SDF
Thermal Cut-Offs
SDF
Our Thermal Cut-Offs
(Organic Thermal Element Type) are
used to prevent fires caused by abnormal heat generation from
circuits and other heat producing electrical products. They are
a non-resettable thermal fuse which open electrical contacts
when temperatures exceed the specified level.
Operating Principle
When the ambient temperature rises to the functioning
temperature, the thermal element melts and the springs move
the contact away and open the circuit permanently.
Applications
Approvals
UL & cUL: E117626
VDE: 115369, 116219
PSE: JET2926-32001-1001-1009
CCC: 2003010205079617
EK: HH05009-2004A-2019A
Dimensions
• Electric home appliances and heating devices
• Coil-winding products and power supplies
• Office equipment and telecommunication devices
• Automobiles & other electronic components
Cautions
• Bends in leads should be at least 3mm from the
body of the TCO.
• Extreme caution must be used while soldering,
use a heatsink and avoid heating above Tf -24°C.
• The metal portion of the TCO is electrically live
and may require insulation.
• Do not use in liquids or poisonous gasses such as
sulfuric acid or nitrous oxide.
• Do not connect heater directly to the cutoff.
EU DIRECTIVE 2011/65/EU
(RoHS II)
Type
A (L1)
B (L2)
Standard
25.4
35.0
Long
35.0
35.0
Option
Custom made
Custom made
Part No.
UL/cUL
VDE
CCC
PSE
TF (ºC)
TH (ºC)
DF66S
O
O
O
O
66
42
DF72S
O
O
O
O
72
50
DF77S
O
O
O
O
77
55
DF84S
O
O
O
O
84
60
DF91S
O
O
O
O
91
67
DF98S
O
O
O
O
98
76
DF100S
O
O
O
O
100
78
DF104S
O
O
O
O
104
80
DF110S
O
O
O
O
110
86
DF115S
115
95
DF119S
O
O
O
O
119
95
DF121S
121
95
DF128S
O
O
O
O
128
106
DF132S
132
110
DF139S
O
O
139
117
DF141S
O
O
O
O
141
117
DF144S
O
O
O
O
144
120
DF152S
O
O
O
O
152
128
DF167S
O
O
O
O
167
142
DF169S
O
169
145
DF170S
O
O
O
O
170
146
DF179S
O
179
155
DF184S
O
O
O
O
184
160
DF192S
O
O
O
O
192
162
DF216S
O
O
O
216
191
DF222S
O
222
195
DF228S
O
O
O
O
228
193
DF240S
O
O
O
240
200
DF260S
O
O
260
220
O
280
230
DF280S
TF = Functioning Temperature
TH = Holding Temperature
Rated Voltage
& Current Max.
EK
250V/15A
125V/15A
UL/cUL
250V/10A
250V/16A
VDE
PSE
CCC
O
250V/15A
125V/15A
250V/15A
250V/15A
APPROVED
APPLIED FOR
TOLERANCE: +0ºC, -5ºC
Determine the Proper Series
• Tp : The highest temperature of the product to which a
cutoff is to be attached.
• Th : The safe temperature range for use of the cutoff.
• Ts : 24ºC (Tp-Th) (Apply 35ºC for Ts value when Tp is
higher than 170ºC.)
• To : The heating temperature caused by electrical load
(Please refer temperature / current correlation curve)
• +a :
1. Self heating of lead wire
2. Structure of ventilation or airtightness
3. Location of connecting terminal
4. Thicknes of insulated covering material
5. Best condition value considering electric voltage changes
Tp + Ts + To +a = Applicable Temperature
Safe Temperature Range
• The increasing temperature by remaining heat in the cutoff after melting is required to remain below Tm.
• The temperature of the area where a cutoff will be attached should not reach over Th under normal usage conditions.
8415 Mountain Sights Avenue • Montreal (Quebec), H4P 2B8, Canada
Tel: (514) 739-3274 • 1-800-561-7207 • Fax: (514) 739-2902 • E-mail: sales@cantherm.com
Website: www.cantherm.com | Division of Microtherm
2016/June SDF
很抱歉,暂时无法提供与“SDF DF104S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.786401+1.09521
- 10+6.7249310+0.83825
- 100+4.76048100+0.59339
- 1000+3.622321000+0.45152
- 5000+3.208335000+0.39991
- 10000+2.9702910000+0.37024
