ELM 3-615
ELM 3-615
    BIVAR
ELM 3-615 数据手册
REV. DATE DESCRIPTION G Engineering Update w/o Changes H Material Update. Ø.255 [Ø6.5mm] APPROVED 02/26/04 11/10/05 M. C. M. C. L Ø.200 [Ø5.1mm] REF. C/L 0.040±0.005 TYP. Ø.025±.005 Ø.100 [Ø2.5mm] REF. C/L 3. TOLERANCE "L" DIMENSION: 0.030 - 0.500 (1.0 - 12.7mm)±0.005(0.1mm) 0.505 - 0.750 (12.8 - 19.1mm)±0.008(0.2mm) 0.755 - 1.250 (19.2 - 31.8mm)±0.015(0.4mm) 2. MATERIAL: PVC ALLOY, 94V-0, BLACK. BIVAR MATERIAL CODE 58-BK. CYBERTECH CYBERSHIELD PVC ALLOY, CS1534WX-BLK02N BLACK. 1. GENERAL SPECIFICATIONS: BIVAR EXTRUDED PRODUCT SPECIFICATION BV00-E105. STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: Shane Irving CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED, SELF-RETAINING LED MOUNT DATE: 02/03/98 DATE: 12/17/02 PART NO: REVISION: ELM 3 H CAGE CODE : 32559 SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. 1
ELM 3-615 价格&库存
很抱歉,暂时无法提供与“ELM 3-615”相匹配的价格&库存,您可以联系我们找货
