BC817-40W RF
BC817-40W RF
    TAIWANSEMICONDUCTOR(台湾半导体)
BC817-40W RF 数据手册
BC817-16W/-25W/-40W Taiwan Semiconductor NPN General Purpose Transistor FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Epitaxial planar die construction Surface mount device type Matte Tin(Sn) lead finish with Nickel(Ni) underplate High temperature soldering guaranteed: 260°C/10s Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IC 500 mA VCBO 50 V VCEO 45 V VEBO 5 V TJ MAX 150 °C Package APPLICATIONS SOT-323 ● General-purpose switching and amplification MECHANICAL DATA ● Case: SOT-323 ● Terminal: Matte tin plated, lead free, solderable per MIL-STD-202, Method 208 guaranteed ● Weight: 5.00mg (approximately) SOT-323 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT Power dissipation PD 200 mW Collector current, dc IC 500 mA Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: E2102 BC817-16W/-25W/-40W Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT RӨJA 625 °C/W Junction-to-ambient thermal resistance ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN MAX UNIT Collector-Base Breakdown Voltage IC = 10μA V(BR)CBO 50 - V Collector-Emitter Breakdown Voltage IC = 10mA V(BR)CEO 45 - V Emitter-Base Breakdown Voltage IE = 10μA V(BR)EBO 5 - V Collector Cut-off Current VCB = 20 V ICBO - 100 nA Emitter Cut-off Current VEB = 5 V IEBO - 100 nA 100 250 - 160 400 - 250 600 - 40 - - VCE(sat) - 0.7 V fT 100 - MHz BC817-16W BC817-25W BC817-40W BC817-16W BC817-25W BC817-40W Collector-Emitter Saturation Voltage VCE = 1 V, IC = 100 mA DC Current Gain Transition Frequency hFE VCE = 1 V, IC = 500 mA IC = 500 mA, IB = 50 mA VCE = 5V, IC = 10mA, f = 100MHz ORDERING AND MARKING INFORMATION ORDERING CODE(1) MARKING PACKAGE PACKING BC817-16W RF 6CR SOT-323 3K / 7" Reel BC817-25W RF 6CS SOT-323 3K / 7" Reel BC817-40W RF 6CT SOT-323 3K / 7" Reel BC817-16W RFG 6CR SOT-323 3K / 7" Reel BC817-25W RFG 6CS SOT-323 3K / 7" Reel BC817-40W RFG 6CT SOT-323 3K / 7" Reel Notes: 1. “G” means green compound (halogen free) 2 Version: E2102 BC817-16W/-25W/-40W Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Total Power Dissipation Fig.2 Permissible Pulse Load 250 1000 200 100 RθJA (K/W) 100 0.5 0.2 0.1 0.05 0.02 0.01 D=0 10 1 50 0.1 1.E+00 1.E+01 1.E+02 1.E+03 1.E+04 1.E+05 1.E+06 0 0 25 50 75 100 125 150 Ta ( oC) tp (μs) Fig.3 Permissible Pulse Load Fig.4 Collector Cutoff Current 100000 1000 1 UF1DLW TJ=125°C 0.1 10 10000 TJ=25°C UF1DLW 1 1000 MAX TJ=125°C (A) Ptotmax/PtotDC 100 D=0 0.005 0.01 0.02 0.05 0.1 0.2 0.5 ICBO (nA) 10 0.1 100 (A) Ptot (mW) 150 TJ=25°C TYP 10 10 0.01 0.01 Pulse width 1 0.001 1.E+00 1.E+01 1.E+02 1.E+03 1.E+04 1.E+05 1.E+06 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 1 0.001 1.2 tp (μs) 3 VPulse CB=25V width 0 0.3 0.4 0.5 50 0.6 0.7 TA ( oC) 100 0.8 0.9 1 150 1.1 Version: E2102 1.2 BC817-16W/-25W/-40W Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 DC Current Gain Fig.6 Transition Frequency 1000 1000 100 hFE fT (MHz) 100°C 25°C -50°C 100 10 VCE=1V VCE=5V 10 1 0 1 10 IC (mA) 100 1 1000 IC (mA) 100 1000 IC (mA) Fig.7 Base-Emitter Saturation Voltage Fig.8 Collector-Emitter Saturation Voltage 1000 1000 100 100 IC (mA) 150°C 25°C -50°C 10 10 1 150°C 25°C -50°C 10 1 hFE=10 0.1 0 1 0.1 2 0 VBEsat (V) 0.2 0.4 0.6 VCEsat (V) 4 Version: E2102 BC817-16W/-25W/-40W Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOT-323 SUGGESTED PAD LAYOUT 5 Version: E2102 BC817-16W/-25W/-40W Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: E2102
BC817-40W RF 价格&库存
很抱歉,暂时无法提供与“BC817-40W RF”相匹配的价格&库存,您可以联系我们找货
