SK310A-T R3G
SK310A-T R3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC(SMA)
SK310A-T R3G 数据手册
SK34A-T - SK310A-T Taiwan Semiconductor 3A, 40V - 100V Surface Mount Schottky Barrier Rectifier FEATURES KEY PARAMETERS ● ● ● ● ● Low power loss, high efficiency Ideal for automated placement Guard ring for over-voltage protection High surge current capability Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF(AV) 3 A VRRM 40 - 100 V IFSM 70 A Package DO-214AC (SMA) Configuration Single Die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Moisture sensitivity level: level 1, per J-STD-020 Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: As marked Weight: 0.07 g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL SK34A-T SK36A-T SK310A-T SK34A SK36A SK310A 100 V UNIT Marking code on the device Repetitive peak reverse voltage VRRM 40 60 Reverse voltage, total rms value VR(RMS) 28 42 70 V VDC IF(AV) 40 60 100 3 V A IFSM 70 A dV/dt 10000 V/μs TJ TSTG - 55 to +150 °C - 55 to +150 °C Maximum DC blocking voltage Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode) Voltage rate of change (Rated VR) Junction temperature Storage temperature 1 Version:B1702 SK34A-T - SK310A-T Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL LIMIT Junction-to-lead thermal resistance RӨJL 25 UNIT °C/W Junction-to-ambient thermal resistance RӨJA 66 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode CONDITIONS SK34A-T SK36A-T (1) TYP MAX UNIT - 0.55 V - 0.72 V - 0.85 V TJ = 25°C - 0.5 mA TJ = 100°C - 10.0 mA TJ = 125°C - - mA TJ = 25°C - 0.2 mA - 5.0 mA TJ = 125°C - 10.0 mA TJ = 25°C - 0.1 mA TJ = 100°C - - mA TJ = 125°C - 0.5 mA IF = 3A, TJ=25°C SYMBOL VF SK310A-T SK34A-T Reverse current @ rated VR per diode SK36A-T (2) SK310A-T TJ = 100°C IR Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms ORDERING INFORMATION PART NO. PACKING CODE SK3xxA-T (Note 1, 2) R3 R2 PACKING CODE SUFFIX G PACKAGE PACKING SMA SMA 1,800 / 7" Plastic reel 7,500 / 13" Paper reel Notes: 1. "xx" defines voltage from 40V (SK34A-T) to 100V (SK310A-T) 2. Whole series with green compound (halogen-free) EXAMPLE P/N EXAMPLE P/N PART NO. PACKING CODE SK36A-T R3G SK36A-T R3 2 PACKING CODE SUFFIX G DESCRIPTION Green compound Version:B1702 SK34A-T - SK310A-T Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig1. Forward Current Derating Curve Fig2. Typical Junction Capacitance 1000 SK34A-T 3 SK36A-T 2.5 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 3.5 2 1.5 1 0.5 SK310A-T f=1.0MHz Vslg=50mVp-p Resistive or inductive load 0 50 60 70 80 90 10 100 110 120 130 140 150 0.1 100 Fig3. Typical Reverse Characteristics Fig4. Typical Forward Characteristics SK34A-T - SK36A-T, 100°C SK310A-T, 125°C SK36A-T, 125°C SK310A-T, 25°C 1 0.1 0.01 SK34A-T - SK36A-T, 25°C 0.001 0 10 REVERSE VOLTAGE (V) 100 10 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOU REVERSE CURRENT (mA) 100 20 40 60 80 100 100 10 SK36A-T 1 SK34A-T TJ=125°C 10 TJ=25°C 0.1 10.01 SK310A-T Pulse width 0.001 0.3 0.1 0 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) UF1DLW 0.4 0.2 0.5 0.4 0.6 0.6 0.7 0.8 Pulse width=300μs 1% duty 0.8 0.9 cycle 1 1.1 1 1.2 1.4 FORWARD VOLTAGE (V) 3 Version:B1702 1.6 1.2 SK34A-T - SK310A-T Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig5. Maximum Non-repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 70 8.3ms single half sine wave 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version:B1702 SK34A-T - SK310A-T Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) DIM Unit (mm) Unit (inch) Min Max Min Max A 1.27 1.58 0.050 0.062 B 4.06 4.60 0.160 0.181 C 2.29 2.83 0.090 0.111 D 1.99 2.50 0.078 0.098 E 0.90 1.41 0.035 0.056 F 4.95 5.33 0.195 0.210 G 0.10 0.20 0.004 0.008 H 0.15 0.31 0.006 0.012 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 1.68 0.066 B 1.52 0.060 C 3.93 0.155 D 2.41 0.095 E 5.45 0.215 MARKING DIAGRAM P/N G YW F 5 = Marking Code = Green Compound = Date Code = Factory Code Version:B1702 SK34A-T - SK310A-T Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version:B1702
SK310A-T R3G 价格&库存
很抱歉,暂时无法提供与“SK310A-T R3G”相匹配的价格&库存,您可以联系我们找货
