TF31-10(4)SA-1SH(800) 数据手册
0.5/1.0mm Pitch, 1.75/2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector
TF31 Series
Multiple Height and Pitch Variations Available
Pitch variations
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
P=0.5mm
■ Features
1. M
ultiple height and pitch variations
available
This series offers two different contact pitches of 0.5 and
1.0mm and two heights variations of 1.75 and 2.0mm.
These options give engineers the ability to choose
the connector that will best fit their design. (Figure. 1)
2. FPC/FFC side catcher design
P=1.0mm
Height variations
1.75mm
2.0mm
4-20Pos.
21-60Pos.
Alternating Direction
The TF31 Series incorporates Hirose's FPC/FFC side catcher
technology. This design feature enables the tabbed FPC/FFC
to be placed in the correct position while achieving stability
and excellent FPC/FFC retention force. (Figure. 2)
EX) TF31-10(4)SA-1SH(800)
(Alternating on the polarity side)
3. Easy FPC/FFC insertion
The actuator is designed to open widely, to approximately
110°, providing excellent FPC/FFC insertion operability.
4. Rugged design
Each terminal is attached to the actuator, which provides
support to the actuator across its entire length. This prevents
the actuator from separating from the housing.
5. Prevents unintended actuator opening
The TF31 Series has an interference design that prevents
the actuator from unintentionally opening.
6. Maximizes board space
The bottom surface of the connector is over-molded.
This allows the PCB space under the connector to be utilized
for additional PCB routing
EX) TF31-40(20)SB-1SH(800)
(Alternating on the opposite polarity side)
Figure.1
FPC/FFC Positioning Alignment
FPC/FFC Positioning Mechanism
Standard FPC/FFC
7. Pick & Place mounting
Offered in tape and reel packaging that is compatible with
automatic machine mounting.
8. Multiple packaging options
The standard packaging is 3,000pcs/reel, but TF31 Series is
also available in 500pcs/reel. (The outer diameter of the reel is
ø180mm for non-standard packaging.)
9. Halogen-Free
All materials and substances used to produce this product
comply with Halogen-free standards.
*As defined by IEC 61249-2-21.
Br : 900ppm max., Cl : 900ppm max., Br+Cl : 1,500ppm max.
FPC/FFC tabs for greater retention force
in the horizontal direction
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2022.05 ②
Figure.2
1
TF31 Series ● 0.5/1.0mm Pitch, 1.75/2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector
■ Product Specifications
Ratings
Storage Temperature : -10 to +50℃ (Note3)
Rated Current : 0.5A (Note1) Operating Temperature : -40 to +105℃ (Note2)
Operating Humidity Range : Relative humidity : 90% Max. Storage Humidity Range : Relative humidity : 90% Max.
Rated Voltage : 50V AC rms
(No condensation)
(No condensation)
Adaptive FPC/FFC
contact specifications
Thickness : 0.3±0.03mm Gold plated contact traces
1. Insulation Resistance
500MΩ Min.
3. Contact Resistance
50mΩ Max.
*Including FPC/FFC conductor resistance
Items
2. Withstanding Voltage
4. Durability
(Insertion/withdrawal)
5. Vibration
Specifications
No flashover or insulation breakdown
150V AC rms for 1 min.
1mA
Contact resistance : 50mΩ Max.
No damage, cracks, or parts dislocation.
20 cycles
No electrical discontinuity of 1μs or more.
Frequency : 10 to 55Hz,
total amplitude of 1.5mm for 2hours in 3 axis directions
No electrical discontinuity of 1㎲ or more
6. Shock
Acceleration : 981m/s2, 6ms duration,
Sine half-waveform, 3 cycles in each of the 3 axis.
Insulation resistance : 50MΩ Min.
7. Humidity
(Steady state)
8. Temperature Cycle
9. Resistance to
Soldering Heat
Conditions
100V DC
96 hours at a temperature of 40℃ and humidity
of 90% to 95%
Temperature : -40 → +15 to +35 → +105 → +15 to +35℃
Time :
30 → 2 to 3 → 30 → 2 to 3 (min.)
5 cycles
No deformation of components affecting
performance
Reflow : At the recommended temperature profile
Manual soldering : 350±10℃ for 5 seconds
Note 1 : When passing the current through all of the contacts, use 70% of the current rating.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term “storage” refers to products stored for long period of time prior to mounting and use.
Operating temperature and humidity range covers non-conducting condition of installed connectors in storage,
shipment or during transportation.
■ Material / Finish
Part
Material
Finish
Actuator
LCP
Black
Insulator
LCP
Contact
Beige
Phosphor bronze
Retention Tab
Remarks
Partially Gold plated
Brass
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
1
2
3
4
6
1
Series Name : TF
2
Series No. : 31
7
4
Standard Type : No symbol
Alternating Contact Type : Number of contacts
9
3
5
2
31
Standard Type : Number of contacts
Alternating Contact Type : Mold size
Contact arrangement : Single(pole piece array)
8
Tin plated
■ Product Number Structure
TF
UL94V-0
S
5
A
6
0.5
7
SH
8
9
Alternating direction : Please refer to Figure 1 on Page 1
No symbol : Standard type(all contacts loaded)
A : Alternating contact type(Alternating on the polarity side)
B : Alternating contact type(Alternating on the opposite polarity side)
Contact Pitch : 0.5mm, 1mm
Terminal Type
SH : SMT horizontal mounting type
Specification
(800) : Partially Gold plated, Emboss tape packaging (3,000pcs/reel)
(895) : Partially Gold plated, Emboss tape packaging (500pcs/reel)
■ Connector Dimensions (0.5mm Pitch Product)
4-20Pos.
21-60Pos.
Note 1 : The coplanarity of each terminal lead is within 0.1mm.
Note 2 : This product is packaged and sold in tape and reel. Check the packaging specifications for details.
Note 3 : Sink mark reliefs may be added due to improvements.
Note 4 : Black spots may appear on the mold resin, but this does not affect product performance.
Additionally, the terminal plating may change color after reflow, however this does not represent a quality issue.
Part No.
TF31-4S-0.5SH(800)
TF31-6S-0.5SH(800)
TF31-7S-0.5SH(800)
TF31-8S-0.5SH(800)
TF31-10S-0.5SH(800)
TF31-12S-0.5SH(800)
TF31-13S-0.5SH(800)
TF31-14S-0.5SH(800)
TF31-16S-0.5SH(800)
TF31-17S-0.5SH(800)
TF31-18S-0.5SH(800)
TF31-20S-0.5SH(800)
TF31-21S-0.5SH(800)
TF31-22S-0.5SH(800)
TF31-24S-0.5SH(800)
TF31-25S-0.5SH(800)
TF31-26S-0.5SH(800)
TF31-28S-0.5SH(800)
TF31-30S-0.5SH(800)
TF31-32S-0.5SH(800)
TF31-35S-0.5SH(800)
TF31-36S-0.5SH(800)
TF31-40S-0.5SH(800)
TF31-45S-0.5SH(800)
TF31-50S-0.5SH(800)
TF31-53S-0.5SH(800)
TF31-54S-0.5SH(800)
TF31-55S-0.5SH(800)
TF31-60S-0.5SH(800)
HRS No.
480-0235-5 00
480-0154-5 00
480-0516-0 00
480-0184-6 00
480-0130-7 00
480-0131-0 00
480-0177-0 00
480-0155-8 00
480-0178-3 00
480-0185-9 00
480-0161-0 00
480-0132-2 00
480-0186-1 00
480-0143-9 00
480-0251-0 00
480-0358-0 00
480-0162-3 00
480-0156-0 00
480-0179-6 00
480-0157-3 00
480-0261-0 00
480-0163-6 00
480-0133-5 00
480-0134-8 00
480-0135-0 00
480-0762-0 00
480-0756-0 00
480-0187-4 00
480-0136-3 00
No. of contacts
4
6
7
8
10
12
13
14
16
17
18
22
24
25
26
28
30
32
35
36
40
45
50
53
54
55
60
A
1.50
2.50
3.00
3.50
4.50
5.50
6.00
6.50
7.50
8.00
8.50
9.50
10.00
10.50
11.50
12.00
12.50
13.50
14.50
15.50
17.00
17.50
19.50
22.00
24.50
26.00
26.50
27.00
29.50
B
2.57
3.57
4.07
4.57
5.57
6.57
7.07
7.57
8.57
9.07
9.57
10.57
11.07
11.57
12.57
13.07
13.57
14.57
15.57
16.57
18.07
18.57
20.57
23.07
25.57
27.07
27.57
28.07
30.57
C
4.70
5.70
6.20
6.70
7.70
8.70
9.20
9.70
10.70
11.20
11.70
12.70
13.20
13.70
14.70
15.20
15.70
16.70
17.70
18.70
20.20
20.70
22.70
25.20
27.70
29.20
29.70
30.20
32.70
D
6.30
7.30
7.80
8.30
9.30
10.30
10.80
11.30
12.30
12.80
13.30
14.30
14.80
15.30
16.30
16.80
17.30
18.30
19.30
20.30
21.80
22.30
24.30
26.80
29.30
30.80
31.30
31.80
34.30
Unit : mm
Purchase Unit
3,000pcs/Reel
3
Part No.
480-0154-0 95
6
TF31-7S-0.5SH(895)
480-0516-0 95
TF31-8S-0.5SH(895)
TF31-10S-0.5SH(895)
TF31-12S-0.5SH(895)
TF31-13S-0.5SH(895)
TF31-14S-0.5SH(895)
TF31-16S-0.5SH(895)
TF31-17S-0.5SH(895)
TF31-18S-0.5SH(895)
TF31-20S-0.5SH(895)
No. of contacts
480-0235-0 95
TF31-6S-0.5SH(895)
TF31-21S-0.5SH(895)
TF31-22S-0.5SH(895)
TF31-24S-0.5SH(895)
TF31-25S-0.5SH(895)
TF31-26S-0.5SH(895)
TF31-28S-0.5SH(895)
TF31-30S-0.5SH(895)
TF31-32S-0.5SH(895)
TF31-35S-0.5SH(895)
TF31-36S-0.5SH(895)
TF31-40S-0.5SH(895)
TF31-45S-0.5SH(895)
TF31-50S-0.5SH(895)
TF31-53S-0.5SH(895)
TF31-54S-0.5SH(895)
TF31-55S-0.5SH(895)
TF31-60S-0.5SH(895)
4
HRS No.
TF31-4S-0.5SH(895)
480-0184-0 95
6.30
7
3.00
4.07
6.20
7.80
8
13
480-0185-9 95
480-0161-0 95
480-0132-0 95
480-0186-0 95
480-0143-0 95
480-0251-0 95
480-0358-0 95
480-0162-0 95
480-0156-0 95
480-0179-0 95
480-0157-0 95
480-0261-0 95
480-0163-0 95
480-0133-0 95
480-0134-0 95
480-0135-0 95
480-0762-0 95
480-0756-0 95
480-0187-0 95
480-0136-0 95
D
4.70
480-0177-0 95
480-0178-3 95
C
2.57
10
480-0155-8 95
B
1.50
480-0130-0 95
480-0131-0 95
A
4
12
14
16
17
18
3.50
4.50
5.50
6.00
6.50
7.50
8.00
8.50
30
32
35
36
40
45
50
53
54
55
60
7.07
7.57
12.00
12.50
13.50
14.50
15.50
17.00
17.50
19.50
22.00
24.50
26.00
26.50
27.00
29.50
5.70
6.70
7.70
11.30
9.57
11.70
11.07
12.57
13.07
13.57
14.57
15.57
16.57
18.07
18.57
20.57
23.07
25.57
27.07
27.57
28.07
30.57
9.30
9.70
10.70
9.07
8.30
10.30
9.20
11.20
12.70
13.20
13.70
14.70
15.20
15.70
16.70
17.70
18.70
20.20
20.70
22.70
25.20
27.70
29.20
29.70
30.20
32.70
Purchase Unit
7.30
8.70
8.57
11.57
11.50
28
6.57
10.50
24
26
5.57
10.57
10.00
25
4.57
9.50
21
22
3.57
Unit : mm
10.80
12.30
12.80
13.30
14.30
14.80
15.30
16.30
16.80
17.30
18.30
19.30
20.30
21.80
22.30
24.30
26.80
29.30
30.80
31.30
31.80
34.30
500pcs/Reel
■ Connector Dimensions (1.0mm Pitch Product)
4-8Pos.
10-30Pos.
Part No.
HRS No.
No. of contacts
480-0168-0 00
6
480-0169-2 00
TF31-8S-1SH(800)
480-0211-7 00
TF31-6S-1SH(800)
TF31-10S-1SH(800)
TF31-22S-1SH(800)
Under planning
TF31-27S-1SH(800)
Under planning
TF31-26S-1SH(800)
TF31-60(30)SB-1SH(800)
8
7.00
9.07
11.20
13.07
15.20
16
Under planning
7.70
480-0848-0 00
TF31-17S-1SH(800)
TF31-32(16)SB-1SH(800)
480-0213-2 00
480-0252-0 00
480-0180-5 00
C
5.57
10
Under planning
B
3.00
480-0212-0 00
TF31-12S-1SH(800)
A
4
5.00
9.00
11.07
15.00
16.57
12
11.00
17
16.00
26
27
30
7.07
19.00
21.00
25.00
26.00
29.00
18.07
20.57
23.07
27.07
28.07
30.57
Note 5 : Contact positions without HRS No. are currently under planning.
Please contact Hirose for detailed information about product variations.
Note 6 : HRS No. with (895) specification : 500pcs/Reel is currently under planning.
D
3.40
12.80
2.90
2.90
10.80
13.20
14.80
20.20
22.70
25.20
29.20
20.20
32.70
F
2.90
9.20
18.70
E
9.30
16.80
20.30
21.80
24.30
26.80
30.80
31.80
34.30
2.90
2.90
2.90
2.40
2.90
2.40
2.90
2.90
2.90
2.40
Unit : mm
Purchase Unit
2.90
2.90
2.90
2.90
2.90
2.90
3,000pcs/Reel
2.90
2.90
2.90
2.90
5
Recommended FPC/FFC Dimensions and Land / Metal Mask Dimensions
0.5mm Pitch Product
FPC/FFC Dimensions
Recommended Metal Mask Thickness : 0.12mm
Part No.
B
C
Part No.
A
B
Unit : mm
C
TF31-4S-0.5SH(###)
1.5
2.5
3.9
TF31-4S-0.5SH(###)
1.5
3.5
7.3
TF31-7S-0.5SH(###)
3.0
4.0
5.4
TF31-7S-0.5SH(###)
3.0
5.0
8.8
TF31-6S-0.5SH(###)
TF31-8S-0.5SH(###)
TF31-10S-0.5SH(###)
TF31-12S-0.5SH(###)
TF31-13S-0.5SH(###)
TF31-14S-0.5SH(###)
TF31-16S-0.5SH(###)
TF31-17S-0.5SH(###)
TF31-18S-0.5SH(###)
TF31-20S-0.5SH(###)
2.5
3.5
4.5
5.5
6.0
6.5
7.5
8.0
TF31-30S-0.5SH(###)
TF31-32S-0.5SH(###)
TF31-35S-0.5SH(###)
TF31-36S-0.5SH(###)
TF31-40S-0.5SH(###)
TF31-45S-0.5SH(###)
TF31-50S-0.5SH(###)
TF31-53S-0.5SH(###)
TF31-54S-0.5SH(###)
TF31-55S-0.5SH(###)
TF31-60S-0.5SH(###)
6.5
7.0
7.5
8.5
5.9
6.9
7.9
8.4
8.9
9.9
10.5
11.9
10.5
11.5
11.5
TF31-28S-0.5SH(###)
5.5
9.5
8.5
TF31-24S-0.5SH(###)
TF31-26S-0.5SH(###)
4.5
4.9
10.4
10.0
TF31-25S-0.5SH(###)
3.5
9.0
TF31-21S-0.5SH(###)
TF31-22S-0.5SH(###)
6
A
Unit : mm
12.0
12.5
13.5
14.5
15.5
17.0
17.5
19.5
22.0
24.5
26.0
26.5
27.0
29.5
9.5
11.0
12.5
13.0
13.5
14.5
15.5
16.5
18.0
18.5
20.5
23.0
25.5
27.0
27.5
28.0
30.5
10.9
12.4
12.9
13.9
14.4
14.9
15.9
16.9
17.9
19.4
19.9
21.9
24.4
26.9
28.4
28.9
29.4
31.9
TF31-6S-0.5SH(###)
TF31-8S-0.5SH(###)
TF31-10S-0.5SH(###)
TF31-12S-0.5SH(###)
TF31-13S-0.5SH(###)
TF31-14S-0.5SH(###)
TF31-16S-0.5SH(###)
TF31-17S-0.5SH(###)
TF31-18S-0.5SH(###)
TF31-20S-0.5SH(###)
2.5
3.5
4.5
5.5
6.0
6.5
7.5
TF31-24S-0.5SH(###)
11.5
TF31-26S-0.5SH(###)
TF31-28S-0.5SH(###)
TF31-30S-0.5SH(###)
TF31-32S-0.5SH(###)
TF31-35S-0.5SH(###)
TF31-36S-0.5SH(###)
TF31-40S-0.5SH(###)
TF31-45S-0.5SH(###)
TF31-50S-0.5SH(###)
TF31-53S-0.5SH(###)
TF31-54S-0.5SH(###)
TF31-55S-0.5SH(###)
TF31-60S-0.5SH(###)
8.0
11.8
7.5
8.5
9.5
11.5
10.5
12.0
12.5
13.5
14.5
15.5
17.0
17.5
19.5
22.0
24.5
26.0
26.5
27.0
29.5
9.3
10.3
9.5
8.5
8.3
6.5
10.0
10.0
TF31-25S-0.5SH(###)
5.5
8.0
TF31-21S-0.5SH(###)
TF31-22S-0.5SH(###)
4.5
10.5
12.0
12.5
13.5
14.0
14.5
15.5
16.5
17.5
19.0
19.5
21.5
24.0
26.5
28.0
28.5
29.0
31.5
11.3
12.3
13.3
13.8
14.3
15.3
15.8
16.3
17.3
17.8
18.3
19.3
20.3
21.3
22.8
23.3
25.3
27.8
30.3
31.8
32.3
32.8
35.3
1.0mm Pitch Product
FPC/FFC Dimensions
Part No.
A
B
C
Unit : mm
D
E
Part No.
A
B
C
Unit : mm
D
E
3.0
5.5
6.9
1.0
1.5
3.0
6.5
10.3
1.5
2.0
TF31-8S-1SH(800)
7.0
9.0
10.4
1.0
1.0
TF31-8S-1SH(800)
7.0
10.0 13.8
1.5
1.5
TF31-6S-1SH(800)
TF31-10S-1SH(800)
5.0
9.0
7.0
8.4
11.0 12.4
TF31-12S-1SH(800)
11.0 13.0 14.4
TF31-17S-1SH(800)
16.0 18.0 19.4
TF31-22S-1SH(800)
TF31-26S-1SH(800)
TF31-27S-1SH(800)
15.0 16.5 17.9
19.0 20.5 21.9
21.0 23.0 24.4
25.0 27.0 28.4
26.0 28.0 29.4
29.0 30.5 31.9
1.0
1.0
1.0
0.5
1.0
0.5
1.0
1.0
1.0
0.5
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
TF31-6S-1SH(800)
TF31-10S-1SH(800)
5.0
9.0
8.0
11.8
12.0 15.8
TF31-12S-1SH(800)
11.0 14.0 17.8
TF31-17S-1SH(800)
16.0 19.0 22.8
TF31-22S-1SH(800)
TF31-26S-1SH(800)
TF31-27S-1SH(800)
15.0 17.5 21.3
19.0 21.5 25.3
21.0 24.0 27.8
25.0 28.0 31.8
26.0 29.0 32.8
29.0 31.5 35.3
1.5
1.5
1.5
1.0
1.5
1.0
1.5
1.5
1.5
1.0
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
1.5
7
Packaging Specification
Embossed Carrier Tape Dimensions(Tape Width 24mm Max.)
Embossed Carrier Tape Dimensions(Tape Width 32mm Min.)
Reel Dimensions
Note 1 : 3,000pcs / Reel (Reel Outer Diameter: ø380±2mm), 500pcs / Reel (Reel Outer Diameter: ø180±2mm)
Note 2 : Material
1) Emboss Tape : Tape width 24mm Max. : PS (Antistatic Treatment), Tape width 32mm Min. : PET (Antistatic Treatment)
2) Cover Tape : PET (Antistatic Treatment)
8
[0.5mm Pitch Product]
Part No.
B
16
16
TF31-7S-0.5SH(###)
16
TF31-6S-0.5SH(###)
TF31-8S-0.5SH(###)
TF31-10S-0.5SH(###)
TF31-12S-0.5SH(###)
TF31-13S-0.5SH(###)
TF31-14S-0.5SH(###)
TF31-16S-0.5SH(###)
A
TF31-4S-0.5SH(###)
TF31-17S-0.5SH(###)
TF31-18S-0.5SH(###)
TF31-20S-0.5SH(###)
TF31-21S-0.5SH(###)
TF31-22S-0.5SH(###)
TF31-24S-0.5SH(###)
TF31-25S-0.5SH(###)
TF31-26S-0.5SH(###)
TF31-28S-0.5SH(###)
TF31-30S-0.5SH(###)
TF31-32S-0.5SH(###)
TF31-35S-0.5SH(###)
TF31-36S-0.5SH(###)
TF31-40S-0.5SH(###)
TF31-45S-0.5SH(###)
TF31-50S-0.5SH(###)
TF31-53S-0.5SH(###)
TF31-54S-0.5SH(###)
TF31-55S-0.5SH(###)
TF31-60S-0.5SH(###)
16
16
24
24
24
24
24
24
24
32
32
44
44
44
44
44
44
44
44
56
B
24
11.1
11.5
32
28.4
15.1
14.2
44
40.4
16
8.1
7.5
TF31-8S-1SH(800)
24
7.6
8.6
9.6
7.5
7.5
7.5
10.6
11.5
11.6
11.5
28.4
28.4
28.4
28.4
28.4
28.4
40.4
40.4
40.4
40.4
40.4
40.4
40.4
40.4
52.4
11.1
12.6
13.1
13.6
14.6
15.1
15.6
16.6
17.1
17.6
18.6
19.6
20.6
22.1
22.6
24.6
27.1
29.6
31.1
31.6
32.1
34.6
11.5
11.5
11.5
11.5
11.5
14.2
TF31-6S-1SH(800)
TF31-10S-1SH(800)
TF31-12S-1SH(800)
TF31-17S-1SH(800)
TF31-22S-1SH(800)
TF31-26S-1SH(800)
TF31-27S-1SH(800)
32
32
44
44
44
44
56
28.4
28.4
40.4
40.4
40.4
40.4
52.4
C
Unit : mm
A
28.4
32
Part No.
7.5
32
32
D
6.6
28.4
32
[1.0mm Pitch Product]
32
32
C
Unit : mm
9.6
13.1
17.1
22.1
20.6
24.6
27.1
31.1
32.1
34.6
D
7.5
11.5
14.2
20.2
14.2
20.2
20.2
20.2
20.2
26.2
14.2
14.2
14.2
14.2
14.2
14.2
14.2
20.2
20.2
20.2
20.2
20.2
20.2
20.2
20.2
26.2
9
TF31 Series FPC/FFC Construction (Recommended Specifications)
FPC : Flexible Printed Circuit
Material Name
Polyimide
Surface treatment
Nickel 1 to 5㎛ +
Copper foil
CU
1oz
35
Polyimide
1mil
25
Polyimide
7mil
Base adhesive
Base film
Reinforcement
Stiffener
FFC : Flexible Flat Cable
Adhesive
Annealed copper foil
Adhesive
Polyester
Adhesive
Stiffener
(25)
(25)
3
Gold plating 0.2㎛
Thermoset adhesive
25
Thermoset adhesive
Total
Material Name
Polyester film
Material
30
175
293
Thickness(㎛)
Polyester thermoplastic
type
(12)
(30)
Gold plated nickel
35
Polyester type
Polyester type
Polyester type
Total
30
12
30
188
295
Note 1 : This specification is recommended for the component configuration of the TF31 Series FPC and FFC (t=0.3±0.03mm)
Note 2 : For details about component configuration, please contact a FPC/FFC manufacturer.
Recommended Temperature Profile
MAX 250○C
250
Temperature
Material adhesive
1mil
Thickness(㎛)
Covering layer film
Cover adhesive
Material
(○C)
230○C
200
200○C
150
100
25○C
(60 seconds)
Start
90 to 120 seconds
Preheating
Time (s)
Reflow method
: Reflow, IR/hot air
Reflow Environment : Room air
Solder Composition : Paste, 96.5%Sn/3%Ag/0.5%Cu
(M705-221CM5-32-10.5 from Senju
Metal Industry Co., Ltd.)
Test Board : Glass epoxy 40mm×80mm×1.6mm thick
Land Dimensions : 0.3mm×1.3mm
Metal Mask : 0.3mm×1.3mm×0.12mm thick
150○C
50
HRS Test Conditions
(30 seconds)
Soldering
The temperature profile is based on the above
conditions. Please check the mounting conditions before
use, conditions such as solder paste types,
manufacturer, PCB size and any other soldering
materials may alter the performance of such materials.
Connector Operation and Precautions
● Board
Board Mounting Precautions
Warpage
Be sure to minimize the board warpage as much
as possible. The lead co-planarity is 0.1mm or less.
Excessive board warpage may result in soldering failures
or co-planarity issues.
● Connector
Actuator Operation
1. Do not apply excessive force on the actuator
when releasing it from its initial position.
Using a nail or finger as shown below,
may result in terminal deformation.
Load
If the connector is not mounted onto a board,
refrain from doing any of the following actions: Do
not apply a force of 0.5N or more to the connector.
Do not insert the FFC or operate the connector.
Any of these actions may damage or break the
connector.
FPC/FFC Insertion/Mating Precautions
Instruction after mounting on the board
Board Stress
It may advisable to split larger boards into smaller
sections to reduce overall board stress. Avoid placing any
excess force on the board during the assembly process.
When using screws to secure the boards, be sure to check
for any unwanted stress that may occur from this operation
as well.
● Acceptable
2. The actuator rotates around the axis as shown below.
Make sure to rotate the whole actuator and
not just the center portion.
3. The actuator opens up to 110°. Do not force
the actuator beyond this point. Doing so may
result in actuator damage or breakage.
Amount of Board Warpage
A 100 mm wide board has an acceptable warp
range of 0.5mm or less. (Below) Excessive amounts of
warping will place stress on the connector which
may result in damage and malfunction.
4. Operate the actuator towards the center.
Operating one side only may result in actuator
damage or incomplete mating.
5. Do not pull or pick at the actuator. Doing so may
damage it. (Do not carry out any operation other than
the actuator rotation operation described in 2.)
● Contact
Orientation
This connector utilizes bottom contacts. Insert the
FPC/FFC with the exposed conductors face down.
11
Inserting the FPC/FFC
1. There is a FPC/FFC positioning guide. Insert the
FPC/FFC straight into the connector while at a 10° angle
to the board surface (see illustration below). Make sure
that it has been fully inserted.
● Ensuring
a Completed Connection
After completing the locking operation, be sure to check
that the actuator is horizontal to the board surface.
Do not apply excessive force when the actuator reaches
0°, doing so may damage the terminals.
Instructions on FPC/FFC layout after Mating
● Load
2. Do not insert the FPC/FFC diagonally.
If the FPC/FFC is inserted in skewed orientation
as illustrated above, the FPC/FFC may get caught
by the terminals resulting in terminal deformation.
Additionally the FPC/FFC may be bent, resulting in
pattern breakage or insufficient insertion which may
cause conduction failure.
*Secure sufficient FPC/FFC insertion space during layout
design to prevent diagonal FPC/FFC insertion.
Additionally if the FPC/FFC is too short, it may be
difficult to insert. Arrange appropriate parts during
layout.
*Consult with your FPC/FFC manufacturer to select
a flex circuit that has the correct flex characteristics
to avoid breakage.
to FPC/FFC
Do not apply direct force to the connector during FPC/FFC
routing. Contact failure, disconnection or breakage may
occur when using a FPC/FFC bent near the connector.
In general the FPC/FFC should not be bent sharply near
the insertion opening. Secure the FPC/FFC when applying
a continuous load.
Load : 0.1 x n N Max.
(n : number of contacts)
FPC/FFC Removal Precautions
Release the actuator near the center. Operating one
side only may result in actuator damage or incomplete
mating.
Remove the FPC/FFC with the actuator released.
There is a FPC/FFC positioning guide. Pull the FPC/FFC
straight out of the connector at a 10° angle to the
board surface.
● Manual
3. After FPC/FFC insertion make sure that the FPC/FFC
positioning tabs are properly aligned. Locking the
actuator with the FPC/FFC tab on the guides may result
in contact failure.
Other Precautions
Soldering
Follow the instructions shown below when soldering the
connector manually during repair work, etc.
1. Do not perform reflow soldering or manual soldering
with the FPC/FFC inserted into the connector.
2. Do not overheat the connector. Do not allow the
soldering iron to contact any part other than
the intended connector leads. Unnecessary contact
may lead to damage and deformities of the connector.
3. Do not use excessive solder (flux). If excessive
solder (flux) is used on the terminals, solder or flux
may adhere to the contacts or rotating parts of the
actuator, resulting in poor contact or a rotation failure
of the actuator.
12
While taking in consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the "Drawing" and "Product Specifications" sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non-specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure,
aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
The contents of this catalog are current as of date of 05/2022. Contents are subject to change without notice for the purpose of improvements.
13
