KIT-ANTUFL18-01
KIT-ANTUFL18-01
    SYNAPSE
KIT-ANTUFL18-01 数据手册
REVISIONS ZONE REV. CHANGE DESCRIPTION APPROVED ALL ITEM PN 1 326043-01A 2 320006-01 3 CON369 A000 CREATE EMJ DATE 11/30/16 DESCRIPTION CABLE, u.FL TO RP-SMA FEMALE, 18-IN ANTENNA, 2.4GHZ, OUTDOOR, RIGHT ANGLE, RP-SMA MALE, 1.5dBi CONN O-RING FOR SMA CONNECTORS 7.1 .28 QTY. 1 1 1 2 RECOMMENDED PANEL OPENING PANEL THICKNESS 0.25" MAX 128.4 5 [457.2] 18 18.8 .74 TO CONTROLLER 1 NUT PART OF ITEM 1 3 BULKHEAD (REFERENCE) THIRD ANGLE PROJECTION LOCK WASHER PART OF ITEM 1 COMMENTS: SYNAPSE WIRELESS INC. 6723 ODYSSEY DR HUNTSVILLE, AL 35806 TITLE: UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: MACH 1 BEND 3 TWO PLACE DECIMAL .01 INTERPRET GEOMETRIC THREE PLACE DECIMAL .005 TOLERANCING PER: ANSI PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF SYNAPSE WIRELESS, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF SYNAPSE WIRELESS, INC IS PROHIBITED. MATERIAL OUTDOOR KIT, U.FL TO RIGHT ANGLE, GLP-KITANTUFL18-01 SIZE DWG. NO. A FINISH DO NOT SCALE DRAWING REV 120-035041-000 ENGR: EMJ A000 SHEET 1 OF 1
KIT-ANTUFL18-01 价格&库存
很抱歉,暂时无法提供与“KIT-ANTUFL18-01”相匹配的价格&库存,您可以联系我们找货
KIT-ANTUFL18-01
  • 14+273.3824414+35.36828
