NRF52811-CAAA-R
NRF52811-CAAA-R
    NORDIC(北欧)
    WLCSP33
NRF52811-CAAA-R 数据手册
nRF52811 Product Specification v1.0 4454_140 v1.0 / 2019-02-26 Feature list Features: • ® Bluetooth 5.1, IEEE 802.15.4-2006, 2.4 GHz transceiver • ® -97 dBm sensitivity in 1 Mbps Bluetooth low energy mode Nordic SoftDevice ready -104 dBm sensitivity in 125 kbps Bluetooth low energy mode (long range) • Support for concurrent multi-protocol • -20 to +4 dBm TX power, configurable in 4 dB steps • 12-bit, 200 ksps ADC - 8 configurable channels with programmable • On-air compatible with nRF52, nRF51, nRF24L, and nRF24AP Series • Supported data rates: ® gain ® • Bluetooth 5.1: 2 Mbps, 1 Mbps, 500 kbps, and 125 kbps • IEEE 802.15.4-2006: 250 kbps • Proprietary 2.4 GHz: 2 Mbps, 1 Mbps Angle-of-arrival (AoA) and angle-of-departure (AoD) direction finding using ® Bluetooth . • Single-ended antenna output (on-chip balun) • 4.6 mA peak current in TX (0 dBm) • 4.6 mA peak current in RX • • 192 kB flash and 24 kB RAM • • • • • RSSI (1 dB resolution) ® ® ARM Cortex -M4 32-bit processor, 64 MHz ® • 144 EEMBC CoreMark score running from flash memory • 34.4 µA/MHz running CoreMark from flash memory • 32.8 µA/MHz running CoreMark from RAM memory • Serial wire debug (SWD) • 64 level comparator • Temperature sensor • Up to 32 general purpose I/O pins • 4-channel pulse width modulator (PWM) unit with EasyDMA • Digital microphone interface (PDM) • 3x 32-bit timer with counter mode • 2x SPI master/slave with EasyDMA • I2C compatible 2-wire master/slave • UART (CTS/RTS) with EasyDMA • Programmable peripheral interconnect (PPI) • Quadrature decoder (QDEC) • AES HW encryption with EasyDMA • 2x real-time counter (RTC) • Single crystal operation • Package variants Flexible power management • 1.7 V to 3.6 V supply voltage range • Fully automatic LDO and DC/DC regulator system • Fast wake-up using 64 MHz internal oscillator • 0.3 µA at 3 V in System OFF mode, no RAM retention • 0.5 µA at 3 V in System OFF mode with full 24 kB RAM retention • 1.5 µA at 3 V in System ON mode, with full 24 kB RAM retention, wake on • QFN48 package, 6 x 6 mm • QFN32 package, 5 x 5 mm • WLCSP package, 2.482 x 2.464 mm RTC • 1.4 µA at 3 V in System ON mode, no RAM retention, wake on RTC Applications: • Computer peripherals and I/O devices • Health and medical • Mouse • Enterprise lighting • Keyboard • Industrial • Mobile HID • Commercial • Retail • CE remote controls • Network processor • Beacons • Wearables • Connectivity device in multi-chip solutions • Virtual reality headsets 4454_140 v1.0 ii Contents Feature list. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ii 1 Revision history. 2 About this document. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 11 2.1 Document naming and status . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.2 Peripheral naming and abbreviations . . . . . . . . . . . . . . . . . . . . . . . . 2.3 Register tables . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3.1 Fields and values . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.4.1 DUMMY . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 11 12 12 12 12 3 Block diagram. 14 4 Core components. 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 4.1 CPU . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.1.1 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.1.2 CPU and support module configuration . . . . . . . . . . . . . . . . . . . . . 4.2 Memory . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.2.1 RAM - Random access memory . . . . . . . . . . . . . . . . . . . . . . . . 4.2.2 Flash - Non-volatile memory . . . . . . . . . . . . . . . . . . . . . . . . . 4.2.3 Memory map . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.2.4 Instantiation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3 NVMC — Non-volatile memory controller . . . . . . . . . . . . . . . . . . . . . . 4.3.1 Writing to flash . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.2 Erasing a page in flash . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.3 Writing to user information configuration registers (UICR) . . . . . . . . . . . . . 4.3.4 Erasing user information configuration registers (UICR) . . . . . . . . . . . . . . . 4.3.5 Erase all . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.6 Partial erase of a page in flash . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.7 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.3.8 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.4 FICR — Factory information configuration registers . . . . . . . . . . . . . . . . . . 4.4.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.5 UICR — User information configuration registers . . . . . . . . . . . . . . . . . . . 4.5.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6.1 EasyDMA error handling . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.6.2 EasyDMA array list . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.7 AHB multilayer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8 Debug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.1 DAP - Debug access port . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.2 CTRL-AP - Control access port . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.3 Debug interface mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.8.4 Real-time debug . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 15 15 15 16 17 17 17 18 19 19 19 20 20 20 20 20 24 24 24 32 32 35 36 37 37 38 39 39 41 41 Power and clock management. 42 . . . . . . . . . . . . . . . . . . . . . . . 5.1 Power management unit (PMU) . . . . . . . . . . . . . . . . . . . . . . . . . . 42 5.2 Current consumption . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 42 4454_140 v1.0 iii 6 5.2.1 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3 POWER — Power supply . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.1 Regulators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.2 System OFF mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.3 System ON mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.4 Power supply supervisor . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.5 RAM power control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.6 Reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.7 Retained registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.8 Reset behavior . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.9 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.3.10 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4 CLOCK — Clock control . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.1 HFCLK clock controller . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.2 LFCLK clock controller . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.3 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5.4.4 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 43 48 48 49 50 50 52 52 53 53 54 60 61 62 63 66 72 Peripherals. 74 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.1 Peripheral interface . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 74 6.1.1 Peripheral ID . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 74 6.1.2 Peripherals with shared ID . . . . . . . . . . . . . . . . . . . . . . . . . . 75 6.1.3 Peripheral registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 6.1.4 Bit set and clear . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 6.1.5 Tasks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 6.1.6 Events . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 75 6.1.7 Shortcuts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 76 6.1.8 Interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 76 6.2 AAR — Accelerated address resolver . . . . . . . . . . . . . . . . . . . . . . . . 77 6.2.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 77 6.2.2 Resolving a resolvable address . . . . . . . . . . . . . . . . . . . . . . . . . 77 6.2.3 Use case example for chaining RADIO packet reception with address resolution using AAR . 78 6.2.4 IRK data structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 78 6.2.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 78 6.2.6 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82 6.3 BPROT — Block protection . . . . . . . . . . . . . . . . . . . . . . . . . . . . 82 6.3.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 84 6.4 CCM — AES CCM mode encryption . . . . . . . . . . . . . . . . . . . . . . . . 85 6.4.1 Key-steam generation . . . . . . . . . . . . . . . . . . . . . . . . . . . . 85 6.4.2 Encryption . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 6.4.3 Decryption . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 86 6.4.4 AES CCM and RADIO concurrent operation . . . . . . . . . . . . . . . . . . . . 87 6.4.5 Encrypting packets on-the-fly in radio transmit mode . . . . . . . . . . . . . . . 87 6.4.6 Decrypting packets on-the-fly in radio receive mode . . . . . . . . . . . . . . . . 88 6.4.7 CCM data structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 89 6.4.8 EasyDMA and ERROR event . . . . . . . . . . . . . . . . . . . . . . . . . . 90 6.4.9 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 90 6.4.10 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 6.5 COMP — Comparator . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 97 6.5.1 Differential mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99 6.5.2 Single-ended mode . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 99 6.5.3 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 101 6.5.4 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 108 6.6 ECB — AES electronic codebook mode encryption . . . . . . . . . . . . . . . . . . 109 4454_140 v1.0 iv 6.6.1 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.6.2 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.6.3 ECB data structure . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.6.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.6.5 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.7 EGU — Event generator unit . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.7.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.7.2 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.8 GPIO — General purpose input/output . . . . . . . . . . . . . . . . . . . . . . 6.8.1 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.8.2 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.8.3 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.9 GPIOTE — GPIO tasks and events . . . . . . . . . . . . . . . . . . . . . . . . . 6.9.1 Pin events and tasks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.9.2 Port event . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.9.3 Tasks and events pin configuration . . . . . . . . . . . . . . . . . . . . . . 6.9.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.9.5 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10 PDM — Pulse density modulation interface . . . . . . . . . . . . . . . . . . . . 6.10.1 Master clock generator . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.2 Module operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.3 Decimation filter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.4 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.5 Hardware example . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.6 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.7 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.10.8 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.11 PPI — Programmable peripheral interconnect . . . . . . . . . . . . . . . . . . . 6.11.1 Pre-programmed channels . . . . . . . . . . . . . . . . . . . . . . . . . 6.11.2 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12 PWM — Pulse width modulation . . . . . . . . . . . . . . . . . . . . . . . . 6.12.1 Wave counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12.2 Decoder with EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12.3 Limitations . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12.4 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.12.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13 QDEC — Quadrature decoder . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.1 Sampling and decoding . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.2 LED output . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.3 Debounce filters . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.4 Accumulators . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.5 Output/input pins . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.6 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.7 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.13.8 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14 RADIO — 2.4 GHz radio . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.1 Packet configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.2 Address configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.3 Data whitening . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.4 CRC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.5 Radio states . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.6 Transmit sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.7 Receive sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.8 Received signal strength indicator (RSSI) . . . . . . . . . . . . . . . . . . . . 4454_140 v1.0 v 109 109 109 110 112 112 113 115 115 116 117 122 123 123 124 124 125 129 129 129 129 130 130 131 132 132 138 139 140 141 145 146 149 156 156 157 165 166 167 167 168 168 168 169 180 180 181 182 182 182 183 184 185 187 6.14.9 Interframe spacing (IFS) . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.10 Device address match . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.11 Bit counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.12 Direction finding . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.13 IEEE 802.15.4 operation . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.14 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.15 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.14.16 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.15 RNG — Random number generator . . . . . . . . . . . . . . . . . . . . . . . 6.15.1 Bias correction . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.15.2 Speed . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.15.3 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.15.4 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16 RTC — Real-time counter . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.1 Clock source . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.2 Resolution versus overflow and the PRESCALER . . . . . . . . . . . . . . . . . 6.16.3 COUNTER register . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.4 Overflow features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.5 TICK event . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.6 Event control feature . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.7 Compare feature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.8 TASK and EVENT jitter/delay . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.9 Reading the COUNTER register . . . . . . . . . . . . . . . . . . . . . . . 6.16.10 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.16.11 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17 SAADC — Successive approximation analog-to-digital converter . . . . . . . . . . . . 6.17.1 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.2 Overview . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.3 Digital output . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.4 Analog inputs and channels . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.5 Operation modes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.6 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.7 Resistor ladder . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.8 Reference . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.9 Acquisition time . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.10 Limits event monitoring . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.11 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.12 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.17.13 Performance factors . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.18 SPI — Serial peripheral interface master . . . . . . . . . . . . . . . . . . . . . 6.18.1 Functional description . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.18.2 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.18.3 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19 SPIM — Serial peripheral interface master with EasyDMA . . . . . . . . . . . . . . 6.19.1 SPI master transaction sequence . . . . . . . . . . . . . . . . . . . . . . . 6.19.2 Master mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . 6.19.3 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19.4 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.19.6 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20 SPIS — Serial peripheral interface slave with EasyDMA . . . . . . . . . . . . . . . . 6.20.1 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.2 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.3 SPI slave operation . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4454_140 v1.0 vi 187 188 188 189 194 202 203 237 243 243 243 244 246 246 247 247 248 248 248 249 249 251 253 254 259 259 259 259 260 261 261 263 264 265 265 266 267 281 282 282 283 286 289 290 291 292 293 293 293 302 303 304 304 304 6.20.4 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.20.6 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21 SWI — Software interrupts . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.21.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22 TEMP — Temperature sensor . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.1 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.22.2 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23 TWI — I2C compatible two-wire interface . . . . . . . . . . . . . . . . . . . . . 6.23.1 Functional description . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.2 Master mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . 6.23.3 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.4 Master write sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.5 Master read sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.6 Master repeated start sequence . . . . . . . . . . . . . . . . . . . . . . . 6.23.7 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.8 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.23.9 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24 TIMER — Timer/counter . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.1 Capture . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.2 Compare . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.3 Task delays . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.4 Task priority . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.24.5 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25 TWIM — I2C compatible two-wire interface master with EasyDMA . . . . . . . . . . . 6.25.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.2 Master write sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.3 Master read sequence . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.4 Master repeated start sequence . . . . . . . . . . . . . . . . . . . . . . . 6.25.5 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.6 Master mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . 6.25.7 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.8 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.25.9 Pullup resistor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26 TWIS — I2C compatible two-wire interface slave with EasyDMA . . . . . . . . . . . . 6.26.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26.2 TWI slave responding to a read command . . . . . . . . . . . . . . . . . . . 6.26.3 TWI slave responding to a write command . . . . . . . . . . . . . . . . . . . 6.26.4 Master repeated start sequence . . . . . . . . . . . . . . . . . . . . . . . 6.26.5 Terminating an ongoing TWI transaction . . . . . . . . . . . . . . . . . . . . 6.26.6 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26.7 Slave mode pin configuration . . . . . . . . . . . . . . . . . . . . . . . . 6.26.8 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.26.9 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27 UART — Universal asynchronous receiver/transmitter . . . . . . . . . . . . . . . . 6.27.1 Functional description . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.2 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.3 Shared resources . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.4 Transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.5 Reception . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.6 Suspending the UART . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.7 Error conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.8 Using the UART without flow control . . . . . . . . . . . . . . . . . . . . . 6.27.9 Parity and stop bit configuration . . . . . . . . . . . . . . . . . . . . . . . 4454_140 v1.0 vii 306 307 318 320 320 320 320 326 327 327 327 328 328 329 330 331 331 338 339 341 341 341 341 341 346 347 348 349 350 351 351 351 362 363 363 366 366 367 368 369 369 369 370 380 380 381 381 381 381 382 383 383 383 383 6.27.10 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.27.11 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28 UARTE — Universal asynchronous receiver/transmitter with EasyDMA . . . . . . . . . 6.28.1 EasyDMA . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28.2 Transmission . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28.3 Reception . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28.4 Error conditions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28.5 Using the UARTE without flow control . . . . . . . . . . . . . . . . . . . . 6.28.6 Parity and stop bit configuration . . . . . . . . . . . . . . . . . . . . . . . 6.28.7 Low power . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28.8 Pin configuration . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28.9 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.28.10 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.29 WDT — Watchdog timer . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.29.1 Reload criteria . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.29.2 Temporarily pausing the watchdog . . . . . . . . . . . . . . . . . . . . . . 6.29.3 Watchdog reset . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.29.4 Registers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6.29.5 Electrical specification . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Hardware and layout. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.1 Pin assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.1.1 QFN48 pin assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.1.2 QFN32 pin assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.1.3 WLCSP ball assignments . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.1.4 GPIO pins located near the radio . . . . . . . . . . . . . . . . . . . . . . . 7.2 Mechanical specifications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2.1 QFN48 6 x 6 mm package . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2.2 QFN32 5 x 5 mm package . . . . . . . . . . . . . . . . . . . . . . . . . . 7.2.3 WLCSP 2.482 x 2.464 mm package . . . . . . . . . . . . . . . . . . . . . . 7.3 Reference circuitry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.3.1 Schematic QFAA QFN48 with internal LDO regulator setup . . . . . . . . . . . . . 7.3.2 Schematic QFAA QFN48 with DC/DC regulator setup . . . . . . . . . . . . . . . 7.3.3 Schematic QCAA QFN32 with internal LDO regulator setup . . . . . . . . . . . . . 7.3.4 Schematic QCAA QFN32 with DC/DC regulator setup . . . . . . . . . . . . . . . 7.3.5 Schematic CAAA WLCSP with internal LDO regulator setup . . . . . . . . . . . . . 7.3.6 Schematic CAAA WLCSP with DC/DC regulator setup . . . . . . . . . . . . . . . 7.3.7 Schematic CAAA WLCSP with two layers . . . . . . . . . . . . . . . . . . . . 7.3.8 PCB guidelines . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.3.9 PCB layout example . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 9 Recommended operating conditions. 383 392 392 393 393 394 396 396 396 396 397 397 410 410 411 411 411 411 415 416 416 416 418 420 423 423 423 424 424 425 425 426 427 428 429 430 432 433 434 . . . . . . . . . . . . . . . . . . . 436 8.1 WLCSP light sensitivity . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 436 Absolute maximum ratings. 10 Ordering information. 10.1 10.2 10.3 10.4 10.5 . . . . . . . . . . . . . . . . . . . . . . . . 437 . . . . . . . . . . . . . . . . . . . . . . . . . . . 438 IC marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Box labels . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Order code . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Code ranges and values . . . . . . . . . . . . . . . . . . . . . . . . . . . . Product options . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4454_140 v1.0 viii 438 438 439 440 441 11 Legal notices. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.1 Liability disclaimer . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.2 Life support applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.3 RoHS and REACH statement . . . . . . . . . . . . . . . . . . . . . . . . . . 11.4 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11.5 Copyright notice . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4454_140 v1.0 ix 443 443 443 443 443 444 1 Revision history Date Version Description February 2019 1.0 First release 4454_140 v1.0 10 2 About this document This product specification is organized into chapters based on the modules and peripherals that are available in this IC. The peripheral descriptions are divided into separate sections that include the following information: • A detailed functional description of the peripheral • Register configuration for the peripheral • Electrical specification tables, containing performance data which apply for the operating conditions described in Recommended operating conditions on page 436. 2.1 Document naming and status Nordic uses three distinct names for this document, which are reflecting the maturity and the status of the document and its content. Document name Description Objective Product Specification (OPS) Applies to document versions up to 0.7. This product specification contains target specifications for product development. Preliminary Product Specification (PPS) Applies to document versions 0.7 and up to 1.0. This product specification contains preliminary data. Supplementary data may be published from Nordic Semiconductor ASA later. Product Specification (PS) Applies to document versions 1.0 and higher. This product specification contains final product specifications. Nordic Semiconductor ASA reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. Table 1: Defined document names 2.2 Peripheral naming and abbreviations Every peripheral has a unique capitalized name or an abbreviation of its name, e.g. TIMER, used for identification and reference. This name is used in chapter headings and references, and it will appear in the ARM® Cortex® Microcontroller Software Interface Standard (CMSIS) hardware abstraction layer to identify the peripheral. The peripheral instance name, which is different from the peripheral name, is constructed using the peripheral name followed by a numbered postfix, starting with 0, for example, TIMER0. A postfix is normally only used if a peripheral can be instantiated more than once. The peripheral instance name is also used in the CMSIS to identify the peripheral instance. 4454_140 v1.0 11 About this document 2.3 Register tables Individual registers are described using register tables. These tables are built up of two sections. The first three colored rows describe the position and size of the different fields in the register. The following rows describe the fields in more detail. 2.3.1 Fields and values The Id (Field Id) row specifies the bits that belong to the different fields in the register. If a field has enumerated values, then every value will be identified with a unique value id in the Value Id column. A blank space means that the field is reserved and read as undefined, and it also must be written as 0 to secure forward compatibility. If a register is divided into more than one field, a unique field name is specified for each field in the Field column. The Value Id may be omitted in the single-bit bit fields when values can be substituted with a Boolean type enumerator range, e.g. true/false, disable(d)/enable(d), on/ off, and so on. Values are usually provided as decimal or hexadecimal. Hexadecimal values have a 0x prefix, decimal values have no prefix. The Value column can be populated in the following ways: • Individual enumerated values, for example 1, 3, 9. • Range of values, e.g. [0..4], indicating all values from and including 0 and 4. • Implicit values. If no values are indicated in the Value column, all bit combinations are supported, or alternatively the field's translation and limitations are described in the text instead. If two or more fields are closely related, the Value Id, Value, and Description may be omitted for all but the first field. Subsequent fields will indicate inheritance with '..'. A feature marked Deprecated should not be used for new designs. 2.4 Registers Register Offset Description DUMMY 0x514 Example of a register controlling a dummy feature Table 2: Register overview 2.4.1 DUMMY Address offset: 0x514 Example of a register controlling a dummy feature Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D Reset 0x00050002 ID Access Field A RW FIELD_A C C C Value ID Value Description Disabled 0 The example feature is disabled NormalMode 1 The example feature is enabled in normal mode ExtendedMode 2 The example feature is enabled along with extra Example of a field with several enumerated values functionality 4454_140 v1.0 B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 12 About this document Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D Reset 0x00050002 ID Access Field B RW FIELD_B C D Value ID Value B A A Description Disabled 0 The override feature is disabled Enabled 1 The override feature is enabled ValidRange [2..7] Example of a deprecated field RW FIELD_C Example of a field with a valid range of values Example of allowed values for this field RW FIELD_D 4454_140 v1.0 C C C 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 Example of a field with no restriction on the values 13 Deprecated Block diagram This block diagram illustrates the overall system. Arrows with white heads indicate signals that share physical pins with other signals. CTRL-AP NVIC slave slave slave CPU ARM CORTEX-M4 slave AHB multilayer AHB-AP nRESET P0 (P0.0 – P0.31) GPIO slave RAM2 slave SW-DP RAM1 slave SWCLK SWDIO RAM0 slave nRF52811 master AHB TO APB BRIDGE FICR UICR Flash SysTick NVMC RNG POWER RTC [0..1] TIMER [0..2] WDT TEMP PPI XC1 XC2 XL1 XL2 CLOCK ANT RADIO ECB master EasyDMA master EasyDMA master mast AAR er EasyDMA CCM EasyDMA master APB0 3 P0 (P0.0 – P0.31) SPIM master GPIOTE COMP AIN0 – AIN7 EasyDMA LED A B OUT[0] - OUT[3] master EasyDMA master EasyDMA TWIM master QDEC UARTE PWM EasyDMA CLK DIN master master PDM EasyDMA master Figure 1: Block diagram 14 SCL SDA SCL SDA RTS CTS TXD RXD EasyDMA SPIS master 4454_140 v1.0 EasyDMA TWIS SAADC SCK MOSI MISO EasyDMA CSN MISO MOSI SCK 4 Core components 4.1 CPU The ARM® Cortex®-M4 processor has a 32-bit instruction set (Thumb®-2 technology) that implements a superset of 16- and 32-bit instructions to maximize code density and performance. This processor implements several features that enable energy-efficient arithmetic and high-performance signal processing including: • • • • Digital signal processing (DSP) instructions Single-cycle multiply and accumulate (MAC) instructions Hardware divide 8 and 16-bit single instruction multiple data (SIMD) instructions The ARM Cortex Microcontroller Software Interface Standard (CMSIS) hardware abstraction layer for the ARM Cortex processor series is implemented and available for the M4 CPU. Real-time execution is highly deterministic in thread mode, to and from sleep modes, and when handling events at configurable priority levels via the nested vectored interrupt controller (NVIC). Executing code from flash will have a wait state penalty on the nRF52 Series. The section Electrical specification on page 15 shows CPU performance parameters including wait states in different modes, CPU current and efficiency, and processing power and efficiency based on the CoreMark® benchmark. The ARM System Timer (SysTick) is present on the device. The SysTick's clock will only tick when the CPU is running or when the system is in debug interface mode. 4.1.1 Electrical specification 4.1.1.1 CPU performance The CPU clock speed is 64 MHz. Current and efficiency data is taken when in System ON and the CPU is executing the CoreMark® benchmark. It includes power regulator and clock base currents. All other blocks are IDLE. Symbol Description Min. WFLASH CPU wait states, running from flash 0 Typ. Max. Units WRAM CPU wait states, running from RAM CMFLASH CoreMark1, running from flash 144 CoreMark CMFLASH/MHz CoreMark per MHz, running from flash 2.25 CoreMark/ CMFLASH/mA CoreMark per mA, running from flash, DCDC 3V 65 2 0 MHz CoreMark/ mA 4.1.2 CPU and support module configuration The ARM® Cortex®-M4 processor has a number of CPU options and support modules implemented on the device. 1 Using IAR v6.50.1.4452 with flags --endian=little --cpu=Cortex-M4 -e --fpu=VFPv4_sp –Ohs -no_size_constraints 4454_140 v1.0 15 Core components Option / Module Description Implemented NVIC Nested vector interrupt controller 30 vectors PRIORITIES Priority bits 3 WIC Wakeup interrupt controller NO Endianness Memory system endianness Little endian Bit-banding Bit banded memory NO DWT Data watchpoint and trace NO SysTick System tick timer YES MPU Memory protection unit YES FPU Floating-point unit NO DAP Debug access port YES ETM Embedded trace macrocell NO ITM Instrumentation trace macrocell NO TPIU Trace port interface unit NO ETB Embedded trace buffer NO FPB Flash patch and breakpoint unit YES HTM AMBA AHB trace macrocell Core options Modules ® NO 4.2 Memory The nRF52811 contains flash and RAM that can be used for code and data storage. The amount of RAM and flash will vary depending on variant, see Memory variants on page 16. Device name RAM Flash nRF52811-QFAA 24 kB 192 kB nRF52811-QCAA 24 kB 192 kB nRF52811-CAAA 24 kB 192 kB Comments Table 3: Memory variants The CPU and peripherals with EasyDMA can access memory via the AHB multilayer interconnect. The CPU is also able to access peripherals via the AHB multilayer interconnect, as illustrated in Memory layout on page 17. 4454_140 v1.0 16 Core components AHB2APB APB CPU System bus EasyDMA ICODE EasyDMA DMA bus Peripheral DMA bus Peripheral DCODE ARM Cortex-M4 Data RAM System Code RAM ICODE/DCODE RAM2 AHB slave Section 1 0x20005000 0x00805000 Section 0 0x20004000 0x00804000 RAM1 AHB slave Section 1 0x20003000 0x00803000 Section 0 0x20002000 0x00802000 RAM0 AHB slave Section 1 0x20001000 0x00801000 Section 0 0x20000000 0x00800000 AHB multilayer interconnect NVMC DCODE AHB slave ICODE AHB AHB slave Page 47 Flash ICODE/DCODE 0x0002F000 Page 3..46 0x00003000 Page 2 Page 1 Page 0 0x00002000 0x00001000 Block 7 0x00000E00 Block 2..6 0x00000400 Block 1 0x00000200 Block 0 0x00000000 Figure 2: Memory layout See AHB multilayer on page 37 and EasyDMA on page 35 for more information about the AHB multilayer interconnect and the EasyDMA. The same physical RAM is mapped to both the Data RAM region and the Code RAM region. It is up to the application to partition the RAM within these regions so that one does not corrupt the other. 4.2.1 RAM - Random access memory The RAM interface is divided into multiple RAM AHB slaves. Each RAM AHB slave is connected to two 4-kilobyte RAM sections, see Section 0 and Section 1 in Memory layout on page 17. Each of the RAM sections have separate power control for System ON and System OFF mode operation, which is configured via RAM register (see the POWER — Power supply on page 48). 4.2.2 Flash - Non-volatile memory The flash can be read an unlimited number of times by the CPU, but it has restrictions on the number of times it can be written and erased, and also on how it can be written. Writing to flash is managed by the non-volatile memory controller (NVMC), see NVMC — Non-volatile memory controller on page 19. The flash is divided into multiple 4 kB pages that can be accessed by the CPU via both the ICODE and DCODE buses as shown in, Memory layout on page 17. Each page is divided into 8 blocks. 4.2.3 Memory map The complete memory map is shown in Memory map on page 18. As described in Memory on page 16, Code RAM and Data RAM are the same physical RAM. 4454_140 v1.0 17 Core components Cortex M4 system address map 0xFFFFFFFF 0xE0100000 0xE0000000 Private peripheral bus 0x5FFFFFFF AHB peripherals 0x50000000 APB peripherals 0x1FFFFFFF 0x10002000 0x40000000 UICR 0x10001000 FICR 0x10000000 0x00806000 Code RAM 0x00800000 0x00030000 Peripheral 0.5GB SRAM 0.5GB Code 0.5GB 0x3FFFFFFF 0x20006000 Data RAM Flash 0x20000000 0x00000000 Figure 3: Memory map 4.2.4 Instantiation ID Base address Peripheral Instance Description 0 0x40000000 BPROT BPROT Block protect 0 0x40000000 CLOCK CLOCK Clock control 0 0x40000000 POWER POWER Power control 0 0x50000000 GPIO P0 General purpose input and output 1 0x40001000 RADIO RADIO 2.4 GHz radio 2 0x40002000 UART UART0 Universal asynchronous receiver/transmitter 2 0x40002000 UARTE UARTE0 Universal asynchronous receiver/transmitter with EasyDMA 3 0x40003000 SPI SPI1 SPI master 1 3 0x40003000 SPIM SPIM1 SPI master 1 3 0x40003000 SPIS SPIS1 SPI slave 1 3 0x40003000 TWI TWI0 Two-wire interface master 3 0x40003000 TWIM TWIM0 Two-wire interface master 3 0x40003000 TWIS TWIS0 Two-wire interface slave 4 0x40004000 SPI SPI0 SPI master 0 4 0x40004000 SPIM SPIM0 SPI master 0 4 0x40004000 SPIS SPIS0 SPI slave 0 6 0x40006000 GPIOTE GPIOTE GPIO tasks and events 7 0x40007000 SAADC SAADC Analog-to-digital converter 8 0x40008000 TIMER TIMER0 Timer 0 9 0x40009000 TIMER TIMER1 Timer 1 10 0x4000A000 TIMER TIMER2 Timer 2 11 0x4000B000 RTC RTC0 Real-time counter 0 12 0x4000C000 TEMP TEMP Temperature sensor 13 0x4000D000 RNG RNG Random number generator 14 0x4000E000 ECB ECB AES Electronic Codebook (ECB) mode block encryption 15 0x4000F000 AAR AAR Accelerated address resolver 4454_140 v1.0 18 Deprecated Deprecated Deprecated Deprecated Core components ID Base address Peripheral Instance Description 15 0x4000F000 CCM CCM AES CCM mode encryption 16 0x40010000 WDT WDT Watchdog timer 17 0x40011000 RTC RTC1 Real-time counter 1 18 0x40012000 QDEC QDEC Quadrature decoder 19 0x40013000 COMP COMP General purpose comparator 20 0x40014000 EGU EGU0 Event generator unit 0 20 0x40014000 SWI SWI0 Software interrupt 0 21 0x40015000 EGU EGU1 Event generator unit 1 21 0x40015000 SWI SWI1 Software interrupt 1 22 0x40016000 SWI SWI2 Software interrupt 2 23 0x40017000 SWI SWI3 Software interrupt 3 24 0x40018000 SWI SWI4 Software interrupt 4 25 0x40019000 SWI SWI5 Software interrupt 5 28 0x4001C000 PWM PWM0 Pulse-width modulation unit 0 29 0x4001D000 PDM PDM Pulse-density modulation (digital microphone interface) 30 0x4001E000 NVMC NVMC Non-volatile memory controller 31 0x4001F000 PPI PPI Programmable peripheral interconnect N/A 0x10000000 FICR FICR Factory information configuration N/A 0x10001000 UICR UICR User information configuration Table 4: Instantiation table 4.3 NVMC — Non-volatile memory controller The non-volatile memory controller (NVMC) is used for writing and erasing of the internal flash memory and the UICR (user information configuration registers). The CONFIG on page 21 is used to enable the NVMC for writing (CONFIG.WEN) and erasing (CONFIG.EEN). The user must make sure that writing and erasing are not enabled at the same time. Having both enabled at the same time may result in unpredictable behavior. The CPU must be halted before initiating a NVMC operation from the debug system. 4.3.1 Writing to flash When writing is enabled, full 32-bit words are written to word-aligned addresses in flash. As illustrated in Memory on page 16, the flash is divided into multiple pages. The same 32-bit word in the flash can only be written nWRITE number of times before a page erase must be performed. The NVMC is only able to write 0 to bits in the flash that are erased (set to 1). It cannot rewrite a bit back to 1. Only full 32-bit words can be written to flash using the NVMC interface. To write less than 32 bits, write the data as a full 32-bit word and set all the bits that should remain unchanged in the word to 1. Note that the restriction on the number of writes (nWRITE) still applies in this case. Only word-aligned writes are allowed. Byte or half-word-aligned writes will result in a hard fault. The time it takes to write a word to flash is specified by tWRITE. The CPU is halted while the NVMC is writing to the flash. 4.3.2 Erasing a page in flash When erase is enabled, the flash memory can be erased page by page using the ERASEPAGE on page 21. 4454_140 v1.0 19 Core components After erasing a flash page, all bits in the page are set to 1. The time it takes to erase a page is specified by tERASEPAGE. The CPU is halted if the CPU executes code from the flash while the NVMC is writing to the flash. See Partial erase of a page in flash on page 20 for information on dividing the page erase time into shorter chunks. 4.3.3 Writing to user information configuration registers (UICR) User information configuration registers (UICR) are written in the same way as flash. After UICR has been written, the new UICR configuration will take effect after a reset. UICR can only be written nWRITE number of times before an erase must be performed using ERASEUICR on page 23 or ERASEALL on page 22. The time it takes to write a word to UICR is specified by tWRITE. The CPU is halted while the NVMC is writing to the UICR. 4.3.4 Erasing user information configuration registers (UICR) When erase is enabled, UICR can be erased using the ERASEUICR on page 23. After erasing UICR all bits in UICR are set to 1. The time it takes to erase UICR is specified by tERASEPAGE. The CPU is halted if the CPU executes code from the flash while the NVMC performs the erase operation. 4.3.5 Erase all When erase is enabled, flash and UICR can be erased completely in one operation by using ERASEALL on page 22. This operation will not erase the factory information configuration registers (FICR). The time it takes to perform an ERASEALL command is specified by tERASEALL. The CPU is halted if the CPU executes code from the flash while the NVMC performs the erase operation. 4.3.6 Partial erase of a page in flash Partial erase is a feature in the NVMC to split a page erase time into shorter chunks, so this can be used to prevent longer CPU stalls in time-critical applications. Partial erase is only applicable to the code area in the flash and does not work with UICR. When erase is enabled, the partial erase of a flash page can be started by writing to ERASEPAGEPARTIAL on page 23. The duration of a partial erase can be configured in ERASEPAGEPARTIALCFG on page 23. A flash page is erased when its erase time reaches tERASEPAGE. Use ERASEPAGEPARTIAL N number of times so that N * ERASEPAGEPARTIALCFG ≥ tERASEPAGE, where N * ERASEPAGEPARTIALCFG gives the cumulative (total) erase time. Every time the cumulative erase time reaches tERASEPAGE, it counts as one erase cycle. After the erase is done, all bits in the page are set to '1'. The CPU is halted if the CPU executes code from the flash while the NVMC performs the partial erase operation. The bits in the page are undefined if the flash page erase is incomplete, i.e. if a partial erase has started but the total erase time is less than tERASEPAGE. 4.3.7 Registers Base address Peripheral Instance Description 0x4001E000 NVMC NVMC Non-volatile memory controller Configuration Table 5: Instances 4454_140 v1.0 20 Core components Register Offset Description READY 0x400 Ready flag CONFIG 0x504 Configuration register ERASEPAGE 0x508 Register for erasing a page in code area ERASEPCR1 0x508 Register for erasing a page in code area. Equivalent to ERASEPAGE. ERASEALL 0x50C Register for erasing all non-volatile user memory ERASEPCR0 0x510 Register for erasing a page in code area. Equivalent to ERASEPAGE. ERASEUICR 0x514 Register for erasing user information configuration registers ERASEPAGEPARTIAL 0x518 Register for partial erase of a page in code area ERASEPAGEPARTIALCFG 0x51C Register for partial erase configuration Deprecated Deprecated Table 6: Register overview 4.3.7.1 READY Address offset: 0x400 Ready flag Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000001 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value ID Value Description Busy 0 NVMC is busy (ongoing write or erase operation) Ready 1 NVMC is ready READY NVMC is ready or busy 4.3.7.2 CONFIG Address offset: 0x504 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A Reset 0x00000000 ID Access Field A RW WEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Program memory access mode. It is strongly recommended to activate erase and write modes only when they are actively used. Ren 0 Read only access Wen 1 Write enabled Een 2 Erase enabled 4.3.7.3 ERASEPAGE Address offset: 0x508 Register for erasing a page in code area 4454_140 v1.0 21 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW ERASEPAGE Value ID Value Description Register for starting erase of a page in code area. The value is the address to the page to be erased (addresses of first word in page). Note that the erase must be enabled using CONFIG.WEN before the page can be erased. Attempts to erase pages that are outside the code area may result in undesirable behavior, e.g. the wrong page may be erased. 4.3.7.4 ERASEPCR1 ( Deprecated ) Address offset: 0x508 Register for erasing a page in code area. Equivalent to ERASEPAGE. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW ERASEPCR1 Value ID Value Description Register for erasing a page in code area. Equivalent to ERASEPAGE. 4.3.7.5 ERASEALL Address offset: 0x50C Register for erasing all non-volatile user memory Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW ERASEALL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Erase all non-volatile memory including UICR registers. Note that the erase must be enabled using CONFIG.WEN before the non-volatile memory can be erased. NoOperation 0 No operation Erase 1 Start erase of chip 4.3.7.6 ERASEPCR0 ( Deprecated ) Address offset: 0x510 Register for erasing a page in code area. Equivalent to ERASEPAGE. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW ERASEPCR0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Register for starting erase of a page in code area. Equivalent to ERASEPAGE. 4454_140 v1.0 22 Core components 4.3.7.7 ERASEUICR Address offset: 0x514 Register for erasing user information configuration registers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW ERASEUICR 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Register starting erase of all user information configuration registers. Note that the erase must be enabled using CONFIG.WEN before the UICR can be erased. NoOperation 0 No operation Erase 1 Start erase of UICR 4.3.7.8 ERASEPAGEPARTIAL Address offset: 0x518 Register for partial erase of a page in code area Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW ERASEPAGEPARTIAL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Register for starting partial erase of a page in code area The value is the address to the page to be partially erased (address of the first word in page). Note that the erase must be enabled using CONFIG.WEN before every erase page partial and disabled using CONFIG.WEN after every erase page partial. Attempts to erase pages that are outside the code area may result in undesirable behaviour, e.g. the wrong page may be erased. 4.3.7.9 ERASEPAGEPARTIALCFG Address offset: 0x51C Register for partial erase configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x0000000A ID Access Field A RW DURATION 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 Value ID Value Description Duration of the partial erase in milliseconds The user must ensure that the total erase time is long enough for a complete erase of the flash page. 4454_140 v1.0 23 Core components 4.3.8 Electrical specification 4.3.8.1 Flash programming Symbol Description nWRITE Number of times a 32-bit word can be written before erase Min. nENDURANCE Erase cycles per page tWRITE Time to write one 32-bit word tERASEPAGE Time to erase one page tERASEALL Time to erase all flash Typ. Max. Units 2 10000 µs 412 ms 2 85 169 tERASEPAGEPARTIAL,acc Accuracy of the partial page erase duration. Total 2 ms 1.052 execution time for one partial page erase is defined as ERASEPAGEPARTIALCFG * tERASEPAGEPARTIAL,acc. 4.4 FICR — Factory information configuration registers Factory information configuration registers (FICR) are pre-programmed in factory and cannot be erased by the user. These registers contain chip-specific information and configuration. 4.4.1 Registers Base address Peripheral Instance Description Configuration 0x10000000 FICR FICR Factory information configuration Table 7: Instances Register Offset Description CODEPAGESIZE 0x010 Code memory page size CODESIZE 0x014 Code memory size DEVICEID[0] 0x060 Device identifier DEVICEID[1] 0x064 Device identifier ER[0] 0x080 Encryption root, word 0 ER[1] 0x084 Encryption root, word 1 ER[2] 0x088 Encryption root, word 2 ER[3] 0x08C Encryption root, word 3 IR[0] 0x090 Identity root, word 0 IR[1] 0x094 Identity root, word 1 IR[2] 0x098 Identity root, word 2 IR[3] 0x09C Identity root, word 3 DEVICEADDRTYPE 0x0A0 Device address type DEVICEADDR[0] 0x0A4 Device address 0 DEVICEADDR[1] 0x0A8 Device address 1 INFO.PART 0x100 Part code INFO.VARIANT 0x104 Part variant, hardware version and production configuration INFO.PACKAGE 0x108 Package option INFO.RAM 0x10C RAM variant INFO.FLASH 0x110 Flash variant INFO.UNUSED8[0] 0x114 2 Reserved HFXO is used here 4454_140 v1.0 24 Core components Register Offset Description INFO.UNUSED8[1] 0x118 INFO.UNUSED8[2] 0x11C TEMP.A0 0x404 Slope definition A0 TEMP.A1 0x408 Slope definition A1 TEMP.A2 0x40C Slope definition A2 TEMP.A3 0x410 Slope definition A3 TEMP.A4 0x414 Slope definition A4 TEMP.A5 0x418 Slope definition A5 TEMP.B0 0x41C Y-intercept B0 TEMP.B1 0x420 Y-intercept B1 TEMP.B2 0x424 Y-intercept B2 TEMP.B3 0x428 Y-intercept B3 TEMP.B4 0x42C Y-intercept B4 TEMP.B5 0x430 Y-intercept B5 TEMP.T0 0x434 Segment end T0 TEMP.T1 0x438 Segment end T1 TEMP.T2 0x43C Segment end T2 TEMP.T3 0x440 Segment end T3 TEMP.T4 0x444 Segment end T4 Reserved Reserved Table 8: Register overview 4.4.1.1 CODEPAGESIZE Address offset: 0x010 Code memory page size Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00001000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CODEPAGESIZE Code memory page size 4.4.1.2 CODESIZE Address offset: 0x014 Code memory size Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000030 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 Value ID Value Description CODESIZE Code memory size in number of pages Total code space is: CODEPAGESIZE * CODESIZE 4.4.1.3 DEVICEID[n] (n=0..1) Address offset: 0x060 + (n × 0x4) Device identifier 4454_140 v1.0 25 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description DEVICEID 64 bit unique device identifier DEVICEID[0] contains the least significant bits of the device identifier. DEVICEID[1] contains the most significant bits of the device identifier. 4.4.1.4 ER[n] (n=0..3) Address offset: 0x080 + (n × 0x4) Encryption root, word n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description ER Encryption root, word n 4.4.1.5 IR[n] (n=0..3) Address offset: 0x090 + (n × 0x4) Identity root, word n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description IR Identity root, word n 4.4.1.6 DEVICEADDRTYPE Address offset: 0x0A0 Device address type Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0xFFFFFFFF ID Access Field A R 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description DEVICEADDRTYPE Device address type Public 0 Public address Random 1 Random address 4.4.1.7 DEVICEADDR[n] (n=0..1) Address offset: 0x0A4 + (n × 0x4) Device address n 4454_140 v1.0 26 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description DEVICEADDR 48 bit device address DEVICEADDR[0] contains the least significant bits of the device address. DEVICEADDR[1] contains the most significant bits of the device address. Only bits [15:0] of DEVICEADDR[1] are used. 4.4.1.8 INFO.PART Address offset: 0x100 Part code Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00052811 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 1 0 1 0 0 0 0 0 0 1 0 0 0 1 Value ID Value Description N52810 0x52810 nRF52810 N52811 0x52811 nRF52811 Unspecified 0xFFFFFFFF Unspecified PART Part code 4.4.1.9 INFO.VARIANT Address offset: 0x104 Part variant, hardware version and production configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description VARIANT Part variant, hardware version and production configuration, encoded as ASCII AAAA 0x41414141 AAAA AAA0 0x41414130 AAA0 AABA 0x41414241 AABA AABB 0x41414242 AABB AAB0 0x41414230 AAB0 AACA 0x41414341 AACA AACB 0x41414342 AACB AAC0 0x41414330 AAC0 Unspecified 0xFFFFFFFF Unspecified 4.4.1.10 INFO.PACKAGE Address offset: 0x108 Package option 4454_140 v1.0 27 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A R Value ID Value Description QF 0x2000 QFxx - 48-pin QFN QC 0x2003 QCxx - 32-pin QFN CA 0x2004 CAxx - WLCSP Unspecified 0xFFFFFFFF Unspecified PACKAGE Package option 4.4.1.11 INFO.RAM Address offset: 0x10C RAM variant Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000018 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 Value ID Value Description K24 0x18 24 kByte RAM Unspecified 0xFFFFFFFF Unspecified RAM RAM variant 4.4.1.12 INFO.FLASH Address offset: 0x110 Flash variant Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x000000C0 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 0 0 0 0 Value ID Value Description K192 0xC0 192 kByte flash Unspecified 0xFFFFFFFF Unspecified FLASH Flash variant 4.4.1.13 TEMP.A0 Address offset: 0x404 Slope definition A0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0x00000320 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 1 0 0 0 0 0 Value ID Value Description A A (slope definition) register 4.4.1.14 TEMP.A1 Address offset: 0x408 Slope definition A1 4454_140 v1.0 28 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0x00000343 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 1 0 0 0 0 1 1 Value ID Value Description A A (slope definition) register 4.4.1.15 TEMP.A2 Address offset: 0x40C Slope definition A2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0x0000035D ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 1 0 1 1 1 0 1 Value ID Value Description A A (slope definition) register 4.4.1.16 TEMP.A3 Address offset: 0x410 Slope definition A3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0x00000400 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 Value ID Value Description A A (slope definition) register 4.4.1.17 TEMP.A4 Address offset: 0x414 Slope definition A4 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0x00000452 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 1 0 1 0 0 1 0 Value ID Value Description A A (slope definition) register 4.4.1.18 TEMP.A5 Address offset: 0x418 Slope definition A5 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A Reset 0x0000037B ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 1 1 1 1 0 1 1 Value ID Value Description A 4454_140 v1.0 A (slope definition) register 29 Core components 4.4.1.19 TEMP.B0 Address offset: 0x41C Y-intercept B0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0x00003FCC ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 1 1 0 0 Value ID Value Description B B (y-intercept) 4.4.1.20 TEMP.B1 Address offset: 0x420 Y-intercept B1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0x00003F98 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 0 0 1 1 0 0 0 Value ID Value Description B B (y-intercept) 4.4.1.21 TEMP.B2 Address offset: 0x424 Y-intercept B2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0x00003F98 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 0 0 1 1 0 0 0 Value ID Value Description B B (y-intercept) 4.4.1.22 TEMP.B3 Address offset: 0x428 Y-intercept B3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0x00000012 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 0 Value ID Value Description B B (y-intercept) 4.4.1.23 TEMP.B4 Address offset: 0x42C Y-intercept B4 4454_140 v1.0 30 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0x0000004D ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 1 0 1 Value ID Value Description B B (y-intercept) 4.4.1.24 TEMP.B5 Address offset: 0x430 Y-intercept B5 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A Reset 0x00003E10 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 0 0 0 0 1 0 0 0 0 Value ID Value Description B B (y-intercept) 4.4.1.25 TEMP.T0 Address offset: 0x434 Segment end T0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x000000E2 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 0 0 0 1 0 Value ID Value Description T T (segment end) register 4.4.1.26 TEMP.T1 Address offset: 0x438 Segment end T1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description T T (segment end) register 4.4.1.27 TEMP.T2 Address offset: 0x43C Segment end T2 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000014 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 Value ID Value Description T 4454_140 v1.0 T (segment end) register 31 Core components 4.4.1.28 TEMP.T3 Address offset: 0x440 Segment end T3 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000019 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 0 0 1 Value ID Value Description T T (segment end) register 4.4.1.29 TEMP.T4 Address offset: 0x444 Segment end T4 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000050 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 Value ID Value Description T T (segment end) register 4.5 UICR — User information configuration registers The user information configuration registers (UICRs) are non-volatile memory (NVM) registers for configuring user-specific settings. For information on writing UICR registers, see the NVMC — Non-volatile memory controller on page 19 and Memory on page 16 chapters. 4.5.1 Registers Base address Peripheral Instance Description 0x10001000 UICR UICR User information configuration Configuration Table 9: Instances Register Offset UNUSED0 0x000 Reserved UNUSED1 0x004 Reserved UNUSED2 0x008 Reserved UNUSED3 0x010 NRFFW[0] 0x014 Reserved for Nordic firmware design NRFFW[1] 0x018 Reserved for Nordic firmware design NRFFW[2] 0x01C Reserved for Nordic firmware design NRFFW[3] 0x020 Reserved for Nordic firmware design NRFFW[4] 0x024 Reserved for Nordic firmware design NRFFW[5] 0x028 Reserved for Nordic firmware design NRFFW[6] 0x02C Reserved for Nordic firmware design NRFFW[7] 0x030 Reserved for Nordic firmware design 4454_140 v1.0 Description Reserved 32 Core components Register Offset Description NRFFW[8] 0x034 Reserved for Nordic firmware design NRFFW[9] 0x038 Reserved for Nordic firmware design NRFFW[10] 0x03C Reserved for Nordic firmware design NRFFW[11] 0x040 Reserved for Nordic firmware design NRFFW[12] 0x044 Reserved for Nordic firmware design NRFHW[0] 0x050 Reserved for Nordic hardware design NRFHW[1] 0x054 Reserved for Nordic hardware design NRFHW[2] 0x058 Reserved for Nordic hardware design NRFHW[3] 0x05C Reserved for Nordic hardware design NRFHW[4] 0x060 Reserved for Nordic hardware design NRFHW[5] 0x064 Reserved for Nordic hardware design NRFHW[6] 0x068 Reserved for Nordic hardware design NRFHW[7] 0x06C Reserved for Nordic hardware design NRFHW[8] 0x070 Reserved for Nordic hardware design NRFHW[9] 0x074 Reserved for Nordic hardware design NRFHW[10] 0x078 Reserved for Nordic hardware design NRFHW[11] 0x07C Reserved for Nordic hardware design CUSTOMER[0] 0x080 Reserved for customer CUSTOMER[1] 0x084 Reserved for customer CUSTOMER[2] 0x088 Reserved for customer CUSTOMER[3] 0x08C Reserved for customer CUSTOMER[4] 0x090 Reserved for customer CUSTOMER[5] 0x094 Reserved for customer CUSTOMER[6] 0x098 Reserved for customer CUSTOMER[7] 0x09C Reserved for customer CUSTOMER[8] 0x0A0 Reserved for customer CUSTOMER[9] 0x0A4 Reserved for customer CUSTOMER[10] 0x0A8 Reserved for customer CUSTOMER[11] 0x0AC Reserved for customer CUSTOMER[12] 0x0B0 Reserved for customer CUSTOMER[13] 0x0B4 Reserved for customer CUSTOMER[14] 0x0B8 Reserved for customer CUSTOMER[15] 0x0BC Reserved for customer CUSTOMER[16] 0x0C0 Reserved for customer CUSTOMER[17] 0x0C4 Reserved for customer CUSTOMER[18] 0x0C8 Reserved for customer CUSTOMER[19] 0x0CC Reserved for customer CUSTOMER[20] 0x0D0 Reserved for customer CUSTOMER[21] 0x0D4 Reserved for customer CUSTOMER[22] 0x0D8 Reserved for customer CUSTOMER[23] 0x0DC Reserved for customer CUSTOMER[24] 0x0E0 Reserved for customer CUSTOMER[25] 0x0E4 Reserved for customer CUSTOMER[26] 0x0E8 Reserved for customer CUSTOMER[27] 0x0EC Reserved for customer CUSTOMER[28] 0x0F0 Reserved for customer CUSTOMER[29] 0x0F4 Reserved for customer CUSTOMER[30] 0x0F8 Reserved for customer CUSTOMER[31] 0x0FC Reserved for customer PSELRESET[0] 0x200 Mapping of the nRESET function (see POWER chapter for details) PSELRESET[1] 0x204 Mapping of the nRESET function (see POWER chapter for details) APPROTECT 0x208 Access port protection Table 10: Register overview 4454_140 v1.0 33 Core components 4.5.1.1 NRFFW[n] (n=0..12) Address offset: 0x014 + (n × 0x4) Reserved for Nordic firmware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A RW NRFFW 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description Reserved for Nordic firmware design 4.5.1.2 NRFHW[n] (n=0..11) Address offset: 0x050 + (n × 0x4) Reserved for Nordic hardware design Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A RW NRFHW Value ID Value Description Reserved for Nordic hardware design 4.5.1.3 CUSTOMER[n] (n=0..31) Address offset: 0x080 + (n × 0x4) Reserved for customer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0xFFFFFFFF ID Access Field A RW CUSTOMER 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description Reserved for customer 4.5.1.4 PSELRESET[n] (n=0..1) Address offset: 0x200 + (n × 0x4) Mapping of the nRESET function (see POWER chapter for details) All PSELRESET registers have to contain the same value for a pin mapping to be valid. If values are not the same, there will be no nRESET function exposed on a GPIO. As a result, the device will always start independently of the levels present on any of the GPIOs. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF ID Access Field A RW PIN C RW CONNECT 4454_140 v1.0 A A A A A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description 21 GPIO pin number onto which nRESET is exposed Connection Disconnected 1 Disconnect Connected 0 Connect 34 Core components 4.5.1.5 APPROTECT Address offset: 0x208 Access port protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0xFFFFFFFF ID Access Field A RW PALL 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description Enable or disable access port protection. See Debug on page 38 for more information. Disabled 0xFF Disable Enabled 0x00 Enable 4.6 EasyDMA EasyDMA is a module implemented by some peripherals to gain direct access to Data RAM. EasyDMA is an AHB bus master similar to CPU and is connected to the AHB multilayer interconnect for direct access to Data RAM. EasyDMA is not able to access flash. A peripheral can implement multiple EasyDMA instances to provide dedicated channels. For example, for reading and writing of data between the peripheral and RAM. This concept is illustrated in EasyDMA example on page 35. RAM AHB multilayer Peripheral READER RAM RAM AHB WRITER AHB Figure 4: EasyDMA example 4454_140 v1.0 EasyDMA 35 EasyDMA Peripheral core Core components An EasyDMA channel is implemented in the following way, but some variations may occur: READERBUFFER_SIZE 5 WRITERBUFFER_SIZE 6 uint8_t readerBuffer[READERBUFFER_SIZE] __at__ 0x20000000; uint8_t writerBuffer[WRITERBUFFER_SIZE] __at__ 0x20000005; // Configuring the READER channel MYPERIPHERAL->READER.MAXCNT = READERBUFFER_SIZE; MYPERIPHERAL->READER.PTR = &readerBuffer; // Configure the WRITER channel MYPERIPHERAL->WRITER.MAXCNT = WRITEERBUFFER_SIZE; MYPERIPHERAL->WRITER.PTR = &writerBuffer; This example shows a peripheral called MYPERIPHERAL that implements two EasyDMA channels - one for reading called READER, and one for writing called WRITER. When the peripheral is started, it is assumed that the peripheral will: • Read 5 bytes from the readerBuffer located in RAM at address 0x20000000. • Process the data. • Write no more than 6 bytes back to the writerBuffer located in RAM at address 0x20000005. The memory layout of these buffers is illustrated in EasyDMA memory layout on page 36. 0x20000000 readerBuffer[0] readerBuffer[1] readerBuffer[2] readerBuffer[3] 0x20000004 readerBuffer[4] writerBuffer[0] writerBuffer[1] writerBuffer[2] 0x20000008 writerBuffer[3] writerBuffer[4] writerBuffer[5] Figure 5: EasyDMA memory layout The WRITER.MAXCNT register should not be specified larger than the actual size of the buffer (writerBuffer). Otherwise, the channel would overflow the writerBuffer. Once an EasyDMA transfer is completed, the AMOUNT register can be read by the CPU to see how many bytes were transferred. For example, CPU can read MYPERIPHERAL->WRITER.AMOUNT register to see how many bytes WRITER wrote to RAM. Note that the PTR register of a READER or WRITER must point to a valid memory region before use. The reset value of a PTR register is not guaranteed to point to valid memory. See Memory on page 16 for more information about the different memory regions and EasyDMA connectivity. 4.6.1 EasyDMA error handling Some errors may occur during DMA handling. If READER.PTR or WRITER.PTR is not pointing to a valid memory region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 16 for more information about the different memory regions. 4454_140 v1.0 36 Core components If several AHB bus masters try to access the same AHB slave at the same time, AHB bus congestion might occur. An EasyDMA channel is an AHB master. Depending on the peripheral, the peripheral may either stall and wait for access to be granted, or lose data. 4.6.2 EasyDMA array list EasyDMA is able to operate in Array List mode. The Array List mode is implemented in channels where the LIST register is available. The array list does not provide a mechanism to explicitly specify where the next item in the list is located. Instead, it assumes that the list is organized as a linear array where items are located one after the other in RAM. The EasyDMA Array List can be implemented by using the data structure ArrayList_type as illustrated in the code example below using a READER EasyDMA channel as an example: #define BUFFER_SIZE 4 typedef struct ArrayList { uint8_t buffer[BUFFER_SIZE]; } ArrayList_type; ArrayList_type ReaderList[3] __at__ 0x20000000; MYPERIPHERAL->READER.MAXCNT = BUFFER_SIZE; MYPERIPHERAL->READER.PTR = &ReaderList; MYPERIPHERAL->READER.LIST = MYPERIPHERAL_READER_LIST_ArrayList; The data structure only includes a buffer with size equal to the size of READER.MAXCNT register. EasyDMA uses the READER.MAXCNT register to determine when the buffer is full. READER.PTR = &ReaderList 0x20000000 : ReaderList[0] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000004 : ReaderList[1] buffer[0] buffer[1] buffer[2] buffer[3] 0x20000008 : ReaderList[2] buffer[0] buffer[1] buffer[2] buffer[3] Figure 6: EasyDMA array list 4.7 AHB multilayer AHB multilayer enables parallel access paths between multiple masters and slaves in a system. Access is resolved using priorities. Each bus master is connected to the slave devices using an interconnection matrix. The bus masters are assigned priorities. Priorities are used to resolve access when two (or more) bus masters request access to the same slave device. The following applies: 4454_140 v1.0 37 Core components • If two (or more) bus masters request access to the same slave device, the master with the highest priority is granted the access first. • Bus masters with lower priority are stalled until the higher priority master has completed its transaction. • If the higher priority master pauses at any point during its transaction, the lower priority master in queue is temporarily granted access to the slave device until the higher priority master resumes its activity. • Bus masters that have the same priority are mutually exclusive, thus cannot be used concurrently. Below is a list of bus masters in the system and their priorities. Bus master name Description CPU SPIM0/SPIS0 Same priority and mutually exclusive RADIO CCM/ECB/AAR Same priority and mutually exclusive SAADC UARTE0 TWIM0/TWIS0 Same priority and mutually exclusive PDM PWM Table 11: AHB bus masters (listed in priority order, highest to lowest) Defined bus masters are the CPU and the peripherals with implemented EasyDMA, and the available slaves are RAM AHB slaves. How the bus masters and slaves are connected using the interconnection matrix is illustrated in Memory on page 16. 4.8 Debug Debug system offers a flexible and powerful mechanism for non-intrusive debugging. DAP SWDCLK External debugger CTRL-AP NVMC SW-DP APPROTECT.PALL SWDIO UICR DAP bus interconnect AHB AHB-AP CxxxPWRUPREQ CxxxPWRUPRACK POWER Power CPU ARM Cortex-M4 APB/AHB Figure 7: Overview The main features of the debug system are: • Two-pin serial wire debug (SWD) interface • Flash patch and breakpoint (FPB) unit supports: 4454_140 v1.0 RAM & flash 38 Peripherals Core components • Two literal comparators • Six instruction comparators 4.8.1 DAP - Debug access port An external debugger can access the device via the DAP. The debug access port (DAP) implements a standard ARM® CoreSight™ serial wire debug port (SW-DP), which implements the serial wire debug protocol (SWD). SWD is a two-pin serial interface, see SWDCLK and SWDIO in Overview on page 38. In addition to the default access port in CPU (AHB-AP), the DAP includes a custom control access port (CTRL-AP). The CTRL-AP is described in more detail in CTRL-AP - Control access port on page 39. Note: • The SWDIO line has an internal pull-up resistor. • The SWDCLK line has an internal pull-down resistor. 4.8.2 CTRL-AP - Control access port The control access port (CTRL-AP) is a custom access port that enables control of the device when other access ports in the DAP are disabled by the access port protection. Access port protection blocks the debugger from read and write access to all CPU registers and memorymapped addresses. See the UICR register APPROTECT on page 35 for more information on enabling access port protection. Control access port has the following features: • Soft reset, see Reset on page 52 for more information • Disabling of access port protection, which is the reason why CTRL-AP allows control of the device even when all other access ports in the DAP are disabled by the access port protection Access port protection is disabled by issuing an ERASEALL command via CTRL-AP. This command will erase the flash, UICR, and RAM. 4.8.2.1 Registers Register Offset Description RESET 0x000 Soft reset triggered through CTRL-AP ERASEALL 0x004 Erase all ERASEALLSTATUS 0x008 Status register for the ERASEALL operation APPROTECTSTATUS 0x00C Status register for access port protection IDR 0x0FC CTRL-AP identification register, IDR Table 12: Register overview 4.8.2.1.1 RESET Address offset: 0x000 Soft reset triggered through CTRL-AP 4454_140 v1.0 39 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW RESET 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Soft reset triggered through CTRL-AP. See Reset behavior in POWER chapter for more details. NoReset 0 Reset is not active Reset 1 Reset is active. Device is held in reset. 4.8.2.1.2 ERASEALL Address offset: 0x004 Erase all Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NoOperation 0 No operation Erase 1 Erase all flash and RAM ERASEALL Erase all flash and RAM 4.8.2.1.3 ERASEALLSTATUS Address offset: 0x008 Status register for the ERASEALL operation Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Ready 0 ERASEALL is ready Busy 1 ERASEALL is busy (on-going) ERASEALLSTATUS Status register for the ERASEALL operation 4.8.2.1.4 APPROTECTSTATUS Address offset: 0x00C Status register for access port protection Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description APPROTECTSTATUS Status register for access port protection Enabled 0 Access port protection enabled Disabled 1 Access port protection not enabled 4.8.2.1.5 IDR Address offset: 0x0FC CTRL-AP identification register, IDR 4454_140 v1.0 40 Core components Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E E E E D D D D C C C C C C C B B B B Reset 0x02880000 0 0 0 0 0 0 1 0 1 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A R APID Value ID Value AP identification B R CLASS Access port (AP) class A A A A A A A A Description NotDefined 0x0 No defined class MEMAP 0x8 Memory access port C R JEP106ID JEDEC JEP106 identity code D R JEP106CONT JEDEC JEP106 continuation code E R REVISION Revision 4.8.2.2 Electrical specification 4.8.2.2.1 Control access port Symbol Description Rpull Internal SWDIO and SWDCLK pull up/down resistance fSWDCLK SWDCLK frequency Min. Typ. Max. 13 0.125 Units kΩ 8 MHz 4.8.3 Debug interface mode Before an external debugger can access either CPU's access port (AHB-AP) or the control access port (CTRL-AP), the debugger must first request the device to power up via CxxxPWRUPREQ in the SWJ-DP. If the device is in System OFF when power is requested via CxxxPWRUPREQ, the system will wake up and the DIF flag in RESETREAS on page 57 will be set. The device is in the debug interface mode as long as the debugger is requesting power via CxxxPWRUPREQ. Once the debugger stops requesting power via CxxxPWRUPREQ, the device is back in normal mode. Some peripherals behave differently in Debug Interface mode compared to normal mode. These differences are described in more detail in the chapters of the peripherals that are affected. When a debug session is over, the external debugger must make sure to put the device back into normal mode since the overall power consumption is higher in debug interface mode than in normal mode. For details on how to use the debug capabilities, read the debug documentation of your IDE. 4.8.4 Real-time debug The nRF52811 supports real-time debugging. Real-time debugging allows interrupts to execute to completion in real time when breakpoints are set in thread mode or lower priority interrupts. This enables developers to set breakpoints and single-step through the code without the risk of real-time event-driven threads running at higher priority failing. For example, this enables the device to continue to service the high-priority interrupts of an external controller or sensor without failure or loss of state synchronization while the developer steps through code in a low-priority thread. 4454_140 v1.0 41 5 Power and clock management 5.1 Power management unit (PMU) Power and clock management in nRF52811 is designed to automatically ensure maximum power efficiency. The core of the power and clock management system is the power management unit (PMU) illustrated in Power management unit on page 42. MCU CPU External power sources Internal voltage regulators PMU Memory External crystals Internal oscillators Peripheral Figure 8: Power management unit The PMU automatically detects which power and clock resources are required by the different components in the system at any given time. It will then start/stop and choose operation modes in supply regulators and clock sources, without user interaction, to achieve the lowest power consumption possible. 5.2 Current consumption As the system is being constantly tuned by the Power management unit (PMU) on page 42, estimating the current consumption of an application can be challenging if the designer is not able to perform measurements directly on the hardware. To facilitate the estimation process, a set of current consumption scenarios are provided to show the typical current drawn from the VDD supply. Each scenario specifies a set of operations and conditions applying to the given scenario. Current consumption scenarios, common conditions on page 43 shows a set of common conditions used in all scenarios, unless otherwise stated in the description of a given scenario. All scenarios are listed in Electrical specification on page 43. 4454_140 v1.0 42 Power and clock management Condition Value VDD 3V Temperature 25°C CPU WFI (wait for interrupt)/WFE (wait for event) sleep Peripherals All idle Clock Not running Regulator LDO RAM Full 24 kB retention Compiler3 GCC v4.9.3 20150529 (arm-none-eabi-gcc). Compiler flags: -O0 -falign-functions=16 -fno-strictaliasing -mcpu=cortex-m4 -mfloat-abi=soft -msoftfloat -mthumb. 32 MHz crystal4 SMD 2520, 32 MHz, 10 pF +/- 10 ppm Table 13: Current consumption scenarios, common conditions 5.2.1 Electrical specification 5.2.1.1 CPU running Symbol Description ICPU0 CPU running CoreMark @64 MHz from flash, Clock = HFXO, Min. Typ. Max. Units 2.2 mA Regulator = DCDC ICPU1 CPU running CoreMark @64 MHz from flash, Clock = HFXO 4.2 mA ICPU2 CPU running CoreMark @64 MHz from RAM, Clock = HFXO, 2.1 mA Regulator = DCDC ICPU3 CPU running CoreMark @64 MHz from RAM, Clock = HFXO 4 mA ICPU4 CPU running CoreMark @64 MHz from flash, Clock = HFINT, 2 mA Regulator = DCDC 3 4 Applying only when CPU is running Applying only when HFXO is running 4454_140 v1.0 43 Power and clock management 5.2.1.2 Radio transmitting/receiving Symbol Description IRADIO_TX0 Radio transmitting @ 4 dBm output power, 1 Mbps Min. Typ. Max. Units 8 mA 5.8 mA 3.4 mA 6.1 mA 10.5 mA 5.1 mA 10.8 mA Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC IRADIO_TX1 Radio transmitting @ 0 dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC IRADIO_TX2 Radio transmitting @ -40 dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC IRADIO_RX0 Radio receiving @ 1 Mbps Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC IRADIO_TX3 Radio transmitting @ 0 dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO IRADIO_TX4 Radio transmitting @ -40 dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO IRADIO_RX1 Radio receiving @ 1 Mbps Bluetooth low energy mode, Clock = HFXO 15 14 Current consumption [mA] 13 12 11 10 9 8 7 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 9: Radio transmitting @ 4 dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC (typical values) 4454_140 v1.0 44 3.6 Power and clock management 10 9.5 9 Current consumption [mA] 8.5 8 7.5 7 6.5 6 5.5 5 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 3.6 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 10: Radio transmitting @ 0 dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC (typical values) 5.2.1.3 Sleep Symbol Description ION_RAMOFF_EVENT System ON, No RAM retention, Wake on any event Min. Typ. 0.6 Max. Units µA ION_RAMON_EVENT System ON, Full 24 kB RAM retention, Wake on any event 0.8 µA ION_RAMON_POF System ON, Full 24 kB RAM retention, Wake on any event, 0.8 µA 3.3 µA 0.8 µA 1.5 µA 1.4 µA 1.1 µA 1.0 µA Power fail comparator enabled ION_RAMON_GPIOTE System ON, Full 24 kB RAM retention, Wake on GPIOTE input (Event mode) ION_RAMON_GPIOTEPORTSystem ON, Full 24 kB RAM retention, Wake on GPIOTE PORT event ION_RAMON_RTC System ON, Full 24 kB RAM retention, Wake on RTC (running from LFRC clock) ION_RAMOFF_RTC System ON, No RAM retention, Wake on RTC (running from LFRC clock) ION_RAMON_RTC_LFXO System ON, Full 24 kB RAM retention, Wake on RTC (running from LFXO clock) ION_RAMOFF_RTC_LFXO System ON, No RAM retention, Wake on RTC (running from LFXO clock) IOFF_RAMOFF_RESET System OFF, No RAM retention, Wake on reset 0.3 µA IOFF_RAMON_RESET System OFF, Full 24 kB RAM retention, Wake on reset 0.5 µA 4454_140 v1.0 45 Power and clock management 2.5 Current consumption [µA] 2 1.5 1 0.5 0 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 3.6 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 11: System OFF, No RAM retention, Wake on reset (typical values) 16 14 Current consumption [µA] 12 10 8 6 4 2 0 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 3.6 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 12: System ON, Full 24 kB RAM retention, Wake on any event (typical values) 4454_140 v1.0 46 Power and clock management 5.2.1.4 Compounded Symbol Description IS0 CPU running CoreMark from flash, Radio transmitting @ 0 Min. Typ. Max. Units 7.4 mA 7.6 mA 13.8 mA 14.2 mA dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC IS1 CPU running CoreMark from flash, Radio receiving @ 1 Mbps Bluetooth low energy mode, Clock = HFXO, Regulator = DCDC IS2 CPU running CoreMark from flash, Radio transmitting @ 0 dBm output power, 1 Mbps Bluetooth low energy mode, Clock = HFXO IS3 CPU running CoreMark from flash, Radio receiving @ 1 Mbps Bluetooth low energy mode, Clock = HFXO 5.2.1.5 TIMER running Symbol Description ITIMER0 One TIMER instance running @ 1 MHz, Clock = HFINT Min. Typ. 432 Max. Units µA ITIMER1 Two TIMER instances running @ 1 MHz, Clock = HFINT 432 µA ITIMER2 One TIMER instance running @ 1 MHz, Clock = HFXO 730 µA ITIMER3 One TIMER instance running @ 16 MHz, Clock = HFINT 495 µA ITIMER4 One TIMER instance running @ 16 MHz, Clock = HFXO 792 µA 5.2.1.6 RNG active Symbol Description IRNG0 RNG running Min. Typ. Max. 539 Units µA 5.2.1.7 TEMP active Symbol Description ITEMP0 TEMP started Min. Typ. Max. 998 Units µA 5.2.1.8 SAADC active Symbol Description ISAADC,RUN SAADC sampling @ 16 ksps, Acquisition time = 20 µs, Clock = Min. Typ. Max. 1.1 Units mA HFXO, Regulator = DCDC 5.2.1.9 COMP active Symbol Description ICOMP,LP COMP enabled, low power mode 17.2 µA ICOMP,NORM COMP enabled, normal mode 21 µA ICOMP,HS COMP enabled, high-speed mode 28.7 µA 4454_140 v1.0 Min. 47 Typ. Max. Units Power and clock management 5.2.1.10 WDT active Symbol Description IWDT,STARTED WDT started Min. Typ. Max. 1.3 Units µA 5.3 POWER — Power supply This device has the following power supply features: • • • • • • On-chip LDO and DC/DC regulators Global System ON/OFF modes with individual RAM section power control Analog or digital pin wakeup from System OFF Supervisor HW to manage power on reset, brownout, and power fail Auto-controlled refresh modes for LDO and DC/DC regulators to maximize efficiency Automatic switching between LDO and DC/DC regulator based on load to maximize efficiency Note: Two additional external passive components are required to use the DC/DC regulator. 5.3.1 Regulators The following internal power regulator alternatives are supported: • Internal LDO regulator • Internal DC/DC regulator The LDO is the default regulator. The DC/DC regulator can be used as an alternative to the LDO regulator and is enabled through the DCDCEN on page 59 register. Using the DC/DC regulator will reduce current consumption compared to when using the LDO regulator, but the DC/DC regulator requires an external LC filter to be connected, as shown in DC/DC regulator setup on page 49. POWER DCDCEN REG Supply LDO 1.3V System power VDD DC/DC DCC DEC4 Figure 13: LDO regulator setup 4454_140 v1.0 48 GND Power and clock management POWER DCDCEN REG Supply LDO 1.3V System power VDD DC/DC DCC DEC4 GND Figure 14: DC/DC regulator setup 5.3.2 System OFF mode System OFF is the deepest power saving mode the system can enter. In this mode, the system’s core functionality is powered down and all ongoing tasks are terminated. The device can be put into System OFF mode using the register SYSTEMOFF on page 57. When in System OFF mode, the device can be woken up through one of the following signals: 1. The DETECT signal, optionally generated by the GPIO peripheral 2. A reset When the system wakes up from System OFF mode, it gets reset. For more details, see Reset behavior on page 53. One or more RAM sections can be retained in System OFF mode, depending on the settings in the RAM[n].POWER registers. RAM[n].POWER are retained registers, see Reset behavior. Note that these registers are usually overwritten by the startup code provided with the nRF application examples. Before entering System OFF mode, the user must make sure that all on-going EasyDMA transactions have been completed. This is usually accomplished by making sure that the EasyDMA enabled peripheral is not active when entering System OFF. 5.3.2.1 Emulated System OFF mode If the device is in debug interface mode, System OFF will be emulated to secure that all required resources needed for debugging are available during System OFF. See Debug on page 38 for more information. Required resources needed for debugging include the following key components: Debug on page 38, CLOCK — Clock control on page 61, POWER — Power supply on page 48, NVMC — Non-volatile memory controller on page 19, CPU, Flash, and RAM. Since the CPU is kept on in an emulated System OFF mode, it is recommended to add an infinite loop directly after entering System OFF, to prevent the CPU from executing code that normally should not be executed. 4454_140 v1.0 49 Power and clock management 5.3.3 System ON mode System ON is the default state after power-on reset. In System ON, all functional blocks such as the CPU or peripherals can be in IDLE or RUN mode, depending on the configuration set by the software and the state of the application executing. Register RESETREAS on page 57 provides information about the source causing the wakeup or reset. The system can switch the appropriate internal power sources on and off, depending on how much power is needed at any given time. The power requirement of a peripheral is directly related to its activity level, and the activity level of a peripheral is usually raised and lowered when specific tasks are triggered or events are generated. 5.3.3.1 Sub power modes In System ON mode, when both the CPU and all the peripherals are in IDLE mode, the system can reside in one of the two sub power modes. The sub power modes are: • Constant Latency • Low-power In Constant Latency mode, the CPU wakeup latency and the PPI task response are constant and kept at a minimum. This is secured by forcing a set of basic resources to be turned on while in sleep. Having a constant and predictable latency is at the cost of having increased power consumption. The Constant Latency mode is selected by triggering the CONSTLAT task. In Low-power mode, the automatic power management system described in System ON mode on page 50 ensures that the most efficient supply option is chosen to save most power. Having the lowest power possible is at the cost of having a varying CPU wakeup latency and PPI task response. The Lowpower mode is selected by triggering the LOWPWR task. When the system enters System ON mode, it is by default in Low-power sub power mode. 5.3.4 Power supply supervisor The power supply supervisor initializes the system at power-on and provides an early warning of impending power failure. In addition, the power supply supervisor puts the system in a reset state if the supply voltage is too low for safe operation (brownout). The power supply supervisor is illustrated in Power supply supervisor on page 51. 4454_140 v1.0 50 Power and clock management VDD C Power on reset R VBOR POFCON Brownout reset 1.7V ........... MUX POFWARN Vpof 2.8V Figure 15: Power supply supervisor 5.3.4.1 Power-fail comparator The power-fail comparator (POF) can provide the CPU with an early warning of impending power failure. It will not reset the system, but give the CPU time to prepare for an orderly power-down. The comparator features a hysteresis of VHYST, as illustrated in Power-fail comparator (BOR = Brownout reset) on page 51. The threshold VPOF is set in register POFCON on page 58. If the POF is enabled and the supply voltage falls below VPOF, the POFWARN event will be generated. This event will also be generated if the supply voltage is already below VPOF at the time the POF is enabled, or if VPOF is reconfigured to a level above the supply voltage. If power-fail warning is enabled and the supply voltage is below VPOF the power-fail comparator will prevent the NVMC from performing write operations to the NVM. See NVMC — Non-volatile memory controller on page 19 for more information about the NVMC. VDD VPOF+VHYST VPOF 1.7V POFWARN POFWARN MCU t BOR Figure 16: Power-fail comparator (BOR = Brownout reset) To save power, the power-fail comparator is not active in System OFF or in System ON when HFCLK is not running. 4454_140 v1.0 51 Power and clock management 5.3.5 RAM power control The RAM power control registers are used for configuring the following: • The RAM sections to be retained during System OFF • The RAM sections to be retained and accessible during System ON In System OFF, retention of a RAM section is configured in the RETENTION field of the corresponding RAM[n] register. In System ON, retention and accessibility for a RAM section is configured in the RETENTION and POWER fields of the corresponding RAM[n] register. The following table summarizes the behavior of these registers. Configuration RAM section status System on/off RAM[n].POWER.POWER RAM[n].POWER.RETENTION Accessible Retained Off x Off No No Off x On No Yes On Off Off No No On Off1 On No Yes On On x Yes Yes Table 14: RAM section configuration. x = don't care. The advantage of not retaining RAM contents is that the overall current consumption is reduced. See chapter Memory on page 16 for more information on RAM sections. 5.3.6 Reset There are multiple sources that may trigger a reset. After a reset has occurred, register RESETREAS can be read to determine which source generated the reset. 5.3.6.1 Power-on reset The power-on reset generator initializes the system at power-on. The system is held in reset state until the supply has reached the minimum operating voltage and the internal voltage regulators have started. A step increase in supply voltage of 300 mV or more, with rise time of 300 ms or less, within the valid supply range, may result in a system reset. 5.3.6.2 Pin reset A pin reset is generated when the physical reset pin on the device is asserted. Pin reset is configured via the PSELRESET[n] registers. Note: Pin reset is not available on all pins. 5.3.6.3 Wakeup from System OFF mode reset The device is reset when it wakes up from System OFF mode. 1 Not useful setting. RAM section power off gives negligible reduction in current consumption when retention is on. 4454_140 v1.0 52 Power and clock management The debug access port (DAP) is not reset following a wake up from System OFF mode if the device is in Debug Interface mode. See chapter Debug on page 38 for more information. 5.3.6.4 Soft reset A soft reset is generated when the SYSRESETREQ bit of the Application Interrupt and Reset Control Register (AIRCR register) in the ARM® core is set. Refer to ARM documentation for more details. A soft reset can also be generated via the RESET on page 39 register in the CTRL-AP. 5.3.6.5 Watchdog reset A Watchdog reset is generated when the watchdog times out. See chapter WDT — Watchdog timer on page 410 for more information. 5.3.6.6 Brown-out reset The brown-out reset generator puts the system in reset state if the supply voltage drops below the brownout reset (BOR) threshold. Refer to section Power fail comparator on page 61 for more information. 5.3.7 Retained registers A retained register is a register that will retain its value in System OFF mode and through a reset, depending on reset source. See individual peripheral chapters for information of which registers are retained for the various peripherals. 5.3.8 Reset behavior Reset source Reset target CPU Peripherals GPIO Debuga SWJ-DP RAM WDT Retained RESETREAS registers CPU lockup 5 x x x Soft reset x x x Wakeup from System OFF x x Watchdog reset 8 x x Pin reset x Brownout reset x Power on reset x x6 x7 x x x x x x x x x x x x x x x x x x x x x x x x x x x mode reset Note: The RAM is never reset, but depending on reset source, RAM content may be corrupted. a 5 6 7 8 All debug components excluding SWJ-DP. See Debug on page 38 chapter for more information about the different debug components in the system. Reset from CPU lockup is disabled if the device is in debug interface mode. CPU lockup is not possible in System OFF. The Debug components will not be reset if the device is in debug interface mode. RAM is not reset on wakeup from OFF mode, but depending on settings in the RAM register parts, or the whole RAM, may not be retained after the device has entered System OFF mode. Watchdog reset is not available in System OFF. 4454_140 v1.0 53 Power and clock management 5.3.9 Registers Base address Peripheral Instance Description Configuration 0x40000000 POWER POWER Power control For 24 kB RAM variant, only RAM[0].x to RAM[2].x registers are in use. Table 15: Instances Register Offset Description TASKS_CONSTLAT 0x078 Enable Constant Latency mode TASKS_LOWPWR 0x07C Enable Low-power mode (variable latency) EVENTS_POFWARN 0x108 Power failure warning EVENTS_SLEEPENTER 0x114 CPU entered WFI/WFE sleep EVENTS_SLEEPEXIT 0x118 CPU exited WFI/WFE sleep INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt RESETREAS 0x400 Reset reason SYSTEMOFF 0x500 System OFF register POFCON 0x510 Power failure comparator configuration GPREGRET 0x51C General purpose retention register GPREGRET2 0x520 General purpose retention register DCDCEN 0x578 DC/DC enable register RAM[0].POWER 0x900 RAM0 power control register. The RAM size will vary depending on product variant, and the RAM0 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[0].POWERSET 0x904 RAM0 power control set register RAM[0].POWERCLR 0x908 RAM0 power control clear register RAM[1].POWER 0x910 RAM1 power control register. The RAM size will vary depending on product variant, and the RAM1 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[1].POWERSET 0x914 RAM1 power control set register RAM[1].POWERCLR 0x918 RAM1 power control clear register RAM[2].POWER 0x920 RAM2 power control register. The RAM size will vary depending on product variant, and the RAM2 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[2].POWERSET 0x924 RAM2 power control set register RAM[2].POWERCLR 0x928 RAM2 power control clear register RAM[3].POWER 0x930 RAM3 power control register. The RAM size will vary depending on product variant, and the RAM3 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[3].POWERSET 0x934 RAM3 power control set register RAM[3].POWERCLR 0x938 RAM3 power control clear register RAM[4].POWER 0x940 RAM4 power control register. The RAM size will vary depending on product variant, and the RAM4 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[4].POWERSET 0x944 RAM4 power control set register RAM[4].POWERCLR 0x948 RAM4 power control clear register RAM[5].POWER 0x950 RAM5 power control register. The RAM size will vary depending on product variant, and the RAM5 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[5].POWERSET 0x954 RAM5 power control set register RAM[5].POWERCLR 0x958 RAM5 power control clear register 4454_140 v1.0 54 Power and clock management Register Offset Description RAM[6].POWER 0x960 RAM6 power control register. The RAM size will vary depending on product variant, and the RAM6 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[6].POWERSET 0x964 RAM6 power control set register RAM[6].POWERCLR 0x968 RAM6 power control clear register RAM[7].POWER 0x970 RAM7 power control register. The RAM size will vary depending on product variant, and the RAM7 register will only be present if the corresponding RAM AHB slave is present on the device. RAM[7].POWERSET 0x974 RAM7 power control set register RAM[7].POWERCLR 0x978 RAM7 power control clear register Table 16: Register overview 5.3.9.1 TASKS_CONSTLAT Address offset: 0x078 Enable Constant Latency mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_CONSTLAT Enable Constant Latency mode Trigger task 5.3.9.2 TASKS_LOWPWR Address offset: 0x07C Enable Low-power mode (variable latency) Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_LOWPWR Enable Low-power mode (variable latency) Trigger task 5.3.9.3 EVENTS_POFWARN Address offset: 0x108 Power failure warning Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_POFWARN 4454_140 v1.0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Power failure warning NotGenerated 0 Event not generated Generated 1 Event generated 55 Power and clock management 5.3.9.4 EVENTS_SLEEPENTER Address offset: 0x114 CPU entered WFI/WFE sleep Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SLEEPENTER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated CPU entered WFI/WFE sleep 5.3.9.5 EVENTS_SLEEPEXIT Address offset: 0x118 CPU exited WFI/WFE sleep Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SLEEPEXIT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated CPU exited WFI/WFE sleep 5.3.9.6 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B Reset 0x00000000 ID Access Field A RW POFWARN B C Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event POFWARN RW SLEEPENTER Write '1' to enable interrupt for event SLEEPENTER RW SLEEPEXIT Write '1' to enable interrupt for event SLEEPEXIT 5.3.9.7 INTENCLR Address offset: 0x308 Disable interrupt 4454_140 v1.0 A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 56 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B Reset 0x00000000 ID Access Field A RW POFWARN B C A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event POFWARN RW SLEEPENTER Write '1' to disable interrupt for event SLEEPENTER RW SLEEPEXIT Write '1' to disable interrupt for event SLEEPEXIT 5.3.9.8 RESETREAS Address offset: 0x400 Reset reason Unless cleared, the RESETREAS register will be cumulative. A field is cleared by writing '1' to it. If none of the reset sources are flagged, this indicates that the chip was reset from the on-chip reset generator, which will indicate a power-on-reset or a brownout reset. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID F Reset 0x00000000 ID Access Field A RW RESETPIN B C D E E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotDetected 0 Not detected Detected 1 Detected Reset from pin-reset detected RW DOG Reset from watchdog detected NotDetected 0 Not detected Detected 1 Detected NotDetected 0 Not detected Detected 1 Detected NotDetected 0 Not detected Detected 1 Detected RW SREQ Reset from soft reset detected RW LOCKUP Reset from CPU lock-up detected RW OFF Reset due to wake up from System OFF mode when wakeup is triggered from DETECT signal from GPIO F NotDetected 0 Not detected Detected 1 Detected RW DIF Reset due to wake up from System OFF mode when wakeup is triggered from entering into debug interface mode NotDetected 0 Not detected Detected 1 Detected 5.3.9.9 SYSTEMOFF Address offset: 0x500 4454_140 v1.0 D C B A 57 Power and clock management System OFF register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SYSTEMOFF Enable System OFF mode Enter 1 Enable System OFF mode 5.3.9.10 POFCON Address offset: 0x510 Power failure comparator configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B B B B A Reset 0x00000000 ID Access Field A RW POF B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable V17 4 Set threshold to 1.7 V V18 5 Set threshold to 1.8 V V19 6 Set threshold to 1.9 V V20 7 Set threshold to 2.0 V V21 8 Set threshold to 2.1 V V22 9 Set threshold to 2.2 V V23 10 Set threshold to 2.3 V V24 11 Set threshold to 2.4 V V25 12 Set threshold to 2.5 V V26 13 Set threshold to 2.6 V V27 14 Set threshold to 2.7 V V28 15 Set threshold to 2.8 V Enable or disable power failure comparator RW THRESHOLD Power failure comparator threshold setting 5.3.9.11 GPREGRET Address offset: 0x51C General purpose retention register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A RW GPREGRET 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description General purpose retention register This register is a retained register 5.3.9.12 GPREGRET2 Address offset: 0x520 General purpose retention register 4454_140 v1.0 58 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A RW GPREGRET 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description General purpose retention register This register is a retained register 5.3.9.13 DCDCEN Address offset: 0x578 DC/DC enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW DCDCEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable DC/DC converter 5.3.9.14 RAM[n].POWER (n=0..7) Address offset: 0x900 + (n × 0x10) RAMn power control register. The RAM size will vary depending on product variant, and the RAMn register will only be present if the corresponding RAM AHB slave is present on the device. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x0000FFFF ID Access Field A-B RW S[i]POWER (i=0..1) Value ID Value Description Keep RAM section Si ON or OFF in System ON mode. RAM sections are always retained when ON, but can also be retained when OFF dependent on the settings in SiRETENTION. All RAM sections will be OFF in System OFF mode. C-D Off 0 Off On 1 On RW S[i]RETENTION (i=0..1) Keep retention on RAM section Si when RAM section is in OFF Off 0 Off On 1 On 5.3.9.15 RAM[n].POWERSET (n=0..7) Address offset: 0x904 + (n × 0x10) RAMn power control set register When read, this register will return the value of the POWER register. 4454_140 v1.0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 59 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x0000FFFF ID Access Field A-B W C-D W B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value On 1 Description S[i]POWER (i=0..1) Keep RAM section Si of RAMn on or off in System ON mode On S[i]RETENTION (i=0..1) Keep retention on RAM section Si when RAM section is switched off On 1 On 5.3.9.16 RAM[n].POWERCLR (n=0..7) Address offset: 0x908 + (n × 0x10) RAMn power control clear register When read, this register will return the value of the POWER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x0000FFFF B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field Value ID A-B W S[i]POWER (i=0..1) C-D W S[i]RETENTION (i=0..1) Value Description Keep RAM section Si of RAMn on or off in System ON mode Off 1 Off Keep retention on RAM section Si when RAM section is switched off Off 1 Off 5.3.10 Electrical specification 5.3.10.1 Device startup times Symbol Description tPOR Time in Power on Reset after VDD reaches 1.7 V for all Min. Typ. Max. Units supply voltages and temperatures. Dependent on supply rise time. 9 tPOR,10us VDD rise time 10us 1 ms tPOR,10ms VDD rise time 10ms 9 ms tPOR,60ms VDD rise time 60ms 23 ms tPINR If a GPIO pin is configured as reset, the maximum time taken to pull up the pin and release reset after power on reset. Dependent on the pin capacitive load (C)10: t=5RC, R = 13kOhm tPINR,500nF C = 500nF 32.5 ms tPINR,10uF C = 10uF 650 ms tR2ON Time from reset to ON (CPU execute) tR2ON,NOTCONF If reset pin not configured tPOR ms tR2ON,CONF If reset pin configured tPOR + ms tPINR 9 10 A step increase in supply voltage of 300 mV or more, with rise time of 300 ms or less, within the valid supply range, may result in a system reset. To decrease maximum time a device could hold in reset, a strong external pullup resistor can be used. 4454_140 v1.0 60 Power and clock management Symbol Description Min. Typ. Max. Units tOFF2ON Time from OFF to CPU execute 16.5 µs tIDLE2CPU Time from IDLE to CPU execute 3.0 µs tEVTSET,CL1 Time from HW event to PPI event in Constant Latency 0.0625 µs 0.0625 µs System ON mode tEVTSET,CL0 Time from HW event to PPI event in Low Power System ON mode 5.3.10.2 Power fail comparator Symbol Description Min. VPOF Nominal power level warning thresholds (falling supply 1.7 Typ. Max. Units 2.8 V ±5 % voltage). Levels are configurable between Min. and Max. in 100mV increments. VPOFTOL Threshold voltage tolerance ±1 VPOFHYST Threshold voltage hysteresis 50 VBOR,OFF Brown out reset voltage range SYSTEM OFF mode 1.2 1.7 V VBOR,ON Brown out reset voltage range SYSTEM ON mode 1.48 1.7 V mV 5.4 CLOCK — Clock control The clock control system can source the system clocks from a range of internal or external high and low frequency oscillators and distribute them to modules based upon a module’s individual requirements. Clock distribution is automated and grouped independently by module to limit current consumption in unused branches of the clock tree. Listed here are the main features for CLOCK: • • • • • • • 64 MHz on-chip oscillator 64 MHz crystal oscillator, using external 32 MHz crystal 32.768 kHz +/-500 ppm RC oscillator 32.768 kHz crystal oscillator, using external 32.768 kHz crystal 32.768 kHz oscillator synthesized from 64 MHz oscillator Firmware (FW) override control of oscillator activity for low latency start up Automatic oscillator and clock control, and distribution for ultra-low power 4454_140 v1.0 61 Power and clock management HFCLKSTART HFCLKSTOP LFCLKSTART LFCLKSTOP CLOCK HFINT Internal oscillator PCLK1M PCLK16M XC1 PCLK32M HFCLK Clock control HFXO Crystal oscillator 32 MHz HCLK64M XC2 LFRC RC oscillator CAL SYNT XL1 LFXO Crystal oscillator 32.768 kHz LFCLK Clock control PCLK32KI XL2 HFCLKSTARTED LFCLKSTARTED Figure 17: Clock control 5.4.1 HFCLK clock controller The HFCLK clock controller provides the following clocks to the system. • • • • HCLK64M: 64 MHz CPU clock PCLK1M: 1 MHz peripheral clock PCLK16M: 16 MHz peripheral clock PCLK32M: 32 MHz peripheral clock The HFCLK controller supports the following high frequency clock (HFCLK) sources: • 64 MHz internal oscillator (HFINT) • 64 MHz crystal oscillator (HFXO) For illustration, see Clock control on page 62. When the system requests one or more clocks from the HFCLK controller, the HFCLK controller will automatically provide them. If the system does not request any clocks provided by the HFCLK controller, the controller will enter a power saving mode. These clocks are only available when the system is in ON mode. When the system enters ON mode, the internal oscillator (HFINT) clock source will automatically start to be able to provide the required HFCLK clock(s) for the system. The HFINT will be used when HFCLK is requested and HFXO has not been started. The HFXO is started by triggering the HFCLKSTART task and stopped using the HFCLKSTOP task. A HFCLKSTARTED event will be generated when the HFXO has started and its frequency is stable. The HFXO must be running to use the RADIO or the calibration mechanism associated with the 32.768 kHz RC oscillator. 5.4.1.1 64 MHz crystal oscillator (HFXO) The 64 MHz crystal oscillator (HFXO) is controlled by a 32 MHz external crystal 4454_140 v1.0 62 Power and clock management The crystal oscillator is designed for use with an AT-cut quartz crystal in parallel resonant mode. To achieve correct oscillation frequency, the load capacitance must match the specification in the crystal data sheet. Circuit diagram of the 64 MHz crystal oscillator on page 63 shows how the 32 MHz crystal is connected to the 64 MHz crystal oscillator. XC1 XC2 C1 C2 32 MHz crystal Figure 18: Circuit diagram of the 64 MHz crystal oscillator The load capacitance (CL) is the total capacitance seen by the crystal across its terminals and is given by: C1 and C2 are ceramic SMD capacitors connected between each crystal terminal and ground. For more information, see Reference circuitry on page 425. Cpcb1 and Cpcb2 are stray capacitances on the PCB. Cpin is the pin input capacitance on the XC1 and XC2 pins. See table 64 MHz crystal oscillator (HFXO) on page 72. The load capacitors C1 and C2 should have the same value. For reliable operation, the crystal load capacitance, shunt capacitance, equivalent series resistance, and drive level must comply with the specifications in table 64 MHz crystal oscillator (HFXO) on page 72. It is recommended to use a crystal with lower than maximum load capacitance and/or shunt capacitance. A low load capacitance will reduce both start up time and current consumption. 5.4.2 LFCLK clock controller The system supports several low frequency clock sources. As illustrated in Clock control on page 62, the system supports the following low frequency clock sources: • 32.768 kHz RC oscillator (LFRC) • 32.768 kHz crystal oscillator (LFXO) • 32.768 kHz synthesized from HFCLK (LFSYNT) The LFCLK clock is started by first selecting the preferred clock source in register LFCLKSRC on page 71 and then triggering the LFCLKSTART task. If the LFXO is selected as the clock source, the LFCLK will initially start running from the 32.768 kHz LFRC while the LFXO is starting up and automatically switch to using the LFXO once this oscillator is running. The LFCLKSTARTED event will be generated when the LFXO has been started. 4454_140 v1.0 63 Power and clock management The LFCLK clock is stopped by triggering the LFCLKSTOP task. It is not allowed to write to register LFCLKSRC on page 71 when the LFCLK is running. A LFCLKSTOP task will stop the LFCLK oscillator. However, the LFCLKSTOP task can only be triggered after the STATE field in register LFCLKSTAT on page 71 indicates a 'LFCLK running' state. The LFCLK clock controller and all of the LFCLK clock sources are always switched off when in OFF mode. 5.4.2.1 32.768 kHz RC oscillator (LFRC) The default source of the low frequency clock (LFCLK) is the 32.768 kHz RC oscillator (LFRC). The LFRC frequency will be affected by variation in temperature. The LFRC oscillator can be calibrated to improve accuracy by using the HFXO as a reference oscillator during calibration. See Table 32.768 kHz RC oscillator (LFRC) on page 73 for details on the default and calibrated accuracy of the LFRC oscillator. The LFRC oscillator does not require additional external components. 5.4.2.2 Calibrating the 32.768 kHz RC oscillator After the 32.768 kHz RC oscillator is started and running, it can be calibrated by triggering the CAL task. In this case, the HFCLK will be temporarily switched on and used as a reference. A DONE event will be generated when calibration has finished. The calibration mechanism will only work as long as HFCLK is generated from the HFCLK crystal oscillator, it is therefore necessary to explicitly start this crystal oscillator before calibration can be started, see HFCLKSTART task. It is not allowed to stop the LFRC during an ongoing calibration. 5.4.2.3 Calibration timer The calibration timer can be used to time the calibration interval of the 32.768 kHz RC oscillator. The calibration timer is started by triggering the CTSTART task and stopped by triggering the CTSTOP task. The calibration timer will always start counting down from the value specified in CTIV and generate a CTTO timeout event when it reaches 0. The Calibration timer will stop by itself when it reaches 0. CTSTART CTSTOP Calibration timer CTIV CTTO Figure 19: Calibration timer Due to limitations in the calibration timer, only one task related to calibration, that is, CAL, CTSTART and CTSTOP, can be triggered for every period of LFCLK. 5.4.2.4 32.768 kHz crystal oscillator (LFXO) For higher LFCLK accuracy the low frequency crystal oscillator (LFXO) must be used. The following external clock sources are supported: • Low swing clock signal applied to the XL1 pin. The XL2 pin shall then be grounded. • Rail-to-rail clock signal applied to the XL1 pin. The XL2 pin shall then be grounded or left unconnected. The LFCLKSRC on page 71 register controls the clock source, and its allowed swing. The truth table for various situations is as follows: 4454_140 v1.0 64 Power and clock management SRC EXTERNAL BYPASS Comment 0 0 0 Normal operation, RC is source 0 0 1 DO NOT USE 0 1 X DO NOT USE 1 0 0 Normal XTAL operation 1 1 0 Apply external low swing signal to XL1, ground XL2 1 1 1 Apply external full swing signal to XL1, leave XL2 grounded or unconnected 1 0 1 DO NOT USE 2 0 0 Normal operation, synth is source 2 0 1 DO NOT USE 2 1 X DO NOT USE Table 17: LFCLKSRC configuration depending on clock source To achieve correct oscillation frequency, the load capacitance must match the specification in the crystal data sheet. Circuit diagram of the 32.768 kHz crystal oscillator on page 65 shows the LFXO circuitry. XL1 XL2 C1 C2 32.768 kHz crystal Figure 20: Circuit diagram of the 32.768 kHz crystal oscillator The load capacitance (CL) is the total capacitance seen by the crystal across its terminals and is given by: C1 and C2 are ceramic SMD capacitors connected between each crystal terminal and ground. Cpcb1 and Cpcb2 are stray capacitances on the PCB. Cpin is the pin input capacitance on the XC1 and XC2 pins (see 32.768 kHz crystal oscillator (LFXO) on page 73). The load capacitors C1 and C2 should have the same value. For more information, see Reference circuitry on page 425. 5.4.2.5 32.768 kHz synthesized from HFCLK (LFSYNT) LFCLK can also be synthesized from the HFCLK clock source. The accuracy of LFCLK will then be the accuracy of the HFCLK. Using the LFSYNT clock avoids the requirement for a 32.768 kHz crystal, but increases average power consumption as the HFCLK will need to be requested in the system. 4454_140 v1.0 65 Power and clock management 5.4.3 Registers Base address Peripheral Instance Description 0x40000000 CLOCK CLOCK Clock control Configuration Table 18: Instances Register Offset Description TASKS_HFCLKSTART 0x000 Start HFCLK crystal oscillator TASKS_HFCLKSTOP 0x004 Stop HFCLK crystal oscillator TASKS_LFCLKSTART 0x008 Start LFCLK source TASKS_LFCLKSTOP 0x00C Stop LFCLK source TASKS_CAL 0x010 Start calibration of LFRC oscillator TASKS_CTSTART 0x014 Start calibration timer TASKS_CTSTOP 0x018 Stop calibration timer EVENTS_HFCLKSTARTED 0x100 HFCLK oscillator started EVENTS_LFCLKSTARTED 0x104 LFCLK started EVENTS_DONE 0x10C Calibration of LFCLK RC oscillator complete event EVENTS_CTTO 0x110 Calibration timer timeout INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt HFCLKRUN 0x408 Status indicating that HFCLKSTART task has been triggered HFCLKSTAT 0x40C HFCLK status LFCLKRUN 0x414 Status indicating that LFCLKSTART task has been triggered LFCLKSTAT 0x418 LFCLK status LFCLKSRCCOPY 0x41C Copy of LFCLKSRC register, set when LFCLKSTART task was triggered LFCLKSRC 0x518 Clock source for the LFCLK CTIV 0x538 Calibration timer interval Retained Table 19: Register overview 5.4.3.1 TASKS_HFCLKSTART Address offset: 0x000 Start HFCLK crystal oscillator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_HFCLKSTART Start HFCLK crystal oscillator Trigger task 5.4.3.2 TASKS_HFCLKSTOP Address offset: 0x004 Stop HFCLK crystal oscillator 4454_140 v1.0 66 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_HFCLKSTOP Stop HFCLK crystal oscillator Trigger task 5.4.3.3 TASKS_LFCLKSTART Address offset: 0x008 Start LFCLK source Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_LFCLKSTART Start LFCLK source Trigger task 5.4.3.4 TASKS_LFCLKSTOP Address offset: 0x00C Stop LFCLK source Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_LFCLKSTOP Stop LFCLK source Trigger task 5.4.3.5 TASKS_CAL Address offset: 0x010 Start calibration of LFRC oscillator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_CAL Start calibration of LFRC oscillator Trigger 1 Trigger task 5.4.3.6 TASKS_CTSTART Address offset: 0x014 Start calibration timer 4454_140 v1.0 67 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_CTSTART Start calibration timer Trigger task 5.4.3.7 TASKS_CTSTOP Address offset: 0x018 Stop calibration timer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_CTSTOP Stop calibration timer Trigger task 5.4.3.8 EVENTS_HFCLKSTARTED Address offset: 0x100 HFCLK oscillator started Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_HFCLKSTARTED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated HFCLK oscillator started 5.4.3.9 EVENTS_LFCLKSTARTED Address offset: 0x104 LFCLK started Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_LFCLKSTARTED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated LFCLK started 5.4.3.10 EVENTS_DONE Address offset: 0x10C Calibration of LFCLK RC oscillator complete event 4454_140 v1.0 68 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DONE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Calibration of LFCLK RC oscillator complete event 5.4.3.11 EVENTS_CTTO Address offset: 0x110 Calibration timer timeout Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_CTTO 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Calibration timer timeout 5.4.3.12 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x00000000 ID Access Field A RW HFCLKSTARTED B C D Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event HFCLKSTARTED RW LFCLKSTARTED Write '1' to enable interrupt for event LFCLKSTARTED RW DONE Write '1' to enable interrupt for event DONE RW CTTO Write '1' to enable interrupt for event CTTO 5.4.3.13 INTENCLR Address offset: 0x308 Disable interrupt 4454_140 v1.0 B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 69 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C Reset 0x00000000 ID Access Field A RW HFCLKSTARTED B C D B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event HFCLKSTARTED RW LFCLKSTARTED Write '1' to disable interrupt for event LFCLKSTARTED RW DONE Write '1' to disable interrupt for event DONE RW CTTO Write '1' to disable interrupt for event CTTO 5.4.3.14 HFCLKRUN Address offset: 0x408 Status indicating that HFCLKSTART task has been triggered Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description STATUS HFCLKSTART task triggered or not NotTriggered 0 Task not triggered Triggered 1 Task triggered 5.4.3.15 HFCLKSTAT Address offset: 0x40C HFCLK status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0x00000000 ID Access Field A R B R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SRC Source of HFCLK RC 0 64 MHz internal oscillator (HFINT) Xtal 1 64 MHz crystal oscillator (HFXO) NotRunning 0 HFCLK not running Running 1 HFCLK running STATE HFCLK state 5.4.3.16 LFCLKRUN Address offset: 0x414 4454_140 v1.0 A 70 Power and clock management Status indicating that LFCLKSTART task has been triggered Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description STATUS LFCLKSTART task triggered or not NotTriggered 0 Task not triggered Triggered 1 Task triggered 5.4.3.17 LFCLKSTAT Address offset: 0x418 LFCLK status Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0x00000000 ID Access Field A R B R A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SRC Source of LFCLK RC 0 32.768 kHz RC oscillator Xtal 1 32.768 kHz crystal oscillator Synth 2 32.768 kHz synthesized from HFCLK STATE LFCLK state NotRunning 0 LFCLK not running Running 1 LFCLK running 5.4.3.18 LFCLKSRCCOPY Address offset: 0x41C Copy of LFCLKSRC register, set when LFCLKSTART task was triggered Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description SRC Clock source RC 0 32.768 kHz RC oscillator Xtal 1 32.768 kHz crystal oscillator Synth 2 32.768 kHz synthesized from HFCLK 5.4.3.19 LFCLKSRC Address offset: 0x518 Clock source for the LFCLK 4454_140 v1.0 71 Power and clock management Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B Reset 0x00000000 ID Access Field A RW SRC B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RC 0 32.768 kHz RC oscillator Xtal 1 32.768 kHz crystal oscillator Synth 2 32.768 kHz synthesized from HFCLK Clock source RW BYPASS Enable or disable bypass of LFCLK crystal oscillator with external clock source C Disabled 0 Disable (use with Xtal or low-swing external source) Enabled 1 Enable (use with rail-to-rail external source) Disabled 0 Disable external source (use with Xtal) Enabled 1 Enable use of external source instead of Xtal (SRC needs to RW EXTERNAL Enable or disable external source for LFCLK be set to Xtal) 5.4.3.20 CTIV ( Retained ) Address offset: 0x538 This register is a retained register Calibration timer interval Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x00000000 ID Access Field A RW CTIV 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Calibration timer interval in multiple of 0.25 seconds. Range: 0.25 seconds to 31.75 seconds. 5.4.4 Electrical specification 5.4.4.1 64 MHz internal oscillator (HFINT) Symbol Description fNOM_HFINT Nominal output frequency Min. Typ. 64 fTOL_HFINT Frequency tolerance VIN-) READY DOWN CROSS UP Figure 33: Comparator overview Once enabled (using the ENABLE register), the comparator is started by triggering the START task and stopped by triggering the STOP task. After a start-up time of tCOMP,START, the comparator will generate a READY event to indicate that it is ready for use and that its output is correct. When the COMP module is started, events will be generated every time VIN+ crosses VIN-. Operation modes The comparator can be configured to operate in two main operation modes, differential mode and singleended mode. See the MODE register for more information. In both operation modes, the comparator can operate in different speed and power consumption modes (low-power, normal and high-speed). Highspeed mode will consume more power compared to low-power mode, and low-power mode will result in slower response time compared to high-speed mode. Use the PSEL register to select any of the AIN0-AIN6 pins (or VDD/2) as VIN+ input, irregardless of the operation mode selected for the comparator. The source of VIN- depends on which operation mode is used: • Differential mode: Derived directly from AIN0 to AIN7 • Single-ended mode: Derived from VREF. VREF can be derived from VDD, AIN0-AIN7 or internal 1.2 V, 1.8 V and 2.4 V references. The selected analog pins will be acquired by the comparator once it is enabled. An optional hysteresis on VIN+ and VIN- can be enabled when the module is used in differential mode through the HYST register. In single-ended mode, VUP and VDOWN thresholds can be set to implement a hysteresis using the reference ladder (see Comparator in single-ended mode on page 100). This hysteresis is in the order of magnitude of 30 mV, and shall prevent noise on the signal to create unwanted events. See Hysteresis example where VIN+ starts below VUP on page 101 for illustration of the effect of an active hysteresis on a noisy input signal. An upward crossing will generate an UP event and a downward crossing will generate a DOWN event. The CROSS event will be generated every time there is a crossing, independent of direction. The immediate value of the comparator can be sampled to RESULT register by triggering the SAMPLE task. 4454_140 v1.0 98 Peripherals 6.5.1 Differential mode In differential mode, the reference input VIN- is derived directly from one of the AINx pins. Before enabling the comparator via the ENABLE register, the following registers must be configured for the differential mode: MUX PSEL EXTREFSEL AIN7 AIN6 AIN5 AIN4 AIN3 AIN2 AIN1 AIN0 AIN6 VDD/2 AIN5 AIN4 AIN3 AIN2 AIN1 AIN0 • PSEL • MODE • EXTREFSEL MUX SAMPLE STOP START VIN+ + VIN- Comparator core MODE RESULT Output 0 = BELOW (VIN+ < VIN-) 1 = ABOVE (VIN+ > VIN-) READY DOWN UP CROSS Figure 34: Comparator in differential mode Restriction: Depending on the device, not all the analog inputs may be available for each MUX. See definitions for PSEL and EXTREFSEL for more information about which analog pins are available on a particular device. When HYST register is turned on while in this mode, the output of the comparator (and associated events) will change from ABOVE to BELOW whenever VIN+ becomes lower than VIN- - (VDIFFHYST / 2). It will also change from BELOW to ABOVE whenever VIN+ becomes higher than VIN- + (VDIFFHYST / 2). This behavior is illustrated in Hysteresis enabled in differential mode on page 99. VIN+ VIN- + (VDIFFHYST / 2) VIN- - (VDIFFHYST / 2) t Output ABOVE (VIN+ > (VIN- + VDIFFHYST /2)) BELOW (VIN+ < (VIN- - VDIFFHYST /2)) ABOVE (VIN+ > (VIN- + VDIFFHYST /2)) Figure 35: Hysteresis enabled in differential mode 6.5.2 Single-ended mode In single-ended mode, VIN- is derived from the reference ladder. 4454_140 v1.0 99 BELOW Peripherals Before enabling the comparator via the ENABLE register, the following registers must be configured for the single-ended mode: • • • • • PSEL MODE REFSEL EXTREFSEL TH MUX PSEL TH EXTREFSEL AIN7 AIN6 AIN5 AIN4 AIN2 AIN3 MUX SAMPLE STOP START VIN+ + - VIN- 0 MUX 1 Comparator core MODE REFSEL AIN1 AIN0 AIN6 VDD/2 AIN5 AIN4 AIN3 AIN2 AIN1 AIN0 The reference ladder uses the reference voltage (VREF) to derive two new voltage references, VUP and VDOWN. VUP and VDOWN are configured using THUP and THDOWN respectively in the TH register. VREF can be derived from any of the available reference sources, configured using the EXTREFSEL and REFSEL registers as illustrated in Comparator in single-ended mode on page 100. When AREF is selected in the REFSEL register, the EXTREFSEL register is used to select one of the AIN0-AIN7 analog input pins as reference input. The selected analog pins will be acquired by the comparator once it is enabled. AREF VDOWN HYST RESULT VDD VUP Reference ladder VREF MUX 1V2 1V8 2V4 Output 0 = BELOW (VIN+ < VIN-) 1 = ABOVE (VIN+ > VIN-) READY DOWN UP CROSS Figure 36: Comparator in single-ended mode Restriction: Depending on the device, not all the analog inputs may be available for each MUX. See definitions for PSEL and EXTREFSEL for more information about which analog pins are available on a particular device. When the comparator core detects that VIN+ > VIN-, i.e. ABOVE as per the RESULT register, VIN- will switch to VDOWN. When VIN+ falls below VIN- again, VIN- will be switched back to VUP. By specifying VUP larger than VDOWN, a hysteresis can be generated as illustrated in Hysteresis example where VIN+ starts below VUP on page 101 and Hysteresis example where VIN+ starts above VUP on page 101. Writing to HYST has no effect in single-ended mode, and the content of this register is ignored. 4454_140 v1.0 100 Peripherals VIN+ VUP VDOWN Output ABOVE (VIN+ > VIN-) BELOW VUP VDOWN VUP RESULT BELOW ( VIN+ < VIN-) VIN- t UP 3 2 START SAMPLE SAMPLE 1 CPU DOWN ABOVE READY BELOW Figure 37: Hysteresis example where VIN+ starts below VUP VIN+ VUP VDOWN Output BELOW ( VIN+ < VIN-) ABOVE (VIN+ > VIN-) BELOW VDOWN VUP VDOWN VUP BELOW 3 2 SAMPLE START SAMPLE 1 CPU ABOVE UP DOWN READY ABOVE DOWN RESULT ABOVE (VIN+ > VIN-) VIN- t Figure 38: Hysteresis example where VIN+ starts above VUP 6.5.3 Registers Base address Peripheral Instance Description Configuration 0x40013000 COMP COMP General purpose comparator Table 30: Instances Register Offset Description TASKS_START 0x000 Start comparator 4454_140 v1.0 101 Peripherals Register Offset Description TASKS_STOP 0x004 Stop comparator TASKS_SAMPLE 0x008 Sample comparator value EVENTS_READY 0x100 COMP is ready and output is valid EVENTS_DOWN 0x104 Downward crossing EVENTS_UP 0x108 Upward crossing EVENTS_CROSS 0x10C Downward or upward crossing SHORTS 0x200 Shortcuts between local events and tasks INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt RESULT 0x400 Compare result ENABLE 0x500 COMP enable PSEL 0x504 Pin select REFSEL 0x508 Reference source select for single-ended mode EXTREFSEL 0x50C External reference select TH 0x530 Threshold configuration for hysteresis unit MODE 0x534 Mode configuration HYST 0x538 Comparator hysteresis enable Table 31: Register overview 6.5.3.1 TASKS_START Address offset: 0x000 Start comparator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_START Start comparator Trigger task 6.5.3.2 TASKS_STOP Address offset: 0x004 Stop comparator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_STOP Stop comparator Trigger task 6.5.3.3 TASKS_SAMPLE Address offset: 0x008 Sample comparator value 4454_140 v1.0 102 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_SAMPLE Sample comparator value Trigger task 6.5.3.4 EVENTS_READY Address offset: 0x100 COMP is ready and output is valid Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_READY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated COMP is ready and output is valid 6.5.3.5 EVENTS_DOWN Address offset: 0x104 Downward crossing Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DOWN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Downward crossing 6.5.3.6 EVENTS_UP Address offset: 0x108 Upward crossing Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_UP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Upward crossing 6.5.3.7 EVENTS_CROSS Address offset: 0x10C Downward or upward crossing 4454_140 v1.0 103 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_CROSS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Downward or upward crossing 6.5.3.8 SHORTS Address offset: 0x200 Shortcuts between local events and tasks Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID Access Field A RW READY_SAMPLE B C D E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Shortcut between event READY and task SAMPLE RW READY_STOP Shortcut between event READY and task STOP RW DOWN_STOP Shortcut between event DOWN and task STOP RW UP_STOP Shortcut between event UP and task STOP Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW CROSS_STOP Shortcut between event CROSS and task STOP 6.5.3.9 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C B A Reset 0x00000000 ID Access Field A RW READY B C D 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Enable or disable interrupt for event READY RW DOWN Enable or disable interrupt for event DOWN RW UP Enable or disable interrupt for event UP RW CROSS Enable or disable interrupt for event CROSS Disabled 4454_140 v1.0 0 Disable 104 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C B A Reset 0x00000000 ID Access Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enabled 1 Enable 6.5.3.10 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C B A Reset 0x00000000 ID Access Field A RW READY B C D 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event READY RW DOWN Write '1' to enable interrupt for event DOWN RW UP Write '1' to enable interrupt for event UP RW CROSS Write '1' to enable interrupt for event CROSS 6.5.3.11 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C B A Reset 0x00000000 ID Access Field A RW READY B C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event READY RW DOWN Write '1' to disable interrupt for event DOWN RW UP 4454_140 v1.0 Write '1' to disable interrupt for event UP 105 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D C B A Reset 0x00000000 ID Access Field D RW CROSS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event CROSS 6.5.3.12 RESULT Address offset: 0x400 Compare result Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description RESULT Result of last compare. Decision point SAMPLE task. Below 0 Input voltage is below the threshold (VIN+ < VIN-) Above 1 Input voltage is above the threshold (VIN+ > VIN-) 6.5.3.13 ENABLE Address offset: 0x500 COMP enable Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A Reset 0x00000000 ID Access Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 2 Enable Enable or disable COMP 6.5.3.14 PSEL Address offset: 0x504 Pin select 4454_140 v1.0 106 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000000 ID Access Field A RW PSEL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description AnalogInput0 0 AIN0 selected as analog input AnalogInput1 1 AIN1 selected as analog input AnalogInput2 2 AIN2 selected as analog input AnalogInput3 3 AIN3 selected as analog input AnalogInput4 4 AIN4 selected as analog input AnalogInput5 5 AIN5 selected as analog input AnalogInput6 6 AIN6 selected as analog input VddDiv2 7 VDD/2 selected as analog input Analog pin select 6.5.3.15 REFSEL Address offset: 0x508 Reference source select for single-ended mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000004 ID Access Field A RW REFSEL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 Value ID Value Description Int1V2 0 VREF = internal 1.2 V reference (VDD >= 1.7 V) Int1V8 1 VREF = internal 1.8 V reference (VDD >= VREF + 0.2 V) Int2V4 2 VREF = internal 2.4 V reference (VDD >= VREF + 0.2 V) VDD 4 VREF = VDD ARef 5 VREF = AREF (VDD >= VREF >= AREFMIN) Reference select 6.5.3.16 EXTREFSEL Address offset: 0x50C External reference select Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000000 ID Access Field A RW EXTREFSEL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description External analog reference select AnalogReference0 0 Use AIN0 as external analog reference AnalogReference1 1 Use AIN1 as external analog reference AnalogReference2 2 Use AIN2 as external analog reference AnalogReference3 3 Use AIN3 as external analog reference AnalogReference4 4 Use AIN4 as external analog reference AnalogReference5 5 Use AIN5 as external analog reference AnalogReference6 6 Use AIN6 as external analog reference AnalogReference7 7 Use AIN7 as external analog reference 6.5.3.17 TH Address offset: 0x530 4454_140 v1.0 107 Peripherals Threshold configuration for hysteresis unit Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B B B B B B Reset 0x00000000 A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field Value ID Value Description A RW THDOWN [63:0] VDOWN = (THDOWN+1)/64*VREF B RW THUP [63:0] VUP = (THUP+1)/64*VREF 6.5.3.18 MODE Address offset: 0x534 Mode configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0x00000000 ID Access Field A RW SP B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Low 0 Low-power mode Normal 1 Normal mode High 2 High-speed mode SE 0 Single-ended mode Diff 1 Differential mode Speed and power modes RW MAIN Main operation modes 6.5.3.19 HYST Address offset: 0x538 Comparator hysteresis enable Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW HYST 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NoHyst 0 Comparator hysteresis disabled Hyst50mV 1 Comparator hysteresis enabled Comparator hysteresis 6.5.4 Electrical specification 6.5.4.1 COMP Electrical Specification Symbol Description tPROPDLY,LP Propagation delay, low-power modea tPROPDLY,N Min. a Propagation delay, normal mode tPROPDLY,HS Propagation delay, high-speed mode VDIFFHYST Optional hysteresis applied to differential input a a Propagation delay is with 10 mV overdrive. 4454_140 v1.0 108 Typ. Max. Units 0.6 µS 0.2 µS 0.1 µS 30 mV Peripherals Symbol Description Min. VVDD-VREF Required difference between VDD and a selected VREF, VDD 0.3 Typ. Max. Units V > VREF tINT_REF,START Startup time for the internal bandgap reference EINT_REF Internal bandgap reference error -3 50 VINPUTOFFSET Input offset -10 tCOMP,START Startup time for the comparator core 80 µS 3 % 10 mV 3 µS 6.6 ECB — AES electronic codebook mode encryption The AES electronic codebook mode encryption (ECB) can be used for a range of cryptographic functions like hash generation, digital signatures, and keystream generation for data encryption/decryption. The ECB encryption block supports 128 bit AES encryption (encryption only, not decryption). AES ECB operates with EasyDMA access to system Data RAM for in-place operations on cleartext and ciphertext during encryption. ECB uses the same AES core as the CCM and AAR blocks and is an asynchronous operation which may not complete if the AES core is busy. AES ECB features: • • • • 128 bit AES encryption Supports standard AES ECB block encryption Memory pointer support DMA data transfer AES ECB performs a 128 bit AES block encrypt. At the STARTECB task, data and key is loaded into the algorithm by EasyDMA. When output data has been written back to memory, the ENDECB event is triggered. AES ECB can be stopped by triggering the STOPECB task. 6.6.1 Shared resources The ECB, CCM, and AAR share the same AES module. The ECB will always have lowest priority and if there is a sharing conflict during encryption, the ECB operation will be aborted and an ERRORECB event will be generated. 6.6.2 EasyDMA The ECB implements an EasyDMA mechanism for reading and writing to the Data RAM. This DMA cannot access the program memory or any other parts of the memory area except RAM. If the ECBDATAPTR is not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 16 for more information about the different memory regions. The EasyDMA will have finished accessing the Data RAM when the ENDECB or ERRORECB is generated. 6.6.3 ECB data structure Input to the block encrypt and output from the block encrypt are stored in the same data structure. ECBDATAPTR should point to this data structure before STARTECB is initiated. Property Address offset Description KEY 0 16 byte AES key CLEARTEXT 16 16 byte AES cleartext input block CIPHERTEXT 32 16 byte AES ciphertext output block Table 32: ECB data structure overview 4454_140 v1.0 109 Peripherals 6.6.4 Registers Base address Peripheral Instance Description Configuration 0x4000E000 ECB ECB AES Electronic Codebook (ECB) mode block encryption Table 33: Instances Register Offset Description TASKS_STARTECB 0x000 Start ECB block encrypt TASKS_STOPECB 0x004 Abort a possible executing ECB operation EVENTS_ENDECB 0x100 ECB block encrypt complete EVENTS_ERRORECB 0x104 ECB block encrypt aborted because of a STOPECB task or due to an error INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ECBDATAPTR 0x504 ECB block encrypt memory pointers Table 34: Register overview 6.6.4.1 TASKS_STARTECB Address offset: 0x000 Start ECB block encrypt If a crypto operation is already running in the AES core, the STARTECB task will not start a new encryption and an ERRORECB event will be triggered Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_STARTECB Start ECB block encrypt If a crypto operation is already running in the AES core, the STARTECB task will not start a new encryption and an ERRORECB event will be triggered Trigger 1 Trigger task 6.6.4.2 TASKS_STOPECB Address offset: 0x004 Abort a possible executing ECB operation If a running ECB operation is aborted by STOPECB, the ERRORECB event is triggered. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_STOPECB Abort a possible executing ECB operation If a running ECB operation is aborted by STOPECB, the ERRORECB event is triggered. Trigger 4454_140 v1.0 1 Trigger task 110 Peripherals 6.6.4.3 EVENTS_ENDECB Address offset: 0x100 ECB block encrypt complete Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_ENDECB 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated ECB block encrypt complete 6.6.4.4 EVENTS_ERRORECB Address offset: 0x104 ECB block encrypt aborted because of a STOPECB task or due to an error Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_ERRORECB 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ECB block encrypt aborted because of a STOPECB task or due to an error NotGenerated 0 Event not generated Generated 1 Event generated 6.6.4.5 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B A Reset 0x00000000 ID Access Field A RW ENDECB B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event ENDECB RW ERRORECB Write '1' to enable interrupt for event ERRORECB 6.6.4.6 INTENCLR Address offset: 0x308 Disable interrupt 4454_140 v1.0 111 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B A Reset 0x00000000 ID Access Field A RW ENDECB B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event ENDECB RW ERRORECB Write '1' to disable interrupt for event ERRORECB 6.6.4.7 ECBDATAPTR Address offset: 0x504 ECB block encrypt memory pointers Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field Value ID A RW ECBDATAPTR Value Description Pointer to the ECB data structure (see Table 1 ECB data structure overview) 6.6.5 Electrical specification 6.6.5.1 ECB Electrical Specification Symbol Description tECB Run time per 16 byte block in all modes Min. Typ. 6 Max. Units µs 6.7 EGU — Event generator unit The Event generator unit (EGU) provides support for inter-layer signaling. This means support for atomic triggering of both CPU execution and hardware tasks from both firmware (by CPU) and hardware (by PPI). This feature can, for instance, be used for triggering CPU execution at a lower priority execution from a higher priority execution, or to handle a peripheral's ISR execution at a lower priority for some of its events. However, triggering any priority from any priority is possible. Listed here are the main EGU features: • Enables SW triggering of interrupts • Separate interrupt vectors for every EGU instance • Up to 16 separate event flags per interrupt for multiplexing Each instance of The EGU implements a set of tasks which can individually be triggered to generate the corresponding event, i.e., the corresponding event for TASKS_TRIGGER[n] is EVENTS_TRIGGERED[n]. Refer to Instances on page 113 for a list of the various EGU instances 4454_140 v1.0 112 Peripherals 6.7.1 Registers Base address Peripheral Instance Description Configuration 0x40014000 EGU EGU0 Event generator unit 0 0x40015000 EGU EGU1 Event generator unit 1 Table 35: Instances Register Offset Description TASKS_TRIGGER[0] 0x000 Trigger 0 for triggering the corresponding TRIGGERED[0] event TASKS_TRIGGER[1] 0x004 Trigger 1 for triggering the corresponding TRIGGERED[1] event TASKS_TRIGGER[2] 0x008 Trigger 2 for triggering the corresponding TRIGGERED[2] event TASKS_TRIGGER[3] 0x00C Trigger 3 for triggering the corresponding TRIGGERED[3] event TASKS_TRIGGER[4] 0x010 Trigger 4 for triggering the corresponding TRIGGERED[4] event TASKS_TRIGGER[5] 0x014 Trigger 5 for triggering the corresponding TRIGGERED[5] event TASKS_TRIGGER[6] 0x018 Trigger 6 for triggering the corresponding TRIGGERED[6] event TASKS_TRIGGER[7] 0x01C Trigger 7 for triggering the corresponding TRIGGERED[7] event TASKS_TRIGGER[8] 0x020 Trigger 8 for triggering the corresponding TRIGGERED[8] event TASKS_TRIGGER[9] 0x024 Trigger 9 for triggering the corresponding TRIGGERED[9] event TASKS_TRIGGER[10] 0x028 Trigger 10 for triggering the corresponding TRIGGERED[10] event TASKS_TRIGGER[11] 0x02C Trigger 11 for triggering the corresponding TRIGGERED[11] event TASKS_TRIGGER[12] 0x030 Trigger 12 for triggering the corresponding TRIGGERED[12] event TASKS_TRIGGER[13] 0x034 Trigger 13 for triggering the corresponding TRIGGERED[13] event TASKS_TRIGGER[14] 0x038 Trigger 14 for triggering the corresponding TRIGGERED[14] event TASKS_TRIGGER[15] 0x03C Trigger 15 for triggering the corresponding TRIGGERED[15] event EVENTS_TRIGGERED[0] 0x100 Event number 0 generated by triggering the corresponding TRIGGER[0] task EVENTS_TRIGGERED[1] 0x104 Event number 1 generated by triggering the corresponding TRIGGER[1] task EVENTS_TRIGGERED[2] 0x108 Event number 2 generated by triggering the corresponding TRIGGER[2] task EVENTS_TRIGGERED[3] 0x10C Event number 3 generated by triggering the corresponding TRIGGER[3] task EVENTS_TRIGGERED[4] 0x110 Event number 4 generated by triggering the corresponding TRIGGER[4] task EVENTS_TRIGGERED[5] 0x114 Event number 5 generated by triggering the corresponding TRIGGER[5] task EVENTS_TRIGGERED[6] 0x118 Event number 6 generated by triggering the corresponding TRIGGER[6] task EVENTS_TRIGGERED[7] 0x11C Event number 7 generated by triggering the corresponding TRIGGER[7] task EVENTS_TRIGGERED[8] 0x120 Event number 8 generated by triggering the corresponding TRIGGER[8] task EVENTS_TRIGGERED[9] 0x124 Event number 9 generated by triggering the corresponding TRIGGER[9] task EVENTS_TRIGGERED[10] 0x128 Event number 10 generated by triggering the corresponding TRIGGER[10] task EVENTS_TRIGGERED[11] 0x12C Event number 11 generated by triggering the corresponding TRIGGER[11] task EVENTS_TRIGGERED[12] 0x130 Event number 12 generated by triggering the corresponding TRIGGER[12] task EVENTS_TRIGGERED[13] 0x134 Event number 13 generated by triggering the corresponding TRIGGER[13] task EVENTS_TRIGGERED[14] 0x138 Event number 14 generated by triggering the corresponding TRIGGER[14] task EVENTS_TRIGGERED[15] 0x13C Event number 15 generated by triggering the corresponding TRIGGER[15] task INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt Table 36: Register overview 6.7.1.1 TASKS_TRIGGER[n] (n=0..15) Address offset: 0x000 + (n × 0x4) Trigger n for triggering the corresponding TRIGGERED[n] event 4454_140 v1.0 113 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_TRIGGER Trigger n for triggering the corresponding TRIGGERED[n] event Trigger 1 Trigger task 6.7.1.2 EVENTS_TRIGGERED[n] (n=0..15) Address offset: 0x100 + (n × 0x4) Event number n generated by triggering the corresponding TRIGGER[n] task Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_TRIGGERED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Event number n generated by triggering the corresponding TRIGGER[n] task NotGenerated 0 Event not generated Generated 1 Event generated 6.7.1.3 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID P O N M L K J I H G F E D C B A Reset 0x00000000 ID Access Field A-P RW TRIGGERED[i] (i=0..15) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enable or disable interrupt for event TRIGGERED[i] Disabled 0 Disable Enabled 1 Enable 6.7.1.4 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID P O N M L K J I H G F E D C B A Reset 0x00000000 ID Access Field A-P RW TRIGGERED[i] (i=0..15) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Write '1' to enable interrupt for event TRIGGERED[i] Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 6.7.1.5 INTENCLR Address offset: 0x308 4454_140 v1.0 114 Peripherals Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID P O N M L K J I H G F E D C B A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field Value ID A-P RW TRIGGERED[i] (i=0..15) Value Description Write '1' to disable interrupt for event TRIGGERED[i] Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 6.7.2 Electrical specification 6.7.2.1 EGU Electrical Specification Symbol Description tEGU,EVT Latency between setting an EGU event flag and the system Min. Typ. 1 Max. Units cycles setting an interrupt 6.8 GPIO — General purpose input/output The general purpose input/output pins (GPIOs) are grouped as one or more ports with each port having up to 32 GPIOs. The number of ports and GPIOs per port might vary with product variant and package. Refer to Registers on page 117 and Pin assignments on page 416 for more information about the number of GPIOs that are supported. GPIO has the following user-configurable features: • • • • • • • • • Up to 32 GPIO pins per GPIO port Configurable output drive strength Internal pull-up and pull-down resistors Wake-up from high or low level triggers on all pins Trigger interrupt on state changes on any pin All pins can be used by the PPI task/event system One or more GPIO outputs can be controlled through PPI and GPIOTE channels All pins can be individually mapped to interface blocks for layout flexibility GPIO state changes captured on SENSE signal can be stored by LATCH register The GPIO port peripheral implements up to 32 pins, PIN0 through PIN31. Each of these pins can be individually configured in the PIN_CNF[n] registers (n=0..31). The following parameters can be configured through these registers: • • • • • • Direction Drive strength Enabling of pull-up and pull-down resistors Pin sensing Input buffer disconnect Analog input (for selected pins) The PIN_CNF registers are retained registers. See POWER — Power supply on page 48 chapter for more information about retained registers. 4454_140 v1.0 115 Peripherals 6.8.1 Pin configuration Pins can be individually configured, through the SENSE field in the PIN_CNF[n] register, to detect either a high level or a low level on their input. When the correct level is detected on any such configured pin, the sense mechanism will set the DETECT signal high. Each pin has a separate DETECT signal. Default behavior, defined by the DETECTMODE register, is that the DETECT signals from all pins in the GPIO port are combined into one common DETECT signal that is routed throughout the system, which then can be utilized by other peripherals. This mechanism is functional in both System ON mode and System OFF mode. See GPIO port and the GPIO pin details on page 116. LDETECT PIN0 ANAEN GPIO port DIR_OVERRIDE DETECTMODE DETECT PIN[0].CNF.DRIVE OUT_OVERRIDE LATCH PIN0 OUT PIN[0].OUT PIN0.DETECT PIN[0].IN PIN[0].CNF PIN[0].CNF.DIR Sense PIN1.DETECT PIN[0].CNF.SENSE .. PIN[0].CNF.PULL PIN[0].CNF.INPUT PIN31.DETECT PIN[0].IN I PIN31 IN PIN[31].OUT PIN[31].IN PIN[31].CNF INPUT_OVERRIDE ANAIN O: output buffer I: input buffer Figure 39: GPIO port and the GPIO pin details GPIO port and the GPIO pin details on page 116 illustrates the GPIO port containing 32 individual pins, where PIN0 is illustrated in more detail as a reference. All signals on the left side in the illustration are used by other peripherals in the system and therefore not directly available to the CPU. Make sure that a pin is in a level that cannot trigger the sense mechanism before enabling it. The DETECT signal will go high immediately if the SENSE condition configured in the PIN_CNF registers is met when the sense mechanism is enabled. This will trigger a PORT event if the DETECT signal was low before enabling the sense mechanism. See GPIOTE — GPIO tasks and events on page 123. See the following peripherals for more information about how the DETECT signal is used: • POWER: uses the DETECT signal to exit from System OFF mode. • GPIOTE: uses the DETECT signal to generate the PORT event. When a pin's PINx.DETECT signal goes high, a flag will be set in the LATCH register. For example, when the PIN0.DETECT signal goes high, bit 0 in the LATCH register will be set to '1'. If the CPU performs a clear operation on a bit in the LATCH register when the associated PINx.DETECT signal is high, the bit in the LATCH register will not be cleared. The LATCH register will only be cleared if the CPU explicitly clears it by writing a '1' to the bit that shall be cleared, i.e. the LATCH register will not be affected by a PINx.DETECT signal being set low. The LDETECT signal will be set high when one or more bits in the LATCH register are '1'. The LDETECT signal will be set low when all bits in the LATCH register are successfully cleared to '0'. If one or more bits in the LATCH register are '1' after the CPU has performed a clear operation on the LATCH registers, a rising edge will be generated on the LDETECT signal. This is illustrated in DETECT signal behavior on page 117. Important: The CPU can read the LATCH register at any time to check if a SENSE condition has been met on one or more of the the GPIO pins, even if that condition is no longer met at the time the CPU queries the LATCH register. This mechanism will work even if the LDETECT signal is not used as the DETECT signal. 4454_140 v1.0 PIN0 PIN[0].OUT O 116 PIN31 Peripherals The LDETECT signal is by default not connected to the GPIO port's DETECT signal, but via the DETECTMODE register it is possible to change from default behavior to DETECT signal being derived directly from the LDETECT signal instead. See GPIO port and the GPIO pin details on page 116. DETECT signal behavior on page 117 illustrates the DETECT signal behavior for these two alternatives. PIN31.DETECT PIN1.DETECT PIN0.DETECT DETECT (Default mode) LATCH.31 LATCH.1 LATCH.0 3 4 LATCH = (1 = 2.7 V 4454_140 v1.0 122 Peripherals Symbol Description Min. IOH,HDL Current at VDD-0.4 V, output set high, high drive, VDD >= 1.7 3 Typ. Max. Units mA V tRF,15pF Rise/fall time, standard drive mode, 10-90%, 15 pF load1 9 ns tRF,25pF Rise/fall time, standard drive mode, 10-90%, 25 pF load1 13 ns tRF,50pF 1 25 ns tHRF,15pF 1 Rise/Fall time, high drive mode, 10-90%, 15 pF load 4 ns tHRF,25pF Rise/Fall time, high drive mode, 10-90%, 25 pF load1 5 ns tHRF,50pF Rise/Fall time, high drive mode, 10-90%, 50 pF load1 8 ns RPU Pull-up resistance 11 13 16 kΩ RPD Pull-down resistance 11 13 16 kΩ CPAD Pad capacitance Rise/fall time, standard drive mode, 10-90%, 50 pF load 3 pF 6.9 GPIOTE — GPIO tasks and events The GPIO tasks and events (GPIOTE) module provides functionality for accessing GPIO pins using tasks and events. Each GPIOTE channel can be assigned to one pin. A GPIOTE block enables GPIOs to generate events on pin state change which can be used to carry out tasks through the PPI system. A GPIO can also be driven to change state on system events using the PPI system. Low power detection of pin state changes is possible when in System ON or System OFF. Instance Number of GPIOTE channels GPIOTE 8 Table 39: GPIOTE properties Up to three tasks can be used in each GPIOTE channel for performing write operations to a pin. Two tasks are fixed (SET and CLR), and one (OUT) is configurable to perform following operations: • Set • Clear • Toggle An event can be generated in each GPIOTE channel from one of the following input conditions: • Rising edge • Falling edge • Any change 6.9.1 Pin events and tasks The GPIOTE module has a number of tasks and events that can be configured to operate on individual GPIO pins. The tasks (SET[n], CLR[n] and OUT[n]) can be used for writing to individual pins, and the events (IN[n]) can be generated from changes occurring at the inputs of individual pins. The SET task will set the pin selected in CONFIG[n].PSEL to high. The CLR task will set the pin low. The effect of the OUT task on the pin is configurable in CONFIG[n].POLARITY , and can either set the pin high, set it low, or toggle it. 1 Rise and fall times based on simulations 4454_140 v1.0 123 Peripherals The tasks and events are configured using the CONFIG[n] registers. Every set of SET, CLR and OUT[n] tasks and IN[n] events has one CONFIG[n] register associated with it. As long as a SET[n], CLR[n] and OUT[n] task or an IN[n] event is configured to control a pin n, the pin's output value will only be updated by the GPIOTE module. The pin's output value as specified in the GPIO will therefore be ignored as long as the pin is controlled by GPIOTE. Attempting to write a pin as a normal GPIO pin will have no effect. When the GPIOTE is disconnected from a pin, see MODE field in CONFIG[n] register, the associated pin will get the output and configuration values specified in the GPIO module. When conflicting tasks are triggered simultaneously (i.e. during the same clock cycle) in one channel, the precedence of the tasks will be as described in Task priorities on page 124. Priority Task 1 OUT 2 CLR 3 SET Table 40: Task priorities When setting the CONFIG[n] registers, MODE=Disabled does not have the same effect as MODE=Task and POLARITY=None. In the latter case, a CLR or SET task occurring at the exact same time as OUT will end up with no change on the pin, according to the priorities described in the table above. When a GPIOTE channel is configured to operate on a pin as a task, the initial value of that pin is configured in the OUTINIT field of CONFIG[n]. 6.9.2 Port event PORT is an event that can be generated from multiple input pins using the GPIO DETECT signal. The event will be generated on the rising edge of the DETECT signal. See GPIO — General purpose input/ output on page 115 for more information about the DETECT signal. Putting the system into System ON IDLE while DETECT is high will not cause DETECT to wake the system up again. Make sure to clear all DETECT sources before entering sleep. If the LATCH register is used as a source, if any bit in LATCH is still high after clearing all or part of the register (for instance due to one of the PINx.DETECT signal still high), a new rising edge will be generated on DETECT, see Pin configuration on page 116. Trying to put the system to System OFF while DETECT is high will cause a wakeup from System OFF reset. This feature is always enabled although the peripheral itself appears to be IDLE, that is, no clocks or other power intensive infrastructure have to be requested to keep this feature enabled. This feature can therefore be used to wake up the CPU from a WFI or WFE type sleep in System ON with all peripherals and the CPU idle, that is, lowest power consumption in System ON mode. In order to prevent spurious interrupts from the PORT event while configuring the sources, the user shall first disable interrupts on the PORT event (through INTENCLR.PORT), then configure the sources (PIN_CNF[n].SENSE), clear any potential event that could have occurred during configuration (write '0' to EVENTS_PORT), and finally enable interrupts (through INTENSET.PORT). 6.9.3 Tasks and events pin configuration Each GPIOTE channel is associated with one physical GPIO pin through the CONFIG.PSEL field. When Event mode is selected in CONFIG.MODE, the pin specified by CONFIG.PSEL will be configured as an input, overriding the DIR setting in GPIO. Similarly, when Task mode is selected in CONFIG.MODE, the pin specified by CONFIG.PSEL will be configured as an output overriding the DIR setting and OUT value in GPIO. When Disabled is selected in CONFIG.MODE, the pin specified by CONFIG.PSEL will use its configuration from the PIN[n].CNF registers in GPIO. 4454_140 v1.0 124 Peripherals Only one GPIOTE channel can be assigned to one physical pin. Failing to do so may result in unpredictable behavior. 6.9.4 Registers Base address Peripheral Instance Description 0x40006000 GPIOTE GPIOTE GPIO tasks and events Configuration Table 41: Instances Register Offset Description TASKS_OUT[0] 0x000 Task for writing to pin specified in CONFIG[0].PSEL. Action on pin is configured in TASKS_OUT[1] 0x004 TASKS_OUT[2] 0x008 TASKS_OUT[3] 0x00C TASKS_OUT[4] 0x010 TASKS_OUT[5] 0x014 TASKS_OUT[6] 0x018 TASKS_OUT[7] 0x01C TASKS_SET[0] 0x030 Task for writing to pin specified in CONFIG[0].PSEL. Action on pin is to set it high. TASKS_SET[1] 0x034 Task for writing to pin specified in CONFIG[1].PSEL. Action on pin is to set it high. TASKS_SET[2] 0x038 Task for writing to pin specified in CONFIG[2].PSEL. Action on pin is to set it high. TASKS_SET[3] 0x03C Task for writing to pin specified in CONFIG[3].PSEL. Action on pin is to set it high. TASKS_SET[4] 0x040 Task for writing to pin specified in CONFIG[4].PSEL. Action on pin is to set it high. TASKS_SET[5] 0x044 Task for writing to pin specified in CONFIG[5].PSEL. Action on pin is to set it high. TASKS_SET[6] 0x048 Task for writing to pin specified in CONFIG[6].PSEL. Action on pin is to set it high. TASKS_SET[7] 0x04C Task for writing to pin specified in CONFIG[7].PSEL. Action on pin is to set it high. TASKS_CLR[0] 0x060 Task for writing to pin specified in CONFIG[0].PSEL. Action on pin is to set it low. TASKS_CLR[1] 0x064 Task for writing to pin specified in CONFIG[1].PSEL. Action on pin is to set it low. TASKS_CLR[2] 0x068 Task for writing to pin specified in CONFIG[2].PSEL. Action on pin is to set it low. TASKS_CLR[3] 0x06C Task for writing to pin specified in CONFIG[3].PSEL. Action on pin is to set it low. TASKS_CLR[4] 0x070 Task for writing to pin specified in CONFIG[4].PSEL. Action on pin is to set it low. TASKS_CLR[5] 0x074 Task for writing to pin specified in CONFIG[5].PSEL. Action on pin is to set it low. TASKS_CLR[6] 0x078 Task for writing to pin specified in CONFIG[6].PSEL. Action on pin is to set it low. TASKS_CLR[7] 0x07C Task for writing to pin specified in CONFIG[7].PSEL. Action on pin is to set it low. EVENTS_IN[0] 0x100 Event generated from pin specified in CONFIG[0].PSEL EVENTS_IN[1] 0x104 Event generated from pin specified in CONFIG[1].PSEL EVENTS_IN[2] 0x108 Event generated from pin specified in CONFIG[2].PSEL EVENTS_IN[3] 0x10C Event generated from pin specified in CONFIG[3].PSEL EVENTS_IN[4] 0x110 Event generated from pin specified in CONFIG[4].PSEL EVENTS_IN[5] 0x114 Event generated from pin specified in CONFIG[5].PSEL EVENTS_IN[6] 0x118 Event generated from pin specified in CONFIG[6].PSEL EVENTS_IN[7] 0x11C Event generated from pin specified in CONFIG[7].PSEL EVENTS_PORT 0x17C Event generated from multiple input GPIO pins with SENSE mechanism enabled INTENSET 0x304 Enable interrupt CONFIG[0].POLARITY. Task for writing to pin specified in CONFIG[1].PSEL. Action on pin is configured in CONFIG[1].POLARITY. Task for writing to pin specified in CONFIG[2].PSEL. Action on pin is configured in CONFIG[2].POLARITY. Task for writing to pin specified in CONFIG[3].PSEL. Action on pin is configured in CONFIG[3].POLARITY. Task for writing to pin specified in CONFIG[4].PSEL. Action on pin is configured in CONFIG[4].POLARITY. Task for writing to pin specified in CONFIG[5].PSEL. Action on pin is configured in CONFIG[5].POLARITY. Task for writing to pin specified in CONFIG[6].PSEL. Action on pin is configured in CONFIG[6].POLARITY. Task for writing to pin specified in CONFIG[7].PSEL. Action on pin is configured in CONFIG[7].POLARITY. 4454_140 v1.0 125 Peripherals Register Offset Description INTENCLR 0x308 Disable interrupt CONFIG[0] 0x510 Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event CONFIG[1] 0x514 Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event CONFIG[2] 0x518 Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event CONFIG[3] 0x51C Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event CONFIG[4] 0x520 Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event CONFIG[5] 0x524 Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event CONFIG[6] 0x528 Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event CONFIG[7] 0x52C Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event Table 42: Register overview 6.9.4.1 TASKS_OUT[n] (n=0..7) Address offset: 0x000 + (n × 0x4) Task for writing to pin specified in CONFIG[n].PSEL. Action on pin is configured in CONFIG[n].POLARITY. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_OUT Task for writing to pin specified in CONFIG[n].PSEL. Action on pin is configured in CONFIG[n].POLARITY. Trigger 1 Trigger task 6.9.4.2 TASKS_SET[n] (n=0..7) Address offset: 0x030 + (n × 0x4) Task for writing to pin specified in CONFIG[n].PSEL. Action on pin is to set it high. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_SET Task for writing to pin specified in CONFIG[n].PSEL. Action on pin is to set it high. Trigger 1 Trigger task 6.9.4.3 TASKS_CLR[n] (n=0..7) Address offset: 0x060 + (n × 0x4) Task for writing to pin specified in CONFIG[n].PSEL. Action on pin is to set it low. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_CLR Task for writing to pin specified in CONFIG[n].PSEL. Action on pin is to set it low. Trigger 4454_140 v1.0 1 Trigger task 126 Peripherals 6.9.4.4 EVENTS_IN[n] (n=0..7) Address offset: 0x100 + (n × 0x4) Event generated from pin specified in CONFIG[n].PSEL Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_IN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated Event generated from pin specified in CONFIG[n].PSEL 6.9.4.5 EVENTS_PORT Address offset: 0x17C Event generated from multiple input GPIO pins with SENSE mechanism enabled Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_PORT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Event generated from multiple input GPIO pins with SENSE mechanism enabled NotGenerated 0 Event not generated Generated 1 Event generated 6.9.4.6 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID I Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-H RW IN[i] (i=0..7) I H G F E D C B A Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event IN[i] RW PORT Write '1' to enable interrupt for event PORT 6.9.4.7 INTENCLR Address offset: 0x308 Disable interrupt 4454_140 v1.0 127 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID I Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-H RW IN[i] (i=0..7) I H G F E D C B A Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event IN[i] RW PORT Write '1' to disable interrupt for event PORT 6.9.4.8 CONFIG[n] (n=0..7) Address offset: 0x510 + (n × 0x4) Configuration for OUT[n], SET[n] and CLR[n] tasks and IN[n] event Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E Reset 0x00000000 ID Access Field A RW MODE D D B B B B B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Mode Disabled 0 Event 1 Disabled. Pin specified by PSEL will not be acquired by the GPIOTE module. Event mode The pin specified by PSEL will be configured as an input and the IN[n] event will be generated if operation specified in POLARITY occurs on the pin. Task 3 Task mode The GPIO specified by PSEL will be configured as an output and triggering the SET[n], CLR[n] or OUT[n] task will perform the operation specified by POLARITY on the pin. When enabled as a task the GPIOTE module will acquire the pin and the pin can no longer be written as a regular output pin from the GPIO module. B RW PSEL D RW POLARITY [0..31] GPIO number associated with SET[n], CLR[n] and OUT[n] tasks and IN[n] event When In task mode: Operation to be performed on output when OUT[n] task is triggered. When In event mode: Operation on input that shall trigger IN[n] event. None 0 Task mode: No effect on pin from OUT[n] task. Event mode: no IN[n] event generated on pin activity. LoToHi 1 HiToLo 2 Task mode: Set pin from OUT[n] task. Event mode: Generate IN[n] event when rising edge on pin. Task mode: Clear pin from OUT[n] task. Event mode: Generate IN[n] event when falling edge on pin. Toggle 3 Task mode: Toggle pin from OUT[n]. Event mode: Generate IN[n] when any change on pin. E RW OUTINIT When in task mode: Initial value of the output when the GPIOTE channel is configured. When in event mode: No effect. Low 4454_140 v1.0 A A 0 Task mode: Initial value of pin before task triggering is low 128 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E Reset 0x00000000 ID Access Field D D B B B B B A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description High 1 Task mode: Initial value of pin before task triggering is high 6.9.5 Electrical specification 6.10 PDM — Pulse density modulation interface The pulse density modulation (PDM) module enables input of pulse density modulated signals from external audio frontends, for example, digital microphones. The PDM module generates the PDM clock and supports single-channel or dual-channel (Left and Right) data input. Data is transferred directly to RAM buffers using EasyDMA. Listed here are the main features for PDM: • • • • Up to two PDM microphones configured as a Left/Right pair using the same data input 16 kHz output sample rate, 16-bit samples EasyDMA support for sample buffering HW decimation filters The PDM module illustrated in PDM module on page 129 is interfacing up to two digital microphones with the PDM interface. It implements EasyDMA, which relieves real-time requirements associated with controlling the PDM slave from a low priority CPU execution context. It also includes all the necessary digital filter elements to produce PCM samples. The PDM module allows continuous audio streaming. CLK Band-pass and Decimation (left) PDM to PCM Band-pass and Decimation (right) RAM PDM to PCM EasyDMA Sampling DIN Master clock generator Figure 41: PDM module 6.10.1 Master clock generator The FREQ field in the master clock's PDMCLKCTRL register allows adjusting the PDM clock's frequency. The master clock generator does not add any jitter to the HFCLK source chosen. It is recommended (but not mandatory) to use the Xtal as HFCLK source. 6.10.2 Module operation By default, bits from the left PDM microphone are sampled on PDM_CLK falling edge, bits for the right are sampled on the rising edge of PDM_CLK, resulting in two bitstreams. Each bitstream is fed into a digital filter which converts the PDM stream into 16-bit PCM samples, and filters and down-samples them to reach the appropriate sample rate. 4454_140 v1.0 129 Peripherals The EDGE field in the MODE register allows swapping Left and Right, so that Left will be sampled on rising edge, and Right on falling. The PDM module uses EasyDMA to store the samples coming out from the filters into one buffer in RAM. Depending on the mode chosen in the OPERATION field in the MODE register, memory either contains alternating left and right 16-bit samples (Stereo), or only left 16-bit samples (Mono). To ensure continuous PDM sampling, it is up to the application to update the EasyDMA destination address pointer as the previous buffer is filled. The continuous transfer can be started or stopped by sending the START and STOP tasks. STOP becomes effective after the current frame has finished transferring, which will generate the STOPPED event. The STOPPED event indicates that all activity in the module are finished, and that the data is available in RAM (EasyDMA has finished transferring as well). Attempting to restart before receiving the STOPPED event may result in unpredictable behaviour. 6.10.3 Decimation filter In order to convert the incoming data stream into PCM audio samples, a decimation filter is included in the PDM interface module. The input of the filter is the two-channel PDM serial stream (with left channel on clock high, right channel on clock low), its output is 2 × 16-bit PCM samples at a sample rate 64 times lower than the PDM clock rate. The filter stage of each channel is followed by a digital volume control, to attenuate or amplify the output samples in a range of -20 dB to +20 dB around the default (reset) setting, defined by GPDM,default. The gain is controlled by the GAINL and GAINR registers. As an example, if the goal is to achieve 2500 RMS output samples (16 bit) with a 1 kHz 90 dBA signal into a -26 dBFS sensitivity PDM microphone, the user will have to sum the PDM module's default gain ( GPDM,default ) and the gain introduced by the microphone and acoustic path of his implementation (an attenuation would translate into a negative gain), and adjust GAINL and GAINR by this amount. Assuming that only the PDM module influences the gain, GAINL and GAINR must be set to -GPDM,default dB to achieve the requirement. With GPDM,default=3.2 dB, and as GAINL and GAINR are expressed in 0.5 dB steps, the closest value to program would be 3.0 dB, which can be calculated as: GAINL = GAINR = (DefaultGain - (2 * 3)) Remember to check that the resulting values programmed into GAINL and GAINR fall within MinGain and MaxGain. 6.10.4 EasyDMA Samples will be written directly to RAM, and EasyDMA must be configured accordingly. The address pointer for the EasyDMA channel is set in SAMPLE.PTR register. If the destination address set in SAMPLE.PTR is not pointing to the Data RAM region, an EasyDMA transfer may result in a HardFault or RAM corruption. See Memory on page 16 for more information about the different memory regions. DMA supports Stereo (Left+Right 16-bit samples) and Mono (Left only) data transfer, depending on setting in the OPERATION field in the MODE register. The samples are stored little endian. 4454_140 v1.0 130 Peripherals MODE.OPERATION Bits per sample Stereo 32 (2x16) Mono 16 Result stored per RAM Physical RAM allocated Result boundary indexes Note word (32 bit words) in RAM L+R ceil(SAMPLE.MAXCNT/2) R0=[31:16]; L0=[15:0] 2xL ceil(SAMPLE.MAXCNT/2) L1=[31:16]; L0=[15:0] Default Table 43: DMA sample storage The destination buffer in RAM consists of one block, the size of which is set in SAMPLE.MAXCNT register. Format is number of 16-bit samples. The physical RAM allocated is always: (RAM allocation, in bytes) = SAMPLE.MAXCNT * 2; (but the mapping of the samples depends on MODE.OPERATION. If OPERATION=Stereo, RAM will contain a succession of Left and Right samples. If OPERATION=Mono, RAM will contain a succession of mono samples. For a given value of SAMPLE.MAXCNT, the buffer in RAM can contain half the stereo sampling time as compared to the mono sampling time. The PDM acquisition can be started by the START task, after the SAMPLE.PTR and SAMPLE.MAXCNT registers have been written. When starting the module, it will take some time for the filters to start outputting valid data. Transients from the PDM microphone itself may also occur. The first few samples (typically around 50) might hence contain invalid values or transients. It is therefore advised to discard the first few samples after a PDM start. As soon as the STARTED event is received, the firmware can write the next SAMPLE.PTR value (this register is double-buffered), to ensure continuous operation. When the buffer in RAM is filled with samples, an END event is triggered. The firmware can start processing the data in the buffer. Meanwhile, the PDM module starts acquiring data into the new buffer pointed to by SAMPLE.PTR, and sends a new STARTED event, so that the firmware can update SAMPLE.PTR to the next buffer address. 6.10.5 Hardware example Connect the microphone clock to CLK, and data to DIN. Vdd L/R nRFxxxxx CLK CLK DATA DIN CLK DIN Figure 42: Example of a single PDM microphone, wired as left Vdd L/R nRFxxxxx CLK CLK DATA DIN CLK DIN Figure 43: Example of a single PDM microphone, wired as right 4454_140 v1.0 131 Peripherals Note that in a single-microphone (mono) configuration, depending on the microphone’s implementation, either the left or the right channel (sampled at falling or rising CLK edge respectively) will contain reliable data. If two microphones are used, one of them has to be set as left, the other as right (L/R pin tied high or to GND on the respective microphone). It is strongly recommended to use two microphones of exactly the same brand and type so that their timings in left and right operation match. Vdd L/R nRFxxxxx CLK CLK DATA DIN Vdd CLK L/R DATA CLK DIN Figure 44: Example of two PDM microphones 6.10.6 Pin configuration The CLK and DIN signals associated to the PDM module are mapped to physical pins according to the configuration specified in the PSEL.CLK and PSEL.DIN registers respectively. If the CONNECT field in any PSEL register is set to Disconnected, the associated PDM module signal will not be connected to the required physical pins, and will not operate properly. The PSEL.CLK and PSEL.DIN registers and their configurations are only used as long as the PDM module is enabled, and retained only as long as the device is in System ON mode. See POWER — Power supply on page 48 for more information about power modes. When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. To ensure correct behaviour in the PDM module, the pins used by the PDM module must be configured in the GPIO peripheral as described in GPIO configuration before enabling peripheral on page 132 before enabling the PDM module. This is to ensure that the pins used by the PDM module are driven correctly if the PDM module itself is temporarily disabled or the device temporarily enters System OFF. This configuration must be retained in the GPIO for the selected I/Os as long as the PDM module is supposed to be connected to an external PDM circuit. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behaviour. PDM signal PDM pin Direction Output value CLK As specified in PSEL.CLK Output 0 DIN As specified in PSEL.DIN Input Not applicable Table 44: GPIO configuration before enabling peripheral 6.10.7 Registers Base address Peripheral Instance Description 0x4001D000 PDM PDM Pulse-density modulation (digital Configuration microphone interface) Table 45: Instances 4454_140 v1.0 132 Comment Peripherals Register Offset Description TASKS_START 0x000 Starts continuous PDM transfer TASKS_STOP 0x004 Stops PDM transfer EVENTS_STARTED 0x100 PDM transfer has started EVENTS_STOPPED 0x104 PDM transfer has finished EVENTS_END 0x108 The PDM has written the last sample specified by SAMPLE.MAXCNT (or the last sample after a INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 PDM module enable register PDMCLKCTRL 0x504 PDM clock generator control MODE 0x508 Defines the routing of the connected PDM microphones' signals GAINL 0x518 Left output gain adjustment GAINR 0x51C Right output gain adjustment PSEL.CLK 0x540 Pin number configuration for PDM CLK signal PSEL.DIN 0x544 Pin number configuration for PDM DIN signal SAMPLE.PTR 0x560 RAM address pointer to write samples to with EasyDMA SAMPLE.MAXCNT 0x564 Number of samples to allocate memory for in EasyDMA mode STOP task has been received) to Data RAM Table 46: Register overview 6.10.7.1 TASKS_START Address offset: 0x000 Starts continuous PDM transfer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_START Starts continuous PDM transfer Trigger task 6.10.7.2 TASKS_STOP Address offset: 0x004 Stops PDM transfer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_STOP Stops PDM transfer Trigger task 6.10.7.3 EVENTS_STARTED Address offset: 0x100 PDM transfer has started 4454_140 v1.0 133 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_STARTED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated PDM transfer has started 6.10.7.4 EVENTS_STOPPED Address offset: 0x104 PDM transfer has finished Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_STOPPED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated PDM transfer has finished 6.10.7.5 EVENTS_END Address offset: 0x108 The PDM has written the last sample specified by SAMPLE.MAXCNT (or the last sample after a STOP task has been received) to Data RAM Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_END 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description The PDM has written the last sample specified by SAMPLE.MAXCNT (or the last sample after a STOP task has been received) to Data RAM NotGenerated 0 Event not generated Generated 1 Event generated 6.10.7.6 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B A Reset 0x00000000 ID Access Field A RW STARTED B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Enable or disable interrupt for event STARTED RW STOPPED 4454_140 v1.0 Enable or disable interrupt for event STOPPED 134 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B A Reset 0x00000000 ID Access Field C RW END 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable interrupt for event END 6.10.7.7 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B A Reset 0x00000000 ID Access Field A RW STARTED B C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to enable interrupt for event STARTED RW STOPPED Write '1' to enable interrupt for event STOPPED RW END Write '1' to enable interrupt for event END 6.10.7.8 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C B A Reset 0x00000000 ID Access Field A RW STARTED B C 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event STARTED RW STOPPED Write '1' to disable interrupt for event STOPPED RW END 4454_140 v1.0 Write '1' to disable interrupt for event END 135 Peripherals 6.10.7.9 ENABLE Address offset: 0x500 PDM module enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable PDM module 6.10.7.10 PDMCLKCTRL Address offset: 0x504 PDM clock generator control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x08400000 0 0 0 0 1 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW FREQ Value ID Value Description 1000K 0x08000000 PDM_CLK = 32 MHz / 32 = 1.000 MHz Default 0x08400000 PDM_CLK = 32 MHz / 31 = 1.032 MHz 1067K 0x08800000 PDM_CLK = 32 MHz / 30 = 1.067 MHz PDM_CLK frequency 6.10.7.11 MODE Address offset: 0x508 Defines the routing of the connected PDM microphones' signals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B A Reset 0x00000000 ID Access Field A RW OPERATION 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Stereo 0 Mono 1 Description Mono or stereo operation Sample and store one pair (Left + Right) of 16bit samples per RAM word R=[31:16]; L=[15:0] Sample and store two successive Left samples (16 bit each) per RAM word L1=[31:16]; L0=[15:0] B RW EDGE Defines on which PDM_CLK edge Left (or mono) is sampled LeftFalling 0 Left (or mono) is sampled on falling edge of PDM_CLK LeftRising 1 Left (or mono) is sampled on rising edge of PDM_CLK 6.10.7.12 GAINL Address offset: 0x518 Left output gain adjustment 4454_140 v1.0 136 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x00000028 ID Access Field A RW GAINL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 Value ID Value Description Left output gain adjustment, in 0.5 dB steps, around the default module gain (see electrical parameters) 0x00 -20 dB gain adjust 0x01 -19.5 dB gain adjust (...) 0x27 -0.5 dB gain adjust 0x28 0 dB gain adjust 0x29 +0.5 dB gain adjust (...) 0x4F +19.5 dB gain adjust 0x50 +20 dB gain adjust MinGain 0x00 -20dB gain adjustment (minimum) DefaultGain 0x28 0dB gain adjustment ('2500 RMS' requirement) MaxGain 0x50 +20dB gain adjustment (maximum) 6.10.7.13 GAINR Address offset: 0x51C Right output gain adjustment Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000028 ID Access Field A RW GAINR 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 Value ID Value Description Right output gain adjustment, in 0.5 dB steps, around the default module gain (see electrical parameters) MinGain 0x00 -20dB gain adjustment (minimum) DefaultGain 0x28 0dB gain adjustment ('2500 RMS' requirement) MaxGain 0x50 +20dB gain adjustment (maximum) 6.10.7.14 PSEL.CLK Address offset: 0x540 Pin number configuration for PDM CLK signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A RW PIN B RW CONNECT 4454_140 v1.0 Value ID A A A A A Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 137 Peripherals 6.10.7.15 PSEL.DIN Address offset: 0x544 Pin number configuration for PDM DIN signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A RW PIN Value ID B RW CONNECT A A A A A Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 6.10.7.16 SAMPLE.PTR Address offset: 0x560 RAM address pointer to write samples to with EasyDMA Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW SAMPLEPTR Value ID Value Description Address to write PDM samples to over DMA 6.10.7.17 SAMPLE.MAXCNT Address offset: 0x564 Number of samples to allocate memory for in EasyDMA mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field Value ID A RW BUFFSIZE Value Description [0..32767] Length of DMA RAM allocation in number of samples 6.10.8 Electrical specification 6.10.8.1 PDM Electrical Specification Symbol Description fPDM,CLK PDM clock speed tPDM,JITTER Jitter in PDM clock output TdPDM,CLK PDM clock duty cycle tPDM,DATA tPDM,cv tPDM,ci Allowed (other) clock edge to data invalid 0 ns tPDM,s Data setup time at fPDM,CLK=1.024 MHz 65 ns tPDM,h Data hold time at fPDM,CLK=1.024 MHz 0 GPDM,default Default (reset) absolute gain of the PDM module 4454_140 v1.0 Min. Typ. Max. 1.032 Units MHz 20 ns 60 % Decimation filter delay 5 ms Allowed clock edge to data valid 125 ns 40 50 ns 3.2 138 dB Peripherals tPDM,CLK CLK tPDM,cv tPDM,s tPDM,h=tPDM,ci DIN (L) tPDM,cv tPDM,s tPDM,h=tPDM,ci DIN(R) Figure 45: PDM timing diagram 6.11 PPI — Programmable peripheral interconnect The programmable peripheral interconnect (PPI) enables peripherals to interact autonomously with each other using tasks and events independent of the CPU. The PPI allows precise synchronization between peripherals when real-time application constraints exist and eliminates the need for CPU activity to implement behavior which can be predefined using PPI. CH[1].EEP CH[0].EEP Peripheral 1 Peripheral 2 CH[n].EEP Event 1 Event 2 Event 1 Event 2 Event 3 0 0 0 1 1 1 n n n CHEN CHG[0] ... CHG[m] 16MHz Task 1 Task 1 Task 2 Task 3 CH[0].TEP Peripheral 1 Peripheral 2 FORK[0].TEP Figure 46: PPI block diagram The PPI system has, in addition to the fully programmable peripheral interconnections, a set of channels where the event end point (EEP) and task end points (TEP) are fixed in hardware. These fixed channels can be individually enabled, disabled, or added to PPI channel groups (see CHG[n] registers), in the same way as ordinary PPI channels. 4454_140 v1.0 139 Peripherals Instance Channel Number of channels PPI 0-19 20 PPI (fixed) 20-31 12 Table 47: Configurable and fixed PPI channels The PPI provides a mechanism to automatically trigger a task in one peripheral as a result of an event occurring in another peripheral. A task is connected to an event through a PPI channel. The PPI channel is composed of three end point registers, one EEP and two TEPs. A peripheral task is connected to a TEP using the address of the task register associated with the task. Similarly, a peripheral event is connected to an EEP using the address of the event register associated with the event. On each PPI channel, the signals are synchronized to the 16 MHz clock, to avoid any internal violation of setup and hold timings. As a consequence, events that are synchronous to the 16 MHz clock will be delayed by one clock period, while other asynchronous events will be delayed by up to one 16 MHz clock period. Note that shortcuts (as defined in the SHORTS register in each peripheral) are not affected by this 16 MHz synchronization, and are therefore not delayed. Each TEP implements a fork mechanism that enables a second task to be triggered at the same time as the task specified in the TEP is triggered. This second task is configured in the task end point register in the FORK registers groups, e.g. FORK.TEP[0] is associated with PPI channel CH[0]. There are two ways of enabling and disabling PPI channels: • Enable or disable PPI channels individually using the CHEN, CHENSET, and CHENCLR registers. • Enable or disable PPI channels in PPI channel groups through the groups’ ENABLE and DISABLE tasks. Prior to these tasks being triggered, the PPI channel group must be configured to define which PPI channels belong to which groups. Note that when a channel belongs to two groups m and n, and the tasks CHG[m].EN and CHG[n].DIS occur simultaneously (m and n can be equal or different), the CHG[m].EN on that channel has priority. PPI tasks (for example, CHG[0].EN) can be triggered through the PPI like any other task, which means they can be hooked to a PPI channel as a TEP. One event can trigger multiple tasks by using multiple channels and one task can be triggered by multiple events in the same way. 6.11.1 Pre-programmed channels Some of the PPI channels are pre-programmed. These channels cannot be configured by the CPU, but can be added to groups and enabled and disabled like the general purpose PPI channels. The FORK TEP for these channels are still programmable and can be used by the application. For a list of pre-programmed PPI channels, see the table below. 4454_140 v1.0 140 Peripherals Channel EEP TEP 20 TIMER0->EVENTS_COMPARE[0] RADIO->TASKS_TXEN 21 TIMER0->EVENTS_COMPARE[0] RADIO->TASKS_RXEN 22 TIMER0->EVENTS_COMPARE[1] RADIO->TASKS_DISABLE 23 RADIO->EVENTS_BCMATCH AAR->TASKS_START 24 RADIO->EVENTS_READY CCM->TASKS_KSGEN 25 RADIO->EVENTS_ADDRESS CCM->TASKS_CRYPT 26 RADIO->EVENTS_ADDRESS TIMER0->TASKS_CAPTURE[1] 27 RADIO->EVENTS_END TIMER0->TASKS_CAPTURE[2] 28 RTC0->EVENTS_COMPARE[0] RADIO->TASKS_TXEN 29 RTC0->EVENTS_COMPARE[0] RADIO->TASKS_RXEN 30 RTC0->EVENTS_COMPARE[0] TIMER0->TASKS_CLEAR 31 RTC0->EVENTS_COMPARE[0] TIMER0->TASKS_START Table 48: Pre-programmed channels 6.11.2 Registers Base address Peripheral Instance Description Configuration 0x4001F000 PPI PPI Programmable peripheral interconnect Table 49: Instances Register Offset Description TASKS_CHG[0].EN 0x000 Enable channel group 0 TASKS_CHG[0].DIS 0x004 Disable channel group 0 TASKS_CHG[1].EN 0x008 Enable channel group 1 TASKS_CHG[1].DIS 0x00C Disable channel group 1 TASKS_CHG[2].EN 0x010 Enable channel group 2 TASKS_CHG[2].DIS 0x014 Disable channel group 2 TASKS_CHG[3].EN 0x018 Enable channel group 3 TASKS_CHG[3].DIS 0x01C Disable channel group 3 TASKS_CHG[4].EN 0x020 Enable channel group 4 TASKS_CHG[4].DIS 0x024 Disable channel group 4 TASKS_CHG[5].EN 0x028 Enable channel group 5 TASKS_CHG[5].DIS 0x02C Disable channel group 5 CHEN 0x500 Channel enable register CHENSET 0x504 Channel enable set register CHENCLR 0x508 Channel enable clear register CH[0].EEP 0x510 Channel 0 event end-point CH[0].TEP 0x514 Channel 0 task end-point CH[1].EEP 0x518 Channel 1 event end-point CH[1].TEP 0x51C Channel 1 task end-point CH[2].EEP 0x520 Channel 2 event end-point CH[2].TEP 0x524 Channel 2 task end-point CH[3].EEP 0x528 Channel 3 event end-point CH[3].TEP 0x52C Channel 3 task end-point CH[4].EEP 0x530 Channel 4 event end-point CH[4].TEP 0x534 Channel 4 task end-point CH[5].EEP 0x538 Channel 5 event end-point CH[5].TEP 0x53C Channel 5 task end-point CH[6].EEP 0x540 Channel 6 event end-point CH[6].TEP 0x544 Channel 6 task end-point 4454_140 v1.0 141 Peripherals Register Offset Description CH[7].EEP 0x548 Channel 7 event end-point CH[7].TEP 0x54C Channel 7 task end-point CH[8].EEP 0x550 Channel 8 event end-point CH[8].TEP 0x554 Channel 8 task end-point CH[9].EEP 0x558 Channel 9 event end-point CH[9].TEP 0x55C Channel 9 task end-point CH[10].EEP 0x560 Channel 10 event end-point CH[10].TEP 0x564 Channel 10 task end-point CH[11].EEP 0x568 Channel 11 event end-point CH[11].TEP 0x56C Channel 11 task end-point CH[12].EEP 0x570 Channel 12 event end-point CH[12].TEP 0x574 Channel 12 task end-point CH[13].EEP 0x578 Channel 13 event end-point CH[13].TEP 0x57C Channel 13 task end-point CH[14].EEP 0x580 Channel 14 event end-point CH[14].TEP 0x584 Channel 14 task end-point CH[15].EEP 0x588 Channel 15 event end-point CH[15].TEP 0x58C Channel 15 task end-point CH[16].EEP 0x590 Channel 16 event end-point CH[16].TEP 0x594 Channel 16 task end-point CH[17].EEP 0x598 Channel 17 event end-point CH[17].TEP 0x59C Channel 17 task end-point CH[18].EEP 0x5A0 Channel 18 event end-point CH[18].TEP 0x5A4 Channel 18 task end-point CH[19].EEP 0x5A8 Channel 19 event end-point CH[19].TEP 0x5AC Channel 19 task end-point CHG[0] 0x800 Channel group 0 CHG[1] 0x804 Channel group 1 CHG[2] 0x808 Channel group 2 CHG[3] 0x80C Channel group 3 CHG[4] 0x810 Channel group 4 CHG[5] 0x814 Channel group 5 FORK[0].TEP 0x910 Channel 0 task end-point FORK[1].TEP 0x914 Channel 1 task end-point FORK[2].TEP 0x918 Channel 2 task end-point FORK[3].TEP 0x91C Channel 3 task end-point FORK[4].TEP 0x920 Channel 4 task end-point FORK[5].TEP 0x924 Channel 5 task end-point FORK[6].TEP 0x928 Channel 6 task end-point FORK[7].TEP 0x92C Channel 7 task end-point FORK[8].TEP 0x930 Channel 8 task end-point FORK[9].TEP 0x934 Channel 9 task end-point FORK[10].TEP 0x938 Channel 10 task end-point FORK[11].TEP 0x93C Channel 11 task end-point FORK[12].TEP 0x940 Channel 12 task end-point FORK[13].TEP 0x944 Channel 13 task end-point FORK[14].TEP 0x948 Channel 14 task end-point FORK[15].TEP 0x94C Channel 15 task end-point FORK[16].TEP 0x950 Channel 16 task end-point FORK[17].TEP 0x954 Channel 17 task end-point FORK[18].TEP 0x958 Channel 18 task end-point FORK[19].TEP 0x95C Channel 19 task end-point FORK[20].TEP 0x960 Channel 20 task end-point 4454_140 v1.0 142 Peripherals Register Offset Description FORK[21].TEP 0x964 Channel 21 task end-point FORK[22].TEP 0x968 Channel 22 task end-point FORK[23].TEP 0x96C Channel 23 task end-point FORK[24].TEP 0x970 Channel 24 task end-point FORK[25].TEP 0x974 Channel 25 task end-point FORK[26].TEP 0x978 Channel 26 task end-point FORK[27].TEP 0x97C Channel 27 task end-point FORK[28].TEP 0x980 Channel 28 task end-point FORK[29].TEP 0x984 Channel 29 task end-point FORK[30].TEP 0x988 Channel 30 task end-point FORK[31].TEP 0x98C Channel 31 task end-point Table 50: Register overview 6.11.2.1 TASKS_CHG[n].EN (n=0..5) Address offset: 0x000 + (n × 0x8) Enable channel group n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description EN Enable channel group n Trigger 1 Trigger task 6.11.2.2 TASKS_CHG[n].DIS (n=0..5) Address offset: 0x004 + (n × 0x8) Disable channel group n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description DIS Disable channel group n Trigger task 6.11.2.3 CHEN Address offset: 0x500 Channel enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID f Reset 0x00000000 ID Access Field A-f RW CH[i] (i=0..31) 4454_140 v1.0 e d c b a Z Y X W V U T S R Q P O N M L K J I H G F E D C B A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable channel Enabled 1 Enable channel Enable or disable channel i 143 Peripherals 6.11.2.4 CHENSET Address offset: 0x504 Channel enable set register Read: reads value of CH{i} field in CHEN register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID f Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-f RW CH[i] (i=0..31) e d c b a Z Y X W V U T S R Q P O N M L K J I H G F E D C B A Value ID Value Description Disabled 0 Read: channel disabled Enabled 1 Read: channel enabled Set 1 Write: Enable channel Channel i enable set register. Writing '0' has no effect 6.11.2.5 CHENCLR Address offset: 0x508 Channel enable clear register Read: reads value of CH{i} field in CHEN register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID f Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-f RW CH[i] (i=0..31) e d c b a Z Y X W V U T S R Q P O N M L K J I H G F E D C B A Value ID Value Description Disabled 0 Read: channel disabled Enabled 1 Read: channel enabled Clear 1 Write: disable channel Channel i enable clear register. Writing '0' has no effect 6.11.2.6 CH[n].EEP (n=0..19) Address offset: 0x510 + (n × 0x8) Channel n event end-point Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW EEP Value ID Value Description Pointer to event register. Accepts only addresses to registers from the Event group. 6.11.2.7 CH[n].TEP (n=0..19) Address offset: 0x514 + (n × 0x8) Channel n task end-point 4454_140 v1.0 144 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW TEP Value ID Value Description Pointer to task register. Accepts only addresses to registers from the Task group. 6.11.2.8 CHG[n] (n=0..5) Address offset: 0x800 + (n × 0x4) Channel group n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID f Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-f RW CH[i] (i=0..31) e d c b a Z Y X W V U T S R Q P O N M L K J I H G F E D C B A Value ID Value Description Excluded 0 Exclude Included 1 Include Include or exclude channel i 6.11.2.9 FORK[n].TEP (n=0..31) Address offset: 0x910 + (n × 0x4) Channel n task end-point Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW TEP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Pointer to task register 6.12 PWM — Pulse width modulation The pulse with modulation (PWM) module enables the generation of pulse width modulated signals on GPIO. The module implements an up or up-and-down counter with four PWM channels that drive assigned GPIOs. The following are the main features of a PWM module: • • • • • Programmable PWM frequency Up to four PWM channels with individual polarity and duty cycle values Edge or center-aligned pulses across PWM channels Multiple duty cycle arrays (sequences) defined in RAM Autonomous and glitch-free update of duty cycle values directly from memory through EasyDMA (no CPU involvement) • Change of polarity, duty cycle, and base frequency possibly on every PWM period • RAM sequences can be repeated or connected into loops 4454_140 v1.0 145 Peripherals Sequence 0 DATA RAM STARTED STOPPED EasyDMA START Sequence 1 PWM STOP SEQSTART[0] SEQSTART[1] SEQ[n].REFRESH SEQSTARTED[0] SEQSTARTED[1] SEQEND[0] SEQEND[1] Decoder NEXTSTEP Carry/Reload COMP0 PSEL.OUT[0] COMP1 PSEL.OUT[1] COMP2 PSEL.OUT[2] COMP3 PSEL.OUT[3] Wave Counter PWM_CLK COUNTERTOP PRESCALER Figure 47: PWM module 6.12.1 Wave counter The wave counter is responsible for generating the pulses at a duty cycle that depends on the compare values, and at a frequency that depends on COUNTERTOP. There is one common 15-bit counter with four compare channels. Thus, all four channels will share the same period (PWM frequency), but can have individual duty cycle and polarity. The polarity is set by a value read from RAM (see figure Decoder memory access modes on page 149). Whether the counter counts up, or up and down, is controlled by the MODE register. The timer top value is controlled by the COUNTERTOP register. This register value, in conjunction with the selected PRESCALER of the PWM_CLK, will result in a given PWM period. A COUNTERTOP value smaller than the compare setting will result in a state where no PWM edges are generated. OUT[n] is held high, given that the polarity is set to FallingEdge. All compare registers are internal and can only be configured through decoder presented later. COUNTERTOP can be safely written at any time. Sampling follows the START task. If DECODER.LOAD=WaveForm, the register value is ignored and taken from RAM instead (see section Decoder with EasyDMA on page 149 for more details). If DECODER.LOAD is anything else than the WaveForm, it is sampled following a STARTSEQ[n] task and when loading a new value from RAM during a sequence playback. The following figure shows the counter operating in up mode (MODE=PWM_MODE_Up), with three PWM channels with the same frequency but different duty cycle: 4454_140 v1.0 146 Peripherals COUNTERTOP COMP1 COMP0 OUT[0] OUT[1] Figure 48: PWM counter in up mode example - FallingEdge polarity The counter is automatically reset to zero when COUNTERTOP is reached and OUT[n] will invert. OUT[n] is held low if the compare value is 0 and held high if set to COUNTERTOP, given that the polarity is set to FallingEdge. Counter running in up mode results in pulse widths that are edge-aligned. The following is the code for the counter in up mode example: uint16_t pwm_seq[4] = {PWM_CH0_DUTY, PWM_CH1_DUTY, PWM_CH2_DUTY, PWM_CH3_DUTY}; NRF_PWM0->PSEL.OUT[0] = (first_pin PSEL.OUT[0] = (first_pin PSEL.OUT[0] = (first_pin DECODER = (PWM_LOOP_CNT_Disabled SEQ[0].PTR = (PWM_DECODER_LOAD_Common SEQ[0].CNT (PWM_DECODER_MODE_RefreshCount TASKS_SEQSTART[0] = 1; To completely stop the PWM generation and force the associated pins to a defined state, a STOP task can be triggered at any time. A STOPPED event is generated when the PWM generation has stopped at the end of currently running PWM period, and the pins go into their idle state as defined in GPIO OUT register. PWM generation can then only be restarted through a SEQSTART[n] task. SEQSTART[n] will resume PWM generation after having loaded the first value from the RAM buffer defined in the SEQ[n].PTR register. The table below indicates when specific registers get sampled by the hardware. Care should be taken when updating these registers to avoid that values are applied earlier than expected. 4454_140 v1.0 151 Peripherals Register Taken into account by hardware Recommended (safe) update SEQ[n].PTR When sending the SEQSTART[n] task After having received the SEQSTARTED[n] event SEQ[n].CNT When sending the SEQSTART[n] task After having received the SEQSTARTED[n] event SEQ[0].ENDDELAY When sending the SEQSTART[0] task Before starting sequence [0] through a SEQSTART[0] task Every time a new value from sequence [0] has been loaded from When no more value from sequence [0] gets loaded from RAM RAM and gets applied to the Wave Counter (indicated by the (indicated by the SEQEND[0] event) PWMPERIODEND event) At any time during sequence [1] (which starts when the SEQSTARTED[1] event is generated) SEQ[1].ENDDELAY When sending the SEQSTART[1] task Before starting sequence [1] through a SEQSTART[1] task Every time a new value from sequence [1] has been loaded from When no more value from sequence [1] gets loaded from RAM RAM and gets applied to the Wave Counter (indicated by the (indicated by the SEQEND[1] event) PWMPERIODEND event) At any time during sequence [0] (which starts when the SEQSTARTED[0] event is generated) SEQ[0].REFRESH When sending the SEQSTART[0] task Before starting sequence [0] through a SEQSTART[0] task Every time a new value from sequence [0] has been loaded from At any time during sequence [1] (which starts when the RAM and gets applied to the Wave Counter (indicated by the SEQSTARTED[1] event is generated) PWMPERIODEND event) SEQ[1].REFRESH When sending the SEQSTART[1] task Before starting sequence [1] through a SEQSTART[1] task Every time a new value from sequence [1] has been loaded from At any time during sequence [0] (which starts when the RAM and gets applied to the Wave Counter (indicated by the SEQSTARTED[0] event is generated) PWMPERIODEND event) COUNTERTOP MODE In DECODER.LOAD=WaveForm: this register is ignored. Before starting PWM generation through a SEQSTART[n] task In all other LOAD modes: at the end of current PWM period After a STOP task has been triggered, and the STOPPED event has (indicated by the PWMPERIODEND event) been received. Immediately Before starting PWM generation through a SEQSTART[n] task After a STOP task has been triggered, and the STOPPED event has been received. DECODER Immediately Before starting PWM generation through a SEQSTART[n] task After a STOP task has been triggered, and the STOPPED event has been received. PRESCALER Immediately Before starting PWM generation through a SEQSTART[n] task After a STOP task has been triggered, and the STOPPED event has been received. LOOP Immediately Before starting PWM generation through a SEQSTART[n] task After a STOP task has been triggered, and the STOPPED event has been received. PSEL.OUT[n] Immediately Before enabling the PWM instance through the ENABLE register Table 51: When to safely update PWM registers Note: SEQ[n].REFRESH and SEQ[n].ENDDELAY are ignored at the end of a complex sequence, indicated by a LOOPSDONE event. The reason for this is that the last value loaded from RAM is maintained until further action from software (restarting a new sequence, or stopping PWM generation). A more complex example, where LOOP.CNT>0, is shown in the following figure: 4454_140 v1.0 152 Peripherals SEQ[0].CNT=2, SEQ[1].CNT=3, SEQ[0].REFRESH=1, SEQ[1].REFRESH=0, SEQ[0].ENDDELAY=1, SEQ[1].ENDDELAY=0, LOOP.CNT=1 SEQ[0].PTR P O COMPARE L PWM clock period Event/Tasks SEQSTART[0] P O COMPARE L (continued below) SEQSTARTED[0] SEQEND[0] SEQ[1].PTR 1 PWM period SEQ[0].ENDDELAY=1 (continuation) P O COMPARE L P O COMPARE L PWM generation maintains last played value Event/Tasks SEQSTARTED[1] SEQEND[1] LOOPSDONE Figure 52: Example using two sequences In this case, an automated playback takes place, consisting of SEQ[0], delay 0, SEQ[1], delay 1, then again SEQ[0], etc. The user can choose to start a complex playback with SEQ[0] or SEQ[1] through sending the SEQSTART[0] or SEQSTART[1] task. The complex playback always ends with delay 1. The two sequences 0 and 1 are defined by the addresses of value tables in RAM (pointed to by SEQ[n].PTR) and the buffer size (SEQ[n].CNT). The rate at which a new value is loaded is defined individually for each sequence by SEQ[n].REFRESH. The chaining of sequence 1 following the sequence 0 is implicit, the LOOP.CNT register allows the chaining of sequence 1 to sequence 0 for a determined number of times. In other words, it allows to repeat a complex sequence a number of times in a fully automated way. In the following code example, sequence 0 is defined with SEQ[0].REFRESH set to 1, meaning that a new PWM duty cycle is pushed every second PWM period. This complex sequence is started with the SEQSTART[0] task, so SEQ[0] is played first. Since SEQ[0].ENDDELAY=1 there will be one PWM period delay between last period on sequence 0 and the first period on sequence 1. Since SEQ[1].ENDDELAY=0 there is no delay 1, so SEQ[0] would be started immediately after the end of SEQ[1]. However, as LOOP.CNT is 4454_140 v1.0 153 Peripherals 1, the playback stops after having played SEQ[1] only once, and both SEQEND[1] and LOOPSDONE are generated (their order is not guaranteed in this case). NRF_PWM0->PSEL.OUT[0] = (first_pin DECODER = (1 SEQ[0].PTR = (PWM_DECODER_LOAD_Common SEQ[0].CNT (PWM_DECODER_MODE_RefreshCount SEQ[1].PTR NRF_PWM0->SEQ[1].CNT = ((uint32_t)(seq1_ram) SEQ[1].ENDDELAY = 0; NRF_PWM0->TASKS_SEQSTART[0] = 1; The decoder can also be configured to asynchronously load new PWM duty cycle. If the DECODER.MODE register is set to NextStep, then the NEXTSTEP task will cause an update of internal compare registers on the next PWM period. The following figures provide an overview of each part of an arbitrary sequence, in various modes (LOOP.CNT=0 and LOOP.CNT>0). In particular, the following are represented: • • • • • Initial and final duty cycle on the PWM output(s) Chaining of SEQ[0] and SEQ[1] if LOOP.CNT>0 Influence of registers on the sequence Events generated during a sequence DMA activity (loading of next value and applying it to the output(s)) 4454_140 v1.0 154 4454_140 v1.0 155 Figure 54: Complex sequence (LOOP.CNT>0) starting with SEQ[0] SEQ[1].ENDDELA Y SEQ[1].CNT SEQ[0].ENDDELA Y SEQ[0].CNT SEQ[1].CNT (LOOP.CNT - 1) ... EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] EVENTS_LOOPSDONE EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] SEQ[0].ENDDELA Y SEQ[0].CNT SEQ[1].ENDDELA Y SEQ[1].CNT LOOP.CNT EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] SEQ[0].ENDDELA Y SEQ[0].CNT Loop counter EVENTS_SEQEND[0] TASKS_SEQSTART[0] EVENTS_SEQSTARTED[0] EVENTS_SEQEND[0] TASKS_SEQSTART[0] EVENTS_SEQSTARTED[0] SEQ[0].ENDDELA Y SEQ[0].CNT Peripherals 100% duty cycle last loaded duty cycle maintained Previously loaded duty cycle New value load 0% duty cycle Figure 53: Single shot (LOOP.CNT=0) Note: The single-shot example also applies to SEQ[1]. Only SEQ[0] is represented for simplicity. 1 100% duty cycle Previously loaded duty cycle last loaded duty cycle maintained New value load 0% duty cycle Peripherals SEQ[1].ENDDELA Y SEQ[1].CNT SEQ[0].ENDDELA Y 1 SEQ[0].CNT SEQ[1].CNT SEQ[0].ENDDELA Y (LOOP.CNT - 1) ... SEQ[0].CNT SEQ[1].CNT SEQ[1].ENDDELA Y LOOP.CNT Loop counter 100% duty cycle Previously loaded duty cycle last loaded duty cycle maintained 0% duty cycle EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] EVENTS_LOOPSDONE EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] EVENTS_SEQEND[0] EVENTS_SEQSTARTED[0] TASKS_SEQSTART[1] EVENTS_SEQSTARTED[1] EVENTS_SEQEND[1] New value load Figure 55: Complex sequence (LOOP.CNT>0) starting with SEQ[1] Note: If a sequence is in use in a simple or complex sequence, it must have a length of SEQ[n].CNT > 0. 6.12.3 Limitations Previous compare value is repeated if the PWM period is shorter than the time it takes for the EasyDMA to retrieve from RAM and update the internal compare registers. This is to ensure a glitch-free operation even for very short PWM periods. 6.12.4 Pin configuration The OUT[n] (n=0..3) signals associated with each PWM channel are mapped to physical pins according to the configuration of PSEL.OUT[n] registers. If PSEL.OUT[n].CONNECT is set to Disconnected, the associated PWM module signal will not be connected to any physical pins. The PSEL.OUT[n] registers and their configurations are used as long as the PWM module is enabled and the PWM generation active (wave counter started). They are retained only as long as the device is in System ON mode (see section POWER for more information about power modes). To ensure correct behavior in the PWM module, the pins that are used must be configured in the GPIO peripheral in the following way before the PWM module is enabled: PWM signal PWM pin Direction Output value Comment OUT[n] As specified in PSEL.OUT[n] Output 0 Idle state defined in GPIO OUT (n=0..3) register Table 52: Recommended GPIO configuration before starting PWM generation 4454_140 v1.0 156 Peripherals The idle state of a pin is defined by the OUT register in the GPIO module, to ensure that the pins used by the PWM module are driven correctly. If PWM generation is stopped by triggering a STOP task, the PWM module itself is temporarily disabled or the device temporarily enters System OFF. This configuration must be retained in the GPIO for the selected pins (I/Os) for as long as the PWM module is supposed to be connected to an external PWM circuit. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. 6.12.5 Registers Base address Peripheral Instance Description 0x4001C000 PWM PWM0 Pulse-width modulation unit 0 Configuration Table 53: Instances Register Offset Description TASKS_STOP 0x004 Stops PWM pulse generation on all channels at the end of current PWM period, and stops TASKS_SEQSTART[0] 0x008 sequence playback Loads the first PWM value on all enabled channels from sequence 0, and starts playing that sequence at the rate defined in SEQ[0]REFRESH and/or DECODER.MODE. Causes PWM generation to start if not running. TASKS_SEQSTART[1] 0x00C Loads the first PWM value on all enabled channels from sequence 1, and starts playing that sequence at the rate defined in SEQ[1]REFRESH and/or DECODER.MODE. Causes PWM generation to start if not running. TASKS_NEXTSTEP 0x010 Steps by one value in the current sequence on all enabled channels if EVENTS_STOPPED 0x104 Response to STOP task, emitted when PWM pulses are no longer generated EVENTS_SEQSTARTED[0] 0x108 First PWM period started on sequence 0 EVENTS_SEQSTARTED[1] 0x10C First PWM period started on sequence 1 EVENTS_SEQEND[0] 0x110 Emitted at end of every sequence 0, when last value from RAM has been applied to wave EVENTS_SEQEND[1] 0x114 DECODER.MODE=NextStep. Does not cause PWM generation to start if not running. counter Emitted at end of every sequence 1, when last value from RAM has been applied to wave counter EVENTS_PWMPERIODEND 0x118 Emitted at the end of each PWM period EVENTS_LOOPSDONE 0x11C Concatenated sequences have been played the amount of times defined in LOOP.CNT SHORTS 0x200 Shortcuts between local events and tasks INTEN 0x300 Enable or disable interrupt INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 PWM module enable register MODE 0x504 Selects operating mode of the wave counter COUNTERTOP 0x508 Value up to which the pulse generator counter counts PRESCALER 0x50C Configuration for PWM_CLK DECODER 0x510 Configuration of the decoder LOOP 0x514 Number of playbacks of a loop SEQ[0].PTR 0x520 Beginning address in RAM of this sequence SEQ[0].CNT 0x524 Number of values (duty cycles) in this sequence SEQ[0].REFRESH 0x528 Number of additional PWM periods between samples loaded into compare register SEQ[0].ENDDELAY 0x52C Time added after the sequence SEQ[1].PTR 0x540 Beginning address in RAM of this sequence SEQ[1].CNT 0x544 Number of values (duty cycles) in this sequence SEQ[1].REFRESH 0x548 Number of additional PWM periods between samples loaded into compare register SEQ[1].ENDDELAY 0x54C Time added after the sequence 4454_140 v1.0 157 Peripherals Register Offset Description PSEL.OUT[0] 0x560 Output pin select for PWM channel 0 PSEL.OUT[1] 0x564 Output pin select for PWM channel 1 PSEL.OUT[2] 0x568 Output pin select for PWM channel 2 PSEL.OUT[3] 0x56C Output pin select for PWM channel 3 Table 54: Register overview 6.12.5.1 TASKS_STOP Address offset: 0x004 Stops PWM pulse generation on all channels at the end of current PWM period, and stops sequence playback Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_STOP Stops PWM pulse generation on all channels at the end of current PWM period, and stops sequence playback Trigger 1 Trigger task 6.12.5.2 TASKS_SEQSTART[n] (n=0..1) Address offset: 0x008 + (n × 0x4) Loads the first PWM value on all enabled channels from sequence n, and starts playing that sequence at the rate defined in SEQ[n]REFRESH and/or DECODER.MODE. Causes PWM generation to start if not running. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_SEQSTART Loads the first PWM value on all enabled channels from sequence n, and starts playing that sequence at the rate defined in SEQ[n]REFRESH and/or DECODER.MODE. Causes PWM generation to start if not running. Trigger 1 Trigger task 6.12.5.3 TASKS_NEXTSTEP Address offset: 0x010 Steps by one value in the current sequence on all enabled channels if DECODER.MODE=NextStep. Does not cause PWM generation to start if not running. 4454_140 v1.0 158 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_NEXTSTEP Steps by one value in the current sequence on all enabled channels if DECODER.MODE=NextStep. Does not cause PWM generation to start if not running. Trigger 1 Trigger task 6.12.5.4 EVENTS_STOPPED Address offset: 0x104 Response to STOP task, emitted when PWM pulses are no longer generated Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_STOPPED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Response to STOP task, emitted when PWM pulses are no longer generated NotGenerated 0 Event not generated Generated 1 Event generated 6.12.5.5 EVENTS_SEQSTARTED[n] (n=0..1) Address offset: 0x108 + (n × 0x4) First PWM period started on sequence n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SEQSTARTED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated First PWM period started on sequence n 6.12.5.6 EVENTS_SEQEND[n] (n=0..1) Address offset: 0x110 + (n × 0x4) Emitted at end of every sequence n, when last value from RAM has been applied to wave counter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SEQEND 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Emitted at end of every sequence n, when last value from RAM has been applied to wave counter 4454_140 v1.0 NotGenerated 0 Event not generated Generated 1 Event generated 159 Peripherals 6.12.5.7 EVENTS_PWMPERIODEND Address offset: 0x118 Emitted at the end of each PWM period Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW EVENTS_PWMPERIODEND Value ID Value Description Emitted at the end of each PWM period NotGenerated 0 Event not generated Generated 1 Event generated 6.12.5.8 EVENTS_LOOPSDONE Address offset: 0x11C Concatenated sequences have been played the amount of times defined in LOOP.CNT Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_LOOPSDONE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Concatenated sequences have been played the amount of times defined in LOOP.CNT NotGenerated 0 Event not generated Generated 1 Event generated 6.12.5.9 SHORTS Address offset: 0x200 Shortcuts between local events and tasks Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID Access Field A RW SEQEND0_STOP B C D E 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Shortcut between event SEQEND[0] and task STOP RW SEQEND1_STOP Shortcut between event SEQEND[1] and task STOP RW LOOPSDONE_SEQSTART0 Shortcut between event LOOPSDONE and task SEQSTART[0] RW LOOPSDONE_SEQSTART1 Shortcut between event LOOPSDONE and task SEQSTART[1] Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW LOOPSDONE_STOP 4454_140 v1.0 Shortcut between event LOOPSDONE and task STOP 160 Peripherals 6.12.5.10 INTEN Address offset: 0x300 Enable or disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID H G F E D C B Reset 0x00000000 ID Access Field B RW STOPPED C-D E-F G H 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable Enable or disable interrupt for event STOPPED RW SEQSTARTED[i] (i=0..1) Enable or disable interrupt for event SEQSTARTED[i] RW SEQEND[i] (i=0..1) Enable or disable interrupt for event SEQEND[i] RW PWMPERIODEND Enable or disable interrupt for event PWMPERIODEND Disabled 0 Disable Enabled 1 Enable Disabled 0 Disable Enabled 1 Enable RW LOOPSDONE Enable or disable interrupt for event LOOPSDONE 6.12.5.11 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID H G F E D C B Reset 0x00000000 ID Access Field B RW STOPPED C-D E-F G H 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Write '1' to enable interrupt for event STOPPED RW SEQSTARTED[i] (i=0..1) Write '1' to enable interrupt for event SEQSTARTED[i] RW SEQEND[i] (i=0..1) Write '1' to enable interrupt for event SEQEND[i] RW PWMPERIODEND Write '1' to enable interrupt for event PWMPERIODEND RW LOOPSDONE 4454_140 v1.0 Write '1' to enable interrupt for event LOOPSDONE 161 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID H G F E D C B Reset 0x00000000 ID Access Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enabled 1 Read: Enabled 6.12.5.12 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID H G F E D C B Reset 0x00000000 ID Access Field B RW STOPPED C-D E-F G H 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event STOPPED RW SEQSTARTED[i] (i=0..1) Write '1' to disable interrupt for event SEQSTARTED[i] RW SEQEND[i] (i=0..1) Write '1' to disable interrupt for event SEQEND[i] RW PWMPERIODEND Write '1' to disable interrupt for event PWMPERIODEND RW LOOPSDONE Write '1' to disable interrupt for event LOOPSDONE 6.12.5.13 ENABLE Address offset: 0x500 PWM module enable register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disabled Enabled 1 Enable Enable or disable PWM module 6.12.5.14 MODE Address offset: 0x504 Selects operating mode of the wave counter 4454_140 v1.0 162 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW UPDOWN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Up 0 Up counter, edge-aligned PWM duty cycle UpAndDown 1 Up and down counter, center-aligned PWM duty cycle Selects up mode or up-and-down mode for the counter 6.12.5.15 COUNTERTOP Address offset: 0x508 Value up to which the pulse generator counter counts Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A Reset 0x000003FF ID Access Field A RW COUNTERTOP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 Value ID Value Description [3..32767] Value up to which the pulse generator counter counts. This register is ignored when DECODER.MODE=WaveForm and only values from RAM are used. 6.12.5.16 PRESCALER Address offset: 0x50C Configuration for PWM_CLK Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000000 ID Access Field A RW PRESCALER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description DIV_1 0 Divide by 1 (16 MHz) DIV_2 1 Divide by 2 (8 MHz) DIV_4 2 Divide by 4 (4 MHz) DIV_8 3 Divide by 8 (2 MHz) DIV_16 4 Divide by 16 (1 MHz) DIV_32 5 Divide by 32 (500 kHz) DIV_64 6 Divide by 64 (250 kHz) DIV_128 7 Divide by 128 (125 kHz) Prescaler of PWM_CLK 6.12.5.17 DECODER Address offset: 0x510 Configuration of the decoder 4454_140 v1.0 163 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B Reset 0x00000000 ID Access Field A RW LOAD A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description How a sequence is read from RAM and spread to the compare register Common 0 1st half word (16-bit) used in all PWM channels 0..3 Grouped 1 1st half word (16-bit) used in channel 0..1; 2nd word in Individual 2 1st half word (16-bit) in ch.0; 2nd in ch.1; ...; 4th in ch.3 WaveForm 3 1st half word (16-bit) in ch.0; 2nd in ch.1; ...; 4th in channel 2..3 COUNTERTOP B RW MODE Selects source for advancing the active sequence RefreshCount 0 NextStep 1 SEQ[n].REFRESH is used to determine loading internal compare registers NEXTSTEP task causes a new value to be loaded to internal compare registers 6.12.5.18 LOOP Address offset: 0x514 Number of playbacks of a loop Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW CNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Disabled 0 Description Number of playbacks of pattern cycles Looping disabled (stop at the end of the sequence) 6.12.5.19 SEQ[n].PTR (n=0..1) Address offset: 0x520 + (n × 0x20) Beginning address in RAM of this sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW PTR 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Beginning address in RAM of this sequence Note: See the memory chapter for details about which memories are available for EasyDMA. 6.12.5.20 SEQ[n].CNT (n=0..1) Address offset: 0x524 + (n × 0x20) Number of values (duty cycles) in this sequence 4454_140 v1.0 164 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW CNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Disabled 0 Description Number of values (duty cycles) in this sequence Sequence is disabled, and shall not be started as it is empty 6.12.5.21 SEQ[n].REFRESH (n=0..1) Address offset: 0x528 + (n × 0x20) Number of additional PWM periods between samples loaded into compare register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000001 ID Access Field A RW CNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value ID Value Description Number of additional PWM periods between samples loaded into compare register (load every REFRESH.CNT+1 PWM periods) Continuous 0 Update every PWM period 6.12.5.22 SEQ[n].ENDDELAY (n=0..1) Address offset: 0x52C + (n × 0x20) Time added after the sequence Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW CNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Time added after the sequence in PWM periods 6.12.5.23 PSEL.OUT[n] (n=0..3) Address offset: 0x560 + (n × 0x4) Output pin select for PWM channel n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF ID Access Field A RW PIN C RW CONNECT A A A A A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 6.13 QDEC — Quadrature decoder The Quadrature decoder (QDEC) provides buffered decoding of quadrature-encoded sensor signals. It is suitable for mechanical and optical sensors. 4454_140 v1.0 165 Peripherals The sample period and accumulation are configurable to match application requirements. The QDEC provides the following: • • • • Decoding of digital waveform from off-chip quadrature encoder. Sample accumulation eliminating hard real-time requirements to be enforced on application. Optional input de-bounce filters. Optional LED output signal for optical encoders. ACCREAD ACCDBLREAD ACC ACCDBL + + SAMPLE Quadrature decoder IO router On-chip Off-chip Phase A Phase B LED Mechanical to electrical Mechanical device Quadrature Encoder Figure 56: Quadrature decoder configuration 6.13.1 Sampling and decoding The QDEC decodes the output from an incremental motion encoder by sampling the QDEC phase input pins (A and B). The off-chip quadrature encoder is an incremental motion encoder outputting two waveforms, phase A and phase B. The two output waveforms are always 90 degrees out of phase, meaning that one always changes level before the other. The direction of movement is indicated by which of these two waveforms that changes level first. Invalid transitions may occur, that is when the two waveforms switch simultaneously. This may occur if the wheel rotates too fast relative to the sample rate set for the decoder. The QDEC decodes the output from the off-chip encoder by sampling the QDEC phase input pins (A and B) at a fixed rate as specified in the SAMPLEPER register. If the SAMPLEPER value needs to be changed, the QDEC shall be stopped using the STOP task. SAMPLEPER can be then changed upon receiving the STOPPED event, and QDEC can be restarted using the START task. Failing to do so may result in unpredictable behaviour. 4454_140 v1.0 166 Peripherals It is good practice to change other registers (LEDPOL, REPORTPER, DBFEN and LEDPRE) only when the QDEC is stopped. When started, the decoder continuously samples the two input waveforms and decodes these by comparing the current sample pair (n) with the previous sample pair (n-1). The decoding of the sample pairs is described in the table below. Previous Current SAMPLE sample pair(n samples register - 1) ACC operation ACCDBL Description operation pair(n) A B A B 0 0 0 0 0 No change No change No movement 0 0 0 1 1 Increment No change Movement in positive direction 0 0 1 0 -1 Decrement No change Movement in negative direction 0 0 1 1 2 No change Increment Error: Double transition 0 1 0 0 -1 Decrement No change Movement in negative direction 0 1 0 1 0 No change No change No movement 0 1 1 0 2 No change Increment Error: Double transition 0 1 1 1 1 Increment No change Movement in positive direction 1 0 0 0 1 Increment No change Movement in positive direction 1 0 0 1 2 No change Increment Error: Double transition 1 0 1 0 0 No change No change No movement 1 0 1 1 -1 Decrement No change Movement in negative direction 1 1 0 0 2 No change Increment Error: Double transition 1 1 0 1 -1 Decrement No change Movement in negative direction 1 1 1 0 1 Increment No change Movement in positive direction 1 1 1 1 0 No change No change No movement Table 55: Sampled value encoding 6.13.2 LED output The LED output follows the sample period, and the LED is switched on a given period before sampling and switched off immediately after the inputs are sampled. The period the LED is switched on before sampling is given in the LEDPRE register. The LED output pin polarity is specified in the LEDPOL register. For using off-chip mechanical encoders not requiring a LED, the LED output can be disabled by writing value 'Disconnected' to the CONNECT field of the PSEL.LED register. In this case the QDEC will not acquire access to a LED output pin and the pin can be used for other purposes by the CPU. 6.13.3 Debounce filters Each of the two-phase inputs have digital debounce filters. When enabled through the DBFEN register, the filter inputs are sampled at a fixed 1 MHz frequency during the entire sample period (which is specified in the SAMPLEPER register), and the filters require all of the samples within this sample period to equal before the input signal is accepted and transferred to the output of the filter. As a result, only input signal with a steady state longer than twice the period specified in SAMPLEPER are guaranteed to pass through the filter, and any signal with a steady state shorter than SAMPLEPER will always be suppressed by the filter. (This is assumed that the frequency during the debounce period never exceeds 500 kHz (as required by the Nyquist theorem when using a 1 MHz sample frequency). The LED will always be ON when the debounce filters are enabled, as the inputs in this case will be sampled continuously. 4454_140 v1.0 167 Peripherals Note that when when the debounce filters are enabled, displacements reported by the QDEC peripheral are delayed by one SAMPLEPER period. 6.13.4 Accumulators The quadrature decoder contains two accumulator registers, ACC and ACCDBL, that accumulate respectively valid motion sample values and the number of detected invalid samples (double transitions). The ACC register will accumulate all valid values (1/-1) written to the SAMPLE register. This can be useful for preventing hard real-time requirements from being enforced on the application. When using the ACC register the application does not need to read every single sample from the SAMPLE register, but can instead fetch the ACC register whenever it fits the application. The ACC register will always hold the relative movement of the external mechanical device since the previous clearing of the ACC register. Sample values indicating a double transition (2) will not be accumulated in the ACC register. An ACCOF event will be generated if the ACC receives a SAMPLE value that would cause the register to overflow or underflow. Any SAMPLE value that would cause an ACC overflow or underflow will be discarded, but any samples not causing the ACC to overflow or underflow will still be accepted. The accumulator ACCDBL accumulates the number of detected double transitions since the previous clearing of the ACCDBL register. The ACC and ACCDBL registers can be cleared by the READCLRACC and subsequently read using the ACCREAD and ACCDBLREAD registers. The ACC register can be separately cleared by the RDCLRACC and subsequently read using the ACCREAD registers. The ACCDBL register can be separately cleared by the RDCLRDBL and subsequently read using the ACCDBLREAD registers. The REPORTPER register allows automating the capture of several samples before it can send out a REPORTRDY event in case a non-null displacement has been captured and accumulated, and a DBLRDY event in case one or more double-displacements have been captured and accumulated. The REPORTPER field in this register selects after how many samples the accumulators contents are evaluated to send (or not) REPORTRDY and DBLRDY events. Using the RDCLRACC task (manually sent upon receiving the event, or using the DBLRDY_RDCLRACC shortcut), ACCREAD can then be read. In case at least one double transition has been captured and accumulated, a DBLRDY event is sent. Using the RDCLRDBL task (manually sent upon receiving the event, or using the DBLRDY_RDCLRDBL shortcut), ACCDBLREAD can then be read. 6.13.5 Output/input pins The QDEC uses a three-pin interface to the off-chip quadrature encoder. These pins will be acquired when the QDEC is enabled in the ENABLE register. The pins acquired by the QDEC cannot be written by the CPU, but they can still be read by the CPU. The pin numbers to be used for the QDEC are selected using the PSEL.n registers. 6.13.6 Pin configuration The Phase A, Phase B, and LED signals are mapped to physical pins according to the configuration specified in the PSEL.A, PSEL.B, and PSEL.LED registers respectively. If the CONNECT field value 'Disconnected' is specified in any of these registers, the associated signal will not be connected to any physical pin. The PSEL.A, PSEL.B, and PSEL.LED registers and their configurations are only used as long as the QDEC is enabled, and retained only as long as the device is in ON mode. 4454_140 v1.0 168 Peripherals When the peripheral is disabled, the pins will behave as regular GPIOs, and use the configuration in their respective OUT bit field and PIN_CNF[n] register. To secure correct behavior in the QDEC, the pins used by the QDEC must be configured in the GPIO peripheral as described in GPIO configuration before enabling peripheral on page 169 before enabling the QDEC. This configuration must be retained in the GPIO for the selected IOs as long as the QDEC is enabled. Only one peripheral can be assigned to drive a particular GPIO pin at a time. Failing to do so may result in unpredictable behavior. QDEC signal QDEC pin Direction Output value Phase A As specified in PSEL.A Input Not applicable Phase B As specified in PSEL.B Input Not applicable LED As specified in PSEL.LED Input Not applicable Comment Table 56: GPIO configuration before enabling peripheral 6.13.7 Registers Base address Peripheral Instance Description Configuration 0x40012000 QDEC QDEC Quadrature decoder Table 57: Instances Register Offset Description TASKS_START 0x000 Task starting the quadrature decoder TASKS_STOP 0x004 Task stopping the quadrature decoder TASKS_READCLRACC 0x008 Read and clear ACC and ACCDBL TASKS_RDCLRACC 0x00C Read and clear ACC TASKS_RDCLRDBL 0x010 Read and clear ACCDBL EVENTS_SAMPLERDY 0x100 Event being generated for every new sample value written to the SAMPLE register EVENTS_REPORTRDY 0x104 Non-null report ready EVENTS_ACCOF 0x108 ACC or ACCDBL register overflow EVENTS_DBLRDY 0x10C Double displacement(s) detected EVENTS_STOPPED 0x110 QDEC has been stopped SHORTS 0x200 Shortcuts between local events and tasks INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt ENABLE 0x500 Enable the quadrature decoder LEDPOL 0x504 LED output pin polarity SAMPLEPER 0x508 Sample period SAMPLE 0x50C Motion sample value REPORTPER 0x510 Number of samples to be taken before REPORTRDY and DBLRDY events can be generated ACC 0x514 Register accumulating the valid transitions ACCREAD 0x518 Snapshot of the ACC register, updated by the READCLRACC or RDCLRACC task PSEL.LED 0x51C Pin select for LED signal PSEL.A 0x520 Pin select for A signal PSEL.B 0x524 Pin select for B signal DBFEN 0x528 Enable input debounce filters LEDPRE 0x540 Time period the LED is switched ON prior to sampling ACCDBL 0x544 Register accumulating the number of detected double transitions 4454_140 v1.0 169 Peripherals Register Offset Description ACCDBLREAD 0x548 Snapshot of the ACCDBL, updated by the READCLRACC or RDCLRDBL task Table 58: Register overview 6.13.7.1 TASKS_START Address offset: 0x000 Task starting the quadrature decoder When started, the SAMPLE register will be continuously updated at the rate given in the SAMPLEPER register. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_START Task starting the quadrature decoder When started, the SAMPLE register will be continuously updated at the rate given in the SAMPLEPER register. Trigger 1 Trigger task 6.13.7.2 TASKS_STOP Address offset: 0x004 Task stopping the quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_STOP Task stopping the quadrature decoder Trigger task 6.13.7.3 TASKS_READCLRACC Address offset: 0x008 Read and clear ACC and ACCDBL Task transferring the content of ACC to ACCREAD and the content of ACCDBL to ACCDBLREAD, and then clearing the ACC and ACCDBL registers. These read-and-clear operations will be done atomically. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_READCLRACC Read and clear ACC and ACCDBL Task transferring the content of ACC to ACCREAD and the content of ACCDBL to ACCDBLREAD, and then clearing the ACC and ACCDBL registers. These read-and-clear operations will be done atomically. Trigger 4454_140 v1.0 1 Trigger task 170 Peripherals 6.13.7.4 TASKS_RDCLRACC Address offset: 0x00C Read and clear ACC Task transferring the content of ACC to ACCREAD, and then clearing the ACC register. This read-and-clear operation will be done atomically. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_RDCLRACC Read and clear ACC Task transferring the content of ACC to ACCREAD, and then clearing the ACC register. This read-and-clear operation will be done atomically. Trigger 1 Trigger task 6.13.7.5 TASKS_RDCLRDBL Address offset: 0x010 Read and clear ACCDBL Task transferring the content of ACCDBL to ACCDBLREAD, and then clearing the ACCDBL register. This readand-clear operation will be done atomically. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description TASKS_RDCLRDBL Read and clear ACCDBL Task transferring the content of ACCDBL to ACCDBLREAD, and then clearing the ACCDBL register. This read-and-clear operation will be done atomically. Trigger 1 Trigger task 6.13.7.6 EVENTS_SAMPLERDY Address offset: 0x100 Event being generated for every new sample value written to the SAMPLE register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_SAMPLERDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Event being generated for every new sample value written to the SAMPLE register NotGenerated 0 Event not generated Generated 1 Event generated 6.13.7.7 EVENTS_REPORTRDY Address offset: 0x104 4454_140 v1.0 171 Peripherals Non-null report ready Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_REPORTRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Non-null report ready Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). NotGenerated 0 Event not generated Generated 1 Event generated 6.13.7.8 EVENTS_ACCOF Address offset: 0x108 ACC or ACCDBL register overflow Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_ACCOF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description NotGenerated 0 Event not generated Generated 1 Event generated ACC or ACCDBL register overflow 6.13.7.9 EVENTS_DBLRDY Address offset: 0x10C Double displacement(s) detected Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). 4454_140 v1.0 172 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_DBLRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Double displacement(s) detected Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). NotGenerated 0 Event not generated Generated 1 Event generated 6.13.7.10 EVENTS_STOPPED Address offset: 0x110 QDEC has been stopped Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_STOPPED 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description QDEC has been stopped NotGenerated 0 Event not generated Generated 1 Event generated 6.13.7.11 SHORTS Address offset: 0x200 Shortcuts between local events and tasks Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID G F E D C B A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW REPORTRDY_READCLRACC B C D E F Value ID Value Description Shortcut between event REPORTRDY and task READCLRACC Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 Disable shortcut Enabled 1 Enable shortcut RW SAMPLERDY_STOP Shortcut between event SAMPLERDY and task STOP RW REPORTRDY_RDCLRACC Shortcut between event REPORTRDY and task RDCLRACC RW REPORTRDY_STOP Shortcut between event REPORTRDY and task STOP RW DBLRDY_RDCLRDBL Shortcut between event DBLRDY and task RDCLRDBL Disabled 0 Disable shortcut Enabled 1 Enable shortcut Disabled 0 RW DBLRDY_STOP 4454_140 v1.0 Shortcut between event DBLRDY and task STOP Disable shortcut 173 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID G F E D C B A Reset 0x00000000 ID G Access Field 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enabled 1 Enable shortcut RW SAMPLERDY_READCLRACC Shortcut between event SAMPLERDY and task READCLRACC Disabled 0 Disable shortcut Enabled 1 Enable shortcut 6.13.7.12 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID Access Field A RW SAMPLERDY B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Write '1' to enable interrupt for event SAMPLERDY Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW REPORTRDY Write '1' to enable interrupt for event REPORTRDY Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). C D Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ACCOF Write '1' to enable interrupt for event ACCOF RW DBLRDY Write '1' to enable interrupt for event DBLRDY Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). E Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to enable interrupt for event STOPPED 6.13.7.13 INTENCLR Address offset: 0x308 Disable interrupt 4454_140 v1.0 174 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D C B A Reset 0x00000000 ID Access Field A RW SAMPLERDY B 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event SAMPLERDY RW REPORTRDY Write '1' to disable interrupt for event REPORTRDY Event generated when REPORTPER number of samples has been accumulated in the ACC register and the content of the ACC register is not equal to 0. (Thus, this event is only generated if a motion is detected since the previous clearing of the ACC register). C D Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW ACCOF Write '1' to disable interrupt for event ACCOF Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW DBLRDY Write '1' to disable interrupt for event DBLRDY Event generated when REPORTPER number of samples has been accumulated and the content of the ACCDBL register is not equal to 0. (Thus, this event is only generated if a double transition is detected since the previous clearing of the ACCDBL register). E Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled RW STOPPED Write '1' to disable interrupt for event STOPPED 6.13.7.14 ENABLE Address offset: 0x500 Enable the quadrature decoder Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW ENABLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enable or disable the quadrature decoder When enabled the decoder pins will be active. When disabled the quadrature decoder pins are not active and can be used as GPIO . 4454_140 v1.0 Disabled 0 Disable Enabled 1 Enable 175 Peripherals 6.13.7.15 LEDPOL Address offset: 0x504 LED output pin polarity Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW LEDPOL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description ActiveLow 0 Led active on output pin low ActiveHigh 1 Led active on output pin high LED output pin polarity 6.13.7.16 SAMPLEPER Address offset: 0x508 Sample period Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A RW SAMPLEPER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Sample period. The SAMPLE register will be updated for every new sample 128us 0 128 us 256us 1 256 us 512us 2 512 us 1024us 3 1024 us 2048us 4 2048 us 4096us 5 4096 us 8192us 6 8192 us 16384us 7 16384 us 32ms 8 32768 us 65ms 9 65536 us 131ms 10 131072 us 6.13.7.17 SAMPLE Address offset: 0x50C Motion sample value Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A R SAMPLE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description [-1..2] Last motion sample The value is a 2's complement value, and the sign gives the direction of the motion. The value '2' indicates a double transition. 4454_140 v1.0 176 Peripherals 6.13.7.18 REPORTPER Address offset: 0x510 Number of samples to be taken before REPORTRDY and DBLRDY events can be generated Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A RW REPORTPER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Specifies the number of samples to be accumulated in the ACC register before the REPORTRDY and DBLRDY events can be generated The report period in [us] is given as: RPUS = SP * RP Where RPUS is the report period in [us/report], SP is the sample period in [us/sample] specified in SAMPLEPER, and RP is the report period in [samples/report] specified in REPORTPER . 10Smpl 0 10 samples / report 40Smpl 1 40 samples / report 80Smpl 2 80 samples / report 120Smpl 3 120 samples / report 160Smpl 4 160 samples / report 200Smpl 5 200 samples / report 240Smpl 6 240 samples / report 280Smpl 7 280 samples / report 1Smpl 8 1 sample / report 6.13.7.19 ACC Address offset: 0x514 Register accumulating the valid transitions Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID ACC Value Description [-1024..1023] Register accumulating all valid samples (not double transition) read from the SAMPLE register Double transitions ( SAMPLE = 2 ) will not be accumulated in this register. The value is a 32 bit 2's complement value. If a sample that would cause this register to overflow or underflow is received, the sample will be ignored and an overflow event ( ACCOF ) will be generated. The ACC register is cleared by triggering the READCLRACC or the RDCLRACC task. 6.13.7.20 ACCREAD Address offset: 0x518 Snapshot of the ACC register, updated by the READCLRACC or RDCLRACC task 4454_140 v1.0 177 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A R Value ID ACCREAD Value Description [-1024..1023] Snapshot of the ACC register. The ACCREAD register is updated when the READCLRACC or RDCLRACC task is triggered 6.13.7.21 PSEL.LED Address offset: 0x51C Pin select for LED signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ID Access Field A RW PIN C RW CONNECT Value ID A A A A A Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 6.13.7.22 PSEL.A Address offset: 0x520 Pin select for A signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF ID Access Field A RW PIN C RW CONNECT A A A A A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 6.13.7.23 PSEL.B Address offset: 0x524 Pin select for B signal Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF ID Access Field A RW PIN C RW CONNECT 4454_140 v1.0 A A A A A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description [0..31] Pin number Connection Disconnected 1 Disconnect Connected 0 Connect 178 Peripherals 6.13.7.24 DBFEN Address offset: 0x528 Enable input debounce filters Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW DBFEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Debounce input filters disabled Enabled 1 Debounce input filters enabled Enable input debounce filters 6.13.7.25 LEDPRE Address offset: 0x540 Time period the LED is switched ON prior to sampling Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A Reset 0x00000010 ID Access Field A RW LEDPRE 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 Value ID Value Description [1..511] Period in us the LED is switched on prior to sampling 6.13.7.26 ACCDBL Address offset: 0x544 Register accumulating the number of detected double transitions Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID ACCDBL Value Description [0..15] Register accumulating the number of detected double or illegal transitions. ( SAMPLE = 2 ). When this register has reached its maximum value the accumulation of double / illegal transitions will stop. An overflow event ( ACCOF ) will be generated if any double or illegal transitions are detected after the maximum value was reached. This field is cleared by triggering the READCLRACC or RDCLRDBL task. 6.13.7.27 ACCDBLREAD Address offset: 0x548 Snapshot of the ACCDBL, updated by the READCLRACC or RDCLRDBL task 4454_140 v1.0 179 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID ACCDBLREAD Value Description [0..15] Snapshot of the ACCDBL register. This field is updated when the READCLRACC or RDCLRDBL task is triggered. 6.13.8 Electrical specification 6.13.8.1 QDEC Electrical Specification Symbol Description Min. tSAMPLE Time between sampling signals from quadrature decoder tLED Time from LED is turned on to signals are sampled Typ. Max. Units 128 131072 µs 0 511 µs 6.14 RADIO — 2.4 GHz radio The 2.4 GHz radio transceiver is compatible with multiple radio standards such as 1 Mbps, 2 Mbps and long range Bluetooth® low energy. IEEE 802.15.4 250 kbps mode is fully supported as well as Nordic's proprietary 1 Mbps and 2 Mbps modes of operation. Listed here are main features for the RADIO: • Multidomain 2.4 GHz radio transceiver • 1 Mbps, 2 Mbps, and long range (125 kbps and 500 kbps mode) Bluetooth® low energy modes • Angle-of-arrival (AoA) and angle-of-departure (AoD) direction finding using Bluetooth® low energy • 250 kbps IEEE 802.15.4 mode • 1 Mbps and 2 Mbps Nordic proprietary modes • Best in class link budget and low power operation • Efficient data interface with EasyDMA support • Automatic address filtering and pattern matching EasyDMA, in combination with an automated packet assembler, packet disassembler, automated CRC generator and CRC checker, makes it easy to configure and use the RADIO. See the following figure for details. RAM RADIO PACKETPTR Device address match Packet synch S0 CRC Packet disassembler L RSSI Address match Dewhitening 2.4 GHz receiver S1 Payload EasyDMA IFS control unit Bit counter S0 ANT1 L Packet assembler S1 Payload CRC MAXLEN Figure 57: RADIO block diagram 4454_140 v1.0 180 Whitening 2.4 GHz transmitter Peripherals The RADIO includes a device address match unit and an interframe spacing control unit that can be utilized to simplify address whitelisting and interframe spacing respectively in Bluetooth® low energy and similar applications. The RADIO also includes a received signal strength indicator (RSSI) and a bit counter. The bit counter generates events when a preconfigured number of bits are sent or received by the RADIO. 6.14.1 Packet configuration A RADIO packet contains the following fields: PREAMBLE, ADDRESS, S0, LENGTH, S1, PAYLOAD, and CRC. PREFIX CI TERM1 S0 LENGTH LSByte S1 PAYLOAD LSByte CRC LSBit BASE MSBit PREAMBLE LSBit LSBit LSBit The content of a RADIO packet is illustrated in the figure below. The RADIO sends the fields in the packet according to the order illustrated in the following figure, starting on the left. TERM 2 MSByte ADDRESS Figure 58: On-air packet layout Not shown in the figure is the static payload add-on (the length of which is defined in PCNF1.STATLEN, and which is 0 bytes in a standard BLE packet). The static payload add-on is sent between PAYLOAD and CRC fields. The RADIO sends the different fields in the packet in the order they are illustrated above, from left to right. The preamble will be sent with least significant bit first on air. PREAMBLE is sent with least significant bit first on air. The size of the PREAMBLE depends on the mode selected in the MODE register: • The PREAMBLE is one byte for MODE = Ble_1Mbit as well as all Nordic proprietary operating modes (MODE = Nrf_1Mbit and MODE = Nrf_2Mbit), and PCNF0.PLEN has to be set accordingly. If the first bit of the ADDRESS is 0, the preamble will be set to 0xAA. Otherwise the PREAMBLE will be set to 0x55. • For MODE = Ble_2Mbit, the PREAMBLE must be set to 2 byte through PCNF0.PLEN. If the first bit of the ADDRESS is 0, the preamble will be set to 0xAAAA. Otherwise the PREAMBLE will be set to 0x5555. • For MODE = Ble_LR125Kbit and MODE = Ble_LR500Kbit, the PREAMBLE is 10 repetitions of 0x3C. • For MODE = Ieee802154_250Kbit, the PREAMBLE is 4 bytes and set to all zeros. Radio packets are stored in memory inside instances of a RADIO packet data structure as illustrated below. The PREAMBLE, ADDRESS, CI, TERM1, TERM2, and CRC fields are omitted in this data structure. Fields S0, LENGTH, and S1 are optional. S0 0 LENGTH S1 PAYLOAD LSByte n Figure 59: In-RAM representation of RADIO packet The byte ordering on air is always least significant byte first for the ADDRESS and PAYLOAD fields, and most significant byte first for the CRC field. The ADDRESS fields are always transmitted and received least significant bit first. The CRC field is always transmitted and received most significant bit first. The bitendian, i.e. the order in which the bits are sent and received, of the S0, LENGTH, S1, and PAYLOAD fields can be configured via PCNF1.ENDIAN. The sizes of the S0, LENGTH and S1 fields can be individually configured via S0LEN, LFLEN, and S1LEN in PCNF0 respectively. If any of these fields are configured to be less than 8 bits, the least significant bits of the fields are used. If S0, LENGTH, or S1 are specified with zero length, their fields will be omitted in memory. Otherwise each field will be represented as a separate byte, regardless of the number of bits in their on-air counterpart. 4454_140 v1.0 181 Peripherals Independent of the configuration of PCNF1.MAXLEN, the combined length of S0, LENGTH, S1, and PAYLOAD cannot exceed 258 bytes. 6.14.2 Address configuration The on-air radio ADDRESS field is composed of two parts, the base address field and the address prefix field. The size of the base address field is configurable via PCNF1.BALEN. The base address is truncated from the least significant byte if the PCNF1.BALEN is less than 4. See Definition of logical addresses on page 182. Logical address Base address Prefix byte 0 BASE0 PREFIX0.AP0 1 BASE1 PREFIX0.AP1 2 BASE1 PREFIX0.AP2 3 BASE1 PREFIX0.AP3 4 BASE1 PREFIX1.AP4 5 BASE1 PREFIX1.AP5 6 BASE1 PREFIX1.AP6 7 BASE1 PREFIX1.AP7 Table 59: Definition of logical addresses The on-air addresses are defined in the BASE0/BASE1 and PREFIX0/PREFIX1 registers. It is only when writing these registers that the user must relate to the actual on-air addresses. For other radio address registers, such as the TXADDRESS, RXADDRESSES, and RXMATCH registers, logical radio addresses ranging from 0 to 7 are being used. The relationship between the on-air radio addresses and the logical addresses is described in Definition of logical addresses on page 182. 6.14.3 Data whitening The RADIO is able to do packet whitening and de-whitening, enabled in PCNF1.WHITEEN. When enabled, whitening and de-whitening will be handled by the RADIO automatically as packets are sent and received. The whitening word is generated using polynomial g(D) = D7+ D4 + 1, which then is XORed with the data packet that is to be whitened, or de-whitened. See the figure below. D0 D4 D7 + Position 0 1 2 3 Data out + 4 5 6 Data in Figure 60: Data whitening and de-whitening Whitening and de-whitening will be performed over the whole packet (except for the preamble and the address field). The linear feedback shift register in the figure above is initialized via register DATAWHITEIV on page 228. 6.14.4 CRC The CRC generator in the RADIO calculates the CRC over the whole packet excluding the preamble. If desirable, the address field can be excluded from the CRC calculation as well. 4454_140 v1.0 182 Peripherals See CRCCNF register for more information. The CRC polynomial is configurable as illustrated in the following figure, where bit 0 in the CRCPOLY register corresponds to X0 and bit 1 corresponds to X1 etc. See CRCPOLY on page 227 for more information. Xn-1 Xn X2 X1 X0 Packet (Clocked in serially) + + + bn + + b0 Figure 61: CRC generation of an n bit CRC The figure shows that the CRC is calculated by feeding the packet serially through the CRC generator. Before the packet is clocked through the CRC generator, the CRC generator's latches b0 through bn will be initialized with a predefined value specified in the CRCINIT register. After the whole packet has been clocked through the CRC generator, b0 through bn will hold the resulting CRC. This value will be used by the RADIO during both transmission and reception. Latches b0 through bn are not available to be read by the CPU at any time. However, a received CRC can be read by the CPU via the RXCRC register. The length (n) of the CRC is configurable, see CRCCNF for more information. Once the entire packet, including the CRC, has been received and no errors were detected, the RADIO generates a CRCOK event. If CRC errors were detected, a CRCERROR event is generated. The status of the CRC check can be read from the CRCSTATUS register after a packet has been received. 6.14.5 Radio states Tasks and events are used to control the operating state of the RADIO. The RADIO can enter the states described the table below. State Description DISABLED No operations are going on inside the RADIO and the power consumption is at a minimum RXRU The RADIO is ramping up and preparing for reception RXIDLE The RADIO is ready for reception to start RX Reception has been started and the addresses enabled in the RXADDRESSES register are being monitored TXRU The RADIO is ramping up and preparing for transmission TXIDLE The RADIO is ready for transmission to start TX The RADIO is transmitting a packet RXDISABLE The RADIO is disabling the receiver TXDISABLE The RADIO is disabling the transmitter Table 60: RADIO state diagram A state diagram showing an overview of the RADIO is shown in the following figure. 4454_140 v1.0 183 Peripherals DISABLE Address sent / ADDRESS START TXDISABLE TXRU / DISABLED Ramp-up complete / READY TXIDLE TX STOP Packet sent / END TXEN TXEN Payload sent [payload length >=0] / PAYLOAD Last bit sent / PHYEND DISABLED RXEN Packet received / END / DISABLED RXDISABLE RXRU Ramp-up complete / READY Address received [Address match] / ADDRESS START RXIDLE RX STOP Payload received [payload length >=0] / PAYLOAD DISABLE Figure 62: Radio states This figure shows how the tasks and events relate to the RADIO's operation. The RADIO does not prevent a task from being triggered from the wrong state. If a task is triggered from the wrong state, for example if the RXEN task is triggered from the RXDISABLE state, this may lead to incorrect behavior. The PAYLOAD event is always generated even if the payload is zero. The END to START shortcut should not be used with Ble_LR125Kbit, Ble_LR500Kbit, and Ieee802154_250Kbit modes. Rather the PHYEND to START shortcut. 6.14.6 Transmit sequence Before the RADIO is able to transmit a packet, it must first ramp-up in TX mode. See TXRU in Radio states on page 184 and Transmit sequence on page 185. A TXRU ramp-up sequence is initiated when the TXEN task is triggered. After the RADIO has successfully ramped up it will generate the READY event indicating that a packet transmission can be initiated. A packet transmission is initiated by triggering the START task. The START task can first be triggered after the RADIO has entered into the TXIDLE state. The following figure illustrates a single packet transmission where the CPU manually triggers the different tasks needed to control the flow of the RADIO, i.e. no shortcuts are used. If shortcuts are not used, a certain amount of delay caused by CPU execution is expected between READY and START, and between END and DISABLE. As illustrated in Transmit sequence on page 185 the RADIO will by default transmit '1's between READY and START, and between END and DISABLED. What is transmitted can be programmed through the DTX field in the MODECNF0 register. 4454_140 v1.0 184 TX PAYLOAD CRC (carrier) 2 DISABLE 3 TXEN START 1 TXDISABLE DISABLED S0 L S1 ADDRESS Lifeline READY A END P (carrier) TXIDLE PHYEND TXIDLE Transmitter TXRU PAYLOAD State Peripherals Figure 63: Transmit sequence TX CRC (carrier) DISABLED PAYLOAD PAYLOAD Lifeline S0 L S1 PHYEND A READY P TXDISABLE ADDRESS Transmitter TXRU END State The following figure shows a slightly modified version of the transmit sequence where the RADIO is configured to use shortcuts between READY and START, and between END and DISABLE, which means that no delay is introduced. 1 TXEN START DISABLE 2 Figure 64: Transmit sequence using shortcuts to avoid delays A S0 L S1 CRC (carrier) 6.14.7 Receive sequence 185 DISABLE 3 START START 2 Figure 65: Transmission of multiple packets 4454_140 v1.0 PAYLOAD DISABLED P PHYEND (carrier) END CRC ADDRESS PAYLOAD END S0 L S1 TXDISABLE TX PHYEND A 1 TXEN Lifeline READY P TXIDLE PAYLOAD TX ADDRESS Transmitter TXRU PAYLOAD State The RADIO is able to send multiple packets one after the other without having to disable and re-enable the RADIO between packets, as illustrated in the following figure. Peripherals Before the RADIO is able to receive a packet, it must first ramp up in RX mode, see RXRU in Radio states on page 184 and Receive sequence on page 186. An RXRU ramp up sequence is initiated when the RXEN task is triggered. After the RADIO has successfully ramped up it will generate the READY event indicating that a packet reception can be initiated. A packet reception is initiated by triggering the START task. As illustrated in Radio states on page 184, the START task can first be triggered after the RADIO has entered into the RXIDLE state. RX PAYLOAD CRC ADDRESS S0 L S1 2 DISABLE 3 START 1 RXEN Lifeline READY A RXDISABLE DISABLED P ’X’ RXIDLE END RXIDLE Reception RXRU PAYLOAD State The following figure shows a single packet reception where the CPU manually triggers the different tasks needed to control the flow of the RADIO, i.e. no shortcuts are used. If shortcuts are not used, a certain amount of delay caused by CPU execution is expected between READY and START, and between END and DISABLE. The RADIO will be listening and possibly receiving undefined data, represented with an 'X', from START and until a packet with valid preamble (P) is received. Figure 66: Receive sequence RX S0 L S1 PAYLOAD CRC DISABLED A END P RXDISABLE 1 2 DISABLE START RXEN Lifeline READY ’X’ ADDRESS Reception RXRU PAYLOAD State The following figure shows a slightly modified version of the receive sequence, where the RADIO is configured to use shortcuts between READY and START, and between END and DISABLE, which means that no delay is introduced. Figure 67: Receive sequence using shortcuts to avoid delays The RADIO is able to receive consecutive packets without having to disable and re-enable the RADIO between packets, as illustrated in the figure below. 4454_140 v1.0 186 ’X’ P A S0 L S1 PAYLOAD CRC DISABLED CRC END PAYLOAD RXDISABLE RX ADDRESS S0 L S1 ADDRESS A START 3 DISABLE 2 START 1 RXEN Lifeline READY ’X’ P RXIDLE PAYLOAD RX END Receiver RXRU PAYLOAD State Peripherals Figure 68: Reception of multiple packets 6.14.8 Received signal strength indicator (RSSI) The RADIO implements a mechanism for measuring the power in the received signal. This feature is called received signal strength indicator (RSSI). The RSSI is measured continuously and the value filtered using a single-pole IIR filter. After a signal level change, the RSSI will settle after approximately RSSISETTLE. Sampling of the received signal strength is started by using the RSSISTART task. The sample can be read from the RSSISAMPLE register. The sample period of the RSSI is defined by RSSIPERIOD. The RSSISAMPLE will hold the pre-filtered received signal strength after this sample period. For the RSSI sample to be valid, the RADIO has to be enabled in receive mode (RXEN task) and the reception has to be started (READY event followed by START task). 6.14.9 Interframe spacing (IFS) Interframe spacing (IFS) is defined as the time, in microseconds, between two consecutive packets, starting from when the end of the last bit of the previous packet is received, to the beginning of the first bit of the subsequent packet that is transmitted. The RADIO is able to enforce this interval, as specified in the TIFS register, as long as the TIFS is not specified to be shorter than the RADIO's turnaround time, i.e. the time needed to switch off the receiver, and then switch the transmitter back on. The TIFS register can be written any time before the last bit on air is received. This timing is illustrated in the figure below. 4454_140 v1.0 187 Peripherals Change to MODE OK TXRU TX P READY DISABLED CRC END A S0 L S1 PAYLOAD START DISABLE TIFS TXEN PAYLOAD RXDISABLE ADDRESS RX PAYLOAD Lifeline On air State Change to SHORTS and TIFS OK Figure 69: IFS timing detail The TIFS duration starts after the last bit on air (just before the END event), and elapses with first bit being transmitted on air (just after READY event). TIFS is only enforced if the shortcuts END-to-DISABLE and DISABLED-to-TXEN or END-to-DISABLE and DISABLED-to-RXEM are enabled. TIFS is qualified for use when MODE is either Ble_1Mbit, Ble_2Mbit, Ble_LR125Kbit, Ble_LR500Kbit, or Ieee802154_250Kbit, using the default ramp-up mode. SHORTS and TIFS are not double-buffered, and can be updated at any point in time before the last bit on air is received. The MODE register is double-buffered and sampled at the TXEN or RXEN task. 6.14.10 Device address match The device address match feature is tailored for address whitelisting in Bluetooth® low energy and similar implementations. This feature enables on-the-fly device address matching while receiving a packet on air. This feature only works in receive mode and when the RADIO is configured for little endian, see PCNF1.ENDIAN. The device address match unit assumes that the first 48 bits of the payload are the device address and that bit number 6 in S0 is the TxAdd bit. See the Bluetooth® Core Specification for more information about device addresses, TxAdd, and whitelisting. The RADIO is able to listen for eight different device addresses at the same time. These addresses are specified in a DAB/DAP register pair, one pair per address, in addition to a TxAdd bit configured in the DACNF register. The DAB register specifies the 32 least significant bits of the device address, while the DAP register specifies the 16 most significant bits of the device address. Each of the device addresses can be individually included or excluded from the matching mechanism. This is configured in the DACNF register. 6.14.11 Bit counter The RADIO implements a simple counter that can be configured to generate an event after a specific number of bits have been transmitted or received. By using shortcuts, this counter can be started from different events generated by the RADIO and count relative to these. The bit counter is started by triggering the BCSTART task, and stopped by triggering the BCSTOP task. A BCMATCH event will be generated when the bit counter has counted the number of bits specified in the 4454_140 v1.0 188 Peripherals BCC register. The bit counter will continue to count bits until the DISABLED event is generated or until the BCSTOP task is triggered. The CPU can therefore, after a BCMATCH event, reconfigure the BCC value for new BCMATCH events within the same packet. The bit counter can only be started after the RADIO has received the ADDRESS event. The bit counter will stop and reset on either the BCSTOP, STOP, or DISABLE task, or the END event. RX DISABLE 3 BCC = 12 + 16 BCSTART START CRC DISABLED BCMATCH BCMATCH READY 2 PAYLOAD 2 BCC = 12 1 RXEN 1 S0 L S1 BCSTOP Lifeline Assuming that the combined length of S0, length (L) and S1 is 12 bits. A ADDRESS Reception 0 ’X’ P RXDISABLE END RXRU PAYLOAD State The figure below illustrates how the bit counter can be used to generate a BCMATCH event in the beginning of the packet payload, and again generate a second BCMATCH event after sending 2 bytes (16 bits) of the payload. Figure 70: Bit counter example 6.14.12 Direction finding The RADIO implements the Angle-of-Arrival (AoA) and Angle-of-Departure (AoD) Bluetooth Low Energy feature, which can be used to determine the direction of a peer device. The feature is available for the BLE 1 Mbps and BLE 2 Mbps modes. When using this feature, the transmitter sends a packet with a continuous tone extension (CTE) appended to the packet, after the CRC. During the CTE, the receiver can take IQ samples of the incoming signal. An antenna array is employed at the transmitter (AoD) or at the receiver (AoA). The AoD transmitter, or AoA receiver, switches between the antennas, in order to collect IQ samples from the different antenna pairs. The IQ samples can be used to calculate the relative path lengths between the antenna pairs, which can be used to estimate the direction of the transmitter. 6.14.12.1 CTE format The CTE is from 16 µs to 160 µs and consists of an unwhitened sequence of 1's, equivalent to a continuous tone nominally offset from the carrier by +250 kHz for the 1 Mbps PHY and +500 kHz for the 2 Mbps BLE PHYs. The format of the CTE, when switching and/or sampling, is shown below. GUARD PERIOD REFERENCE PERIOD SWITCH SLOT SAMPLE SLOT 4 µs 8 µs 1 or 2 µs 1 or 2 µs SWITCH SLOT SAMPLE SLOT ... SWITCH SLOT SAMPLE SLOT 16-160 µs Figure 71: Constant tone extension (CTE) structure Antenna switching is performed during switch slots and the guard period. The AoA/AoD feature requires that one IQ sample is taken for each microsecond within the reference period, and once for each sample 4454_140 v1.0 189 Peripherals slot. Oversampling is possible by changing the sample spacing as described in IQ sampling on page 193. The switch slot and sample slot durations are either 1 or 2 µs, but must be equal. The format of the CTE and switching and sampling procedures may be configured prior to, or during, packet transmission and reception. Alternatively, during packet reception, these operations can be configured by reading specific fields of the packet contents. 6.14.12.2 Mode Depending on the DFEMODE, the device performs the following procedures: DFEMODE AOA TX Generating and transmitting CTE AoA/AoD Procedure AOD RX x TX RX x Receiving, interpreting, and sampling CTE x Antenna switching x x x Table 61: AoA/AoD Procedures performed as a function of DFEMODE and TX/RX mode 6.14.12.3 Inline configuration When inline configuration is enabled during RX, further configuration of the AoA/AoD procedures is performed based on the values of the CP bit and the CTEInfo octet within the packet. This is enabled by setting CTEINLINECONF.CTEINLINECTRLEN. The CTEInfo octet is present only if the CP bit is set. The position of the CP bit and CTEInfo octet depends on whether the packet has a Data Channel PDU (CTEINLINECONF.CTEINFOINS1=InS1), or an Advertising Channel PDU (CTEINLINECONF.CTEINFOINS1=NotInS1). Data channel PDU For Data Channel PDUs, PCNF0.S0LEN must be 1 byte, and PCNF0.LFLEN must be 8 bits. To determine if S1 is present, the registers CTEINLINECONF.S0MASK and CTEINLINECONF.S0CONF forms a bitwise mask-andtest for the S0 field. If the bitwise AND between S0 and S0MASK equals S0CONF, then S1 is determined to be present. When present, the value of PCNF0.S1LEN will be ignored, as this is decided by the CP bit in the the following figure. S0 LENGTH S1 ... CP ... Length CTEInfo 5 bits 1 bit 2 bits 8 bits 0 or 8 bits Figure 72: Data channel PDU header When encrypting and decrypting BLE packets using the CCM peripheral, it is also required to set PCNF0.S1INCL=1. The CCM mode must be configured to use an 8-bit length field. The value of the CP bit is included in the calculation of the MIC, while the S1 field is ignored by the CCM calculation. Advertising channel PDU For advertising channel PDUs, the CTEInfo Flag replaces the CP bit. The CTEInfo Flag is within the extended header flag field in some of the advertising PDUs that employ the common extended advertising payload format (i.e. AUX_SYNC_IND, AUX_CHAIN_IND). The format of such packets is shown in the following figure. 4454_140 v1.0 190 Peripherals S0 LENGTH PAYLOAD PDU Type ... Length Extended Header Length AdvMode ... CTEInfo flag ... AdvA TargetA CTEInfo ... 4 bits 4 bits 8 bits 6 bits 2 bits 2 bits 1 bit 5 bits 6 octets 6 octets 8 bits ... CRC CTE Extended Header Flags Figure 73: Advertising channel PDU header The CTEINLINECONF.S0CONF and CTEINLINECONF.S0MASK fields can be configured to accept only certain advertising PDU Types. If the extended header length is non-zero, the CTEInfo extended header flag is checked to determine whether CTEInfo is present. If a bit before the CTEInfo flag within the extended header flags is set, then the CTEInfo position is postponed 6 octets. CTEInfo parsing The CTEInfo field is shown in the following figure. CTETime RFU CTEType 5 bits 1 bit 2 bits Figure 74: CTEInfo field The CTETIME field defines the length of the CTE in 8 µs units. The valid upper bound of values can be adjusted using CTEINLINECONF.CTETIMEVALIDRANGE, including allowing use of the RFU bit within this field. If the CTETIME field is an invalid value of either 0 or 1, the CTE is assumed to be the minimum valid length of 16 µs. The slot duration is determined by the CTEType field. In RX this determines whether the sample spacing as defined in CTEINLINECONF.CTEINLINERXMODE1US or CTEINLINECONF.CTEINLINERXMODE2US is used. CTEType Description TX switch spacing RX sample spacing during Sample spacing RX during reference period reference period - TSAMPLESPACING1 TSAMPLESPACING2 0 AoA, no switching 1 AoD, 1 µs slots 2 µs TSAMPLESPACING1 CTEINLINERXMODE1US 2 AoD, 2 µs slots 4 µs TSAMPLESPACING1 CTEINLINERXMODE2US 3 Reserved for future use Table 62: Switching and sampling spacing based on CTEType 6.14.12.4 Manual configuration If CTEINLINECONF.CTEINLINECTRLEN is not set, then the packet is not parsed to determine the CTE parameters, and the antenna switching and sampling is controlled by other registers, see Antenna switching on page 192. The length of the CTE is given in 8 µs units by DFECTRL1.NUMBEROF8US. The start of the antenna switching and/or sampling (denoted as an AoA/AoD procedure), can be configured to start at some trigger with an additional offset. Using DFECTRL1.DFEINEXTENSION, the trigger can be configured to be the end of the CRC, or alternatively, the ADDRESS event. The additional offset for antenna switching is configured using DFECTRL2.TSWITCHOFFSET. Similarly, the additional offset for antenna sampling is configured using DFECTRL2.TSAMPLEOFFSET. 6.14.12.5 Receive- and transmit sequences The addition of the CTE to the transmitted packet is illustrated in the following figure. 4454_140 v1.0 191 PAYLOAD ADDRESS CTE (carrier) 2 3 TXEN START 1 CRC DISABLE Lifeline S0 L S1 TXDISABLE DISABLED A TXIDLE PHYEND P READY (carrier) TX END TXIDLE Transmitter TXRU PAYLOAD State Peripherals Figure 75: Transmit sequence with DFE RX CRC CTE 2 DISABLE 3 START RXEN RXDISABLE DISABLED PAYLOAD PAYLOAD S0 L S1 ADDRESS Lifeline 1 A CTEWARNING P READY ’X’ RXIDLE END RXIDLE Reception RXRU CTEPRESENT State The prescence of CTE within a received packet is signalled by the CTEPRESENT and CTEWARNING events illustrated in the figure below. Figure 76: Receive sequence with DFE 6.14.12.6 Antenna switching The RADIO can control up to 8 GPIO pins in order to control external antenna switches used in direction finding. Pin configuration The eight antenna selection signals are mapped to physical pins according to the pin numbers specified in the PSEL.DFEGPIO[n] registers. Only pins that have the PSEL.DFEGPIO[n].CONNECTED field set to Connected will be controlled by the RADIO. Pins that are Disconnected will be controlled by GPIO. During transmission in AoD TX mode or reception in AoA RX mode, the RADIO automatically acquires the pins as needed. At times when the RADIO does not use the pin, the pin is released to its default state and controlled by the GPIO configuration. Thus, the pin must be configured using the GPIO peripheral. Pin acquired by RADIO Direction Yes Output No Specified by GPIO Value Comment Specified in SWITCHPATTERN Pin acquired by RADIO, and in use for DFE. Specified by GPIO DFE not in progress. Pin has not been acquired by RADIO, but is available for DFE use. Table 63: Pin configuration matrix for a connected and enabled pin [n] 4454_140 v1.0 192 Peripherals Switch pattern configuration The values of the GPIOs while switching during the CTE are configured by writing successively to the SWITCHPATTERN register. The first write to SWITCHPATTERN is the GPIO pattern applied from the call of TASKS_TXEN or TASKS_RXEN until the first antenna switch is triggered. The second write sets the pattern for the reference period and is applied at the start of the guard period. The following writes set the pattern for the remaining switch slots and are applied at the start of each switch slot. If writing beyond the total number of antenna slots, the pattern will wrap to SWITCHPATTERN[2] and start over again. During operation, when the end of the SWITCHPATTERN buffer is reached, the RADIO cycles back to SWITCHPATTERN[2]. At the end of the AoA/AoD procedure, SWITCHPATTERN[0] is applied to DFECTRL1.TSWITCHSPACING after the previous antenna switch. The SWITCHPATTERN buffer can be erased/cleared using CLEARPATTERN. A minimum number of three patterns must be written to the SWITCHPATTERN register. If CTEINLINECONF.CTEINLINECTRLEN is not set, then the antenna switch spacing is determined by DFECTRL1.TSWITCHSPACING (otherwise described by Switching and sampling spacing based on CTEType on page 191). DFECTRL2.TSWITCHOFFSET determines the position of the first switch compared to the configurable start of CTE (see DFECTRL1.DFEINEXTENSION). 6.14.12.7 IQ sampling The RADIO uses DMA to write IQ samples recorded during the CTE to RAM. Alternatively, the magnitude and phase of the samples can be recorded using the DFECTRL1.SAMPLETYPE field. The samples are written to the location in RAM specified by DFEPACKET.PTR. The maximum number of samples to transfer are specified by DFEPACKET.MAXCNT and the number of samples transferred are given in DFEPACKET.AMOUNT. The IQ samples are recorded with respect to the RX carrier frequency. The format of the samples is provided in the following table. SAMPLETYPE Field Bits Description 0: I_Q (default) Q 31:16 12 bits signed, sign extended to 16 bits I 15:0 reserved 31:29 Always zero magnitude 28:16 13 bits unsigned. Equals 1.646756*sqrt(I^2+Q^2) phase 15:0 9 bits signed, sign extended to 16 bits. Equals 64*atan2(Q, I) in the range [-201,201] 1: MagPhase Table 64: Format of samples Oversampling is configured separately for the reference period and for the time after the reference period. During the reference period, the sample spacing is determined by DFECTRL1.TSAMPLESPACINGREF. DFECTRL2.TSAMPLEOFFSET determines the position of the first sample relative to the end of the last bit of the CRC. For the time after the reference period, if CTEINLINECONF.CTEINLINECTRLEN is disabled, the sample spacing is set in DFECTRL1.TSAMPLESPACING. However, when CTEINLINECONF.CTEINLINECTRLEN is enabled, the sample spacing are determined by two different registers, depending on whether the device is in AoA or AoD RX-mode, as follows. For AoD RX mode, the sample spacing after the reference period is determined by the CTEType in the packet, as listed in the table below. CTEType Sample spacing AoD 1 µs slots CTEINLINECONF.CTEINLINERXMODE1US AoD 2 µs slots CTEINLINECONF.CTEINLINERXMODE2US Other DFECTRL1.TSAMPLESPACING Table 65: Sample spacing when CTEINLINECONF.CTEINLINECTRLEN is set and the device is in AoD RX mode 4454_140 v1.0 193 Peripherals For AoA RX mode, the sample spacing after the reference period is determined by DFECTRL1.TSWITCHSPACING, as listed in the table below. DFECTRL1.TSWITCHSPACING Sample spacing 2 µs CTEINLINECONF.CTEINLINERXMODE1US 4 µs CTEINLINECONF.CTEINLINERXMODE2US Other DFECTRL1.TSAMPLESPACING Table 66: Sample spacing when CTEINLINECONF.CTEINLINECTRLEN is set and the device is in AoA RX mode For the reference- and switching periods, DFECTRL1.TSAMPLESPACINGREF and DFECTRL1.TSAMPLESPACING can be used to achieve oversampling. 6.14.13 IEEE 802.15.4 operation With the MODE=Ieee802154_250kbit the RADIO will comply with the IEEE 802.15.4-2006 standard implementing its 250 kbps, 2450 MHz, O-QPSK PHY. The IEEE 802.15.4 standard differs from Nordic's proprietary and Bluetooth® low energy modes. Notable differences include modulation scheme, channel structure, packet structure, security, and medium access control. The main features of the IEEE 802.15.4 mode are: • • • • Ultra-low power 250 kbps, 2450 MHz, IEEE 802.15.4-2006 compliant link Clear channel assessment Energy detection scan CRC generation 6.14.13.1 Packet structure The IEEE 802.15.4 standard defines an on-the-air frame/packet that is different from what is used in BLE mode. The following figure provides an overview of the physical frame structure and its timing. 160 µs Preamble sequence 32 µs PHY protocol data unit (PPDU) SFD Length 5 octets synchronization header (SHR) 1 octet (PHR) 0 Include 1 Always include S1 field in RAM independent of S1LEN G RW CILEN Length of code indicator - long range H RW PLEN Length of preamble on air. Decision point: TASKS_START task I J 8bit 0 8-bit preamble 16bit 1 16-bit preamble 32bitZero 2 32-bit zero preamble - used for IEEE 802.15.4 LongRange 3 Preamble - used for BLE long range Exclude 0 LENGTH does not contain CRC Include 1 LENGTH includes CRC RW CRCINC Indicates if LENGTH field contains CRC or not RW TERMLEN Length of TERM field in Long Range operation 6.14.15.52 PCNF1 Address offset: 0x518 Packet configuration register 1 4454_140 v1.0 A A A A 224 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID E D Reset 0x00000000 ID Access Field A RW MAXLEN C C C B B B B B B B B A A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description [0..255] Maximum length of packet payload. If the packet payload is larger than MAXLEN, the radio will truncate the payload to MAXLEN. B RW STATLEN [0..255] Static length in number of bytes The static length parameter is added to the total length of the payload when sending and receiving packets, e.g. if the static length is set to N the radio will receive or send N bytes more than what is defined in the LENGTH field of the packet. C RW BALEN [2..4] Base address length in number of bytes The address field is composed of the base address and the one byte long address prefix, e.g. set BALEN=2 to get a total address of 3 bytes. D RW ENDIAN On-air endianness of packet, this applies to the S0, LENGTH, S1, and the PAYLOAD fields. E Little 0 Least significant bit on air first Big 1 Most significant bit on air first Disabled 0 Disable Enabled 1 Enable RW WHITEEN Enable or disable packet whitening 6.14.15.53 BASE0 Address offset: 0x51C Base address 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW BASE0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Base address 0 6.14.15.54 BASE1 Address offset: 0x520 Base address 1 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW BASE1 Value ID Value Description Base address 1 6.14.15.55 PREFIX0 Address offset: 0x524 Prefixes bytes for logical addresses 0-3 4454_140 v1.0 225 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A-D RW AP[i] (i=0..3) Value ID Value Description Address prefix i. 6.14.15.56 PREFIX1 Address offset: 0x528 Prefixes bytes for logical addresses 4-7 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D D D D D C C C C C C C C B B B B B B B B A A A A A A A A Reset 0x00000000 ID Access Field A-D RW AP[i] (i=4..7) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Address prefix i. 6.14.15.57 TXADDRESS Address offset: 0x52C Transmit address select Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A Reset 0x00000000 ID Access Field A RW TXADDRESS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Transmit address select Logical address to be used when transmitting a packet 6.14.15.58 RXADDRESSES Address offset: 0x530 Receive address select Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID H G F E D C B A Reset 0x00000000 ID Access Field A-H RW ADDR[i] (i=0..7) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disable Enabled 1 Enable Enable or disable reception on logical address i. 6.14.15.59 CRCCNF Address offset: 0x534 CRC configuration 4454_140 v1.0 226 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B B Reset 0x00000000 ID Access Field A RW LEN A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description [1..3] CRC length in number of bytes. Note: For MODE Ble_LR125Kbit and Ble_LR500Kbit, only LEN set to 3 is supported B Disabled 0 CRC length is zero and CRC calculation is disabled One 1 CRC length is one byte and CRC calculation is enabled Two 2 CRC length is two bytes and CRC calculation is enabled Three 3 CRC length is three bytes and CRC calculation is enabled RW SKIPADDR Include or exclude packet address field out of CRC calculation. Include 0 CRC calculation includes address field Skip 1 CRC calculation does not include address field. The CRC Ieee802154 2 calculation will start at the first byte after the address. CRC calculation as per 802.15.4 standard. Starting at first byte after length field. 6.14.15.60 CRCPOLY Address offset: 0x538 CRC polynomial Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW CRCPOLY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CRC polynomial Each term in the CRC polynomial is mapped to a bit in this register which index corresponds to the term's exponent. The least significant term/bit is hardwired internally to 1, and bit number 0 of the register content is ignored by the hardware. The following example is for an 8 bit CRC polynomial: x8 + x7 + x3 + x2 + 1 = 1 1000 1101 . 6.14.15.61 CRCINIT Address offset: 0x53C CRC initial value Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW CRCINIT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CRC initial value Initial value for CRC calculation 6.14.15.62 TIFS Address offset: 0x544 4454_140 v1.0 227 Peripherals Interframe spacing in µs Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A Reset 0x00000000 ID Access Field A RW TIFS 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Interframe spacing in µs Interframe space is the time interval between two consecutive packets. It is defined as the time, in microseconds, from the end of the last bit of the previous packet to the start of the first bit of the subsequent packet. 6.14.15.63 RSSISAMPLE Address offset: 0x548 RSSI sample Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID RSSISAMPLE Value Description [0..127] RSSI sample RSSI sample result. The value of this register is read as a positive value while the actual received signal strength is a negative value. Actual received signal strength is therefore as follows: received signal strength = -A dBm 6.14.15.64 STATE Address offset: 0x550 Current radio state Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description STATE Current radio state Disabled 0 RADIO is in the Disabled state RxRu 1 RADIO is in the RXRU state RxIdle 2 RADIO is in the RXIDLE state Rx 3 RADIO is in the RX state RxDisable 4 RADIO is in the RXDISABLED state TxRu 9 RADIO is in the TXRU state TxIdle 10 RADIO is in the TXIDLE state Tx 11 RADIO is in the TX state TxDisable 12 RADIO is in the TXDISABLED state 6.14.15.65 DATAWHITEIV Address offset: 0x554 Data whitening initial value 4454_140 v1.0 228 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A Reset 0x00000040 ID Access Field A RW DATAWHITEIV 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 Value ID Value Description Data whitening initial value. Bit 6 is hardwired to '1', writing '0' to it has no effect, and it will always be read back and used by the device as '1'. Bit 0 corresponds to Position 6 of the LSFR, Bit 1 to Position 5, etc. 6.14.15.66 BCC Address offset: 0x560 Bit counter compare Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW BCC 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Bit counter compare Bit counter compare register 6.14.15.67 DAB[n] (n=0..7) Address offset: 0x600 + (n × 0x4) Device address base segment n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW DAB 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Device address base segment n 6.14.15.68 DAP[n] (n=0..7) Address offset: 0x620 + (n × 0x4) Device address prefix n Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW DAP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Device address prefix n 6.14.15.69 DACNF Address offset: 0x640 Device address match configuration 4454_140 v1.0 229 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID P O N M L K J I H G F E D C B A Reset 0x00000000 ID Access Field A-H RW ENA[i] (i=0..7) 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Enable or disable device address matching using device address i I-P Disabled 0 Disabled Enabled 1 Enabled RW TXADD[i] (i=0..7) TxAdd for device address i 6.14.15.70 MHRMATCHCONF Address offset: 0x644 Search pattern configuration Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW MHRMATCHCONF 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Search pattern configuration 6.14.15.71 MHRMATCHMAS Address offset: 0x648 Pattern mask Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW MHRMATCHMAS Value ID Value Description Pattern mask 6.14.15.72 MODECNF0 Address offset: 0x650 Radio mode configuration register 0 Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C C Reset 0x00000200 ID Access Field A RW RU 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 Value ID Value Default 0 Fast 1 Description Radio ramp-up time Default ramp-up time (tRXEN and tTXEN), compatible with firmware written for nRF51 Fast ramp-up (tRXEN,FAST and tTXEN,FAST), see electrical specification for more information When enabled, TIFS is not enforced by hardware and software needs to control when to turn on the Radio. 4454_140 v1.0 A 230 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C C Reset 0x00000200 ID Access Field C RW DTX A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 Value ID Value Description Default TX value Specifies what the RADIO will transmit when it is not started, i.e. between: RADIO.EVENTS_READY and RADIO.TASKS_START RADIO.EVENTS_END and RADIO.TASKS_START RADIO.EVENTS_END and RADIO.EVENTS_DISABLED Note: For 802.15.4 and BLE LR mode, only Center is a valid setting B1 0 Transmit '1' B0 1 Transmit '0' Center 2 Transmit center frequency When tuning the crystal for center frequency, the RADIO must be set in DTX = Center mode to be able to achieve the expected accuracy 6.14.15.73 SFD Address offset: 0x660 IEEE 802.15.4 start of frame delimiter Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x000000A7 ID Access Field A RW SFD 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 1 1 1 Value ID Value Description IEEE 802.15.4 start of frame delimiter 6.14.15.74 EDCNT Address offset: 0x664 IEEE 802.15.4 energy detect loop count Number of iterations to perform an ED scan. If set to 0 one scan is performed, otherwise the specified number + 1 of ED scans will be performed and the max ED value tracked in EDSAMPLE. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A RW EDCNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description IEEE 802.15.4 energy detect loop count 6.14.15.75 EDSAMPLE Address offset: 0x668 IEEE 802.15.4 energy detect level 4454_140 v1.0 231 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A RW EDLVL 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description [0..127] IEEE 802.15.4 energy detect level Register value must be converted to IEEE 802.15.4 range by an 8-bit saturating multiplication by factor ED_RSSISCALE, as shown in the code example for ED sampling 6.14.15.76 CCACTRL Address offset: 0x66C IEEE 802.15.4 clear channel assessment control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID D D D D D D D D C C C C C C C C B B B B B B B B Reset 0x052D0000 ID Access Field A RW CCAMODE A A A 0 0 0 0 0 1 0 1 0 0 1 0 1 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description CCA mode of operation EdMode 0 Energy above threshold Will report busy whenever energy is detected above CCAEDTHRES CarrierMode 1 Carrier seen Will report busy whenever compliant IEEE 802.15.4 signal is seen CarrierAndEdMode 2 Energy above threshold AND carrier seen CarrierOrEdMode 3 Energy above threshold OR carrier seen EdModeTest1 4 Energy above threshold test mode that will abort when first ED measurement over threshold is seen. No averaging. B RW CCAEDTHRES CCA energy busy threshold. Used in all the CCA modes except CarrierMode. Must be converted from IEEE 802.15.4 range by dividing by factor ED_RSSISCALE - similar to EDSAMPLE register C RW CCACORRTHRES D RW CCACORRCNT CCA correlator busy threshold. Only relevant to CarrierMode, CarrierAndEdMode, and CarrierOrEdMode. Limit for occurances above CCACORRTHRES. When not equal to zero the corrolator based signal detect is enabled. 6.14.15.77 DFEMODE Address offset: 0x900 Whether to use Angle-of-Arrival (AOA) or Angle-of-Departure (AOD) Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A Reset 0x00000000 ID Access Field A RW DFEOPMODE 4454_140 v1.0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Direction finding mode disabled AoD 2 Direction finding mode set to AoD AoA 3 Direction finding mode set to AoA Direction finding operation mode 232 Peripherals 6.14.15.78 CTEINLINECONF Address offset: 0x904 Configuration for CTE inline mode Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID I Reset 0x00002800 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW CTEINLINECTRLEN Value ID I I I I I I I H H H H H H H H G G G F F F Value E E C B Description Enable parsing of CTEInfo from received packet in BLE modes B C E Enabled 1 Parsing of CTEInfo is enabled Disabled 0 Parsing of CTEInfo is disabled InS1 1 CTEInfo is in S1 byte (data PDU) NotInS1 0 CTEInfo is NOT in S1 byte (advertising PDU) Yes 1 Sampling and antenna switching also when CRC is not OK No 0 No sampling and antenna switching when CRC is not OK RW CTEINFOINS1 CTEInfo is S1 byte or not RW CTEERRORHANDLING Sampling/switching if CRC is not OK RW CTETIMEVALIDRANGE Max range of CTETime Note: Valid range is 2-20 in BLE core spec. If larger than 20, it can be an indication of an error in the received packet. 20 0 20 in 8us unit (default) 31 1 31 in 8us unit 63 2 63 in 8us unit Set to 20 if parsed CTETime is larger han 20 F RW CTEINLINERXMODE1US Spacing between samples for the samples in the SWITCHING period when CTEINLINEMODE is set When the device is in AoD mode, this is used when the received CTEType is "AoD 1 us". When in AoA mode, this is used when TSWITCHSPACING is 2 us. G 4us 1 4us 2us 2 2us 1us 3 1us 500ns 4 0.5us 250ns 5 0.25us 125ns 6 0.125us RW CTEINLINERXMODE2US Spacing between samples for the samples in the SWITCHING period when CTEINLINEMODE is set When the device is in AoD mode, this is used when the received CTEType is "AoD 2 us". When in AoA mode, this is used when TSWITCHSPACING is 4 us. 4454_140 v1.0 4us 1 4us 2us 2 2us 1us 3 1us 500ns 4 0.5us 250ns 5 0.25us 125ns 6 0.125us 233 A Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID I Reset 0x00002800 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 ID Access Field H RW S0CONF Value ID I I I I I I I H H H H H H H H G G G F F F Value E E C B A Description S0 bit pattern to match The least significant bit always corresponds to the first bit of S0 received. I RW S0MASK S0 bit mask to set which bit to match The least significant bit always corresponds to the first bit of S0 received. 6.14.15.79 DFECTRL1 Address offset: 0x910 Various configuration for Direction finding Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID I I I I Reset 0x00023282 ID Access Field A RW NUMBEROF8US G G G F E E E C C C B A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 1 1 0 0 1 0 1 0 0 0 0 0 1 0 Value ID Value Description Length of the AoA/AoD procedure in number of 8 us units Always used in TX mode, but in RX mode only when CTEINLINECTRLEN is 0 B RW DFEINEXTENSION Add CTE extension and do antenna switching/sampling in this extension C CRC 1 AoA/AoD procedure triggered at end of CRC Payload 0 Antenna switching/sampling is done in the packet payload RW TSWITCHSPACING Interval between every time the antenna is changed in the SWITCHING state E F G 4us 1 4us 2us 2 2us 1us 3 1us 4us 1 4us 2us 2 2us 1us 3 1us 500ns 4 0.5us 250ns 5 0.25us 125ns 6 0.125us IQ 0 Complex samples in I and Q MagPhase 1 Complex samples as magnitude and phase RW TSAMPLESPACINGREF Interval between samples in the REFERENCE period RW SAMPLETYPE Whether to sample I/Q or magnitude/phase RW TSAMPLESPACING Interval between samples in the SWITCHING period when CTEINLINECTRLEN is 0 Note: Not used when CTEINLINECTRLEN is set. Then either CTEINLINERXMODE1US or CTEINLINERXMODE2US are used. 4454_140 v1.0 4us 1 4us 2us 2 2us 1us 3 1us 500ns 4 0.5us 234 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID I I I I Reset 0x00023282 ID I Access Field G G G F E E E C C C B A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 1 1 0 0 1 0 1 0 0 0 0 0 1 0 Value ID Value Description 250ns 5 0.25us 125ns 6 0.125us RW AGCBACKOFFGAIN Gain will be lowered by the specified number of gain steps at the start of CTE Note: First LNAGAIN gain drops, then MIXGAIN, then AAFGAIN 6.14.15.80 DFECTRL2 Address offset: 0x914 Start offset for Direction finding Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID B B B B B B B B B B B B Reset 0x00000000 ID Access Field A RW TSWITCHOFFSET B RW TSAMPLEOFFSET A A A A A A A A A A A A A 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Signed value offset after the end of the CRC before starting switching in number of 16M cycles Signed value offset before starting sampling in number of 16M cycles relative to the beginning of the REFERENCE state - 12 us after switching start 6.14.15.81 SWITCHPATTERN Address offset: 0x928 GPIO patterns to be used for each antenna Maximum 8 GPIOs can be controlled. To secure correct signal levels on the pins, the pins must be configured in the GPIO peripheral as described in Pin configuration. If, during switching, the total number of antenna slots is bigger than the number of written patterns, the RADIO loops back to the pattern used after the reference pattern. A minimum number of 3 patterns must be written. Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A RW SWITCHPATTERN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Fill array of GPIO patterns for antenna control The GPIO pattern array size is 40 entries. When written, bit n corresponds to the GPIO configured in PSEL.DFEGPIO[n]. When read, returns the number of GPIO patterns written since the last time the array was cleared. Use CLEARPATTERN to clear the array. 4454_140 v1.0 235 Peripherals 6.14.15.82 CLEARPATTERN Address offset: 0x92C Clear the GPIO pattern array for antenna control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW CLEARPATTERN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Clear 1 Description Clears GPIO pattern array for antenna control Clear the GPIO pattern 6.14.15.83 PSEL.DFEGPIO[n] (n=0..7) Address offset: 0x930 + (n × 0x4) Pin select for DFE pin n Must be set before enabling the radio Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID C Reset 0xFFFFFFFF ID Access Field A B C RW CONNECT B A A A A A 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Value ID Value Description RW PIN [0..31] Pin number RW PORT [0..1] Port number Connection Disconnected 1 Disconnect Connected 0 Connect 6.14.15.84 DFEPACKET.PTR Address offset: 0x950 Data pointer Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A A Reset 0x00000000 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 ID Access Field A RW PTR Value ID Value Description Data pointer Note: See the memory chapter for details about which memories are available for EasyDMA. 6.14.15.85 DFEPACKET.MAXCNT Address offset: 0x954 Maximum number of buffer words to transfer 4454_140 v1.0 236 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A Reset 0x00001000 ID Access Field A RW MAXCNT 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Maximum number of buffer words to transfer 6.14.15.86 DFEPACKET.AMOUNT Address offset: 0x958 Number of samples transferred in the last transaction Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description AMOUNT Number of samples transferred in the last transaction 6.14.15.87 POWER Address offset: 0xFFC Peripheral power control Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000001 ID Access Field A RW POWER 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 Value ID Value Description Peripheral power control. The peripheral and its registers will be reset to its initial state by switching the peripheral off and then back on again. Disabled 0 Peripheral is powered off Enabled 1 Peripheral is powered on 6.14.16 Electrical specification 6.14.16.1 General radio characteristics Symbol Description Min. fOP Operating frequencies 2360 Typ. Max. Units 2500 MHz fPLL,CH,SP PLL channel spacing 1 MHz fDELTA,1M Frequency deviation @ 1 Mbps ±170 kHz fDELTA,BLE,1M Frequency deviation @ BLE 1 Mbps ±250 kHz fDELTA,2M Frequency deviation @ 2 Mbps ±320 kHz fDELTA,BLE,2M Frequency deviation @ BLE 2 Mbps fskBPS On-the-air data rate fchip, IEEE 802.15.4 Chip rate in IEEE 802.15.4 mode ±500 125 kHz 2000 2000 kbps kchip/ s 6.14.16.2 Radio current consumption (transmitter) Symbol Description ITX,PLUS4dBM,DCDC TX only run current (DC/DC, 3 V) PRF = +4 dBm 4454_140 v1.0 Min. Typ. 7.0 237 Max. Units mA Peripherals Symbol Description Min. ITX,PLUS4dBM TX only run current PRF = +4 dBm 15.4 mA ITX,0dBM,DCDC TX only run current (DC/DC, 3 V)PRF = 0 dBm 4.6 mA ITX,0dBM TX only run current PRF = 0 dBm 10.1 mA ITX,MINUS4dBM,DCDC TX only run current DC/DC, 3 V PRF = -4 dBm 3.6 mA ITX,MINUS4dBM TX only run current PRF = -4 dBm 7.8 mA ITX,MINUS8dBM,DCDC TX only run current DC/DC, 3 V PRF = -8 dBm 3.2 mA ITX,MINUS8dBM TX only run current PRF = -8 dBm 6.8 mA ITX,MINUS12dBM,DCDC TX only run current DC/DC, 3 V PRF = -12 dBm 2.9 mA ITX,MINUS12dBM TX only run current PRF = -12 dBm Typ. Max. Units 6.2 mA ITX,MINUS16dBM,DCDC TX only run current DC/DC, 3 V PRF = -16 dBm 2.7 mA ITX,MINUS16dBM 5.7 mA ITX,MINUS20dBM,DCDC TX only run current DC/DC, 3 V PRF = -20 dBm 2.5 mA ITX,MINUS20dBM TX only run current PRF = -16 dBm 5.4 mA ITX,MINUS40dBM,DCDC TX only run current DC/DC, 3 V PRF = -40 dBm TX only run current PRF = -20 dBm 2.1 mA ITX,MINUS40dBM TX only run current PRF = -40 dBm 4.3 ISTART,TX,DCDC TX start-up current DC/DC, 3 V, PRF = 4 dBm .. .. .. mA ISTART,TX TX start-up current, PRF = 4 dBm .. .. .. mA Min. Typ. Max. Units mA 6.14.16.3 Radio current consumption (Receiver) Symbol Description IRX,1M,DCDC RX only run current (DC/DC, 3 V) 1 Mbps/1 Mbps BLE 4.6 mA IRX,1M RX only run current (LDO, 3 V) 1 Mbps/1 Mbps BLE 10.0 mA IRX,2M,DCDC RX only run current (DC/DC, 3 V) 2 Mbps/2 Mbps BLE 5.2 mA IRX,2M RX only run current (LDO, 3 V) 2 Mbps/2 Mbps BLE 11.2 mA ISTART,RX,1M,DCDC RX start-up current (DC/DC, 3 V) 1 Mbps/1 Mbps BLE 3.5 mA ISTART,RX,1M RX start-up current 1 Mbps/1 Mbps BLE 6.7 mA 6.14.16.4 Transmitter specification Symbol Description Min. PRF Maximum output power 4.0 PRFC RF power control range 24 PRFCR RF power accuracy PRF1,1 1st Adjacent Channel Transmit Power 1 MHz (1 Mbps) -25 dBc PRF2,1 2nd Adjacent Channel Transmit Power 2 MHz (1 Mbps) -50 dBc PRF1,2 1st Adjacent Channel Transmit Power 2 MHz (2 Mbps) -25 dBc PRF2,2 2nd Adjacent Channel Transmit Power 4 MHz (2 Mbps) -50 dBc Evm Max. Error vector magnitude IEEE 802.15.4 12 %rms -45 dBm Pharm3rd, IEEE 802.15.4 3rd harmonics in IEEE 802.15.4 Units dBm dB ±4 Pharm2nd, IEEE 802.15.4 2nd harmonics in IEEE 802.15.4 mode 4454_140 v1.0 Typ. dB dBm 238 Peripherals 6 5.5 Output power [dBm] 5 4.5 4 3.5 3 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 3.6 3.4 3.6 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 85: Output power, 1 Mbps Bluetooth low energy mode, at maximum TXPOWER setting (typical values) 2.5 2 Output power [dBm] 1.5 1 0.5 0 -0.5 -1 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 86: Output power, 1 Mbps Bluetooth low energy mode, at 0 dBm TXPOWER setting (typical values) 4454_140 v1.0 239 Peripherals 6.14.16.5 Receiver operation Symbol Description PRX,MAX Maximum received signal strength at < 0.1% PER Min. Typ. Max. Units 0 dBm PSENS,IT,1M 14 Sensitivity, 1 Mbps nRF mode ideal transmitter -94 dBm PSENS,IT,2M Sensitivity, 2 Mbps nRF mode ideal transmitter15 -91 dBm PSENS,IT,SP,1M,BLE Sensitivity, 1 Mbps BLE ideal transmitter, packet length ≤ 37 -97 dBm -96 dBm -94 dBm bytes BER=1E-316 PSENS,IT,LP,1M,BLE Sensitivity, 1 Mbps BLE ideal transmitter, packet length ≥ 128 bytes BER=1E-4 17 PSENS,IT,SP,2M,BLE Sensitivity, 2 Mbps BLE ideal transmitter, packet length ≤ 37 bytes PSENS,IT,BLE LE125k Sensitivity, 125 kbps BLE mode -104 dBm PSENS,IT,BLE LE500k Sensitivity, 500 kbps BLE mode -100 dBm PSENS,IEEE 802.15.4 Sensitivity in IEEE 802.15.4 mode -101 dBm -95.5 -96 Sensitivity [dBm] -96.5 -97 -97.5 -98 -98.5 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 3.6 Supply voltage [V] -40 ºC 25 ºC 85 ºC Figure 87: Sensitivity, 1 Mbps Bluetooth low energy mode, Regulator = LDO (typical values) 6.14.16.6 RX selectivity RX selectivity with equal modulation on interfering signal18 14 15 16 17 18 Typical sensitivity applies when ADDR0 is used for receiver address correlation. When ADDR[1...7] are used for receiver address correlation, the typical sensitivity for this mode is degraded by 3 dB. Typical sensitivity applies when ADDR0 is used for receiver address correlation. When ADDR[1..7] are used for receiver address correlation, the typical sensitivity for this mode is degraded by 3 dB. As defined in the Bluetooth Core Specification v4.0 Volume 6: Core System Package (Low Energy Controller Volume) Equivalent BER limit < 10E-04 Desired signal level at PIN = -67 dBm. One interferer is used, having equal modulation as the desired signal. The input power of the interferer where the sensitivity equals BER = 0.1% is presented 4454_140 v1.0 240 Peripherals Symbol Description Min. Typ. Max. Units C/I1M,co-channel 1Mbps mode, Co-Channel interference 9 dB C/I1M,-1MHz 1 Mbps mode, Adjacent (-1 MHz) interference -2 dB C/I1M,+1MHz 1 Mbps mode, Adjacent (+1 MHz) interference -10 dB C/I1M,-2MHz 1 Mbps mode, Adjacent (-2 MHz) interference -19 dB C/I1M,+2MHz 1 Mbps mode, Adjacent (+2 MHz) interference -42 dB C/I1M,-3MHz 1 Mbps mode, Adjacent (-3 MHz) interference -38 dB C/I1M,+3MHz 1 Mbps mode, Adjacent (+3 MHz) interference -48 dB C/I1M,±6MHz 1 Mbps mode, Adjacent (≥6 MHz) interference -50 dB C/I1MBLE,co-channel 1 Mbps BLE mode, Co-Channel interference 6 dB C/I1MBLE,-1MHz 1 Mbps BLE mode, Adjacent (-1 MHz) interference -2 dB C/I1MBLE,+1MHz 1 Mbps BLE mode, Adjacent (+1 MHz) interference -9 dB C/I1MBLE,-2MHz 1 Mbps BLE mode, Adjacent (-2 MHz) interference -22 dB C/I1MBLE,+2MHz 1 Mbps BLE mode, Adjacent (+2 MHz) interference -46 dB C/I1MBLE,>3MHz 1 Mbps BLE mode, Adjacent (≥3 MHz) interference -50 dB C/I1MBLE,image Image frequency interference -22 dB C/I1MBLE,image,1MHz Adjacent (1 MHz) interference to in-band image frequency -35 dB C/I2M,co-channel 2 Mbps mode, Co-Channel interference 10 dB C/I2M,-2MHz 2 Mbps mode, Adjacent (-2 MHz) interference 6 dB C/I2M,+2MHz 2 Mbps mode, Adjacent (+2 MHz) interference -14 dB C/I2M,-4MHz 2 Mbps mode, Adjacent (-4 MHz) interference -20 dB C/I2M,+4MHz 2 Mbps mode, Adjacent (+4 MHz) interference -44 dB C/I2M,-6MHz 2 Mbps mode, Adjacent (-6 MHz) interference -42 dB C/I2M,+6MHz 2 Mbps mode, Adjacent (+6 MHz) interference -47 dB C/I2M,≥12MHz 2 Mbps mode, Adjacent (≥12 MHz) interference -52 dB C/I2MBLE,co-channel 2 Mbps BLE mode, Co-Channel interference 6 dB C/I2MBLE,±2MHz 2 Mbps BLE mode, Adjacent (±2 MHz) interference -2 dB C/I2MBLE,±4MHz 2 Mbps BLE mode, Adjacent (±4 MHz) interference -48 dB C/I2MBLE,≥6MHz 2 Mbps BLE mode, Adjacent (≥6 MHz) interference -50 dB C/I2MBLE,image Image frequency interference -29 dB C/I2MBLE,image, 2MHz Adjacent (2 MHz) interference to in-band image frequency -44 dB C/I125k BLE LR,co- 125 kbps BLE LR mode, Co-Channel interference 4 dB C/I125k BLE LR,-1MHz 125 kbps BLE LR mode, Adjacent (-1 MHz) interference -9 dB C/I125k BLE LR,+1MHz 125 kbps BLE LR mode, Adjacent (+1 MHz) interference -16 dB C/I125k BLE LR,-2MHz 125 kbps BLE LR mode, Adjacent (-2 MHz) interference -30 dB C/I125k BLE LR,+2MHz 125 kbps BLE LR mode, Adjacent (+2 MHz) interference -50 dB C/I125k BLE LR,>3MHz 125 kbps BLE LR mode, Adjacent (≥3 MHz) interference -55 dB C/I125k BLE LR,image Image frequency interference -30 dB C/IIEEE 802.15.4,-5MHz IEEE 802.15.4 mode, Adjacent (-5 MHz) rejection 33 dB C/IIEEE 802.15.4,+5MHz IEEE 802.15.4 mode, Adjacent (+5 MHz) rejection 38 dB C/IIEEE 802.15.4,| 48 dB channel IEEE 802.15.4 mode, Alternate (10 MHz) rejection 10MHz| 6.14.16.7 RX intermodulation RX intermodulation19 19 Desired signal level at PIN = -64 dBm. Two interferers with equal input power are used. The interferer closest in frequency is not modulated, the other interferer is modulated equal with the desired signal. The input power of the interferers where the sensitivity equals BER = 0.1% is presented. 4454_140 v1.0 241 Peripherals Symbol Description Min. PIMD,5TH,1M IMD performance, 1 Mbps, 5th offset channel, packet length Typ. Max. Units -33 dBm -30 dBm -33 dBm -31 dBm ≤ 37 bytes PIMD,5TH,1M,BLE IMD performance, BLE 1 Mbps, 5th offset channel, packet length ≤ 37 bytes PIMD,5TH,2M IMD performance, 2 Mbps, 5th offset channel, packet length ≤ 37 bytes PIMD,5TH,2M,BLE IMD performance, BLE 2 Mbps, 5th offset channel, packet length ≤ 37 bytes 6.14.16.8 Radio timing Symbol Description Min. Max. Units tTXEN,BLE,1M Time between TXEN task and READY event after channel 140 Typ. 140 µs 40 40 µs 6 6 µs 140 140 µs 40 40 µs 0 0 µs 4 4 µs 0 0 µs 130 130 µs 40 40 µs 21 21 µs 130 130 µs 40 40 µs 0.5 0.5 µs FREQUENCY configured (1 Mbps BLE and 150 µs TIFS) tTXEN,FAST,BLE,1M Time between TXEN task and READY event after channel FREQUENCY configured (1 Mbps BLE with fast ramp-up and 150 µs TIFS) tTXDIS,BLE,1M When in TX, delay between DISABLE task and DISABLED event for MODE = Nrf_1Mbit and MODE = Ble_1Mbit tRXEN,BLE,1M Time between the RXEN task and READY event after channel FREQUENCY configured (1 Mbps BLE) tRXEN,FAST,BLE,1M Time between the RXEN task and READY event after channel FREQUENCY configured (1 Mbps BLE with fast ramp-up) tRXDIS,BLE,1M When in RX, delay between DISABLE task and DISABLED event for MODE = Nrf_1Mbit and MODE = Ble_1Mbit tTXDIS,BLE,2M When in TX, delay between DISABLE task and DISABLED event for MODE = Nrf_2Mbit and MODE = Ble_2Mbit tRXDIS,BLE,2M When in RX, delay between DISABLE task and DISABLED event for MODE = Nrf_2Mbit and MODE = Ble_2Mbit tTXEN,IEEE 802.15.4 Time between TXEN task and READY event after channel FREQUENCY configured (IEEE 802.15.4) tTXEN,FAST,IEEE 802.15.4 Time between TXEN task and READY event after channel FREQUENCY configured (IEEE 802.15.4 with fast ramp-up) tTXDIS,IEEE 802.15.4 When in TX, delay between DISABLE task and DISABLED event (IEEE 802.15.4) tRXEN,IEEE 802.15.4 Time between the RXEN task and READY event after channel FREQUENCY configured (IEEE 802.15.4) tRXEN,FAST,IEEE 802.15.4 Time between the RXEN task and READY event after channel FREQUENCY configured (IEEE 802.15.4 with fast ramp-up) tRXDIS,IEEE 802.15.4 When in RX, delay between DISABLE task and DISABLED event (IEEE 802.15.4) tRX-to-TX turnaround Maximum TX-to-RX or RX-to-TX turnaround time in IEEE 40 µs 802.15.4 mode 6.14.16.9 Received signal strength indicator (RSSI) specifications Symbol Description RSSIACC RSSI accuracy valid range -90 to -20 dBm ±2 dB RSSIRESOLUTION RSSI resolution 1 dB RSSIPERIOD RSSI sampling time from RSSI_START task 0.25 µs RSSISETTLE RSSI settling time after signal level change 15 µs 4454_140 v1.0 Min. 242 Typ. Max. Units Peripherals 6.14.16.10 Jitter Symbol Description tDISABLEDJITTER Jitter on DISABLED event relative to END event when Min. Typ. Max. Units 0.25 µs 0.25 µs shortcut between END and DISABLE is enabled tREADYJITTER Jitter on READY event relative to TXEN and RXEN task 6.14.16.11 IEEE 802.15.4 energy detection constants Symbol Description Min. Typ. Max. ED_RSSISCALE Scaling value when converting between hardware-reported 4 4 4 -92 -92 -92 Units value and dBm ED_RSSIOFFS Offset value when converting between hardware-reported value and dBm 6.15 RNG — Random number generator The Random number generator (RNG) generates true non-deterministic random numbers based on internal thermal noise that are suitable for cryptographic purposes. The RNG does not require a seed value. START STOP Random number generator VALRDY VALUE Figure 88: Random number generator The RNG is started by triggering the START task and stopped by triggering the STOP task. When started, new random numbers are generated continuously and written to the VALUE register when ready. A VALRDY event is generated for every new random number that is written to the VALUE register. This means that after a VALRDY event is generated the CPU has the time until the next VALRDY event to read out the random number from the VALUE register before it is overwritten by a new random number. 6.15.1 Bias correction A bias correction algorithm is employed on the internal bit stream to remove any bias toward '1' or '0'. The bits are then queued into an eight-bit register for parallel readout from the VALUE register. It is possible to enable bias correction in the CONFIG register. This will result in slower value generation, but will ensure a statistically uniform distribution of the random values. 6.15.2 Speed The time needed to generate one random byte of data is unpredictable, and may vary from one byte to the next. This is especially true when bias correction is enabled. 4454_140 v1.0 243 Peripherals 6.15.3 Registers Base address Peripheral Instance Description Configuration 0x4000D000 RNG RNG Random number generator Table 70: Instances Register Offset Description TASKS_START 0x000 Task starting the random number generator TASKS_STOP 0x004 Task stopping the random number generator EVENTS_VALRDY 0x100 Event being generated for every new random number written to the VALUE register SHORTS 0x200 Shortcuts between local events and tasks INTENSET 0x304 Enable interrupt INTENCLR 0x308 Disable interrupt CONFIG 0x504 Configuration register VALUE 0x508 Output random number Table 71: Register overview 6.15.3.1 TASKS_START Address offset: 0x000 Task starting the random number generator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_START Task starting the random number generator Trigger task 6.15.3.2 TASKS_STOP Address offset: 0x004 Task stopping the random number generator Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A W 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Trigger 1 Description TASKS_STOP Task stopping the random number generator Trigger task 6.15.3.3 EVENTS_VALRDY Address offset: 0x100 Event being generated for every new random number written to the VALUE register 4454_140 v1.0 244 Peripherals Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW EVENTS_VALRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Event being generated for every new random number written to the VALUE register NotGenerated 0 Event not generated Generated 1 Event generated 6.15.3.4 SHORTS Address offset: 0x200 Shortcuts between local events and tasks Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW VALRDY_STOP 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Shortcut between event VALRDY and task STOP Disabled 0 Disable shortcut Enabled 1 Enable shortcut 6.15.3.5 INTENSET Address offset: 0x304 Enable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW VALRDY 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Write '1' to enable interrupt for event VALRDY Set 1 Enable Disabled 0 Read: Disabled Enabled 1 Read: Enabled 6.15.3.6 INTENCLR Address offset: 0x308 Disable interrupt Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW VALRDY 4454_140 v1.0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Clear 1 Disable Disabled 0 Read: Disabled Enabled 1 Read: Enabled Write '1' to disable interrupt for event VALRDY 245 Peripherals 6.15.3.7 CONFIG Address offset: 0x504 Configuration register Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A Reset 0x00000000 ID Access Field A RW DERCEN 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID Value Description Disabled 0 Disabled Enabled 1 Enabled Bias correction 6.15.3.8 VALUE Address offset: 0x508 Output random number Bit number 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 ID A A A A A A A A Reset 0x00000000 ID Access Field A R 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 Value ID VALUE Value Description [0..255] Generated random number 6.15.4 Electrical specification 6.15.4.1 RNG Electrical Specification Symbol Description tRNG,START Time from setting the START task to generation begins. Min. Typ. Max. Units 128 µs 30 µs 120 µs This is a one-time delay on START signal and does not apply between samples. tRNG,RAW Run time per byte without bias correction. Uniform distribution of 0 and 1 is not guaranteed. tRNG,BC Run time per byte with bias correction. Uniform distribution of 0 and 1 is guaranteed. Time to generate a byte cannot be guaranteed. 6.16 RTC — Real-time counter The Real-time counter (RTC) module provides a generic, low power timer on the low-frequency clock source (LFCLK). 4454_140 v1.0 246 Peripherals 32.768 kHz START STOP CLEAR TRIGOVRFLW task PRESCALER event TICK event OVRFLW event COMPARE[0..N] COUNTER task RTC task task CC[0:3] Figure 89: RTC block schematic The RTC module features a 24-bit COUNTER, a 12-bit (1/X) prescaler, capture/compare registers, and a tick event generator for low power, tickless RTOS implementation. 6.16.1 Clock source The RTC will run off the LFCLK. The COUNTER resolution will therefore be 30.517 μs. Depending on the source, the RTC is able to run while the HFCLK is OFF and PCLK16M is not available. The software has to explicitely start LFCLK before using the RTC. See CLOCK — Clock control on page 61 for more information about clock sources. 6.16.2 Resolution versus overflow and the PRESCALER Counter increment frequency: fRTC [kHz] = 32.768 / (PRESCALER + 1 ) The PRESCALER register is read/write when the RTC is stopped. The PRESCALER register is read-only once the RTC is STARTed. Writing to the PRESCALER register when the RTC is started has no effect. The PRESCALER is restarted on START, CLEAR and TRIGOVRFLW, that is, the prescaler value is latched to an internal register () on these tasks. Examples: 1. Desired COUNTER frequency 100 Hz (10 ms counter period) PRESCALER = round(32.768 kHz / 100 Hz) - 1 = 327 fRTC = 99.9 Hz 10009.576 μs counter period 2. Desired COUNTER frequency 8 Hz (125 ms counter period) PRESCALER = round(32.768 kHz / 8 Hz) – 1 = 4095 fRTC = 8 Hz 4454_140 v1.0 247 Peripherals 125 ms counter period Prescaler Counter resolution Overflow 0 30.517 μs 512 seconds 28-1 7812.5 μs 131072 seconds 125 ms 582.542 hours 12 2 -1 Table 72: RTC resolution versus overflow 6.16.3 COUNTER register The COUNTER increments on LFCLK when the internal PRESCALER register () is 0x00. is reloaded from the PRESCALER register. If enabled, the TICK event occurs on each increment of the COUNTER. The TICK event is disabled by default. SysClk LFClk TICK PRESC COUNTER 0x000 0x000 0x000 0x000 0x000 0x000000 0x000001 0x000002 0x000003 Figure 90: Timing diagram - COUNTER_PRESCALER_0 SysClk LFClk TICK PRESC 0x001 0x000 COUNTER 0x001 0x000000 0x000 0x001 0x000001 Figure 91: Timing diagram - COUNTER_PRESCALER_1 6.16.4 Overflow features The TRIGOVRFLW task sets the COUNTER value to 0xFFFFF0 to allow SW test of the overflow condition. OVRFLW occurs when COUNTER overflows from 0xFFFFFF to 0. Important: The OVRFLW event is disabled by default. 6.16.5 TICK event The TICK event enables low power "tick-less" RTOS implementation as it optionally provides a regular interrupt source for a RTOS without the need to use the ARM® SysTick feature. Using the RTC TICK event rather than the SysTick allows the CPU to be powered down while still keeping RTOS scheduling active. 4454_140 v1.0 248 Peripherals Important: The TICK event is disabled by default. 6.16.6 Event control feature To optimize RTC power consumption, events in the RTC can be individually disabled to prevent PCLK16M and HFCLK being requested when those events are triggered. This is managed using the EVTEN register. For example, if the TICK event is not required for an application, this event should be disabled as it is frequently occurring and may increase power consumption if HFCLK otherwise could be powered down for long durations. This means that the RTC implements a slightly different task and event system compared to the standard system described in Peripheral interface on page 74. The RTC task and event system is illustrated in Tasks, events and interrupts in the RTC on page 249. Task signal from PPI RTC write TASK OR task RTC core event EVTEN m INTEN m EVENT m IRQ signal to NVIC Event signal to PPI Figure 92: Tasks, events and interrupts in the RTC 6.16.7 Compare feature There are a number of Compare registers. For more information, see Registers on page 254. When setting a compare register, the following behavior of the RTC compare event should be noted: • If a CC register value is 0 when a CLEAR task is set, this will not trigger a COMPARE event. 4454_140 v1.0 249 Peripherals SysClk LFClk PRESC 0x000 COUNTER X 0x000000 CLEAR CC[0] 0x000000 COMPARE[0] 0 Figure 93: Timing diagram - COMPARE_CLEAR • If a CC register is N and the COUNTER value is N when the START task is set, this will not trigger a COMPARE event. SysClk LFClk PRESC 0x000 COUNTER N-1 N N+1 START CC[0] N COMPARE[0] 0 Figure 94: Timing diagram - COMPARE_START • COMPARE occurs when a CC register is N and the COUNTER value transitions from N-1 to N. SysClk LFClk PRESC COUNTER 0x000 N-2 N-1 CC[0] COMPARE[0] N N+1 N 0 1 Figure 95: Timing diagram - COMPARE • If the COUNTER is N, writing N+2 to a CC register is guaranteed to trigger a COMPARE event at N+2. 4454_140 v1.0 250 Peripherals SysClk LFClk PRESC COUNTER 0x000 N-1 N N+1 N+2 > 62.5 ns CC[0] X N+2 COMPARE[0] 0 1 Figure 96: Timing diagram - COMPARE_N+2 • If the COUNTER is N, writing N or N+1 to a CC register may not trigger a COMPARE event. SysClk LFClk PRESC COUNTER 0x000 N-2 N-1 N N+1 >= 0 CC[0] X N+1 COMPARE[0] 0 Figure 97: Timing diagram - COMPARE_N+1 • If the COUNTER is N and the current CC register value is N+1 or N+2 when a new CC value is written, a match may trigger on the previous CC value before the new value takes effect. If the current CC value greater than N+2 when the new value is written, there will be no event due to the old value. SysClk LFClk PRESC COUNTER CC[0] 0x000 N-2 N-1 N N+1 >= 0 N X COMPARE[0] 0 1 Figure 98: Timing diagram - COMPARE_N-1 6.16.8 TASK and EVENT jitter/delay Jitter or delay in the RTC is due to the peripheral clock being a low frequency clock (LFCLK) which is not synchronous to the faster PCLK16M. Registers in the peripheral interface, part of the PCLK16M domain, have a set of mirrored registers in the LFCLK domain. For example, the COUNTER value accessible from the CPU is in the PCLK16M domain and is latched on read from an internal register called COUNTER in the LFCLK domain. COUNTER is the register which is actually modified each time the RTC ticks. These registers must be synchronised between clock domains (PCLK16M and LFCLK). 4454_140 v1.0 251 Peripherals The following is a summary of the jitter introduced on tasks and events. Figures illustrating jitter follow. Task Delay CLEAR, STOP, START, TRIGOVRFLOW +15 to 46 μs Table 73: RTC jitter magnitudes on tasks Operation/Function Jitter START to COUNTER increment COMPARE to COMPARE +/- 15 μs +/- 62.5 ns 20 Table 74: RTC jitter magnitudes on events 1. CLEAR and STOP (and TRIGOVRFLW; not shown) will be delayed as long as it takes for the peripheral to clock a falling edge and rising of the LFCLK. This is between 15.2585 μs and 45.7755 μs – rounded to 15 μs and 46 μs for the remainder of the section. SysClk CLEAR LFClk PRESC COUNTER CLEARa 0x000 X X+1 0x000000 0x000001 0 or more SysClk after = ~15 us 1 or more SysClk before CLEARb Figure 99: Timing diagram - DELAY_CLEAR SysClk STOP LFClk PRESC COUNTER STOPa STOPb 0x000 X X+1 0 or more SysClk after = ~15 us 1 or more SysClk before Figure 100: Timing diagram - DELAY_STOP 2. The START task will start the RTC. Assuming that the LFCLK was previously running and stable, the first increment of COUNTER (and instance of TICK event) will be typically after 30.5 μs +/-15 μs. In some cases, in particular if the RTC is STARTed before the LFCLK is running, that timing can be up to ~250 μs. The software should therefore wait for the first TICK if it has to make sure the RTC is running. 20 Assumes RTC runs continuously between these events. Note: 32.768 kHz clock jitter is additional to the numbers provided above. 4454_140 v1.0 252 Peripherals Sending a TRIGOVRFLW task sets the COUNTER to a value close to overflow. However, since the update of COUNTER relies on a stable LFCLK, sending this task while LFCLK is not running will start LFCLK, but the update will then be delayed by the same amount of time of up to ~250 us. The figures show the smallest and largest delays to on the START task which appears as a +/-15 μs jitter on the first COUNTER increment. SysClk First tick LFClk PRESC 0x000 COUNTER X X+1 X+2 X+3 >= ~15 us 0 or more SysClk before START Figure 101: Timing diagram - JITTER_STARTSysClk First tick LFClk PRESC 0x000 COUNTER X X+1 X+2
NRF52811-CAAA-R 价格&库存
很抱歉,暂时无法提供与“NRF52811-CAAA-R”相匹配的价格&库存,您可以联系我们找货
