FLOWLED-3820
FLOWLED-3820
    WAKEFIELD-VETTE
FLOWLED-3820 数据手册
LED Heat Sinks FLOWLED Heat Sink Features: • • • • Thermal resistance range Rth(7.69°C/W; 5.0°C/W; 4.17°C/W). Radial design with mounting holes foreseen for direct mounting of a wide range of LED modules and COB’s: Diameter 48mm -110mm Extruded from highly conductive aluminum. Black anodized Compatible with: • • • • • • • • • • • • • • • • • Xicato XSM, XIM,XTM; Bridgelux ESS, ESR, Vero 10, Vero 13,Vero 18 V-series; Citizen CLL022-CLU024, CLL032-CLU034; Cree XLamp CXA13xx, CXA15xx,CSA18xx; Lumileds Luxeon COB's 1203, 1204, 1205, Luxeon K arrays K12, K16; Osram PrevaLED Core,SOLERIQ P and SOLERIQ S LED engines. Seoul Semiconductor ZC6, ZC12, ZC18,ZC25; Tridonic TALEXXmodule SLE modules; LG Innotek LEMWM18 10W, 13W, 17W Edison EdiLex SLM and EdiLex II COB LED engines. Lustrous LUSTRON 6 series LL604F, LL608D, LL613F, LL620F Prolight Opto PABS, PABA, PACB, PANA Samung LC013,LC019,LC026 COB LED engines. SHARP Mini Zenigata Intermo and Mega Zenigata LED engines. Philips Fortimo SLM LED engines. Vossloh-Schwabe LUGA Shop LED engines. Luminus C##9,C##14 LED engines. www.wakefield-vette.com LED Heat Sinks FLOWLED Heat Sink WKV Part Number Description Height (mm) FLOWLED-3820 Flow LED Heat Sink 38MM DIA 20H 20 FLOWLED-3850 Flow LED Heat Sink 38MM DIA 50H 50 *Note: All Bases Have no Holes Thermal Data FLOWLED-3820 Thermal Data FLOWLED-3850 38mm Diameter Diameter (mm) 38 38 Max. Lumen (lm) 630 980 Dissipated Power (W) 4.5 7 Thermal Resistance( °C/W) 7 11.4 Weight (g) 24 60.9 LED Heat Sinks FLOWLED Heat Sink WKV Part Number FLOWLED-7040 FLOWLED-7080 Description Flow LED Heat Sink 70MM DIA 40H Flow LED Heat Sink 70MM DIA 80H Height (mm) 40 80 *Note: All Bases Have no Holes Thermal Data FLOWLED-7040 Thermal Data FLOWLED-7080 70mm Diameter Diameter (mm) 70 70 Max. Lumen (lm) 2700 3200 Dissipated Power (W) 19.6 23 Thermal Resistance( °C/W) 2.3 1.9 Weight (g) 183 294 LED Heat Sinks FLOWLED Heat Sink WKV Part Number FLOWLED-8540 FLOWLED-8560 Description Flow LED Heat Sink 85MM DIA 40H Flow LED Heat Sink 85MM DIA 60H 85mm Diameter Height (mm) 40 60 *Note: All Bases Have no Holes Thermal Data FLOWLED-8540 Thermal Data FLOWLED-8560 Diameter (mm) 85 85 Max. Lumen (lm) 3600 4440 Dissipated Power (W) 26 32 Thermal Resistance( °C/W) 1.9 1.6 Weight (g) 249 398 LED Heat Sinks FLOWLED Heat Sink WKV Part Number FLOWLED-9650 FLOWLED-9680 Description Flow LED Heat Sink 96MM DIA 50H Flow LED Heat Sink 96MM DIA 90H Height (mm) 50 80 *Note: All Bases Have no Holes Thermal Data FLOWLED-9650 Thermal Data FLOWLED-9680 96mm Diameter Diameter (mm) 96 96 Max. Lumen (lm) 4400 5600 Dissipated Power (W) 32 40 Thermal Resistance(°C/W) 1.5 1.2 Weight (g) 312 499
FLOWLED-3820 价格&库存
很抱歉,暂时无法提供与“FLOWLED-3820”相匹配的价格&库存,您可以联系我们找货
