PYD 1598
PYD 1598
    EXCELITASTECHNOLOGIES(埃赛力达)
PYD 1598 数据手册
low power DigiPyro TM Infrared Sensing Solutions Product Specification PYD 1598 / 7655 Features • Integrated digitization • Motion detection unit with Interrupt function • Low-power consumption of only 3 µA at 1.8 V. • High responsivity ceramic pyroelectric elements • Dual detector with 2 × 1 mm2 elements • 130◦ field-of-view • TO-5 metal housing for high EMI immunity Low Power Dual Element Large Field-of-View Pyro The PYD 1598 is a serial opposed format, two elements detector based on pyroceramic. The signal is converted to a digital value using Sigma-Delta and DSP techniques. A configurable motion detection unit is implemented. Once motion was detected, an interrupt will be send to the host system. Putting the host system to sleep an overall ultra low power consumption will be achieved. All data is accessible by the host system to enable advanced signal analysis with your own detection criteria. Excelitas digital solutions provide excellent EMI immunity. • Optimal for fast designs Applications • Long distance motion detection (with lens) • Energy saving applications • Intrusion alarms • Horizontal mounting applications • Battery operation • Gesture direction recognition • Touchless switch Issued: 20/03/2018 / Revised: 27/09/2022 Contents 1 Physical Characteristics 1.1 Pyro-Electric Elements . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2 Optical Properties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.3 Filter Properties . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Electrical Characteristics 2.1 Absolute Maximum Ratings 2.2 Electrical Data . . . . . . . 2.3 Interface Overview . . . . 2.4 Motion Detection Unit . . 2.5 Configuration Register . . 2.6 Serial In Interface . . . . . 2.7 Direct Link Interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 5 6 7 8 8 9 10 11 11 13 13 3 Handling, Operation and Precautions 16 3.1 Handling . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 3.2 Operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16 4 Quality and Statements 17 5 Packaging 18 PYD 1598 / 7655 Physical Characteristics Table 1: Summary of physical characteristics. Parameters and data refer to an ambient temperature of 25 ± 3 ◦C. Parameter Symbol Min Typ Housing TO-5 Lead Length 13.2 130 2×1 1 600 4.0 Field of View FOV Element Size Spacing Optical Distance Responsivity Match R (R A − R B )/R A 3.3 Noise 20 IR-Filter Standard Max Unit Remarks/Conditions see fig. 1 mm ◦ 10 78 see fig. 1 see sec. 1.2 mm see fig. 1 mm see fig. 1 µm see fig. 1 kV W−1 see sec. 1.1 % see sec. 1.1 µVpp see sec. 1.1 see sec. 1.3 Figure 1: Dimensions and Connections. Explanations follow in this document. 3 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 430 www.excelitas.com Product Specification 1 Issued: 20/03/2018 / Revised: 27/09/2022 PYD 1598 / 7655 Issued: 20/03/2018 / Revised: 27/09/2022 Pin Number Symbol Description 1 Direct Link 1-wire digital interface for data readout. An external decoupling capacitor close to the pin is recommended. See technical note for details. 2 VDD Positive power supply. An external decoupling capacitor close to the pin is recommended. See technical note for details. 3 Serial In 1-wire digital interface for detector configuration. An external decoupling capacitor close to the pin is recommended. See technical note for details. 4 VSS Negative Power Supply. Should be set to the host ground. 4 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 430 www.excelitas.com Product Specification BOTTOM VIEW PYD 1598 / 7655 Pyro-Electric Elements The element configuration is shown in figure 1. It features a dual element configuration in a serial opposed format. Its typical application is long distance, wall mounted, motion detection . Figure 2: Test set up for the measurement of responsivity and match. 1 2 3 4 6 5 DSP Display Figure 3: Masking of elements to test the electrical parameters. Responsivity A Responsivity B Match Noise Cover Plate The typical set-up for the measurement of responsivity and match is illustrated in figure 2. The black body (BB) radiator (1) is set to 373 K (100 ◦C). The signal is modulated by a rotating chopper (2). An aperture (3) is used to adjust the radiation flux. The cover plate (4) is masking the elements as shown in figure 3. The sensor (5) is interfaced to a signal processing chain (6). To measure noise, a bandpass filter in the range of 0.4 Hz to 10 Hz is applied. Responsivity (R ) and match are measured at a modulation frequency of 1 Hz. The match is defined by Match R × 100 (1) Noise is measured shut from infra-red energy. The measurement is performed after a settling time of 10 min at an ambient temperature of 25 ◦C ± 3 ◦C. Noise is monitored for the duration of 600 s . 5 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 430 www.excelitas.com Product Specification 1.1 Issued: 20/03/2018 / Revised: 27/09/2022 PYD 1598 / 7655 Product Specification 1.2 Issued: 20/03/2018 / Revised: 27/09/2022 Optical Properties Figure 4: Illustration for the definition of the horizontal field of view (FOV). FOV The horizontal field of view (FOV) as drawn to figure 4 is given as the geometrically unobstructed light path to both elements. The FOV of 130◦ is given for the optical light acceptance with the full so-called common mode suppression. The optical distance as it is given in figure 1 represents the effective focal plane for the application specific optics. The optical distance is shorter than the geometrical due to refraction of light in the filter. 6 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 430 www.excelitas.com PYD 1598 / 7655 Product Specification 1.3 Issued: 20/03/2018 / Revised: 27/09/2022 Filter Properties Table 3: Filter properties Parameter Symbol Min Average Filter Transmittance TA 77 Average Filter Transmittance TA Cut-on Wavelength λ(5 %) Typ 5.2 Max 5.5 Unit Remarks/Conditions % 7.5 µm < λ < 13.5 µm λ < 5 µm at 25 ◦C 0.5 % 5.8 µm Figure 5: Filter transmittance, typical curve 100 90 80 Transmittance [%] 70 60 50 40 30 20 10 0 3 4 5 6 7 8 9 10 11 12 13 14 15 16 Wavelength [µm] 7 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 430 www.excelitas.com PYD 1598 / 7655 Electrical Characteristics 2.1 Absolute Maximum Ratings Table 4: Absolute Maxiumum Ratings. Data applicable to operation at free-air temperature range. Parameter Symbol Min Voltage at any pin VDD ,VSerial In ,VDirect Link I pin −0.3 −100 −40 −40 Current into any pin Storage Temperature Operating Temperature Typ Max Unit 3.6 100 85 70 V Remarks/Conditions mA ◦C < 60 % r.H. ◦C Stresses beyond the limits listed in table 4 may cause permanent damage to the device. Exposure to absolute maximum ratings for long time may affect the device reliability and may lead to deterioration of any parameter. 8 Excelitas Technologies GmbH & Co. KG Wenzel-Jaksch-Str. 31 65199 Wiesbaden Germany Tel.: +49 (0)611 492 430 www.excelitas.com Product Specification 2 Issued: 20/03/2018 / Revised: 27/09/2022 PYD 1598 / 7655 Electrical Data Table 5: Electrical Data. Unless specified differently all data refers to 25 ± 3 ◦C. Parameter Symbol Min Typ Max Unit Operating Voltage VDD 1.8 IDD 3.6 3.5 V Supply Current 3 3 µA Remarks/Conditions VDD =1.8 V, no load SERIN Input Low Voltage VSIL Input High Voltage VSIH Input Current ISI Data Clock Low Time tSL Data Clock High Time tSH Data In Hold Time tSHD Data Load Time tSLT −0.3 0.8VDD −1 200 200 80 650 0.2VDD VDD + 0.3 1 2000 2000 150 −0.3 0.8VDD −1 120 200 200 0.2VDD VDD + 0.3 1 150 2000 2000 2 12.51 22 V V µA Max V
PYD 1598 价格&库存
很抱歉,暂时无法提供与“PYD 1598”相匹配的价格&库存,您可以联系我们找货
