last incoming frame NFCID1_LAST 0x590 Last NFCID1 part (4, 7 or 10 bytes ID) NFCID1_2ND_LAST 0x594 Second last NFCID1 part (7 or 10 bytes ID) NFCID1_3RD_LAST 0x598 Third last NFCID1 part (10 bytes ID) SENSRES 0x5A0 NFC-A SENS_RES auto-response settings SELRES 0x5A4 NFC-A SEL_RES auto-response settings 42.12.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A Reset 0x00000000 Id RW Field A RW FIELDDETECTED_ACTIVATE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between FIELDDETECTED event and ACTIVATE task See EVENTS_FIELDDETECTED and TASKS_ACTIVATE B Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW FIELDLOST_SENSE Shortcut between FIELDLOST event and SENSE task See EVENTS_FIELDLOST and TASKS_SENSE Disabled 0 Disable shortcut Enabled 1 Enable shortcut 42.12.2 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id RW Field A RW READY 0 Value Id N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for READY event See EVENTS_READY B Disabled 0 Disable Enabled 1 Enable RW FIELDDETECTED Enable or disable interrupt for FIELDDETECTED event See EVENTS_FIELDDETECTED C Disabled 0 Disable Enabled 1 Enable RW FIELDLOST Enable or disable interrupt for FIELDLOST event See EVENTS_FIELDLOST D Disabled 0 Disable Enabled 1 Enable RW TXFRAMESTART Enable or disable interrupt for TXFRAMESTART event See EVENTS_TXFRAMESTART E Disabled 0 Disable Enabled 1 Enable RW TXFRAMEEND Enable or disable interrupt for TXFRAMEEND event See EVENTS_TXFRAMEEND F Disabled 0 Disable Enabled 1 Enable RW RXFRAMESTART Enable or disable interrupt for RXFRAMESTART event Page 425 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id RW Field 0 N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable See EVENTS_RXFRAMESTART G RW RXFRAMEEND Enable or disable interrupt for RXFRAMEEND event See EVENTS_RXFRAMEEND H Disabled 0 Disable Enabled 1 Enable RW ERROR Enable or disable interrupt for ERROR event See EVENTS_ERROR K Disabled 0 Disable Enabled 1 Enable RW RXERROR Enable or disable interrupt for RXERROR event See EVENTS_RXERROR L Disabled 0 Disable Enabled 1 Enable RW ENDRX Enable or disable interrupt for ENDRX event See EVENTS_ENDRX M Disabled 0 Disable Enabled 1 Enable RW ENDTX Enable or disable interrupt for ENDTX event See EVENTS_ENDTX N Disabled 0 Disable Enabled 1 Enable RW AUTOCOLRESSTARTED Enable or disable interrupt for AUTOCOLRESSTARTED event See EVENTS_AUTOCOLRESSTARTED R Disabled 0 Disable Enabled 1 Enable RW COLLISION Enable or disable interrupt for COLLISION event See EVENTS_COLLISION S Disabled 0 Disable Enabled 1 Enable RW SELECTED Enable or disable interrupt for SELECTED event See EVENTS_SELECTED T Disabled 0 Disable Enabled 1 Enable RW STARTED Enable or disable interrupt for STARTED event See EVENTS_STARTED Disabled 0 Disable Enabled 1 Enable 42.12.3 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id RW Field A RW READY 0 Value Id N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for READY event See EVENTS_READY Page 426 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id B RW Field 0 N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW FIELDDETECTED Write '1' to Enable interrupt for FIELDDETECTED event See EVENTS_FIELDDETECTED C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW FIELDLOST Write '1' to Enable interrupt for FIELDLOST event See EVENTS_FIELDLOST D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXFRAMESTART Write '1' to Enable interrupt for TXFRAMESTART event See EVENTS_TXFRAMESTART E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXFRAMEEND Write '1' to Enable interrupt for TXFRAMEEND event See EVENTS_TXFRAMEEND F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXFRAMESTART Write '1' to Enable interrupt for RXFRAMESTART event See EVENTS_RXFRAMESTART G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXFRAMEEND Write '1' to Enable interrupt for RXFRAMEEND event See EVENTS_RXFRAMEEND H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Enable interrupt for ERROR event See EVENTS_ERROR K Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXERROR Write '1' to Enable interrupt for RXERROR event See EVENTS_RXERROR L Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDRX Write '1' to Enable interrupt for ENDRX event See EVENTS_ENDRX M Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDTX Write '1' to Enable interrupt for ENDTX event See EVENTS_ENDTX Set 1 Enable Page 427 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id N RW Field 0 N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW AUTOCOLRESSTARTED Write '1' to Enable interrupt for AUTOCOLRESSTARTED event See EVENTS_AUTOCOLRESSTARTED R Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW COLLISION Write '1' to Enable interrupt for COLLISION event See EVENTS_COLLISION S Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SELECTED Write '1' to Enable interrupt for SELECTED event See EVENTS_SELECTED T Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STARTED Write '1' to Enable interrupt for STARTED event See EVENTS_STARTED Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 42.12.4 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id RW Field A RW READY 0 Value Id N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for READY event See EVENTS_READY B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW FIELDDETECTED Write '1' to Disable interrupt for FIELDDETECTED event See EVENTS_FIELDDETECTED C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW FIELDLOST Write '1' to Disable interrupt for FIELDLOST event See EVENTS_FIELDLOST D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXFRAMESTART Write '1' to Disable interrupt for TXFRAMESTART event See EVENTS_TXFRAMESTART Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Page 428 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id RW Field E RW TXFRAMEEND 0 Value Id N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for TXFRAMEEND event See EVENTS_TXFRAMEEND F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXFRAMESTART Write '1' to Disable interrupt for RXFRAMESTART event See EVENTS_RXFRAMESTART G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXFRAMEEND Write '1' to Disable interrupt for RXFRAMEEND event See EVENTS_RXFRAMEEND H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ERROR Write '1' to Disable interrupt for ERROR event See EVENTS_ERROR K Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW RXERROR Write '1' to Disable interrupt for RXERROR event See EVENTS_RXERROR L Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDRX Write '1' to Disable interrupt for ENDRX event See EVENTS_ENDRX M Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ENDTX Write '1' to Disable interrupt for ENDTX event See EVENTS_ENDTX N Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW AUTOCOLRESSTARTED Write '1' to Disable interrupt for AUTOCOLRESSTARTED event See EVENTS_AUTOCOLRESSTARTED R Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW COLLISION Write '1' to Disable interrupt for COLLISION event See EVENTS_COLLISION S Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SELECTED Write '1' to Disable interrupt for SELECTED event See EVENTS_SELECTED T Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STARTED Write '1' to Disable interrupt for STARTED event Page 429 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id T S R Reset 0x00000000 Id RW Field 0 N M L K H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_STARTED 42.12.5 ERRORSTATUS Address offset: 0x404 NFC Error Status register Write a bit to '1' to clear it. Writing '0' has no effect. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D C Reset 0x00000000 0 Value Id A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW FRAMEDELAYTIMEOUT Value Description C RW NFCFIELDTOOSTRONG Field level is too high at max load resistance D RW NFCFIELDTOOWEAK Field level is too low at min load resistance No STARTTX task triggered before expiration of the time set in FRAMEDELAYMAX 42.12.6 FRAMESTATUS.RX Address offset: 0x40C Result of last incoming frames Write a bit to '1' to clear it. Writing '0' has no effect. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B Reset 0x00000000 Id RW Field A RW CRCERROR B C 0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description CRCCorrect 0 Valid CRC detected CRCError 1 CRC received does not match local check ParityOK 0 Frame received with parity OK ParityError 1 Frame received with parity error NoOverrun 0 No overrun detected Overrun 1 Overrun error No valid End of Frame detected RW PARITYSTATUS Parity status of received frame RW OVERRUN Overrun detected 42.12.7 CURRENTLOADCTRL Address offset: 0x430 Current value driven to the NFC Load Control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description CURRENTLOADCTRL Current value driven to the NFC Load Control 42.12.8 FIELDPRESENT Address offset: 0x43C Page 430 42 NFCT — Near field communication tag Indicates the presence or not of a valid field Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description FIELDPRESENT Indicates the presence or not of a valid field. Available only in the activated state. B R NoField 0 No valid field detected FieldPresent 1 Valid field detected NotLocked 0 Not locked to field Locked 1 Locked to field LOCKDETECT Indicates if the low level has locked to the field 42.12.9 FRAMEDELAYMIN Address offset: 0x504 Minimum frame delay Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000480 Id RW Field A RW FRAMEDELAYMIN 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 0 0 0 0 0 0 0 Value Description Minimum frame delay in number of 13.56 MHz clocks 42.12.10 FRAMEDELAYMAX Address offset: 0x508 Maximum frame delay Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00001000 Id RW Field A RW FRAMEDELAYMAX 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Maximum frame delay in number of 13.56 MHz clocks 42.12.11 FRAMEDELAYMODE Address offset: 0x50C Configuration register for the Frame Delay Timer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A Reset 0x00000001 Id RW Field A RW FRAMEDELAYMODE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Description FreeRun 0 Window 1 ExactVal 2 Frame is transmitted exactly at FRAMEDELAYMAX WindowGrid 3 Frame is transmitted on a bit grid between FRAMEDELAYMIN Configuration register for the Frame Delay Timer Transmission is independent of frame timer and will start when the STARTTX task is triggered. No timeout. Frame is transmitted between FRAMEDELAYMIN and FRAMEDELAYMAX and FRAMEDELAYMAX 42.12.12 PACKETPTR Address offset: 0x510 Packet pointer for TXD and RXD data storage in Data RAM Page 431 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Packet pointer for TXD and RXD data storage in Data RAM. This address is a byte aligned RAM address. 42.12.13 MAXLEN Address offset: 0x514 Size of allocated for TXD and RXD data storage buffer in Data RAM Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXLEN 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..257] Size of allocated for TXD and RXD data storage buffer in Data RAM 42.12.14 TXD.FRAMECONFIG Address offset: 0x518 Configuration of outgoing frames Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D Reset 0x00000017 Id RW Field A RW PARITY B C D 0 C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 1 1 Value Id Value Description NoParity 0 Parity is not added in TX frames Parity 1 Parity is added TX frames DiscardEnd 0 Unused bits is discarded at end of frame DiscardStart 1 Unused bits is discarded at start of frame NoSoF 0 Start of Frame symbol not added SoF 1 Start of Frame symbol added NoCRCTX 0 CRC is not added to the frame CRC16TX 1 16 bit CRC added to the frame based on all the data read from Adding parity or not in the frame RW DISCARDMODE Discarding unused bits in start or at end of a Frame RW SOF Adding SoF or not in TX frames RW CRCMODETX CRC mode for outgoing frames RAM that is used in the frame 42.12.15 TXD.AMOUNT Address offset: 0x51C Size of outgoing frame Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B A A A Reset 0x00000000 Id RW Field A RW TXDATABITS 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..7] Number of bits in the last or first byte read from RAM that shall be included in the frame (excluding parity bit). The DISCARDMODE field in FRAMECONFIG.TX selects if unused bits is discarded at the start or at the end of a frame. A value of 0 data bytes and 0 data bits is invalid. B RW TXDATABYTES [0..257] Number of complete bytes that shall be included in the frame, excluding CRC, parity and framing Page 432 42 NFCT — Near field communication tag 42.12.16 RXD.FRAMECONFIG Address offset: 0x520 Configuration of incoming frames Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C Reset 0x00000015 Id RW Field A RW PARITY B C 0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 1 Value Id Value Description NoParity 0 Parity is not expected in RX frames Parity 1 Parity is expected in RX frames NoSoF 0 Start of Frame symbol is not expected in RX frames SoF 1 Start of Frame symbol is expected in RX frames NoCRCRX 0 CRC is not expected in RX frames CRC16RX 1 Last 16 bits in RX frame is CRC, CRC is checked and CRCSTATUS Parity expected or not in RX frame RW SOF SoF expected or not in RX frames RW CRCMODERX CRC mode for incoming frames updated 42.12.17 RXD.AMOUNT Address offset: 0x524 Size of last incoming frame Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B B B B B B B B B A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RXDATABITS Number of bits in the last byte in the frame, if less than 8 (including CRC, but excluding parity and SoF/EoF framing). Frames with 0 data bytes and less than 7 data bits are invalid and are not received properly. B R RXDATABYTES Number of complete bytes received in the frame (including CRC, but excluding parity and SoF/EoF framing) 42.12.18 NFCID1_LAST Address offset: 0x590 Last NFCID1 part (4, 7 or 10 bytes ID) Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00006363 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 1 1 0 1 1 0 0 0 1 1 Id RW Field Value A RW NFCID1_Z Description NFCID1 byte Z (very last byte sent) B RW NFCID1_Y NFCID1 byte Y C RW NFCID1_X NFCID1 byte X D RW NFCID1_W NFCID1 byte W 42.12.19 NFCID1_2ND_LAST Address offset: 0x594 Second last NFCID1 part (7 or 10 bytes ID) Page 433 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW NFCID1_V Value Description NFCID1 byte V B RW NFCID1_U NFCID1 byte U C RW NFCID1_T NFCID1 byte T 42.12.20 NFCID1_3RD_LAST Address offset: 0x598 Third last NFCID1 part (10 bytes ID) Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW NFCID1_S Value Description NFCID1 byte S B RW NFCID1_R NFCID1 byte R C RW NFCID1_Q NFCID1 byte Q 42.12.21 SENSRES Address offset: 0x5A0 NFC-A SENS_RES auto-response settings Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E E E E D D D D C C B A A A A A Reset 0x00000001 Id RW Field A RW BITFRAMESDD 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Description Bit frame SDD as defined by the b5:b1 of byte 1 in SENS_RES response in the NFC Forum, NFC Digital Protocol Technical Specification SDD00000 0 SDD pattern 00000 SDD00001 1 SDD pattern 00001 SDD00010 2 SDD pattern 00010 SDD00100 4 SDD pattern 00100 SDD01000 8 SDD pattern 01000 SDD10000 16 SDD pattern 10000 B RW RFU5 Reserved for future use. Shall be 0. C RW NFCIDSIZE NFCID1 size. This value is used by the Auto collision resolution engine. D NFCID1Single 0 NFCID1 size: single (4 bytes) NFCID1Double 1 NFCID1 size: double (7 bytes) NFCID1Triple 2 NFCID1 size: triple (10 bytes) RW PLATFCONFIG Tag platform configuration as defined by the b4:b1 of byte 2 in SENS_RES response in the NFC Forum, NFC Digital Protocol Technical Specification E RW RFU74 Reserved for future use. Shall be 0. 42.12.22 SELRES Address offset: 0x5A4 NFC-A SEL_RES auto-response settings Page 434 42 NFCT — Near field communication tag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E D D C C B A A Reset 0x00000000 Id RW Field A RW RFU10 B RW CASCADE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Reserved for future use. Shall be 0. Cascade bit (controlled by hardware, write has no effect) Complete 0 NFCID1 complete NotComplete 1 NFCID1 not complete C RW RFU43 Reserved for future use. Shall be 0. D RW PROTOCOL Protocol as defined by the b7:b6 of SEL_RES response in the E RW RFU7 NFC Forum, NFC Digital Protocol Technical Specification Reserved for future use. Shall be 0. 42.13 Electrical specification 42.13.1 NFCT Electrical Specification Symbol Description fc Frequency of operation Min. Typ. Max. CMI Carrier modulation index DR Data Rate 106 fs Modulation sub-carrier frequency fc/16 Vswing Peak differential Input voltage swing on NFC1 and NFC2 Vsense Peak differential Field detect threshold level on NFC1-NFC235 1.0 Vp Isense Current in SENSE STATE 100 nA Iactivated Current in ACTIVATED STATE 480 Rin_min Minimum input resistance when regulating voltage swing Rin_max Maximum input resistance when regulating voltage swing 1.0 Rin_loadmod Input resistance when load modulating 8 Imax Maximum input current on NFC pins 13.56 Units MHz 95 % kbps MHz VDD Vp µA 40 Ω kΩ 22 Ω 80 mA Max. Units 500 us 20 us 42.13.2 NFCT Timing Parameters Symbol Description tactivate Time from task_ACTIVATE in SENSE or DISABLE state to Min. Typ. ACTIVATE_A or IDLE state36 tsense Time from remote field is present in SENSE mode to FIELDDETECTED event is asserted DISABLE ACTIVATE SENSE TASKS tactivate tsense tsense RF-Carrier MODES DISABLE SENSE_FIELD IDLERU Activated DISABLE FIELDDETECTED FIELDLOST READY FIELDDETECTED EVENTS Figure 123: NFCT timing parameters (Shortcuts for FIELDDETECTED and FIELDLOST are disabled) 35 36 Input is high impedance in sense mode Does not account for voltage supply and oscillator startup times Page 435 43 PDM — Pulse density modulation interface 43 PDM — Pulse density modulation interface The pulse density modulation (PDM) module enables input of pulse density modulated signals from external audio frontends, for example, digital microphones. The PDM module generates the PDM clock and supports single-channel or dual-channel (Left and Right) data input. Data is transferred directly to RAM buffers using EasyDMA. Listed here are the main features for PDM: • • • • Up to two PDM microphones configured as a Left/Right pair using the same data input 16 kHz output sample rate, 16-bit samples EasyDMA support for sample buffering HW decimation filters The PDM module illustrated in Figure 124: PDM module on page 436 is interfacing up to two digital microphones with the PDM interface. It implements EasyDMA, which relieves real-time requirements associated with controlling the PDM slave from a low priority CPU execution context. It also includes all the necessary digital filter elements to produce PCM samples. The PDM module allows continuous audio streaming. CLK Band-pass and Decimation (left) PDM to PCM Band-pass and Decimation (right) RAM PDM to PCM EasyDMA Sampling DIN Master clock generator Figure 124: PDM module 43.1 Master clock generator The FREQ field in the master clock's PDMCLKCTRL register allows adjusting the PDM clock's frequency. The master clock generator does not add any jitter to the HFCLK source chosen. It is recommended (but not mandatory) to use the Xtal as HFCLK source. 43.2 Module operation By default, bits from the left PDM microphone are sampled on PDM_CLK falling edge, bits for the right are sampled on the rising edge of PDM_CLK, resulting in two bitstreams. Each bitstream is fed into a digital filter which converts the PDM stream into 16-bit PCM samples, and filters and down-samples them to reach the appropriate sample rate. The EDGE field in the MODE register allows swapping Left and Right, so that Left will be sampled on rising edge, and Right on falling. The PDM module uses EasyDMA to store the samples coming out from the filters into one buffer in RAM. Depending on the mode chosen in the OPERATION field in the MODE register, memory either contains alternating left and right 16-bit samples (Stereo), or only left 16-bit samples (Mono). To ensure continuous PDM sampling, it is up to the application to update the EasyDMA destination address pointer as the previous buffer is filled. Page 436 43 PDM — Pulse density modulation interface The continuous transfer can be started or stopped by sending the START and STOP tasks. STOP becomes effective after the current frame has finished transferring, which will generate the STOPPED event. The STOPPED event indicates that all activity in the module are finished, and that the data is available in RAM (EasyDMA has finished transferring as well). Attempting to restart before receiving the STOPPED event may result in unpredictable behaviour. 43.3 Decimation filter In order to convert the incoming data stream into PCM audio samples, a decimation filter is included in the PDM interface module. The input of the filter is the two-channel PDM serial stream (with left channel on clock high, right channel on clock low), its output is 2 × 16-bit PCM samples at a sample rate 64 times lower than the PDM clock rate. The filter stage of each channel is followed by a digital volume control, to attenuate or amplify the output samples in a range of -20 dB to +20 dB around the default (reset) setting, defined by GPDM,default. The gain is controlled by the GAINL and GAINR registers. As an example, if the goal is to achieve 2500 RMS output samples (16 bit) with a 1 kHz 90 dBA signal into a -26 dBFS sensitivity PDM microphone, the user will have to sum the PDM module's default gain ( GPDM,default ) and the gain introduced by the microphone and acoustic path of his implementation (an attenuation would translate into a negative gain), and adjust GAINL and GAINR by this amount. Assuming that only the PDM module influences the gain, GAINL and GAINR must be set to -GPDM,default dB to achieve the requirement. With GPDM,default=3.2 dB, and as GAINL and GAINR are expressed in 0.5 dB steps, the closest value to program would be 3.0 dB, which can be calculated as: GAINL = GAINR = (DefaultGain - (2 * 3)) Remember to check that the resulting values programmed into GAINL and GAINR fall within MinGain and MaxGain. 43.4 EasyDMA Samples will be written directly to RAM, and EasyDMA must be configured accordingly. The address pointer for the EasyDMA channel is set in SAMPLE.PTR register. If the destination address set in SAMPLE.PTR is not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 23 for more information about the different memory regions. DMA supports Stereo (Left+Right 16-bit samples) and Mono (Left only) data transfer, depending on setting in the OPERATION field in the MODE register. The samples are stored little endian. Table 102: DMA sample storage MODE.OPERATION Bits per sample Stereo Mono 32 (2x16) 16 Result stored per RAM word L+R 2xL Physical RAM allocated (32 bit words) ceil(SAMPLE.MAXCNT/2) ceil(SAMPLE.MAXCNT/2) Result boundary indexes in RAM R0=[31:16]; L0=[15:0] L1=[31:16]; L0=[15:0] Note Default The destination buffer in RAM consists of one block, the size of which is set in SAMPLE.MAXCNT register. Format is number of 16-bit samples. The physical RAM allocated is always: (RAM allocation, in bytes) = SAMPLE.MAXCNT * 2; (but the mapping of the samples depends on MODE.OPERATION. If OPERATION=Stereo, RAM will contain a succession of Left and Right samples. If OPERATION=Mono, RAM will contain a succession of mono samples. Page 437 43 PDM — Pulse density modulation interface For a given value of SAMPLE.MAXCNT, the buffer in RAM can contain half the stereo sampling time as compared to the mono sampling time. The PDM acquisition can be started by the START task, after the SAMPLE.PTR and SAMPLE.MAXCNT registers have been written. When starting the module, it will take some time for the filters to start outputting valid data. Transients from the PDM microphone itself may also occur. The first few samples (typically around 50) might hence contain invalid values or transients. It is therefore advised to discard the first few samples after a PDM start. As soon as the STARTED event is received, the firmware can write the next SAMPLE.PTR value (this register is double-buffered), to ensure continuous operation. When the buffer in RAM is filled with samples, an END event is triggered. The firmware can start processing the data in the buffer. Meanwhile, the PDM module starts acquiring data into the new buffer pointed to by SAMPLE.PTR, and sends a new STARTED event, so that the firmware can update SAMPLE.PTR to the next buffer address. 43.5 Hardware example Connect the microphone clock to CLK, and data to DIN. Vdd L/R nRFxxxxx CLK CLK DATA DIN CLK DIN Figure 125: Example of a single PDM microphone, wired as left Vdd L/R nRFxxxxx CLK CLK DATA DIN CLK DIN Figure 126: Example of a single PDM microphone, wired as right Note that in a single-microphone (mono) configuration, depending on the microphone’s implementation, either the left or the right channel (sampled at falling or rising CLK edge respectively) will contain reliable data. If two microphones are used, one of them has to be set as left, the other as right (L/R pin tied high or to GND on the respective microphone). It is strongly recommended to use two microphones of exactly the same brand and type so that their timings in left and right operation match. Vdd L/R nRFxxxxx CLK CLK DATA DIN Vdd CLK L/R DATA CLK DIN Figure 127: Example of two PDM microphones 43.6 Pin configuration The CLK and DIN signals associated to the PDM module are mapped to physical pins according to the configuration specified in the PSEL.CLK and PSEL.DIN registers respectively. If the CONNECT field in any PSEL register is set to Disconnected, the associated PDM module signal will not be connected to the required physical pins, and will not operate properly. Page 438 43 PDM — Pulse density modulation interface The PSEL.CLK and PSEL.DIN registers and their configurations are only used as long as the PDM module is enabled, and retained only as long as the device is in System ON mode. See POWER — Power supply on page 78 for more information about power modes. When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. To ensure correct behaviour in the PDM module, the pins used by the PDM module must be configured in the GPIO peripheral as described in Table 103: GPIO configuration before enabling peripheral on page 439 before enabling the PDM module. This is to ensure that the pins used by the PDM module are driven correctly if the PDM module itself is temporarily disabled or the device temporarily enters System OFF. This configuration must be retained in the GPIO for the selected I/Os as long as the PDM module is supposed to be connected to an external PDM circuit. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behaviour. Table 103: GPIO configuration before enabling peripheral PDM signal CLK DIN PDM pin As specified in PSEL.CLK As specified in PSEL.DIN Direction Output Input Output value 0 Not applicable Comment 43.7 Registers Table 104: Instances Base address Peripheral Instance Description 0x4001D000 PDM PDM Pulse Density Modulation (Digital Configuration Microphone Interface) Table 105: Register Overview Register Offset Description TASKS_START 0x000 Starts continuous PDM transfer TASKS_STOP 0x004 Stops PDM transfer EVENTS_STARTED 0x100 PDM transfer has started EVENTS_STOPPED 0x104 PDM transfer has finished EVENTS_END 0x108 The PDM has written the last sample specified by SAMPLE.MAXCNT (or the last sample after a STOP INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 PDM module enable register PDMCLKCTRL 0x504 PDM clock generator control MODE 0x508 Defines the routing of the connected PDM microphones' signals GAINL 0x518 Left output gain adjustment GAINR 0x51C Right output gain adjustment PSEL.CLK 0x540 Pin number configuration for PDM CLK signal PSEL.DIN 0x544 Pin number configuration for PDM DIN signal SAMPLE.PTR 0x560 RAM address pointer to write samples to with EasyDMA SAMPLE.MAXCNT 0x564 Number of samples to allocate memory for in EasyDMA mode task has been received) to Data RAM 43.7.1 INTEN Address offset: 0x300 Enable or disable interrupt Page 439 43 PDM — Pulse density modulation interface Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW STARTED 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for STARTED event See EVENTS_STARTED B Disabled 0 Disable Enabled 1 Enable RW STOPPED Enable or disable interrupt for STOPPED event See EVENTS_STOPPED C Disabled 0 Disable Enabled 1 Enable RW END Enable or disable interrupt for END event See EVENTS_END Disabled 0 Disable Enabled 1 Enable 43.7.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW STARTED 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for STARTED event See EVENTS_STARTED B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW END Write '1' to Enable interrupt for END event See EVENTS_END Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 43.7.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW STARTED 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for STARTED event See EVENTS_STARTED B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Disable interrupt for STOPPED event Page 440 43 PDM — Pulse density modulation interface Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_STOPPED C RW END Write '1' to Disable interrupt for END event See EVENTS_END Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 43.7.4 ENABLE Address offset: 0x500 PDM module enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable PDM module 43.7.5 PDMCLKCTRL Address offset: 0x504 PDM clock generator control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x08400000 Id RW Field A RW FREQ 0 0 0 0 1 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description 1000K 0x08000000 PDM_CLK = 32 MHz / 32 = 1.000 MHz Default 0x08400000 PDM_CLK = 32 MHz / 31 = 1.032 MHz 1067K 0x08800000 PDM_CLK = 32 MHz / 30 = 1.067 MHz PDM_CLK frequency 43.7.6 MODE Address offset: 0x508 Defines the routing of the connected PDM microphones' signals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A Reset 0x00000000 Id RW Field A RW OPERATION 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Stereo 0 Mono 1 Description Mono or stereo operation Sample and store one pair (Left + Right) of 16bit samples per RAM word R=[31:16]; L=[15:0] Sample and store two successive Left samples (16 bit each) per RAM word L1=[31:16]; L0=[15:0] B RW EDGE Defines on which PDM_CLK edge Left (or mono) is sampled LeftFalling 0 Left (or mono) is sampled on falling edge of PDM_CLK LeftRising 1 Left (or mono) is sampled on rising edge of PDM_CLK Page 441 43 PDM — Pulse density modulation interface 43.7.7 GAINL Address offset: 0x518 Left output gain adjustment Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A Reset 0x00000028 Id RW Field A RW GAINL 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 Value Description Left output gain adjustment, in 0.5 dB steps, around the default module gain (see electrical parameters) 0x00 -20 dB gain adjust 0x01 -19.5 dB gain adjust (...) 0x27 -0.5 dB gain adjust 0x28 0 dB gain adjust 0x29 +0.5 dB gain adjust (...) 0x4F +19.5 dB gain adjust 0x50 +20 dB gain adjust MinGain 0x00 -20dB gain adjustment (minimum) DefaultGain 0x28 0dB gain adjustment ('2500 RMS' requirement) MaxGain 0x50 +20dB gain adjustment (maximum) 43.7.8 GAINR Address offset: 0x51C Right output gain adjustment Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000028 Id RW Field A RW GAINR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 Value Description Right output gain adjustment, in 0.5 dB steps, around the default module gain (see electrical parameters) MinGain 0x00 -20dB gain adjustment (minimum) DefaultGain 0x28 0dB gain adjustment ('2500 RMS' requirement) MaxGain 0x50 +20dB gain adjustment (maximum) 43.7.9 PSEL.CLK Address offset: 0x540 Pin number configuration for PDM CLK signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 43.7.10 PSEL.DIN Address offset: 0x544 Page 442 43 PDM — Pulse density modulation interface Pin number configuration for PDM DIN signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN B RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 43.7.11 SAMPLE.PTR Address offset: 0x560 RAM address pointer to write samples to with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 Id RW Field Value Id A RW SAMPLEPTR 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Address to write PDM samples to over DMA 43.7.12 SAMPLE.MAXCNT Address offset: 0x564 Number of samples to allocate memory for in EasyDMA mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW BUFFSIZE 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description [0..32767] Length of DMA RAM allocation in number of samples 43.8 Electrical specification 43.8.1 PDM Electrical Specification Symbol Description IPDM,stereo PDM module active current, stereo operation37 Min. Typ. 1.4 fPDM,CLK PDM clock speed 1.032 tPDM,JITTER Jitter in PDM clock output TdPDM,CLK PDM clock duty cycle tPDM,DATA Max. Units mA MHz 20 ns 60 % Decimation filter delay 5 ms tPDM,cv Allowed clock edge to data valid 125 ns tPDM,ci Allowed (other) clock edge to data invalid 0 ns tPDM,s Data setup time at fPDM,CLK=1.024 MHz 65 ns tPDM,h Data hold time at fPDM,CLK=1.024 MHz 0 GPDM,default Default (reset) absolute gain of the PDM module 37 40 50 ns 3.2 Average current including PDM and DMA transfers, excluding clock and power supply base currents Page 443 dB 43 PDM — Pulse density modulation interface tPDM,CLK CLK tPDM,cv tPDM,s DIN (L) tPDM,cv tPDM,s tPDM,h=tPDM,ci DIN(R) Figure 128: PDM timing diagram Page 444 tPDM,h=tPDM,ci 2 44 I S — Inter-IC sound interface 2 44 I S — Inter-IC sound interface 2 2 The I S (Inter-IC Sound) module, supports the original two-channel I S format, and left or right-aligned formats. It implements EasyDMA for sample transfer directly to and from RAM without CPU intervention. 2 The I S peripheral has the following main features: • • • • • • Master and Slave mode Simultaneous bi-directional (TX and RX) audio streaming 2 Original I S and left- or right-aligned format 8, 16 and 24-bit sample width Low-jitter Master Clock generator Various sample rates PSEL.MCK PSEL.LRCK PSEL.SCK PSEL.SDIN PSEL.SDOUT I2S CONFIG.MCKEN Master clock generator MCK CONFIG.MCKFREQ CONFIG.RATIO Div CONFIG.FORMAT Div CONFIG.MODE Serial tranceiever TXD.PTR RXD.PTR RXTXD.MAXCNT EasyDMA SDOUT SDIN SCK LRCK CONFIG.ALIGN RAM 2 Figure 129: I S master 44.1 Mode 2 The I S protocol specification defines two modes of operation, Master and Slave. 2 The I S mode decides which of the two sides (Master or Slave) shall provide the clock signals LRCK and SCK, and these signals are always supplied by the Master to the Slave. 44.2 Transmitting and receiving 2 The I S module supports both transmission (TX) and reception (RX) of serial data. In both cases the serial data is shifted synchronously to the clock signals SCK and LRCK. Page 445 2 44 I S — Inter-IC sound interface TX data is written to the SDOUT pin on the falling edge of SCK, and RX data is read from the SDIN pin on the rising edge of SCK. The most significant bit (MSB) is always transmitted first. TX and RX are available in both Master and Slave modes and can be enabled/disabled independently in the CONFIG.TXEN on page 455 and CONFIG.RXEN on page 455. Transmission and/or reception is started by triggering the START task. When started and transmission is enabled (in CONFIG.TXEN on page 455), the TXPTRUPD event will be generated for every RXTXD.MAXCNT on page 458 number of transmitted data words (containing one or more samples). Similarly, when started and reception is enabled (in CONFIG.RXEN on page 455), the RXPTRUPD event will be generated for every RXTXD.MAXCNT on page 458 received data words. RXTXD.MAXCNT Left 0 Right 0 Left 1 RIght 1 Left 2 Right 2 Left 3 A A A A C C C Right 3 C Left 4 E B B B B D D D D F RXPTRUPD TXPTRUPD RXPTRUPD RXPTRUPD TXPTRUPD RXD.PTR = H TXD.PTR = G RXD.PTR = F TXD.PTR = E TXD.PTR = C RXD.PTR = D START TXD.PTR = A RXD.PTR = B CPU TXPTRUPD LRCK SCK SDIN SDOUT RXTXD.MAXCNT Figure 130: Transmitting and receiving. CONFIG.FORMAT = Aligned, CONFIG.SWIDTH = 8Bit, CONFIG.CHANNELS = Stereo, RXTXD.MAXCNT = 1. 44.3 Left right clock (LRCK) 2 The Left Right Clock (LRCK), often referred to as "word clock", "sample clock" or "word select" in I S context, is the clock defining the frames in the serial bit streams sent and received on SDOUT and SDIN, respectively. In I2S mode, each frame contains one left and right sample pair, with the left sample being transferred during the low half period of LRCK followed by the right sample being transferred during the high period of LRCK. In Aligned mode, each frame contains one left and right sample pair, with the left sample being transferred during the high half period of LRCK followed by the right sample being transferred during the low period of LRCK. Consequently, the LRCK frequency is equivalent to the audio sample rate. When operating in Master mode, the LRCK is generated from the MCK, and the frequency of LRCK is then given as: LRCK = MCK / CONFIG.RATIO LRCK always toggles around the falling edge of the serial clock SCK. 44.4 Serial clock (SCK) The serial clock (SCK), often referred to as the serial bit clock, pulses once for each data bit being transferred on the serial data lines SDIN and SDOUT. Page 446 2 44 I S — Inter-IC sound interface When operating in Master mode the SCK is generated from the MCK, and the frequency of SCK is then given as: SCK = 2 * LRCK * CONFIG.SWIDTH The falling edge of the SCK falls on the toggling edge of LRCK. 2 When operating in Slave mode SCK is provided by the external I S master. 44.5 Master clock (MCK) The master clock (MCK) is the clock from which LRCK and SCK are derived when operating in Master mode. The MCK is generated by an internal MCK generator. This generator always needs to be enabled when in Master mode, but the generator can also be enabled when in Slave mode. Enabling the generator when in slave mode can be useful in the case where the external Master is not able to generate its own master clock. The MCK generator is enabled/disabled in the register CONFIG.MCKEN on page 456, and the generator is started or stopped by the START or STOP tasks. In Master mode the LRCK and the SCK frequencies are closely related, as both are derived from MCK and set indirectly through CONFIG.RATIO on page 456 and CONFIG.SWIDTH on page 457. When configuring these registers, the user is responsible for fulfilling the following requirements: 1. SCK frequency can never exceed the MCK frequency, which can be formulated as: CONFIG.RATIO >= 2 * CONFIG.SWIDTH 2. The MCK/LRCK ratio shall be a multiple of 2 * CONFIG.SWIDTH, which can be formulated as: Integer = (CONFIG.RATIO / (2 * CONFIG.SWIDTH)) 2 The MCK signal can be routed to an output pin (specified in PSEL.MCK) to supply external I S devices that require the MCK to be supplied from the outside. 2 When operating in Slave mode, the I S module does not use the MCK and the MCK generator does not need to be enabled. RATIO = MCK LRCK MCK LRCK SWIDTH SCK Figure 131: Relation between RATIO, MCK and LRCK. Table 106: Configuration examples Desired LRCK [Hz] 16000 16000 16000 32000 32000 32000 44100 44100 44100 CONFIG.SWIDTH 16Bit 16Bit 16Bit 16Bit 16Bit 16Bit 16Bit 16Bit 16Bit CONFIG.RATIO 32X 64X 256X 32X 64X 256X 32X 64X 256X CONFIG.MCKFREQ 32MDIV63 32MDIV31 32MDIV8 32MDIV31 32MDIV16 32MDIV4 32MDIV23 32MDIV11 32MDIV3 MCK [Hz] 507936.5 1032258.1 4000000.0 1032258.1 2000000.0 8000000.0 1391304.3 2909090.9 10666666.7 LRCK [Hz] 15873.0 16129.0 15625.0 32258.1 31250.0 31250.0 43478.3 45454.5 41666.7 LRCK error [%] -0.8 0.8 -2.3 0.8 -2.3 -2.3 -1.4 3.1 -5.5 44.6 Width, alignment and format The CONFIG.SWIDTH register primarily defines the sample width of the data written to memory. In master mode, it then also sets the amount of bits per frame. In Slave mode it controls padding/trimming if required. Left, right, transmitted, and received samples always have the same width. The CONFIG.FORMAT register specifies the position of the data frames with respect to the LRCK edges in both Master and Slave modes. Page 447 2 44 I S — Inter-IC sound interface 2 When using I S format, the first bit in a half-frame (containing one left or right sample) gets sampled on the second rising edge of the SCK after a LRCK edge. When using Aligned mode, the first bit in a half-frame gets sampled on the first rising edge of SCK following a LRCK edge. For data being received on SDIN the sample value can be either right or left-aligned inside a half-frame, as specified in CONFIG.ALIGN on page 457. CONFIG.ALIGN on page 457 affects only the decoding of the incoming samples (SDIN), while the outgoing samples (SDOUT) are always left-aligned (or justified). When using left-alignment, each half-frame starts with the MSB of the sample value (both for data being sent on SDOUT and received on SDIN). When using right-alignment, each half-frame of data being received on SDIN ends with the LSB of the sample value, while each half-frame of data being sent on SDOUT starts with the MSB of the sample value (same as for left-alignment). In Master mode, the size of a half-frame (in number of SCK periods) equals the sample width (in number of bits), and in this case the alignment setting does not care as each half-frame in any case will start with the MSB and end with the LSB of the sample value. In slave mode, however, the sample width does not need to equal the frame size. This means you might have extra or fewer SCK pulses per half-frame than what the sample width specified in CONFIG.SWIDTH requires. In the case where we use left-alignment and the number of SCK pulses per half-frame is higher than the sample width, the following will apply: • • For data received on SDIN, all bits after the LSB of the sample value will be discarded. For data sent on SDOUT, all bits after the LSB of the sample value will be 0. In the case where we use left-alignment and the number of SCK pulses per frame is lower than the sample width, the following will apply: • Data sent and received on SDOUT and SDIN will be truncated with the LSBs being removed first. In the case where we use right-alignment and the number of SCK pulses per frame is higher than the sample width, the following will apply: • • For data received on SDIN, all bits before the MSB of the sample value will be discarded. For data sent on SDOUT, all bits after the LSB of the sample value will be 0 (same behavior as for leftalignment). In the case where we use right-alignment and the number of SCK pulses per frame is lower than the sample width, the following will apply: • • Data received on SDIN will be sign-extended to "sample width" number of bits before being written to memory. Data sent on SDOUT will be truncated with the LSBs being removed first (same behavior as for leftalignment). frame left LRCK right left SCK SDIN or SDOUT 2 Figure 132: I S format. CONFIG.SWIDTH equalling half-frame size. frame LRCK left right SCK SDATA Figure 133: Aligned format. CONFIG.SWIDTH equalling half-frame size. Page 448 left 2 44 I S — Inter-IC sound interface 44.7 EasyDMA 2 The I S module implements EasyDMA for accessing internal Data RAM without CPU intervention. The source and destination pointers for the TX and RX data are configured in TXD.PTR on page 458 and RXD.PTR on page 458. The memory pointed to by these pointers will only be read or written when TX or RX are enabled in CONFIG.TXEN on page 455 and CONFIG.RXEN on page 455. The addresses written to the pointer registers TXD.PTR on page 458 and RXD.PTR on page 458 are double-buffered in hardware, and these double buffers are updated for every RXTXD.MAXCNT on page 458 words (containing one or more samples) read/written from/to memory. The events TXPTRUPD and RXPTRUPD are generated whenever the TXD.PTR and RXD.PTR are transferred to these double buffers. If TXD.PTR on page 458 is not pointing to the Data RAM region when transmission is enabled, or RXD.PTR on page 458 is not pointing to the Data RAM region when reception is enabled, an EasyDMA transfer may result in a HardFault and/or memory corruption. See Memory on page 23 for more information about the different memory regions. 2 Due to the nature of I S, where the number of transmitted samples always equals the number of received samples (at least when both TX and RX are enabled), one common register RXTXD.MAXCNT on page 458 is used for specifying the sizes of these two memory buffers. The size of the buffers is specified in a number of 32-bit words. Such a 32-bit memory word can either contain four 8-bit samples, two 16-bit samples or one right-aligned 24-bit sample sign extended to 32 bit. In stereo mode (CONFIG.CHANNELS=Stereo), the samples are stored as "left and right sample pairs" in memory. Figure Figure 134: Memory mapping for 8 bit stereo. CONFIG.SWIDTH = 8Bit, CONFIG.CHANNELS = Stereo. on page 449, Figure 136: Memory mapping for 16 bit stereo. CONFIG.SWIDTH = 16Bit, CONFIG.CHANNELS = Stereo. on page 450 and Figure 138: Memory mapping for 24 bit stereo. CONFIG.SWIDTH = 24Bit, CONFIG.CHANNELS = Stereo. on page 450 show how the samples are mapped to memory in this mode. The mapping is valid for both RX and TX. In mono mode (CONFIG.CHANNELS=Left or Right), RX sample from only one channel in the frame is stored in memory, the other channel sample is ignored. Illustrations Figure 135: Memory mapping for 8 bit mono. CONFIG.SWIDTH = 8Bit, CONFIG.CHANNELS = Left. on page 450, Figure 137: Memory mapping for 16 bit mono, left channel only. CONFIG.SWIDTH = 16Bit, CONFIG.CHANNELS = Left. on page 450 and Figure 139: Memory mapping for 24 bit mono, left channel only. CONFIG.SWIDTH = 24Bit, CONFIG.CHANNELS = Left. on page 451 show how RX samples are mapped to memory in this mode. For TX, the same outgoing sample read from memory is transmitted on both left and right in a frame, resulting in a mono output stream. 31 24 23 16 15 8 7 0 x.PTR Right sample 1 Left sample 1 Right sample 0 Left sample 0 x.PTR + 4 Right sample 3 Left sample 3 Right sample 2 Left sample 2 Left sample n-1 Right sample n-1 Right sample n-2 Left sample n-2 x.PTR + (n*2) - 4 Figure 134: Memory mapping for 8 bit stereo. CONFIG.SWIDTH = 8Bit, CONFIG.CHANNELS = Stereo. Page 449 2 44 I S — Inter-IC sound interface 31 24 23 16 15 8 7 0 x.PTR Left sample 3 Left sample 2 Left sample 1 Left sample 0 x.PTR + 4 Left sample 7 Left sample 6 Left sample 5 Left sample 4 Left sample n-1 Left sample n-2 Left sample n-3 Left sample n-4 x.PTR + n - 4 Figure 135: Memory mapping for 8 bit mono. CONFIG.SWIDTH = 8Bit, CONFIG.CHANNELS = Left. 31 16 15 0 x.PTR Right sample 0 Left sample 0 x.PTR + 4 Right sample 1 Left sample 1 Right sample n - 1 Left sample n - 1 x.PTR + (n*4) - 4 Figure 136: Memory mapping for 16 bit stereo. CONFIG.SWIDTH = 16Bit, CONFIG.CHANNELS = Stereo. 31 16 15 0 x.PTR Left sample 1 Left sample 0 x.PTR + 4 Left sample 3 Left sample 2 Left sample n - 1 Left sample n - 2 x.PTR + (n*2) - 4 Figure 137: Memory mapping for 16 bit mono, left channel only. CONFIG.SWIDTH = 16Bit, CONFIG.CHANNELS = Left. 31 23 0 x.PTR Sign ext. Left sample 0 x.PTR + 4 Sign ext. Right sample 0 x.PTR + (n*8) - 8 Sign ext. Left sample n - 1 x.PTR + (n*8) - 4 Sign ext. Right sample n - 1 Figure 138: Memory mapping for 24 bit stereo. CONFIG.SWIDTH = 24Bit, CONFIG.CHANNELS = Stereo. Page 450 2 44 I S — Inter-IC sound interface 31 23 0 x.PTR Sign ext. Left sample 0 x.PTR + 4 Sign ext. Left sample 1 x.PTR + (n*4) - 4 Sign ext. Left sample n - 1 Figure 139: Memory mapping for 24 bit mono, left channel only. CONFIG.SWIDTH = 24Bit, CONFIG.CHANNELS = Left. 44.8 Module operation 2 Described here is a typical operating procedure for the I S module. 2 1. Configure the I S module using the CONFIG registers // Enable reception NRF_I2S->CONFIG.RXEN = (I2S_CONFIG_RXEN_RXEN_Enabled CONFIG.TXEN = (I2S_CONFIG_TXEN_TXEN_Enabled CONFIG.MCKEN = (I2S_CONFIG_MCKEN_MCKEN_Enabled CONFIG.MCKFREQ = I2S_CONFIG_MCKFREQ_MCKFREQ_32MDIV8 CONFIG.RATIO = I2S_CONFIG_RATIO_RATIO_256X CONFIG.SWIDTH = I2S_CONFIG_SWIDTH_SWIDTH_16Bit CONFIG.ALIGN = I2S_CONFIG_ALIGN_ALIGN_Left CONFIG.FORMAT = I2S_CONFIG_FORMAT_FORMAT_I2S CONFIG.CHANNELS = I2S_CONFIG_CHANNELS_CHANNELS_Stereo PSEL.MCK = (0 EVENTS_TXPTRUPD != 0) { NRF_I2S->TXD.PTR = my_next_tx_buf; NRF_I2S->EVENTS_TXPTRUPD = 0; } if(NRF_I2S->EVENTS_RXPTRUPD != 0) { NRF_I2S->RXD.PTR = my_next_rx_buf; NRF_I2S->EVENTS_RXPTRUPD = 0; } 44.9 Pin configuration 2 The MCK, SCK, LRCK, SDIN and SDOUT signals associated with the I S module are mapped to physical pins according to the pin numbers specified in the PSEL.x registers. 2 These pins are acquired whenever the I S module is enabled through the register ENABLE on page 455. 2 When a pin is acquired by the I S module, the direction of the pin (input or output) will be configured automatically, and any pin direction setting done in the GPIO module will be overridden. The directions for 2 the various I S pins are shown below in Table 107: GPIO configuration before enabling peripheral (master mode) on page 452 and Table 108: GPIO configuration before enabling peripheral (slave mode) on page 453. 2 To secure correct signal levels on the pins when the system is in OFF mode, and when the I S module is disabled, these pins must be configured in the GPIO peripheral directly. Table 107: GPIO configuration before enabling peripheral (master mode) I2S signal MCK LRCK I2S pin As specified in PSEL.MCK As specified in PSEL.LRCK Direction Output Output Page 452 Output value 0 0 Comment 2 44 I S — Inter-IC sound interface I2S signal SCK SDIN SDOUT I2S pin As specified in PSEL.SCK As specified in PSEL.SDIN As specified in PSEL.SDOUT Direction Output Input Output Output value 0 Not applicable 0 Comment Table 108: GPIO configuration before enabling peripheral (slave mode) I2S signal MCK LRCK SCK SDIN SDOUT I2S pin As specified in PSEL.MCK As specified in PSEL.LRCK As specified in PSEL.SCK As specified in PSEL.SDIN As specified in PSEL.SDOUT Direction Output Input Input Input Output Output value 0 Not applicable Not applicable Not applicable 0 Comment 44.10 Registers Table 109: Instances Base address Peripheral Instance Description 0x40025000 I2S I2S Inter-IC Sound Interface Configuration Table 110: Register Overview Register Offset Description TASKS_START 0x000 Starts continuous I2S transfer. Also starts MCK generator when this is enabled. TASKS_STOP 0x004 Stops I2S transfer. Also stops MCK generator. Triggering this task will cause the {event:STOPPED} EVENTS_RXPTRUPD 0x104 event to be generated. The RXD.PTR register has been copied to internal double-buffers. When the I2S module is started and RX is enabled, this event will be generated for every RXTXD.MAXCNT words that are received on the SDIN pin. EVENTS_STOPPED 0x108 I2S transfer stopped. EVENTS_TXPTRUPD 0x114 The TDX.PTR register has been copied to internal double-buffers. When the I2S module is started and TX is enabled, this event will be generated for every RXTXD.MAXCNT words that are sent on the SDOUT pin. INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 Enable I2S module. CONFIG.MODE 0x504 I2S mode. CONFIG.RXEN 0x508 Reception (RX) enable. CONFIG.TXEN 0x50C Transmission (TX) enable. CONFIG.MCKEN 0x510 Master clock generator enable. CONFIG.MCKFREQ 0x514 Master clock generator frequency. CONFIG.RATIO 0x518 MCK / LRCK ratio. CONFIG.SWIDTH 0x51C Sample width. CONFIG.ALIGN 0x520 Alignment of sample within a frame. CONFIG.FORMAT 0x524 Frame format. CONFIG.CHANNELS 0x528 Enable channels. RXD.PTR 0x538 Receive buffer RAM start address. TXD.PTR 0x540 Transmit buffer RAM start address. RXTXD.MAXCNT 0x550 Size of RXD and TXD buffers. PSEL.MCK 0x560 Pin select for MCK signal. PSEL.SCK 0x564 Pin select for SCK signal. PSEL.LRCK 0x568 Pin select for LRCK signal. PSEL.SDIN 0x56C Pin select for SDIN signal. PSEL.SDOUT 0x570 Pin select for SDOUT signal. 44.10.1 INTEN Address offset: 0x300 Enable or disable interrupt Page 453 2 44 I S — Inter-IC sound interface Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id F Reset 0x00000000 Id RW Field B RW RXPTRUPD 0 Value Id C B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for RXPTRUPD event See EVENTS_RXPTRUPD C Disabled 0 Disable Enabled 1 Enable RW STOPPED Enable or disable interrupt for STOPPED event See EVENTS_STOPPED F Disabled 0 Disable Enabled 1 Enable RW TXPTRUPD Enable or disable interrupt for TXPTRUPD event See EVENTS_TXPTRUPD Disabled 0 Disable Enabled 1 Enable 44.10.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id F Reset 0x00000000 Id RW Field B RW RXPTRUPD 0 Value Id C B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for RXPTRUPD event See EVENTS_RXPTRUPD C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TXPTRUPD Write '1' to Enable interrupt for TXPTRUPD event See EVENTS_TXPTRUPD Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 44.10.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id F Reset 0x00000000 Id RW Field B RW RXPTRUPD 0 Value Id Value Description Write '1' to Disable interrupt for RXPTRUPD event See EVENTS_RXPTRUPD C C B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to Disable interrupt for STOPPED event Page 454 2 44 I S — Inter-IC sound interface Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id F Reset 0x00000000 Id RW Field 0 C B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_STOPPED F RW TXPTRUPD Write '1' to Disable interrupt for TXPTRUPD event See EVENTS_TXPTRUPD Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 44.10.4 ENABLE Address offset: 0x500 Enable I2S module. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable Enable I2S module. 44.10.5 CONFIG.MODE Address offset: 0x504 I2S mode. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW MODE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Master 0 Slave 1 Description I2S mode. Master mode. SCK and LRCK generated from internal master clcok (MCK) and output on pins defined by PSEL.xxx. Slave mode. SCK and LRCK generated by external master and received on pins defined by PSEL.xxx 44.10.6 CONFIG.RXEN Address offset: 0x508 Reception (RX) enable. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW RXEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Disabled 0 Enabled 1 Description Reception (RX) enable. Reception disabled and now data will be written to the RXD.PTR address. Reception enabled. 44.10.7 CONFIG.TXEN Address offset: 0x50C Page 455 2 44 I S — Inter-IC sound interface Transmission (TX) enable. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000001 Id RW Field A RW TXEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Disabled 0 Enabled 1 Description Transmission (TX) enable. Transmission disabled and now data will be read from the RXD.TXD address. Transmission enabled. 44.10.8 CONFIG.MCKEN Address offset: 0x510 Master clock generator enable. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000001 Id RW Field A RW MCKEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Disabled 0 Enabled 1 Description Master clock generator enable. Master clock generator disabled and PSEL.MCK not connected(available as GPIO). Master clock generator running and MCK output on PSEL.MCK. 44.10.9 CONFIG.MCKFREQ Address offset: 0x514 Master clock generator frequency. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x20000000 Id RW Field A RW MCKFREQ 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description 32MDIV2 0x80000000 32 MHz / 2 = 16.0 MHz 32MDIV3 0x50000000 32 MHz / 3 = 10.6666667 MHz 32MDIV4 0x40000000 32 MHz / 4 = 8.0 MHz 32MDIV5 0x30000000 32 MHz / 5 = 6.4 MHz 32MDIV6 0x28000000 32 MHz / 6 = 5.3333333 MHz 32MDIV8 0x20000000 32 MHz / 8 = 4.0 MHz 32MDIV10 0x18000000 32 MHz / 10 = 3.2 MHz 32MDIV11 0x16000000 32 MHz / 11 = 2.9090909 MHz 32MDIV15 0x11000000 32 MHz / 15 = 2.1333333 MHz 32MDIV16 0x10000000 32 MHz / 16 = 2.0 MHz 32MDIV21 0x0C000000 32 MHz / 21 = 1.5238095 32MDIV23 0x0B000000 32 MHz / 23 = 1.3913043 MHz 32MDIV30 0x08800000 32 MHz / 30 = 1.0666667 MHz 32MDIV31 0x08400000 32 MHz / 31 = 1.0322581 MHz 32MDIV32 0x08000000 32 MHz / 32 = 1.0 MHz 32MDIV42 0x06000000 32 MHz / 42 = 0.7619048 MHz 32MDIV63 0x04100000 32 MHz / 63 = 0.5079365 MHz 32MDIV125 0x020C0000 32 MHz / 125 = 0.256 MHz Master clock generator frequency. 44.10.10 CONFIG.RATIO Address offset: 0x518 MCK / LRCK ratio. Page 456 2 44 I S — Inter-IC sound interface Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000006 Id RW Field A RW RATIO 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 Value Id Value Description 32X 0 LRCK = MCK / 32 48X 1 LRCK = MCK / 48 64X 2 LRCK = MCK / 64 96X 3 LRCK = MCK / 96 128X 4 LRCK = MCK / 128 192X 5 LRCK = MCK / 192 256X 6 LRCK = MCK / 256 384X 7 LRCK = MCK / 384 512X 8 LRCK = MCK / 512 MCK / LRCK ratio. 44.10.11 CONFIG.SWIDTH Address offset: 0x51C Sample width. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A Reset 0x00000001 Id RW Field A RW SWIDTH 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Id Value Description 8Bit 0 8 bit. 16Bit 1 16 bit. 24Bit 2 24 bit. Sample width. 44.10.12 CONFIG.ALIGN Address offset: 0x520 Alignment of sample within a frame. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ALIGN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Left 0 Left-aligned. Right 1 Right-aligned. Alignment of sample within a frame. 44.10.13 CONFIG.FORMAT Address offset: 0x524 Frame format. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW FORMAT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description I2S 0 Original I2S format. Aligned 1 Alternate (left- or right-aligned) format. Frame format. 44.10.14 CONFIG.CHANNELS Address offset: 0x528 Enable channels. Page 457 2 44 I S — Inter-IC sound interface Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A Reset 0x00000000 Id RW Field A RW CHANNELS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Stereo 0 Stereo. Left 1 Left only. Right 2 Right only. Enable channels. 44.10.15 RXD.PTR Address offset: 0x538 Receive buffer RAM start address. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Receive buffer Data RAM start address. When receiving, words containing samples will be written to this address. This address is a word aligned Data RAM address. 44.10.16 TXD.PTR Address offset: 0x540 Transmit buffer RAM start address. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Transmit buffer Data RAM start address. When transmitting, words containing samples will be fetched from this address. This address is a word aligned Data RAM address. 44.10.17 RXTXD.MAXCNT Address offset: 0x550 Size of RXD and TXD buffers. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW MAXCNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Size of RXD and TXD buffers in number of 32 bit words. 44.10.18 PSEL.MCK Address offset: 0x560 Pin select for MCK signal. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect Page 458 2 44 I S — Inter-IC sound interface 44.10.19 PSEL.SCK Address offset: 0x564 Pin select for SCK signal. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 44.10.20 PSEL.LRCK Address offset: 0x568 Pin select for LRCK signal. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 44.10.21 PSEL.SDIN Address offset: 0x56C Pin select for SDIN signal. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 44.10.22 PSEL.SDOUT Address offset: 0x570 Pin select for SDOUT signal. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect Page 459 2 44 I S — Inter-IC sound interface 44.11 Electrical specification 44.11.1 I2S timing specification Symbol Description Min. tS_SDIN SDIN setup time before SCK rising 20 Typ. Max. Units ns tH_SDIN SDIN hold time after SCK rising 15 ns tS_SDOUT SDOUT setup time after SCK falling 40 ns tH_SDOUT SDOUT hold time before SCK falling 6 tSCK_LRCK SCLK falling to LRCK edge -5 fMCK ns 0 5 ns MCK frequency 4000 kHz fLRCK LRCK frequency 48 kHz fSCK SCK frequency 2000 kHz DCCK Clock duty cycle (MCK, LRCK, SCK) 55 % 45 tSCK_LRCK LRCK SCK tS_SDIN tH_SDIN SDIN tH_SDOUT SDOUT Figure 140: I2S timing diagram Page 460 tS_SDOUT 45 MWU — Memory watch unit 45 MWU — Memory watch unit The Memory watch unit (MWU) can be used to generate events when a memory region is accessed by the CPU. The MWU can be configured to trigger events for access to Data RAM and Peripheral memory segments. The MWU allows an application developer to generate memory access events during development for debugging or during production execution for failure detection and recovery. Listed here are the main features for MWU: • • • • • Six memory regions, four user-configurable and two fixed regions in peripheral address space Flexible configuration of regions with START and END addresses Generate events on CPU read and/or write to a defined region of Data RAM or peripheral memory address space Programmable maskable or non-maskable (NMI) interrupt on events Peripheral interfaces can be watched for read and write access using subregions of the two fixed memory regions Table 111: Memory regions Memory region REGION[0..3] PREGION[0] PREGION[1] START address Configurable 0x40000000 0x40020000 END address Configurable 0x4001FFFF 0x4003FFFF Each MWU region is defined by a start address and an end address, configured by the START and END registers respectively. These addresses are byte aligned and inclusive. The END register value has to be greater or equal to the START register value. Each region is associated with a pair of events that indicate that either a write access or a read access from the CPU has been detected inside the region. For regions containing subregions (see below), a set of status registers PERREGION[0..1].SUBSTATWA and PERREGION[0..1].SUBSTATRA indicate which subregion(s) caused the EVENT_PREGION[0..1].WA and EVENT_PREGION[0..1].RA respectively. The MWU is only able to detect memory accesses in the Data RAM and Peripheral memory segments from the CPU, see Memory on page 23 for more information about the different memory segments. EasyDMA accesses are not monitored by the MWU. The MWU requires two HCLK cycles to detect and generate the event. The peripheral regions, PREGION[0...1], are divided into 32 equally sized subregions, SR[0...31]. All subregions are excluded in the main region by default, and any can be included by specifying them in the SUBS register. When a subregion is excluded from the main region, the memory watch mechanism will not trigger any events when that subregion is accessed. Subregions in PREGION[0..1] cannot be individually configured for read or write access watch. Watch configuration is only possible for a region as a whole. The PRGNiRA and PRGNiWA (i=0..1) fields in the REGIONEN register control watching read and write access. REGION[0..3] can be individually enabled for read and/or write access watching through their respective RGNiRA and RGNiWA (i=0..3) fields in the REGIONEN register. REGIONENSET and REGIONENCLR allow respectively enabling and disabling one or multiple REGIONs or PREGIONs watching in a single write access. 45.1 Registers Table 112: Instances Base address Peripheral Instance Description 0x40020000 MWU MWU Memory Watch Unit Page 461 Configuration 45 MWU — Memory watch unit Table 113: Register Overview Register Offset Description EVENTS_REGION[0].WA 0x100 Write access to region 0 detected EVENTS_REGION[0].RA 0x104 Read access to region 0 detected EVENTS_REGION[1].WA 0x108 Write access to region 1 detected EVENTS_REGION[1].RA 0x10C Read access to region 1 detected EVENTS_REGION[2].WA 0x110 Write access to region 2 detected EVENTS_REGION[2].RA 0x114 Read access to region 2 detected EVENTS_REGION[3].WA 0x118 Write access to region 3 detected EVENTS_REGION[3].RA 0x11C Read access to region 3 detected EVENTS_PREGION[0].WA 0x160 Write access to peripheral region 0 detected EVENTS_PREGION[0].RA 0x164 Read access to peripheral region 0 detected EVENTS_PREGION[1].WA 0x168 Write access to peripheral region 1 detected EVENTS_PREGION[1].RA 0x16C Read access to peripheral region 1 detected INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt NMIEN 0x320 Enable or disable non-maskable interrupt NMIENSET 0x324 Enable non-maskable interrupt NMIENCLR 0x328 Disable non-maskable interrupt PERREGION[0].SUBSTATWA 0x400 Source of event/interrupt in region 0, write access detected while corresponding subregion was enabled for watching PERREGION[0].SUBSTATRA 0x404 Source of event/interrupt in region 0, read access detected while corresponding subregion was enabled for watching PERREGION[1].SUBSTATWA 0x408 Source of event/interrupt in region 1, write access detected while corresponding subregion was enabled for watching PERREGION[1].SUBSTATRA 0x40C Source of event/interrupt in region 1, read access detected while corresponding subregion was enabled for watching REGIONEN 0x510 Enable/disable regions watch REGIONENSET 0x514 Enable regions watch REGIONENCLR 0x518 Disable regions watch REGION[0].START 0x600 Start address for region 0 REGION[0].END 0x604 End address of region 0 REGION[1].START 0x610 Start address for region 1 REGION[1].END 0x614 End address of region 1 REGION[2].START 0x620 Start address for region 2 REGION[2].END 0x624 End address of region 2 REGION[3].START 0x630 Start address for region 3 REGION[3].END 0x634 End address of region 3 PREGION[0].START 0x6C0 Reserved for future use PREGION[0].END 0x6C4 Reserved for future use PREGION[0].SUBS 0x6C8 Subregions of region 0 PREGION[1].START 0x6D0 Reserved for future use PREGION[1].END 0x6D4 Reserved for future use PREGION[1].SUBS 0x6D8 Subregions of region 1 45.1.1 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW REGION0WA 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for REGION[0].WA event See EVENTS_REGION[0].WA Disabled 0 Disable Page 462 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id B RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Enable RW REGION0RA Enable or disable interrupt for REGION[0].RA event See EVENTS_REGION[0].RA C Disabled 0 Disable Enabled 1 Enable RW REGION1WA Enable or disable interrupt for REGION[1].WA event See EVENTS_REGION[1].WA D Disabled 0 Disable Enabled 1 Enable RW REGION1RA Enable or disable interrupt for REGION[1].RA event See EVENTS_REGION[1].RA E Disabled 0 Disable Enabled 1 Enable RW REGION2WA Enable or disable interrupt for REGION[2].WA event See EVENTS_REGION[2].WA F Disabled 0 Disable Enabled 1 Enable RW REGION2RA Enable or disable interrupt for REGION[2].RA event See EVENTS_REGION[2].RA G Disabled 0 Disable Enabled 1 Enable RW REGION3WA Enable or disable interrupt for REGION[3].WA event See EVENTS_REGION[3].WA H Disabled 0 Disable Enabled 1 Enable RW REGION3RA Enable or disable interrupt for REGION[3].RA event See EVENTS_REGION[3].RA I Disabled 0 Disable Enabled 1 Enable RW PREGION0WA Enable or disable interrupt for PREGION[0].WA event See EVENTS_PREGION[0].WA J Disabled 0 Disable Enabled 1 Enable RW PREGION0RA Enable or disable interrupt for PREGION[0].RA event See EVENTS_PREGION[0].RA K Disabled 0 Disable Enabled 1 Enable RW PREGION1WA Enable or disable interrupt for PREGION[1].WA event See EVENTS_PREGION[1].WA L Disabled 0 Disable Enabled 1 Enable RW PREGION1RA Enable or disable interrupt for PREGION[1].RA event See EVENTS_PREGION[1].RA Disabled 0 Disable Enabled 1 Enable 45.1.2 INTENSET Address offset: 0x304 Enable interrupt Page 463 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW REGION0WA 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for REGION[0].WA event See EVENTS_REGION[0].WA B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION0RA Write '1' to Enable interrupt for REGION[0].RA event See EVENTS_REGION[0].RA C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1WA Write '1' to Enable interrupt for REGION[1].WA event See EVENTS_REGION[1].WA D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1RA Write '1' to Enable interrupt for REGION[1].RA event See EVENTS_REGION[1].RA E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2WA Write '1' to Enable interrupt for REGION[2].WA event See EVENTS_REGION[2].WA F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2RA Write '1' to Enable interrupt for REGION[2].RA event See EVENTS_REGION[2].RA G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3WA Write '1' to Enable interrupt for REGION[3].WA event See EVENTS_REGION[3].WA H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3RA Write '1' to Enable interrupt for REGION[3].RA event See EVENTS_REGION[3].RA I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0WA Write '1' to Enable interrupt for PREGION[0].WA event See EVENTS_PREGION[0].WA J Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0RA Write '1' to Enable interrupt for PREGION[0].RA event See EVENTS_PREGION[0].RA K Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION1WA Write '1' to Enable interrupt for PREGION[1].WA event Page 464 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_PREGION[1].WA L RW PREGION1RA Write '1' to Enable interrupt for PREGION[1].RA event See EVENTS_PREGION[1].RA Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 45.1.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW REGION0WA 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for REGION[0].WA event See EVENTS_REGION[0].WA B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION0RA Write '1' to Disable interrupt for REGION[0].RA event See EVENTS_REGION[0].RA C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1WA Write '1' to Disable interrupt for REGION[1].WA event See EVENTS_REGION[1].WA D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1RA Write '1' to Disable interrupt for REGION[1].RA event See EVENTS_REGION[1].RA E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2WA Write '1' to Disable interrupt for REGION[2].WA event See EVENTS_REGION[2].WA F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2RA Write '1' to Disable interrupt for REGION[2].RA event See EVENTS_REGION[2].RA G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3WA Write '1' to Disable interrupt for REGION[3].WA event See EVENTS_REGION[3].WA Clear 1 Disable Page 465 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id H RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3RA Write '1' to Disable interrupt for REGION[3].RA event See EVENTS_REGION[3].RA I Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0WA Write '1' to Disable interrupt for PREGION[0].WA event See EVENTS_PREGION[0].WA J Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0RA Write '1' to Disable interrupt for PREGION[0].RA event See EVENTS_PREGION[0].RA K Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION1WA Write '1' to Disable interrupt for PREGION[1].WA event See EVENTS_PREGION[1].WA L Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION1RA Write '1' to Disable interrupt for PREGION[1].RA event See EVENTS_PREGION[1].RA Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 45.1.4 NMIEN Address offset: 0x320 Enable or disable non-maskable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW REGION0WA 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable non-maskable interrupt for REGION[0].WA event See EVENTS_REGION[0].WA B Disabled 0 Disable Enabled 1 Enable RW REGION0RA Enable or disable non-maskable interrupt for REGION[0].RA event See EVENTS_REGION[0].RA C Disabled 0 Disable Enabled 1 Enable RW REGION1WA Enable or disable non-maskable interrupt for REGION[1].WA event See EVENTS_REGION[1].WA Disabled 0 Disable Enabled 1 Enable Page 466 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field D RW REGION1RA 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable non-maskable interrupt for REGION[1].RA event See EVENTS_REGION[1].RA E Disabled 0 Disable Enabled 1 Enable RW REGION2WA Enable or disable non-maskable interrupt for REGION[2].WA event See EVENTS_REGION[2].WA F Disabled 0 Disable Enabled 1 Enable RW REGION2RA Enable or disable non-maskable interrupt for REGION[2].RA event See EVENTS_REGION[2].RA G Disabled 0 Disable Enabled 1 Enable RW REGION3WA Enable or disable non-maskable interrupt for REGION[3].WA event See EVENTS_REGION[3].WA H Disabled 0 Disable Enabled 1 Enable RW REGION3RA Enable or disable non-maskable interrupt for REGION[3].RA event See EVENTS_REGION[3].RA I Disabled 0 Disable Enabled 1 Enable RW PREGION0WA Enable or disable non-maskable interrupt for PREGION[0].WA event See EVENTS_PREGION[0].WA J Disabled 0 Disable Enabled 1 Enable RW PREGION0RA Enable or disable non-maskable interrupt for PREGION[0].RA event See EVENTS_PREGION[0].RA K Disabled 0 Disable Enabled 1 Enable RW PREGION1WA Enable or disable non-maskable interrupt for PREGION[1].WA event See EVENTS_PREGION[1].WA L Disabled 0 Disable Enabled 1 Enable RW PREGION1RA Enable or disable non-maskable interrupt for PREGION[1].RA event See EVENTS_PREGION[1].RA Disabled 0 Disable Enabled 1 Enable 45.1.5 NMIENSET Address offset: 0x324 Enable non-maskable interrupt Page 467 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW REGION0WA 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable non-maskable interrupt for REGION[0].WA event See EVENTS_REGION[0].WA B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION0RA Write '1' to Enable non-maskable interrupt for REGION[0].RA event See EVENTS_REGION[0].RA C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1WA Write '1' to Enable non-maskable interrupt for REGION[1].WA event See EVENTS_REGION[1].WA D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1RA Write '1' to Enable non-maskable interrupt for REGION[1].RA event See EVENTS_REGION[1].RA E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2WA Write '1' to Enable non-maskable interrupt for REGION[2].WA event See EVENTS_REGION[2].WA F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2RA Write '1' to Enable non-maskable interrupt for REGION[2].RA event See EVENTS_REGION[2].RA G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3WA Write '1' to Enable non-maskable interrupt for REGION[3].WA event See EVENTS_REGION[3].WA H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3RA Write '1' to Enable non-maskable interrupt for REGION[3].RA event See EVENTS_REGION[3].RA I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0WA Write '1' to Enable non-maskable interrupt for PREGION[0].WA event See EVENTS_PREGION[0].WA Page 468 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id J RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0RA Write '1' to Enable non-maskable interrupt for PREGION[0].RA event See EVENTS_PREGION[0].RA K Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION1WA Write '1' to Enable non-maskable interrupt for PREGION[1].WA event See EVENTS_PREGION[1].WA L Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION1RA Write '1' to Enable non-maskable interrupt for PREGION[1].RA event See EVENTS_PREGION[1].RA Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 45.1.6 NMIENCLR Address offset: 0x328 Disable non-maskable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW REGION0WA 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable non-maskable interrupt for REGION[0].WA event See EVENTS_REGION[0].WA B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION0RA Write '1' to Disable non-maskable interrupt for REGION[0].RA event See EVENTS_REGION[0].RA C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1WA Write '1' to Disable non-maskable interrupt for REGION[1].WA event See EVENTS_REGION[1].WA D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION1RA Write '1' to Disable non-maskable interrupt for REGION[1].RA event See EVENTS_REGION[1].RA Page 469 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id E RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2WA Write '1' to Disable non-maskable interrupt for REGION[2].WA event See EVENTS_REGION[2].WA F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION2RA Write '1' to Disable non-maskable interrupt for REGION[2].RA event See EVENTS_REGION[2].RA G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3WA Write '1' to Disable non-maskable interrupt for REGION[3].WA event See EVENTS_REGION[3].WA H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REGION3RA Write '1' to Disable non-maskable interrupt for REGION[3].RA event See EVENTS_REGION[3].RA I Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0WA Write '1' to Disable non-maskable interrupt for PREGION[0].WA event See EVENTS_PREGION[0].WA J Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION0RA Write '1' to Disable non-maskable interrupt for PREGION[0].RA event See EVENTS_PREGION[0].RA K Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION1WA Write '1' to Disable non-maskable interrupt for PREGION[1].WA event See EVENTS_PREGION[1].WA L Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PREGION1RA Write '1' to Disable non-maskable interrupt for PREGION[1].RA event See EVENTS_PREGION[1].RA Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Page 470 45 MWU — Memory watch unit 45.1.7 PERREGION[0].SUBSTATWA Address offset: 0x400 Source of event/interrupt in region 0, write access detected while corresponding subregion was enabled for watching Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW SR0 B C D E F G H I J K L M N O P Q Value Id Value Description NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion Subregion 0 in region 0 (write '1' to clear) RW SR1 Subregion 1 in region 0 (write '1' to clear) RW SR2 Subregion 2 in region 0 (write '1' to clear) RW SR3 Subregion 3 in region 0 (write '1' to clear) RW SR4 Subregion 4 in region 0 (write '1' to clear) RW SR5 Subregion 5 in region 0 (write '1' to clear) RW SR6 Subregion 6 in region 0 (write '1' to clear) RW SR7 Subregion 7 in region 0 (write '1' to clear) RW SR8 Subregion 8 in region 0 (write '1' to clear) RW SR9 Subregion 9 in region 0 (write '1' to clear) RW SR10 Subregion 10 in region 0 (write '1' to clear) RW SR11 Subregion 11 in region 0 (write '1' to clear) RW SR12 Subregion 12 in region 0 (write '1' to clear) RW SR13 Subregion 13 in region 0 (write '1' to clear) RW SR14 Subregion 14 in region 0 (write '1' to clear) RW SR15 Subregion 15 in region 0 (write '1' to clear) RW SR16 Subregion 16 in region 0 (write '1' to clear) Page 471 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id R S T U V W X Y Z a b c d e f RW Field Value Id Value Description NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion RW SR17 I H G F E D C B A Subregion 17 in region 0 (write '1' to clear) RW SR18 Subregion 18 in region 0 (write '1' to clear) RW SR19 Subregion 19 in region 0 (write '1' to clear) RW SR20 Subregion 20 in region 0 (write '1' to clear) RW SR21 Subregion 21 in region 0 (write '1' to clear) RW SR22 Subregion 22 in region 0 (write '1' to clear) RW SR23 Subregion 23 in region 0 (write '1' to clear) RW SR24 Subregion 24 in region 0 (write '1' to clear) RW SR25 Subregion 25 in region 0 (write '1' to clear) RW SR26 Subregion 26 in region 0 (write '1' to clear) RW SR27 Subregion 27 in region 0 (write '1' to clear) RW SR28 Subregion 28 in region 0 (write '1' to clear) RW SR29 Subregion 29 in region 0 (write '1' to clear) RW SR30 Subregion 30 in region 0 (write '1' to clear) RW SR31 Subregion 31 in region 0 (write '1' to clear) 45.1.8 PERREGION[0].SUBSTATRA Address offset: 0x404 Source of event/interrupt in region 0, read access detected while corresponding subregion was enabled for watching Page 472 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW SR0 B C D E F G H I J K L M N O P Q R S Value Id Value Description NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion Subregion 0 in region 0 (write '1' to clear) RW SR1 Subregion 1 in region 0 (write '1' to clear) RW SR2 Subregion 2 in region 0 (write '1' to clear) RW SR3 Subregion 3 in region 0 (write '1' to clear) RW SR4 Subregion 4 in region 0 (write '1' to clear) RW SR5 Subregion 5 in region 0 (write '1' to clear) RW SR6 Subregion 6 in region 0 (write '1' to clear) RW SR7 Subregion 7 in region 0 (write '1' to clear) RW SR8 Subregion 8 in region 0 (write '1' to clear) RW SR9 Subregion 9 in region 0 (write '1' to clear) RW SR10 Subregion 10 in region 0 (write '1' to clear) RW SR11 Subregion 11 in region 0 (write '1' to clear) RW SR12 Subregion 12 in region 0 (write '1' to clear) RW SR13 Subregion 13 in region 0 (write '1' to clear) RW SR14 Subregion 14 in region 0 (write '1' to clear) RW SR15 Subregion 15 in region 0 (write '1' to clear) RW SR16 Subregion 16 in region 0 (write '1' to clear) RW SR17 Subregion 17 in region 0 (write '1' to clear) RW SR18 Subregion 18 in region 0 (write '1' to clear) Page 473 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id T U V W X Y Z a b c d e f RW Field Value Id Value Description NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion RW SR19 I H G F E D C B A Subregion 19 in region 0 (write '1' to clear) RW SR20 Subregion 20 in region 0 (write '1' to clear) RW SR21 Subregion 21 in region 0 (write '1' to clear) RW SR22 Subregion 22 in region 0 (write '1' to clear) RW SR23 Subregion 23 in region 0 (write '1' to clear) RW SR24 Subregion 24 in region 0 (write '1' to clear) RW SR25 Subregion 25 in region 0 (write '1' to clear) RW SR26 Subregion 26 in region 0 (write '1' to clear) RW SR27 Subregion 27 in region 0 (write '1' to clear) RW SR28 Subregion 28 in region 0 (write '1' to clear) RW SR29 Subregion 29 in region 0 (write '1' to clear) RW SR30 Subregion 30 in region 0 (write '1' to clear) RW SR31 Subregion 31 in region 0 (write '1' to clear) 45.1.9 PERREGION[1].SUBSTATWA Address offset: 0x408 Source of event/interrupt in region 1, write access detected while corresponding subregion was enabled for watching Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW SR0 Value Id Value Description NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion Subregion 0 in region 1 (write '1' to clear) Page 474 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field B RW SR1 C D E F G H I J K L M N O P Q R S T Value Id Value Description NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion Subregion 1 in region 1 (write '1' to clear) RW SR2 Subregion 2 in region 1 (write '1' to clear) RW SR3 Subregion 3 in region 1 (write '1' to clear) RW SR4 Subregion 4 in region 1 (write '1' to clear) RW SR5 Subregion 5 in region 1 (write '1' to clear) RW SR6 Subregion 6 in region 1 (write '1' to clear) RW SR7 Subregion 7 in region 1 (write '1' to clear) RW SR8 Subregion 8 in region 1 (write '1' to clear) RW SR9 Subregion 9 in region 1 (write '1' to clear) RW SR10 Subregion 10 in region 1 (write '1' to clear) RW SR11 Subregion 11 in region 1 (write '1' to clear) RW SR12 Subregion 12 in region 1 (write '1' to clear) RW SR13 Subregion 13 in region 1 (write '1' to clear) RW SR14 Subregion 14 in region 1 (write '1' to clear) RW SR15 Subregion 15 in region 1 (write '1' to clear) RW SR16 Subregion 16 in region 1 (write '1' to clear) RW SR17 Subregion 17 in region 1 (write '1' to clear) RW SR18 Subregion 18 in region 1 (write '1' to clear) RW SR19 Subregion 19 in region 1 (write '1' to clear) Page 475 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id U V W X Y Z a b c d e f RW Field Value Id Value Description NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion NoAccess 0 No write access occurred in this subregion Access 1 Write access(es) occurred in this subregion RW SR20 I H G F E D C B A Subregion 20 in region 1 (write '1' to clear) RW SR21 Subregion 21 in region 1 (write '1' to clear) RW SR22 Subregion 22 in region 1 (write '1' to clear) RW SR23 Subregion 23 in region 1 (write '1' to clear) RW SR24 Subregion 24 in region 1 (write '1' to clear) RW SR25 Subregion 25 in region 1 (write '1' to clear) RW SR26 Subregion 26 in region 1 (write '1' to clear) RW SR27 Subregion 27 in region 1 (write '1' to clear) RW SR28 Subregion 28 in region 1 (write '1' to clear) RW SR29 Subregion 29 in region 1 (write '1' to clear) RW SR30 Subregion 30 in region 1 (write '1' to clear) RW SR31 Subregion 31 in region 1 (write '1' to clear) 45.1.10 PERREGION[1].SUBSTATRA Address offset: 0x40C Source of event/interrupt in region 1, read access detected while corresponding subregion was enabled for watching Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW SR0 B Value Id Value Description NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion Subregion 0 in region 1 (write '1' to clear) RW SR1 Subregion 1 in region 1 (write '1' to clear) Page 476 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field C RW SR2 D E F G H I J K L M N O P Q R S T U Value Id Value Description NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion Subregion 2 in region 1 (write '1' to clear) RW SR3 Subregion 3 in region 1 (write '1' to clear) RW SR4 Subregion 4 in region 1 (write '1' to clear) RW SR5 Subregion 5 in region 1 (write '1' to clear) RW SR6 Subregion 6 in region 1 (write '1' to clear) RW SR7 Subregion 7 in region 1 (write '1' to clear) RW SR8 Subregion 8 in region 1 (write '1' to clear) RW SR9 Subregion 9 in region 1 (write '1' to clear) RW SR10 Subregion 10 in region 1 (write '1' to clear) RW SR11 Subregion 11 in region 1 (write '1' to clear) RW SR12 Subregion 12 in region 1 (write '1' to clear) RW SR13 Subregion 13 in region 1 (write '1' to clear) RW SR14 Subregion 14 in region 1 (write '1' to clear) RW SR15 Subregion 15 in region 1 (write '1' to clear) RW SR16 Subregion 16 in region 1 (write '1' to clear) RW SR17 Subregion 17 in region 1 (write '1' to clear) RW SR18 Subregion 18 in region 1 (write '1' to clear) RW SR19 Subregion 19 in region 1 (write '1' to clear) RW SR20 Subregion 20 in region 1 (write '1' to clear) Page 477 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id V W X Y Z a b c d e f RW Field Value Id Value Description NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion NoAccess 0 No read access occurred in this subregion Access 1 Read access(es) occurred in this subregion RW SR21 I H G F E D C B A Subregion 21 in region 1 (write '1' to clear) RW SR22 Subregion 22 in region 1 (write '1' to clear) RW SR23 Subregion 23 in region 1 (write '1' to clear) RW SR24 Subregion 24 in region 1 (write '1' to clear) RW SR25 Subregion 25 in region 1 (write '1' to clear) RW SR26 Subregion 26 in region 1 (write '1' to clear) RW SR27 Subregion 27 in region 1 (write '1' to clear) RW SR28 Subregion 28 in region 1 (write '1' to clear) RW SR29 Subregion 29 in region 1 (write '1' to clear) RW SR30 Subregion 30 in region 1 (write '1' to clear) RW SR31 Subregion 31 in region 1 (write '1' to clear) 45.1.11 REGIONEN Address offset: 0x510 Enable/disable regions watch Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW RGN0WA B C D 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disable 0 Disable write access watch in this region Enable 1 Enable write access watch in this region Disable 0 Disable read access watch in this region Enable 1 Enable read access watch in this region Disable 0 Disable write access watch in this region Enable 1 Enable write access watch in this region Enable/disable write access watch in region[0] RW RGN0RA Enable/disable read access watch in region[0] RW RGN1WA Enable/disable write access watch in region[1] RW RGN1RA Enable/disable read access watch in region[1] Page 478 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id E F G H I J K L RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disable 0 Disable read access watch in this region Enable 1 Enable read access watch in this region Disable 0 Disable write access watch in this region Enable 1 Enable write access watch in this region Disable 0 Disable read access watch in this region Enable 1 Enable read access watch in this region Disable 0 Disable write access watch in this region Enable 1 Enable write access watch in this region Disable 0 Disable read access watch in this region Enable 1 Enable read access watch in this region Disable 0 Disable write access watch in this PREGION Enable 1 Enable write access watch in this PREGION Disable 0 Disable read access watch in this PREGION Enable 1 Enable read access watch in this PREGION Disable 0 Disable write access watch in this PREGION Enable 1 Enable write access watch in this PREGION Disable 0 Disable read access watch in this PREGION Enable 1 Enable read access watch in this PREGION RW RGN2WA Enable/disable write access watch in region[2] RW RGN2RA Enable/disable read access watch in region[2] RW RGN3WA Enable/disable write access watch in region[3] RW RGN3RA Enable/disable read access watch in region[3] RW PRGN0WA Enable/disable write access watch in PREGION[0] RW PRGN0RA Enable/disable read access watch in PREGION[0] RW PRGN1WA Enable/disable write access watch in PREGION[1] RW PRGN1RA Enable/disable read access watch in PREGION[1] 45.1.12 REGIONENSET Address offset: 0x514 Enable regions watch Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW RGN0WA B C D E 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable write access watch in this region Disabled 0 Write access watch in this region is disabled Enabled 1 Write access watch in this region is enabled Set 1 Enable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Set 1 Enable write access watch in this region Disabled 0 Write access watch in this region is disabled Enabled 1 Write access watch in this region is enabled Set 1 Enable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Set 1 Enable write access watch in this region Disabled 0 Write access watch in this region is disabled Enable write access watch in region[0] RW RGN0RA Enable read access watch in region[0] RW RGN1WA Enable write access watch in region[1] RW RGN1RA Enable read access watch in region[1] RW RGN2WA Enable write access watch in region[2] Page 479 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id F G H I J K L RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Write access watch in this region is enabled Set 1 Enable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Set 1 Enable write access watch in this region Disabled 0 Write access watch in this region is disabled Enabled 1 Write access watch in this region is enabled Set 1 Enable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Set 1 Enable write access watch in this PREGION Disabled 0 Write access watch in this PREGION is disabled Enabled 1 Write access watch in this PREGION is enabled Set 1 Enable read access watch in this PREGION Disabled 0 Read access watch in this PREGION is disabled Enabled 1 Read access watch in this PREGION is enabled Set 1 Enable write access watch in this PREGION Disabled 0 Write access watch in this PREGION is disabled Enabled 1 Write access watch in this PREGION is enabled Set 1 Enable read access watch in this PREGION Disabled 0 Read access watch in this PREGION is disabled Enabled 1 Read access watch in this PREGION is enabled RW RGN2RA Enable read access watch in region[2] RW RGN3WA Enable write access watch in region[3] RW RGN3RA Enable read access watch in region[3] RW PRGN0WA Enable write access watch in PREGION[0] RW PRGN0RA Enable read access watch in PREGION[0] RW PRGN1WA Enable write access watch in PREGION[1] RW PRGN1RA Enable read access watch in PREGION[1] 45.1.13 REGIONENCLR Address offset: 0x518 Disable regions watch Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field A RW RGN0WA B C D 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable write access watch in this region Disabled 0 Write access watch in this region is disabled Enabled 1 Write access watch in this region is enabled Clear 1 Disable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Clear 1 Disable write access watch in this region Disabled 0 Write access watch in this region is disabled Enabled 1 Write access watch in this region is enabled Clear 1 Disable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Disable write access watch in region[0] RW RGN0RA Disable read access watch in region[0] RW RGN1WA Disable write access watch in region[1] RW RGN1RA Disable read access watch in region[1] Page 480 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id L K J Reset 0x00000000 Id RW Field E RW RGN2WA F G H I J K L 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable write access watch in this region Disabled 0 Write access watch in this region is disabled Enabled 1 Write access watch in this region is enabled Clear 1 Disable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Clear 1 Disable write access watch in this region Disabled 0 Write access watch in this region is disabled Enabled 1 Write access watch in this region is enabled Clear 1 Disable read access watch in this region Disabled 0 Read access watch in this region is disabled Enabled 1 Read access watch in this region is enabled Clear 1 Disable write access watch in this PREGION Disabled 0 Write access watch in this PREGION is disabled Enabled 1 Write access watch in this PREGION is enabled Clear 1 Disable read access watch in this PREGION Disabled 0 Read access watch in this PREGION is disabled Enabled 1 Read access watch in this PREGION is enabled Clear 1 Disable write access watch in this PREGION Disabled 0 Write access watch in this PREGION is disabled Enabled 1 Write access watch in this PREGION is enabled Clear 1 Disable read access watch in this PREGION Disabled 0 Read access watch in this PREGION is disabled Enabled 1 Read access watch in this PREGION is enabled Disable write access watch in region[2] RW RGN2RA Disable read access watch in region[2] RW RGN3WA Disable write access watch in region[3] RW RGN3RA Disable read access watch in region[3] RW PRGN0WA Disable write access watch in PREGION[0] RW PRGN0RA Disable read access watch in PREGION[0] RW PRGN1WA Disable write access watch in PREGION[1] RW PRGN1RA Disable read access watch in PREGION[1] 45.1.14 REGION[0].START Address offset: 0x600 Start address for region 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW START 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Start address for region 45.1.15 REGION[0].END Address offset: 0x604 End address of region 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW END 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description End address of region. Page 481 45 MWU — Memory watch unit 45.1.16 REGION[1].START Address offset: 0x610 Start address for region 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW START 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Start address for region 45.1.17 REGION[1].END Address offset: 0x614 End address of region 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW END 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description End address of region. 45.1.18 REGION[2].START Address offset: 0x620 Start address for region 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW START 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Start address for region 45.1.19 REGION[2].END Address offset: 0x624 End address of region 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW END 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description End address of region. 45.1.20 REGION[3].START Address offset: 0x630 Start address for region 3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW START 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Start address for region 45.1.21 REGION[3].END Address offset: 0x634 End address of region 3 Page 482 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW END 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description End address of region. 45.1.22 PREGION[0].START Address offset: 0x6C0 Reserved for future use Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description START Reserved for future use 45.1.23 PREGION[0].END Address offset: 0x6C4 Reserved for future use Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description END Reserved for future use 45.1.24 PREGION[0].SUBS Address offset: 0x6C8 Subregions of region 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW SR0 B C D E F G Value Id Value Description Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Include or exclude subregion 0 in region RW SR1 Include or exclude subregion 1 in region RW SR2 Include or exclude subregion 2 in region RW SR3 Include or exclude subregion 3 in region RW SR4 Include or exclude subregion 4 in region RW SR5 Include or exclude subregion 5 in region RW SR6 Include or exclude subregion 6 in region Page 483 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field H RW SR7 I J K L M N O P Q R S T U V W X Y Z Value Id Value Description Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Include or exclude subregion 7 in region RW SR8 Include or exclude subregion 8 in region RW SR9 Include or exclude subregion 9 in region RW SR10 Include or exclude subregion 10 in region RW SR11 Include or exclude subregion 11 in region RW SR12 Include or exclude subregion 12 in region RW SR13 Include or exclude subregion 13 in region RW SR14 Include or exclude subregion 14 in region RW SR15 Include or exclude subregion 15 in region RW SR16 Include or exclude subregion 16 in region RW SR17 Include or exclude subregion 17 in region RW SR18 Include or exclude subregion 18 in region RW SR19 Include or exclude subregion 19 in region RW SR20 Include or exclude subregion 20 in region RW SR21 Include or exclude subregion 21 in region RW SR22 Include or exclude subregion 22 in region RW SR23 Include or exclude subregion 23 in region RW SR24 Include or exclude subregion 24 in region RW SR25 Include or exclude subregion 25 in region Page 484 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id a b c d e f RW Field Value Id Value Description Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include RW SR26 I H G F E D C B A Include or exclude subregion 26 in region RW SR27 Include or exclude subregion 27 in region RW SR28 Include or exclude subregion 28 in region RW SR29 Include or exclude subregion 29 in region RW SR30 Include or exclude subregion 30 in region RW SR31 Include or exclude subregion 31 in region 45.1.25 PREGION[1].START Address offset: 0x6D0 Reserved for future use Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description START Reserved for future use 45.1.26 PREGION[1].END Address offset: 0x6D4 Reserved for future use Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description END Reserved for future use 45.1.27 PREGION[1].SUBS Address offset: 0x6D8 Subregions of region 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field A RW SR0 Value Id Value Exclude 0 Description Include or exclude subregion 0 in region Exclude Page 485 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id B C D E F G H I J K L M N O P Q R S RW Field Value Id Value Description Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include RW SR1 Include or exclude subregion 1 in region RW SR2 Include or exclude subregion 2 in region RW SR3 Include or exclude subregion 3 in region RW SR4 Include or exclude subregion 4 in region RW SR5 Include or exclude subregion 5 in region RW SR6 Include or exclude subregion 6 in region RW SR7 Include or exclude subregion 7 in region RW SR8 Include or exclude subregion 8 in region RW SR9 Include or exclude subregion 9 in region RW SR10 Include or exclude subregion 10 in region RW SR11 Include or exclude subregion 11 in region RW SR12 Include or exclude subregion 12 in region RW SR13 Include or exclude subregion 13 in region RW SR14 Include or exclude subregion 14 in region RW SR15 Include or exclude subregion 15 in region RW SR16 Include or exclude subregion 16 in region RW SR17 Include or exclude subregion 17 in region RW SR18 Include or exclude subregion 18 in region Page 486 I H G F E D C B A 45 MWU — Memory watch unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id f e d c b a Z Y X W V U T S R Q P O N M L K J Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Id RW Field T RW SR19 U V W X Y Z a b c d e f Value Id Value Description Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Exclude 0 Exclude Include 1 Include Include or exclude subregion 19 in region RW SR20 Include or exclude subregion 20 in region RW SR21 Include or exclude subregion 21 in region RW SR22 Include or exclude subregion 22 in region RW SR23 Include or exclude subregion 23 in region RW SR24 Include or exclude subregion 24 in region RW SR25 Include or exclude subregion 25 in region RW SR26 Include or exclude subregion 26 in region RW SR27 Include or exclude subregion 27 in region RW SR28 Include or exclude subregion 28 in region RW SR29 Include or exclude subregion 29 in region RW SR30 Include or exclude subregion 30 in region RW SR31 Include or exclude subregion 31 in region Page 487 I H G F E D C B A 46 EGU — Event generator unit 46 EGU — Event generator unit The Event generator unit (EGU) provides support for inter-layer signaling. This means support for atomic triggering of both CPU execution and hardware tasks from both firmware (by CPU) and hardware (by PPI). This feature can, for instance, be used for triggering CPU execution at a lower priority execution from a higher priority execution, or to handle a peripheral's ISR execution at a lower priority for some of its events. However, triggering any priority from any priority is possible. Listed here are the main EGU features: • • • Enables SW triggering of interrupts 6 EGU instances – separate interrupt vectors Up to 16 separate event flags per interrupt for multiplexing The EGU implements a set of tasks which can individually be triggered to generate the corresponding event, i.e., the corresponding event for TASKS_TRIGGER[n] is EVENTS_TRIGGERED[n]. Table 114: EGU configuration EGU instance 0-5 Number of event flags 16 46.1 Registers Table 115: Instances Base address Peripheral Instance Description 0x40014000 EGU EGU0 Event Generator Unit 0 0x40015000 EGU EGU1 Event Generator Unit 1 0x40016000 EGU EGU2 Event Generator Unit 2 0x40017000 EGU EGU3 Event Generator Unit 3 0x40018000 EGU EGU4 Event Generator Unit 4 0x40019000 EGU EGU5 Event Generator Unit 5 Configuration Table 116: Register Overview Register Offset Description TASKS_TRIGGER[0] 0x000 Trigger 0 for triggering the corresponding TRIGGERED[0] event TASKS_TRIGGER[1] 0x004 Trigger 1 for triggering the corresponding TRIGGERED[1] event TASKS_TRIGGER[2] 0x008 Trigger 2 for triggering the corresponding TRIGGERED[2] event TASKS_TRIGGER[3] 0x00C Trigger 3 for triggering the corresponding TRIGGERED[3] event TASKS_TRIGGER[4] 0x010 Trigger 4 for triggering the corresponding TRIGGERED[4] event TASKS_TRIGGER[5] 0x014 Trigger 5 for triggering the corresponding TRIGGERED[5] event TASKS_TRIGGER[6] 0x018 Trigger 6 for triggering the corresponding TRIGGERED[6] event TASKS_TRIGGER[7] 0x01C Trigger 7 for triggering the corresponding TRIGGERED[7] event TASKS_TRIGGER[8] 0x020 Trigger 8 for triggering the corresponding TRIGGERED[8] event TASKS_TRIGGER[9] 0x024 Trigger 9 for triggering the corresponding TRIGGERED[9] event TASKS_TRIGGER[10] 0x028 Trigger 10 for triggering the corresponding TRIGGERED[10] event TASKS_TRIGGER[11] 0x02C Trigger 11 for triggering the corresponding TRIGGERED[11] event TASKS_TRIGGER[12] 0x030 Trigger 12 for triggering the corresponding TRIGGERED[12] event TASKS_TRIGGER[13] 0x034 Trigger 13 for triggering the corresponding TRIGGERED[13] event TASKS_TRIGGER[14] 0x038 Trigger 14 for triggering the corresponding TRIGGERED[14] event TASKS_TRIGGER[15] 0x03C Trigger 15 for triggering the corresponding TRIGGERED[15] event EVENTS_TRIGGERED[0] 0x100 Event number 0 generated by triggering the corresponding TRIGGER[0] task EVENTS_TRIGGERED[1] 0x104 Event number 1 generated by triggering the corresponding TRIGGER[1] task EVENTS_TRIGGERED[2] 0x108 Event number 2 generated by triggering the corresponding TRIGGER[2] task EVENTS_TRIGGERED[3] 0x10C Event number 3 generated by triggering the corresponding TRIGGER[3] task EVENTS_TRIGGERED[4] 0x110 Event number 4 generated by triggering the corresponding TRIGGER[4] task Page 488 46 EGU — Event generator unit Register Offset Description EVENTS_TRIGGERED[5] 0x114 Event number 5 generated by triggering the corresponding TRIGGER[5] task EVENTS_TRIGGERED[6] 0x118 Event number 6 generated by triggering the corresponding TRIGGER[6] task EVENTS_TRIGGERED[7] 0x11C Event number 7 generated by triggering the corresponding TRIGGER[7] task EVENTS_TRIGGERED[8] 0x120 Event number 8 generated by triggering the corresponding TRIGGER[8] task EVENTS_TRIGGERED[9] 0x124 Event number 9 generated by triggering the corresponding TRIGGER[9] task EVENTS_TRIGGERED[10] 0x128 Event number 10 generated by triggering the corresponding TRIGGER[10] task EVENTS_TRIGGERED[11] 0x12C Event number 11 generated by triggering the corresponding TRIGGER[11] task EVENTS_TRIGGERED[12] 0x130 Event number 12 generated by triggering the corresponding TRIGGER[12] task EVENTS_TRIGGERED[13] 0x134 Event number 13 generated by triggering the corresponding TRIGGER[13] task EVENTS_TRIGGERED[14] 0x138 Event number 14 generated by triggering the corresponding TRIGGER[14] task EVENTS_TRIGGERED[15] 0x13C Event number 15 generated by triggering the corresponding TRIGGER[15] task INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt 46.1.1 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id RW Field A RW TRIGGERED0 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for TRIGGERED[0] event See EVENTS_TRIGGERED[0] B Disabled 0 Disable Enabled 1 Enable RW TRIGGERED1 Enable or disable interrupt for TRIGGERED[1] event See EVENTS_TRIGGERED[1] C Disabled 0 Disable Enabled 1 Enable RW TRIGGERED2 Enable or disable interrupt for TRIGGERED[2] event See EVENTS_TRIGGERED[2] D Disabled 0 Disable Enabled 1 Enable RW TRIGGERED3 Enable or disable interrupt for TRIGGERED[3] event See EVENTS_TRIGGERED[3] E Disabled 0 Disable Enabled 1 Enable RW TRIGGERED4 Enable or disable interrupt for TRIGGERED[4] event See EVENTS_TRIGGERED[4] F Disabled 0 Disable Enabled 1 Enable RW TRIGGERED5 Enable or disable interrupt for TRIGGERED[5] event See EVENTS_TRIGGERED[5] G Disabled 0 Disable Enabled 1 Enable RW TRIGGERED6 Enable or disable interrupt for TRIGGERED[6] event See EVENTS_TRIGGERED[6] H Disabled 0 Disable Enabled 1 Enable RW TRIGGERED7 Enable or disable interrupt for TRIGGERED[7] event See EVENTS_TRIGGERED[7] Disabled 0 Disable Page 489 46 EGU — Event generator unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id I RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Enable RW TRIGGERED8 Enable or disable interrupt for TRIGGERED[8] event See EVENTS_TRIGGERED[8] J Disabled 0 Disable Enabled 1 Enable RW TRIGGERED9 Enable or disable interrupt for TRIGGERED[9] event See EVENTS_TRIGGERED[9] K Disabled 0 Disable Enabled 1 Enable RW TRIGGERED10 Enable or disable interrupt for TRIGGERED[10] event See EVENTS_TRIGGERED[10] L Disabled 0 Disable Enabled 1 Enable RW TRIGGERED11 Enable or disable interrupt for TRIGGERED[11] event See EVENTS_TRIGGERED[11] M Disabled 0 Disable Enabled 1 Enable RW TRIGGERED12 Enable or disable interrupt for TRIGGERED[12] event See EVENTS_TRIGGERED[12] N Disabled 0 Disable Enabled 1 Enable RW TRIGGERED13 Enable or disable interrupt for TRIGGERED[13] event See EVENTS_TRIGGERED[13] O Disabled 0 Disable Enabled 1 Enable RW TRIGGERED14 Enable or disable interrupt for TRIGGERED[14] event See EVENTS_TRIGGERED[14] P Disabled 0 Disable Enabled 1 Enable RW TRIGGERED15 Enable or disable interrupt for TRIGGERED[15] event See EVENTS_TRIGGERED[15] Disabled 0 Disable Enabled 1 Enable 46.1.2 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id RW Field A RW TRIGGERED0 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for TRIGGERED[0] event See EVENTS_TRIGGERED[0] B Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED1 Write '1' to Enable interrupt for TRIGGERED[1] event See EVENTS_TRIGGERED[1] Set 1 Enable Page 490 46 EGU — Event generator unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id C RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED2 Write '1' to Enable interrupt for TRIGGERED[2] event See EVENTS_TRIGGERED[2] D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED3 Write '1' to Enable interrupt for TRIGGERED[3] event See EVENTS_TRIGGERED[3] E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED4 Write '1' to Enable interrupt for TRIGGERED[4] event See EVENTS_TRIGGERED[4] F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED5 Write '1' to Enable interrupt for TRIGGERED[5] event See EVENTS_TRIGGERED[5] G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED6 Write '1' to Enable interrupt for TRIGGERED[6] event See EVENTS_TRIGGERED[6] H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED7 Write '1' to Enable interrupt for TRIGGERED[7] event See EVENTS_TRIGGERED[7] I Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED8 Write '1' to Enable interrupt for TRIGGERED[8] event See EVENTS_TRIGGERED[8] J Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED9 Write '1' to Enable interrupt for TRIGGERED[9] event See EVENTS_TRIGGERED[9] K Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED10 Write '1' to Enable interrupt for TRIGGERED[10] event See EVENTS_TRIGGERED[10] L Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED11 Write '1' to Enable interrupt for TRIGGERED[11] event See EVENTS_TRIGGERED[11] Set 1 Enable Disabled 0 Read: Disabled Page 491 46 EGU — Event generator unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id M RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Enabled 1 Read: Enabled RW TRIGGERED12 Write '1' to Enable interrupt for TRIGGERED[12] event See EVENTS_TRIGGERED[12] N Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED13 Write '1' to Enable interrupt for TRIGGERED[13] event See EVENTS_TRIGGERED[13] O Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED14 Write '1' to Enable interrupt for TRIGGERED[14] event See EVENTS_TRIGGERED[14] P Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED15 Write '1' to Enable interrupt for TRIGGERED[15] event See EVENTS_TRIGGERED[15] Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 46.1.3 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id RW Field A RW TRIGGERED0 0 Value Id I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for TRIGGERED[0] event See EVENTS_TRIGGERED[0] B Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED1 Write '1' to Disable interrupt for TRIGGERED[1] event See EVENTS_TRIGGERED[1] C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED2 Write '1' to Disable interrupt for TRIGGERED[2] event See EVENTS_TRIGGERED[2] D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED3 Write '1' to Disable interrupt for TRIGGERED[3] event See EVENTS_TRIGGERED[3] E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED4 Write '1' to Disable interrupt for TRIGGERED[4] event Page 492 46 EGU — Event generator unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id RW Field 0 I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_TRIGGERED[4] F RW TRIGGERED5 Write '1' to Disable interrupt for TRIGGERED[5] event See EVENTS_TRIGGERED[5] G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED6 Write '1' to Disable interrupt for TRIGGERED[6] event See EVENTS_TRIGGERED[6] H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED7 Write '1' to Disable interrupt for TRIGGERED[7] event See EVENTS_TRIGGERED[7] I Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED8 Write '1' to Disable interrupt for TRIGGERED[8] event See EVENTS_TRIGGERED[8] J Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED9 Write '1' to Disable interrupt for TRIGGERED[9] event See EVENTS_TRIGGERED[9] K Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED10 Write '1' to Disable interrupt for TRIGGERED[10] event See EVENTS_TRIGGERED[10] L Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED11 Write '1' to Disable interrupt for TRIGGERED[11] event See EVENTS_TRIGGERED[11] M Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED12 Write '1' to Disable interrupt for TRIGGERED[12] event See EVENTS_TRIGGERED[12] N Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED13 Write '1' to Disable interrupt for TRIGGERED[13] event See EVENTS_TRIGGERED[13] O Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED14 Write '1' to Disable interrupt for TRIGGERED[14] event See EVENTS_TRIGGERED[14] Page 493 46 EGU — Event generator unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id P O N M L K J Reset 0x00000000 Id P 0 RW Field I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW TRIGGERED15 Write '1' to Disable interrupt for TRIGGERED[15] event See EVENTS_TRIGGERED[15] Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 46.2 Electrical specification 46.2.1 EGU Electrical Specification Symbol Description tEGU,EVT Latency between setting an EGU event flag and the system Min. setting an interrupt Page 494 Typ. 1 Max. Units cycles 47 PWM — Pulse width modulation 47 PWM — Pulse width modulation The PWM module enables the generation of pulse width modulated signals on GPIO. The module implements an up or up-and-down counter with four PWM channels that drive assigned GPIOs. Three PWM modules can provide up to 12 PWM channels with individual frequency control in groups of up to four channels. Furthermore, a built-in decoder and EasyDMA capabilities make it possible to manipulate the PWM duty cycles without CPU intervention. Arbitrary duty-cycle sequences are read from Data RAM and can be chained to implement ping-pong buffering or repeated into complex loops. Listed here are the main features of one PWM module: • • • • • • • Fixed PWM base frequency with programmable clock divider Up to four PWM channels with individual polarity and duty-cycle values Edge or center-aligned pulses across PWM channels Multiple duty-cycle arrays (sequences) defined in Data RAM Autonomous and glitch-free update of duty cycle values directly from memory through EasyDMA Change of polarity, duty-cycle, and base frequency possibly on every PWM period Data RAM sequences can be repeated or connected into loops Sequence 0 DATA RAM STARTED STOPPED EasyDMA START Sequence 1 PWM STOP SEQSTART[0] SEQSTART[1] SEQ[n].REFRESH SEQSTARTED[0] SEQSTARTED[1] SEQEND[0] SEQEND[1] Decoder NEXTSTEP Carry/Reload COMP0 PSEL.OUT[0] COMP1 PSEL.OUT[1] COMP2 PSEL.OUT[2] COMP3 PSEL.OUT[3] Wave Counter PWM_CLK COUNTERTOP PRESCALER Figure 141: PWM Module 47.1 Wave counter The wave counter is responsible for generating the pulses at a duty-cycle that depends on the compare values, and at a frequency that depends on COUNTERTOP. There is one common 15-bit counter with four compare channels. Thus, all four channels will share the same period (PWM frequency), but can have individual duty-cycle and polarity. The polarity is set by the value read from RAM (see Figure 144: Decoder memory access modes on page 498), while the MODE register controls if the counter counts up, or up and down. The timer top value is controlled by the COUNTERTOP register. This register value in conjunction with the selected PRESCALER of the PWM_CLK will result in a given PWM period. A COUNTERTOP value smaller than the compare setting will result in a state where no PWM edges are generated. Respectively, OUT[n] is held high, given that the polarity is set to FallingEdge. All the compare registers are internal and can only be configured through the decoder presented later. COUNTERTOP can be safely written at any time. It will get sampled following a START task. If DECODER.LOAD is anything else than WaveForm, it will also get sampled following a STARTSEQ[n] task, Page 495 47 PWM — Pulse width modulation and when loading a new value from RAM during a sequence playback. If DECODER.LOAD=WaveForm, the register value is ignored, and taken from RAM instead (see Decoder with EasyDMA on page 498 below). Figure 142: PWM up counter example - FallingEdge polarity on page 496 shows the counter operating in up (MODE=PWM_MODE_Up) mode with three PWM channels with the same frequency but different duty cycle. The counter is automatically reset to zero when COUNTERTOP is reached and OUT[n] will invert. OUT[n] is held low if the compare value is 0 and held high respectively if set to COUNTERTOP given that the polarity is set to FallingEdge. Running in up counter mode will result in pulse widths that are edge-aligned. See the code example below: uint16_t pwm_seq[4] = {PWM_CH0_DUTY, PWM_CH1_DUTY, PWM_CH2_DUTY, PWM_CH3_DUTY}; NRF_PWM0->PSEL.OUT[0] = (first_pin PSEL.OUT[0] = (first_pin OUT. PWM generation can then only be restarted through a SEQSTART[n] task. SEQSTART[n] will resume PWM generation after having loaded the first value from the RAM buffer defined in the SEQ[n].PTR register. The table below provides indication of when specific registers get sampled by the hardware. Care should be taken when updating these registers to avoid values to be applied earlier than expected. Table 117: When to safely update PWM registers Register SEQ[n].PTR SEQ[n].CNT SEQ[0].ENDDELAY SEQ[1].ENDDELAY Taken into account by hardware When sending the SEQSTART[n] task When sending the SEQSTART[n] task When sending the SEQSTART[0] task Recommended (safe) update After having received the SEQSTARTED[n] event After having received the SEQSTARTED[n] event Before starting sequence [0] through a SEQSTART[0] task Every time a new value from sequence [0] has been loaded from RAM and gets applied to the Wave Counter (indicated by the PWMPERIODEND event) When no more value from sequence [0] gets loaded from RAM (indicated by the SEQEND[0] event) When sending the SEQSTART[1] task Every time a new value from sequence [1] has been loaded from RAM and gets applied to the Wave Counter (indicated by the PWMPERIODEND event) At any time during sequence [1] (which starts when the SEQSTARTED[1] event is fired) Before starting sequence [1] through a SEQSTART[1] task When no more value from sequence [1] gets loaded from RAM (indicated by the SEQEND[1] event) At any time during sequence [0] (which starts when the SEQSTARTED[0] event is fired) Before starting sequence [0] through a SEQSTART[0] task SEQ[0].REFRESH When sending the SEQSTART[0] task At any time during sequence [1] (which starts when the SEQSTARTED[1] event is fired) SEQ[1].REFRESH Every time a new value from sequence [0] has been loaded from RAM and gets applied to the Wave Counter (indicated by the PWMPERIODEND event) When sending the SEQSTART[1] task At any time during sequence [0] (which starts when the SEQSTARTED[0] event is fired) COUNTERTOP Every time a new value from sequence [1] has been loaded from RAM and gets applied to the Wave Counter (indicated by the PWMPERIODEND event) In DECODER.LOAD=WaveForm: this register is ignored. MODE In all other LOAD modes: at the end of current PWM period (indicated by the PWMPERIODEND event) Immediately After a STOP task has been issued, and the STOPPED event has been received. Before starting PWM generation through a SEQSTART[n] task Immediately After a STOP task has been issued, and the STOPPED event has been received. Before starting PWM generation through a SEQSTART[n] task Immediately After a STOP task has been issued, and the STOPPED event has been received. Before starting PWM generation through a SEQSTART[n] task Immediately After a STOP task has been issued, and the STOPPED event has been received. Before starting PWM generation through a SEQSTART[n] task Immediately After a STOP task has been issued, and the STOPPED event has been received. Before enabling the PWM instance through the ENABLE register DECODER PRESCALER LOOP PSEL.OUT[n] Before starting sequence [1] through a SEQSTART[1] task Before starting PWM generation through a SEQSTART[n] task Important: SEQ[n].REFRESH and SEQ[n].ENDDELAY are ignored at the end of a complex sequence, indicated by a LOOPSDONE event. The reason for this is that the last value loaded from RAM is maintained until further action from software (restarting a new sequence, or stopping PWM generation). Page 499 47 PWM — Pulse width modulation Figure 145: Simple sequence example on page 500 depicts the source code used for configuration and timing details in a sequence where only sequence 0 is used and only run once with a new PWM duty cycle for each period. NRF_PWM0->PSEL.OUT[0] = (first_pin TASKS_SEQSTART[0] = 1; SEQ[0].CNT=4, SEQ[0].REFRESH=0, SEQ[0].ENDDELAY=0, LOOP.CNT=0 SEQ[0].PTR Event/Tasks SEQSTART[0] P COMPARE O 0 L P COMPARE O 1 L P COMPARE O 2 L Continues With Last Setting P COMPARE O 3 L PWM Pulse Period SEQSTARTED[0] SEQEND[0] Figure 145: Simple sequence example A more complex example is shown in Figure 146: Example using two sequences on page 501, where LOOP.CNT>0 . In this case, an automated playback takes place, consisting of SEQ[0], delay 0, SEQ[1], delay 1, then again SEQ[0], etc. The user can choose to start a complex playback with SEQ[0] or SEQ[1] through sending the SEQSTART[0] or SEQSTART[1] task. The complex playback always ends with delay 1. The two sequences 0 and 1 are defined with address of values tables in Data RAM (pointed by SEQ[n].PTR) and respective buffer size (SEQ[n].CNT). The rate at which a new value is loaded is defined individually for each sequence by SEQ[n].REFRESH . The chaining of sequence 1 following sequence 0 is implicit, the LOOP.CNT register allows the chaining of sequence 1 to sequence 0 for a determined number of times. In other words, it allows to repeat a complex sequence a number of times in a fully automated way. In the example below, sequence 0 is defined with SEQ[0].REFRESH set to one - that means that a new PWM duty cycle is pushed every second PWM period. This complex sequence is started with the SEQSTART[0] task, so SEQ[0] is played first. Since SEQ[0].ENDDELAY=1 there will be one PWM period delay between last period on sequence 0 and the first period on sequence 1. Since SEQ[1].ENDDELAY=0 there is no delay 1, so SEQ[0] would be started immediately after the end of SEQ[1]. However, as LOOP.CNT is one, the playback stops after having played only once SEQ[1], and both SEQEND[1] and LOOPSDONE are generated (their order is not guaranteed in this case). Page 500 47 PWM — Pulse width modulation NRF_PWM0->PSEL.OUT[0] = (first_pin SEQ[1].PTR = ((uint32_t)(seq1_ram) SEQ[1].CNT = ((sizeof(seq1_ram) / sizeof(uint16_t)) SEQ[1].REFRESH = 0; NRF_PWM0->SEQ[1].ENDDELAY = 0; NRF_PWM0->TASKS_SEQSTART[0] = 1; SEQ[0].CNT=2, SEQ[1].CNT=3, SEQ[0].REFRESH=1, SEQ[1].REFRESH=0, SEQ[0].ENDDELAY=1, SEQ[1].ENDDELAY=0, LOOP.CNT=1 SEQ[0].PTR Event/Tasks SEQSTART[0] P O COMPARE L P O COMPARE L PWM Clock Period (continued below) SEQSTARTED[0] SEQEND[0] SEQ[1].PTR 1 PWM period SEQ[0].ENDDELAY=1 (continuation) P O COMPARE L P O COMPARE L PWM Generation maintains last played value Event/Tasks SEQSTARTED[1] SEQEND[1] LOOPSDONE Figure 146: Example using two sequences The decoder can also be configured to asynchronously load a new PWM duty cycle. If the DECODER.MODE register is set to NextStep - then the NEXTSTEP task will cause an update of the internal compare registers on the next PWM period. The figures below provide an overview of each part of an arbitrary sequence, in various modes (LOOP.CNT=0 and LOOP.CNT>0). In particular are represented: • • • • • Initial and final duty cycle on the PWM output(s) Chaining of SEQ[0] and SEQ[1] if LOOP.CNT>0 Influence of registers on the sequence Events fired during a sequence DMA activity (loading of next value and applying it to the output(s)) Note that the single-shot example applies also to SEQ[1], only SEQ[0] is represented for simplicity. Page 501 Page 502 Figure 148: Complex sequence (LOOP.CNT>0) starting with SEQ[0] SEQ[1].ENDDELA Y SEQ[1].CNT SEQ[0].ENDDELA Y SEQ[0].CNT SEQ[1].CNT (LOOP.CNT - 1) ... EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] EVENTS_LOOPSDONE EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] SEQ[0].ENDDELA Y SEQ[0].CNT SEQ[1].ENDDELA Y SEQ[1].CNT LOOP.CNT EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] SEQ[0].ENDDELA Y SEQ[0].CNT Loop counter EVENTS_SEQEND[0] TASKS_SEQSTART[0] EVENTS_SEQSTARTED[0] EVENTS_SEQEND[0] TASKS_SEQSTART[0] EVENTS_SEQSTARTED[0] SEQ[0].ENDDELA Y SEQ[0].CNT 47 PWM — Pulse width modulation 100% duty cycle last loaded duty cycle maintained Previously loaded duty cycle New value load 0% duty cycle Figure 147: Single shot (LOOP.CNT=0) 1 100% duty cycle Previously loaded duty cycle last loaded duty cycle maintained New value load 0% duty cycle 47 PWM — Pulse width modulation SEQ[1].ENDDELA Y SEQ[1].CNT SEQ[0].ENDDELA Y SEQ[0].CNT 1 SEQ[1].CNT SEQ[0].ENDDELA Y (LOOP.CNT - 1) ... SEQ[0].CNT SEQ[1].CNT SEQ[1].ENDDELA Y LOOP.CNT Loop counter 100% duty cycle Previously loaded duty cycle last loaded duty cycle maintained 0% duty cycle EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] EVENTS_LOOPSDONE EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] TASKS_SEQSTART[1] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] New value load Figure 149: Complex sequence (LOOP.CNT>0) starting with SEQ[1] Note that if a sequence is in use in a simple or complex sequence, it must have a length of SEQ[n].CNT > 0 . 47.3 Limitations The previous compare value will be repeated if the PWM period is selected to be shorter than the time it takes for the EasyDMA to fetch from RAM and update the internal compare registers. This is to ensure a glitch-free operation even if very short PWM periods are chosen. 47.4 Pin configuration The OUT[n] (n=0..3) signals associated to each channel of the PWM module are mapped to physical pins according to the configuration specified in the respective PSEL.OUT[n] registers. If a PSEL.OUT[n].CONNECT is set to Disconnected, the associated PWM module signal will not be connected to any physical pins. The PSEL.OUT[n] registers and their configurations are only used as long as the PWM module is enabled and PWM generation is active (wave counter started), and retained only as long as the device is in System ON mode, see POWER chapter for more information about power modes. To ensure correct behaviour in the PWM module, the pins used by the PWM module must be configured in the GPIO peripheral as described in Table 118: Recommended GPIO configuration before starting PWM generation on page 504 before enabling the PWM module. The pins' idle state is defined by the OUT registers in the GPIO module. This is to ensure that the pins used by the PWM module are driven correctly, if PWM generation is stopped through a STOP task, the PWM module itself is temporarily disabled, or the device temporarily enters System OFF. This configuration must be retained in the GPIO for the selected IOs as long as the PWM module is supposed to be connected to an external PWM circuit. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behaviour. Page 503 47 PWM — Pulse width modulation Table 118: Recommended GPIO configuration before starting PWM generation PWM signal OUT[n] PWM pin As specified in PSEL.OUT[n] (n=0..3) Direction Output Output value 0 Comment Idle state defined in GPIO->OUT 47.5 Registers Table 119: Instances Base address Peripheral Instance Description 0x4001C000 PWM PWM0 Pulse Width Modulation Unit 0 0x40021000 PWM PWM1 Pulse Width Modulation Unit 1 0x40022000 PWM PWM2 Pulse Width Modulation Unit 2 Configuration Table 120: Register Overview Register Offset Description TASKS_STOP 0x004 Stops PWM pulse generation on all channels at the end of current PWM period, and stops sequence TASKS_SEQSTART[0] 0x008 playback Loads the first PWM value on all enabled channels from sequence 0, and starts playing that sequence at the rate defined in SEQ[0]REFRESH and/or DECODER.MODE. Causes PWM generation to start it was not running. TASKS_SEQSTART[1] 0x00C Loads the first PWM value on all enabled channels from sequence 1, and starts playing that sequence at the rate defined in SEQ[1]REFRESH and/or DECODER.MODE. Causes PWM generation to start it was not running. TASKS_NEXTSTEP 0x010 EVENTS_STOPPED 0x104 Steps by one value in the current sequence on all enabled channels if DECODER.MODE=NextStep. Does not cause PWM generation to start it was not running. Response to STOP task, emitted when PWM pulses are no longer generated EVENTS_SEQSTARTED[0] 0x108 First PWM period started on sequence 0 EVENTS_SEQSTARTED[1] 0x10C First PWM period started on sequence 1 EVENTS_SEQEND[0] 0x110 Emitted at end of every sequence 0, when last value from RAM has been applied to wave counter EVENTS_SEQEND[1] 0x114 Emitted at end of every sequence 1, when last value from RAM has been applied to wave counter EVENTS_PWMPERIODEND0x118 Emitted at the end of each PWM period EVENTS_LOOPSDONE 0x11C Concatenated sequences have been played the amount of times defined in LOOP.CNT SHORTS 0x200 Shortcut register INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 PWM module enable register MODE 0x504 Selects operating mode of the wave counter COUNTERTOP 0x508 Value up to which the pulse generator counter counts PRESCALER 0x50C Configuration for PWM_CLK DECODER 0x510 Configuration of the decoder LOOP 0x514 Amount of playback of a loop SEQ[0].PTR 0x520 Beginning address in Data RAM of this sequence SEQ[0].CNT 0x524 Amount of values (duty cycles) in this sequence SEQ[0].REFRESH 0x528 Amount of additional PWM periods between samples loaded into compare register SEQ[0].ENDDELAY 0x52C Time added after the sequence SEQ[1].PTR 0x540 Beginning address in Data RAM of this sequence SEQ[1].CNT 0x544 Amount of values (duty cycles) in this sequence SEQ[1].REFRESH 0x548 Amount of additional PWM periods between samples loaded into compare register SEQ[1].ENDDELAY 0x54C Time added after the sequence PSEL.OUT[0] 0x560 Output pin select for PWM channel 0 PSEL.OUT[1] 0x564 Output pin select for PWM channel 1 PSEL.OUT[2] 0x568 Output pin select for PWM channel 2 PSEL.OUT[3] 0x56C Output pin select for PWM channel 3 Page 504 47 PWM — Pulse width modulation 47.5.1 SHORTS Address offset: 0x200 Shortcut register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id E D C B A Reset 0x00000000 Id RW Field A RW SEQEND0_STOP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Shortcut between SEQEND[0] event and STOP task See EVENTS_SEQEND[0] and TASKS_STOP B Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW SEQEND1_STOP Shortcut between SEQEND[1] event and STOP task See EVENTS_SEQEND[1] and TASKS_STOP C Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW LOOPSDONE_SEQSTART0 Shortcut between LOOPSDONE event and SEQSTART[0] task See EVENTS_LOOPSDONE and TASKS_SEQSTART[0] D Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW LOOPSDONE_SEQSTART1 Shortcut between LOOPSDONE event and SEQSTART[1] task See EVENTS_LOOPSDONE and TASKS_SEQSTART[1] E Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW LOOPSDONE_STOP Shortcut between LOOPSDONE event and STOP task See EVENTS_LOOPSDONE and TASKS_STOP Disabled 0 Disable shortcut Enabled 1 Enable shortcut 47.5.2 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E D C B Reset 0x00000000 Id RW Field B RW STOPPED 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Enable or disable interrupt for STOPPED event See EVENTS_STOPPED C Disabled 0 Disable Enabled 1 Enable RW SEQSTARTED0 Enable or disable interrupt for SEQSTARTED[0] event See EVENTS_SEQSTARTED[0] D Disabled 0 Disable Enabled 1 Enable RW SEQSTARTED1 Enable or disable interrupt for SEQSTARTED[1] event See EVENTS_SEQSTARTED[1] E Disabled 0 Disable Enabled 1 Enable RW SEQEND0 Enable or disable interrupt for SEQEND[0] event See EVENTS_SEQEND[0] F Disabled 0 Disable Enabled 1 Enable RW SEQEND1 Enable or disable interrupt for SEQEND[1] event Page 505 47 PWM — Pulse width modulation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E D C B Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable Enabled 1 Enable See EVENTS_SEQEND[1] G RW PWMPERIODEND Enable or disable interrupt for PWMPERIODEND event See EVENTS_PWMPERIODEND H Disabled 0 Disable Enabled 1 Enable RW LOOPSDONE Enable or disable interrupt for LOOPSDONE event See EVENTS_LOOPSDONE Disabled 0 Disable Enabled 1 Enable 47.5.3 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E D C B Reset 0x00000000 Id RW Field B RW STOPPED 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for STOPPED event See EVENTS_STOPPED C Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQSTARTED0 Write '1' to Enable interrupt for SEQSTARTED[0] event See EVENTS_SEQSTARTED[0] D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQSTARTED1 Write '1' to Enable interrupt for SEQSTARTED[1] event See EVENTS_SEQSTARTED[1] E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQEND0 Write '1' to Enable interrupt for SEQEND[0] event See EVENTS_SEQEND[0] F Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQEND1 Write '1' to Enable interrupt for SEQEND[1] event See EVENTS_SEQEND[1] G Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PWMPERIODEND Write '1' to Enable interrupt for PWMPERIODEND event See EVENTS_PWMPERIODEND H Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW LOOPSDONE Write '1' to Enable interrupt for LOOPSDONE event Page 506 47 PWM — Pulse width modulation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E D C B Reset 0x00000000 Id RW Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled See EVENTS_LOOPSDONE 47.5.4 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id H G F E D C B Reset 0x00000000 Id RW Field B RW STOPPED 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for STOPPED event See EVENTS_STOPPED C Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQSTARTED0 Write '1' to Disable interrupt for SEQSTARTED[0] event See EVENTS_SEQSTARTED[0] D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQSTARTED1 Write '1' to Disable interrupt for SEQSTARTED[1] event See EVENTS_SEQSTARTED[1] E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQEND0 Write '1' to Disable interrupt for SEQEND[0] event See EVENTS_SEQEND[0] F Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW SEQEND1 Write '1' to Disable interrupt for SEQEND[1] event See EVENTS_SEQEND[1] G Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW PWMPERIODEND Write '1' to Disable interrupt for PWMPERIODEND event See EVENTS_PWMPERIODEND H Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW LOOPSDONE Write '1' to Disable interrupt for LOOPSDONE event See EVENTS_LOOPSDONE Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 47.5.5 ENABLE Address offset: 0x500 Page 507 47 PWM — Pulse width modulation PWM module enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disabled Enabled 1 Enable Enable or disable PWM module 47.5.6 MODE Address offset: 0x504 Selects operating mode of the wave counter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW UPDOWN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Up 0 Up counter - edge aligned PWM duty-cycle UpAndDown 1 Up and down counter - center aligned PWM duty cycle Selects up or up and down as wave counter mode 47.5.7 COUNTERTOP Address offset: 0x508 Value up to which the pulse generator counter counts Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A Reset 0x000003FF Id RW Field A RW COUNTERTOP 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 Value Description [3..32767] Value up to which the pulse generator counter counts. This register is ignored when DECODER.MODE=WaveForm and only values from RAM will be used. 47.5.8 PRESCALER Address offset: 0x50C Configuration for PWM_CLK Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A Reset 0x00000000 Id RW Field A RW PRESCALER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description DIV_1 0 Divide by 1 (16MHz) DIV_2 1 Divide by 2 ( 8MHz) DIV_4 2 Divide by 4 ( 4MHz) DIV_8 3 Divide by 8 ( 2MHz) DIV_16 4 Divide by 16 ( 1MHz) DIV_32 5 Divide by 32 ( 500kHz) DIV_64 6 Divide by 64 ( 250kHz) DIV_128 7 Divide by 128 ( 125kHz) Pre-scaler of PWM_CLK 47.5.9 DECODER Address offset: 0x510 Configuration of the decoder Page 508 47 PWM — Pulse width modulation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id B Reset 0x00000000 Id RW Field A RW LOAD 0 Value Id A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description How a sequence is read from RAM and spread to the compare register Common 0 1st half word (16-bit) used in all PWM channels 0..3 Grouped 1 1st half word (16-bit) used in channel 0..1; 2nd word in channel Individual 2 1st half word (16-bit) in ch.0; 2nd in ch.1; ...; 4th in ch.3 WaveForm 3 1st half word (16-bit) in ch.0; 2nd in ch.1; ...; 4th in 2..3 COUNTERTOP B RW MODE Selects source for advancing the active sequence RefreshCount 0 NextStep 1 SEQ[n].REFRESH is used to determine loading internal compare registers NEXTSTEP task causes a new value to be loaded to internal compare registers 47.5.10 LOOP Address offset: 0x514 Amount of playback of a loop Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Disabled 0 Description Amount of playback of pattern cycles Looping disabled (stop at the end of the sequence) 47.5.11 SEQ[0].PTR Address offset: 0x520 Beginning address in Data RAM of this sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Beginning address in Data RAM of this sequence 47.5.12 SEQ[0].CNT Address offset: 0x524 Amount of values (duty cycles) in this sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Disabled 0 Description Amount of values (duty cycles) in this sequence Sequence is disabled, and shall not be started as it is empty 47.5.13 SEQ[0].REFRESH Address offset: 0x528 Amount of additional PWM periods between samples loaded into compare register Page 509 47 PWM — Pulse width modulation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000001 Id RW Field A RW CNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Description Amount of additional PWM periods between samples loaded into compare register (load every REFRESH.CNT+1 PWM periods) Continuous 0 Update every PWM period 47.5.14 SEQ[0].ENDDELAY Address offset: 0x52C Time added after the sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Time added after the sequence in PWM periods 47.5.15 SEQ[1].PTR Address offset: 0x540 Beginning address in Data RAM of this sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW PTR 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Beginning address in Data RAM of this sequence 47.5.16 SEQ[1].CNT Address offset: 0x544 Amount of values (duty cycles) in this sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Disabled 0 Description Amount of values (duty cycles) in this sequence Sequence is disabled, and shall not be started as it is empty 47.5.17 SEQ[1].REFRESH Address offset: 0x548 Amount of additional PWM periods between samples loaded into compare register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000001 Id RW Field A RW CNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value Description Amount of additional PWM periods between samples loaded into compare register (load every REFRESH.CNT+1 PWM periods) Continuous 0 Update every PWM period 47.5.18 SEQ[1].ENDDELAY Address offset: 0x54C Page 510 47 PWM — Pulse width modulation Time added after the sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 Id RW Field A RW CNT 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Time added after the sequence in PWM periods 47.5.19 PSEL.OUT[0] Address offset: 0x560 Output pin select for PWM channel 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 47.5.20 PSEL.OUT[1] Address offset: 0x564 Output pin select for PWM channel 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 47.5.21 PSEL.OUT[2] Address offset: 0x568 Output pin select for PWM channel 2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN C RW CONNECT Value Id Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 47.5.22 PSEL.OUT[3] Address offset: 0x56C Output pin select for PWM channel 3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field A RW PIN Value Id Value Description [0..31] Pin number Page 511 47 PWM — Pulse width modulation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Id RW Field C RW CONNECT Value Id Value Description Disconnected 1 Disconnect Connected 0 Connect Connection 47.6 Electrical specification 47.6.1 PWM Electrical Specification Symbol Description IPWM,16MHz PWM run current, Prescaler set to DIV_1 (16 MHz), excluding Min. Typ. Max. Units 200 µA 150 µA 150 µA DMA and GPIO IPWM,8MHz PWM run current, Prescaler set to DIV_2 (8 MHz), excluding DMA and GPIO IPWM,125kHz PWM run current, Prescaler set to DIV_128 (125 kHz), excluding DMA and GPIO Page 512 48 SPI — Serial peripheral interface master 48 SPI — Serial peripheral interface master The SPI master provides a simple CPU interface which includes a TXD register for sending data and an RXD register for receiving data. This section is added for legacy support for now. PSEL.MISO MISO PSEL.SCK PSEL.MOSI RXD-1 TXD+1 RXD TXD MOSI READY Figure 150: SPI master RXD-1 and TXD+1 illustrate the double buffered version of RXD and TXD respectively. 48.1 Functional description The TXD and RXD registers are double-buffered to enable some degree of uninterrupted data flow in and out of the SPI master. The SPI master does not implement support for chip select directly. Therefore, the CPU must use available GPIOs to select the correct slave and control this independently of the SPI master. The SPI master supports SPI modes 0 through 3. Table 121: SPI modes Mode Clock polarity CPOL SPI_MODE00 (Leading) SPI_MODE10 (Leading) SPI_MODE21 (Trailing) SPI_MODE31 (Trailing) Clock phase CPHA 0 (Active High) 1 (Active Low) 0 (Active High) 1 (Active Low) 48.1.1 SPI master mode pin configuration The different signals SCK, MOSI, and MISO associated with the SPI master are mapped to physical pins. This mapping is according to the configuration specified in the PSELSCK, PSELMOSI, and PSELMISO registers respectively. If a value of 0xFFFFFFFF is specified in any of these registers, the associated SPI master signal is not connected to any physical pin. The PSELSCK, PSELMOSI, and PSELMISO registers and their configurations are only used as long as the SPI master is enabled, and retained only as long as the device is in ON mode. PSELSCK, PSELMOSI, and PSELMISO must only be configured when the SPI master is disabled. To secure correct behavior in the SPI, the pins used by the SPI must be configured in the GPIO peripheral as described in Table 122: GPIO configuration on page 514 prior to enabling the SPI. The SCK must Page 513 48 SPI — Serial peripheral interface master always be connected to a pin, and that pin's input buffer must always be connected for the SPI to work. This configuration must be retained in the GPIO for the selected IOs as long as the SPI is enabled. Only one peripheral can be assigned to drive a particular GPIO pin at a time, failing to do so may result in unpredictable behavior. Table 122: GPIO configuration SPI master signal SCK MOSI MISO SPI master pin As specified in PSELSCK As specified in PSELMOSI As specified in PSELMISO Direction Output Output Input Output value Same as CONFIG.CPOL 0 Not applicable 48.1.2 Shared resources The SPI shares registers and other resources with other peripherals that have the same ID as the SPI. Therefore, the user must disable all peripherals that have the same ID as the SPI before the SPI can be configured and used. Disabling a peripheral that has the same ID as the SPI will not reset any of the registers that are shared with the SPI. It is therefore important to configure all relevant SPI registers explicitly to secure that it operates correctly. See the Instantiation table in Instantiation on page 24 for details on peripherals and their IDs. 48.1.3 SPI master transaction sequence An SPI master transaction is started by writing the first byte, which is to be transmitted by the SPI master, to the TXD register. Since the transmitter is double buffered, the second byte can be written to the TXD register immediately after the first one. The SPI master will then send these bytes in the order they are written to the TXD register. The SPI master is a synchronous interface, and for every byte that is sent, a different byte will be received at the same time; this is illustrated in Figure 151: SPI master transaction on page 515. Bytes that are received will be moved to the RXD register where the CPU can extract them by reading the register. The RXD register is double buffered in the same way as the TXD register, and a second byte can therefore be received at the same time as the first byte is being extracted from RXD by the CPU. The SPI master will generate a READY event every time a new byte is moved to the RXD register. The double buffered byte will be moved from RXD-1 to RXD as soon as the first byte is extracted from RXD. The SPI master will stop when there are no more bytes to send in TXD and TXD+1. Page 514 48 SPI — Serial peripheral interface master CSN n-1 n MISO A B C m-2 m-1 m 6 7 m-1 = RXD m = RXD TXD = n 5 m-2 = RXD C = RXD 4 TXD = n-1 B = RXD TXD = 2 TXD = 1 3 TXD = n-2 2 A = RXD 1 TXD = 0 CPU READY n-2 READY 2 READY 1 READY 0 READY MOSI READY SCK Figure 151: SPI master transaction The READY event of the third byte transaction is delayed until B is extracted from RXD in occurrence number 3 on the horizontal lifeline. The reason for this is that the third event is generated first when C is moved from RXD-1 to RXD after B is read. CSN SCK MOSI (CPHA=1) 1 Figure 152: SPI master transaction Page 515 READY MISO Lifeline READY Lifeline MISO MOSI SCK (CPHA=0) CSN The SPI master will move the incoming byte to the RXD register after a short delay following the SCK clock period of the last bit in the byte. This also means that the READY event will be delayed accordingly, see Figure 152: SPI master transaction on page 515. Therefore, it is important that you always clear the READY event, even if the RXD register and the data that is being received is not used. 1 48 SPI — Serial peripheral interface master 48.2 Registers Table 123: Instances Base address Peripheral Instance Description 0x40003000 SPI SPI0 SPI master 0 Configuration Deprecated 0x40004000 SPI SPI1 SPI master 1 Deprecated 0x40023000 SPI SPI2 SPI master 2 Deprecated Table 124: Register Overview Register Offset Description EVENTS_READY 0x108 TXD byte sent and RXD byte received INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 Enable SPI PSELSCK 0x508 Pin select for SCK Deprecated PSELMOSI 0x50C Pin select for MOSI Deprecated PSELMISO 0x510 Pin select for MISO Deprecated PSEL.SCK 0x508 Pin select for SCK PSEL.MOSI 0x50C Pin select for MOSI PSEL.MISO 0x510 Pin select for MISO RXD 0x518 RXD register TXD 0x51C TXD register FREQUENCY 0x524 SPI frequency CONFIG 0x554 Configuration register 48.2.1 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW READY 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Enable interrupt for READY event See EVENTS_READY Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 48.2.2 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A Reset 0x00000000 Id RW Field A RW READY 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description Write '1' to Disable interrupt for READY event See EVENTS_READY Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Page 516 48 SPI — Serial peripheral interface master 48.2.3 ENABLE Address offset: 0x500 Enable SPI Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A Reset 0x00000000 Id RW Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description Disabled 0 Disable SPI Enabled 1 Enable SPI Enable or disable SPI 48.2.4 PSELSCK ( Deprecated ) Address offset: 0x508 Pin select for SCK Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELSCK 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI SCK signal 0xFFFFFFFF Disconnect 48.2.5 PSELMOSI ( Deprecated ) Address offset: 0x50C Pin select for MOSI Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELMOSI 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI MOSI signal 0xFFFFFFFF Disconnect 48.2.6 PSELMISO ( Deprecated ) Address offset: 0x510 Pin select for MISO Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELMISO 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI MISO signal 0xFFFFFFFF Disconnect 48.2.7 PSEL.SCK Address offset: 0x508 Pin select for SCK Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELSCK 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI SCK signal 0xFFFFFFFF Disconnect Page 517 48 SPI — Serial peripheral interface master 48.2.8 PSEL.MOSI Address offset: 0x50C Pin select for MOSI Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELMOSI 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI MOSI signal 0xFFFFFFFF Disconnect 48.2.9 PSEL.MISO Address offset: 0x510 Pin select for MISO Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF Id RW Field A RW PSELMISO 1 Value Id Disconnected 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value Description [0..31] Pin number configuration for SPI MISO signal 0xFFFFFFFF Disconnect 48.2.10 RXD Address offset: 0x518 RXD register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A R 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description RXD RX data received. Double buffered 48.2.11 TXD Address offset: 0x51C TXD register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A Reset 0x00000000 Id RW Field A RW TXD 0 Value Id 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Description TX data to send. Double buffered 48.2.12 FREQUENCY Address offset: 0x524 SPI frequency Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x04000000 Id RW Field A RW FREQUENCY 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description K125 0x02000000 125 kbps K250 0x04000000 250 kbps K500 0x08000000 500 kbps M1 0x10000000 1 Mbps SPI master data rate Page 518 48 SPI — Serial peripheral interface master Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x04000000 Id 0 RW Field 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description M2 0x20000000 2 Mbps M4 0x40000000 4 Mbps M8 0x80000000 8 Mbps 48.2.13 CONFIG Address offset: 0x554 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Id C B A Reset 0x00000000 Id RW Field A RW ORDER B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value Id Value Description MsbFirst 0 Most significant bit shifted out first LsbFirst 1 Least significant bit shifted out first Leading 0 Trailing 1 Bit order RW CPHA Serial clock (SCK) phase Sample on leading edge of clock, shift serial data on trailing edge Sample on trailing edge of clock, shift serial data on leading edge C RW CPOL Serial clock (SCK) polarity ActiveHigh 0 Active high ActiveLow 1 Active low 48.3 Electrical specification 48.3.1 SPI master interface Symbol Description Max. Units fSPI Bit rates for SPI38 Min. Typ. 839 Mbps ISPI,2Mbps Run current for SPI, 2 Mbps 50 µA ISPI,8Mbps Run current for SPI, 8 Mbps 50 µA ISPI,IDLE Idle current for SPI (STARTed, no CSN activity)
nRF52832-QFAA-T 价格&库存
很抱歉,暂时无法提供与“nRF52832-QFAA-T”相匹配的价格&库存,您可以联系我们找货
nRF52832-QFAA-T
  • 1+41.300101+5.35330
  • 10+31.5620010+4.09110
  • 25+29.4659025+3.81940
  • 100+26.12400100+3.38620
  • 250+24.81840250+3.21700
  • 490+24.55490490+3.18280
  • 980+23.05770980+2.98880
库存:2121
