1107-062 NT
1107-062 NT
    BIVAR
1107-062 NT 数据手册
REV. DATE APPROVED 02/13/04 11/26/07 09/11/12 05/16/16 M. C. M. C. T. Y. J. C. DESCRIPTION C Engineering Update w/o Changes D Updated S Dimension E Updated 14-NL Material to 94V-0 F Added Notes 3, 4, 5 & Color Options Sheet #2 L1 W (1107X-XXX) (1107X0-XXX) L2 0.260 [6.6mm] 0.65 [16.6mm] S (SLOT BASE) (1107X-XXX) 0.435 [11.0mm] 0.59 [15.0mm] (1107X0-XXX) 0.185 [4.7mm] Ø.093 [Ø2.36mm] 0.490 [12.4mm] 6 DEG MAX DRAFT PART NO. COLOR 1107-062 NT NATURAL 1107-062 XX SEE S.#2 11073-062 NT NATURAL 11073-062 XX SEE S.#2 11073-093 NT NATURAL 11073-093 XX SEE S.#2 11073-125 NT NATURAL 11073-125 XX SEE S.#2 110710-062 NT NATURAL 110710-062 XX SEE S.#2 1107310-062 NT NATURAL 1107310-062 XX SEE S.#2 1107310-093 NT NATURAL 1107310-093 XX SEE S.#2 1107310-125 NT NATURAL 1107310-125 XX SEE S.#2 L2 PCB THICKNESS ROLL PIN DESC .075 (1.9mm) .290 (7.4mm) 2.0 (50.8mm) - .062 (1.6mm) RP-250 83023-09 .075 (1.9mm) .350 (8.9mm) 2.0 (50.8mm) - .062 (1.6mm) RP-312 - .100 (2.5mm) .350 (8.9mm) 2.0 (50.8mm) - .093 (2.4mm) RP-312 - .140 (3.6mm) .350 (8.9mm) 2.0 (50.8mm) - .125 (3.2mm) RP-312 83023-10 S W L1 .075 (1.9mm) .290 (7.4mm) - 1.5 (38.1mm) .062 (1.6mm) RP-250 83023-11 .075 (1.9mm) .350 (8.9mm) - 1.5 (38.1mm) .062 (1.6mm) RP-312 - .100 (2.5mm) .350 (8.9mm) - 1.5 (38.1mm) .093 (2.4mm) RP-312 - .140 (3.6mm) .350 (8.9mm) - 1.5 (38.1mm) .125 (3.2mm) RP-312 - 0.30 [7.6mm]MIN. 45° x 0.25 [6.4mm] CHAMFER 0.24 [6.1mm] 0.25 [6.4mm] 0.18 [4.6mm] 0.51 [12.9mm] MIN. 0.25 [6.4mm] 0.047 [1.2mm] Ø.109 [Ø2.8mm] Recommended Application Layout STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS 4. PRE-ASSEMBLED ROLL PINS AVAILABLE UPON REQUEST. 3. ROLL PINS INCLUDED. PACKAGED SEPARATELY. 2. MATERIAL: NYLON 6/6, 30% GLASS, 94V-0 NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PCB INSERTER/EXTRACTOR DATE: 04/16/03 DATE: 04/16/03 REVISION: PART NO: 1107XXX-XXX XX CAGE CODE : 32559 F SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 OTHER AVAILABLE COLORS * SEE TABLE FOR ORDERING INFORMATION 1107___-___ SERIES 1107-062 11073-062 11073-093 11073-125 110710-062 1107310-062 1107310-093 1107310-125 ORDER CODE AA BK BE BN FG GY GN LE OE PK RD VT YW COLOR AQUA BLACK BLUE BROWN FOREST GREEN GRAY GREEN LIME ORANGE PINK RED VIOLET YELLOW STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: PCB INSERTER/EXTRACTOR DESIGNED: D. Green 5. PARTS ARE DYED TO COLOR UPON REQUEST. CHECKED: M. Chen DATE: 04/16/03 DATE: 04/16/03 REVISION: PART NO: 1107XXX-XXX XX CAGE CODE : 32559 F SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
1107-062 NT 价格&库存
很抱歉,暂时无法提供与“1107-062 NT”相匹配的价格&库存,您可以联系我们找货
