P6SMB6.8(A) – P6SMB220(A)
Taiwan Semiconductor
600W, 6.8V - 220V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
Low profile package
Ideal for automated placement
Glass passivated chip junction
Excellent clamping capability
Typical IR less than 1μA above 10V
Fast response time: Typically less than
1.0ps from 0 volt to BV min
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
5.5 - 185
V
VBR
6.8 - 220
V
PPPSM
600
W
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
TV
Monitor
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.090g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Non-repetitive peak impulse power dissipation with
(1)
10/1000μs waveform
Steady state power dissipation at TA = 25°C
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
SYMBOL
VALUE
UNIT
PPPSM
600
W
Ptot
3
W
IFSM
100
A
Forward Voltage @ IF = 50A for Uni-directional only
VF
3.5 / 5.0
V
Junction temperature
TJ
-55 to +150
°C
(2)
TSTG
-55 to +150
Storage temperature
Notes:
1. Non-repetitive current pulse per Fig.3 and derated above TA = 25°C per Fig.2
2. VF = 3.5V on P6SMB6.8 - P6SMB91 device and VF = 5.0V on P6SMB100 - P6SMB220 device.
°C
Devices for Bipolar Applications
1. For bidirectional use C or CA suffix for types P6SMB6.8 - types P6SMB220A
2. Electrical characteristics apply in both directions
1
Version: Q2209
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-case thermal resistance
RӨJC
10
°C/W
Junction-to-ambient thermal resistance
RӨJA
55
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Breakdown
Device
P6SMB6.8
P6SMB6.8A
P6SMB7.5
P6SMB7.5A
P6SMB8.2
P6SMB8.2A
P6SMB9.1
P6SMB9.1A
P6SMB10
P6SMB10A
P6SMB11
P6SMB11A
P6SMB12
P6SMB12A
P6SMB13
P6SMB13A
P6SMB15
P6SMB15A
P6SMB16
P6SMB16A
P6SMB18
P6SMB18A
P6SMB20
P6SMB20A
P6SMB22
P6SMB22A
P6SMB24
P6SMB24A
P6SMB27
P6SMB27A
P6SMB30
P6SMB30A
P6SMB33
P6SMB33A
P6SMB36
P6SMB36A
P6SMB39
P6SMB39A
P6SMB43
P6SMB43A
P6SMB47
P6SMB47A
Device
Voltage
Test
Marking
VBR (V)
Current
Code
(Note 1)
IT (mA)
KDJ
KEJ
KFJ
KGJ
KHJ
KKJ
KLJ
KMJ
KNJ
KPJ
KQJ
KRJ
KSJ
KTJ
KUJ
KVJ
KWJ
KXJ
KYJ
KZJ
LDJ
LEJ
LFJ
LGJ
LHJ
LKJ
LLJ
LMJ
LNJ
LPJ
LQJ
LRJ
LSJ
LTJ
LUJ
LVJ
LWJ
LXJ
LYJ
LZJ
MDJ
MEJ
Min
6.12
6.46
6.75
7.13
7.38
7.79
8.19
8.65
9.00
9.50
9.90
10.5
10.8
11.4
11.7
12.4
13.5
14.3
14.4
15.2
16.2
17.1
18.0
19.0
19.8
20.9
21.6
22.8
24.3
25.7
27.0
28.5
29.7
31.4
32.4
34.2
35.1
37.1
38.7
40.9
42.3
44.7
Max
7.48
7.14
8.25
7.88
9.02
8.61
10.00
9.55
11.00
10.5
12.1
11.6
13.2
12.6
14.3
13.7
16.5
15.8
17.6
16.8
19.8
18.9
22.0
21.0
24.2
23.1
26.4
25.2
29.7
28.4
33.0
31.5
36.3
34.7
39.6
37.8
42.9
41.0
47.3
45.2
51.7
49.4
Stand-Off
Voltage
VWM
(V)
10
10
10
10
10
10
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
5.50
5.80
6.05
6.40
6.63
7.02
7.37
7.78
8.10
8.55
8.92
9.40
9.72
10.2
10.5
11.1
12.1
12.8
12.9
13.6
14.5
15.3
16.2
17.1
17.8
18.8
19.4
20.5
21.8
23.1
24.3
25.6
26.8
28.2
29.1
30.8
31.6
33.3
34.8
36.8
38.1
40.2
2
Maximum
Maximum
Maximum
Reverse
Peak Pulse
clamping
Leakage
Current
voltage
@VWM
IPPM(A)
VC@IPPM
ID(µA)
(Note 2)
(V)
1000
1000
500
500
200
200
50
50
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
58
60
53
55
50
52
45
47
42
43
38
40
36
37
33
34
28
29
26
28
23
25
21
22
19
19
16
16.8
14.0
15.0
13.0
13.8
12.0
12.6
11.1
11.6
10.0
10.6
9.2
9.7
10.8
10.5
11.7
11.3
12.5
12.1
13.8
13.4
15.0
14.5
16.2
15.6
17.3
16.7
19.0
18.2
22.0
21.2
23.5
22.5
26.5
25.5
29.1
27.7
31.9
30.6
34.7
33.2
39.1
37.5
43.5
41.4
47.7
45.7
52.0
49.9
56.4
53.9
61.9
59.3
67.8
64.8
Maximum
Temperature
Coefficient of
VBR(%/°C)
0.057
0.057
0.061
0.061
0.065
0.065
0.068
0.068
0.073
0.073
0.075
0.075
0.078
0.078
0.081
0.081
0.084
0.084
0.086
0.086
0.088
0.088
0.090
0.090
0.092
0.092
0.094
0.094
0.096
0.096
0.097
0.097
0.098
0.098
0.099
0.099
0.100
0.100
0.101
0.101
0.101
0.101
Version: Q2209
Breakdown
Device
Device
Voltage
Test
Marking
VBR (V)
Current
Code
(Note 1)
IT (mA)
Min
45.9
48.5
50.4
53.2
55.8
58.9
61.2
64.6
67.5
71.3
73.8
77.9
81.9
86.5
90
95
99
105
108
114
117
124
135
143
144
152
153
162
162
171
180
190
198
209
Stand-Off
Voltage
VWM
(V)
Max
56.1
53.6
61.6
58.8
68.2
65.1
74.8
71.4
82.5
78.8
90.2
86.1
100
95.5
110
105
121
116
132
126
143
137
165
158
176
168
187
179
198
189
220
210
242
231
Maximum
Maximum
Maximum
Reverse
Peak Pulse
clamping
Leakage
Current
voltage
@VWM
IPPM(A)
VC@IPPM
ID(µA)
(Note 2)
(V)
8.5
8.9
7.8
8.1
7.0
7.4
6.4
6.8
5.8
6.1
5.3
5.5
4.8
5.0
4.3
4.5
3.9
4.1
3.6
3.8
3.3
3.5
2.9
3.0
2.7
2.8
2.5
2.6
2.4
2.5
2.1
2.2
1.8
1.9
73.5
70.1
80.5
77.0
89.0
85.0
98.0
92.0
108
103
118
113
131
125
144
137
158
152
173
165
187
179
215
207
230
219
244
234
258
246
287
274
342
328
P6SMB51
MFJ
1.0
41.3
1
P6SMB51A
MGJ
1.0
43.6
1
P6SMB56
MHJ
1.0
45.4
1
P6SMB56A
MKJ
1.0
47.8
1
P6SMB62
MLJ
1.0
50.2
1
P6SMB62A
MMJ
1.0
53.0
1
P6SMB68
MNJ
1.0
55.1
1
P6SMB68A
MPJ
1.0
58.1
1
P6SMB75
MQJ
1.0
60.7
1
P6SMB75A
MRJ
1.0
64.1
1
P6SMB82
MSJ
1.0
66.4
1
P6SMB82A
MTJ
1.0
70.1
1
P6SMB91
MUJ
1.0
73.7
1
P6SMB91A
MVJ
1.0
77.8
1
P6SMB100
MWJ
1.0
81.0
1
P6SMB100A
MXJ
1.0
85.5
1
P6SMB110
MYJ
1.0
89.2
1
P6SMB110A
MZJ
1.0
94.0
1
P6SMB120
NDJ
1.0
97.2
1
P6SMB120A
NEJ
1.0
102.0
1
P6SMB130
NFJ
1.0
105.0
1
P6SMB130A
NGJ
1.0
111.0
1
P6SMB150
NHJ
1.0
121.0
1
P6SMB150A
NKJ
1.0
128.0
1
P6SMB160
NLJ
1.0
130.0
1
P6SMB160A
NMJ
1.0
136.0
1
P6SMB170
NNJ
1.0
138.0
1
P6SMB170A
NPJ
1.0
145.0
1
P6SMB180
NQJ
1.0
146.0
1
P6SMB180A
NRJ
1.0
154.0
1
P6SMB200
NSJ
1.0
162.0
1
P6SMB200A
NTJ
1.0
171.0
1
P6SMB220
NUJ
1.0
175.0
1
P6SMB220A
NVJ
1.0
185.0
1
Notes:
1.
VBR measure after IT applied for 30ms, IT = square wave pulse or equivalent.
2.
Surge current waveform per Fig.3 and derate per Fig.2.
3.
For bipolar types having VWM of 10V and under, the ID limit is doubled.
4.
For bidirectional use C or CA suffix for types P6SMB6.8 - P6SMB220A.
5.
All terms and symbols are consistent with ANSI/IEEE C62.35.
Maximum
Temperature
Coefficient of
VBR(%/°C)
0.102
0.102
0.103
0.103
0.104
0.104
0.104
0.104
0.105
0.105
0.105
0.105
0.106
0.106
0.106
0.106
0.107
0.107
0.107
0.107
0.107
0.107
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
0.108
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
P6SMBx
DO-214AA (SMB)
3,000 / Tape & Reel
Notes:
1.
"x" defines voltage from 6.8V(P6SMB6.8) to 220V(P6SMB220A)
3
Version: Q2209
CHARACTERISTICS CURVES
Fig.2 Pulse Derating Curve
PPPM, PEAK PULSE POWER, KW
100
NON-REPETITIVE
PULSE
WAVEFORM
SHOWN in FIG.3
10
1
0.1
0.1
1
10
100
1000
10000
PEAK PULSE POWER(PPP) OR CURRENT (IPP)
DERATING IN PERCENTAGE (%)
Fig.1 Peak Pulse Power Rating Curve
125
100
75
50
25
tp, PULSE WIDTH, (μs)
Peak value
IPPM
80
Half value-IPPM/2
60
40
10/1000μs, waveform
tp
1
1.5
2
2.5
3
IFSM, PEAK FORWARD SURGE CURRENT (A)
IPPM, PEAK PULSE CURRENT (%)
Rise time tr=10μs to 100%
100
75
100
125
150
Fig.4 Maximum Non-Repetitive Forward Surge
Current Unidirectional Only
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
120
50
TA, AMBIENT TEMPERATURE (°C)
Fig.3 Clamping Power Pulse Waveform
140
25
PERCENT OF RATEDt,PEAK
REVERSE VOLTAGE (%)
TIME (ms)
100
8.3ms Single Half Sine Wave
10
1
10
100
NUMBER OF CYCLES AT 60 Hz
4
Version: Q2209
Fig.5 Typical Junction Capacitance
CJ, JUNCTION CAPACITANCE (pF)
10000
VR=0
1000
MEASURED at STAND-OFF VOLTAGE,Vwm
100
f=1.0MHz
Vsig=50mVp-p
10
1
10
100
VBR, BREAKDOWN VOLTAGE (V)
5
Version: Q2209
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Cathode band for uni-directional products only
6
Version: Q2209
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: Q2209
很抱歉,暂时无法提供与“P6SMB33CA R5”相匹配的价格&库存,您可以联系我们找货
