REV.
DATE
DESCRIPTION
G Engineering Update w/o Changes
H Material Update.
Ø.255 [Ø6.5mm]
APPROVED
02/26/04
11/10/05
M. C.
M. C.
L
Ø.200 [Ø5.1mm]
REF. C/L
0.040±0.005
TYP.
Ø.025±.005
Ø.100 [Ø2.5mm]
REF. C/L
3. TOLERANCE "L" DIMENSION:
0.030 - 0.500 (1.0 - 12.7mm)±0.005(0.1mm)
0.505 - 0.750 (12.8 - 19.1mm)±0.008(0.2mm)
0.755 - 1.250 (19.2 - 31.8mm)±0.015(0.4mm)
2. MATERIAL: PVC ALLOY, 94V-0, BLACK. BIVAR MATERIAL CODE 58-BK.
CYBERTECH CYBERSHIELD PVC ALLOY, CS1534WX-BLK02N BLACK.
1. GENERAL SPECIFICATIONS: BIVAR EXTRUDED PRODUCT SPECIFICATION BV00-E105.
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .005
DESIGNED:
Shane Irving
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
EXTRUDED, SELF-RETAINING LED MOUNT
DATE:
02/03/98
DATE:
12/17/02
PART NO:
REVISION:
ELM 3
H
CAGE CODE : 32559
SHEET # 1 OF
CAD GENERATED DOCUMENT,
DO NOT MEASURE DRAWING.
1
很抱歉,暂时无法提供与“ELM 3-580”相匹配的价格&库存,您可以联系我们找货
