FX23L-100S-0.5SV
FX23L-100S-0.5SV
    HRS(广濑)
    SMD
FX23L-100S-0.5SV 数据手册
High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors FX23/FX23L Series Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX23 Features 1. 0.5mm pitch 2. Stacking (Height : 8 - 30mm)/vertical 3. Contacts available : 20/40/60/80/100/120 for signal + 4 for power source 4. Floating movable amount : X direction : ±0.6mm ; Y direction: ±0.6mm FX23L Floating ability : XY-axis±0.6mm Y X Y X Y X A floating movement above the connector pitch is possible. (Fig.1) 5. High-speed transmission (8+ Gbps) 6. Hybrid power design (3A/pin×4 lines) Vertical connection The guide posts on both sides of the connector are equipped with 4 lines of power contacts in addition to the signal contact. (Fig.2) 7. Current capacity : Signal contact 0.5A/pin, power contact 3A/pin 8. Available for automatic mounting (absorption tape is attached as standard equipment) 9. Excellent mating performance due to the large guide post. Stacking connection Fig.1 Hybrid Power/Signal contacts Power contact Signal integrity ● ICR (Insertion-loss-to-Crosstalk-Ratio) The ICR containing cross-talk from 5 adjacent differential pairs provides adequate margin in comparison with the criteria based on the specification of IEEE802.3ap. Signal contact ● Differential impedance Header side Receptacle side Differential impedance is 100±10ø at the rise time of 87.5ps (20 to 80%). In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. Fig.2 2019.6⑥ 1 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ■Product Specifications Ratings Items Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range : -55 to 105℃ (Note 1) Storage temperature range : -10 to 60℃ (Note 2) Operating/storage humidity range : 90% or less relative humidity (No dew condensation is allowed) Rated current : Signal part 0.5A Power part 3.0A Rated voltage : Signal part AC 50V Power part AC 200V Specifications Conditions 1. Contact resistance Signal part 70mø or less Power part 20mø or less Measured at 100mA 2. Insulation resistance Signal part 100Mø or more Power part 1,000Mø or more Signal part Measured at DC Signal Measured at DC 100V Power Measured at DC 250V 3. Withstanding Voltage No flashover or breakdown. Signal contacts Energized at AC 150V for 1 minute Power contacts Energized at AC 600V for 1 minute 4. Mating durability Contact resistance of the signal part 80mø or less Power part 30mø or less. 100 times insertion/withdrawal 5. Vibration proof No electric outage of 1μ or greater. Frequency 10 - 55Hz, half amplitude 0.75mm, 10 cycles in each of the 3-axis directions each for 5 minutes per cycle 6. Shock resistance No electric outage of 1μ or greater. Acceleration of 490m/s2 ; duration 11ms, sine half-wave, 3 cycles in each of the 3 axes each in both directions. 7. Moisture resistance Contact resistance of the signal part 80mø or less Power part 30mø or less Insulation resistance at the signal part 100Mø or more Power part 1,000Mø or more. Left to stand for 96 hours at the temperature of 40℃ and the humidity of 90 to 95% 8. Temperature cycle Contact resistance of the signal part 80mø or less Power part 30mø or less Insulation resistance at the signal part 100Mø or more Power part 1,000Mø or more. Temperature -55 → 85℃ 5 cycles for a series of time periods : 30 minutes → 30 minutes Note 1 : Includes temperature rise caused by current flow. Note 2 : The term “storage” refers to the long-term storage condition of unused products before mounting on PCB. ■Materials / Finish Part Insulator (FX23) Insulator (FX23L) Materials Finish UL standard Black color UL94V-0 Polyamide resin Black color UL94V-0 Copper alloy Contacted part : gold plating Signal contact-mounting part : gold plating Power contact-mounting part : pure tin plating − Pure tin plated − Header Polyamide resin Receptacle LCP resin Header Receptacle Header Contact Receptacle Reinforcement metal fitting 2 Brass FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Straight header FX23 - 120 P - 0.5 SV 15 ❶ ❷ ❸ ❹ ❺ ❶Series name :FX23 ❷Number of contacts ❻ ❸Connector type ●Straight receptacle FX23 - 120 S - 0.5 SV 10 ❶ ❷ ❸ ❹ ❺ ❹Contact pitch P :Header type S :Receptacle type :0.5mm ❺Product type SV :Vertical SH :Right angle type ❻ ❻Product height type Mating height [mm] = Numerical value on the header side + Numerical value on the receptacle side FX23 - 120 S - 0.5 SH ❶ ❷ ❸ ❹ ❺ ●Straight header ❶Series name FX23L - 120 P - 0.5 SV 8 ❶ ❷ ❸ ❹ ❺ ❻ ●Straight receptacle FX23L - 120 S - 0.5 SV 10 ❶ ❷ ❸ ❹ ❺ :FX23L ❷Number of contacts ❸Connector type P :Header type S :Receptacle type ❹Contact pitch :0.5mm ❺Product type SV :Vertical ❻Product height type Mating height [mm] = Numerical value on the header side ❻ High-speed transmission property (FX23 : h=15mm, FX23L : h=12mm) ●Pin assignment The following pin arrangement is recommended to match the 100ø differential impedance and to contain cross-talk. Signal pin Diff pair Ground pin ●Differential impedance 80ps rise time (20 to 80%) 115 115 110 FX23 110 Z(Ohm) 100 100 95 95 90 90 85 0.8 FX23L 105 105 Z(Ohm) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Right angle receptacle 1 1.2 1.4 Time (ns) 1.6 1.8 85 0.8 1 1.2 1.4 Time (ns) 1.6 1.8 Meets the criterion of 100±10ø at the rise time of 80ps (20 to 80%). 3 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors 0 0 -1 -1 -2 -2 -3 -3 -4 -4 S (dB) S (dB) ●Insertion loss -5 -6 -5 -6 -7 -7 -8 -8 -9 -10 -9 FX23 0 2 4 6 Frequency (GHz) 8 -10 10 FX23L 0 2 4 6 Frequency (GHz) 8 10 2 4 6 Frequency (GHz) 8 10 4 6 Frequency (GHz) 8 10 4 6 Frequency (GHz) 8 10 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Return loss 0 0 FX23 -10 -10 -15 -15 -20 -20 -25 -30 -25 -30 -35 -35 -40 -40 -45 -45 -50 0 FX23L -5 S (dB) S (dB) -5 2 4 6 Frequency (GHz) 8 -50 10 0 Passes insertion loss, return loss up to 5GHz. ●Near end cross-talk (NEXT) 0 0 FX23 -10 -20 -20 -30 -30 -40 -40 S (dB) S (dB) -10 -50 -60 -50 -60 -70 -70 -80 -80 -90 -90 -100 0 -100 0 2 4 6 Frequency (GHz) 8 10 FX23L 2 ●Far end cross-talk (FEXT) 0 0 FX23 -10 -20 -20 -30 -30 -40 -40 S (dB) S (dB) -10 -50 -60 -60 -70 -80 -80 -90 -90 -100 0 -100 0 4 6 Frequency (GHz) Low cross-talk up to 10GHz. 4 -50 -70 2 8 10 FX23L 2 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ●Insertion loss/cross-talk ratio (ICR) for FEXT Signal pin Victim Diff pair Aggressor Diff pair 60 60 50 50 40 40 S (dB) S (dB) 30 20 10 10 FX23 0 30 20 0 2 ICR(5 aggressors) 10GBASE-KR Spec. ICR 4 6 8 10 Frequency (GHz) FX23L 0 0 2 ICR(5 aggressors) 10GBASE-KR Spec. ICR 4 6 8 10 Frequency (GHz) Insertion loss/cross-talk ratio (ICR) for FEXT using 5 sets of Aggressors has an adequate margin according to the specification of IEEE802.3ap. ■List of connection variations (vertical connection) Right angle receptacle 15.9 13.9 Rigid combination FX23L-**P-0.5SV10 20.9 FX23-**S-0.5SH 11.9 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ground pin Floating combination FX23L-**P-0.5SV12  FX23-**P-0.5SV15 FX23-**P-0.5SV20 Vertical header **⇒Number of contacts:20、40、60、80、100、120 Note : FX23L-**P-0.5SV8 and FX23-**S-0.5SH can not engage since the metal hold down interferes each other. 5 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ■List of connection variations (Parallel connection) ●Height variation FX23L-**P-0.5SV8 FX23L-**P-0.5SV10 FX23L-**P-0.5SV12 FX23-**P-0.5SV15 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Rigid Type FX23L-**S-0.5SV Rigid Type Rigid Type Floating Type FX23-**P-0.5SV20 Floating Type FX23L series Standard Type FX23×FX23L series Double Floating Type Floating range : XY direction ±0.6mm Floating range : XY direction ±1.2mm 8mm 10mm 12mm 14mm 19mm Floating Type FX23×FX23L series Rigid Type FX23 series Standard Type No floating ability FX23-**S-0.5SV Floating range : XY direction ±0.6mm 9mm 11mm 13mm 15mm 20mm 19mm 21mm 23mm 25mm 30mm Rigid Type FX23-**S-0.5SV10 Rigid Type 6 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ■Product dimensions FX23 series ●Vertical header [FX23-**P-0.5SV15] A±0.3 B±0.2 Contact No.G Contact No.H Contact No.F Contact No.1 t=0.15±0.03 × w=0.2±0.05 7.3±0.25 8.9±0.3 P=0.5±0.15 1.35±0.25 12.85±0.3 7.8±0.3 3.7±0.15 0.15±0.03 0.8±0.1 2.6±0.25 7.45±0.25 1.35±0.25 0.8±0.1 D±0.25 0.25±0.03 E±0.25 +0.2 4ר1.4 0(Land) P=0.5±0.03 Contact No.G Contact No.H  0 4.1 −0.1 4ר1 Power contact No.4 B±0.03 +0.1  0 +0.1  0(TH) 7.45±0.03 Power contact No.3 2.6±0.03 +0.1 7.9 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C±0.15 4ר1.2  0(TH) +0.2  0(Land) 4ר1.6 Power contact No.1 Power contact No.2 Contact No.1 Contact No.F Land Pattern : 0.3±0.03 Metal Mask(t=0.15):0.25±0.03 Metal Mask(t=0.12):0.3±0.03 D±0.03 E±0.03 Unit : mm Part No. HRS No. No. of contacts A B C D E F G H FX23-20P-0.5SV15 573-3001-0 00 20 18.7 4.5 FX23-40P-0.5SV15 573-3002-3 00 40 23.7 9.5 11.65 9.5 17.5 10 11 20 16.65 14.5 22.5 20 21 40 FX23-60P-0.5SV15 573-3003-6 00 60 28.7 14.5 21.65 19.5 27.5 30 31 60 FX23-80P-0.5SV15 573-3004-9 00 80 FX23-100P-0.5SV15 573-3005-1 00 100 33.7 19.5 26.65 24.5 32.5 40 41 80 38.7 24.5 31.65 29.5 37.5 50 51 100 FX23-120P-0.5SV15 573-3006-4 00 120 43.7 29.5 36.65 34.5 42.5 60 61 120 7 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors [FX23-**P-0.5SV20] A±0.3 B±0.2 Contact No.G Contact No.H 7.3±0.25 8.9±0.3 P=0.5±0.15 Contact No.F Contact No.1 t=0.15±0.03 × w=0.2±0.05 1.35±0.25 0.15±0.03 0.8±0.1 2.6±0.25 7.45±0.25 D±0.25 0.25±0.03 E±0.25 +0.2  0(Land) 4ר1.4  0 P=0.5±0.03 Contact No.G 4.1 −0.1 Power Contact No.4 B±0.03 Contact No.H +0.1  0 +0.1 7.45±0.03 2.6±0.03 Power Contact No.3 4ר1 0(TH) 3.7±0.15 0.8±0.1 1.35±0.25 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 17.85±0.3 12.8±0.3 C±0.15 7.9 +0.1 4ר1.2  0(TH) +0.2  0(Land) 4ר1.6 Power Contact No.1 Power Contact No.2 Contact No.F Contact No.1 Land Pattern : 0.3±0.03 Metal Mask(t=0.15):0.25±0.03 Metal Mask(t=0.12):0.3±0.03 D±0.03 E±0.03 Unit : mm Part No. 8 HRS No. No. of contacts A B C D E F G H FX23-20P-0.5SV20 573-3101-5 00 20 18.7 4.5 FX23-40P-0.5SV20 573-3102-8 00 40 23.7 9.5 11.65 9.5 17.5 10 11 20 16.65 14.5 22.5 20 21 40 FX23-60P-0.5SV20 573-3103-0 00 60 28.7 14.5 21.65 19.5 27.5 30 31 60 FX23-80P-0.5SV20 573-3104-3 00 80 33.7 19.5 26.65 24.5 32.5 40 41 80 FX23-100P-0.5SV20 573-3105-6 00 100 38.7 24.5 31.65 29.5 37.5 50 51 100 FX23-120P-0.5SV20 573-3106-9 00 120 43.7 29.5 36.65 34.5 42.5 60 61 120 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ●Vertical receptacle [FX23-**S-0.5SV] A±0.3 B±0.2 Contact No.1 Contact No.E 7.6±0.3 P=0.5±0.15 Contact No.G Contact No.F 6.8±0.3 0.15±0.03 0.8±0.1 2.6±0.25 6.1±0.25 7.6±0.25 1.35±0.25 1.35±0.25 0.8±0.1 C±0.25 0.25±0.03 D±0.25 Power Contact No.2  0 P=0.5±0.03 Contact No.1 4.4 −0.1 B±0.03 Contact No.E 8.2 +0.1  0 6.1±0.03 Power Contact No.1 2.6±0.03 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. t=0.15±0.03 × w=0.2±0.05 +0.1 4ר1 0(TH) +0.2 4ר1.4 0 (Land) 4ר1.2 +0.1  0(TH) +0.2 4ר1.6 0 (Land) Power Contact No.3 Contact No.F Contact No.G Land Pattern : 0.3±0.03 Metal Mask(t=0.15):0.25±0.03 Metal Mask(t=0.12):0.3±0.03 C±0.03 D±0.03 Power Contact No.4 Unit : mm HRS No. No. of contacts A B C D E F G FX23-20S-0.5SV Part No. 573-3201-0 00 20 17.2 4.5 9.5 15.7 10 11 20 FX23-40S-0.5SV 573-3202-2 00 40 22.2 9.5 14.5 20.7 20 21 40 FX23-60S-0.5SV 573-3203-5 00 60 27.2 14.5 19.5 25.7 30 31 60 FX23-80S-0.5SV 573-3204-8 00 80 32.2 19.5 24.5 30.7 40 41 80 FX23-100S-0.5SV 573-3205-0 00 100 37.2 24.5 29.5 35.7 50 51 100 FX23-120S-0.5SV 573-3206-3 00 120 42.2 29.5 34.5 40.7 60 61 120 9 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors [FX23-**S-0.5SV10] A±0.3 B±0.2 P=0.5±0.15 Contact No.E 7.6±0.3 Contact No.1 Contact No.F Contact No.G 0.15±0.03 0.8±0.1 2.6±0.25 6.1±0.25 7.6±0.25 1.35±0.25 1.35±0.25 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 16.8±0.3 t=0.15±0.03 × w=0.2±0.05 0.8±0.1 C±0.25 0.25±0.03 D±0.25 Power Contact No.2  0 P=0.5±0.03 Contact No.1 4.4 −0.1 B±0.03 Contact No.E 8.2 +0.1  0 6.1±0.03 2.6±0.03 Power Contact No.1 +0.1 4ר1 0(TH) +0.2 4ר1.4 0 (Land) 4ר1.2 +0.1  0(TH) +0.2 4ר1.6 0 (Land) Power Contact No.3 Contact No.F Contact No.G Land Pattern:0.3±0.03 Metal Mask(t=0.15):0.25±0.03 Metal Mask(t=0.12):0.3±0.03 C±0.03 D±0.03 Power Contact No.4 Unit : mm Part No. 10 HRS No. No. of contacts A B C D E F G FX23-20S-0.5SV10 573-3301-4 00 20 17.2 4.5 9.5 15.7 10 11 20 FX23-40S-0.5SV10 573-3302-7 00 40 22.2 9.5 14.5 20.7 20 21 40 FX23-60S-0.5SV10 573-3303-0 00 60 27.2 14.5 19.5 25.7 30 31 60 FX23-80S-0.5SV10 573-3304-2 00 80 32.2 19.5 24.5 30.7 40 41 80 FX23-100S-0.5SV10 573-3305-5 00 100 37.2 24.5 29.5 35.7 50 51 100 FX23-120S-0.5SV10 573-3306-8 00 120 42.2 29.5 34.5 40.7 60 61 120 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ●Right angle receptacle [FX23-**S-0.5SH] A±0.3 B±0.2 Contact No.1 Contact No.F 8.5±0.3 8±0.3 t=0.15±0.03 × w=0.2±0.05 P=0.5±0.15 Contact No.H Contact No.G 1.35±0.25 t=0.15±0.03 × w=0.2±0.05 B±0.2 7.3±0.3 1.35±0.25 0.8±0.1 C±0.25 0.15±0.03 0.8±0.1 0.8±0.1 D±0.25 0.25±0.03 E±0.25 Power Contact No.2 Power Contact No.4 B±0.03 +0.1 4ר1.2 0(TH) P=0.5±0.03 Contact No.1 Contact No.F Contact No.G Contact No.H 4.65±0.03 6.4±0.03 +0.1 1.65  0 Power Contact No.3 Power Contact No.1 +0.2 +0.1 8.6±0.05 4ר1.6 0 (Land) 2ר1 0(TH) 0.15±0.03 (1.75) 6.4±0.25 4.65±0.25 (1.7) +0.2 Land Pattern : 0.3±0.03 Metal Mask(t=0.15):0.25±0.03 Metal Mask(t=0.12):0.3±0.03 C±0.03 D±0.03 E±0.03 1.8 0 End of PCB (Fitting mouth side) +0.1 2ר1.4 0(Land) 2max 2±0.03 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P=0.5±0.15 Unit : mm Part No. FX23-20S-0.5SH HRS No. No. of contacts A B C D E F G H 573-3401-9 00 20 15.5 4.5 7.8 11.2 14 10 11 20 FX23-40S-0.5SH 573-3402-1 00 40 20.5 9.5 12.8 16.2 19 20 21 40 FX23-60S-0.5SH 573-3403-4 00 60 25.5 14.5 17.8 21.2 24 30 31 60 FX23-80S-0.5SH 573-3404-7 00 80 30.5 19.5 22.8 26.2 29 40 41 80 FX23-100S-0.5SH 573-3405-0 00 100 35.5 24.5 27.8 31.2 34 50 51 100 FX23-120S-0.5SH 573-3406-2 00 120 40.5 29.5 32.8 36.2 39 60 61 120 11 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ■Product dimensions FX23L series ●Vertical header [FX23L-**P-0.5SV8] A±0.3 B±0.3 C±0.2 P=0.5±0.15 6.6±0.3 2.7±0.2 Contact No.H 0.15±0.15 Contact No.J A Contact No.G Contact No.1 D±0.15 1.35±0.25 3.7±0.15 0.15±0.03 4.75±0.25 (7.6) 0.8±0.1 E±0.25 4ר1.6 +0.1 0(Land) 4.4 0 −0.1 P=0.5±0.03 +0.1 0 (TH) +0.1 4.75±0.05 3.2±0.05 4ר1.2 C±0.05 8.2  0 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6.85±0.3 1.9±0.3 t=0.15±0.03 × w=0.2±0.05 Land Pattern : 0.3±0.03 Metal Mask(t=0.15) : 0.25±0.03 Metal Mask(t=0.12) : 0.3±0.03 E±0.05 F±0.05 2.45±0.05 2.45±0.05 Unit : mm Part No. 12 HRS No. No. of contacts A B C D E F G H J FX23L-20P-0.5SV8 573-2001-5 00 20 18.7 17.2 4.5 11.65 9.5 14.9 10 11 20 FX23L-40P-0.5SV8 573-2002-8 00 40 23.7 22.2 9.5 16.65 14.5 19.9 20 21 40 FX23L-60P-0.5SV8 573-2003-0 00 60 28.7 27.2 14.5 21.65 19.5 24.9 30 31 60 FX23L-80P-0.5SV8 573-2004-3 00 80 33.7 32.2 19.5 26.65 24.5 29.9 40 41 80 FX23L-100P-0.5SV8 573-2005-6 00 100 38.7 37.2 24.5 31.65 29.5 34.9 50 51 100 FX23L-120P-0.5SV8 573-2006-9 00 120 43.7 42.2 29.5 36.65 34.5 39.9 60 61 120 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors [FX23L-**P-0.5SV10] A±0.3 B±0.3 C±0.2 P=0.5±0.15 6.6±0.3 2.7±0.2 Contact No.H 0.15±0.15 Contact No.J A Contact No.1 Contact No.G 1.35±0.25 D±0.15 3.7±0.15 0.15±0.03 4.75±0.25 (7.6) 0.8±0.1 E±0.25 +0.1 0(Land) 4.4 0 −0.1 P=0.5±0.03 +0.1 0 (TH) +0.1 4ר1.2 C±0.05 8.2  0 4ר1.6 4.75±0.05 3.2±0.05 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.85±0.3 3.9±0.3 t=0.15±0.03×w=0.2±0.05 Land Pattern : 0.3±0.03 Metal Mask(t=0.15) : 0.25±0.03 Metal Mask(t=0.12) : 0.3±0.03 E±0.05 F±0.05 2.45±0.05 2.45±0.05 Unit : mm Part No. HRS No. No. of contacts A B FX23L-20P-0.5SV10 573-2101-0 00 20 18.7 17.2 FX23L-40P-0.5SV10 573-2102-2 00 40 23.7 22.2 FX23L-60P-0.5SV10 573-2103-5 00 60 28.7 FX23L-80P-0.5SV10 573-2104-8 00 80 FX23L-100P-0.5SV10 573-2105-0 00 100 FX23L-120P-0.5SV10 573-2106-3 00 120 C D E F G H J 4.5 11.65 9.5 14.9 10 11 20 9.5 16.65 14.5 19.9 20 21 40 27.2 14.5 21.65 19.5 24.9 30 31 60 33.7 32.2 19.5 26.65 24.5 29.9 40 41 80 38.7 37.2 24.5 31.65 29.5 34.9 50 51 100 43.7 42.2 29.5 36.65 34.5 39.9 60 61 120 13 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors [FX23L-**P-0.5SV12] A±0.3 B±0.3 C±0.2 P=0.5±0.15 6.6±0.3 2.7±0.2 Contact No.H 0.15±0.15 Contact No.J A Contact No.1 3.7±0.15 D±0.15 1.35±0.25 0.15±0.03 4.75±0.25 (7.6) 0.8±0.1 E±0.25 4ר1.6 +0.1 0(Land) 4.4 0 −0.1 P=0.5±0.03 +0.1 0 (TH) +0.1 4.75±0.05 3.2±0.05 4ר1.2 C±0.05 8.2  0 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10.85±0.3 5.9±0.3 Contact No.G t=0.15±0.03 × w=0.2±0.05 Land Pattern : 0.3±0.03 Metal Mask(t=0.15) : 0.25±0.03 Metal Mask(t=0.12) : 0.3±0.03 E±0.05 F±0.05 2.45±0.05 2.45±0.05 Unit : mm 14 Part No. HRS No. No. of contacts A B FX23L-20P-0.5SV12 573-2201-4 00 20 18.7 17.2 FX23L-40P-0.5SV12 573-2202-7 00 40 23.7 22.2 FX23L-60P-0.5SV12 573-2203-0 00 60 28.7 FX23L-80P-0.5SV12 573-2204-2 00 80 FX23L-100P-0.5SV12 573-2205-5 00 100 FX23L-120P-0.5SV12 573-2206-8 00 120 C D E F G H J 4.5 11.65 9.5 14.9 10 11 20 9.5 16.65 14.5 19.9 20 21 40 27.2 14.5 21.65 19.5 24.9 30 31 60 33.7 32.2 19.5 26.65 24.5 29.9 40 41 80 38.7 37.2 24.5 31.65 29.5 34.9 50 51 100 43.7 42.2 29.5 36.65 34.5 39.9 60 61 120 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ●Vertical receptacle [FX23L-**S-0.5SV] A±0.3 B±0.3 C±0.2 10.5±0.3 2.7±0.2 Contact No.1 0.15±0.15 Contact No.G P=0.5±0.15 Contact No.J Contact No.H 1.35±0.25 0.15±0.03 9.35±0.25 (10.5) 0.8±0.1 D±0.25 +0.1 4ר1.6 0(Land) +0.1 D±0.05 C±0.05 11.3 0  0 P=0.5±0.03 +0.1 4Ø1.2 0(TH) 7.7−0.1 9.35±0.05 3.2±0.05 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.8±0.3 t=0.15±0.03 × w=0.2±0.05 Land Pattern : 0.3±0.03 Metal Mask(t=0.15) : 0.25±0.03 Metal Mask(t=0.12) : 0.3±0.03 E F±0.05 2.45±0.05 2.45±0.05 Unit : mm Part No. HRS No. No. of contacts A B C D E F G H J FX23L-20S-0.5SV 573-2301-9 00 20 21 19.5 4.5 9.5 4.8 17.2 10 11 20 FX23L-40S-0.5SV 573-2302-1 00 40 26 24.5 9.5 14.5 9.8 22.2 20 21 40 FX23L-60S-0.5SV 573-2303-4 00 60 31 29.5 14.5 19.5 14.8 27.2 30 31 60 FX23L-80S-0.5SV 573-2304-7 00 80 36 34.5 19.5 24.5 19.8 32.2 40 41 80 FX23L-100S-0.5SV 573-2305-0 00 100 41 39.5 24.5 29.5 24.8 37.2 50 51 100 FX23L-120S-0.5SV 573-2306-2 00 120 46 44.5 29.5 34.5 29.8 42.2 60 61 120 15 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors Tray packaged diagram FX23 series ●Vertical header (325) (B) (A) (D) FX23-20P-0.5SV15 FX23-20P-0.5SV20 FX23-120P-0.5SV15 A FX23-40P-0.5SV15 (225) (165) (P=15) (30) (P=C) Unit : mm Part No. FX23-40P-0.5SV20 FX23-60P-0.5SV15 FX23-60P-0.5SV20 FX23-80P-0.5SV15 FX23-80P-0.5SV20 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. QTY. 60 FX23-100P-0.5SV15 >PS< FX23-100P-0.5SV20 FX23-120P-0.5SV15 FX23-120P-0.5SV20 Packaging A B C 84 50 225 37.5 84 50 225 37.5 84 72 72 50 225 37.5 50 225 45 47.5 230 46 47.5 230 (A) (D) FX23-20S-0.5SV10 FX23-120S-0.5SV A FX23-40S-0.5SV FX23-40S-0.5SV10 FX23-60S-0.5SV FX23-60S-0.5SV10 FX23-80S-0.5SV FX23-80S-0.5SV10 QTY. 60 FX23-100S-0.5SV >PS< FX23-100S-0.5SV10 FX23-120S-0.5SV FX23-120S-0.5SV10 (30.5) (A) (15.3) (P=C) FX23-120S-0.5SH (225) (165) (P=15) A QTY. 60 16 >PS< 20.9 25.9 20.9 25.9 25.9 20.9 25.9 20.9 60 52.5 220 55 Packaging A B C 84 50 225 37.5 84 50 225 37.5 84 50 225 37.5 72 47.5 230 46 72 47.5 230 46 60 52.5 220 55 ●Right angle receptacle (325) (B) 25.9 25.9 Unit : mm Part No. FX23-20S-0.5SV (225) (165) (P=15) (30) (P=C) 20.9 20.9 46 ●Vertical receptacle (325) (B) D D 15 25.2 15 25.2 15 25.2 15 25.2 15 25.2 15 25.2 Unit : mm Packaging A B C FX23-20S-0.5SH Part No. 84 50 225 37.5 FX23-40S-0.5SH 84 50 225 37.5 FX23-60S-0.5SH 84 50 225 37.5 FX23-80S-0.5SH 72 50 225 45 FX23-100S-0.5SH 72 47.5 230 46 FX23-120S-0.5SH 60 52.5 220 55 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors Tray packaged diagram FX23L series ●Vertical header Unit : mm (325) (B) (A) (D) FX23L-120P-0.5SV8 A B C 96 40 245 35 D 15.1 17.1 FX23L-20P-0.5SV12 (225) (165) (P=15) (30) FX23L-20P-0.5SV10 19.1 FX23L-40P-0.5SV8 FX23L-40P-0.5SV10 QTY. 60 15.1 84 50 225 37.5 19.1 FX23L-60P-0.5SV8 15.1 72 50 225 45 FX23L-60P-0.5SV12 >PS< FX23L-80P-0.5SV10 15.1 72 50 225 45 19.1 FX23L-100P-0.5SV8 15.1 60 52.5 220 55 19.1 FX23L-120P-0.5SV8 15.1 60 52.5 220 55 FX23L-120P-0.5SV12 FX23L-120S-0.5SV (31.5) (225) (162) (P=18) A QTY. 50 17.1 19.1 ●Vertical receptacle (P=C) 17.1 FX23L-100P-0.5SV12 FX23L-120P-0.5SV10 (A) 17.1 FX23L-80P-0.5SV12 FX23L-100P-0.5SV10 (14) 17.1 19.1 FX23L-80P-0.5SV8 (325) (B) 17.1 FX23L-40P-0.5SV12 FX23L-60P-0.5SV10 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Packaging FX23L-20P-0.5SV8 (P=C) A Part No. Unit : mm Packaging A B C FX23L-20S-0.5SV Part No. 90 38.5 248 31 FX23L-40S-0.5SV 80 40 245 35 FX23L-60S-0.5SV 70 42.5 240 40 FX23L-80S-0.5SV 60 47.5 230 46 FX23L-100S-0.5SV 50 52.5 220 55 FX23L-120S-0.5SV 50 52.5 220 55 >PS< 17 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors In Regards to Storing FX23 Series Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. There are two types of tray (A and B) for the FX23 series. These have been designed to stack in alternating order (A-B-A-B...) for shipping and storage. If tray A is stacked on top of another tray A, or if tray B is stacked on top of another tray B, the trays will put a load on the connectors, potentially causing connector breakage or deformation. Tray B Tray A Tray A Tray A When stacked correctly, the outer structure of the trays will prevent any load from being placed on the connectors below. When stacked incorrectly, the outer structure of the trays will not function, resulting in adding load to the connector. When storing the FX23 series, please ensure that the trays are stacked in alternating order. Thank you. 18 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors Recommended temperature profile (Peak temperature : MAX250℃) 260 Test PCB Dimension : 110×60×1.6mm Material 240 220℃ 220 200℃ 180 Solder composition : Sn-3Ag-0.5Cu Flux content : 11wt% Metal mask thickness : 0.12mm, 0.15mm Number of reflow times : 2 times max. 160 140 0 150℃ (90 to 120 seconds) Preheating time(150 to 200℃) *The temperature profile is a reference under the condition of the above settings : Temperature profile may change depending on the conditions such as solder paste types, manufacturers, PCB size, and other soldering materials, please fully check the mounting conditions before use. (within 60 seconds) Soldering time (220℃ or more) Cleaning conditions ●Cleaning with organic solvent Solvent Cleaning at normal temperature Heating cleaning IPA (Isopropyl alcohol) ○ ○ ●Cleaning with water When water-type cleaning agents (terpene, alkaline saponification agents) are used, select cleaning agents based on the 'table of influence' on metals and resins issued by the cleaning agent manufacturer. Caution : Do not leave with any water content left. ●Precautions in cleaning When cleaning the parts with organic solvents and water-type agents, if flux or cleaning agents remain in the connector, it could cause the deterioration of electric performance. Please be sure to check if adequate cleaning has been carried out. Precautions in use ●About the specified dimension between PCBs The dimension between PCBs shall be within the following range : FX23-**S-0.5SH 16.7max 21.7max (15.9) (20.9) 2.3max FX23L-**S-0.5SV FX23-**S-0.5SH +0.5 +0.5 FX23-**P-0.5SV** ## - 0.127 FX23L-**P-0.5SV** ## - 0.127 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature (℃) 200 : Glass epoxy FX23-**S-0.5SV** FX23-**P-0.5SV15 2.3max FX23-**P-0.5SV20 ## : Stack height 19 FX23/FX23L Series●High-speed transmission 0.5mm pitch Board-to-Board connection floating connectors ●Fixation among PCBs Please take measures to fix the PCB other than using connectors. ●Cautions in mating operations ・This connector is designed to prevent reverse insertion. The connector could be damaged if excessive force is exerted when mating. Avoid excessive force when mating. Mate only after confirming the following connector properties ((chamfer of the external face) : Chamfer Chamfer Header side Chamfer Receptacle side Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ・The allowable misalignment is ±1.2mm in both the X and Y directions. After mating is started, proceed with the operation along a straight line without forcing the connector. ±1.2mm ±1.2mm ±1.2mm ±1.2mm X direction (longitudinal direction) Y direction (transverse direction) ・When mating / un-mating, it is strongly recommended to insert or remove in a straight line. If not possible, the operation shall be carried out within the following angle. Moreover, during the mating operation, be sure to proceed without forcibly applying a load to the connector. Allow the connector to be placed straight when the mating operation is completed. X direction (longitudinal direction) ⇒ for 20, 40, 60-pos. : within 2°; for 80, 100, 120-pos. : within 10° Y direction (transverse direction) ⇒ within 0.5° (However, this is not a recommended operation. Damage to the connector could occur.) Within ±2° , ±10° Within ±2° , ±10° X direction (longitudinal direction) Within ±0 .5 ° Within ±0 .5 ° Y direction (transverse direction) ●Permissible position deviation in the mated state (floating movable amount) This connector is designed to float when mated, the permissible PCB position deviation in the mated state is ±0.6mm in both the X and Y directions. However, it is not applicable to absorbing when the position deviation amount is continually changing due to vibration etc. Be sure to secure PCBs after mating. Additionally, the number of repetitive floating operations shall be according to the number of connector insertion/withdrawal cycles. Floating side ±0.6mm ±0.6mm ±0.6mm ±0.6mm Floating side Floating side X direction (longitudinal direction) ® 20 Y direction (transverse direction) 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 06/2019. Contents are subject to change without notice for the purpose of improvements.
FX23L-100S-0.5SV 价格&库存
很抱歉,暂时无法提供与“FX23L-100S-0.5SV”相匹配的价格&库存,您可以联系我们找货
