BC817-40 RF
BC817-40 RF
    TAIWANSEMICONDUCTOR(台湾半导体)
BC817-40 RF 数据手册
BC817-16/-25/-40 Taiwan Semiconductor 300mW, NPN Small Signal Transistor FEATURES KEY PARAMETERS ● ● ● ● Low power loss, high efficiency Ideal for automated placement High surge current capability Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter PARAMETER VALUE UNIT VCBO 50 V VCEO 45 V VEBO 5 V IC 500 mA hFE 250-600 Package SOT-23 Configuration Single Dice MECHANICAL DATA ● ● ● ● Case: SOT-23 Molding compound meets UL 94 V-0 flammability rating Moisture sensitivity level: level 1, per J-STD-020 Packing code with suffix "G" means green compound (halogen-free) ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 1A whisker test ● Weight: 8mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Power dissipation BC817- BC817- BC81716 6A 25 6B 40 6C UNIT PD 300 mW Collector-base voltage, emitter open IC = 10 μA, IE = 0 VCBO 50 V Collector-emitter voltage, base open IC = 10 mA, IB = 0 VCEO 45 V Emitter-base voltage, collector open IE = 1 μA, IC = 0 VEBO 5 V Collector current, dc IC 500 mA Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version:J1702 BC817-16/-25/-40 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS Collector cutoff current, emitter open Emitter cutoff current, collector open SYMBOL MIN TYP MAX UNIT VCB = 45 V, IE = 0 ICBO - - 0.1 µA VEB = 4 V, IC = 0 IEBO - - 0.1 µA 100 - 250 160 - 400 250 - 600 BC817-16 VCE = 1 V, DC current gain IC = 100 mA Collector-emitter saturation voltage Base-emitter saturation voltage BC817-25 hFE BC817-40 IC = 500 mA, IB = 50 mA VCE(sat) - - 0.7 V IC = 500 mA, IB = 50 mA VBE(sat) - - 1.2 V fT 100 - - MHz VCE = 5 V , IC = 10 mA, Transition frequency f= 100MHz ORDERING INFORMATION PART NO. PACKING PACKING CODE CODE SUFFIX(*) RF G BC817-XX (Note 1) PACKAGE PACKING SOT-23 3K / 7" Reel Notes: 1. "xx" is Device Code is"16" and "25" and "40" *: optional available EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BC817-16 RFG BC817-16 RF PACKING CODE SUFFIX G 2 DESCRIPTION Green compound Version:J1702 BC817-16/-25/-40 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Typical Pulsed Current Gain VS. Fig. 2 Collector-Emitter Saturation Voltage VS. Collector Current Collector Current 10.00 IC , Collector Current (mA) IC , Collector Current (A) 10 1 0.1 0.01 1.00 0.10 VCE = 5 V 0.01 0.001 0 100 200 300 400 0.0 500 hFE 0.1 0.3 0.4 0.5 0.6 VCE(sat) , Collector Emitter Voltage (V) Fig.3 Base-Emitter Saturation Voltage Fig.4 Base-Emitter On Voltage VS. Collector Current VS. Collector Current 1000 1 IC , Collector Current (A) -IC, Collector Current (mA) 0.2 100 10 1 0.1 0.01 0.001 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0.0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 VBE(sat) , Base-Emitter on Voltage (V) VBE , Base-Emitter Voltage (V) 3 Version:J1702 BC817-16/-25/-40 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Collector-Base Capacitance VS. Collector-Base Voltage Collector-Base Capacitance (pF) 40 30 20 10 0 0 4 8 12 16 20 24 28 VCB , Collector-Base Voltage (V) 4 Version:J1702 BC817-16/-25/-40 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION SOT-23 DIM. Unit(mm) Unit(inch) Min Max Min Max A 2.70 3.10 0.106 0.122 B 1.10 1.50 0.043 0.059 C 0.30 0.51 0.012 0.020 D 1.78 2.04 0.070 0.080 E 2.10 2.64 0.083 0.104 F 0.89 1.30 0.035 0.051 G 0.55 REF 0.022 REF H 0.10 REF 0.004 REF SUGGEST PAD LAYOUT Unit(mm) Unit(inch) TYP TYP Z 2.8 0.11 X 0.7 0.03 Y 0.9 0.04 C 1.9 0.07 E 1.0 0.04 DIM. 5 Version:J1702 BC817-16/-25/-40 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version:J1702
BC817-40 RF 价格&库存
很抱歉,暂时无法提供与“BC817-40 RF”相匹配的价格&库存,您可以联系我们找货
