Application Note
BNO055
USB Stick user guide
Bosch Sensortec
User Motion
Quaternion
Linear Acceleration
Rotation
Gravity
Robust Heading
Application note: BNO055 USB stick user guide
Document revision
1.1
Document release date
June 2016
Document number
BST-BNO055-AN009-01
Technical reference code(s)
0 273 141 209
Notes
Data in this document are subject to change without notice. Product photos
and pictures are for illustration purposes only and may differ from the real
product’s appearance.
Application note
BNO055 – USB stick user guide
Page 2
INDEX OF CONTENTS
1. INTRODUCTION .................................................................................................................... 3
2. INSTALLATION ..................................................................................................................... 4
2.1 REQUIREMENTS .................................................................................................................. 4
2.2 INSTALLATION OF DEVELOPMENT DESKTOP .......................................................................... 4
3. USING THE BNO055 USB STICK ......................................................................................... 5
3.1 SENSOR CALIBRATION ......................................................................................................... 6
4. FLASHING NEW FIRMWARE ............................................................................................... 7
4.1 FLASHING NEW BNO055 FIRMWARE .................................................................................... 7
4.2 FLASHING NEW BNO055 USB STICK FIRMWARE ................................................................... 7
5. MISCELLANEOUS ................................................................................................................ 7
5.1 LED INDICATIONS ............................................................................................................... 7
5.2 SWITCH FUNCTIONS ............................................................................................................ 7
6. LEGAL DISCLAIMER ............................................................................................................ 8
6.1 ENGINEERING SAMPLES ...................................................................................................... 8
6.2 PRODUCT USE .................................................................................................................... 8
6.3 APPLICATION EXAMPLES AND HINTS ..................................................................................... 8
7. DOCUMENT HISTORY AND MODIFICATIONS .................................................................... 9
BST-BNO055-AN009-01 | Revision 1.1 | June 2016
Bosch Sensortec
© Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to third
parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany.
Note: Specifications within this document are subject to change without notice.
Application note
Page 3
1. Introduction
This document is a detailed guide to use the BNO055 USB stick using the sensor evaluation
environment, Development Desktop from Bosch Sensortec.
The USB stick contains the BNO055 and an MCU which acts as an interface to the USB port.
Figure 1 : BNO055 USB Stick
You can find 2 LEDs in the middle and a switch at one end. The switch is used to control the
modes of operation (see Chapter 5.2).
Bosch Sensortec
Application note
Page 4
2. Installation
2.1 Requirements
Following are the minimum requirements for a successful installation:
Windows 7
Installer for Development Desktop 2.0 (UI version 2.8 or higher), which can be downloaded
from this link.
BNO055 USB Stick
Figure 2 : DD 2.0 UI Version printed on the USB Stick
Note: The first version of the BNO055 USB stick (which has a green colored PCB) is not
compatible with USB 3.0 ports. Hence the user could connect the stick over a USB2.0 port.
For usage with USB 3.0 ports, you need to have the updated version of the hardware (red colored
PCB) and the latest version of DD2.0. The working combination of the stick and Development
Desktop’s version will be printed on the PCB as shown above in Figure 2 “DD2.0 UI 3.0 or later”.
2.2 Installation of Development Desktop
Please follow the instructions from the User manual of Development Desktop.
Note: Also ensure that the USB driver is installed (i.e. follow the installation process carefully).
Bosch Sensortec
Application note
Page 5
3. Using the BNO055 USB stick
1. Make sure the switch at the end of the USB stick is in position H (see Figure 1 : BNO055
USB Stick) or in ‘lock’ position.
2. Plug the USB stick into the USB port of your PC. The red LED on the stick should glow.
3. Open Development Desktop. You should see the main window as below:
Figure 3 : Main window of Development Desktop
4. On startup, the BNO055 is in CONFIG_MODE. Select an operation mode in the
dropdown to the right of Config Mode or simply disable CONFIG_MODE (refer figure).
5. Once CONFIG_MODE is disabled, you can start streaming as shown below in Figure 4.
Bosch Sensortec
Application note
Page 6
Figure 4 : Streaming option in Development Desktop
6. Check the BNO055 data sheet and the Development Desktop documentation for more
options.
The help file outlining BNO055 use in Development Desktop environment is under :
Help->User Manuals->BNO055 User Manual
7. If you go to Panels and activate 3D Compass a new window opens and displays a 3D object
whose motion is controlled according to the motion of the BNO055.
Please note:
Before you start the 3D Compass, the BNO055 must be set to one of the following fusion modes:
eCompass (accelerometer + magnetometer)
IMU (accelerometer + gyroscope)
9Dof (accelerometer + gyroscope + magnetometer)
3.1 Sensor calibration
The BNO055 must be calibrated before use. Un-calibrated BNO055 stick will deliver data of lower
accuracy. Calibration of magnetometer and gyroscope is crucial.
Calibration procedure:
Gyroscope: Requires a steady state for short moment in order to calibrate itself. Place sensor
on a flat surface for a few seconds.
Magnetometer: The stick must be moved a few times in a figure of 8 or ∞ pattern. You can
have a look at the video here.
Accelerometer: To calibrate the sensor stick must be placed in six different steady positions.
This step can be omitted, since the offsets of the accelerometer channels are small and have
no negative impact on the data accuracy of the fused data.
Bosch Sensortec
Application note
Page 7
4. Flashing new firmware
4.1 Flashing new BNO055 firmware
A new BNO055 USB stick firmware will be released with every new release of Development
Desktop 2.0 version. Please follow the appropriate documentation of Development Desktop 2.0
for more details.
4.2 Flashing new BNO055 USB stick firmware
Please follow the instructions carefully given in the Development Desktop 2.0 help files to flash
the new firmware. The firmware file is “BNOinUSBStick.fwu3”. DO NOT flash anything other
than files having “.fwu3” format!
5. Miscellaneous
5.1 LED indications
MCU is in bootloader mode D1 and D2 both glow together three times.
MCU is power on and is in application mode only D1 glows continuously.
Flashing BNO055 firmware D2 glows
5.2 Switch functions
During power on:
o
If switch is at ‘unlock’ position MCU will be in boot loader mode
o
If switch is at ‘lock’ position MCU will be in Application mode
Bosch Sensortec
Application note
Page 8
6. Legal disclaimer
6.1 Engineering samples
Engineering Samples are marked with an asterisk (*) or (e) or (E). Samples may vary from the
valid technical specifications of the product series contained in this data sheet. They are therefore
not intended or fit for resale to third parties or for use in end products. Their sole purpose is
internal client testing. The testing of an engineering sample may in no way replace the testing of
a product series. Bosch Sensortec assumes no liability for the use of engineering samples. The
Purchaser shall indemnify Bosch Sensortec from all claims arising from the use of engineering
samples.
6.2 Product use
Bosch Sensortec products are developed for the consumer goods industry. They may only be
used within the parameters of this product data sheet. They are not fit for use in life-sustaining or
security sensitive systems. Security sensitive systems are those for which a malfunction is
expected to lead to bodily harm or significant property damage. In addition, they are not fit for use
in products which interact with motor vehicle systems.
The resale and/or use of products are at the purchaser’s own risk and his own responsibility. The
examination of fitness for the intended use is the sole responsibility of the Purchaser.
The purchaser shall indemnify Bosch Sensortec from all third party claims arising from any
product use not covered by the parameters of this product data sheet or not approved by Bosch
Sensortec and reimburse Bosch Sensortec for all costs in connection with such claims.
The purchaser must monitor the market for the purchased products, particularly with regard to
product safety, and inform Bosch Sensortec without delay of all security relevant incidents.
6.3 Application examples and hints
With respect to any examples or hints given herein, any typical values stated herein and/or any
information regarding the application of the device, Bosch Sensortec hereby disclaims any and
all warranties and liabilities of any kind, including without limitation warranties of non-infringement
of intellectual property rights or copyrights of any third party. The information given in this
document shall in no event be regarded as a guarantee of conditions or characteristics. They are
provided for illustrative purposes only and no evaluation regarding infringement of intellectual
property rights or copyrights or regarding functionality, performance or error has been made.
Bosch Sensortec
Application note
Page 9
7. Document history and modifications
Rev. No
Chapter
Description of modification/changes
Date
1.0
n/a
Document creation
2014-07-25
1.1
all
Updated for newer version of the hardware
2016-06-08
Gerhard-Kindler-Strasse 9
72770 Reutlingen / Germany
contact@bosch-sensortec.com
www.bosch-sensortec.com
Modifications reserved | Printed in Germany
Specifications subject to change without notice
Document number: BST-BNO055-AN009-01
Revision_1.1_062016
Bosch Sensortec
很抱歉,暂时无法提供与“BNO055 USB Stick”相匹配的价格&库存,您可以联系我们找货
