ANT-B20-PW-QW-UFL
ANT-B20-PW-QW-UFL
    LINXTECHNOLOGIES(灵思)
    PW系列天线坚固、成本低且易于安装。单频段设计使天线选择更加简单,并在目标频段内具有更好的性能,同时拒绝不需要的频率信号。
ANT-B20-PW-QW-UFL 数据手册
Datasheet PW Series LTE Band 20 Single-Band Monopole Antenna PW Series antennas are rugged, low-cost and easy to install. The single frequency band of PW antennas makes the job of antenna selection RG-174 Cable, Straight Cut simple, with better performance in the target 1.32 mm Cable With frequency band than in multiband antennas andU.FL/MHF Jack rejection of signals from unwanted frequencies. Cut End UFL The PW LTE Band 20 antenna targets 790 MHz to 870 MHz with excellent VSWR, gain and efficiency for cellular IoT (LTE-M, NB-IoT) and traditional LTE Band 20, GSM and UMTS applications. This rugged 1/4-wave monopole antenna may be used with plastic or metal enclosures and supports weather-resistant applications. Features Applications • • • • • • • • • • • • • • • • Outperforms similar multiband solutions Durable, flexible main shaft Wide bandwidth Weather resistant for IP-rated applications1 O-ring compatible base Compatible with plastic2 and metal enclosures High gain (1.5 dBi at 790 MHz, 0.6 dBi at 826 MHz and 0.5 dBi at 870 MHz) High efficiency (75% at 790 MHz, 63% at 826 MHz and 56% at 870 MHz) LTE band 20 LTE-M (Cat-M1) and NB-IoT devices GSM: T-GSM-810 UMTS: ECDD Sensing and remote monitoring Hand-held devices Internet of Things (IoT) devices Low-power wide-area (LPWA) networks Ordering Information Part Number Description LTE Band 20 PW Series antenna, with 216 mm (8.5 in) 1.32 mm coax cable terminated ANT-B20-PW-QW-UFL with U.FL jack (female) connector ANT-B20-PW-QW LTE Band 20 PW Series antenna, with 216 mm (8.5 in) unterminated RG-174 coax cable Available from Linx Technologies and select distributors and representatives. Notes 1 Use of an O-ring is recommended, IP-ratings cannot be guaranteed 2 With appropriate counterpoise PW Series Antenna LTE Band 20 Datasheet Electrical Specifications ANT-B20-PW-QW-ccc Frequency Range 790 MHz to 870 MHz Center Frequency 826 MHz VSWR ≤ 2.1 : 1 Peak Gain 1.6 dBi Polarization Linear Radiation Omnidirectional Max Power 10 W Wavelength 1/4-wave Impedance 50 Ω Connection U.FL/MHF jack (female) on 1.32 mm cable or unterminated RG-174 cable Cable Length 216 mm (8.5 in) Height 89.7 mm (3.53 in) Weight ANT-B20-PW-QW = 20.6 g (0.73 oz) ANT-B20-PW-QW-UFL = 19.4 g (0.68 oz) Operating Temperature -40 °C to +90 °C Electrical specifications and plots measured with a 102 mm x 102 mm (4 in x 4 in) reference ground plane. VSWR 862.0 832.0 821.0 5 791.0 Figure 1 and Figure 2 provide the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of the percentage of transmitter power reflected back from the antenna. VSWR 4 30 3 20 2 10 1 0 790 795 800 805 810 815 820 825 830 835 840 845 850 855 860 865 870 Frequency (MHz) Figure 1.  PW LTE Band 20 Antenna VSWR with Band 20 Uplink/Downlink Highlights 2 Reflected Power (%) 40 PW Series Antenna LTE Band 20 862.0 832.0 5 821.0 791.0 Datasheet VSWR 4 30 3 20 2 1 10 740 760 780 800 820 840 Frequency (MHz) 860 880 900 Reflected Power (%) 40 0 Figure 2.  PW LTE Band 20 Antenna Full Bandwidth VSWR Return Loss 862.0 832.0 821.0 0 791.0 Return loss (Figure 3), represents the loss in power at the antenna due to reflected signals. Like VSWR, a lower return loss value indicates better antenna performance at a given frequency. -2 Return Loss (dB) -4 -6 -8 -10 -12 -14 -16 -18 -20 790 795 800 805 810 815 820 825 830 835 840 Frequency (MHz) 845 850 855 860 865 870 Figure 3.  PW LTE Band 20 Antenna Return Loss with Band 20 Uplink/Downlink Highlights 3 PW Series Antenna LTE Band 20 Datasheet Peak Gain 862.0 832.0 821.0 5 791.0 The peak gain across the antenna bandwidth is shown in Figure 4. Peak gain represents the maximum antenna input power concentration across 3-dimensional space, and therefore peak performance, at a given frequency, but does not consider any directionality in the gain pattern. Peak Gain (dBi) 0 -5 -10 -15 -20 790 795 800 805 810 815 820 825 830 835 840 Frequency (MHz) 845 850 855 860 865 870 Figure 4.  PW LTE Band 20 Antenna Peak Gain with Band 20 Uplink/Downlink Highlights Average Gain 862.0 832.0 821.0 5 791.0 Average gain (Figure 5), is the average of all antenna gain in 3-dimensional space at each frequency, providing an indication of overall performance without expressing antenna directionality. Average Gain (dBi) 0 -5 -10 -15 -20 790 795 800 805 810 815 820 825 830 835 840 Frequency (MHz) 845 850 855 860 865 Figure 5.  PW LTE Band 20 Antenna Average Gain with Band 20 Uplink/Downlink Highlights 4 870 PW Series Antenna LTE Band 20 Datasheet Radiation Efficiency 862.0 832.0 821.0 100 791.0 Radiation efficiency (Figure 6), shows the ratio of power delivered to the antenna relative to the power radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance at a given frequency. 90 80 Efficiency (%) 70 60 50 40 30 20 10 0 790 795 800 805 810 815 820 825 830 835 840 Frequency (MHz) 845 850 855 860 865 870 Figure 6.  PW LTE Band 20 Antenna Radiation Efficiency with Band 20 Uplink/Downlink Highlights Product Dimensions Ø 14.5 mm (0.57 in) 7/16 in. Hex Nut 1/4-28UNF Thread 89.7 mm (3.53 in) 52.0 mm (2.05 in) Ø 6.0 mm (0.24 in) Ø 7.8 mm (0.31 in) Figure 7.  PW LTE Band 20 Antenna Dimensions 5 PW Series Antenna LTE Band 20 Datasheet Antenna Mounting The antenna is attached by placing its cable and base through a 6.35 mm (0.25 in) hole in the product enclosure and securing it with the included nut or by threading it into a PEM-style insert (not included). The straight-cut RG-174 coax cable option allows the attachment of a 50-ohm RF connector or allows the cable to be soldered directly to a PCB, eliminating the need for a connector. The connectorized option provides a 1.32 mm coax cable terminated with a U.FL/MHF compatible connector for simplified manufacturing or for applications requiring the ability to disconnect the antenna. Counterpoise Quarter-wave or monopole antennas require an associated ground plane counterpoise for proper operation. The size and location of the ground plate relative to the antenna will affect the overall performance of the antenna in the final design. When used in conjunction with a ground plane smaller than that used to tune the antenna, the center frequency typically will shift higher in frequency and the bandwidth will decrease. The proximity of other circuit elements and packaging near the antenna will also affect the final performance. For further discussion and guidance on the importance of the ground plane counterpoise, please refer to Linx Application Note AN-00501: Understanding Antenna Specifications and Operation. Figure 8.  PW LTE Band 20 Antenna Shown On Edge of Evaluation Board 6 PW Series Antenna LTE Band 20 Datasheet Radiation Patterns Radiation patterns provide information about the directionality and 3-dimensional gain performance of the antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns (Figure 9), are shown using polar plots covering 360 degrees. The antenna graphic above the plots provides reference to the plane of the column of plots below it. Note: when viewed with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail. XZ-Plane Gain YZ-Plane Gain XY-Plane Gain 791 MHz to 862 MHz (826 MHz) 330 340 320 310 300 290 280 270 350 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 0 10 20 30 330 40 320 50 310 60 300 70 260 250 120 230 130 220 140 210 200 190 180 170 160 XZ-Plane Gain 150 290 80 280 90 270 100 260 110 240 340 350 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 0 10 20 30 330 40 320 50 310 60 300 70 250 120 230 130 220 140 210 200 190 180 170 160 150 290 80 280 90 270 100 260 110 240 340 350 5 0 -5 -10 -15 -20 -25 -30 -35 -40 -45 -50 0 10 20 30 40 50 60 70 80 90 100 250 110 240 120 230 130 220 140 210 200 YZ-Plane Gain 190 180 170 160 150 826 MHz 791 MHz 862 MHz XY-Plane Gain Figure 9.  Radiation Patterns for PW LTE Band 20 Antenna 7 Website: http://linxtechnologies.com Linx Offices: 159 Ort Lane, Merlin, OR, US 97532 Phone: +1 (541) 471-6256 E-MAIL: info@linxtechnologies.com Linx Technologies reserves the right to make changes to the product(s) or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information. Wireless Made Simple is a registered trademark of Linx Acquisitions LLC. Other product and brand names may be trademarks or registered trademarks of their respective owners. Copyright © 2019 Linx Technologies All Rights Reserved Doc # DS19168-17ANT
ANT-B20-PW-QW-UFL 价格&库存
很抱歉,暂时无法提供与“ANT-B20-PW-QW-UFL”相匹配的价格&库存,您可以联系我们找货
