M-C308 HEAT SINK KITS 数据手册
V10
HEATSINK KIT for
DC/DC CONVERTERS
FEATURES:
* Constructed of aluminum AL6063 for optimum heat transfer
* Designed specifically for DC/DC Converters and other baseplate packages
* Finished with black anodize plating
* Mounting hardware and thermal pad are available
DC/DC
PACKAGE
SB
1”x1”
B
2”x1”
LB
2.05”x1.2”
Quarter
Brick
Half Brick
FIN STYLE
HEATSINK
HEIGH
(mm)
Cross Cut
10.0
Cross Cut
10.0
Transverse
12.7
Longitudinal
12.7
PART NUMBER
HEATSINK
SBC100
(K-C087)
BC100
(K-C088)
N/A ^7
CLIP HC01
12.5
N/A ^7
CLIP HC01
10.2
8.99
3.29
2.73
2.40
2.10
5.61
4.01
3.39
2.86
2.49
4.78
2.44
2.06
1.76
1.58
3.9
1.74
1.33
1.12
0.97
4.7
2.89
2.3
1.88
1.59
3.0
1.44
1.17
1.04
0.95
2.4
1.76
1.17
1.0
0.83
2.4
1.76
1.17
1.0
0.83
PQ01
21
HBL210
(M-C308)
Transverse
12.7
HBT127
(M-C091)
Transverse
25.4
HBT254
(M-C092)
Longitudinal
25.4
FBL254
(M-B012)
25.4
CONVECTION
QBL127
(M-C448)
QBT210
(M-C421)
Longitudinal
Longitudinal
MOUNTING
HARDWARE
PL01
21
Full Brick
THERMAL
PAD
LBT127
(M-C655)
Transverse
THERMAL RESISTANCE (C/W)
PH01
K258W
(NOTES 5)
K308W
(NOTES 5)
K310W
(NOTES 5)
K320W
PF01
FBL254T ^1
(M-C997)
(NOTES 5)
K320N
(NOTES 5)
NATURAL
100 LFM 200 LFM 300 LFM 400 LFM
NOTES:
1. With threaded mounting hole
2. Example Part Numbers:
QBL127: Quarter Brick Heatsink (12.7mm High), plate fin (longitudinal)
FBL254PF01: Full Brick Heatsink (25.4mm High), plate fin (longitudinal) with thermal interface pad
HBT127PH01K308W: Half Brick Heatsink (12.7mm High), plate fin (transverse) with thermal interface pad and 4 pieces of
M3 x 8mm screws & spring washers
HBL210K308W: Half Brick Heatsink (21.0mm High), plate fin (longitudinal) with 4 pieces of M3 x 8mm screws & spring washers
3. Thermal data provided are for reference only. Actual cooling performance may vary by application.
4. Specifcations are subject to change without notice.
5. K258W: Screw set M2.5*8mm screw & lock washer x 2pcs
K308W : Screw set M3*8mm screw with spring washer x 4pcs
K310W: Screw set M3*10mm screw with spring washer x 4pcs
K320W : Screw set M3*20mm screw & spring washer x 4pcs
K320N: Screw set M3*20mm screw & lock screw nut x 4pcs
6. For volume orders, converters will be supplied with heat-sink already mounted. Separate heatsinks are only available for prototypes
and small quantity orders.
7. Applying proper thermal paste is recommended.
1
V10
SB 1”x1” CASE
HEATSINK KIT
Cross Cut Heat Sink: SBC100 (K-C087)
All Dimensions in mm
Rca: 12.5°C/W (typ.), at natural convection
Assembly:
Heat Sink: SBC100
Clip: HC01
2
V10
B 2”x1” CASE
HEATSINK KIT
Cross Cut Heat Sink: BC100 (K-C088)
Rca: 10.2°C/W (typ.), at natural convection
Assembly:
Heat Sink: BC100
Clip: HC01
3
V10
LB 2.05”x1.2” CASE
HEATSINK KIT
Heat Sink: LBT127 (M-C655) Transverse Fins
.15
+0 .10
20.70±0.2
30.50±0.2
9.5
8.1
2-
2.7
4
2-R
7.22
21
22.4
4.90
.6
36.5±0.2
50.8
15-3.30
16-1.30
16-R0.65
12.7±0.3
0.3
2 Side 4-C0.2
Rca: 8.99°C/W (typ.), at natural convection
3.29°C/W (typ.), at 100LFM
2.73°C/W (typ.), at 200LFM
2.40°C/W (typ.), at 300LFM
2.10°C/W (typ.), at 400LFM
Thermal Pad: PL01 29.5*49.8*0.25mm
Screw Set: K258W M2.5*8mm+Lock Washer
4
3±0.3
V10
QB CASE HEATSINK
KIT
Heat Sink: QBT210 (M-C421) Transverse Fins
Rca: 4.78°C/W (typ.), at natural convection
2.44°C/W (typ.), at 100LFM
2.06°C/W (typ.), at 200LFM
1.76°C/W (typ.), at 300LFM
1.58°C/W (typ.), at 400LFM
Thermal Pad: PQ01 35.8*56.9*0.25 mm
Screw Set: K308W SMP+SW M3*8mm
5
V10
QB CASE HEATSINK
KIT
Heat Sink: QBL127 (M-C448) Longitudinal Fins
0.30
Rca: 5.61°C/W (typ.), at natural convection
4.01°C/W (typ.), at 100LFM
3.39°C/W (typ.), at 200LFM
2.86°C/W (typ.), at 300LFM
2.49°C/W (typ.), at 400LFM
6
V10
HB CASE HEATSINK
Heat Sink: HBL210 (M-C308) Longitudinal Fins
60.70
50.80
58
48.20
2-8.50
5-7.80
8-2
21
3±0.3
R1
0.30
Rca: 3.9°C/W (typ.), at natural convection
1.74°C/W (typ.), at 100LFM
1.33°C/W (typ.), at 200LFM
1.12°C/W (typ.), at 300LFM
0.97 °C/W (typ.), at 400LFM
7
V10
HB CASE HEATSINK
Heat Sink: HBT127 (M-C091) Transverse Fins
61
50.8
48.2
58
12.7
2.7
M-C091
Rca: 4.7°C/W (typ.), at natural convection
2.89°C/W (typ.), at 100LFM
2.30°C/W (typ.), at 200LFM
1.88°C/W (typ.), at 300LFM
1.59°C/W (typ.), at 400LFM
8
章
節
HS-1
頁
次
1-8
V10
HB CASE HEATSINK
Heat Sink: HBT127 (M-C092) Transverse Fins
61
50.8
48.2
58
25.4
2.7
M-C092
Rca: 3°C/W (typ.), at natural convection
1.44°C/W (typ.), at 100LFM
1.17°C/W (typ.), at 200LFM
1.04°C/W (typ.), at 300LFM
0.95°C/W (typ.), at 400LFM
9
V10
HB CASE HEATSINK
Assembly
HBT127 (M-C091)
HBT254 (M-C092)
Thermal Pad: PH01 56.9*60*0.25 mm
10
V10
FB CASE HEATSINK
Heat Sink: FBL254 (M-B012) Longitudinal Fins
**Clear Mounting Inserts Φ3.3mm Through**
25.4
8
8
1.4
6-R
1.0
5
4
0.
-R
10 0.2
R
4-
2.1
8
8
32
50.8±0.1
+0
2.7
9.6
5.05
14.5
5.1
106.7±0.1
.9
R0
61 -0.1
5.4
2-
116.8 +0
-0.1
8
0.30
9.6
90°
4-
3.3
R0
.8
1.8
2-
0.5
4.2
Heat Sink: FBL254T(M-C997) Longitudinal Fins
** Mounting Inserts M3*0.5 Through**
116.8±0.3
25.4
106.7±0.2
5.05
5.4
2-R0.9
2.7
9.6
5.1
8.0
0.3
6-R1.05
10-R0.4
8.0
61.0±0.5
50.8±0.2
8.0
1.4
8.0
4-R0.2
8.0
C0.3
4-M3*0.5
90°
9.6
2.1
0.5
4.2
Rca: 2.4°C/W (typ.), at natural convection
1.76°C/W (typ.), at 100LFM
1.00°C/W (typ.), at 300LFM
0.83°C/W (typ.), at 400LFM
11
2-R0.8
C0.3
V10
FB CASE HEATSINK
Assembly
Screw
Heatsink
Thermal Pad
Screw nut
Thermal Pad: PF01 60*115.8*0.25mm
Screw Set: K320N M3*20mm + Nut NH+WOM3*P0.5N
12
V10
FB CASE HEATSINK
Assembly
Heatsink
Thermal Pad
Washer
Screw
Heat Sink: FBL254T (M-C997)
Screw Set: K320W M3*20mm+Washer WS3.2N
13
M-C308 HEAT SINK KITS 价格&库存
很抱歉,暂时无法提供与“M-C308 HEAT SINK KITS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+51.504851+6.44529
- 10+45.5704610+5.70266
- 25+43.4081525+5.43207
- 50+41.8384350+5.23564
- 120+39.93665120+4.99765
- 360+37.66974360+4.71397
- 600+36.65878600+4.58746
- 1080+35.527891080+4.44594
