山东晶导微电子有限公司
SS32F THRU SS320F
Jingdao Microelectronics
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 20 to 200 V
Forward Current - 3.0A
PINNING
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: SS32 — SS320
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 27mg / 0.00095oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load,
for capacitive load, derate by 20 %
Symbols
Parameter
SS32F
SS34F
SS34AF SS36F
SS38F
SS310F SS312F SS315F
SS320F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
45
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
31.5
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
45
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
3.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
80
A
Max Instantaneous Forward Voltage at 3 A
VF
0.55
T a =100°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
0.85
0.95
IR
0.5
5
0.3
3
Cj
250
180
Maximum DC Reverse Current T a = 25°C
at Rated DC Reverse Voltage
0.70
V
mA
pF
RθJA
70
RθJC
18
Tj
-55 ~ +125
°C
T stg
-55 ~ +150
°C
°C/W
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.10
SMAF-S-SS32F~SS320F-3A200V
Page 1 of 3
山东晶导微电子有限公司
SS32F THRU SS320F
Fig.2 Typical Reverse Characteristics
3.5
3.0
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
SS32F/SS36F
SS38F-SS320F
10
1
T J =25°C
10 0
80
100
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1.0
SS32F/SS34F
SS34AF/SS38F
SS310F/SS312F
SS315F/SS320F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
500
200
100
SS32F~SS38F
SS32F~SS36F
SS310F~SS320F
SS38F~SS320F
10
1.8
0.1
1
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
100
SS32F-SS38F
SS310F-SS320F
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
1000
Instaneous Forward Voltage (V)
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
100
Number of Cycles at 60Hz
2016.10
T J =100°C
10 3
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
SS32F THRU SS320F
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
47
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
D
E
A
V M
7°
SS26F
The recommended mounting pad size
Marking
Type number
2.2
(86)
1.6
(63)
SS22F
SS24F
1.8
(71)
1.6
(63)
mm
Unit :
(mil)
2016.10
610205A0
Marking code
SS32F
SS32
SS34F
SS34
SS34AF
SS34A
SS36F
SS36
SS38F
SS38
SS310F
SS310
SS312F
SS312
SS315F
SS315
SS320F
SS320
Page 3 of 3
很抱歉,暂时无法提供与“SS315F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33351
- 100+0.26201
- 300+0.22616
