LFTVXO072344REEL
LFTVXO072344REEL
    IQD
LFTVXO072344REEL 数据手册
TCVCXO Specification Part No. + Packaging: LFTVXO072344Reel Customer Part: Description The IQXT-316-7 uses ASIC technology and is designed to meet the short and medium term stability requirements of packet network synchronisation for Small Cells. The oscillator has low jitter to meet network interface requirements (e.g. 10GE) and low phase noise to meet radio interface requirements of LTE-A (TS 36.104) and WCDMA (TS 25.104) transceivers. The IQXT-316-7 is the ideal choice for Small Cell synchronisation requirements. Model IQXT-316-7 Model Issue number 1 Outline (mm) Frequency Parameters Frequency 24.5760MHz Frequency Tolerance Tolerance Condition Frequency Stability ±1.00ppm @ 25°C ±1°C & VC=1.65V ±0.16ppm Operating Temperature Range -20.00 to 70.00°C Ageing @ 25°C: ±20ppb max per day ±200ppb max per month ±1ppm max per year ±2ppm max over 3yrs Acceleration Sensitivity (gamma vector of all 3 axes from 30 to 1500Hz): 2ppb/G typ Supply Voltage Variation (±2% change @ 25°C ref to frequency @ nominal Vs): ±10ppb typ Load Variation (±1pF change @ 25°C ref to frequency @ nominal load): ±10ppb typ Reflow Variation (after 1hr recovery @ 25°C): ±0.5ppm max Temperature Rate of Change (maximum rate of change of temperature condition for guaranteed stability specifications): 1°C/min max Note: The characteristics of the oscillator may be temporarily affected by the processes of assembly and soldering. The frequency specifications apply 48hrs after assembly and after the first excursion over the operating temperature range. Electrical Parameters 3.3V ±5% Supply Voltage Current Draw 6.500mA Absolute Maximum Ratings: Supply Voltage (Vs): -0.5 to 7V Control Voltage (VC): -0.5V to 9V All other inputs: -0.5 to Vs+0.5V Power Dissipation: 100mW max Junction Temperature: 150°C max Note: Operating beyond these limits may result in change or permanent damage to the oscillator. Frequency Adjustment Pulling ±5ppm to ±10ppm Control Voltage 1.65V ±1.15V Input Impedance Linearity: 1% max Slope: +7ppm/V typ Modulation Bandwidth: 1Hz min 100kΩ min Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 23:55 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 3 TCVCXO Specification Part No. + Packaging: LFTVXO072344Reel Customer Part: Output Details HCMOS Output Compatibility Drive Capability 15pF Rise and Fall Time 8.0ns max 45/55 Duty Cycle Output Voltage Levels: Output Low (VoL): 10%Vs max Output High (VoH): 90%Vs min Start Up Time (amplitude within 90% of specified output level): 15ms Output Control Tri-State Mode: Logic '0' (20%Vs max) to pad 6 disables the oscillator output, the output goes to a high impedance state. Logic '1' (60%Vs min) or no connection to pad 6 enables the oscillator output. Note: When disabled the oscillator and compensation circuit are still active (Current Consumption: 2mA typ) Output Enable Time: 100us max Noise Parameters Phase Noise @ 25°C (typ): -60dBc/Hz @ 1Hz -98dBc/Hz @ 10Hz -127dBc/Hz @ 100Hz -143dBc/Hz @ 1kHz -151dBc/Hz @ 10kHz -154dBc/Hz @ 100kHz -157dBc/Hz @ 1MHz Phase Jitter (12kHz to 5MHz): 290fs RMS typ Environmental Parameters Low Temperature Storage: IEC 60068-2-01, Test Ab: 1000hrs @ -55°C. High Temperature Storage: IEC 60068-2-02, Test Bb: 1000hrs @ 150°C. Mechanical Shock: JESD22-B104: 1500G, 0.5ms duration, 5 pulses in each of 6 directions. Vibration: JESD22-B103: 20G peak acceleration for 4hrs in each of the 3 orientations, tested from 60-2000Hz, 12hrs total. High Temperature Operating Life (HTOL): JESD22-A108: 1008hrs @ 125°C. Thermal Cycling: JESD22-A104: 500 temperature cycles, -55 to 125°C. Solderability: JESD22-B102, Method 1, Condition E: 260°C for 5secs, (preconditioning: 150°C, 16hrs). Resistance to Soldering Heat: IPC/JEDEC J-STD-020: 3 reflow cycles (peak temperature 260°C). Humidity: JESD22-A101: After 1008hrs @ 85°C, 85% RH (preconditioning: 3 reflow cycles @ peak temperature 260°C). Ageing: MIL-PRF-55310: 1008hrs @ 85°C (preconditioning: 3 reflow cycles @ peak temperature 260°C). Manufacturing Details Maximum Process Temperature: 260°C (30secs max) RoHS Terminations RoHS Reflow Temp 260°C max for 30secs max Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 23:55 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 3 TCVCXO Specification Part No. + Packaging: LFTVXO072344Reel Customer Part: Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant 1 Packaging Details Pack Style: Reel Pack Size: 500 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 23:55 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 3 of 3
LFTVXO072344REEL 价格&库存
很抱歉,暂时无法提供与“LFTVXO072344REEL”相匹配的价格&库存,您可以联系我们找货
