TS9013SCW RPG
TS9013SCW RPG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT223-4
TS9013SCW RPG 数据手册
TS9013 Taiwan Semiconductor 500mA Low Quiescent Current CMOS LDO FEATURES TS9013 is a positive voltage regulator developed utilizing CMOS technology featured very low power consumption, low dropout voltage and high output voltage accuracy. Built in low on-resistor provides low dropout voltage and large output current. A 2.2µF or greater can be used as an output capacitor.TS9013 are prevented device failure under the worst operation condition with both thermal shutdown and current foldback. These series are recommended for configuring portable devices and large current application, respectively. ● Output current up to 500mA ● Low power consumption, 15µA(typ.) @VO=5V ● Output voltage ±2% ● Internal current limit ● ● Thermal shutdown protection Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC. Halogen-free according to IEC 61249-2-21 TS 9 TS 01 3 9 No 01 5C t R 3SC W e co W R P mm R P G G en de d DESCRIPTION ● APPLICATION ● ● ● ● ● ● SOT-89 Pin Definition: 1. Ground 2. Input 3. Output Palmtops Video recorders Battery powered equipment PC peripherals CD-ROM, DVD ROM Digital signal camera SOT-223 Pin Definition: 1. Input 2. Ground 3. Output TYPICAL APPLICATION CIRCUIT 1 Version: I1608 TS9013 Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Input Supply Voltage VIN 12 V Recommend Operating Input Voltage VIN 10 V Output Current Io 500 mA 0.5 SOT-89 Power Dissipation (without heat sink) PD SOT-223 TJ -40 ~ +150 °C TSTG -65 ~ +150 °C 5 S TS 9 TS 01 3 9 No 01 5C t R 3SC W e co W R P mm R P G G en de d Operating Junction Temperature Range W 0.7 Storage Temperature Range o Lead Soldering Temperature (260 C) Notes: Stress above the listed absolute rating may cause permanent damage to the device. ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS MIN TYP MAX TS90135 4.90 5.0 5.10 VIN=VO + 1V, TS9013S 3.23 3.3 3.36 Io =1mA, TS9013K 2.45 2.5 2.55 TS9013D 1.76 1.8 1.83 TS90135 4.85 5.0 5.10 VIN=VO + 1V, TS9013S 3.20 3.3 3.36 IO =1mA ~ 500mA TS9013K 2.42 2.5 2.55 TS9013D 1.74 1.8 1.83 500 -- -- mA -- 0.2 0.3 % -- 40 80 Output Voltage Maximum Output Current VIN=VO+1V, Input Stability VO+1V ≤ VIN ≤ VO+2V, IO=1mA Load Regulation (Note1) VIN=VO+1V, TS90135 1mA ≤ IL ≤ 500mA TS9013S VIN=VO+1V, TS9013K 1mA ≤ IL ≤ 500mA TS9013D IO=300mA Dropout Voltage (Note 2) IO=500mA IO=500mA Quiescent Current VIN=VO+1V, IO=0A Output Current Limit VOUT < 0.4V Power Supply Rejection Ratio TS90135 TS9013S TS90135 TS9013S TS9013K TS9013D At f=100KHz, IO=10mA Output Voltage Temperature Coefficient UNIT V V mV -- 40 90 -- 300 500 -- 500 600 -- 600 850 -- 15 25 μA 550 -- -- mA -- 30 -- dB -- 100 -- ppm/°C mV Note: 1. Regulation is measured at constant junction temperature, using pulsed ON time. 2. Dropout is measured at constant junction temperature, using pulsed ON time, and the criterion is VOUT inside target value +/3%. 2 Version: I1608 TS9013 Taiwan Semiconductor ORDERING INFORMATION OUTPUT VOLTAGE 1.8V 2.5V PACKAGE PACKING TS9013DCW RPG SOT-223 2,500pcs / 13” Reel TS9013DCY RMG SOT-89 1,000pcs / 7” Reel TS9013KCW RPG SOT-223 2,500pcs / 13” Reel TS9013SCW RPG SOT-223 2,500pcs / 13” Reel TS9013SCY RMG SOT-89 1,000pcs / 7” Reel TS 9 TS 01 3 9 No 01 5C t R 3SC W e co W R P mm R P G G en de d 3.3V PART NO. 5V TS90135CW RPG SOT-223 3 2,500pcs / 13” Reel Version: I1608 TS9013 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TS 9 TS 01 3 9 No 01 5C t R 3SC W e co W R P mm R P G G en de d SOT-89 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr ` V =Aug S =May T =Jun U =Jul Y =Nov Z =Dec W =Sep X =Oct L = Lot Code (1~9, A~Z) X = Fixed Output Voltage Code 18=1.8V, 33=3.3V, 50=5.0V.. 4 Version: I1608 TS9013 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TS 9 TS 01 3 9 No 01 5C t R 3SC W e co W R P mm R P G G en de d SOT-223 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr ` V =Aug S =May T =Jun U =Jul Y =Nov Z =Dec W =Sep X =Oct L = Lot Code (1~9, A~Z) X = Fixed Output Voltage Code 18=1.8V, 25=3.3V, 33=3.3V, 50=5.0V.. 5 Version: I1608 TS9013 TS 9 TS 01 3 9 No 01 5C t R 3SC W e co W R P mm R P G G en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I1608
TS9013SCW RPG 价格&库存
很抱歉,暂时无法提供与“TS9013SCW RPG”相匹配的价格&库存,您可以联系我们找货
