Effective June 2017
Supersedes October 2012
Technical Data 2012
GLD/GBA
1/4" x 1-1/4" (6.3 mm x 32 mm) Pin indicating
fast acting fuse
1.44"
(36.5mm)
(blown)
15
8
10
5
3
100
2
GLD/GBA
o GLD-albaloy-plated
indicating pin
o GBA-red indicating pin
Non-Time-Delay: Indicating
Amp Rating: 1⁄2 to 15 Amps
0.75
1
AMP
RATING
10
Agency information:
CE, UL Listed, Std. 248-14
1⁄2-5 A/125 Vac, 10 kA AIC
Guide JDYX, File E19180
UL Recognized, 6 A/125 Vac, 1 kA
(Approximate)
TIME IN SECONDS
1.27"
(±0.031)
(32.2mm)
(not blown)
Time-Current Characteristic Curves–Average Melt
Product features
Dimensions - in
1
AIC
0.255" Max
0.249˝ Min
10-15 A/50 Vac/dc, 300 AIC
Guide JDYX2, File E19180
.1
CSA Certified, 1⁄2-5 A/125 Vac, 10 kA
GLD-2
GLD-6
GLD-3⁄4
GLD-3
GLD-10
GLD-1
GLD-4
GLD-12
GLD-1-1⁄2
GLD-5
GLD-15
GBA-1⁄2
GBA-2
GBA-6
GBA-3⁄4
GBA-3
GBA-10
GBA-1
GBA-4
GBA-15
GBA-1-1⁄2
GBA-5
Amp
Ratings
Carton
Qty.
⁄2-15
1
100
Lbs.
0.86
Weight
Kg.
0.390
200
100
.4
GLD-1⁄2
Carton Quantity and Weight
.01
10
Class 1422-01, File 53787
Electrical Ratings (Catalog Symbol and Amps)
1
AIC
CURRENT IN AMPS
General Information:
• Use in power electronic circuits in which a fuse opening
must be quickly apparent.
• Opening of fuse results in the ejection of end pin.
• Type GLD has an albaloy-plated pin for positive, electrical
signal circuit activation.
• Type GBA has a red pin for high visibility.
• The Cooper Bussmann Series 8000 fuse blocks are
recommended for visual indication.
• For visual indication use Cooper Bussmann panel-mounted
fuse holder HLD (15 A maximum)
• Ferrules: Nickel-plated brass end caps.
Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written
approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used
in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user.
Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also
reserves the right to change or update, without notice, any technical information contained in this bulletin.
Eaton
Electronics Division
1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eaton.com/electronics
© 2017 Eaton
All Rights Reserved
Printed in USA
Publication No. 2012 BU-SB12694
June 2017
Eaton is a registered trademark.
All other trademarks are property
of their respective owners.
很抱歉,暂时无法提供与“GBA-15”相匹配的价格&库存,您可以联系我们找货
