CL21-0.01uF100V 5%
CL21-0.01uF100V 5%
    TONGFENG(铜峰)
CL21-0.01uF100V 5% 数据手册
CL21 型金属化聚酯薄膜电容器 Metallized Polyester Film Capacitor Type CL21 ■特点 Features 体积小容量大 具有自愈性能 ● Small size, large capacitance values; self-healing property ■ 用途 Applications ● ● ● ● 直流和 VHF 级信号隔直,旁路和耦合电路 Blocking, by-pass and coupling of DC and signals to VHF range 用于逻辑和时间电路 Logic and timing circuit 轻值脉冲形成网络 Light duty pulse forming network 广泛用于滤波,降噪和低脉动电路中 Widely applied to filtration, noise suppression and low pulsating circuits ■ 技术规范 Technical Specifications ●引用标准 Reference Standard:GB7335-87 ●额定值和特性 Ratings and characteristics 气候类别 Climate category:55/085/21 ● 额定电压 Rated voltage:50/100160V,250V,400V,630V ● 电容量范围 Capacitance range:0.01~4.7μF ● 电容量偏差 Capacitance tolerance:±5%(J)、±10%(K)、±20%(M) ● - 损耗角正切:≤10×10 3(20℃,1kHz) ● 耐电压 voltage proof:1.75Ur(5s) ● 绝缘电阻 Withstand voltage:Cr≤0.33μF ,U R≤100V,R≥20000MΩ; UR>100V,R≥40000MΩ ● Cr>0.33μF,UR≤100V,RC≥6600S; UR>100V,RC≥12000S ●结构 Construction ·金属化聚酯薄膜,环氧树脂包封 Metallized Polyester film, flame-retardant epoxy resin coating ■ 外形尺寸 Dimensions(mm) 50V/100V/160V 电容量(μF) Wmax Hmax Tmax 250V p±1 d Wmax Hmax Tmax 400V p±1 d Wmax Hmax Tmax 630V p±1 d Wmax Hmax Tmax p±1 d 0.015 10 7.7 4.6 7.5 0.6 10 7.7 4.6 7.5 0.6 10 7.7 4.6 7.5 0.6 10 7.7 4.6 7.5 0.6 0.022 10 7.7 4.6 7.5 0.6 10 7.7 4.6 7.5 0.6 10 7.7 4.6 7.5 0.6 10 7.7 4.6 7.5 0.6 0.033 10 7.9 4.7 7.5 0.6 10 7.9 4.7 7.5 0.6 10 7.9 4.7 7.5 0.6 10 7.9 4.7 7.5 0.6 0.047 10 8 4.6 7.5 0.6 10 8 4.6 7.5 0.6 10 8 4.6 7.5 0.6 10 8 4.6 7.5 0.6 0.068 10 8 4.6 7.5 0.6 10 8 4.6 7.5 0.6 10 8 4.6 7.5 0.6 10 9 6 7.5 0.6 0.1 10 8.1 4.8 7.5 0.6 10 8.1 4.8 7.5 0.6 10 8.5 5 7.5 0.6 13 10 6.5 7.5 0.6 0.15 10 8.6 4.8 7.5 0.6 10 8.6 4.8 7.5 0.6 13 10 5 10 0.6 13 11 8 10 0.6 0.22 10 9 5 7.5 0.6 13 9 5 10 0.6 13 11 6 10 0.6 18 11.5 6.5 15 0.8 0.33 10 8.5 5 7.5 0.6 13 10 6 10 0.6 18 11 6 15 0.8 18 13 8 15 0.8 0.47 10 9 5.5 7.5 0.6 18 10.5 5.5 15 0.8 18 12 6 15 0.8 18 14 9 15 0.8 0.68 13 10 5.5 10 0.6 18 11.5 6.5 15 0.8 18 14 9 15 0.8 23 15 8.5 20 0.8 1.0 13 11 6.5 10 0.6 18 13 8 15 0.8 18 16 11 15 0.8 1.5 18 11 6 15 0.8 18 14.5 10 15 0.8 23 17 10 20 0.8 2.2 18 12 7 15 0.8 18 16.5 12 15 0.8 23 19 12.5 20 0.8 注:表中以外的规格和尺寸,可以商谈。 Note: Other specifications and sizes out of the table are negotiable.
CL21-0.01uF100V 5% 价格&库存
很抱歉,暂时无法提供与“CL21-0.01uF100V 5%”相匹配的价格&库存,您可以联系我们找货
