SS38C
SS38C
    JINGDAO(晶导微电子)
    SMC(DO-214AB)
SS38C 数据手册
山东晶导微电子股份有限公司 SS32C THRU SS320C Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200 V Forward Current - 3 A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 2 1 Top View Marking Code: SS32 ~ SS320 Simplified outline SMC and symbol MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols SS32C SS34C SS36C SS38C SS310C SS312C SS315C SS320C Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) 3.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 80 A Max Instantaneous Forward Voltage at 3 A VF Maximum DC Reverse Current T a = 25°C T a =100°C IR 0.5 5 0.3 3 mA Typical Junction Capacitance(1) Cj 450 350 pF Typical Thermal Resistance (2) RθJA 50 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C at Rated DC Reverse Voltage Operating Junction Temperature Range Storage Temperature Range 0.55 0.70 0.85 0.95 V (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.04 SMC-S-SS32C~SS320C-3A200V Page 1 of 3 山东晶导微电子股份有限公司 SS32C THRU SS320C Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics 3.5 3.0 2.4 1.8 1.2 0.6 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Average Forward Current (A) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 T J =75°C 10 2 SS32C/SS36C T J =25°C 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1.0 SS32C/SS34C SS36C/SS38C SS310C/SS312C SS315C/SS320C 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 200 100 20 SS32C~SS36C SS38C~SS320C 10 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 100 80 60 40 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 500 1.8 120 10 1000 Instaneous Forward Voltage (V) 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 100 Number of Cycles 2017.04 SS38C~SS320C 10 1 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 SS32C THRU SS320C Jingdao Microelectronics co.LTD PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) 2017.04 706305B0 Type number Marking code SS32C SS32 SS34C SS34 SS36C SS36 SS38C SS38 SS310C SS310 SS312C SS312 SS315C SS315 SS320C SS320 Page 3 of 3
SS38C
物料型号:SS32C至SS320C系列。
器件简介:表面贴装肖特基势垒整流器,适用于表面贴装应用,具有低功耗、高效率,高正向浪涌电流能力,适用于低电压、高频逆变器、自由轮转和极性保护应用。
引脚分配:2引脚,1为阴极,2为阳极。
参数特性: - 最大重复峰值反向电压(VRRM):20V至200V。 - 最大RMS电压(VRMS):70V至140V。 - 最大直流阻断电压(VDC):150V。 - 最大平均正向整流电流(IF(AV)):3.0A。 - 正向浪涌电流(IFSM):0.55A至0.85A。 - 最大瞬时正向电压(VF):0.95V至0.3V。 - 最大直流反向电流(IR):5mA至100mA。
功能详解:器件为金属硅结,主要载流子导电,适用于低电压、高频逆变器、自由轮转和极性保护。
应用信息:用于低电压、高频逆变器、自由轮转和极性保护。
封装信息:塑料表面贴装封装,2引线,标记代码为SS32至SS320。
SS38C 价格&库存
很抱歉,暂时无法提供与“SS38C”相匹配的价格&库存,您可以联系我们找货
SS38C
  • 1+0.59180
  • 200+0.40810
  • 1500+0.37070
  • 3000+0.34650
库存:10
SS38C
    • 1+0.58600
    库存:5
