AMM-2738-B-R
AMM-2738-B-R
    PUIAUDIO
AMM-2738-B-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Data Sheet AMM-2738-B-R Specifications Parameters Sensitivity (1 kHz @ 50cm) 0 dB=1V/Pa Rated Voltage Operating Voltage Range Output Impedance (@ 1 kHz) Current consumption (at 2 VDC/at 3.6 VDC) Signal-to-Noise Ratio (1kHz, 94 dB input, A-weighted) Decreasing Voltage (0 dB=1V/Pa, 3.6 to 1.5 VDC) Frequency Range Total Harmonic Distortion (94 dB @ 50cm, 1 kHz) Acoustic Overload Point (AOP) (50cm, 1kHz, 10% THD) Directivity Acceptable Soldering Methods Environmental Compliances Power Supply Rejection (PSR, 100 mVpp Square Wave @ 217 Hz, A-weighted) Weight Operating Temperature (VDD < 3 VDC) Operating Temperature (VDD > 3 VDC) Storage Temperature MSL (Moisture Sensitivity Level)* Values Units -38 ±1 2 1.5 to 3.6 300 dB VDC VDC Ω 130/150 µA 64 dB 0.5 20 – 20,000 dB Hz 0.5% - 123 dB Omnidirectional See page 4 for soldering Reflow Solder information RoHS/Halogen Free -98
AMM-2738-B-R 价格&库存
很抱歉,暂时无法提供与“AMM-2738-B-R”相匹配的价格&库存,您可以联系我们找货
AMM-2738-B-R
  • 1250+8.233871250+1.06527
  • 2500+7.674942500+0.99296
  • 3750+7.392203750+0.95638
库存:103
AMM-2738-B-R
  • 1+15.892481+2.05612
  • 10+12.4631710+1.61245
  • 25+11.3401325+1.46715
  • 50+10.5671750+1.36715
  • 100+9.85569100+1.27510
  • 250+9.04824250+1.17063
库存:103
