Xtra-Guard®
Industrial Ethernet Cable
Industrial Ethernet cable for the
toughest network applications
Rugged connectivity
that goes beyond
factory tough
Alpha Wire’s new line of
Xtra-Guard® Industrial
Ethernet cables give you
rugged connectivity for your
industrial networking needs.
Choose from the widest
selection of materials,
configurations, and shielding
options to satisfy your
needs for flexibility, fluid
resistance, noise immunity,
and other challenging
application demands.
Designed for uncompromising
performance to keep the
network running anywhere,
Alpha Wire’s Industrial
Ethernet cables feature
an abrasion-resistant
thermoplastic elastomer jacket
with three times the lowtemperature flexibility,
and resists solvents,
chemicals, and fuels better
than ordinary PVC.
Exceptional performance
temperature range of -50°C
up to +125°C, and our
polypropylene constructions
perform at temperatures
ranging from -50°C up
to +105°C.
These new Cat 5e cables
combine the advanced
technology of Ethernet
communications with the
durability and temperature
range of Alpha’s renowned
Xtra-Guard 4 jacket. The
result is a flexible and
routable Ethernet cable that
provides rugged, reliable
performance in the most
extreme environments.
New! High Flex Cable
Available with your choice of
insulations, unshielded, foil
shield or Supra-Shield® foil +
braid for exceptional EMI
resistance, our FEP-insulated
constructions provide a
In stock and
available now
We now offer a high-flex
version of Xtra-Guard
(7602F) ideal for motion
control applications, rated for
10 million flex cycles.
Xtra-Guard Industrial Ethernet
cables are available from
stock for same-day shipment
in standard lengths of 500’
and 1000’. The standard TPE
jacket is available in black.
Other colors, including red
and teal, are available by
special order.
Alpha Wire gives you a full range of
Industrial Ethernet Cat 5e cables
24 AWG
Part No.
Shielding
75020
Unshielded
75021
Foil
75022
Foil/Braid
76020
Unshielded
76021
Foil
76022
Foil/Braid
7602F (High Flex)
Foil/Braid
75010
Unshielded
75011
Foil
75012
Foil/Braid
75000
Unshielded
75001
Foil
75002
Foil/Braid
76010
Unshielded
76011
Foil
76012
Foil/Braid
76000
Unshielded
76001
Foil
76002
Foil/Braid
Insulation
Temperature (°C)
Pairs
PP
-50 to +105*
2
PP
-50 to +105*
Conductors
Jacket
Stranded
4
PO
-40 to +80°C (static)
-10 to 80°C (dynamic)
PP
-50 to +105*
TPE
2
FEP
-50 to +125**
Solid
PP
-50 to +105*
4
FEP
-50 to +125**
*UL riser rated at 75°C.
**UL riser rated at 105°C.
Approvals
Meets ANSI/TIA-568-C.2 Cat 5e requirements
Supports data rates up to Gigabit Ethernet
UL Type CMR
Passes UL 1666 Riser and CSA FT-4 flame test
Suitable for use in NFPA 79 applications
Resistance
• Sunlight resistant
• Resistant to hazardous fluids
• Extra tough, abrasion-resistant TPE jacket is flexible and routable
Availability
• Choice of unshielded, foil shield, or Supra-Shield foil + braid for best EMI protection
• Available in 500’ and 1000’ lengths
For additional
information and free
samples, visit
www.alphawire.com.
The cables you trust.
The service you deserve.
Every application is critical
and cable failure is not an
option when the safety of your
equipment and personnel is
paramount. Specify Xtra-Guard
extreme environments and
crucial applications, since the
integrity of your system is
only as robust as the products
you use.
GLOBAL HEADQUARTERS
711 Lidgerwood Avenue
Elizabeth, NJ 07207-0711 USA
Toll Free: 1-800-52 ALPHA
Tel: 1-908-925-8000
Fax: 1-908-925-5411
E-mail: info@alphawire.com
Superior availability
Alpha offers Xtra-Guard
Industrial Ethernet cables
from stock in most sizes
and constructions, in small
quantities, so you can order
them when you need them.
Our products are available
for same-day shipment,
eliminating long lead times.
EUROPE
Alpha Wire International
Saxon House
1 Downside | Sunbury-on-Thames
Middlesex | United Kingdom | TW16 6RT
Tel: +44-(0)-800-288-8809
Fax: +44-(0)-800-288-8810
E-mail: europe@alphawire.com
©2013 Alpha Wire. All rights reserved.
Specifications subject to change. Consult Alpha Wire for latest specifications.
Service and support,
second-to-none
Selecting the correct cable
is essential to overall system
reliability, performance, and
safety. So we make it easy for
you to select the right Alpha
product for your specific
application. Our online
resources include a wire and
cable selection guide, technical
information, full product
catalog, and a distributor
locator to make it easy to
select and get the cable,
wire, and wire management
accessories you need. Just visit
www.alphawire.com!
ASIA PACIFIC
Alpha Wire
Silver Center | Room 1708
North Shanxi Road 1388
Shanghai | China | 200060
Tel: +86-21-61498201/61498205
Fax: +86-21-61498001
E-mail: apac@alphawire.com
Lit. No. XGIE-Bro-1310
Supersedes: XGIE-Bro-1202
很抱歉,暂时无法提供与“5472C SL005”相匹配的价格&库存,您可以联系我们找货
