IP804A
IP804A
    ICPLUS(九阳电子)
    QFN48_EP
IP804A 数据手册
IP804A Preliminary Datasheet 4-Port PSE Controller for PoE Systems Features „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ „ IEEE 802.3AF-2003 and 802.3AT-2009 compliant Single DC power supply voltage input (45~57V) Wide temperature range: -40℃~+85℃ Supplies 4 independent power ports Built-in power FETs I2C Bus to access up to 8 x IP804A devices Continuous system monitoring for every port Independent system parameters setting for every port Thermal monitoring and protection Built-in 3.3V regulators for external devices Built-in Power on Reset Configurations: (1) 30W x 4 ports Total Current Limit Built-in LEDs control Built-in EEPROM interface for dumb application Package and operation temperature 48 Pin(7mmx7mm) MQFN, -40~85℃ Application „ „ General Description 4 port PSE Switch 8 port PSE Switch IP804A is an 4-port PSE (Power Sourcing Equipment) controller IC for PoE (Power over Ethernet) systems. It integrates power, analog and logic circuits into a single chip, and can be used for Midcap and Endpoint PSE applications. IP804A meets all IEEE 802.3AF-2003 requirements, such as multi-point resistor detection, PD classification, DC Disconnect, and Back-off for Midcap. It also meets all IEEE 802.3AT-2009 requirements, such as two-event classification and supply maximum 36W per port. IP804A comprises internal temperature monitoring and thermal protection to protect against junction overheating. The 3.3V regulator is built-in to support external devices. Multiple IP804As can integrate to build an 4 x N ports PSE system, and I2C bus uses to collect PD power status from each IP804A to support global power managements. Multiple IP804As can build a cost effective PHY level PSE system to support PD classification and power management without a host. With a management host, a networked LLDP (Link Layer Discovery Protocol) based multiple IP804As PSE system can be built. Based on LLDP (part of IEEE Std 802.3AT-2009), dynamic power management between PSE and PD can be maintained in real time for power efficiency. Management switch host has options to communicate IP804As via I2C bus for PSE management activities. Opt couplers can be implemented to provide electrical isolations between the host and IP804As for signal communication. 1 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Table of Contents Features ................................................................................................................................................................................. 1 General Description .............................................................................................................................................................. 1 Table of Contents .................................................................................................................................................................. 2 List of Figures ........................................................................................................................................................................ 3 List of Tables .......................................................................................................................................................................... 3 Revision History..................................................................................................................................................................... 4 1 Pin diagram ..................................................................................................................................................................... 5 1.1 IP804A Pin diagram (MQFN48) ................................................................................................ 5 2 IP804A application diagram .......................................................................................................................................... 6 2.1 Dumb & Smart device application ............................................................................................. 6 3 Block diagram ................................................................................................................................................................. 7 3.1 Blocks Description ..................................................................................................................... 8 3.1.1 Global Blocks ................................................................................................................. 9 3.1.2 Per Port Block .............................................................................................................. 10 4 Pin description ............................................................................................................................................................... 11 5 Functional Description..................................................................................................................................................13 5.1 System Reset .......................................................................................................................... 13 5.2 Operation Modes & System Configuration ............................................................................. 14 5.3 I2C Slave Interface .................................................................................................................. 16 5.4 EEPROM controller ................................................................................................................. 18 5.5 PSE State Machine ................................................................................................................. 19 5.6 Power Manager ....................................................................................................................... 22 5.6.1 Power Trunks ............................................................................................................... 22 5.6.2 Power Configuration .................................................................................................... 22 5.6.3 Port Polling................................................................................................................... 25 5.6.4 Power Event Handling ................................................................................................. 26 5.7 Real time Monitor Power Event .............................................................................................. 27 5.8 Port Status and Interrupt ......................................................................................................... 28 5.9 Total Current Limit ................................................................................................................... 30 5.10 LED Interface .......................................................................................................................... 31 6 IP804A Register descriptions ......................................................................................................................................34 7 Electrical Characteristics..............................................................................................................................................38 7.1 Absolute Maximum Ratings .................................................................................................... 38 7.2 Operating Conditions .............................................................................................................. 38 7.3 Electrical Characteristics for Analog I/O Pins ......................................................................... 38 7.4 IEEE802.3 AF/AT Mode Parameters ...................................................................................... 39 7.5 Digital Electrical Characteristics.............................................................................................. 42 7.6 AC Timing ................................................................................................................................ 43 7.6.1 Power On Sequence and Reset Timing ...................................................................... 43 7.6.2 EEPROM Timing .......................................................................................................... 44 7.6.2.1 Data read cycle .................................................................................................. 44 7.6.2.2 Command cycle ................................................................................................. 44 7.6.3 I2C Timing .................................................................................................................... 45 7.6.3.1 Data read cycle .................................................................................................. 45 7.6.3.2 Command cycle ................................................................................................. 45 7.7 Thermal Data ........................................................................................................................... 45 8 Order Information..........................................................................................................................................................46 9 Package Detail ..............................................................................................................................................................47 9.1 48 MQFN Outline Dimensions (in mm) ................................................................................... 47 2 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet List of Figures Figure 1 Figure 2 Figure 3 Figure 4 Figure 5 Figure 6 Figure 7 Figure 8 Figure 9 Figure 10 Figure 11 Figure 12 Figure 13 Pin Diagram ............................................................................................................... 5 Application Diagram .................................................................................................. 6 Block Diagram ........................................................................................................... 7 I2C bus read/write cycles diagram ........................................................................... 16 EEPROM Format ..................................................................................................... 18 LED behavior and system diagram of multiple IP804A application ........................ 33 Typical Power up Sequence .................................................................................... 40 Power on Sequence and Reset Timing Diagram .................................................... 43 EEPROM Read Cycle Timing Diagram ................................................................... 44 EEPROM Command Cycle Timing Diagram........................................................... 44 I2C Read Cycle Timing Diagram .............................................................................. 45 I2C Command Cycle Timing Diagram ..................................................................... 45 Package Outline Dimensions .................................................................................. 47 List of Tables Table 1 Table 2 Table 3 Table 4 Table 5 Table 6 Table 7 Table 8 Table 9 Table 10 Pin description ............................................................................................................. 11 Mode Setting ............................................................................................................... 15 Available functions in Operation modes...................................................................... 15 Port power off conditions ............................................................................................. 27 Register Page 0 description ........................................................................................ 34 Register Page 1 description ........................................................................................ 36 Electrical Characteristics ............................................................................................. 38 IEEE802.3 AF/AT Mode Parameters ........................................................................... 39 Digital Electrical Characteristics .................................................................................. 42 Order Information ...................................................................................................... 46 3 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Revision History Revision # IP804A-DS-R01 Date 2017/05/02 Change Description Initial release 4 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 1 Pin diagram 1.1 IP804A Pin diagram (MQFN48) AD0 AD1 AD2 RstN DV3P3 DGND INITB SDAI/EE_DAT SDAO SCL/EE_CLK LED_DAT LED_CLK 48 47 46 45 44 43 42 41 40 39 38 37 (7mm X 7mm Top view) AGND 1 36 AGND RS0 2 35 AGND PortN0 3 34 AGND RS1 4 33 AGND PortN1 AGND 5 32 AGND 31 AGND RS2 7 30 AGND PortN2 8 29 AGND RS3 9 28 AGND PortN3 10 27 AGND AGND AGND 11 26 AGND 12 25 AGND 6 Exposed PAD (Ground) 17 18 19 20 21 22 23 24 RGND V54 AGND V5 V3P3 V2P5 VPP In_Top EnB_Reg SCAN1 VRext SCAN0 16 14 15 13 Exposed pad is system GND, must be soldered to PCB ground plane Figure 1 Pin Diagram 5 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 2 IP804A application diagram 2.1 Dumb & Smart device application Switch PA0+~PA3+ Diode V54 C PA0- Port N0 SCAN1 Operation Mode Transformer Transformer 44~57V Power input FUSE SCAN0 0.5 ohm IP804A TVS RS0 LED_CLK LED LED_DAT PA3- Port N3 SCL/EE_CLK SDAI/EE_DAT EEPROM SDAO RJ45 RS3 TP cable RJ45 TP cable MCU Power Device 2 I C Bus Power Device Options for Smart Application Figure 2 Application Smart MCU V Dumb X Application Diagram EEPROM X V: update default value X: use default value IP804A Mode setting Manual mode Reference Section 5.3 Auto mode Section 5.4 V: necessary; X: unnecessary 6 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 3 Block diagram RGND Vrext EnB_Reg V3P3 V5 AD0 AD1 AD2 SCL/EE_CLK SDAI/EE_DAT SDAO INTB VPP AGND V54 Port3 Port1 Reference & Regulator Port0 2 IC Interface Registers Detection Amp AGND RstN SCAN0 SCAN1 DV3P3 V2P5 DGND Control Management & State Machine Classification T Sensor & Thermal Shutdown PortN0 ︴ Power Management 10 Bits ADC Bias PortN3 I/V Control DC Disconnect LED_DAT LED_CLK LED Control POR & OSC AGND RS3 RS0 AGND Figure 3 Block Diagram 7 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 3.1 Blocks Description The blocks of IP804A include global blocks for and per port blocks as below: Global blocks for 4 ports: ‹ Reference & Regulator 2 ‹ I C Interface ‹ Registers ‹ Control Management & State Machine ‹ Power Management ‹ 10 Bits ADC ‹ POR & OSC Per port blocks for individual port: ‹ Detection ‹ Classification ‹ I/V Control & Fold-back ‹ Amp ‹ DC Disconnect ‹ T sensor & Thermal Shutdown ‹ Bias ‹ Power MOSFET 8 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 3.1.1 Global Blocks ¾ Reference & Regulator: The Reference & Regulator generates 2.5V, 3.3V and 5V power for internal use and 3.3V power also can supply typical 6mA current on V3P3 pin for external devices if EnB_Reg pin is connected to GND. If EnB_Reg is conncted to 3.3V, the internal 3.3V regulator is disabled and V3P3 pin should be connected to an external 3.3V power source. It also generates 1.25V voltage on VREXT pin, which is connected to ground through an external 62KΩ resistor, to generate internal bias current. ¾ Registers: The “Registers” provides the 8 bits data for Ilim, Icut programming registers, and all other needing registers per port ¾ Control Management & State Machine: This block provides all the control procedures to perform PoE function. The “State Machine” implements as specified in the IEEE802.3AF/AT. ¾ Power Management: The “Power Management” provides power management method to meet PD power requirement, or not to power PD if power is not enough. ¾ 10 Bits ADC: The 10 Bits ADC used to convert analog signals into digital bus for Control Management, State Machine, and Power Management for request. ¾ POR & OSC: The POR generates an internal power on reset signal when V54 is power on. The POR also monitors V3P3, DV3P3, V5, & V54 voltage level. If these voltages level are below specific thresholds, a reset signal generates and resets IP804A. The OSC is an internal oscillator to generate 8MHz clock for IP804A timing source. ¾ I2C Interface: A host (master) can communicates with multiple IP804A (slave) via I2C Interface (SCL/EE_CLK, SDAO, SDAI/EE_DAT) to collect PD power status to support global power managements and all control requirements. 9 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 3.1.2 Per Port Block ¾ Detection: The IP804A uses 4 points detection method to discover PD. It shall accepted resistance as a valid “AF/AT PD” between 19KΩand 26.5KΩ, with a paralleled capacitance small than 0.15uF. It shall rejects resistance with paralleled capacitance as an invalid “AF/AT PD” small than 15KΩ, larger than 33KΩ, or capacitance larger than 10uF. The specification is as specified in the IEEE802.3AF/AT. ¾ Classification: The “Classification” is to distinguish the requested power of PD as specified in the IEEE802.3AF/AT. In IEEE 802.3AF, classification is 1-event method. In IEEE 802.3AT, classification is 2-event method. ¾ I/V Control: The “I/V Control” is to control the slew rate during “detection, classification, inrush, short circuit, power off … and so on”, as specified in IEEE802.3AF/AT When short circuit event occurs, the “I/V control” will reduce the port current instantaneously to protect the power MOSFET from damages. ¾ Amp: The “AMP” is used to convert the differential voltage between V54 and PortNx into single end voltage. This voltage will be fed into the “Detection, Classification, I/V Control” blocks to perform the IEEE8023AF/AT specifications. ¾ DC Disconnect: The IP804A supports DC Disconnect function according to IEEE 802.3AF-2003 & IEEE 802.3AT-2009 requirement. This DC Disconnect continuously monitors port current after port inrush time, and disconnects port current when port current is below 7.5mA (typical) for more than 360ms (typical) .Please refer to Tmpdo in table 8 for detail information. ¾ T sensor & Thermal Shutdown: The “T sensor” senses the temperature of each port, and will shutdown the port current as temperature beyond 150℃. When temperature goes down to 129℃, the port will start again. ¾ Bias: The “Bias” provides the current & voltage bias for all ports according to control signals. 10 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 4 Pin description Type Description Type Description P Power or Ground O Output I Input OD Open drain IL Input reset NC No connection in internal latched upon Table 1 Pin description Pin no. Label Type Description Exposed pad, it should be connected to AGND. Analog ground Port0 current sensing voltage input It should be connected to AGND through a 0.5Ω±1% resistor. Port0 negative feeding voltage input. Port1 current sensing voltage input It should be connected to AGND through a 0.5Ω±1% resistor. Port1 negative feeding voltage input. Analog ground Port2 current sensing voltage input It should be connected to AGND through a 0.5Ω±1% resistor. Port2 negative feeding voltage input. Port0 current sensing voltage input It should be connected to AGND through a 0.5Ω±1% resistor. Port0 negative feeding voltage input. Analog ground Analog ground Operation mode, please refer to section 5.2 table 2 for more detail information. Operation mode, please refer to section 5.2 table 2 for more detail information. It should be connected to AGND for normal operation. Connecting to RGND through a 62KΩ±1% resistor, it is for internal bias only. Low noise analog reference ground, it should be connected to AGND. Main power supply input for chip A 4.7uF capacitor should be added between V54 and AGND. Analog ground Internal 5V generation for internal use only. A 4.7uF capacitor should be added between V5 and AGND. When EnB_Reg is connected to AGND, the built-in 3.3v regulator is active, and besides IP804A itself, V3P3 can provide 3.3v (6mA) for external device. When EnB_Reg is connected to 3.3v, V3P3 should be connected to an external power 3.3V (6mA minimum) for IP804A. A 4.7uF capacitor should be added between V3P3 and AGND. Enable/Disable the internal 3.3V regulator Please refer to pin description of V3P3. Internal 2.5V for internal use only Adding an 1uF capacitor between V2P5 and AGND Connecting to V5 for EFuse power 1 EPAD AGND P P 2 RS0 I 3 PortN0 I 4 RS1 I 5 6 PortN1 AGND I P 7 RS2 I 8 PortN2 I 9 RS3 I 10 PortN3 11 AGND 12 AGND I P P 13 SCAN0 I 14 SCAN1 I 15 Vrext 16 RGND O P 17 V54 P 18 AGND P 19 V5 P 20 V3P3 P 24 EnB_Reg I 21 V2P5 P 22 VPP P 11 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet (Continued) Pin Label no. 23 In_Top 25 AGND 26 AGND 27 AGND Type P P Description P It should be connected to RGND for normal operation. Analog ground Analog ground P Analog ground 28 AGND 29 AGND P P Analog ground 30 AGND P Analog ground 31 AGND 32 AGND 33 AGND 34 AGND P P Analog ground Analog ground P P Analog ground 35 AGND 36 AGND P Analog ground P Analog ground Analog ground Analog ground 37 LED_CLK OD Serial LED clock output, please refer to section 5.10 LED interface. 38 LED_DAT OD Serial LED data output 39 SCL/EE_CLK I/OD In manual mode, this pin is I2C clock input. In auto mode, this pin is clock out to EEPROM. I2C serial data output In manual mode, this pin is I2C serial data input. 41 SDAI/EE_DAT I/OD In auto mode, this pin is data input from EEPROM. 40 SDAO OD 42 INTB OD Interrupt output and low active 43 DGND P Digital ground, it should be connected to AGND. Digital power 3.3V A 4.7uF capacitor should be added between DV3P3 and DGND and DV3P3 should be connected to V3P3. 44 DV3P3 P 45 RstN 46 AD2 I IL It is a low active signal to reset IP804A. I2C device address bus AD2, please refer to section 5.3&5.10 47 AD1 IL I2C device address bus AD1 48 AD0 IL I2C device address bus AD0 12 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5 Functional Description 5.1 System Reset System reset occurs in either of the following conditions: 1. Reset triggered by the built-in power-on-reset circuit IP804A generates an internal power on reset signal when V54 is power on. It didn’t leave reset state until V54 reaching V54_UVL. After reset, IP804A still keeps on monitoring voltage level of V3P3, DV3P3, and V54. If the voltage level of V54 (V3P3) is below V54_UVL(V3P3_UVL),or over V54_OVL (V3P3_OVL), IP804A enters reset state. Please refer to section 7.3 for detail specification of V54_UVL, and V3P3_UVL. It is note that there are two values for one parameter because of hysteresis. 2. Reset triggered by the reset pin (RstN) 3. Reset triggered by the Software ¾ System Control Register @ 0x02 of Page 1 Bit # 7:1 R/W R 0 R/W Default Description 0 Reserved. Software Reset. Writing 1 to this bit initiates a system reset. After system reset, this bit is 0 automatically cleared. Writing 0 has no effects. Reading this bit always returns 0. 13 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.2 Operation Modes & System Configuration IP804A operates in four possible modes, namely the Auto Mode, Manual Mode, Diagnostic Mode, and Scan Mode. The mode in which the chip operates in is determined by the two pins SCAN at system reset. ¾ Auto Mode means the chip is operating in a stand alone fashion, i.e. without the need for software intervention. The state machine does the detection, classification, power configuration, and system event monitoring automatically. The system events and status will be recorded in the corresponding registers, however, no interrupt will be generated and I2C bus in this mode could not be used. IP804A detects voltage of power supply automatically to determine whether it should support AF or AT standard. If V54 is greater than 50 volts, IP804A supports AT standard (PSE type 2), otherwise IP804A supports AF standard (PSE type 1). The detection result is stored in the AF/AT Mode Register. Avoid setting the wrong AF/AT mode, IP808 reset time must be 0.5S or more waiting power supply voltage to stable. If there is an EEPROM, the contents of the EEPROM are loaded into the register file as initial values. Please refer to the section 5.4 for the description of the syntax of the contents of the EEPROM. ¾ Manual Mode means the chip will not be working, that is all ports are disabled, until the software has (1) enabled the port by writing 0x01 to the Port Power Control Register, and (2) written 1 to the Start bit of the System Control Register; at that time, the state machine start doing the detection, classification, power configuration, and system event monitoring as does in auto mode. The interrupt output pin will be active if the interrupt masks are turned off by software and predefined events occur. The ports can be disabled (power turned off and no further detection activity) by writing 0x00 to the Port Power Control Register. If the operation mode is either in manual mode or diagnostic mode, the host CPU can read register 0 (I2C LSB Device Address Register) to make sure that IP804A has done the system start up procedure ¾ Diagnostic Mode, as its name suggests, is not for normal operation. It is used in field diagnosis and mass production test. In this mode, the state machine will be working in a step-by-step fashion, in which the state machine will stop at each detection, classification, and power configuration step and can be controlled by software to advance to the next step. The port current, voltage, or temperature measured by the ADC can be read in each steps. Another use of diagnostic mode is to program the E-Fuse during mass production. ¾ Scan Mode is also not for normal operation. It is used to execute the scan test through the scan in, scan out, and scan enable pins. The state machine will not be working in this mode. Mode Pin setting SCAN0 SCAN1 AD2 LED_CLK LED_DAT Auto Mode LED Master 0 0 1 1 1 LED Slave 0 0 0 1 1 LED Disable 0 0 X 0 0 Manual Mode LED Master 1 0 1 1 1 LED Slave 1 0 0 1 1 LED Disable 1 0 X 0 0 Diagnostic Mode Scan Mode 0 1 X 0 X 1 1 X X X Please refer to Section 5.11 for LED mode setting. 14 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Table 2 Mode Setting A summary of available functions in different modes Function Auto start detection,classfiction, and power up Program to detection, classfiction, and power up Stepbystepdetection classfiction, and power up Access register through I2C Load EEPROM LED master & slave Auto mode V V V Manual mode V V V V Diagnostic mode V V V - Reference Section 5.2 Section 5.2 Section 5.2 Section 5.3 Section 5.4 Section 5.10 Table 3 Available functions in Operation modes ¾ System Configuration Register @ 0x01 of Page 1 Bit # R/W Default 7:6 R N/A 5 R 0 4 R/W 0 3:0 R 0 Description Operation Modes. At system reset, these bits latch the input pins SCAN to determine the operation mode. 00b: Auto Mode. 01b: Manual Mode. 10b: Diagnostic Mode. 11b: Scan Mode. Reserved. Alternative Indicator. 0: Alternative A. 1: Alternative B. Reserved. AF/AT Mode Register @ 0x25 of Page 0 Bit # R/W Default 3:0 R/W 0x00 Description AF/AT Mode. The 4 bits represent the AF/AT mode of the 4 ports, where bit 0 corresponds to port 0, and bit 1 corresponds to port 1, etc. 0 = AF mode. 1 = AT mode. In auto mode, IP804A will detect the supply voltage to determine AF/AT mode and automatically update this register. In manual mode or diagnostic mode, this register should be written by host CPU. Note: When Host Defined Power Limit (HDPL) is used, please refer to Host Defined Power Limit (HDPL) application note. 15 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet I2C Slave Interface 5.3 Through the I2C slave interface of IP804A, host CPU can access the register file in IP804A. It consists of SCL, SDAO and SDAI pins, where SCL is Clock, SDAO is Serial Data Output and SDAI is Serial Data Input. It should be note that SDAO and SDAI could be connected to implement a bidirectional data pin. This I2C interface supports the 7-bit addressing mode of the I2C standard. The clock speed can be up to 1 Mbit/sec. There can be up to eight IP804A chips on one I2C bus, the LSB 3 bits of the I2C address can be assigned with the address pin AD2~AD0. The MSB 4 bits of the I2C address are fixed at 1010b. The following diagram is the register read/write cycles of the I2C bus. I2C Register Write Cycle S 7-bit SLAVE address R/W A Register Address A A 1st Register Address A A 1stRegisterData A Register Data A P ‘0’ = Write I2C Register Read Cycle S 7-bit SLAVE address R/W P ‘0’ = Write S 7-bit SLAVE address R/W ‘1’ =Read the last Register data …. N (Data bytes+ ACK) P Data byte + NACK = From host to IP804A S = Start Bit = 1Æ0 P = Stop Bit = 0Æ1 = From IP804A to host A = ACK Bit=0 A = NACK Bit=1 Figure 4 A I2C bus read/write cycles diagram Following the 7-bit slave address and read/write bit, the 1st data byte received by IP804A is always interpreted as the register address to be accessed, thus named the address byte. In a write cycle, following the address byte, there is only one byte, which contains the register data to be written. IP804A replies an ACK to the host whenever it receives a data byte. After writing this byte, the host should terminate the write cycle by sending a STOP bit. In a read cycle, the host writes only one byte, which contains the initial address of registers to be read, to the IP804A firstly. Then the host needs to start another I2C cycle with its read/write bit set to 1. IP804A will continue to send out the next data and increase the address by one automatically whenever the host acknowledges a data byte with an ACK, If the calculated register address is valid (within valid address range). The host can terminates a read cycle by sending a NACK following by a STOP bit. If the address of the data to be sent back falls out of valid register address range, IP804A always returns 00h. 16 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet ¾ I2C Device Address Register @ 0x00 of Both Pages Bit # 7 R/W R Default 0 6 R/W 0 5:3 R 0 2:0 R 000b Description Reserved. Register Page. This bit specifies the page number of the register to be accessed through the I2C interface. 0: page 0, 1: page 1 Reserved. I2C Device LSB Address. Unique device address to identify this chip on the I2C bus. This address is latched in from the input pins AD2~AD0. The highest I2C clock speed supported is 1MHz. However, in order to prevent abnormal activity on the I C bus from hanging IP804A, the I2C interface implements a time out mechanism. Host CPU can stop the I2C clock when it’s low and resume the clock within 7 mini-seconds. If the clock does not resume within 7 mini-seconds, the I2C interface will abort the current I2C cycle and wait for the next START condition. 2 17 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.4 EEPROM controller When IP804A operates in auto mode, the register file can be loaded with some initial value from external EEPROM (24xx series EEPROM, Maximum support to 24C16). IP804A reads the EEPROM starting from address 0, parses the contents of the EEPROM command blocks, checks for integrity of the contents, and then writes the designated registers. This process continues until there is either no more data or the integrity check fails. EEPROM is necessary only if user wants to modify the default value of registers in auto mode. The format of the EEPROM follows: BYTE 0 1 2 3 … 1+N 2+N 3+N Bit 7 Bit 6 Command Bit 5 Bit 3 Bit 2 # of Data Bytes Starting Register Address Data Byte 1 Data Byte 2 … Data Byte N Checksum Byte Next command block Figure 5 Bit 4 Bit 1 Bit 0 X EEPROM Format Where: ¾ Command: 10b = valid command, other values are invalid command and will stop the EEPROM loading process. ¾ # Of Data Bytes: the number of data bytes in this command block. 0 = 1 byte, 1 = 2 bytes, etc. ¾ Starting Register Address: the starting register address to be loaded by the following data bytes. ¾ Data Bytes: the data bytes to be loaded in to specified registers. ¾ Checksum Byte: the checksum byte is the checksum of all previous bytes in the command block. The checksum is calculated by adding all the previous bytes with the carry bit (if any) adding back to the sum. If the checksum fails, the system start up procedure fails and the system halt. 18 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.5 PSE State Machine IP804A has four ports and each port is mainly controlled by a state machine to perform the detection, classification, and powering up procedures. As the eight state machines run in parallel, they contend for ADC 1 in the detection and classification procedures. Thus an arbiter is needed to grant the access rights among the eight state machines. Furthermore, to limit the chip inrush current, a maximum of two ports are allowed to start their classification procedures simultaneously. And only one port is allowed to turn on power at a time. After successful detection, classification, and power configuration, the port power is turned on. The state machine is also designed to respond to abnormal power events, such as overload, short circuit, and overheat (thermal shutdown); basically port power will be turned off when such event happens. It takes time to cool off the device after power is turned off, so the state machine will delay a certain amount of time before starting next detection procedure for the port. ¾ Port 0~3 Power Control Registers @ 0x98~0x9B of Page 1 Bit # 7:2 1:0 R/W Default Description R 0x00 Reserved. PSE Enable. 00b = PSE port disabled. The port is disabled, port power is turned off, and the PSE state machine returns to the IDLE state. 01b = PSE port enabled. The port is enabled, and the PSE state machine starts the detection process if the port is not in error condition and the Start State Machine bit in the State Machine Control Register is set to be 1. R/W 0x0 10b = PSE port force power on. The port is forced to turn power on without going through the normal detection, classification, and power configuration processes. This is used for testing purpose, not for normal operation. 11b = PSE port enabled (skip detection process). The port is enabled, and the PSE state machine skips the detection process and starts the classification process directly. This is only used for testing purpose and not for normal operation. ¾ Port 0~3 State Machine Control Registers @ 0x90~0x93 of Page 1 Bit # R/W Default 7 R/W 0 6 R/W 0 5 R 0 4:0 R 0 Description Start State Machine. When in manual mode or diagnostic mode, writing 1 to this bit will start the state machine (from IDLE state) if the port is enabled. Step State Machine. When in diagnostic mode, writing 1 to this bit will advance the state machine to the next state, after which this bit will be cleared by hardware. Writing 0 has no effect. Note that not every state can be stepped; Basically, only those states directly related to the detection and classification procedures can be stepped. Reserved. Current State of the State Machine. Current state of the state machine. 0 = DISABLED 1 = TEST_MODE 2 = TEST_ERROR 3 = IDLE 4 = START_DETECTION 5 = DETECT_EVAL 6 = SINATURE_INVALID 19 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Bit # R/W Default Description 7 = BACKOFF 8 = START_CLASSIFICATION (AF Mode) 1-EVENT_CLASS (AT Mode) 9 = CLASS_EV1 (AT Mode) 10 = MARK_EV1 (AT Mode) 11 = CLASS_EV2 (AT Mode) 12 = MARK_EV2 (AT Mode) 13 = CLASSIFICATION_EVAL 14 = POWER_DENIED 15 = POWER_UP 16 = POWER_ON 17 = SET_PARAMETERS (AT Mode) 18 = DLL_ENABLE (AT Mode) 19 = ERROR_DELAY (AT Mode) ERROR_DELAY_SHORT (AF Mode) 20 = ERROR_DELAY_OVER (AF Mode) ¾ Port 0~3 Detected Signature Registers @ 0x68~0x6B of Page 0 Bit # 7:3 R/W R 1:0 R Default Description 0x0 Reserved. Detected Signature. 00b = RBAD. 0 01b = RGOOD. 10b = ROPEN. ¾ Port 0~3 Invalid Signature Counter Registers @ 0xB0~0xB3 of Page 1 Bit # R/W Default 3:0 R 0 Description Invalid Signature Counter. When an invalid signature is detected in the detection process, this counter is increased by 1. ¾ Port 0~3 Classification Event Number Registers @ 0xA0 of Page 1 Bit # R/W Default 7:6 R/W 2 5:4 3:2 1:0 R/W R/W R/W 2 2 2 Description Number of Classification Events for Port 3. Valid value range is from 0 to 2. The value 3 will be regarded as 2. If the value is 0, no classification is executed, and the PD is always deemed class 0 device. This register can be written to by host CPU. However, according to IEEE802.3 standard, if the port is in AF mode, only one classification event is executed, and in AT mode, there will be two classification events. So, this register will be automatically updated when the AF/AT Mode Register is updated. Number of Classification Events for Port 2. Number of Classification Events for Port 1. Number of Classification Events for Port 0. 20 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet ¾ PSE Skip Event 2 Register @ 0xA2 of Page 1 Bit # R/W Default 3:0 R/W 0xFF Description Skip the Second Classification Event. Bit 0 corresponds to port 0, bit 1 corresponds to port 1, etc. 0 = do not skip event 2, 1 = skip event 2. ¾ Port 0~1 Detected PD Class Registers @ 0x88 of Page 0 Bit # 7 R/W R 6:4 R 3 2:0 R R Default Description 0 Reserved. Detected PD Class of Port 1. 0 = Class 0 1 = Class 1 2 = Class 2 5 3 = Class 3 4 = Class 4 5 = Unknown 0 Reserved. 5 Detected PD Class of Port 0. ¾ Port 2~3 Detected PD Class Registers @ 0x89 of Page 0 Bit # 7 6:4 3 2:0 R/W R R R R Default 0 5 0 5 Description Reserved. Detected PD Class of Port 3. Reserved. Detected PD Class of Port 2. ¾ Port ICLASS Registers @ 0x78~0x7F of Page 0 ¾ Bit # 7:5 R/W R 4:0 R Bit # 7:0 R/W R Default Description 0 Reserved. Port ICLASS MSB. The current detected in classification. 5 The MSB 10 bits are integer and the LSB 4 bits are fractional. Unit is in mAmp. Default Description 0x00 Port ICLASS LSB. Port PD Requested Power Registers @ 0x90~0x93 of Page 0 Bit # R/W Default 7:0 R 0x00 Description PD Requested Power of Port. The power requested by a PD that passes detection and classification. The MSB 6 bits are the integer part, and the LSB 2 bits are the fractional part. Unit is in Watts. 21 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.6 Power Manager Power manager is responsible for two tasks: power configuration and power monitoring. Power configuration is the task to allocate power to the ports requesting for power. Power monitoring is the task to monitor power conditions (current, voltage, and temperature). When invalid conditions occur, proper actions will be taken to prevent hazardous consequences. 5.6.1 Power Trunks Before doing power configuration, the total available power must be determined first. IP804A supports two trunks of power, where each power trunk has its own set of parameters to facilitate the calculation of total available power. ¾ Trunk Power Limit is the maximum power supply capacity allocated to the power trunk. ¾ Trunk 0 Power Limit Register @ 0x40~0x41 of Page 1 Bit # R/W Default Description 7:3 R 0 Reserved. 2:0 R/W 1 Trunk 0 Power Limit (MSB). Bit # R/W Default Description Trunk 0 Power Limit (LSB). 7:0 R/W 0x2C Trunk Power Limit specifies the upper limit of the power supply. Default is 300 Watts. ¾ Trunk 1 Power Limit Register @ 0x42~0x43 of Page 1 Bit # R/W Default Description 7:3 R 0 Reserved. 0x42 2:0 R/W 1 Trunk 1 Power Limit (MSB). 0x42 Trunk 1 Power Limit (LSB). 0x43 7:0 R/W 0x2C Default is 300 Watts. ¾ Trunk Select Register @ 0x69 of Page 1 Bit # R/W Default Description 7:3 R 0 Reserved. Trunk Select. Writing to this register will switch power trunk. Note that whenever the parameters of the power trunk currently in use are updated, this Trunk Select 1:0 R/W 0 Register must also be written to make the newly updated parameters in effect. 0 = Trunk 0, 1 = Trunk 1. 5.6.2 Power Configuration Power manager is responsible to allocate powers to the ports that pass the detection and classification process. To do so, several parameters must be specified or be calculated in advance: 1) Maximun Trunk Power (specified in register 0x40~0x43, page1). 2) Power configuration Mode (specified in register 0x10, page1). ¾ Power configuration Mode specifies the way to determine the requested port power of the power device (RPP of Power configuration Mode Register) in the power configuration process. ¾ Requested Port Power is determined in the power configuration process according to RPP of power configuration mode. . 22 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet ¾ Power configuration Mode Register 0 @ 0x10 of Page 1 Bit # 7:5 R/W R/W 4:3 R/W 2:0 R Default Description 0 Reserved Requested port power (RPP) specifies ways to determine the port power requested by the power device in the power configuration process 0 = Host Defined Power Limit (HDPL) specified in Host Defined Power Limit registers 1 1 = Class defined power limit (CDPL) specified in Class Defined Power Limit registers. 0 Note: When Host Defined Power Limit (HDPL) is used, please refer to Host Defined Power Limit (HDPL) application note. Reserved. ¾ Class 0 Defined Power Limit Registers @ 0x12 of Page 1 Bit # R/W Default 7:0 R/W 0x3e Description Class 0 Port Power Limit (C0DPL). The maximum allowable port power for class 0 devices if RPP is set to be 1. Bit 7~2 specifies the integral part of the power limit, whereas bit 1~0 specifies the fractional part of the power limit value. Default is 0x3e = 15.5W. ¾ Class 1 Defined Power Limit Registers @ 0x13 of Page 1 Bit # R/W Default 7:0 R/W 0x10 Description Class 1 Port Power Limit (C1DPL). The maximum allowable port power for class 1 devices if RPP is set to be 1. Bit 7~2 specifies the integral part of the power limit, whereas bit 1~0 specifies the fractional part of the power limit value. Default is 0x10 = 4.0W. ¾ Class 2 Defined Power Limit Registers @ 0x14 of Page 1 Bit # R/W Default 7:0 R/W 0x1c Description Class 2 Port Power Limit (C2DPL). The maximum allowable port power for class 2 devices if RPP is set to be 1. Bit 7~2 specifies the integral part of the power limit, whereas bit 1~0 specifies the fractional part of the power limit value. Default is 0x1c = 7.0W. ¾ Class 3 Defined Power Limit Registers @ 0x15 of Page 1 Bit # R/W Default 7:0 R/W 0x3e Description Class 3 Port Power Limit (C3DPL). The maximum allowable port power for class 3 devices if RPP is set to be 1. Bit 7~2 specifies the integral part of the power limit, whereas bit 1~0 specifies the fractional part of the power limit value. Default is 0x3e = 15.5W. 23 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet ¾ Class 4 Type 1 Power Limit Registers @ 0x16 of Page 1 Bit # R/W Default 7:0 R/W 0x3e Description Class 4 Port Power Limit Type 1 (C4DPL_TYPE1). The maximum allowable port power for class 4 type 1 devices if RPP is set to be 1. Bit 7~2 specifies the integral part of the power limit, whereas bit 1~0 specifies the fractional part of the power limit value. Default is 0x3e = 15.5W (i.e. Type 1 device, ICABLE = 0.35A, VPORT_PSE_MIN = 44V) ¾ Class 4 Type 2 Power Limit Registers @ 0x17 of Page 1 Bit # R/W Default 7:0 R/W 0x78 Description Class 4 Port Power Limit Type 2 (C4DPL_TYPE2). The maximum allowable port power for type 2 class 4 devices if RPP is set to be 1. Bit 7~2 specifies the integral part of the power limit, whereas bit 1~0 specifies the fractional part of the power limit value. Default is 0x78 = 30.0W (i.e. Type 1 device, ICABLE = 0.60A, VPORT_PSE_MIN = 50V) 24 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.6.3 Port Polling Besides power configuration, power manager is also responsible for the monitoring of port current (I), port voltage (V), and port temperature (T). When either of IVT is out of its valid range, power manager will take prompt actions to prevent the system from hazardous consequences. Power manager do the monitoring by periodically polling the IVT of each port. The poll period can be specified in the IVT Poll Register. ¾ Force Poll Register @ 0xE2 of Page 0 Bit # R/W Default 3:0 R/W 0 Description Force Poll. Writing 1 to a bit will force an IVT poll on the corresponding port. Bit 0 corresponds to port 0, and bit 1 corresponds to port 1, etc. When the polling completes, the bit will be cleared automatically. ¾ IVT Poll Register @ 0xE3 of Page 0 Bit # 3 R/W R 6 R/W 5 R/W 4:0 R/W Default Description 0 Reserved. Check Port Voltage. 1 0 = do not check port voltage. 1= check port voltage after polling. Auto Poll. 0 Enable automatically polling of IVT of powered ports. In auto mode, this bit will be set to 1 automatically after system reset. Poll Period. 10 Number of 8ms between each poll to the port IVT. Minimum value is 10. Thus, by default, the poll period is 10 * 8 = 80 ms. ¾ Port 0~3 Current Registers @ 0xA0~0xA3 of Page 0 Bit # 7:4 3:0 Bit # R/W R R R/W 7:0 R Default Description 0 Reserved. 0 Port Current. Default Description Port Current. 0 The port current. MSB 10 bits are the integer part and LSB 2 bits are the fractional part. The unit is mA. ¾ Port 0~3 Voltage Registers @ 0xB0~0xB7 Bit # 7:4 3:0 Bit # R/W R R R/W 7:0 R Default Description 0 Reserved. 0 Port Voltage. Default Description Port Voltage. The MSB 8 bits are the integer part and the LSB 4 bits are the fractional part. 0 The unit is Volts. This value is updated every time the port is polled. Note that the true port voltage is (Supply Voltage - Port Voltage). Please refer to Supply Voltage Registers. 25 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet ¾ Port 0~3 Temperature Registers @ 0xC0~0xC7 of Page 0 Bit # 7:5 4:0 Bit # R/W R R R/W 7:0 R Default Description 0 Reserved. 0 Port Temperature. Default Description Port Temperature. 0 The MSB 9 bits are the integer part and the LSB 4 bits are the fractional part. The unit is Celsius. This value is updated every time the port is polled. ¾ Supply Voltage Registers @ 0xE0~0xE1 of Page 0 Bit # 7:4 3:0 Bit # R/W R R R/W 7:0 R Default Description 0 Reserved. 0 Supply Voltage. Default Description Supply Voltage. The supply voltage in Volts. 0 The MSB 8 bits are the integer part, where the LSB 4 bits are the fractional part. 5.6.4 Power Event Handling After the IVTs are polled and recorded, the power manager checks the polled values against predefined valid ranges. If the polled values drop out of the predefined valid range, power events are recorded and handled. The power events triggered by power manager Port Temperature Limit Event. When a power event occurs, if its corresponding power event handle bit is 1, the port power is turned off. If IP804A is in manual mode or diagnostic mode, and the power event’s corresponding status mask bit is 1, an interrupt will be issued to the host CPU. ¾ Port Temperature Limit Event (Bit 7). After the port is polled and if the port temperature is above the value specified in Port Temperature Limit Register, a Port Temperature Limit Event occurs. ¾ Port Temperature Limit Registers @ 0x24~0x25 of Page 1 Bit # 7:5 4:0 Bit # R/W R R R/W 7:0 R Default Description 0 Reserved. 0x9 Port Temperature Limit. Default Description Port Temperature Limit. The port temperature limit in Celsius, over which a port temperature limit 0x60 event will be reported. The 9 MSB bits are the integer part, and the 4 LSB bits are the fraction part. Default 0x960 = 150°C. 26 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.7 Real time Monitor Power Event Power events described in previous sections are discovered only when the ports are polled. The analog monitor can continuously watch over and report time-critical power events so that the power manager can take prompt actions. Power events from analog monitor include thermal shutdown event, severe short circuit event (I > 1Amp), MPS error event (DC Disconnect), overload event (I > ICUT), and short circuit event (I > ILIM). ¾ Thermal Shutdown Event is the event where the port temperature is over the pre-defined thermal shutdown threshold. The port power is turned off and the port is eligible for detection only after the port is cooled off (temperature drops below the threshold). ¾ Severe Short Circuit Event is the event where the port current is over 1 Amp. Immediate action must be taken to eliminate such event. The power manager responds to this event by temporarily turn off port power. ¾ DC Disconnect Event is the event the port cannot maintain its power signature (MPS). If the event lasts for specified period of time (Event High Count Register), this will be considered an MPS error event and the port power will be turned off. After the power is turned off the port start another detection process after about 1.6 seconds. ¾ Overload (ICUT) Event is the event where port current is greater than ICUT. If the event lasts for specified period of time (Event High Count Register), this will be considered an overload event. When an overload condition is determined, the port power will be turned off. After the power is turned off the port start another detection process after about 1.6 seconds. ¾ Short Circuit (ILIM) Event is the event where port current is greater than ILIM. This event should be sampled by the power manager to determine if a short circuit event has occurred either during the power up process or after the port being powered up. When a short circuit condition is determined, the port power will be turned off. After the power is turned off the port start another detection process after about 1.6 seconds. A summary of power off conditions Condition Power Trunk< budget Port temp > limit Port temp > thermal Port I > 1A Port unplug UTP Port I > Ilim Port I > Icut description Power Trunk not enough power to port used Port temperature Event Thermal Shutdown Event Severe Short Circuit Event DC Disconnect Event short circuit event Overload (ICUT) Event Power off moment Reference Section Power up sequence 5.6.1 IVT polling Real-time monitor Real-time monitor Real-time monitor Real-time monitor Real-time monitor 5.6.4 5.7 5.7 5.7 5.7 5.7 Table 4 Port power off conditions 27 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.8 Port Status and Interrupt Port state and power events are recorded in the registers. In manual mode and diagnostic mode, these statuses can generate interrupts to host CPU for further processing. ¾ Port Power Event Handle Register @ 0x81 of Page 1 Bit # 7 R/W R/W 6:0 R/W Default Description 1 Port Temperature Limit Event Handle. 0 = Do not turn off power when the event occurs. 1 = Turn off power when the event occurs. 0x1F Not used. ¾ Port 0~3 Power Event Register @ 0x70~0x73 of Page 1 Bit # R/W Default 7 W1C 0 6:5 W1C 0 4 W1C 0 3 W1C 0 2 W1C 0 1 W1C 0 0 W1C 0 Description Port Temperature Limit Event. In manual or diagnostic mode, write 1 to clear the bit. Writing 0 to this bit has no effect. Not used. Port Thermal Shutdown Event. In manual or diagnostic mode, write 1 to clear the bit. Writing 0 to this bit has no effect. Port Severe Short Circuit Event. In manual or diagnostic mode, write 1 to clear the bit. Writing 0 to this bit has no effect. Port MPS Error (DC Disconnect) Event. In manual or diagnostic mode, write 1 to clear the bit. Writing 0 to this bit has no effect. Port Short Circuit Limit (ILIM) Event. In manual or diagnostic mode, write 1 to clear the bit. Writing 0 to this bit has no effect. Port Overload (ICUT) Event. In manual or diagnostic mode, write 1 to clear the bit. Writing 0 to this bit has no effect. ¾ Port 0~3 Power Event Mask Register @ 0x78~0x7B of Page 1 Bit # R/W Default 7 R/W 1 6:5 4 3 2 1 0 R/W R/W R/W R/W R/W R/W 1 1 1 1 1 1 Description Port Temperature Limit Event Mask. In manual mode or diagnostic mode, when mask bit is 0, no interrupt will be issued for this event. Not used. Port Thermal Shutdown Event Mask. Port Severe Short Circuit Event Mask. Port MPS Error (DC Disconnect) Event Mask. Port Short Circuit (ILIM) Event Mask. Port Overload (ICUT) Event Mask. 28 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet ¾ Port Interrupt Register @ 0x80 of Page 1 Bit # 7:4 R/W R 3 R 2 R 1 R 0 R Default Description 0 Not used. Port 3 Interrupt. 0 Port 3 has interrupt. Port 2 Interrupt. 0 Port 2 has interrupt. Port 1 Interrupt. 0 Port 1 has interrupt. Port 0 Interrupt. 0 Port 0 has interrupt. ¾ Port Power Status Register @ 0x82 of Page 1 Bit # R/W Default 3:0 R 0x00 Description Power Status of the Ports. 0 = power off. 1 = power on. Bit 0 corresponds to port 0, and bit 1 corresponds to port 1, etc. ¾ Port MPS Present Status Register @ 0x83 of Page 1 Bit # R/W Default 3:0 R 0x00 Description MPS Status of the Ports. 0 = MPS not present. 1 = MPS present Bit 0 corresponds to port 0, and bit 1 corresponds to port 1, etc. ¾ Port 0~3 Invalid Signature Counter Registers @ 0xB0~0xB3 of Page 1 Bit # R/W Default 3:0 R 0 Description Invalid Signature Counter. Number of times the port encounters an “Invalid Signature” in detection process. ¾ Port 0~3 Power Denied Counter Registers @ 0xB8~0xBB of Page 1 Bit # R/W Default 3:0 R 0 Description Power Denied Counter. Number of times the port encounters a “Power Denied” in classification process. 29 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.9 Total Current Limit When the IVT is polled, the port currents are summed up to get the total current consumption. Total current limit Register can be specified and checked against the total current consumption. When this total current limit is exceeded, the last port powered on would be turned off. The total current limit is by default disabled and can be enabled by using the Total Current Limit Control Register. The total current limit is specified in the PSE Available Current Registers. ¾ Total Current Limit Control Registers @ 0xC0 of Page 1 Bit # R/W Default 7 R/W 0 6:0 R 0 Description Enable Total Current Limit 0= Disable 1= Enable Reserved. ¾ PSE Available Current Registers @ 0xC1~0xC2 of Page 1 Bit # 7:6 5:0 Bit # R/W R R/W R/W 7:0 R/W Default Description 0 Reserved. 0 PSE Available Current MSB Default Description PSE Available Current LSB Total available current is the maximum current that the power supply can 0 provide to the ports. The MSB 12 bits are the integer part and LSB 2 bits are the fractional part. The unit is mA. 30 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 5.10 LED Interface In auto mode or manual mode, the LED interface can hook up with an IP403 (Serial-to-Parallel LED driver) to display the port status. A port status LED is lit up when IP804A allocates power to the port LED interface is enabled by pulling up LED_DAT pin with a resister. One IP804A can handle 4 LEDs and up to three IP804As can share one IP403, where one IP804A serves as the master to drive LED_CLK and the others are slaves. AD2 pin defines IP804A to be a master or a slave. The index counter in all IP804As counts from 0 to 55 repeatly with LED_CLK after reset and the value of index counter in all IP804A are identical. An IP804A will send out 4-bit LED information on LED_DAT when its index counter reaches start index defined in start index register (0x0B). The detail is illustrated in the LED start index register (0x0B) and figure 7. If there is only one IP804A, user can replace IP403 with a 74LV164 to display port status for cost saving. IP804A should be configured as a master. LED Configuration Register @ 0x08 of Page 1 Bit # R/W 7 R/W 6:5 R 4 R/W 3 R/W 2 R/W 1 R/W 0 R/W Default Description LED Interface Enable. Enable the LED interface. 0/1 0 = disable, 1 = enable. The default value of this bit is latched from LED_DAT pin. 0 Reserved. LED Order. The order in which 4-bit LED information is shifted out. 1 0 = Port 0, Port1, .… Port3. 1 = Port3, Port1, …. Port 0. LED Active Level. 0 0 = light up a LED by driving logic low 1 = light up a LED by driving logic high LED Initial Level. 1 The initial level of the LED. After reset, the LED will be driven to this initial value. LED Clock Rate. Clock rate of the LED clock. 1 0 = LED clock is 512k Hz 1 = LED clock is 1M Hz LED Master. 0 = slave. IP804A receives LED clock on LED_CLK pin. 0/1 1 = master. IP804A drives LED_CLK pin. The default value of this bit is latched from AD2 pin. 31 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet ¾ LED Start Index Register @ 0x0B of Page 1 Bit # 7:6 5:0 R/W R R/W Default Description 0 Reserved. LED Start Index. There are 3 default values can be selected with I2C address pin AD2 ~ AD0. It is benefit to implement a multiple (no more than 3) IP804A LED display without software programming. AD2~AD0 default value of bit [5:0] 1,x,x (master) 0x30h (48d) 0,0,0(slave) 0x28h (40d) 0,0,1(slave) 0x20h (32d) 0,1,0(slave) 0x18h (24d) 0,1,1(slave) 0x10h (16d) The following table demostrates the LED applications for 1~3 IP804A. 3 x IP804A Master Slave1 Slave2 Start index 0x30h 0x28h 0x20h AD2~AD0 1,x,x 0,0,0 0,0,1 2 x IP804A Master Slave1 Start index 0x30h 0x28h -AD2~AD0 1,x,x 0,0,0 -1 x IP804A Master Start index 0x30h --AD2~AD0 1,x,x --In manual mode, because AD0~AD2 is used for I2C address at the same time, the default setting of LED start index may be incorrect. User has to correct the LED start index by writing this register to make sure that IP804A can send out LED status correctly. There is an alternative for LED implementation if there is a MCU in the system. The MCU reads the port status of IP804A through I2C and write the LED information to IP403, where IP403 works as a GPIO controller not a serial-to-parallel LED driver. Because LED is handled by MCU itself, the start index in IP804A can be ignored. 32 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet LED_DAT … … … … LED Order = 0 P0 P1 … P3 P0 P1 … P3 P0 P1 … P3 LED Order = 1 (default) P3 P2 … P0 P3 P2 … P0 P3 P2 … P0 Index conter 32 33 … 35 40 41 … 43 48 49 … 51 AD2, AD0 LED_CLK 01: 10 bit LED data sent out by 00 : 10 bit LED data sent out by Slave2 with Start Index = 32 Slave1 with Start Index = 40 … … 0 1 32 33 IP804A-3 (Slave2) AD0 AD2 LED_CLK 34 35 … 36 40 41 42 IP804A-2 (Slave1) LED_DAT 1x: 10 bit LED data sent out by Master with Start Index = 48 LED_CLK 43 44 … 48 49 50 54 IP804A-1 (Master) AD0 AD2 LED_CLK LED_DAT 55 AD2 LED_DAT LED_CLK LED_DAT IP403 (Serial to parallel mode, Mode[2:0]=100) Q 1 …… Q … 3 3 Case 1: LED Order = 0 Q 3 5 Q 3 6 Q 4 1 … Q 4 3 Q 4 4 Q 4 9 … Q 5 1 Port 3 ~ Port 0 power LED Port 3~ Port 0 power LED Port 3 ~ Port 0 power LED Port 0 ~ Port 3 power LED Port 0 ~ Port 3 power LED Port 0 ~ Port 3 power LED Slave2: Start Index = 32 Slave1: Start Index = 40 Master: Start Index = 48 Q 5 2 Case 2: LED Order = 1 Figure 6 LED behavior and system diagram of multiple IP804A application 33 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 6 IP804A Register descriptions Table 5 Register Page 0 description Page Register Address Register Name # and Attribute 2 I C Interface Registers 0 0x00 R/W Register Page & I2C LSB Device Address (I2C Addr) Analog Configure and Control Registers 0 0x01~0x24 R Reserved (write prohibited) 0 0x25 R/W AF/AT Mode 0 0x26 R Reserved (write prohibited) 0 0x27 R/W Power Down HV Analog Driver 0 0x28~0x5E R Reserved (write prohibited) 0 0x5F R/W Inrush Time 0 0x60~0x67 R Reserved (write prohibited) Detection Result 0 0x68 R RDET for Port 0 0 0x69 R RDET for Port 1 0 0x6A R RDET for Port 2 0 0x6B R RDET for Port 3 0 0x6C~0x77 R Reserved (write prohibited) Classification Currents 0 0x78 R ICLASS for Port 0 MSB 0 0x79 R ICLASS for Port 0 LSB 0 0x7A R ICLASS for Port 1 MSB 0 0x7B R ICLASS for Port 1 LSB 0 0x7C R ICLASS for Port 2 MSB 0 0x7D R ICLASS for Port 2 LSB 0 0x7E R ICLASS for Port 3 MSB 0 0x7F R ICLASS for Port 3 LSB 0 0x80~0x87 R Reserved (write prohibited) Classification Results (Detected PD Classes) 0 0x88 R Detected PD Class Port 1 & 0 0 0x89 R Detected PD Class Port 3 & 2 0 0x8A~0x8F R Reserved (write prohibited) PD Requested Powers 0 0x90 R PD 0 Requested Power 0 0x91 R PD 1 Requested Power 0 0x92 R PD 2 Requested Power 0 0x93 R PD 3 Requested Power 0 0x94~0x9F R Reserved (write prohibited) Port Currents 0 0xA0 R Port 0 Current MSB 0 0xA1 R Port 0 Current LSB 0 0xA2 R Port 1 Current MSB 0 0xA3 R Port 1 Current LSB 0 0xA4 R Port 2 Current MSB 0 0xA5 R Port 2 Current LSB 0 0xA6 R Port 3 Current MSB 0 0xA7 R Port 3 Current LSB 0 0xA8~0xAF R Reserved (write prohibited) 34 / 47 Copyright © 2017, IC Plus Corp. Default Value (x0xx,xPPP) P: pin setting (0000,0000) (0000,0000) (0111,1110) (xxxx,xx00) (xxxx,xx00) (xxxx,xx00) (xxxx,xx00) (xx00,0000) (0000,0000) (xx00,0000) (0000,0000) (xx00,0000) (0000,0000) (xx00,0000) (0000,0000) (x101,x101) (x101,x101) (0000,0000) (0000,0000) (0000,0000) (0000,0000) (xxxx,0000) (0000,0000) (xxxx,0000) (0000,0000) (xxxx,0000) (0000,0000) (xxxx,0000) (0000,0000) May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Page Register Address # and Attribute Port Voltages 0 0xB0 R 0 0xB1 R 0 0xB2 R 0 0xB3 R 0 0xB4 R 0 0xB5 R 0 0xB6 R 0 0xB7 R 0 0xB8~0xBF R Port Temperatures 0 0xC0 R 0 0xC1 R 0 0xC2 R 0 0xC3 R 0 0xC4 R 0 0xC5 R 0 0xC6 R 0 0xC7 R 0 0xC8~0xDF R Supply Voltage 0 0xE0 R 0 0xE1 R IVT Poll Control 0 0xE2 R/W 0 0xE3 R/W 0 0xE4 ~ 0xFF R Register Name Port 0 Voltage MSB Port 0 Voltage LSB Port 1 Voltage MSB Port 1 Voltage LSB Port 2 Voltage MSB Port 2 Voltage LSB Port 3 Voltage MSB Port 3 Voltage LSB Reserved (write prohibited) (xxxx,0000) (0000,0000) (xxxx,0000) (0000,0000) (xxxx,0000) (0000,0000) (xxxx,0000) (0000,0000) - Port 0 Temp. MSB Port 0 Temp. LSB Port 1 Temp. MSB Port 1 Temp. LSB Port 2 Temp. MSB Port 2 Temp. LSB Port 3 Temp. MSB Port 3 Temp. LSB Reserved (write prohibited) (xxx0,0000) (0000,0000) (xxx0,0000) (0000,0000) (xxx0,0000) (0000,0000) (xxx0,0000) (0000,0000) - Supply Voltage MSB Supply Voltage LSB (xxxx,0000) (0000,0000) Force IVT Poll IVT Poll Control Reserved (write prohibited) (0000,0000) (x101,1110) - 35 / 47 Copyright © 2017, IC Plus Corp. Default Value May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Table 6 Register Page 1 description Page Register Address # and Attribute Register Page & I2C Interface Registers 1 0x00 R/W Register Name Default Value (Binary) Register Page & I2C LSB Device Address (I2C Addr) (x0xx,xPPP) P:pin setting System Configuration & Control Registers 1 0x01 R/W 1 0x02 R/W 1 0x03~0x07 R LED Control & Configuration 1 0x08 R/W 1 0x09~0x0A R 1 0x0B R/W System Configuration System Control Reserved (write prohibited) LED Control Reserved (write prohibited) LED Start Index 1 0x0C~0x0F R Reserved (write prohibited) Power Configuration 1 0x10 R/W Power Configuration Mode (PAM) 1 0x11 R Reserved (write prohibited) 1 0x12 R/W Class 0 Port Power Limit 1 0x13 R/W Class 1 Port Power Limit 1 0x14 R/W Class 2 Port Power Limit 1 0x15 R/W Class 3 Port Power Limit 1 0x16 R/W Class 4 Port Power Limit Type 1 1 0x17 R/W Class 4 Port Power Limit Type 2 1 0x18~0x23 R Reserved (write prohibited) 1 0x24 R/W Port Temp. Limit MSB 1 0x25 R/W Port Temp. Limit LSB 1 0x26~0x3F R Reserved (write prohibited) Power Trunk Control & Configuration 1 0x40 R/W Trunk 0 Power Limit MSB 1 0x41 R/W Trunk 0 Power Limit LSB 1 0x42 R/W Trunk 1 Power Limit MSB 1 0x43 R/W Trunk 1 Power Limit LSB 1 0x44~0x68 R Reserved (write prohibited) 1 0x69 R/W Trunk Select 1 0x6A~0x6F R Reserved (write prohibited) Port Status 1 0x70 R/W1C Port 0 Status 1 0x71 R/W1C Port 1 Status 1 0x72 R/W1C Port 2 Status 1 0x73 R/W1C Port 3 Status 1 0x74~0x77 R Reserved (write prohibited) 1 0x78 R/W Port 0 Status Mask 1 0x79 R/W Port 1 Status Mask 1 0x7A R/W Port 2 Status Mask 1 0x7B R/W Port 3 Status Mask 1 0x7C~0x7F R Reserved (write prohibited) 1 0x80 R Port Interrupt Status 36 / 47 Copyright © 2017, IC Plus Corp. (PPx0,xxxx) P:pin setting (xxxx,xxx0) (Pxx1,011P) P:PinSetting (PPPP,PPPP) P:PinSetting (0000,1000) (0011,1110) (0001,0000) (0001,1100) (0011,1110) (0011,1110) (0111,1000) (xxx0,1001) (0110,0000) (xxxx,x000) (1111,1010) (xxxx,x000) (1111,1010) (xxxx,xx00) (0000,0000) (0000,0000) (0000,0000) (0000,0000) (1111,1111) (1111,1111) (1111,1111) (1111,1111) (0000,0000) May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Page Register Address # and Attribute 1 0x81 R/W 1 0x82 R 1 0x83 R 1 0x84~0x8F R State Machine Control & Status 1 0x90 R/W 1 0x91 R/W 1 0x92 R/W 1 0x93 R/W 1 0x94~0x97 R 1 0x98 R/W 1 0x99 R/W 1 0x9A R/W 1 0x9B R/W 1 0x9C~0x9F R 1 0xA0 R/W 1 0xA1 R 1 0xA2 R/W 1 0XA3~0xAF R Counter Registers 1 0xB0 R 1 0xB1 R 1 0xB2 R 1 0xB3 R 1 0XB3~0xB7 R 1 0xB8 R 1 0xB9 R 1 0xBA R 1 0xBB R 1 0xBC~0xFF R Total Current Limit Registers 1 0xC0 R/W 1 0xC1 R/W 1 0xC2 R/W Register Name Power Event Handle Port Power Status MPS Present Status Reserved (write prohibited) Port 0 State Machine State Port 1 State Machine State Port 2 State Machine State Port 3 State Machine State Reserved (write prohibited) Port 0 Power Control Port 1 Power Control Port 2 Power Control Port 3 Power Control Reserved (write prohibited) Port 3-0 Classification Event Number Reserved (write prohibited) PSE Skip Event 2 Reserved (write prohibited) (00x0,0000) (00x0,0000) (00x0,0000) (00x0,0000) (xxxx,xx00) (xxxx,xx00) (xxxx,xx00) (xxxx,xx00) (1010,1010) (1111,1111) - Port 0 Invalid Signature Count Port 1 Invalid Signature Count Port 2 Invalid Signature Count Port 3 Invalid Signature Count Reserved (write prohibited) Port 0 Power Denied Count Port 1 Power Denied Count Port 2 Power Denied Count Port 3 Power Denied Count Reserved (write prohibited) (0000,0000) (0000,0000) (0000,0000) (0000,0000) (0000,0000) (0000,0000) (0000,0000) (0000,0000) - Total Current Limit Control PSE Available Current MSB PSE Available Current LSB (0xxx,xxxx) (xx00,0000) (0000,0000) 37 / 47 Copyright © 2017, IC Plus Corp. Default Value (Binary) (111x,xxxx) (0000,0000) (0000,0000) - May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 7 Electrical Characteristics 7.1 Absolute Maximum Ratings (Note: Beyond these ratings can cause damage to the device) Table 7 Electrical Characteristics Parameter Supply Voltage PortN0~PortN3 RS0~RS3 V5 All other Pins RGND, AGND Maximum Junction Temperature Storage Temperature Range Lead Temperature ESD at all Pins 7.2 Description V54 – AGND PortNn– AGND @n=0~3 RSn – AGND @n=0~3 V5 – AGND All other Pin – (AGND, or DGND) DGND – AGND Typ. -65 Soldering 10 seconds HBM Max. +80 +80 +5.5 +5.5 +3.6 +0.3 Unit V V V V V V 150 ℃ 150 ℃ 300 ℃ KV Max. +85 57 57 Units ℃ V V ±2 Operating Conditions Parameter Description Ta Ambient temperature V54 V54 – AGND @ AF V54 – AGND @ AT 7.3 Min. -0.3 -0.3 -0.3 -0.3 -0.3 -0.3 Min. -40 45 51 Typ. 48 54 Electrical Characteristics for Analog I/O Pins Parameter Description Conditions Min. 45V~57V @AF V54 51V~57V @AT All ports on @w/o peripheral load I54 current & port load current External Capacitance=4.7uF V3P3 V3P3 voltage @short V3P3 and DV3P3 V3P3 providing to peripheral device Iout_v3p3 EnB_Reg=low @short V3P3 and DV3P3 External 3.3V provides to V3P3 @short Iin_v3p3 EnB_Reg=high V3P3 and DV3P3 V5 Internal use only External Capacitance=4.7uF V2P5 Internal use only External Capacitance=1uF Increasing V54 – AGND V54 under V54_UVL voltage lockout Decreasing V54 – AGND V54 overvoltage Increasing V54 – AGND V54_OVL lockout Decreasing V54 – AGND V3P3 under Increasing V3P3 – AGND V3P3_UVL voltage lockout V3P3 – AGND @short V3P3 and DV3P3 V3P3 overvoltage Decreasing V3P3 – AGND V3P3_OVL lockout V3P3 – AGND @short V3P3 and DV3P3 Power Supply voltage V54 operating current 38 / 47 Copyright © 2017, IC Plus Corp. Typ. Max. Unit 57 57 V V 12 18 mA 3.30 3.46 V 6 mA 45 51 3.10 6 5 2.37 mA 5.25 2.5 30 27 63 60 5.5 2.62 V V V V V V 2.8 V 1.9. V May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 7.4 IEEE802.3 AF/AT Mode Parameters Table 8 IEEE802.3 AF/AT Mode Parameters Parameter Description Conditions Min. Typ. Max. Unit Tovlrec Auto-recovery time From overload shutdown to next detection 1.6 s Tudlrec Auto-recovery time From Imin_off shutdown to next detection 1.6 s Tbackoff Back-off time Midspan mode detection back-off time 2.5 s Iinrush Inrush current For t=50ms Cload=180uF max. 400 Iport Port output current Continuous port output current after AF startup period AT Pport Port output power 425 450 mA 10 375 mA 10 640 mA Continuous port output power after startup period @ AF 0.57 15.4 W Continuous port output power after startup period @ AT 0.57 30 W 5 mA Imin_off Port off Must disconnect for t greater than Tmpdo 0 Imin_onoff Port off or on May or may not disconnect for greater than Tmpdo 5 7.5 10 mA Tmpdo PD Maintenance power signature dropout time limit AF/AT 300 350 400 ms Tmps PD Maintenance Port current pulse width to reset power signature time disconnect timer for validity Icut Over load current (default) AF 350 375 400 mA AT 600 640 664 mA Tcut Over load time Iport > Icut, AF/AT 50 62.5 75 ms Ilim Current limit AF 400 425 450 mA AT 800 860 920 mA Tlim Current limit time Iport = Ilim, AF/AT 50 62.5 75 ms Toff Turn off time From VportN to V54-2.8V 500 ms Ron Port on resistance Iport≦640mA, & Ta=25℃ Ioff_port PortN leakage current V54=54V , Ta=25℃, Port off 39 / 47 Copyright © 2017, IC Plus Corp. 49 ms 0.3 Ω 10 uA May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Typical: PortN0~3 (Detection, 2-event Classification, Port On, Port Off) sequence Time specification show in table 8 Tpon Tdet 0V -4V -8V -9V Time Port Off Port Off -Vdet1 -Vdet2 -Vdet2 -Vdet1 -Vmark -18V -54V -Vclass Port On (PortNn-V54, n=0~3) Figure 7 Typical Power up Sequence IEEE802.3 AF/AT Mode Parameters: (continued) Parameter Description Detection Vdet1 Detection voltage @first point Detection voltage @second point Idetlim Detection current limit Time to complete Tdet detection of a PD Detection port open Vdet_oc circuit voltage Minimum Rdet Rdet_min detection resistance Maximum Rdet Rdet_max detection resistance Rdet_open Open circuit resistance Valid Cdet detection Cdet_good capacitance Invalid Cdet detection Cdet_bad capacitance Vdet2 Conditions V54 – PortNn, (n=0~3) @Rdet=25ΚΩ V54 – PortNn, (n=0~3) @Rdet=25KΩ V54=PortNn, (n=0~3) Typ. Max. Unit 2.8 8 10 V 2.8 4 10 V 5 mA 500 ms 30 V AF/AT 326 V54 – PortNn, (n=0~3) @Port open circuit @Cdet=0.15uF 15 17 19 KΩ @Cdet=0.15uF 26.5 30 33 KΩ Rdet @Cdet=0.15uF 500 @Rdet=25KΩ 0 @Rdet=25KΩ 10 40 / 47 Copyright © 2017, IC Plus Corp. Min. KΩ 0.15 uF uF May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet Parameter Description Classification Conditions Min. Typ. Max. Unit 15.5 18.0 20.5 V Vclass Classification voltage V54 – PortNn, (n=0~3) @0mA≦Iclass≦50mA Iclasslim Classification current limitation V54=PortNn, (n=0~3) 51 100 mA Iclass Classification current Class 0 Class 1 Class 2 Class 3 Class 4 Invalid class 0 8 16 25 35 51 5 13 21 31 45 mA mA mA mA mA Vmark Mark voltage V54 – PortNn, (n=0~3) @0mA≦Imark≦10mA 7 10 V Imarklim Mark current limitation V54=PortNn, (n=0~3) 5 100 mA Tme1 Tme2 Classification event time Mark event 1 time Mark event 2 time Tpon Power turn on time Tcle Width for classification event 1 or event 2 Width for mark event 1 Width for mark event 2 From end of valid detect to application of power to port 9 6 12 30 ms 6 16 9 22 12 ms ms 55 400 ms Temperature Sensor Tsd Thermal shutdown Thy Thermal shutdown hysteresis Internal temperature for thermal shutdown Internal temperature for release thermal shutdown 41 / 47 Copyright © 2017, IC Plus Corp. 150 ℃ 129 ℃ May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 7.5 Digital Electrical Characteristics Table 9 Digital Electrical Characteristics Parameter Description 2 I C & EEPROM interface VIL Input low voltage VIH VOL VOL Tscl Tee TSDAO TSDAOH TSDAI TSDAIH Others VIL VIH Conditions Min. Max. Unit 0.8 V 2 SCL/EE_CLK,SDAI/EE_DAT@ I C mode, SCAN0, SCAN1 2 Input high voltage SCL/EE_CLK,SDAI/EE_DAT@I C mode, SCAN0, SCAN1 Open drain output SCL/EE_CLK,SDAI/EE_DAT@auto low voltage mode @ Isink =5mA Open drain output SDAO,INTB,LED_CLK,LED_DAT low voltage @ Isink =5mA 2 SCL/EE_CLK input I C input clock SCL/EE_CLK output Output clock for EEPROM SDAO output Delay SDAO output Hold SDAI Input Setup SDAI Input Hold 350 125 50 50 Input low voltage Input high voltage 2.2 AD0~AD2 AD0~AD2 42 / 47 Copyright © 2017, IC Plus Corp. Typ. 2.2 V 0.7 V 0.7 V 1 1 MHz MHz ns ns ns ns 0.8 V V May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 7.6 AC Timing 7.6.1 Power On Sequence and Reset Timing Description Min. V54_Power on time@ V54 rising time from 0v to 57v V54 stable to RstN release Reset to System up time Typ. Max. Unit 100 - ms ms ms 200 150 V54_Power on time V54 RstN V54 stable to RstN release I2C Reset to System up time 2 I C Access Figure 8 Power on Sequence and Reset Timing Diagram 43 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 7.6.2 EEPROM Timing 7.6.2.1 Data read cycle Symbol Description TSCL TsSCL ThSCL Receive clock period SDA to SCL setup time SDA to SCL hold time Min. Typ. Max. Unit 2 0.5 20480 - - ns ns ns Min. Typ. Max. Unit - 20480 - 5200 ns ns T SCL SCL T hS C L SDA T sSCL R ead data cycle Figure 9 EEPROM Read Cycle Timing Diagram 7.6.2.2 Command cycle Symbol Description TSCL TdSCL Transmit clock period SCL falling edge to SDA T SCL SCL T dSCL SDA Comand cycle Figure 10 EEPROM Command Cycle Timing Diagram 44 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 7.6.3 I2C Timing 7.6.3.1 Data read cycle Symbol Description 2 TSCL TSDAO TSDAOH I C clock period SDAO output delay SDAO output hold time of the last data bit Min. Typ. Max. Unit 1000 125 - 350 - ns ns ns Min. Typ. Max. Unit 1000 50 50 - - ns ns ns T SCL SCL T SDAOH T SDAO SDAO R ead data cycle Figure 11 I2C Read Cycle Timing Diagram 7.6.3.2 Command cycle Symbol Description I2C clock period SDAI setup time SDAI hold time TSCL TSDAI TSDAIH T SCL SCL T SDAI T SDAIH SDAI Comand cycle Figure 12 I2C Command Cycle Timing Diagram 7.7 Thermal Data θJA θJC ΨJT Conditions 21 9.6 0.47 4 Layer PCB 45 / 47 Copyright © 2017, IC Plus Corp. Units o C/W May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 8 Order Information Table 10 Order Information Part No. IP804A Package 48-Lead MQFN Operating Temperature -40°C to 85°C 46 / 47 Copyright © 2017, IC Plus Corp. Notice May 2, 2017 IP804A-DS-R01 IP804A Preliminary Datasheet 9 Package Detail 9.1 48 MQFN Outline Dimensions (in mm) Figure 13 Package Outline Dimensions IC Plus Corp. Headquarters 10F, No.47, Lane 2, Kwang-Fu Road, Sec. 2, Hsin-Chu City, Taiwan 300, R.O.C. TEL: 886-3-575-0275 FAX: 886-3-575-0475 Website: www.icplus.com.tw Sales Office 4F, No. 106, Hsin-Tai-Wu Road, Sec.1, Hsi-Chih, Taipei Hsien, Taiwan 221, R.O.C. TEL: 886-2-2696-1669 FAX: 886-2-2696-2220 47 / 47 Copyright © 2017, IC Plus Corp. May 2, 2017 IP804A-DS-R01
IP804A 价格&库存
很抱歉,暂时无法提供与“IP804A”相匹配的价格&库存,您可以联系我们找货
