CONUFL001-SMD
CONUFL001-SMD
    LINXTECHNOLOGIES(灵思)
CONUFL001-SMD 数据手册
8 5 6 7 4 2 3 1 REVISIONS 0.020 0.50 REV 0.071 1.80 DESCRIPTION A INITIAL RELEASE OF LINX INTERNAL DRAWING DATE APPV 15-MAY-17 CLL 10-JUL-17 CLL TITLE; ADDED P/N TABLE AND SECOND SHEET B UPDATED SHOWING TAPE AND REEL INFORMATION D D GND 0.157±0.002 4.00±0.05 GND CUT OUT PROHIBITION AREA 0.075±0.002 1.90±0.05 SIG GND 0.079 2.00 C 0.039±0.002 1.00±0.05 C 0.087±0.002 2.20±0.05 0.049±0.002 1.25±0.05 GND 0.014±0.002 0.35±0.05 0.041±0.002 1.05±0.05 0.039±0.002 1.00±0.05 0.118 3.00 0.102 2.60 B SIG RECOMMENDED FOOTPRINT 0.024 0.60 NOTES: (UNLESS OTHERWISE SPECIFIED) 1. ALL DIMENSIONS ARE IN INCHES [mm]. 2. DIMENSIONS APPLY AFTER FINISHING. 3. MANUFACTURE TO BE COMPLIANT WITH EU RoHS DIRECTIVE,USE MATERIALS THAT DO NOT CONTAIN REACH SUBSTANCES OF VERY HIGH CONCERN >1000ppm, AND USE DRC CONFLICT-FREE SOURCED MATERIALS. 4. SAFETY BREAK ALL SHARP CORNERS AND EDGES .02 MAXIMUM. 5. COMPATIBLE WITH IPEX MHF, MHFII AND HIROSE U.FL. 6. HOUSING: LCP, UL94V-0, WHITE 7. CONTACT: BRASS, GOLD PLATING 8. GROUND CONTACT: PHOSPHOR BRONZE, GOLD PLATING. 9. ELECTRICAL SPECIFICATIONS IMPEDANCE: 50 OHM FREQUENCY: 0 - 6GHz OPERATING TEMPERATURE: -40°C TO +90°C. PART NUMBER 0.122 3.10 0.102 2.60 CONUFL001-SMD CONUFL001-SMD-T 0.071 1.80 WARNING: THIS DRAWING CONTAINS PROPRIETARY INFORMATION THAT IS THE SOLE PROPERTY OF LINX TECHNOLOGIES, AND SHALL BE TREATED AS SUCH. NO DISCLOSURE OR REPRODUCTION OF THIS DOCUMENT IS PERMITTED, IN WHOLE OR IN PART, WITHOUT THE EXPRESS WRITTEN PERMISSION OF LINX TECHNOLOGIES OR ITS DESIGNATED AGENTS. A MATERIAL: 4XR0.010 0.25 8 7 6 INTERPRET DIMENSIONS AND TOLERANCES PER ASME Y14.5. 32 FINISH: 5 4 TITLE: SURFACE FINISH: ANGLES: 1 TOLERANCES: .X .1 .XX .01 .XXX .005 PACKAGING BULK TAPE & REEL 159 ORT LANE MERLIN, OR 97532 SIZE DWG. NO. REV B B DRAWN: B.MURPHY DT: 10-MAY-17 CONUFL001-SMD-* ENGR:D.VARATHARAJAN DT: 15-MAY-17 SCALE: 16:1 DO NOT SCALE DRAWING 3 A MICRO COAXIAL SURFACE MOUNT CONNECTOR PROJECTION: 2 B SHEET 1 OF 2 1 LDCFDFB_C 8 7 6 5 4 3 2 1 SEE SHEET 1 FOR REVISIONS D D C C B B NOTES: 1. ALL DIMENSIONS ARE IN MILLIMETERS. 2. TOLERANCES (UNLESS OTHERWISE SPECIFIED): .X ±0.1mm .XX ±0.05mm .XXX ±0.03mm A SIZE DWG. NO. A 7 6 5 4 3 2 B CONUFL001-SMD-T SCALE: 16:1 8 REV SHEET 2 OF 2 DO NOT SCALE DRAWING 1 LDCFDFB_A A
CONUFL001-SMD 价格&库存
很抱歉,暂时无法提供与“CONUFL001-SMD”相匹配的价格&库存,您可以联系我们找货
