4180603
4180603
    LAPP(缆普)
4180603 数据手册
ÖLFLEX® UNCONTROLLED COPY Harmonized European hook-up wire & cordage Harmonized hook-up wire Multi-standard hook-up wire H05V-K: UL AWM Style 1007 & 1569, UL/CSA • H07V-K: UL AWM Style 1015, UL MTW 1063, CSA Construction Conductors: finely stranded tinned copper Insulation: PVC This internationally approved hook-up wire was designed to meet North American and European market requirements. It passes H05V-K, H07V-K, UL AWM, UL MTW (16 AWG & larger), CSA TEW & CE. Application advantage •O  nly one inventory vs. two for domestic and export consumption Recommended applications • 13 standard color options Panel and machine wiring for domestic and export usage; internal wiring of devices, electrical, and medical equipment • UL MTW (16 AWG & larger) •A  vailable in large cardboard barrels for easy pull (16 AWG & larger) • Embossed cable marking available upon request Approvals Cable attributes page 648 OIL OR-02 FLAME FR-02 MOTION FL-02 MECH. MP-01 Technical data Temperature range: - /IEC: -40°C to +70°C - UL/CSA: -40°C to +105°C Nominal voltage: - H05V-K: - /IEC: - UL/CSA: - H07V-K: - /IEC: - UL/CSA: Color code: * No for yellow or green wires ≥ 16 AWG 300/500V 300V Approvals: - H05V-K: UL: Canada: Additional: - H07V-K: UL: Canada: Additional: 450/750V 600V Test voltage: - H05V-K: 2000V - H07V-K: 2500V Conductor stranding: Class 5 fine wire Part number Standard H05V-K 22 AWG (0.5 mm2) 41804.. H05V-K 20 AWG (0.75 mm2) 41805.. H05V-K 18 AWG (1 mm2) 41806.. H05V-K H07V-K 2 16 AWG (1.5 mm ) 41604.. H07V-K 14 AWG (2.5 mm2) 41605.. H07V-K 12 AWG (4 mm2) 41606.. H07V-K 10 AWG (6 mm2) 41607.. H07V-K Maximum outer diameter in mm 00: 01: 02: 03: 04: 05: 06: Copper weight lbs/mft Approx. weight lbs/mft 0.098 2.5 3 6 0.102 2.6 5 8 0.110 2.8 6 10 0.134 3.4 10 15 0.157 4.0 16 25 0.181 4.6 26 30 0.201 5.1 39 48 Part number Standard 8 AWG (10 mm2) 41608.. H07V-K 6 AWG (16 mm2) 41609..* H07V-K 4 AWG (25 mm2) 41610.. H07V-K 2 AWG (35 mm2) 41611.. H07V-K 1 AWG (50 mm2) 41612.. H07V-K 2/0 AWG (70 mm2) 41613.. H07V-K 3/0 AWG (95 mm2) 41614.. H07V-K 4/0 AWG (120 mm2) 41615.. H07V-K green/yellow black blue brown red white gray 07: 08: 09: 10: 11: 14: violet pink orange yellow* green* dark blue AWM 1007 & 1569 CSA AWM I A/B H05V-K CE & RoHS MTW per UL 1063 AWM 1015 TEW H07V-K CE & RoHS Maximum outer diameter in mm Copper weight lbs/mft Approx. weight lbs/mft 0.268 6.8 65 81 0.354 9.0 103 126 0.402 10.2 161 195 0.461 11.7 226 268 0.547 13.9 323 376 0.630 16.0 452 521 0.717 18.2 613 693 0.780 19.8 774 864 * No approval available for 6 AWG (X07V-K) For LAPP part number, add the double digit color code (see above) to the part number prefix in the table; e.g.: 16 AWG H07V-K green/yellow = 4160400 If not otherwise specified, all values relating to the product are nominal values. Photographs are not to scale and are not true representations of the products in question. 128 for current information see: www.lappusa.com • www.lappcanada.com
4180603 价格&库存
很抱歉,暂时无法提供与“4180603”相匹配的价格&库存,您可以联系我们找货
