KX222-1054
KX222-1054
    KIONIX(Kionix传感器)
    LGA-12(2x2)
    Accelerometers Medium-G Tri-Axis, User Selectable +/- 8g, 16g, 32g, Digital (I2C/SPI) Output, Integr...
KX222-1054 数据手册
PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Product Description The KX222-1054 is a tri-axis ±8g, ±16g or ±32g silicon micromachined accelerometer with integrated 2048-byte buffer, orientation, Directional-TapTM/Double-TapTM, activity detecting, and Free fall algorithms. The sense element is fabricated using Kionix’s proprietary plasma micromachining process technology. Acceleration sensing is based on the principle of a differential capacitance arising from acceleration-induced motion of the sense element, which further utilizes common mode cancellation to decrease errors from process variation, temperature, and environmental stress. The sense element is hermetically sealed at the wafer level by bonding a second silicon lid wafer to the device using a glass frit. A separate ASIC device packaged with the sense element provides signal conditioning, and intelligent user-programmable application algorithms. The accelerometer is delivered in a 2 x 2 x 0.9 mm LGA plastic package operating from a 1.71V – 3.6V DC supply. Voltage regulators are used to maintain constant internal operating voltages over the range of input supply voltages. This results in stable operating characteristics over the range of input supply voltages. I2C or SPI digital protocol is used to communicate with the chip to configure and check for updates to the orientation, Directional-TapTM/Double-TapTM detection, Free fall detection, and activity monitoring algorithms. 2 x 2 x 0.9 mm LGA User-selectable g Range up to ±32g User-selectable Output Data Rate up to 25600Hz User-selectable Low Power or High Resolution modes Digital High-Pass Filter Outputs Extra-large embedded 2048 byte FIFO/FILO buffer Low Power Consumption with FlexSet™ Performance Optimization Internal voltage regulator Enhanced integrated Free fall, Directional-TapTM/Double-TapTM, and Device-orientation Algorithms User-configurable wake-up function Digital I2C up to 3.4MHz and Digital SPI up to 10MHz Lead-free Solderability Excellent Temperature Performance High Shock Survivability Factory Programmed Offset and Sensitivity Self-test Function N ot R Features • • • • • • • • • • • • • • • • 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 1 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Table of Contents PRODUCT DESCRIPTION ....................................................................................................................................................................1 FEATURES .........................................................................................................................................................................................1 TABLE OF CONTENTS .........................................................................................................................................................................2 FUNCTIONAL DIAGRAM ....................................................................................................................................................................5 PRODUCT SPECIFICATIONS................................................................................................................................................................6 ot R MECHANICAL ............................................................................................................................................................................................ 6 ELECTRICAL ............................................................................................................................................................................................... 7 Start Up Time Profile ........................................................................................................................................................................ 8 Current Profile .................................................................................................................................................................................. 8 Power-On Procedure......................................................................................................................................................................... 9 ENVIRONMENTAL..................................................................................................................................................................................... 10 TERMINOLOGY ........................................................................................................................................................................................ 11 g ...................................................................................................................................................................................................... 11 Sensitivity........................................................................................................................................................................................ 11 Zero-g offset ................................................................................................................................................................................... 11 Self-test ........................................................................................................................................................................................... 11 FUNCTIONALITY ....................................................................................................................................................................................... 12 Sense element................................................................................................................................................................................. 12 ASIC interface ................................................................................................................................................................................. 12 Factory calibration .......................................................................................................................................................................... 12 APPLICATION SCHEMATIC AND PIN DESCRIPTION ........................................................................................................................................... 13 Application Schematic .................................................................................................................................................................... 13 Pin Description ................................................................................................................................................................................ 13 PACKAGE DIMENSIONS AND ORIENTATION ................................................................................................................................................... 14 Dimensions ..................................................................................................................................................................................... 14 Orientation ..................................................................................................................................................................................... 15 DIGITAL INTERFACE ......................................................................................................................................................................... 17 N I2C SERIAL INTERFACE ............................................................................................................................................................................... 17 I2C Operation .................................................................................................................................................................................. 18 Writing to an 8-bit Register ............................................................................................................................................................ 19 Reading from an 8-bit Register ....................................................................................................................................................... 20 Data Transfer Sequences ................................................................................................................................................................ 21 HS-mode ......................................................................................................................................................................................... 22 I2C Timing Diagram ......................................................................................................................................................................... 23 SPI COMMUNICATIONS............................................................................................................................................................................. 24 4-Wire SPI Interface ........................................................................................................................................................................ 24 4-Wire SPI Timing Diagram ............................................................................................................................................................ 25 4-Wire Read and Write Registers ................................................................................................................................................... 26 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 2 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications 3-Wire SPI Interface ........................................................................................................................................................................ 27 3-Wire SPI Timing Diagram ............................................................................................................................................................ 28 3-Wire Read and Write Registers ................................................................................................................................................... 29 EMBEDDED REGISTERS.................................................................................................................................................................... 30 N ot R ACCELEROMETER OUTPUTS........................................................................................................................................................................ 31 XHP_L .................................................................................................................................................................................................. 32 XHP_H ................................................................................................................................................................................................. 32 YHP_L .................................................................................................................................................................................................. 32 YHP_H ................................................................................................................................................................................................. 32 ZHP_L .................................................................................................................................................................................................. 33 ZHP_H ................................................................................................................................................................................................. 33 XOUT_L ............................................................................................................................................................................................... 33 XOUT_H............................................................................................................................................................................................... 33 YOUT_L ............................................................................................................................................................................................... 34 YOUT_H ............................................................................................................................................................................................... 34 ZOUT_L................................................................................................................................................................................................ 34 ZOUT_H ............................................................................................................................................................................................... 34 COTR ................................................................................................................................................................................................... 35 WHO_AM_I ......................................................................................................................................................................................... 35 TSCP .................................................................................................................................................................................................... 36 TSPP .................................................................................................................................................................................................... 36 INS1 ..................................................................................................................................................................................................... 37 INS2 ..................................................................................................................................................................................................... 37 INS3 ..................................................................................................................................................................................................... 39 STATUS_REG ....................................................................................................................................................................................... 39 INT_REL ............................................................................................................................................................................................... 40 CNTL1 .................................................................................................................................................................................................. 40 CNTL2 .................................................................................................................................................................................................. 42 CNTL3 .................................................................................................................................................................................................. 43 ODCNTL ............................................................................................................................................................................................... 45 INC1 .................................................................................................................................................................................................... 47 INC2 .................................................................................................................................................................................................... 48 INC3 .................................................................................................................................................................................................... 48 INC4 .................................................................................................................................................................................................... 49 INC5 .................................................................................................................................................................................................... 49 INC6 .................................................................................................................................................................................................... 50 TILT_TIMER ......................................................................................................................................................................................... 51 WUFC .................................................................................................................................................................................................. 51 TDTRC.................................................................................................................................................................................................. 52 TDTC .................................................................................................................................................................................................... 52 TTH ...................................................................................................................................................................................................... 53 TTL ....................................................................................................................................................................................................... 53 FTD ...................................................................................................................................................................................................... 54 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 3 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications STD ...................................................................................................................................................................................................... 54 TLT ....................................................................................................................................................................................................... 55 TWS ..................................................................................................................................................................................................... 55 FFTH .................................................................................................................................................................................................... 56 FFC ...................................................................................................................................................................................................... 56 FFCNTL ................................................................................................................................................................................................ 56 ATH ..................................................................................................................................................................................................... 57 TILT_ANGLE_LL ................................................................................................................................................................................... 58 TILT_ANGLE_HL................................................................................................................................................................................... 58 HYST_SET ............................................................................................................................................................................................ 59 LP_CNTL .............................................................................................................................................................................................. 59 BUF_CNTL1 ......................................................................................................................................................................................... 60 BUF_CNTL2 ......................................................................................................................................................................................... 61 BUF_STATUS_1 ................................................................................................................................................................................... 62 BUF_STATUS_2 ................................................................................................................................................................................... 62 BUF_CLEAR ......................................................................................................................................................................................... 63 BUF_READ ........................................................................................................................................................................................... 63 SELF_TEST ........................................................................................................................................................................................... 63 EMBEDDED APPLICATIONS ............................................................................................................................................................. 64 N ot R ORIENTATION DETECTION FEATURE ............................................................................................................................................................. 64 Hysteresis........................................................................................................................................................................................ 64 Device Orientation Angle (aka Tilt Angle)....................................................................................................................................... 65 Tilt Timer......................................................................................................................................................................................... 66 MOTION INTERRUPT FEATURE DESCRIPTION ................................................................................................................................................. 67 DIRECTIONAL-TAP DETECTION FEATURE DESCRIPTION .................................................................................................................................... 69 Performance Index.......................................................................................................................................................................... 69 Single Tap Detection ....................................................................................................................................................................... 70 Double-Tap Detection ..................................................................................................................................................................... 71 FREE FALL DETECT .................................................................................................................................................................................... 72 SAMPLE BUFFER FEATURE DESCRIPTION ....................................................................................................................................................... 74 FIFO Mode ...................................................................................................................................................................................... 74 Stream Mode .................................................................................................................................................................................. 74 Trigger Mode .................................................................................................................................................................................. 75 FILO Mode ...................................................................................................................................................................................... 75 Buffer Operation ............................................................................................................................................................................. 75 REVISION HISTORY .......................................................................................................................................................................... 81 APPENDIX ....................................................................................................................................................................................... 82 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 4 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Functional Diagram X Accel Y Accel Z Accel Amplifier ADC Digital R Power nCS SDO/ADDR SDI/SDA SCLK/SCL TRIG INT1 INT2 N ot VDD GND IO_VDD 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 5 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Product Specifications Mechanical (specifications are for operation at 2.5V and T = 25C unless stated otherwise) Parameters Units Min Operating Temperature Range °C -40 Zero-g Offset mg Zero-g Offset Variation from RT over Temp. mg/°C GSEL1=0, GSEL0=0 (±8g) Sensitivity1 Sensitivity (Buffer 8-bit mode)1,2 GSEL1=0, GSEL0=1 (±16g) Max - +85 ±75 0.5 4096 counts/g 2048 GSEL1=1, GSEL0=0 (±32g) 1024 GSEL1=0, GSEL0=0 (±8g) 16 GSEL1=0, GSEL0=1 (±16g) counts/g GSEL1=1, GSEL0=0 (±32g) Sensitivity Variation from RT over Temp. Positive Self Test Output change on Activation4 Signal Bandwidth (-3dB) Non-Linearity Cross Axis Sensitivity Noise3,5 Typical RMS Density 8 4 %/°C 0.01 g 0.5 Hz 8000 (xy) 5100 (z) % of FS 0.6 % 2 mg 3.3 µg/√Hz 630 Table 1: Mechanical Specifications Notes: N ot R 1. Resolution and acceleration ranges are user selectable via I2C or SPI 2. Sensitivity is proportional to BRES in BUF_CNTL2 3. Noise varies with Output Data Rate (ODR), and the Average Filter Control settings and can be tested using Kionix FlexSetTM Performance Optimization Tool found at http://www.kionix.com/flexset 4. Requires changing of STPOL bit in INC1 register to 1 prior to performing self-test 5. Measured with ODR=50Hz, IIR_BYPASS=0, LPRO=1 (filter corner frequency set to ODR/2) 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 6 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r Electrical KX222-1054 Rev. 2.0 22-Dec-2017 (specifications are for operation at 2.5V and T = 25C unless stated otherwise) Units Min Typical Max Supply Voltage (VDD) Operating Parameters V 1.71 2.5 3.6 I/O Pads Supply Voltage (IO_VDD) V 1.7 High Resolution Mode (RES = 1) Current Consumption Low Power Mode1 (RES = 0) 3.6 145 A 10 Standby 0.9 Output Low Voltage (IO_VDD < 2V)2 V - - 0.2 * IO_VDD Output Low Voltage (IO_VDD ≥ 2V)2 V - - 0.4 Output High Voltage V 0.8 * IO_VDD - - Input Low Voltage V - - 0.2 * IO_VDD V 0.8 * IO_VDD - ms 2 Input High Voltage Start Up Time3 Power Up Time4 I2C Communication Rate ms - 1300 20 MHz 50 3.4 I2C Slave Address (7-bit) 0x1E / 0x1F SPI Communication Rate MHz Output Data Rate (ODR)5 Hz Bandwidth (-3dB)6 Hz 10 0.781 50 25600 ODR/9 or ODR/2 Table 2: Electrical Specifications N ot R Notes: 1. Current varies with Output Data Rate (ODR) as shown in Figure 2, types and number of enabled digital engines, and the Average Filter Control settings that can be tested using Kionix FlexSetTM Performance Optimization Tool found at http://www.kionix.com/flexset. 2. For I2C communication, this assumes a minimum 1.5kΩ pull-up resistor on SCL and SDA pins. 3. Start up time is from PC1 set to valid outputs. Time varies with Output Data Rate (ODR) and power mode setting. See Figure 1 for details. 4. Power up time is from VDD valid to device boot completion. 5. User selectable through I2C or SPI. 6. User selectable and dependent on ODR. See ODCNTL register description for details. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 7 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Start Up Time Profile Figure 1: Start up Time as a function of the Output Data Rate (ODR) and Power Mode Settings Current Profile Representative Current (µA) 16x Averaging Filter (default) 1000.0 145 145 145 145 145 145 145 145 145 145 145 145 145 145 145 145 100.0 145 145 145 145 145 145 145 Current (µA) 43 21 10.0 13 5 7 RES = 0 (Low Power Mode) RES = 1 when ODR ≥ 400Hz 3.0 100000 Accelerometer ODR (Hz) 10000 1000 100 RES = 1 (High Resolution Mode) 10 1 2.2 1.8 2.0 1.0 0.1 N ot R Representative Current Profile (µA) ODR (Hz) High Res Low Power Standby 0.9 0.9 0.781 145 1.8 1.563 145 2.0 3.125 145 2.2 6.25 145 3.0 12.5 145 5 25 145 7 50 145 13 100 145 21 200 145 43 400 145 145 800 145 145 1600 145 145 3200 145 145 6400 145 145 12800 145 145 25600 145 145 Figure 2: Current as a function of the Output Data Rate (ODR) and Power Mode Settings 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 8 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Power-On Procedure Proper functioning of power-on reset (POR) is dependent on the specific VDD, VDDLOW, TVDD (rise time), and TVDD_OFF profile of individual applications. It is recommended to minimize VDDLOW, and TVDD, and maximize TVDD_OFF. It is also advised that the VDD ramp up time TVDD be monotonic. Note that the outputs will not be stable until VDD has reached its final value. To assure proper POR, the application should be evaluated over the customer specified range of VDD, VDDLOW, TVDD, TVDD_OFF and temperature as POR performance can vary depending on these parameters. N ot R Please refer to Technical Note TN004 Power-On Procedure for more information. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 9 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Environmental Units Min Typical Max Supply Voltage (VDD) Absolute Limits Parameters V -0.5 - 3.60 Operating Temperature Range °C -40 - 85 Storage Temperature Range °C -55 - 150 Mech. Shock (powered and unpowered) g - - 5000 for 0.5ms 10000 for 0.2ms ESD V - - 2000 HBM Table 3: Environmental Specifications Caution: ESD Sensitive and Mechanical Shock Sensitive Component, improper handling can cause permanent damage to the device. These products conform to RoHS Directive 2011/65/EU of the European Parliament and of the Council of the European Union that was issued June 8, 2011. Specifically, these products do not contain any non-exempted amounts of lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE) above the maximum concentration values (MCV) by weight in any of its homogenous materials. Homogenous materials are “of uniform composition throughout”. The MCV for lead, mercury, hexavalent chromium, PBB, and PBDE is 0.10%. The MCV for cadmium is 0.010%. N ot R Applicable Exemption: 7C-I - Electrical and electronic components containing lead in a glass or ceramic other than dielectric ceramic in capacitors (piezoelectronic devices) or in a glass or ceramic matrix compound. HF These products are also in conformance with REACH Regulation No 1907/2006 of the European Parliament and of the Council that was issued Dec. 30, 2011. They do not contain any Substances of Very High Concern (SVHC-174) as identified by the European Chemicals Agency as of 12 July 2017. This product is halogen-free per IEC 61249-2-21. Specifically, the materials used in this product contain a maximum total halogen content of 1500 ppm with less than 900-ppm bromine and less than 900-ppm chlorine. Soldering Soldering recommendations are available upon request or from www.kionix.com. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 10 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Terminology g A unit of acceleration equal to the acceleration of gravity at the earth's surface. One thousandth of a g (0.0098 m/s2) is referred to as 1 milli-g (1 mg). m 1g  9.8 2 s Sensitivity The sensitivity of an accelerometer is the change in output per unit of input acceleration at nominal VDD and temperature. The term is essentially the gain of the sensor expressed in counts per g (counts/g) or LSB’s per g (LSB/g). Occasionally, sensitivity is expressed as a resolution, i.e. milli-g per LSB (mg/LSB) or milli-g per count (mg/count). Sensitivity for a given axis is determined by measurements of the formula: Sensitivit y  Output @ 1g  Output @ 1g  2g The sensitivity tolerance describes the range of sensitivities that can be expected from a large population of sensors at room temperature and over life. When the temperature deviates from room temperature (25°C), the sensitivity will vary by the amount shown in Table 1. R Zero-g offset N ot Zero-g offset or 0-g offset describes the actual output of the accelerometer when no acceleration is applied. Ideally, the output would always be in the middle of the dynamic range of the sensor (content of the XOUT, YOUT, ZOUT registers = 0x00, expressed as a 2’s complement number). However, because of mismatches in the sensor, calibration errors, and mechanical stress, the output can deviate from 0x00. This deviation from the ideal value is called 0-g offset. The zero-g offset tolerance describes the range of 0-g offsets of a population of sensors over the operating temperature range. Self-test Self-test allows a functional test of the sensor without applying a physical acceleration to it. When activated, an electrostatic force is applied to the sensor, simulating an input acceleration. The sensor outputs respond accordingly. If the output signals change within the amplitude specified in Table 1 then the sensor is working properly and the parameters of the interface chip are within the defined specifications. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 11 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Functionality Sense element The sense element is fabricated using Kionix’s proprietary plasma micromachining process technology. This process technology allows Kionix to create mechanical silicon structures which are essentially massspring systems that move in the direction of the applied acceleration. Acceleration sensing is based on the principle of a differential capacitance arising from the acceleration-induced motion. Capacitive plates on the moving mass move relative to fixed capacitive plates anchored to the substrate. The sense element is hermetically sealed at the wafer level by bonding a second silicon lid wafer to the device using a glass frit. ASIC interface A separate ASIC device packaged with the sense element provides all the signal conditioning and communication with the sensor. The complete measurement chain is composed by a low-noise capacitance to voltage amplifier which converts the differential capacitance of the MEMS sensor into an analog voltage that is sent through an analog-to-digital converter. The acceleration data may be accessed through the I2C digital communications provided by the ASIC. In addition, the ASIC contains all the logic to allow the user to choose data rates, g-ranges, filter settings, and interrupt logic. Plus, there are two programmable state machines which allow the user to create unique embedded functions based on changes in acceleration. Factory calibration N ot R Kionix trims the offset and sensitivity of each accelerometer by adjusting gain (sensitivity) and 0-g offset trim codes stored in non-volatile memory (OTP). Additionally, all functional register default values are also programmed into the nonvolatile memory. Every time the device is turned on or a software reset command is issued, the trimming parameters and default register values are downloaded into the volatile registers to be used during active operation. This allows the device to function without further calibration. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 12 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Application Schematic and Pin Description Application Schematic Pin Description Name 1 SDO/ADDR 2 SDI/SDA 3 IO_VDD 4 TRIG Serial Data Out pin during 4 wire SPI communication and part of the device address during I2C communication. Do not leave floating. SPI Data input / I2C Serial Data The power supply input for the digital communication bus. Optionally decouple this pin to ground with a 0.1uF ceramic capacitor. Trigger pin for FIFO buffer control - Connect to GND when not using external trigger option Physical Interrupt 1 (Push-Pull). The pin is in High-Z state during POR and driven LOW following POR. Leave floating if not used. Physical Interrupt 2 (Push-Pull). The pin is in High-Z state during POR and driven LOW following POR. Leave floating if not used. The power supply input. Decouple this pin to ground with a 0.1uF ceramic capacitor. INT1 ot 5 Description R Pin 6 INT2 VDD 8 GND Ground 9 GND Ground 10 nCS Chip Select (active LOW) for SPI communication. Connect to IO_VDD for I2C communication. Do not leave floating. 11 NC Not Internally Connected - Can be connected to VDD, IO_VDD, GND or leave floating. 12 SCLK/SCL N 7 SPI and I2C Serial Clock Table 4: Pin Description 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 13 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Package Dimensions and Orientation Dimensions N ot R 2 x 2 x 0.9 mm LGA All dimensions and tolerances conform to ASME Y14.5M-1994 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 14 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r Orientation KX222-1054 Rev. 2.0 22-Dec-2017 When device is accelerated in +X, +Y or +Z direction, the corresponding output will increase. Static X/Y/Z Output Response versus Orientation to Earth’s surface (1g): GSEL1=0, GSEL0=0 (±8g) Position 1 Diagram Resolution (bits) X (counts) +4096 Y (counts) Z (counts) 0 0 3 4 5 Top 6 Bottom Bottom Top 16 8 16 8 16 8 16 8 16 8 +16 0 0 0 -4096 0 0 -16 0 -4096 0 0 -16 0 0 0 +4096 0 0 +16 0 0 0 +4096 0 0 +16 0 0 -4096 0 0 -16 R 8 + 0 0 N ot X-Polarity Y-Polarity Z-Polarity 16 2 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com 0 0 0 0 0 + 0 0 0 + 0 0 - (1g) Earth’s Surface © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 15 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Static X/Y/Z Output Response versus Orientation to Earth’s surface (1g): GSEL1=0, GSEL0=1 (±16g) Position 1 Diagram Resolution (bits) X (counts) +2048 Y (counts) Z (counts) 0 0 16 2 4 5 Top 6 Bottom Bottom Top 8 16 8 16 8 16 8 16 8 16 8 +8 0 0 0 -2048 0 0 -8 0 -2048 0 0 -8 0 0 0 +2048 0 0 +8 0 0 0 +2048 0 0 +8 0 0 -2048 0 0 -8 + 0 0 X-Polarity Y-Polarity Z-Polarity 3 0 0 0 0 0 + 0 0 0 + 0 0 - (1g) Earth’s Surface Static X/Y/Z Output Response versus Orientation to Earth’s surface (1g): GSEL1=1, GSEL0=0 (±32g) Diagram 1 +1024 Y (counts) Z (counts) 0 0 N ot Resolution (bits) X (counts) X-Polarity Y-Polarity Z-Polarity 2 R Position 16 3 4 5 Top 6 Bottom Bottom Top 8 16 8 16 8 16 8 16 8 16 8 +4 0 0 0 -1024 0 0 -4 0 -1024 0 0 -4 0 0 0 +1024 0 0 +4 0 0 0 +1024 0 0 +4 0 0 -1024 0 0 -4 + 0 0 0 0 0 0 0 + 0 0 0 + 0 0 - (1g) Earth’s Surface 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 16 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Digital Interface The Kionix KX222 digital accelerometer can communicate via the I2C and SPI digital serial interface protocols. This allows for easy system integration by eliminating analog-to-digital converter requirements and by providing direct communication with system micro-controllers. The serial interface terms and descriptions as indicated in Table 5 below will be observed throughout this document. Term Transmitter Receiver Master Slave Description The device that transmits data to the bus. The device that receives data from the bus. The device that initiates a transfer, generates clock signals, and terminates a transfer. The device addressed by the Master. Table 5: Serial Interface Terminologies I2C Serial Interface As previously mentioned, the KX222 accelerometer can communicate on an I2C bus. I2C is primarily used for synchronous serial communication between a Master device and one or more Slave devices. The Master, typically a micro controller, provides the serial clock signal and addresses Slave devices on the bus. The KX222 always operates as a Slave device during standard Master-Slave I2C operation. ot R I2C is a two-wire serial interface that contains a Serial Clock (SCL) line and a Serial Data (SDA) line. SCL is a serial clock that is provided by the Master, but can be held LOW by any Slave device, putting the Master into a wait condition. SDA is a bi-directional line used to transmit and receive data to and from the interface. Data is transmitted MSB (Most Significant Bit) first in 8-bit per byte format, and the number of bytes transmitted per transfer is unlimited. The I2C bus is considered free when both lines are HIGH. N The I2C interface is compliant with high-speed mode, fast mode, and standard mode I2C protocols. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 17 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 I2C Operation Transactions on the I2C bus begin after the Master transmits a start condition (S), which is defined as a HIGHto-LOW transition on the data line while the SCL line is held HIGH. The bus is considered busy after this condition. The next byte of data transmitted after the start condition contains the Slave Address (SAD) in the seven MSBs (Most Significant Bits), and the LSB (Least Significant Bit) tells whether the Master will be receiving data ‘1’ from the Slave or transmitting data ‘0’ to the Slave. When a Slave Address is sent, each device on the bus compares the seven MSBs with its internally stored address. If they match, the device considers itself addressed by the Master. The KX222 Slave Address is comprised of a user programmable part, a factory programmable part, and a fixed part, which allows for connection of multiple accelerometers to the same I 2C bus. The Slave Address associated with the KX222 is 00111YX, where the user programmable bit X, is determined by the assignment of ADDR pin to GND or IO_VDD. Also, the factory programmable bit Y is set at the factory. For KX222-1054, the factory programmable bit Y is fixed to 1 (contact your Kionix sales representative for list of available devices). Table 6 lists possible I2C addresses for KX222-1054. It is possible to have up to four accelerometers on a shared I2C bus as shown in Figure 3 (i.e. two KX222-1054 accelerometers and two additional accelerometers with the factory programmable bit Y set to 0). Description Address Pad 7-bit Address Address I2C Wr I2C Rd I2C Wr I2C Rd GND GND IO_VDD IO_VDD 0x1E 0x1E 0x1F 0x1F 0x3C 0x3D 0x3E 0x3F 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 Y X 1 1 1 1 1 1 1 1 0 0 1 1 0 1 0 1 Table 6: I2C Slave Addresses for KX222-1054 N ot R It is mandatory that receiving devices acknowledge (ACK) each transaction. Therefore, the transmitter must release the SDA line during this ACK pulse. The receiver then pulls the data line LOW so that it remains stable LOW during the HIGH period of the ACK clock pulse. A receiver that has been addressed, whether it is Master or Slave, is obliged to generate an ACK after each byte of data has been received. To conclude a transaction, the Master must transmit a stop condition (P) by transitioning the SDA line from LOW to HIGH while SCL is HIGH. The I2C bus is now free. Note that if the accelerometer is accessed through I2C protocol before the startup is finished a NACK signal is sent. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 18 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 I2C Device Part Number 1 2 3 4 ADDR Pin Slave Address Bit Y (Bit 1 in 7-bit address) KX222-1054 GND 0x1E Factory Set to 1 KX222-1054 IO_VDD 0x1F Factory Set to 1 *KXMMM GND 0x1C Factory Set to 0 *KXMMM IO_VDD 0x1D Factory Set to 0 * KXMMM – contact Kionix sales representative for list of compatible devices Figure 3: Multiple KX222 Accelerometers on a Shared I2C Bus R Writing to an 8-bit Register N ot Upon power up, the Master must write to the KX222’s control registers to set its operational mode. Therefore, when writing to a control register on the I2C bus, as shown Sequence 1, the following protocol must be observed: After a start condition, SAD+W transmission, and the KX222 ACK has been returned, an 8-bit Register Address (RA) command is transmitted by the Master. This command is telling the KX222 to which 8-bit register the Master will be writing the data. Since this is I2C mode, the MSB of the RA command should always be zero (0). The KX222 acknowledges the RA and the Master transmits the data to be stored in the 8-bit register. The KX222 acknowledges that it has received the data and the Master transmits a stop condition (P) to end the data transfer. The data sent to the KX222 is now stored in the appropriate register. The KX222 automatically increments the received RA commands and, therefore, multiple bytes of data can be written to sequential registers after each Slave ACK as shown in Sequence 2. **Note** If a STOP condition is sent on the least significant bit of write data or the following master acknowledge cycle, the last write operation is not guaranteed and it may alter the content of the affected registers. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 19 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Reading from an 8-bit Register When reading data from a KX222 8-bit register on the I2C bus, as shown in Sequence 3, the following protocol must be observed: The Master first transmits a start condition (S) and the appropriate Slave Address (SAD) with the LSB set at ‘0’ to write. The KX222 acknowledges and the Master transmits the 8-bit RA of the register it wants to read. The KX222 again acknowledges, and the Master transmits a repeated start condition (Sr). After the repeated start condition, the Master addresses the KX222 with a ‘1’ in the LSB (SAD+R) to read from the previously selected register. The Slave then acknowledges and transmits the data from the requested register. The Master does not acknowledge (NACK) it received the transmitted data, but transmits a stop condition to end the data transfer. Note that the KX222 automatically increments through its sequential registers, allowing data to be read from multiple registers following a single SAD+R command as shown below in Sequence 4. Reading data from a buffer read register is a special case because if register address (RA) is set to buffer read register (BUF_READ) in Sequence 4, the register auto-increment feature is automatically disabled. Instead, the Read Pointer will increment to the next data in the buffer, thus allowing reading multiple bytes of data from the buffer using a single SAD+R command. N ot R **Note** Accelerometer’s output data should be read in a single transaction using the auto-increment feature to prevent output data from being updated prior to intended completion of the read transaction. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 20 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Data Transfer Sequences The following information illustrates the variety of data transfers that can occur on the I 2C bus and how the Master and Slave interact during these transfers. Table 7 defines the I2C terms used during the data transfers. Term S Sr SAD W R ACK NACK RA Data P Definition Start Condition Repeated Start Condition Slave Address Write Bit Read Bit Acknowledge Not Acknowledge Register Address Transmitted/Received Data Stop Condition Table 7: I2C Terms Sequence 1: The Master is writing one byte to the Slave Master Slave S SAD + W RA ACK DATA ACK P ACK R Sequence 2: The Master is writing multiple bytes to the Slave Master Slave S SAD + W RA ACK DATA ACK DATA ACK P ACK ot Sequence 3: The Master is receiving one byte of data from the Slave S SAD + W N Master Slave RA ACK Sr SAD + R ACK NACK ACK P DATA Sequence 4: The Master is receiving multiple bytes of data from the Slave Master Slave S SAD + W 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com RA ACK Sr ACK SAD + R ACK ACK DATA NACK DATA © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 21 of 82 P PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 HS-mode To enter the 3.4MHz high speed mode of communication, the device must receive the following sequence of conditions from the master: a Start condition followed by a Master code (00001XXX) and a Master Nonacknowledge. Once recognized, the device switches to HS-mode communication. Read/write data transfers then proceed as described in the sequences above. Devices return to the FS-mode after a STOP occurrence on the bus. Sequence 5: HS-mode data transfer of the Master writing multiple bytes to the Slave Speed Master Slave S FS-mode M-code NACK Sr SAD + W ACK HS-mode RA ACK FS-mode DATA P ACK n bytes + ack. Sequence 6: HS-mode data transfer of the Master receiving multiple bytes of data from the Slave Speed Master Slave Sr HS-mode SAD + W RA ACK ACK FS-mode HS-mode Sr SAD + R NACK ACK DATA ACK P DATA (n-1) bytes + ack. N ot R Speed Master Slave S FS-mode M-code NACK 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 22 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 I2C Timing Diagram Number Description SDA LOW to SCL LOW transition (Start event) SDA LOW to first SCL rising edge SCL pulse width: HIGH SCL pulse width: LOW SCL HIGH before SDA falling edge (Start Repeated) SCL pulse width: HIGH during a S/Sr/P event SCL HIGH before SDA rising edge (Stop) SDA pulse width: HIGH SDA valid to SCL rising edge SCL rising edge to SDA invalid SCL falling edge to SDA valid (when slave is transmitting) SCL falling edge to SDA invalid (when slave is transmitting) Recommended I2C CLK Table 8: I2C Timing (Fast Mode) MIN MAX Units 50 100 100 100 50 100 50 25 50 50 100 ns ns ns ns ns ns ns ns ns ns ns ns 0 2.5 - µs N ot R t0 t1 t2 t3 t4 t5 t6 t7 t8 t9 t10 t11 Note 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 23 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications SPI Communications 4-Wire SPI Interface The KX222 also utilizes an integrated 4-Wire Serial Peripheral Interface (SPI) for digital communication. The SPI interface is primarily used for synchronous serial communication between one Master device and one or more Slave devices. The Master, typically a micro controller, provides the SPI clock signal (SCLK) and determines the state of Chip Select (nCS). The KX222 always operates as a Slave device during standard Master-Slave SPI operation. N ot R 4-wire SPI is a synchronous serial interface that uses two control and two data lines. With respect to the Master, the Serial Clock output (SCLK), the Data Output (SDI or MOSI) and the Data Input (SDO or MISO) are shared among the Slave devices. The Master generates an independent Chip Select (nCS) for each Slave device that goes LOW at the start of transmission and goes back HIGH at the end. The Slave Data Output (SDO) line, remains in a high-impedance (hi-z) state when the device is not selected, so it does not interfere with any active devices. This allows multiple Slave devices to share a master SPI port as shown in Figure 4 below. Figure 4: 4-wire SPI Connections 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 24 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 4-Wire SPI Timing Diagram t3 t nCS CLK SDI SDO t1 bit 7 bit 6 bit 1 5 bit 0 t4 bit 7 5 bit 7 5 t5 t6 Number t1 t2 t3 t4 t5 t6 t7 t2 bit 6 bit 1 5 bit 6 bit 1 5 bit 0 bit 0 t7 Description CLK pulse width: HIGH CLK pulse width: LOW nCS LOW to first CLK rising edge nCS LOW after the final CLK rising edge SDI valid to CLK rising edge CLK rising edge to SDI invalid CLK falling edge to SDO valid MIN MAX Units 35 ns ns ns ns ns ns ns 40 40 20 30 10 10 Table 9: 4-Wire SPI Timing N ot R Notes 1. t7 is only present during reads. 2. Timings are for VDD of 1.8V to 3.6V with 1k pull-up resistor and maximum 20pF load capacitor on SDO. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 25 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 4-Wire Read and Write Registers The registers embedded in the KX222 accelerometer have 8-bit addresses. Upon power up, the Master must write to the accelerometer’s control registers to set its operational mode. On the falling edge of nCS, a 2-byte command is written to the appropriate control register. The first byte initiates the write to the appropriate register, and is followed by the user-defined, data byte. The MSB (Most Significant Bit) of the register address byte will indicate “0” when writing to the register and “1” when reading from the register. This operation occurs over 16 clock cycles. All commands are sent MSB first. The host must return nCS HIGH for at least one clock cycle before the next data request. However, when data is being read from a buffer read register (BUF_READ), the nCS signal can remain LOW until the buffer is read. Figure 5 below shows the timing diagram for carrying out an 8-bit register write operation. Write Address First 8 bits Second 8 bits Last 8 bits CLK SDI SDO A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 D7 D6 D5 D2 D1 D0 HI-Z HI-Z CS Figure 5: Timing Diagram for 8-Bit Register Write Operation N ot R In order to read an 8-bit register, an 8-bit register address must be written to the accelerometer to initiate the read. The MSB of this register address byte will indicate “0” when writing to the register and “1” when reading from the register. Upon receiving the address, the accelerometer returns the 8-bit data stored in the addressed register. This operation also occurs over 16 clock cycles. All returned data is sent MSB first, and the host must return nCS HIGH for at least one clock cycle before the next data request. Figure 6 shows the timing diagram for an 8-bit register read operation. Read Address First 8 bits Second 8 bits Last 8 bits CLK SDI SDO A7 A6 A5 A4 A3 A2 A1 A0 HI-Z D7 D6 D5 D4 D3 D2 D1 D0 D7 D6 D5 D3 D2 D1 D0 HI-Z CS Figure 6: Timing Diagram for 8-Bit Register Read Operation 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 26 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications 3-Wire SPI Interface Figure 7: 3-wire SPI Connections N ot R The KX222 also utilizes an integrated 3-Wire Serial Peripheral Interface (SPI) for digital communication. 3-wire SPI is a synchronous serial interface that uses two control lines and one data line. With respect to the Master, the Serial Clock output (SCLK), the Data Output/Input (SDI) are shared among the Slave devices. The Master generates an independent Chip Select (nCS) for each Slave device that goes LOW at the start of transmission and goes back HIGH at the end. This allows multiple Slave devices to share a master SPI port as shown in Figure 7 below. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 27 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications 3-Wire SPI Timing Diagram t3 nCS CLK SDI t1 bit 7 t5 bit 6 bit 1 5 t2 t4 bit 0 bit 7 t7 t6 bit 1 5 bit 0 t8 Number Description MIN MAX Units t1 t2 t3 t4 t5 t6 t7 t8 CLK pulse width: HIGH CLK pulse width: LOW nCS LOW to first CLK rising edge nCS LOW after the final CLK falling edge SDI valid to CLK rising edge CLK rising edge to SDI input invalid CLK extra clock cycle rising edge to SDI output becomes valid CLK falling edge to SDI output becomes valid 40 40 20 20 10 10 - 35 ns ns ns ns ns ns ns ns - Table 10: 3-Wire SPI Timing N ot R Notes 1. t7 and t8 are only present during reads. 2. Timings are for VDD of 1.8V to 3.6V with 1k pull-up resistor and maximum 20pF load capacitor on SDI. 3. The SDO/ADDR pin is configured in a high-impedance input-state, and must be externally tied to GND or IO_VDD 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 28 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 3-Wire Read and Write Registers The registers embedded in the KX222 accelerometer have 8-bit addresses. Upon power up, the Master must write to the accelerometer’s control registers to set its operational mode. On the falling edge of nCS, a 2-byte command is written to the appropriate control register. The first byte initiates the write to the appropriate register, and is followed by the user-defined, data byte. The MSB (Most Significant Bit) of the register address byte will indicate “0” when writing to the register and “1” when reading from the register. A read operation occurs over 17 clock cycles and a write operation occurs over 16 clock cycles. All commands are sent MSB first. The host must return nCS HIGH for at least one clock cycle before the next data request. However, when data is being read from a buffer read register (BUF_READ), the nCS signal can remain LOW until the buffer is read. Figure 8 below shows the timing diagram for carrying out an 8-bit register write operation. SCLK SDI A7 A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 (MSB) (MSB) CS Figure 8: Timing Diagram for 8-Bit Register Write Operation SCLK N ot R In order to read an 8-bit register, an 8-bit register address must be written to the accelerometer to initiate the read. The MSB of this register address byte will indicate “0” when writing to the register and “1” when reading from the register. Upon receiving the address, the accelerometer returns the 8-bit data stored in the addressed register. For 3-wire read operations, one extra clock cycle between the address byte and the data output byte is required. Therefore, this operation occurs over 17 clock cycles. All returned data is sent MSB first, and the host must return nCS HIGH for at least one clock cycle before the next data request. Figure 9 shows the timing diagram for an 8-bit register read operation. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com SDI D7 D6 D5 D4 D3 D2 D1 D0 HI-Z A7 A6 A5 A4 A3 A2 A1 A0 (MSB) (MSB) CS Figure 9: Timing Diagram for 8-Bit Register Read Operation © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 29 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Embedded Registers The KX222 has 57 embedded 8-bit registers that are accessible by the user. This section contains the addresses for all embedded registers and describes bit functions of each register. Table 11 below provides a listing of the accessible 8-bit registers and their addresses. Register Name R/W Address Register Name R/W 0x00 0x01 0x02 0x03 0x04 0x05 0x06 0x07 0x08 0x09 0x0A 0x0B 0x0C 0x0D 0x0E 0x0F 0x10 0x11 0x12 0x13 0x14 0x15 0x16 0x17 0x18 0x19 0x1A 0x1B 0x1C 0x1D 0x1E 0x1F 0x20 XHPL XHPH YHPL YHPH ZHPL ZHPH XOUTL XOUTH YOUTL YOUTH ZOUTL ZOUTH COTR Kionix Reserved Kionix Reserved WHO_AM_I TSCP TSPP INS1 INS2 INS3 STAT Kionix Reserved INT_REL CNTL1* CNTL2* CNTL3* ODCNTL* INC1* INC2* INC3* INC4* INC5* R R R R R R R R R R R R R 0x21 0x22 0x23 0x24 0x25 0x26 0x27 0x28 0x29 0x2A 0x2B 0x2C 0x2D 0x2E 0x2F 0x30 0x31 0x32 0x33 0x34 0x35 0x36 0x37 0x38 0x39 0x3A 0x3B 0x3C 0x3D 0x3E 0x3F 0x60 INC6* TILT_TIMER* WUFC* TDTRC* TDTC* TTH* TTL* FTD* STD* TLT* TWS* FFTH* FFC* FFCNTL* Kionix Reserved ATH* Kionix Reserved TILT_ANGLE_LL* TILT_ANGLE_HL* HYST_SET* LP_CNTL* Kionix Reserved Kionix Reserved Kionix Reserved Kionix Reserved BUF_CNTL1* BUF_CNTL2* BUF_STATUS_1 BUF_STATUS_2 BUF_CLEAR BUF_READ SELF_TEST R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W N ot R Address R R R R R R R R R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R/W R R W R W * Note: ▪ When changing the contents of these registers, the PC1 bit in CNTL1 register must first be set to “0”. ▪ Reserved registers should not be written. Table 11: Register Map 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 30 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Register Descriptions Accelerometer Outputs These registers contain up to 16-bits of valid acceleration data for each axis. However, the user may choose to read only the 8 MSB thus reading an effective 8-bit resolution. When BRES = 0 in BUF_CNTL2 register, the 8 MSB is the only data recorded in the buffer. The data is updated every user-defined ODR period, is protected from overwrite during each read, and can be converted from digital counts to acceleration (g) per Table 12 below. The register acceleration output binary data is represented in 2’s complement format. For example, if N = 16 bits, then the Counts range is from -32768 to 32767, and if N = 8 bits, then the Counts range is from -128 to 127. Equivalent Counts in decimal Range = ±8g Range = ±16g Range = ±32g 0111 1111 1111 1111 32767 +7.99976g +15.99951g +31.99902g 0111 1111 1111 1110 32766 +7.99951g +15.99902g +31.99805g … … … … … 0000 0000 0000 0001 1 +0.00024g +0.00049g +0.00098g 0000 0000 0000 0000 0 0.00000g 0.00000g 0.00000g 1111 1111 1111 1111 -1 -0.00024g -0.00049g -0.00098g … … … … … 1000 0000 0000 0001 -32767 -7.99976g -15.99951g -31.99902g 1000 0000 0000 0000 -32768 -8.00000g -16.00000g -32.00000g 8-bit Register Data (2’s complement) Equivalent Counts in decimal Range = ±8g Range = ±16g Range = ±32g 0111 1111 127 +7.93750g +15.87500g +31.75000g 0111 1110 126 +7.87500g +15.75000g +31.50000g … … … … … 0000 0001 1 +0.06250g +0.12500g +0.25000g 0000 0000 0 0.0000g 0.0000g 0.0000g 1111 1111 -1 -0.06250g -0.12500g -0.25000g … … … … … 1000 0001 -127 -7.93750g -15.87500g -31.75000g 1000 0000 -128 -8.00000g -16.00000g -32.00000g N ot R 16-bit Register Data (2’s complement) Table 12: Acceleration (g) Calculation 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 31 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications XHP_L X-axis high-pass filter accelerometer output least significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3 register. Data is only available when wake-up engine is enabled (WUFE = 1 in CNTL1 register) R XHPD7 Bit7 R XHPD6 Bit6 R XHPD5 Bit5 R XHPD4 Bit4 R XHPD3 Bit3 R XHPD2 Bit2 R R XHPD1 XHPD0 Bit1 Bit0 Address: 0x00 XHP_H X-axis high-pass filter accelerometer output most significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3 register. Data is only available when wake-up engine is enabled (WUFE = 1 in CNTL1 register) R XHPD15 Bit7 R XHPD14 Bit6 R XHPD13 Bit5 R XHPD12 Bit4 R XHPD11 Bit3 R XHPD10 Bit2 R R XHPD9 XHPD8 Bit1 Bit0 Address: 0x01 YHP_L Y-axis high-pass filter accelerometer output least significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3 register. Data is only available when wake-up engine is enabled (WUFE = 1 in CNTL1 register) R YHPD6 Bit6 R YHPD5 Bit5 R YHPD4 Bit4 R YHPD3 Bit3 R YHPD2 Bit2 ot R R YHPD7 Bit7 R R YHPD1 YHPD0 Bit1 Bit0 Address: 0x02 N YHP_H Y-axis high-pass filter accelerometer output most significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3 register. Data is only available when wake-up engine is enabled (WUFE = 1 in CNTL1 register) R YHPD15 Bit7 R YHPD14 Bit6 R YHPD13 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com R YHPD12 Bit4 R YHPD11 Bit3 R YHPD10 Bit2 R R YHPD9 YHPD8 Bit1 Bit0 Address: 0x03 © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 32 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 ZHP_L Z-axis high-pass filter accelerometer output least significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3 register. Data is only available when wake-up engine is enabled (WUFE = 1 in CNTL1 register) R ZHPD7 Bit7 R ZHPD6 Bit6 R ZHPD5 Bit5 R ZHPD4 Bit4 R ZHPD3 Bit3 R ZHPD2 Bit2 R R ZHPD1 ZHPD0 Bit1 Bit0 Address: 0x04 ZHP_H Z-axis high-pass filter accelerometer output most significant byte. Data is updated at the ODR frequency determined by OWUF in CNTL3 register. Data is only available when wake-up engine is enabled (WUFE = 1 in CNTL1 register) R ZHPD15 Bit7 R ZHPD14 Bit6 R ZHPD13 Bit5 R ZHPD12 Bit4 R ZHPD11 Bit3 R ZHPD10 Bit2 R R ZHPD9 ZHPD8 Bit1 Bit0 Address: 0x05 XOUT_L X-axis accelerometer output least significant byte. Data is updated at the ODR frequency determined by OSA bits in ODCNTL register. R XOUTD6 Bit6 R XOUTD5 Bit5 R XOUTD4 Bit4 R XOUTD3 Bit3 R XOUTD2 Bit2 R R XOUTD1 XOUTD0 Bit1 Bit0 Address: 0x06 ot R R XOUTD7 Bit7 N XOUT_H X-axis accelerometer output most significant byte. Data is updated at the ODR frequency determined by OSA bits in ODCNTL register. R R R R R R R R XOUTD15 XOUTD14 XOUTD13 XOUTD12 XOUTD11 XOUTD10 XOUTD9 XOUTD8 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Address: 0x07 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 33 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications YOUT_L Y-axis accelerometer output least significant byte. Data is updated at the ODR frequency determined by OSA bits in ODCNTL register. R YOUTD7 Bit7 R YOUTD6 Bit6 R YOUTD5 Bit5 R YOUTD4 Bit4 R YOUTD3 Bit3 R YOUTD2 Bit2 R R YOUTD1 YOUTD0 Bit1 Bit0 Address: 0x08 YOUT_H Y-axis accelerometer output most significant byte. Data is updated at the ODR frequency determined by OSA bits in ODCNTL register. R R R R R R R R YOUTD15 YOUTD14 YOUTD13 YOUTD12 YOUTD11 YOUTD10 YOUTD9 YOUTD8 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Address: 0x09 ZOUT_L Z-axis accelerometer output least significant byte. Data is updated at the ODR frequency determined by OSA bits in ODCNTL register. R ZOUTD6 Bit6 R ZOUTD5 Bit5 R R ZOUTD7 Bit7 R ZOUTD4 Bit4 R ZOUTD3 Bit3 R ZOUTD2 Bit2 R R ZOUTD1 ZOUTD0 Bit1 Bit0 Address: 0x0A ot ZOUT_H Z-axis accelerometer output most significant byte. Data is updated at the ODR frequency determined by OSA bits in ODCNTL register. N R R R R R R R R ZOUTD15 ZOUTD14 ZOUTD13 ZOUTD12 ZOUTD11 ZOUTD10 ZOUTD9 ZOUTD8 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Address: 0x0B 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 34 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications COTR The Command Test Response (COTR) register is used to verify proper integrated circuit functionality. The value of this register will change from a default value of 0x55 to 0xAA when COTC bit in CNTL2 register is set. After reading 0xAA from this register, the byte value returns to the default value of 0x55 and COTC bit in CNTL2 register is cleared. R DCSTR7 Bit7 R DCSTR6 Bit6 R DCSTR5 Bit5 R DCSTR4 Bit4 R DCSTR3 Bit3 R DCSTR2 Bit2 R R DCSTR1 DCSTR0 Bit1 Bit0 Address: 0x0C Reset Value 01010101 WHO_AM_I This register is used for supplier recognition, as it is factory written to a known byte value. The default value is 0x2C. R WIA6 Bit6 R WIA5 Bit5 R WIA4 Bit4 R WIA3 Bit3 R WIA2 Bit2 R R WIA1 WIA0 Bit1 Bit0 Address: 0x0F Reset Value 00101100 N ot R R WIA7 Bit7 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 35 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Tilt Position Registers These two registers report previous and current position data that is updated at the user-defined ODR frequency OTP in CNTL3 register. Data protected during register read. Table 13 describes the reported position for each bit value. TSCP The Tilt Status Current Position (TSCP) register reports the current tilt position. R 0 Bit7 R 0 Bit6 R LE Bit5 R RI Bit4 R DO Bit3 R UP Bit2 R R FD FU Bit1 Bit0 Address: 0x10 Reset Value 00100000 TSPP The Tilt Status Previous Position (TSPP) register reports previous tilt position. R 0 Bit6 R LE Bit5 R RI Bit4 R DO Bit3 Bit LE RI DO UP FD FU R UP Bit2 R R FD FU Bit1 Bit0 Address: 0x11 Reset Value 00100000 Description Left State (X-) Right State (X+) Down State (Y-) Up State (Y+) Face-Down State (Z-) Face-Up State (Z+) Table 13: Tilt Position N ot R R 0 Bit7 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 36 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Interrupt Source Registers These three registers report interrupt state changes. This data is updated when a new interrupt event occurs and each application’s result is latched until the interrupt release register is read. INS1 The Interrupt Source 1 (INS1) register indicates the triggering axis when a Tap/Double-TapTM interrupt occurs. Data is updated at the ODR settings determined by OTDT bits in CNTL3 register. R 0 Bit7 R 0 Bit6 R TLE Bit5 R TRI Bit4 R TDO Bit3 Bit TLE TRI TDO TUP TFD TFU R TUP Bit2 R R TFD TFU Bit1 Bit0 Address: 0x12 Description X Negative (X-) Reported X Positive (X+) Reported Y Negative (Y-) Reported Y Positive (Y+) Reported Z Negative (Z-) Reported Z Positive (Z+) Reported INS2 R Table 14: Directional-TapTM Reporting The Interrupt Source 2 (INS2) register reports which function caused an interrupt. R BFI Bit6 N ot R FFS Bit7 R WMI Bit5 R DRDY Bit4 R TDTS1 Bit3 R TDTS0 Bit2 R R WUFS TPS Bit1 Bit0 Address: 0x13 FFS – Free fall. This bit is cleared when the interrupt latch release register (INT_REL) is read. FFS = 0 – No Free fall FFS = 1 – Free fall has activated the interrupt BFI – Buffer Full Interrupt. Automatically cleared when at least one sample is read from the buffer or following the write to BUF_CLEAR register. BFI = 0 – Buffer is not full BFI = 1 – Buffer is full 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 37 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications WMI – The Watermark Interrupt bit is set to 1 when FIFO has filled up to the value stored in the SMP_TH bits. This bit is automatically cleared when FIFO is read and the SMP_LEV returns to a value below the value stored in the SMP_TH bits, or following the write to BUF_CLEAR register. WMI = 0 – Buffer watermark has not been exceeded WMI = 1 – Buffer watermark has been exceeded DRDY – The Data Ready bit indicates that new acceleration data (0x06 to 0x0B) is available. This bit is cleared when acceleration data is read or the interrupt release register INT_REL is read. DRDY = 0 – new acceleration data not available DRDY = 1 – new acceleration data available TDTS1, TDTS0 – The Tap/Double-TapTM Status bits indicate whether a tap event has occurred and what kind. The status bits are cleared when interrupt release register INT_REL is read. TDTS1 TDTS0 Event 0 0 No Tap 0 1 Single Tap 1 0 Double-Tap 1 1 undefined R WUFS – The Wake-Up Function Status bit is cleared when the interrupt release register INT_REL is read. ot WUFS = 0 – No motion WUFS = 1 – Motion has activated the interrupt N TPS – The Tilt Position Status bit is cleared when the interrupt release register INT_REL is read. TPS = 0 – Position has not changed TPS = 1 – Position has changed 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 38 of 82 PART NUMBER: INS3 KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications The Interrupt Source 3 (INS3) register reports the axis and direction of detected motion. R 0 Bit7 R 0 Bit6 R XNWU Bit5 R XPWU Bit4 R YNWU Bit3 R YPWU Bit2 R R ZNWU ZPWU Bit1 Bit0 Address: 0x14 Bit Description XNWU X Negative (X-) Reported XPWU X Positive (X+) Reported YNWU Y Negative (Y-) Reported YPWU Y Positive (Y+) Reported ZNWU Z Negative (Z-) Reported ZPWU Z Positive (Z+) Reported Table 15: Motion Detection Reporting STATUS_REG The Status Register reports the status of whether the interrupt is present. R 0 Bit7 R 0 Bit6 R 0 Bit5 R INT Bit4 R 0 Bit3 R 0 Bit2 R R 0 0 Bit1 Bit0 Address: 0x15 INT = 0 – no interrupt event INT = 1 – interrupt event has occurred N ot R INT – The INT bit reports the combined (OR) interrupt information of all features. If BFI and WMI bits in INS2 register are 0, the INT bit is set to 0 when INT_REL register is read. If WMI or BFI bit in INS2 register is 1, INT bit remains at 1 until these bits are cleared by FIFO/FILO buffer read. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 39 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications INT_REL Interrupt Release (INT_REL) register: Latched interrupt source information reported in INS1, INS2, and INS3 registers is cleared and physical interrupt latched pin is changed to its inactive state when this register is read. However, WMI and BFI bits in INS2 register are not cleared by this command. Furthermore, INT bit in STATUS_REG will not be cleared by reading this register if WMI or BFI bits in INS2 register are set to 1. Read value is dummy. R X Bit7 R X Bit6 R X Bit5 R X Bit4 R X Bit3 R X Bit2 R R X X Bit1 Bit0 Address: 0x17 CNTL1 The Control 1 (CNTL1) register controls the main feature set of the accelerometer. R/W PC1 Bit7 R/W RES Bit6 R/W DRDYE Bit5 R/W GSEL1 Bit4 R/W GSEL0 Bit3 R/W TDTE Bit2 R/W R/W WUFE TPE Bit1 Bit0 Address: 0x18 Reset Value 00000000 PC1 – The PC1 bit controls the operating mode of the KX222. Note, when configuration changes need to be made, please allow 2/ODR (sec) delay time after setting PC1=0 (i.e. transitioning from operating mode to standby mode) R PC1 = 0 – Standby mode PC1 = 1 – operating mode (Low Power or High Resolution) N ot RES – The RES bit determines the performance mode of the KX222. The noise varies with ODR, RES and different LP_CNTL settings possibly reducing the effective resolution. Note that to change the value of this bit, the PC1 bit must first be set to “0”. RES = 0 – Low Power mode (higher noise, lower current, 16-bit output data) RES = 1 – High Resolution mode (lower noise, higher current, 16-bit output data) DRDYE – The Data Ready Enable bit enables the reporting of the availability of new acceleration data as an interrupt. Note that to change the value of this bit, the PC1 bit must first be set to “0”. DRDYE = 0 – availability of new acceleration data is not reflected as an interrupt DRDYE = 1 – availability of new acceleration data is reflected as an interrupt 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 40 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications GSEL1, GSEL0 – The G-Select bits allow to select the acceleration range of the accelerometer outputs per Table 16. Note that to change the value of this bit, the PC1 bit must first be set to “0”. GSEL1 GSEL0 Range 0 0 ±8g 0 1 ±16g 1 0 ±32g Table 16: Selected Acceleration Range TDTE – The Tap/Double-TapTM Enable bit enables the Directional-TapTM function that will detect single and double tap events. Note that to change the value of this bit, the PC1 bit must first be set to “0”. TDTE = 0 – Tap/Double-TapTM disabled TDTE = 1 – Tap/Double-TapTM enabled WUFE – The Wake-up Function Enable bit enables the Wake-Up (motion detect) function. Note that to change the value of this bit, the PC1 bit must first be set to “0”. WUFE = 0 – Wake-Up function disabled WUFE = 1 – Wake-Up function enabled R TPE – The Tilt Position Enable bit enables the Tilt Position function that will detect changes in device orientation. Note that to change the value of this bit, the PC1 bit must first be set to “0”. N ot TPE = 0 – Tilt Position function disabled TPE = 1 – Tilt Position function enabled 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 41 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications CNTL2 The Control 2 (CNTL2) register provides additional feature set control. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W SRST Bit7 R/W COTC Bit6 R/W LEM Bit5 R/W RIM Bit4 R/W DOM Bit3 R/W UPM Bit2 R/W R/W FDM FUM Bit1 Bit0 Address: 0x19 Reset Value 00111111 SRST – The Software Reset bit initiates software reset, which performs the RAM reboot routine. This bit will remain 1 until the RAM reboot routine is finished. Please refer to Technical Note TN004 Power-On Procedure for more information on software reset. SRST = 0 – no action SRST = 1 – start RAM reboot routine COTC – The Command Test Control bit is used to verify proper ASIC functionality. COTC = 0 – no action COTC = 1 – sets COTR register to 0xAA. When COTR register is then read, sets COTC bit to 0 and sets COTR register to 0x55. Bit LEM RIM DOM UPM FDM FUM Description Left state enable (X-) Right state enable (X+) Down state enable (Y-) Up state enable (Y+) Face-Down state enable (Z-) Face-Up state enable (Z+) Table 17: Tilt Direction Axis Mask N ot R LEM, RIM, DOM, UPM, FDM, FUM – these bits control the tilt axis mask. Per Table 17, if a direction’s bit is set to one (1), tilt in that direction will generate an interrupt. If it is set to zero (0), tilt in that direction will not generate an interrupt. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 42 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 CNTL3 The Control 3 (CNTL3) register sets the output data rates for Tilt, Directional-TapTM, and the Motion Wake-Up digital engines. The output data rate set in this register and the averaging filter control settings set in LP_CNTL register, will influence overall performance of the digital engines and the power consumption of the accelerometer. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W OTP1 Bit7 R/W OTP0 Bit6 R/W OTDT2 Bit5 R/W OTDT1 Bit4 R/W OTDT0 Bit3 R/W OWUF2 Bit2 R/W R/W OWUF1 OWUF0 Bit1 Bit0 Address: 0x1A Reset Value 10011000 OTP1, OTP0 – The ODR Tilt bits set the output data rate for the Tilt Position function per Table 18. The default Tilt Position ODR is 12.5Hz. OTP1 OTP0 Output Data Rate 0 0 1.563Hz 0 1 6.25Hz 1 0 12.5Hz 1 1 50Hz Table 18: Tilt Position Function Output Data Rate N ot R OTDT2, OTDT1, OTDT0 – The ODR Tap/Double-TapTM bits set the output data rate for the Directional-TapTM function per Table 19. The default Directional-TapTM ODR is 400Hz. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com OTDT2 OTDT1 OTDT0 Output Data Rate 0 0 0 50Hz 0 0 1 100Hz 0 1 0 200Hz 0 1 1 400Hz 1 0 0 12.5Hz 1 0 1 25Hz 1 1 0 800Hz 1 1 1 1600Hz Table 19: Directional-TapTM Function Output Data Rate © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 43 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications OWUF2, OWUF1, OWUF0 – The ODR Wake-Up Function bits set the output data rate for the general motion detection function and the high-pass filtered outputs per Table 20. The default Motion Wake-Up ODR is 0.781Hz. N ot R OWUF2 OWUF1 OWUF0 Output Data Rate 0 0 0 0.781Hz 0 0 1 1.563Hz 0 1 0 3.125Hz 0 1 1 6.250Hz 1 0 0 12.5Hz 1 0 1 25Hz 1 1 0 50Hz 1 1 1 100Hz Table 20: Motion Wake-Up Function Output Data Rate 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 44 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 ODCNTL The ODR Control (ODCNTL) register is responsible for configuring Output Data Rate (ODR) and lowpass filter settings. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W IIR_BYPASS Bit7 R/W LPRO Bit6 R/W R/W RESERVED RESERVED Bit5 Bit4 R/W OSA3 Bit3 R/W OSA2 Bit2 R/W R/W OSA1 OSA0 Bit1 Bit0 Address: 0x1B Reset Value 00000010 IIR_BYPASS filter bypass mode IIR_BYPASS = 0 – filtering applied (default) IIR_BYPASS = 1 – filter bypassed. This setting may reduce the resolution of the output data. N ot R LPRO low-pass filter roll off control LPRO = 0 – filter corner frequency set to ODR/9 (default) LPRO = 1 – filter corner frequency set to ODR/2 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com Figure 10: Low-Pass Filter Design and Control Circuitry © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 45 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications OSA3, OSA2, OSA1, OSA0 – The OSA bits set the acceleration output data rate (ODR). The default ODR is 50Hz. OSA3 OSA2 OSA1 OSA0 Output Data Rate 0 0 0 0 12.5Hz* 0 0 0 1 25Hz* 0 0 1 0 50Hz* 0 0 1 1 100Hz* 0 1 0 0 200Hz* 0 1 0 1 400Hz** 0 1 1 0 800Hz 0 1 1 1 1600Hz 1 0 0 0 0.781Hz* 1 0 0 1 1.563Hz* 1 0 1 0 3.125Hz* 1 0 1 1 6.25Hz* 1 1 0 0 3200Hz 1 1 0 1 6400Hz 1 1 1 0 12800Hz 1 1 1 1 25600Hz Table 21: Accelerometer Output Data Rates (ODR) N ot R * Low Power mode available, all other data rates will default to High Resolution mode ** 400Hz High Resolution mode only (will not output in Low Power mode) 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 46 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r INC1 KX222-1054 Rev. 2.0 22-Dec-2017 The Interrupt Control 1 (INC1) register controls the settings for the physical interrupt pin INT1, the Selftest function, and 3-wire SPI interface. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W R/W PWSEL11 PWSEL10 Bit7 Bit6 R/W IEN1 Bit5 R/W IEA1 Bit4 R/W IEL1 Bit3 R/W Reserved Bit2 R/W R/W STPOL SPI3E Bit1 Bit0 Address: 0x1C Reset Value 00010000 PWSEL1 – Pulse interrupt 1 width configuration 00 = 50 µsec (10 µsec if OSA > 1600Hz) 01 = 1 * OSA period 10 = 2 * OSA periods 11 = 4 * OSA periods When PWSEL1 > 0, interrupt source auto-clearing (ACLR1=1) should be set to keep consistency between the internal status and the physical interrupt. IEN1 enables/disables the physical interrupt pin INT1 IEN1 = 0 – physical interrupt pin is disabled IEN1 = 1 – physical interrupt pin is enabled R IEA1 sets the polarity of the physical interrupt pin INT1 IEA1 = 0 – polarity of the physical interrupt pin is active LOW IEA1 = 1 – polarity of the physical interrupt pin is active HIGH N ot IEL1 sets the response of the physical interrupt pin INT1 IEL1 = 0 – the physical interrupt pin latches until it is cleared by reading INT_REL. (excludes buffer full interrupt (BFI) and watermark interrupt (WMI)). IEL1 = 1 – the physical interrupt pin will transmit one pulse configurable by PWSEL1 STPOL sets the polarity of Self-test STPOL = 0 – Negative STPOL = 1 – Positive SPI3E sets the 3-wire SPI interface (set to 0 when I2C communication is used) SPI3E = 0 – disabled SPI3E = 1 – enabled 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 47 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r INC2 KX222-1054 Rev. 2.0 22-Dec-2017 The Interrupt Control 2 (INC2) register controls which axis and direction of detected motion can cause an interrupt. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W 0 Bit7 R/W AOI Bit6 R/W XNWUE Bit5 R/W XPWUE Bit4 R/W YNWUE Bit3 R/W YPWUE Bit2 R/W R/W ZNWUE ZPWUE Bit1 Bit0 Address: 0x1D Reset Value 00111111 AOI – AND-OR configuration on motion detection 0 – OR combination between selected directions 1 – AND combination between selected axes Ex. If all directions are enabled, Active state in OR configuration = (XN || XP || YN || YP || ZN || ZP) Active state in AND configuration = (XN || XP) && (YN || YP) && (ZN || ZP) XNWU XPWU YNWU YPWU ZNWU ZPWU INC3 – – – – – – x x y y z z negative positive negative positive negative positive (x-): (x+): (y-): (y+): (z-): (z+): 0 0 0 0 0 0 = = = = = = disabled, disabled, disabled, disabled, disabled, disabled, 1 1 1 1 1 1 = = = = = = enabled enabled enabled enabled enabled enabled ot R The Interrupt Control 3 (INC3) register controls which axis and direction of Tap/Double-TapTM can cause an interrupt. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. N R/W 0 Bit7 R/W 0 Bit6 TLEM TRIM TDOM TUPM TFDM TFUM R/W TLEM Bit5 – – – – – – 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com Tilt Tilt Tilt Tilt Tilt Tilt R/W TRIM Bit4 R/W TDOM Bit3 R/W TUPM Bit2 R/W R/W TFDM TFUM Bit1 Bit0 Address: 0x1E Reset Value 00111111 left state mask: 0 = disabled, 1 = enabled right state mask: 0 = disabled, 1 = enabled down state mask: 0 = disabled, 1 = enabled up state mask: 0 = disabled, 1 = enabled face-down state mask: 0 = disabled, 1 = enabled face-up state mask: 0 = disabled, 1 = enabled © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 48 of 82 PART NUMBER: INC4 KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications The Interrupt Control 4 (INC4) register controls routing of an interrupt reporting to physical interrupt pin INT1. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W FFI1 Bit7 R/W BFI1 Bit6 R/W WMI1 Bit5 R/W DRDYI1 Bit4 R/W Reserved Bit3 R/W TDTI1 Bit2 R/W R/W WUFI1 TPI1 Bit1 Bit0 Address: 0x1F Reset Value 00000000 FFI1 – Free fall interrupt reported on physical interrupt INT1 BFI1 – Buffer full interrupt reported on physical interrupt pin INT1 WMI1 – Watermark interrupt reported on physical interrupt pin INT1 DRDYI1 – Data ready interrupt reported on physical interrupt pin INT1 TDTI1 – Tap/Double-TapTM interrupt reported on physical interrupt pin INT1 WUFI1 – Wake-Up (motion detect) interrupt reported on physical interrupt pin INT1 TPI1 – Tilt position interrupt reported on physical interrupt pin INT1 INC5 The Interrupt Control 5 (INC5) register controls the settings for the physical interrupt pin INT2. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W IEN2 Bit5 R/W IEA2 Bit4 R/W IEL2 Bit3 R/W Reserved Bit2 R R/W R/W PWSEL21 PWSEL20 Bit7 Bit6 R/W R/W ACLR2 ACLR1 Bit1 Bit0 Address: 0x20 Reset Value 00010000 N ot PWSEL2 – Pulse interrupt 2 width configuration 00 = 50µsec (10µsec if OSA > 1600Hz) 01 = 1 * OSA period 10 = 2 * OSA periods 11 = 4 * OSA periods When PWSEL2 > 0, Interrupt source auto-clearing (ACLR2=1) is strongly recommended to keep consistency between the internal status and the physical interrupt. IEN2 enables/disables the physical interrupt pin INT2 IEN2 = 0 – physical interrupt pin is disabled IEN2 = 1 – physical interrupt pin is enabled 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 49 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 IEA2 sets the polarity of the physical interrupt pin INT2 IEA2 = 0 – polarity of the physical interrupt pin is active LOW IEA2 = 1 – polarity of the physical interrupt pin is active HIGH IEL2 sets the response of the physical interrupt pin INT2 IEL2 = 0 – the physical interrupt pin latches until it is cleared by reading INT_REL. (excludes buffer full interrupt (BFI) and watermark interrupt (WMI)). IEL2 = 1 – the physical interrupt pin will transmit one pulse configurable by PWSEL2 ACLR2 – Latched interrupt source information(INS1-INS3) is cleared and physical interrupt-1 latched pin is changed to its inactive state at pulse interrupt-2 trailing edge. Note: WMI and BFI are not auto-cleared by a pulse interrupt trailing edge. ACLR2 = 0 – disable ACLR2 = 1 – enable ACLR1 – Latched interrupt source information(INS1-INS3) is cleared and physical interrupt-2 latched pin is changed to its inactive state at pulse interrupt-1 trailing edge. Note: WMI and BFI are not auto-cleared by a pulse interrupt trailing edge. ACLR1 = 0 – disable ACLR1 = 1 – enable Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). INC6 R The Interrupt Control 6 (INC6) register controls routing of interrupt reporting to physical interrupt pin INT2. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W BFI2 Bit6 N ot R/W FFI2 Bit7 R/W WMI2 Bit5 R/W DRDYI2 Bit4 R/W Reserved Bit3 R/W TDTI2 Bit2 R/W R/W WUFI2 TPI2 Bit1 Bit0 Address: 0x21 Reset Value 00000000 FFI2 – Free fall interrupt reported on physical interrupt INT2 BFI2 – Buffer full interrupt reported on physical interrupt pin INT2 WMI2 – Watermark interrupt reported on physical interrupt pin INT2 DRDYI2 – Data ready interrupt reported on physical interrupt pin INT2 TDTI2 – Tap/Double-TapTM interrupt reported on physical interrupt pin INT2 WUFI2 – Wake-Up (motion detect) interrupt reported on physical interrupt pin INT2 TPI2 – Tilt position interrupt reported on physical interrupt pin INT2 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 50 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). TILT_TIMER This register is the initial count register for the tilt position state timer (0 to 255 counts). Every count is calculated as 1/ODR delay period, where the ODR is user-defined per Table 18. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W TSC7 Bit7 R/W TSC6 Bit6 R/W TSC5 Bit5 R/W TSC4 Bit4 R/W TSC3 Bit3 R/W TSC2 Bit2 R/W R/W TSC1 TSC0 Bit1 Bit0 Address: 0x22 Reset Value 00000000 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). WUFC The Wake-Up Function Counter (WUFC) is the initial count register for the motion detection timer (0 to 255 counts). Every count is calculated as 1/ODR delay period, where the ODR is user-defined per Table 20. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W WUFC6 Bit6 R/W WUFC5 Bit5 R/W WUFC4 Bit4 R/W WUFC3 Bit3 R/W WUFC2 Bit2 R/W R/W WUFC1 WUFC0 Bit1 Bit0 Address: 0x23 Reset Value 00000000 ot R R/W WUFC7 Bit7 N Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 51 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 TDTRC The Tap/Double-TapTM Report Control (TDTRC) register is responsible for enabling/disabling reporting of Tap/Double-TapTM events. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W 0 Bit7 R/W 0 Bit6 R/W 0 Bit5 R/W 0 Bit4 R/W 0 Bit3 R/W 0 Bit2 R/W R/W DTRE STRE Bit1 Bit0 Address: 0x24 Reset Value 00000011 DTRE – enables/disables the double tap interrupt DTRE = 0 – do not update/trigger interrupts on Double-TapTM events DTRE = 1 – update interrupts on Double-TapTM events STRE – enables/disables single tap interrupt STRE = 0 – do not update/trigger interrupts on single tap events STRE = 1 – update interrupts on single tap events R TDTC The Tap/Double-TapTM Counter (TDTC) register contains counter information for the detection of a double tap event. When the Directional-TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional-TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional-TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional-TapTM ODR is user-defined per Table 19. The TDTC counts starts at the beginning of the first tap and it represents the minimum time separation between the first tap and the second tap in a double tap event. More specifically, the second tap event must end outside of the TDTC. The Kionix recommended default value is 0.3 seconds (0x78). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W TDTC6 Bit6 N ot R/W TDTC7 Bit7 R/W TDTC5 Bit5 R/W TDTC4 Bit4 R/W TDTC3 Bit3 R/W TDTC2 Bit2 R/W R/W TDTC1 TDTC0 Bit1 Bit0 Address: 0x25 Reset Value 01111000 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 52 of 82 PART NUMBER: TTH KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications The Tap Threshold High (TTH) register represents the 8-bit jerk high threshold to determine if a tap is detected. The value is compared against the upper 8 bits of the 16g output value (independent of the actual g-range setting of the device). Though this is an 8-bit register, the register value is internally multiplied by two to set the high threshold. This multiplication results in a range of 0 to 510 with a resolution of two counts. The Performance Index (PI) is the jerk signal that is expected to be less than this threshold, but greater than the TTL threshold during single and double tap events. Equation 1 shows how to calculate the Performance Index. See AN090 Getting Started for recommended settings (LINK). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0” X’ = X (current) – X (previous) Y’ = Y (current) – Y (previous) Z’ = Z (current) – Z (previous) PI = |X’| + |Y’| + |Z’| Equation 1: Performance Index R/W TTH7 Bit7 R/W TTH6 Bit6 R/W TTH5 Bit5 R/W TTH4 Bit4 R/W TTH3 Bit3 R/W TTH2 Bit2 R/W R/W TTH1 TTH0 Bit1 Bit0 Address: 0x26 Reset Value 11001011 TTL R Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). N ot The Tap Threshold Low (TTL) register represents the 8-bit (0-255) jerk low threshold to determine if a tap is detected. The value is compared against the upper 8 bits of the 16g output value (independent of the actual g-range setting of the device). The Performance Index (PI) is the jerk signal that is expected to be greater than this threshold and less than the TTH threshold during single and double tap events. See AN090 Getting Started for recommended settings (LINK). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0” R/W TTL7 Bit7 R/W TTL6 Bit6 R/W TTL5 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com R/W TTL4 Bit4 R/W TTL3 Bit3 R/W TTL2 Bit2 R/W R/W TTL1 TTL0 Bit1 Bit0 Address: 0x27 Reset Value 00011010 © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 53 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). FTD This register contains counter information for the detection of any tap event. When the Directional-TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional-TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional-TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional-TapTM ODR is user-defined per Table 19. To ensure that only tap events are detected, these time limits are used. A tap event must be above the performance index threshold for at least the low limit (FTDL0 – FTDL2) and no more than the high limit (FTDH0 – FTDH4). The Kionix recommended default value for the high limit is 0.05 seconds and for the low limit is 0.005 seconds (0xA2). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W FTDH4 Bit7 R/W FTDH3 Bit6 R/W FTDH2 Bit5 R/W FTDH1 Bit4 R/W FTDH0 Bit3 R/W FTDL2 Bit2 R/W R/W FTDL1 FTDL0 Bit1 Bit0 Address: 0x28 Reset Value 10100010 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). STD N ot R This register contains counter information for the detection of a double tap event. When the DirectionalTapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the DirectionalTapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional-TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional-TapTM ODR is user-defined per Table 19. To ensure that only tap events are detected, this time limit is used. This register sets the total amount of time that the two taps in a double tap event can be above the PI threshold (TTL). The Kionix recommended default value for STD is 0.09 seconds (0x24). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W STD7 Bit7 R/W STD6 Bit6 R/W STD5 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com R/W STD4 Bit4 R/W STD3 Bit3 R/W STD2 Bit2 R/W R/W STD1 STD0 Bit1 Bit0 Address: 0x29 Reset Value 00100100 © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 54 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). TLT This register contains counter information for the detection of a tap event. When the Directional-TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional-TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the Directional-TapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional-TapTM ODR is user-defined per Table 19. To ensure that only tap events are detected, this time limit is used. This register sets the total amount of time that the tap algorithm will count samples that are above the PI threshold (TTL) during a potential tap event. It is used during both single and double tap events. However, reporting of single taps on the physical interrupt pin INT1 or INT2 will occur at the end of the TWS. The Kionix recommended default value for TLT is 0.1 seconds (0x28). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W TLT7 Bit7 R/W TLT6 Bit6 R/W TLT5 Bit5 R/W TLT4 Bit4 R/W TLT3 Bit3 R/W TLT2 Bit2 R/W R/W TLT1 TLT0 Bit1 Bit0 Address: 0x2A Reset Value 00101000 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). R TWS N ot This register contains counter information for the detection of single and double taps. When the Directional-TapTM ODR is 400Hz or less, every count is calculated as 1/ODR delay period. When the Directional-TapTM ODR is 800Hz, every count is calculated as 2/ODR delay period. When the DirectionalTapTM ODR is 1600Hz, every count is calculated as 4/ODR delay period. The Directional-TapTM ODR is user-defined per Table 19. It defines the time window for the entire tap event, single or double, to occur. Reporting of single taps on the physical interrupt pin INT1 or INT2 will occur at the end of this tap window. The Kionix recommended default value for TWS is 0.4 seconds (0xA0). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W TWS7 Bit7 R/W TWS6 Bit6 R/W TWS5 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com R/W TWS4 Bit4 R/W TWS3 Bit3 R/W TWS2 Bit2 R/W R/W TWS1 TWS0 Bit1 Bit0 Address: 0x2B Reset Value 10100000 © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 55 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). FFTH The Free Fall Threshold (FFTH) register contains the threshold of the Free fall detection. This value is compared to the top 8 bits of the accelerometer 32g output value (independent of the actual g-range setting of the device). See AN090 Getting Started for recommended settings (LINK). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W FFTH7 Bit7 R/W FFTH6 Bit6 R/W FFTH5 Bit5 R/W FFTH4 Bit4 R/W FFTH3 Bit3 R/W FFTH2 Bit2 R/W R/W FFTH1 FFTH0 Bit1 Bit0 Address: 0x2C Reset Value 00000000 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). FFC The Free Fall Counter (FFC) register contains the counter setting of the Free fall detection. Every count is calculated as 1/ODR delay period where ODR is a Free fall ODR set by OFFI bits in FFCNTL register. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W FFC6 Bit6 R/W FFC5 Bit5 R R/W FFC7 Bit7 R/W FFC4 Bit4 R/W FFC3 Bit3 R/W FFC2 Bit2 R/W R/W FFC1 FFC0 Bit1 Bit0 Address: 0x2D Reset Value 00000000 N ot Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). FFCNTL The Free Fall Control (FFCNTL) register contains the control setting of the Free fall detection. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W FFIE Bit7 R/W ULMODE Bit6 R/W 0 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com R/W 0 Bit4 R/W DCRM Bit3 R/W OFFI2 Bit2 R/W R/W OFFI1 OFFI0 Bit1 Bit0 Address: 0x2E Reset Value 00000000 © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 56 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications FFIE – Free fall engine enable FFIE = 0 – Free fall engine disabled FFIE = 1 – Free fall engine enabled ULMODE – Free fall interrupt latch/un-latch control ULMODE = 0 – latched ULMODE = 1 – unlatched DCRM – Debounce methodology control DCRM = 0 – count up/down DCRM = 1 – count up/reset OFFI – Output Data Rate at which the Free fall engine performs its function. The default Free fall ODR is 12.5Hz. R OFFI Output Data Rate (Hz) 000 12.5 001 25 010 50 011 100 100 200 101 400 110 800 111 1600 Table 22: Free Fall Detection Output Data Rate ot Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). N ATH The Activity Threshold (ATH) register sets the threshold for wake-up (motion detect) interrupt is set. This value is compared to the top 8 bits of the accelerometer 32g output value (independent of the actual grange setting of the device). The KX222 will ship from the factory with this value set to correspond to a change in acceleration of 0.5g. See AN090 Getting Started for recommended settings (LINK). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W ATH7 Bit7 R/W ATH6 Bit6 R/W ATH5 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com R/W ATH4 Bit4 R/W ATH3 Bit3 R/W ATH2 Bit2 R/W R/W ATH1 ATH0 Bit1 Bit0 Address: 0x30 Reset Value 00000010 © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 57 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). TILT_ANGLE_LL Tilt Angle Low Limit: This register sets the low-level threshold for tilt angle detection. The low-level threshold value is compared against the upper 8 bits of the 16g output value (independent of the actual g-range setting of the device). Note that the minimum suggested tilt angle is 10°. See AN090 Getting Started for recommended settings (LINK). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W TA7 Bit7 R/W TA6 Bit6 R/W TA5 Bit5 R/W TA4 Bit4 R/W TA3 Bit3 R/W TA2 Bit2 R/W TA1 Bit1 R/W TA0 Bit0 Reset Value 00001100 Address: 0x32 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). R/W HL6 Bit6 N ot R/W HL7 Bit7 R TILT_ANGLE_HL Tilt Angle High Limit: This register sets the high-level threshold for tilt angle detection. The high-level threshold is used by an internal algorithm to eliminate dynamic g-variations caused by the device movement. Instead, only static g-variation (gravity) caused by the actual tilt changes are used. The highlevel threshold value is compared against the upper 8 bits of the 16g output value (independent of the actual g-range setting of the device). See AN090 Getting Started for recommended settings (LINK). Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W HL5 Bit5 R/W HL4 Bit4 R/W HL3 Bit3 R/W HL2 Bit2 R/W HL1 Bit1 R/W HL0 Bit0 Reset Value 00101010 Address: 0x33 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 58 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 HYST_SET This register sets the Hysteresis that is placed in between the Screen Rotation states. The KX222 ships from the factory with HYST_SET set to ±15° of hysteresis. Note that when writing a new value to this register the current values of RES0 and RES1 must be preserved. These values are set at the factory and must not change. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W R/W Reserved Reserved Bit7 Bit6 R/W HYST5 Bit5 R/W HYST4 Bit4 R/W HYST3 Bit3 R/W HYST2 Bit2 R/W R/W HYST1 HYST0 Bit1 Bit0 Address: 0x34 Reset Value 00010100 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). LP_CNTL The Averaging Filter Control setting can be used in the optimization of current and noise performance of the accelerometer and can be tested using Kionix FlexSetTM Performance Optimization Tool. More specifically, this setting determines the number of internal acceleration samples to be averaged in Low Power mode. Also, it determines the number of internal acceleration samples to be averaged for digital engines operation (Directional-TapTM, Tilt, Wake-Up, Free fall) both in High Resolution and Low Power modes. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. Reserved Bit7 R/W AVC2 Bit6 R/W AVC1 Bit5 R R/W R/W AVC0 Bit4 R/W R/W R/W Reserved Reserved Reserved Bit3 Bit2 Bit1 R/W Reserved Bit0 Reset Value 01001011 ot Address: 0x35 N AVC – Averaging Filter Control. The default setting is 16 samples and was found to work for most case. 000 001 010 011 100 101 110 111 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com = = = = = = = = No Averaging 2 Samples Averaged 4 Samples Averaged 8 Samples Averaged 16 Samples Averaged (default) 32 Samples Averaged 64 Samples Averaged 128 Samples Averaged © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 59 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Note: New data is blocked from being written to the sample buffer when this register is read from using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). BUF_CNTL1 The Buffer Control 1 (BUF_CNTL1) register controls the buffer sample threshold. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W R/W R/W R/W R/W R/W R/W R/W SMP_TH7 SMP_TH6 SMP_TH5 SMP_TH4 SMP_TH3 SMP_TH2 SMP_TH1 SMP_TH0 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Address: 0x3A Reset Value 00000000 SMP_TH [9:0] Sample Threshold determines the number of samples that will trigger a watermark interrupt or will be saved prior to a trigger event. When BUF_RES=1, the maximum number of samples is 340; when BUF_RES=0, the maximum number of samples is 681. Buffer Model Sample Function Bypass None FIFO N ot R Stream Trigger FILO Specifies how many buffer samples are needed to trigger a watermark interrupt. Specifies how many buffer samples are needed to trigger a watermark interrupt. Specifies how many buffer samples before the trigger event are retained in the buffer. Specifies how many buffer samples are needed to trigger a watermark interrupt. Table 23: Sample Threshold Operation by Buffer Mode Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 60 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications BUF_CNTL2 The Buffer Control 2 (BUF_CNTL2) register controls sample buffer operation. Note that to properly change the value of this register, the PC1 bit in CNTL1 register must first be set to “0”. R/W BUFE Bit7 R/W BRES Bit6 R/W BFIE Bit5 R/W 0 Bit4 R/W R/W R/W R/W SMP_TH9 SMP_TH8 BUF_M1 BUF_M0 Bit3 Bit2 Bit1 Bit0 Address: 0x3B Reset Value 00000000 BUFE controls activation of the sample buffer. BUFE = 0 – sample buffer inactive BUFE = 1 – sample buffer active Note: Disabling the sample buffer (BUFE = 0) will clear the buffer. The buffer will also be cleared (1) following write to BUF_CLEAR register and/or (2) after setting PC1 bit in CNTL1 register to 0 (standby mode). BRES determines the resolution of the acceleration data samples collected by the sample buffer. BRES = 0 – 8-bit samples are accumulated in the buffer BRES = 1 – 16-bit samples are accumulated in the buffer R BFIE buffer full interrupt enable bit BFIE = 0 – buffer full interrupt disabled BFIE = 1 – buffer full interrupt updated in INS2 BUF_M1, BUF_M0 selects the operating mode of the sample buffer per Table 24. BUF_M0 ot BUF_M1 0 FIFO 0 1 Stream 1 0 Trigger 1 1 FILO N 0 Mode Description The buffer collects 681 sets of 8-bit low resolution values or 340 sets of 16-bit high resolution values and then stops collecting data, collecting new data only when the buffer is not full. The buffer holds the last 681 sets of 8-bit low resolution values or 340 sets of 16-bit high resolution values. Once the buffer is full, the oldest data is discarded to make room for newer data. When a trigger event occurs, the buffer holds the last data set of SMP_TH[9:0] samples before the trigger event and then continues to collect data until full. New data is collected only when the buffer is not full. The buffer holds the last 681 sets of 8-bit low resolution values or 340 sets of 16-bit high resolution values. Once the buffer is full, the oldest data is discarded to make room for newer data. Reading from the buffer in this mode will return the most recent data first. Table 24: Selected Buffer Mode 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 61 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Note: New data is blocked from being written to the sample buffer when this register is read from / written to using SPI interface only. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready). BUF_STATUS_1 Buffer Status 1: This register reports the status of the sample buffer. R R R R R R R R SMP_LEV7 SMP_LEV6 SMP_LEV5 SMP_LEV4 SMP_LEV3 SMP_LEV2 SMP_LEV1 SMP_LEV0 Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 Address: 0x3C SMP_LEV [10:0] Sample Level: reports the number of data bytes that have been stored in the sample buffer. When BRES=1, this count will increase by 6 for each 3-axis sample in the buffer. When BRES=0, the count will increase by 3 for each 3-axis sample. If this register reads 0, no data has been stored in the buffer. Note: New data is blocked from being written to the sample buffer when this register is read using I2C/SPI interface. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready) or perform a burst read from 0x3B to 0x3C. BUF_STATUS_2 Buffer Status 2: This register reports the status of the sample buffer trigger function. R 0 Bit6 R 0 Bit5 R 0 Bit4 R 0 Bit3 R R R SMP_LEV10 SMP_LEV9 SMP_LEV8 Bit2 Bit1 Bit0 Address: 0x3D N ot R R BUF_TRIG Bit7 BUF_TRIG reports the status of the buffer’s trigger function if this mode has been selected. When using trigger mode, a buffer read should only be performed after a trigger event. This bit is cleared after writing to BUF_CLEAR register. This will prevent Buffer Full interrupt from firing while TRIG pin remains de-asserted. Note: New data is blocked from being written to the sample buffer when this register is read from using I2C/SPI interface. To prevent this, complete the serial communication transacting before the next ODR update (synchronous with Data Ready) or perform a burst read from 0x3B to 0x3D. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 62 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications BUF_CLEAR Buffer Clear: When any data is written to this register, the entire sample buffer is cleared. This causes the sample level bits SMP_LEV [10:0] to be cleared in BUF_STATUS_1 and BUF_STATUS_2 registers. In addition, if the sample buffer is set to Trigger mode, the BUF_TRIG bit in BUF_STATUS_2 is cleared too. Finally, the BFI and WMI bits in INS2 will be cleared and physical interrupt latched pin will be changed to its inactive state. W X Bit7 W X Bit6 W X Bit5 W X Bit4 W X Bit3 W X Bit2 W W X X Bit1 Bit0 Address: 0x3E R X Bit3 R X Bit2 R R X X Bit1 Bit0 Address: 0x3F BUF_READ Buffer Read: Buffer output register R X Bit7 R X Bit6 R X Bit5 R X Bit4 Note: New data is not being written to the buffer during the buffer read operation. Thus, care must be taken when reading from the buffer. If data loss is not desired, the buffer read operation should be completed within ODR clock cycle. ot R SELF_TEST Self-Test: When 0xCA value is written to this register, the MEMS self-test function is enabled. Electrostatic-actuation of the accelerometer, results in a DC shift of the X, Y and Z axis outputs. Writing 0x00 to this register will return the accelerometer to normal operation. **Note, this is a write-only register. Read back value from this register will always be 0x00. N W 0 Bit7 W 0 Bit6 W 0 Bit5 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com W 0 Bit4 W 0 Bit3 W 0 Bit2 W W 0 0 Bit1 Bit0 Address: 0x60 Reset Value 00000000 © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 63 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Embedded Applications Orientation Detection Feature The orientation detection feature of the KX222 will report changes in face up, face down, ± vertical and ± horizontal orientation. This intelligent embedded algorithm considers very important factors that provide accurate orientation detection from low cost tri-axis accelerometers. Factors such as: hysteresis, device orientation angle, and delay time are described below as these techniques are utilized inside the KX222. Hysteresis R A 45° tilt angle threshold seems like a good choice because it is halfway between 0° and 90°. However, a problem arises when the user holds the device near 45°. Slight vibrations, noise and inherent sensor error will cause the acceleration to go above and below the threshold rapidly and randomly, so the screen will quickly flip back and forth between the 0° and the 90° orientations. This problem is avoided in the KX222 by choosing a 30° threshold angle. With a 30° threshold, the screen will not rotate from 0° to 90° until the device is tilted to 60° (30° from 90°). To rotate back to 0°, the user must tilt back to 30°, thus avoiding the screen flipping problem. This example essentially applies ± 15° of hysteresis in between the four screen rotation states. Table 25 shows the acceleration limits implemented for  T =30°. Orientation X Acceleration (g) Y Acceleration (g) 0°/360° -0.5 < ax < 0.5 ay > 0.866 90° ax > 0.866 -0.5 < ay < 0.5 180° -0.5 < ax < 0.5 ay < -0.866 270° ax < -0.866 -0.5 < ay < 0.5 Table 25: Acceleration at the four orientations with ± 15° of hysteresis N ot The KX222 allows the user to change the amount of hysteresis in between the four screen rotation states. By simply writing to the HYST_SET register, the user can adjust the amount of hysteresis up to ± 45°. The plot in Figure 11 shows the typical amount of hysteresis applied for a given digital count value of HYST_SET. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 64 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 HYST_SET vs Hysteresis 50 45 Hysteresis (+/- degrees) 40 35 30 25 20 15 10 5 0 Hysteresis 0 5 10 15 20 25 30 HYST_SET Value (Counts) Figure 11: HYST_SET vs Hysteresis Device Orientation Angle (aka Tilt Angle) N ot R To ensure that horizontal and vertical device orientation changes are detected, even when it isn’t in the ideal vertical orientation – where the angle θ in Figure 12 is 90°, the KX222 considers device orientation angle in its algorithm. Figure 12: Device Orientation Angle As the angle in Figure 12 is decreased, the maximum gravitational acceleration on the X-axis or Y-axis will also decrease. Therefore, when the angle becomes small enough, the user will not be able to make 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 65 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 the screen orientation change. When the device orientation angle approaches 0° (device is flat on a desk or table), ax = ay = 0g, az = +1g, and there is no way to determine which way the screen should be oriented, the internal algorithm determines that the device is in either the face-up or face-down orientation, depending on the sign of the z-axis. The KX222 will only change the screen orientation when the orientation angle is above the factory-defaulted/user-defined threshold set in the TILT_ANGLE_LL register. Equation 2 can be used to determine what value to write to the TILT_ANGLE_LL register to set the device orientation angle. The value for TILT_ANGLE_HL is preset at the factory but can be adjusted in special cases (e.g. to reduce the effect of transient g-variation such as when device is being moved rather than just being rotated). TILT_ANGLE_LL (counts) = sin θ * (8 (counts/g)) Equation 2: Tilt Angle Threshold Tilt Timer The 8-bit register, TILT_TIMER can be used to qualify changes in orientation. The KX222 does this by incrementing a counter with a size that is specified by the value in TILT_TIMER for each set of acceleration samples to verify that a change to a new orientation state is maintained. A user defined Tilt Position output data rate (ODR) as set by OTP bits in CNTL3 register, determines the time period for each sample. Equation 3 shows how to calculate the TILT_TIMER register value for a desired delay time. TILT_TIMER (counts) = Delay Time (sec) x Tilt Position ODR (Hz) N ot R Equation 3: Tilt Position Delay Time 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 66 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Motion Interrupt Feature Description The Motion interrupt feature of the KX222 reports qualified changes in the high-pass filtered acceleration based on the wake-up Activity Threshold (ATH). If the high-pass filtered acceleration on any axis is greater than the user-defined wake-up activity threshold (ATH), the device has transitioned from an inactive state to an active state. Equation 4 shows how to calculate the ATH register value for a desired wake-up threshold. The wake-up engine function is independent of the user selected g-range and resolution. ATH (counts) = Wake-Up Threshold (g) x 4 (counts/g) Equation 4: Wake-Up Threshold An 8-bit raw unsigned value represents a counter that permits the user to qualify each active/inactive state change. Note that each Wake-Up Function Counter (WUFC) count value qualifies 1 (one) user-defined Wakeup Function ODR period as set by OWUF bits in CNTL3 register. Equation 5 shows how to calculate the WUFC register value for a desired wake-up delay time. WUFC (counts) = Wake-Up Delay Time (sec) x Wake-up Function ODR (Hz) Equation 5: Wake-Up Delay Time ot R The latched motion interrupt response algorithm works as following: while the part is in inactive state, the algorithm evaluates differential measurement between each new acceleration data point with the preceding one and evaluates it against the Activity Threshold (ATH). When the differential measurement is greater than ATH, the wake-up function counter (WUFC) starts the count. Differential measurements are now calculated based on the difference between the current acceleration and the acceleration when the counter started. The part will report that motion has occurred at the end of the count assuming each differential measurement has remained above the threshold. If at any moment during the count the differential measurement falls below the threshold, the counter will stop the count and the part will remain in inactive state. N To illustrate how the algorithm works, consider the Figure 13 below that shows the latched response of the motion detection algorithm with the Wake-up Function Counter (WUFC) set to 10 counts. Note how the difference between the acceleration sample marked in red and the one marked in green resulted in a differential measurement represented with orange bar being above the Activity Threshold (ATH). At this point, the Wakeup Function Counter (WUFC) begins to count number of counts stored in WUFC register and the wake-up algorithm will evaluate the difference between each new acceleration measurement and the measurement marked in green that will remain a reference measurement for the duration of the counter count. At the end of the count, assuming all differential measurements were larger than Activity Threshold (ATH), as is the case in the example showed in Figure 13 a motion event will be reported. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 67 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 N ot R e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Figure 13: Latched Motion Interrupt Response 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 68 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Directional-Tap Detection Feature Description The Directional-TapTM Detection feature of the KX222 recognizes single and double tap inputs and reports the acceleration axis and direction that each tap occurred. Eight performance parameters, as well as a userselectable ODR are used to configure the KX222 for a desired tap detection response. Performance Index The Directional-TapTM detection algorithm uses low and high thresholds to help determine when a tap event has occurred. A tap event is detected when the previously described jerk summation exceeds the low threshold (TTL) for more than the tap detection low limit, but less than the tap detection high limit as contained in FTD. Samples that exceed the high limit (TTH) will be ignored. Figure 14 shows an example of a single tap event meeting the performance index criteria. Calculated Performance Index PI 180 : Sampled Data 160 140 100 R jerk (counts) 120 80 ot 60 N 40 TTL 20 0 3.14 3.15 3.16 3.17 3.18 time(sec) 3.19 3.2 3.21 Figure 14: Jerk Summation vs Threshold 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 69 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Single Tap Detection The latency timer (TLT) sets the time period that a tap event will only be characterized as a single tap. A second tap must occur outside of the latency timer. If a second tap occurs inside the latency time, it will be ignored as it occurred too quickly. The single tap will be reported at the end of the TWS. Figure 15 shows a single tap event meeting the PI, latency and window requirements. Calculated Performance Index 160 PI 140 TWS 120 jerk (counts) 100 80 TLT 60 R 40 ot TTL 20 N 0 2.1 2.2 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com 2.3 2.4 2.5 2.6 2.7 time(sec) 2.8 2.9 3 3.1 Figure 15: Single Directional-TapTM Timing © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 70 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Double-Tap Detection N ot R An event can be characterized as a double tap if the second tap crosses the performance index (TTL) inside the TWS period and ends outside the TDTC. This means that the TDTC determines the minimum time separation that must exist between the two taps of a double tap event. Similar to the single tap, the first tap event must exceed the performance index for the time limit contained in FTD. Also, the duration when the first and second events combined exceed the performance index should not exceed STD. The double tap will be reported at the end of the second TLT. Figure 16 shows a double tap event meeting the PI, latency and window requirements. Figure 16: Double-TapTM Timing 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 71 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Free fall Detect The KX222 features a Free fall interrupt that sends a flag through the INT1 or the INT2 output pins when the accelerometer senses a Free fall event. The interrupt event is also reflected on the INT (bit 4) of the STATUS_REG and FFS (bit 7) of the INS2 registers. A Free fall event is evident when all three accelerometer axes simultaneously fall below a certain acceleration threshold for a set amount of time. The KX222 gives the user the option to define the acceleration threshold value through the FFTH 8-bit register where 256 counts cover the g range of the accelerometer. This value is compared to the top 8 bits of the accelerometer 32g output value (independent of the actual g-range setting of the device). Equation 6 shows how to calculate the FFTH register value for a desired Free fall threshold. The threshold of 0.5g is a good starting point. FFTH (counts) = Free fall Threshold (g) x 4 (counts/g) Equation 6: Free fall Threshold Through the Free Fall Counter (FFC), the user can set the amount of time all three accelerometer axes must simultaneously remain below the FFTH acceleration threshold before the Free fall interrupt flag is sent through the INT1 or the INT2 output pins. This delay/debounce time is defined by the available 0 to 255 counts, which represent accelerometer samples taken at the Free fall ODR defined by OFFI bits in the FFCNTL register. Every count is calculated as 1/ODR delay period. Equation 7 shows how to calculate the FFC register value for a desired Free fall delay. The delay of 0.32 sec is a good starting point. FFC (counts) = Free fall delay (sec) x Free fall ODR (Hz) Equation 7: Free fall Threshold N ot R When the Free fall interrupt is enabled the part must not be in a physical state that would trigger the Free fall interrupt or the delay will not be correct for the present Free fall. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 72 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Typical Freefall Interrupt Example (nonLatching) 255 Pos. Motion limit 216 Pos. Freefall limit 0g Neg. Freefall limit 148 Neg. Motion limit 40 128 108 0 Freefall debounce timer 10 Set to 10 counts. FF/MOT Interrupt Figure 17: Typical Free Fall Interrupt Example (FFCNTL ULMODE = 1) Typical Freefall Interrupt Example (Latching) 255 216 Pos. Freefall limit 0g Neg. Freefall limit 148 ot R Pos. Motion limit N Neg. Motion limit 128 108 40 0 Freefall debounce timer 10 Set to 10 counts. FF/MOT Interrupt Figure 18: Typical Free Fall Interrupt Example (FFCNTL ULMODE = 0) 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 73 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Sample Buffer Feature Description The sample buffer feature of the KX222 accumulates and outputs acceleration data based on how it is configured. There are 4 buffer modes available, and samples can be accumulated at either low (8-bit) or high (16-bit) resolution. Acceleration data is collected at the ODR specified by OSA[3:0] in the ODCNTL register. Each buffer mode accumulates data, reports data, and interacts with status indicators in a slightly different way. FIFO Mode Data Accumulation Sample collection stops when the buffer is full. Data Reporting Data is reported with the oldest byte of the oldest sample first (X_L or X based on resolution). Status Indicators A watermark interrupt occurs when the number of samples in the buffer reaches the Sample Threshold. The watermark interrupt stays active until the buffer contains less than this number of samples. This can be accomplished through clearing the buffer or explicitly reading greater than SMPX samples (calculated with Equation 8). BUF_RES=0: SMPX = SMP_LEV[10:0] /3 – SMP_TH[9:0] R BUF_RES=1: SMPX = SMP_LEV[10:0] /6 – SMP_TH[9:0] Equation 8: Samples Above Sample Threshold N ot Stream Mode Data Accumulation Sample collection continues when the buffer is full; older data is discarded to make room for newer data. Data Reporting Data is reported with the oldest sample first (uses FIFO read pointer). Status Indicators A watermark interrupt occurs when the number of samples in the buffer reaches the Sample Threshold. The watermark interrupt stays active until the buffer contains less than this number of samples. This can be accomplished through clearing the buffer or explicitly reading greater than SMPX samples (calculated with Equation 8). 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 74 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Trigger Mode Data Accumulation When a physical interrupt is caused by one of the digital engines or when a logic high signal occurs on the TRIG pin, the trigger event is asserted and SMP_TH[9:0] samples prior to the event are retained. Sample collection continues until the buffer is full. Data Reporting Data is reported with the oldest sample first (uses FIFO read pointer). Status Indicators When a physical interrupt occurs and there are at least SMP_TH[9:0] samples in the buffer, BUF_TRIG in BUF_STATUS_2 is asserted. FILO Mode R Data Accumulation Sample collection continues when the buffer is full; older data is discarded to make room for newer data. Data Reporting Data is reported with the newest byte of the newest sample first (Z_H or Z based on resolution). Status Indicators A watermark interrupt occurs when the number of samples in the buffer reaches the Sample Threshold. The watermark interrupt stays active until the buffer contains less than this number of samples. This can be accomplished through clearing the buffer or explicitly reading greater than SMPX samples (calculated with Equation 8). N ot Buffer Operation The following diagrams illustrate the operation of the buffer conceptually. Actual physical implementation has been abstracted to offer a simplified explanation of how the different buffer modes operate. Figure 19 represents a high-resolution 3-axis sample within the buffer. Figure 20 – Figure 28 represent a 10-sample version of the buffer (for simplicity), with Sample Threshold set to 8. Regardless of the selected mode, the buffer fills sequentially, one byte at a time. Figure 19 shows one 6-byte data sample. Note the location of the FILO read pointer versus that of the FIFO read pointer. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 75 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 Index Byte 0 X_L -- FIFO read pointer 1 X_H 2 Y_L 3 Y_H 4 Z_L 5 Z_H -- FILO read pointer buffer write pointer -- 6 Figure 19: One Buffer Sample Regardless of the selected mode, the buffer fills sequentially, one sample at a time. Note in Figure 20 the location of the FILO read pointer versus that of the FIFO read pointer. The buffer write pointer shows where the next sample will be written to the buffer. buffer write pointer → Index Sample 0 Data0 1 Data1 2 Data2 ← FIFO read pointer ← FILO read pointer 3 N ot R 4 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com 5 6 7 ← Sample Threshold 8 9 Figure 20: Buffer Filling © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 76 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 The buffer continues to fill sequentially until the Sample Threshold is reached. Note in Figure 21 the location of the FILO read pointer versus that of the FIFO read pointer. buffer write pointer → Index Sample 0 Data0 1 Data1 2 Data2 3 Data3 4 Data4 5 Data5 6 Data6 7 ← FIFO read pointer ← FILO read pointer ← Sample Threshold 8 9 Figure 21: Buffer Approaching Sample Threshold N ot R In FIFO, Stream, and FILO modes, a watermark interrupt is issued when the number of samples in the buffer reaches the Sample Threshold. In trigger mode, this is the point where the oldest data in the buffer is discarded to make room for newer data. buffer write pointer → 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com Index 0 1 2 3 4 5 6 7 Sample Data0 Data1 Data2 Data3 Data4 Data5 Data6 Data7 ← FIFO read pointer ← Sample Threshold/FILO read pointer 8 9 Figure 22: Buffer at Sample Threshold © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 77 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications In trigger mode, data is accumulated in the buffer sequentially until the Sample Threshold is reached. Once the Sample Threshold is reached, the oldest samples are discarded when new samples are collected. Note in Figure 23 how Data0 was thrown out to make room for Data8. Index Sample 0 Data1 ← Trigger read pointer 1 Data2 2 Data3 3 Data4 4 Data5 5 Data6 6 Data7 7 Data8 Trigger write pointer → ← Sample Threshold 8 9 Figure 23: Additional Data Prior to Trigger Event N ot R After a trigger event occurs, the buffer no longer discards the oldest samples, and instead begins accumulating samples sequentially until full. The buffer then stops collecting samples, as seen in Figure 24. This results in the buffer holding SMP_TH[9:0] samples prior to the trigger event, and SMPX samples after the trigger event. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com Index 0 1 2 3 4 5 6 Sample Data1 Data2 Data3 Data4 Data5 Data6 Data7 ← Trigger read pointer 7 Data8 ← Sample Threshold 8 Data9 9 Data10 Figure 24: Additional Data after Trigger Event © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 78 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications In FIFO, Stream, FILO, and Trigger (after a trigger event has occurred) modes, the buffer continues filling sequentially after the Sample Threshold is reached. Sample accumulation after the buffer is full depends on the selected operation mode. FIFO and Trigger modes stop accumulating samples when the buffer is full, and Stream and FILO modes begin discarding the oldest data when new samples are accumulated. Index 0 1 2 3 4 5 6 7 8 9 Sample Data0 ← FIFO read pointer Data1 Data2 Data3 Data4 Data5 Data6 Data7 ← Sample Threshold Data8 Data9 ← FILO read pointer Figure 25: Buffer Full N ot R After the buffer has been filled in FILO or Stream mode, the oldest samples are discarded when new samples are collected. Note in Figure 26 how Data0 was thrown out to make room for Data10. Index 0 1 2 3 4 5 6 Sample Data1 Data2 Data3 Data4 Data5 Data6 Data7 ← FIFO read pointer 7 Data8 ← Sample Threshold 8 Data9 9 Data10 ← FILO read pointer Figure 26: Buffer Full – Additional Sample Accumulation in Stream or FILO Mode 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 79 of 82 PART NUMBER: ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications e N co ew m m D es en ig de ns d fo r KX222-1054 Rev. 2.0 22-Dec-2017 In FIFO, Stream, or Trigger mode, reading one sample from the buffer will remove the oldest sample and effectively shift the entire buffer contents up, as seen in Figure 27. Index Sample 0 Data1 1 Data2 2 Data3 3 Data4 4 Data5 5 Data6 6 Data7 7 Data8 8 Data9 ← FIFO read pointer ← Sample Threshold ← FILO read pointer 9 buffer write pointer → Figure 27: FIFO Read from Full Buffer N ot R In FILO mode, reading one sample from the buffer will remove the newest sample and leave the older samples untouched, as seen in Figure 28. Index 0 1 2 3 4 5 6 7 Sample Data0 Data1 Data2 Data3 Data4 Data5 Data6 Data7 8 Data8 ← FIFO read pointer ← Sample Threshold ← FILO read pointer 9 buffer write pointer → Figure 28: FILO Read from Full Buffer 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 80 of 82 PART NUMBER: KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications Revision History Revision 1.0 2.0 Description Initial Release Updated Bandwidth (-3dB) setting in Electrical Speicifications table and corresponding note under the table. Updated Mechanical Resonant frequency in Mechanical Spec. Updated Noise in Mechanical Spec table. Updated Functional Diagram. Updated 3-Wire Read and Write Registers section. Revised RoHS/REACH compliance section. Updated Start Up Time and Current Profile figures. Updated IO_VDD max parameter. Revised Package Outline Drawing. Revised Sample Buffer, Motion Interrupt, Free fall Detect, Device Orientation engine descriptions. Updated SPI3E, PC1, RES, IIR_BYPASS, SMP_TH, BUFE, BFI, WMI, IEL1, IEL2, TDTS, SRST, BUF_TRIG bit descriptions. Revised INT1, INT2 pin descriptions. Revised CNTL3, LP_CNTL, SELF-TEST, INT_REL, FFC, FFCNTL, BUF_READ, BUF_CLEAR register descriptions. Date 26-Sep-2016 22-Dec-2017 N ot R "Kionix" is a registered trademark of Kionix, Inc. Products described herein are protected by patents issued or pending. No license is granted by implication or otherwise under any patent or other rights of Kionix. The information contained herein is believed to be accurate and reliable but is not guaranteed. Kionix does not assume responsibility for its use or distribution. Kionix also reserves the right to change product specifications or discontinue this product at any time without prior notice. This publication supersedes and replaces all information previously supplied. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 81 of 82 PART NUMBER: Appendix KX222-1054 Rev. 2.0 22-Dec-2017 e N co ew m m D es en ig de ns d fo r ± 8g / 16g / 32g Tri-axis Digital Accelerometer Specifications N ot R The following Notice is included to guide the use of Kionix products in its application and manufacturing processes. Kionix, Inc., is a ROHM Group company. For purposes of this Notice, the name “ROHM” would also imply Kionix, Inc. 36 Thornwood Dr. – Ithaca, NY 14850 tel: 607-257-1080 – fax: 607-257-1146 www.kionix.com - info@kionix.com © 2017 Kionix – All Rights Reserved 754-10411-1712221306-0.37 Page 82 of 82 Notice Precaution on using ROHM Products Our Products are designed and manufactured for application in ordinary electronic equipments (such as AV equipment, OA equipment, telecommunication equipment, home electronic appliances, amusement equipment, etc.). If you (Note 1) intend to use our Products in devices requiring extremely high reliability (such as medical equipment , transport equipment, traffic equipment, aircraft/spacecraft, nuclear power controllers, fuel controllers, car equipment including car accessories, safety devices, etc.) and whose malfunction or failure may cause loss of human life, bodily injury or serious damage to property (“Specific Applications”), please consult with the ROHM sales representative in advance. Unless otherwise agreed in writing by ROHM in advance, ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of any ROHM’s Products for Specific Applications. or 1. ROHM designs and manufactures its Products subject to strict quality control system. However, semiconductor products can fail or malfunction at a certain rate. Please be sure to implement, at your own responsibilities, adequate safety measures including but not limited to fail-safe design against the physical injury, damage to any property, which a failure or malfunction of our Products may cause. The following are examples of safety measures: [a] Installation of protection circuits or other protective devices to improve system safety [b] Installation of redundant circuits to reduce the impact of single or multiple circuit failure 3. Our Products are designed and manufactured for use under standard conditions and not under any special or extraordinary environments or conditions, as exemplified below. Accordingly, ROHM shall not be in any way responsible or liable for any damages, expenses or losses arising from the use of any ROHM’s Products under any special or extraordinary environments or conditions. If you intend to use our Products under any special or extraordinary environments or conditions (as exemplified below), your independent verification and confirmation of product performance, reliability, etc, prior to use, must be necessary: [a] Use of our Products in any types of liquid, including water, oils, chemicals, and organic solvents [b] Use of our Products outdoors or in places where the Products are exposed to direct sunlight or dust [c] Use of our Products in places where the Products are exposed to sea wind or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [d] Use of our Products in places where the Products are exposed to static electricity or electromagnetic waves [e] Use of our Products in proximity to heat-producing components, plastic cords, or other flammable items [f] Sealing or coating our Products with resin or other coating materials [g] Use of our Products without cleaning residue of flux (even if you use no-clean type fluxes, cleaning residue of flux is recommended); or Washing our Products by using water or water-soluble cleaning agents for cleaning residue after soldering [h] Use of the Products in places subject to dew condensation 4. The Products are not subject to radiation-proof design. 5. Please verify and confirm characteristics of the final or mounted products in using the Products. 6. In particular, if a transient load (a large amount of load applied in a short period of time, such as pulse. is applied, confirmation of performance characteristics after on-board mounting is strongly recommended. Avoid applying power exceeding normal rated power; exceeding the power rating under steady-state loading condition may negatively affect product performance and reliability. 7. De-rate Power Dissipation depending on ambient temperature. When used in sealed area, confirm that it is the use in the range that does not exceed the maximum junction temperature. 8. Confirm that operation temperature is within the specified range described in the product specification. 9. ROHM shall not be in any way responsible or liable for failure induced under deviant condition from what is defined in this document. ot R 2. N e N co ew m m D es en ig de ns d f (Note1) Medical Equipment Classification of the Specific Applications JAPAN USA EU CHINA CLASSⅢ CLASSⅡb CLASSⅢ CLASSⅢ CLASSⅣ CLASSⅢ Precaution for Mounting / Circuit board design 1. When a highly active halogenous (chlorine, bromine, etc.) flux is used, the residue of flux may negatively affect product performance and reliability. 2. In principle, the reflow soldering method must be used on a surface-mount products, the flow soldering method must be used on a through hole mount products. If the flow soldering method is preferred on a surface-mount products, please consult with the ROHM representative in advance. For details, please refer to ROHM Mounting specification Notice-PGA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.003 Precautions Regarding Application Examples and External Circuits If change is made to the constant of an external circuit, please allow a sufficient margin considering variations of the characteristics of the Products and external components, including transient characteristics, as well as static characteristics. 2. You agree that application notes, reference designs, and associated data and information contained in this document are presented only as guidance for Products use. Therefore, in case you use such information, you are solely responsible for it and you must exercise your own independent verification and judgment in the use of such information contained in this document. ROHM shall not be in any way responsible or liable for any damages, expenses or losses incurred by you or third parties arising from the use of such information. Precaution for Electrostatic or 1. e N co ew m m D es en ig de ns d f This Product is electrostatic sensitive product, which may be damaged due to electrostatic discharge. Please take proper caution in your manufacturing process and storage so that voltage exceeding the Products maximum rating will not be applied to Products. Please take special care under dry condition (e.g. Grounding of human body / equipment / solder iron, isolation from charged objects, setting of Ionizer, friction prevention and temperature / humidity control). Precaution for Storage / Transportation 1. Product performance and soldered connections may deteriorate if the Products are stored in the places where: [a] the Products are exposed to sea winds or corrosive gases, including Cl2, H2S, NH3, SO2, and NO2 [b] the temperature or humidity exceeds those recommended by ROHM [c] the Products are exposed to direct sunshine or condensation [d] the Products are exposed to high Electrostatic 2. Even under ROHM recommended storage condition, solderability of products out of recommended storage time period may be degraded. It is strongly recommended to confirm solderability before using Products of which storage time is exceeding the recommended storage time period. 3. Store / transport cartons in the correct direction, which is indicated on a carton with a symbol. Otherwise bent leads may occur due to excessive stress applied when dropping of a carton. 4. Use Products within the specified time after opening a humidity barrier bag. Baking is required before using Products of which storage time is exceeding the recommended storage time period. Precaution for Product Label A two-dimensional barcode printed on ROHM Products label is for ROHM’s internal use only. Precaution for Disposition When disposing Products please dispose them properly using an authorized industry waste company. Precaution for Foreign Exchange and Foreign Trade act Since concerned goods might be fallen under listed items of export control prescribed by Foreign exchange and Foreign trade act, please consult with ROHM in case of export. All information and data including but not limited to application example contained in this document is for reference only. ROHM does not warrant that foregoing information or data will not infringe any intellectual property rights or any other rights of any third party regarding such information or data. ot 1. R Precaution Regarding Intellectual Property Rights ROHM shall not have any obligations where the claims, actions or demands arising from the combination of the Products with other articles such as components, circuits, systems or external equipment (including software). 3. No license, expressly or implied, is granted hereby under any intellectual property rights or other rights of ROHM or any third parties with respect to the Products or the information contained in this document. Provided, however, that ROHM will not assert its intellectual property rights or other rights against you or your customers to the extent necessary to manufacture or sell products containing the Products, subject to the terms and conditions herein. N 2. Other Precaution 1. This document may not be reprinted or reproduced, in whole or in part, without prior written consent of ROHM. 2. The Products may not be disassembled, converted, modified, reproduced or otherwise changed without prior written consent of ROHM. 3. In no event shall you use in any way whatsoever the Products and the related technical information contained in the Products or this document for any military purposes, including but not limited to, the development of mass-destruction weapons. 4. The proper names of companies or products described in this document are trademarks or registered trademarks of ROHM, its affiliated companies or third parties. Notice-PGA-E © 2015 ROHM Co., Ltd. All rights reserved. Rev.003
KX222-1054 价格&库存
很抱歉,暂时无法提供与“KX222-1054”相匹配的价格&库存,您可以联系我们找货
