NTC Thermistor
Features
This is a Negative Temperature Coefficient Resistor Whose resistance
changes with ambient temperature changes. Thermistor comprises 2 or 4
kinds of metal oxides of iron, nickel,cobalt, manganese and copper, being
shaped and Sintered at high temperature(1200℃ to 1500℃ )
Critical Technical Parameters of NTC Thermistor
* Rt---Resistance Value at Zero-power
It's a resistance which is got at a fixed temperature on a basis of a testing
power which causes resistance to Vary in a range which can be ignored in
relation to the total testing eror.
* R25---Resistance Value at Rated Zero-power
The design resistance of the thermistor usually refers to the resistance value got at Zero-power at 25℃ , which is usually
indicated on the thermistor.
* Max. steady state current.Imax.
The maximum allowable continuous current passing through thermistor at 25℃.
* Dissipation Coefficient δ
It's the ratio of the changes with a thermistor dissipation power, in a pre-set ambient temperature, to the changes with the
temperature. The formula is as below:δ = △P/ △T ,δ changes in response when the ambient temperature changes, within the
ranges of the working temperature.
Applications
Conversion power supply, switch power, UPS power, Kinds of electric heter, electronic energy-saving lamps, electronic ballast
etc all kinds of power cicuit proterction of electronic equipments, filament proterction of CRT, bulb and other lighting lamps.
Part Numbering System
NTC
Cofficient Resistor
10
D-13
Resistance Value:10Ω
Diameter of Chip: Φ13
Circuit Protection
System
Specifications are subject to change without notice.
Page:1
NTC Thermistor
Electriacl Characteristics
Thermal
Time
Constant
Operating
Temperature
Range
Ω
A
mW/°C
Sec
°C
6.5max
5D-5
5
1
6
-55 ~ +200
10D-5
10
0.7
6
-55 ~ +200
60D-5
60
0.3
6
18
-55 ~ +200
200
0.1
5D-7
5
2
6
18
-55 ~ +200
10
28
-55 ~ +200
D-7 Series Sensing NTC Thermistor
5±1
8D-7
8
1
9
27
-55 ~ +200
10
1
9
27
-55 ~ +200
12D-7
12
1
9
27
-55 ~ +200
16D-7
16
0.7
9
27
-55 ~ +200
22D-7
22
0.6
9
27
-55 ~ +200
33D-7
33
0.5
10
28
-55 ~ +200
200D-7
200
0.2
11
28
-55 ~ +200
5±1
0.6/0.5
8.5max
10D-7
5±1
5max
6.5max
25
D-5 Series Sensing NTC Thermistor
200D-5
Package Dimensions
(mm)
25
Thermal
Dissipation
Constant
0.6/0.5
5.5max
8.5max
25
Max.Steady
State
Current
At 25°C
25
Type Number
Zero Power
Resistance
At 25°C
5±1
0.6±0.1
0.6±0.1
D-9 Series Sensing NTC Thermistor
4
11
35
-55 ~ +200
3
11
35
-55 ~ +200
5D-9
5
3
11
34
-55 ~ +200
6D-9
6
2
11
34
-55 ~ +200
8D-9
8
2
11
32
-55 ~ +200
9D-9
9
2
11
32
-55 ~ +200
10D-9
10
1
11
32
-55 ~ +200
12D-9
12
1
11
32
-55 ~ +200
16D-9
16
1
11
31
-55 ~ +200
20D-9
11
30
-55 ~ +200
22D-9
22
1
11
30
-55 ~ +200
30D-9
30
1
11
30
-55 ~ +200
33D-9
33
1
11
30
-55 ~ +200
50D-9
50
1
11
30
-55 ~ +200
60D-9
60
0.8
11
30
-55 ~ +200
80D-9
80
0.8
11
30
-55 ~ +200
120D-9
120
0.8
11
30
-55 ~ +200
200D-9
200
0.5
11
32
-55 ~ +200
400D-9
400
0.2
11
32
-55 ~ +200
Circuit Protection
System
10.5max
7.5/5
5.5max
10.5max
0.6±0.1
7.5/5
25
3
4
25
3D-9
4D-9
0.6±0.1
Page:2
NTC Thermistor
Type Number
Zero Power
Resistance
At 25°C
Max.Steady
State
Current
At 25°C
Thermal
Dissipation
Constant
Thermal
Time
Constant
Operating
Temperature
Range
Ω
A
mW/°C
Sec
°C
Package Dimensions
(mm)
D-11 Series Sensing NTC Thermistor
5
13
43
-55 ~ +200
3D-11
3
5
13
43
-55 ~ +200
4D-11
4
4
13
44
-55 ~ +200
5D-11
5
4
13
45
-55 ~ +200
6D-11
6
3
13
45
-55 ~ +200
8D-11
8
3
14
47
-55 ~ +200
10D-11
10
3
14
47
-55 ~ +200
12D-11
12
2
14
48
-55 ~ +200
16D-11
16
2
14
50
-55 ~ +200
20D-11
15
52
-55 ~ +200
22D-11
22
2
15
52
-55 ~ +200
30D-11
30
1.5
15
52
-55 ~ +200
33D-11
33
1.5
15
52
-55 ~ +200
50D-11
50
1.5
15
52
-55 ~ +200
60D-11
60
1.5
15
52
-55 ~ +200
80D-11
80
1.2
15
52
-55 ~ +200
120D-13
120
1.2
16
65
-55 ~ +200
12.5max
5.5max
12.5max
7.5/5
0.8±0.05
25
2.5
25
2.5D-11
7.5/5
0.8±0.05
D-13 Series Sensing NTC Thermistor
7
13
60
-55 ~ +200
1.5
7
13
60
-55 ~ +200
2.5D-13
2.5
6
13
60
-55 ~ +200
3D-13
3
6
14
60
-55 ~ +200
4D-13
4
5
15
67
-55 ~ +200
5D-13
5
5
15
68
-55 ~ +200
6D-13
6
4
15
65
-55 ~ +200
7D-13
7
4
15
65
-55 ~ +200
8D-13
8
4
15
60
-55 ~ +200
10D-13
10
4
15
65
-55 ~ +200
12D-13
12
3
16
65
-55 ~ +200
15D-13
15
3
16
60
-55 ~ +200
16D-13
16
3
16
60
-55 ~ +200
20D-13
16
65
-55 ~ +200
30D-13
30
2.5
16
65
-55 ~ +200
47D-13
47
2
17
65
-55 ~ +200
120D-13
120
1.2
16
65
-55 ~ +200
Circuit Protection
System
14.5max
7.5/5
6max
14.5max
0.8±0.05
7.5/5
25
1.3
1.5D-13
25
1.3D-13
0.8±0.05
Page:3
NTC Thermistor
Type Number
Zero Power
Resistance
At 25°C
Max.Steady
State
Current
At 25°C
Thermal
Dissipation
Constant
Thermal
Time
Constant
Operating
Temperature
Range
Ω
A
mW/°C
Sec
°C
Package Dimensions
(mm)
D-15 Series Sensing NTC Thermistor
8
18
68
-55 ~ +200
1.5D-15
1.5
8
18
69
-55 ~ +200
3D-15
3
7
18
76
-55 ~ +200
5D-15
5
6
-55 ~ +200
6D-15
6
5
-55 ~ +200
7D-15
7
5
-55 ~ +200
8D-15
8
5
-55 ~ +200
10D-15
10
5
-55 ~ +200
12D-15
12
5
21
75
-55 ~ +200
15D-15
15
4
21
85
-55 ~ +200
16D-15
16
4
21
70
-55 ~ +200
20D-15
21
86
-55 ~ +200
30D-15
30
3
21
75
-55 ~ +200
47D-15
47
3
21
86
-55 ~ +200
120D-15
120
1.8
22
87
-55 ~ +200
0.7D-20
0.7
11
24
89
-55 ~ +200
1.3D-20
1.3
9
24
88
-55 ~ +200
3D-20
3
8
24
88
-55 ~ +200
5D-20
5
7
24
87
-55 ~ +200
6D-20
6
6
25
103
-55 ~ +200
16.5max
7max
16.5max
7.5±0.1
25
1.3
25
1.3D-15
7.5±0.1
0.8±0.05
0.8±0.05
D-20 Series Sensing NTC Thermistor
105
-55 ~ +200
102
-55 ~ +200
12D-20
12
5
25
100
-55 ~ +200
16D-20
16
5
25
100
-55 ~ +200
D-25 Series Sensing NTC Thermistor
1D-25
1
12
30
120
-55 ~ +200
1.5D-25
1.5
10
30
121
-55 ~ +200
3D-25
3
9
32
124
-55 ~ +200
5D-25
5
8
32
125
-55 ~ +200
8D-25
8
7
33
125
-55 ~ +200
10D-25
10
7
32
125
-55 ~ +200
12D-25
12
6
32
126
-55 ~ +200
16D-25
16
6
35
126
-55 ~ +200
Circuit Protection
System
7.5/10
7.5/10
1.0±0.05
26.5max
10
25
25
25
1.0±0.05
8max
26.5max
0.8
10
25
6
6
25
8
10
7max
22max
25
8D-20
10D-20
22max
0.8
Page:4
很抱歉,暂时无法提供与“NTC 1.5D-15”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.11653
- 50+1.68233
- 250+1.35115
- 500+1.11896
- 2500+1.01554
- 5000+0.95357
- 国内价格
- 1+1.13300
- 50+0.87120
- 250+0.80300
