EA W128128-XRLB
EA W128128-XRLB
    ELECTRONICASSEMBLYGMBH
EA W128128-XRLB 数据手册
Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 1.2022 Round OLED 37mm - 128x128 dots Incl. controller SSD1327ZB Features • 1.2” Low-Power OLED • -40..+80°C (TOp.) • 128x128 dots • Incl. controller SSD1327ZB • SPI, I²C, 8-Bit Interface • Fast response time (10µs) even at -40°C • ZIFF connection • 37mm diameter Ordering code OLED 1.2” - 128x128 dots, round yellow OLED 1.2” - 128x128 dots, round white EA W128128-XRLG EA W128128-XRLW Accessory ZIFF connector 24 pins, 0.5mm pitch, bottom contact ZIFF connector 24 pins, 0.5mm pitch, top contact USB-Testboard EA WF050-24S EA WF050-24T EA 9781-2USB Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de Content 1. General Specification 2. Contour Drawing & Block Diagram 3. Interface Pin Function 4. Absolute Maximum Ratings 5. Electrical Characteristics 6. Optical Characteristics 7. OLED Lifetime 8. Reliability 9. Inspection specification 10. Precautions in use of OLED Modules 11. Initialization example 12. Application example EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 2 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 1. General Specification Item Dimension Unit 128 x 128 Dots - 37.18× 41.23 × 2.05 mm Active Area 30.00×30.00 mm Pixel Size 0.210 × 0.210 mm Pixel Pitch 0.235 × 0.235 mm Dot Matrix Module dimension Display Mode Display Color Drive Duty IC EA W128128-XR Passive Matrix EA W128128-XLG: Yellow EA W128128-XLW: White 1/128Duty SSD1327ZB Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 3 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 2. Contour Drawing & Block Diagram EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 4 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de FUNCTION BLOCK DIAGRAM EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 5 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 3. Interface Pin Function No. 1 2 3 4 5 6 7 8 9 10 11 12 13 Symbol Function VSS Ground pin. It must be connected to external ground. Power supply for panel driving voltage. This is also the most positive power voltage VCC supply pin. It is supplied by external high voltage source. COM signal deselected voltage level. VCOMH A capacitor should be connected between this pin and VSS. No external power supply is allowed to connect to this pin. Low voltage power supply and power supply for interface logic level. It should match VCI with the MCU interface voltage level and must be connected to external source. VCI must always set to be equivalent to or higher than VDD. VDD Power supply pin for core logic operation. MCU bus interface selection pins. Select appropriate logic setting as described in the following table. BS1 and BS2 are pin select. Bus Interface selection BS1 BS[2:1] Interface 00 4 line SPI 01 I2C 11 8-bit 8080 parallel 10 8-bit 6800 parallel BS2 Note (1) 0 is connected to VSS (2) 1 is connected to VCI VSS Ground pin. It must be connected to external ground. IREF This pin is the segment output current reference pin This pin is the chip select input connecting to the MCU. CS# The chip is enabled for MCU communication only when CS# is pulled LOW (active LOW). This pin is reset signal input. RES# When the pin is pulled LOW, initialization of the chip is executed. Keep this pin pull HIGH during normal operation. This pin is Data/Command control pin connecting to the MCU. When the pin is pulled HIGH, the data at D[7:0] will be interpreted as data. When the pin is pulled LOW, the data at D[7:0] will be transferred to a command D/C register. In I2C mode, this pin acts as SA0 for slave address selection. When 3-wire serial interface is selected, this pin must be connected to VSS. This pin is read / write control input pin connecting to the MCU interface. When 6800 interface mode is selected, this pin will be used as Read/Write (R/W#) selection input. Read mode will be carried out when this pin is pulled HIGH and write W/R# mode when LOW. When 8080 interface mode is selected, this pin will be the Write (WR#) input. Data write operation is initiated when this pin is pulled LOW and the chip is selected. EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 6 of 27 Zeppelinstrasse 19 14 RD# 15 16 17 18 19 20 21 22 D0 D1 D2 D3 D4 D5 D6 D7 23 VCC 24 VSS EA W128128-XR D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de This pin is MCU interface input. When 6800 interface mode is selected, this pin will be used as the Enable (E) signal. Read/write operation is initiated when this pin is pulled HIGH and the chip is selected. When 8080 interface mode is selected, this pin receives the Read (RD#) signal. Read operation is initiated when this pin is pulled LOW and the chip is selected. When serial or I2C interface is selected, this pin must be connected to VSS. These pins are bi-directional data bus connecting to the MCU data bus. Unused pins are recommended to tie LOW. When serial interface mode is selected, D0 will be the serial clock input: SCLK; D1 will be the serial data input: SDIN and D2 should be kept NC. When I2C mode is selected, D2, D1 should be tied together and serve as SDAout, SDAin in application and D0 is the serial clock input, SCL. Power supply for panel driving voltage. This is also the most positive power voltage supply pin. It is supplied by external high voltage source. Ground pin. Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 7 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 4. Absolute Maximum Ratings Parameter Symbol Min Max Unit Notes Supply Voltage for Operation VCI -0.3 4 V 1, 2 Supply Voltage for Logic VDD -0.5 2.75 V 1, 2 Supply Voltage for Display VCC -0.5 19 V 1, 2 Operating Temperature TOP -40 +80 °C - TSTG -40 +80 °C - Storage Temperature Note 1: All the above voltages are on the basis of “VSS = 0V”. Note 2: When this module is used beyond the above absolute maximum ratings, permanent breakage of the module may occur. Also, for normal operations, it is desirable to use this module under the conditions according to Section6 “Electrical Characteristics”. If this module is used beyond these conditions, malfunctioning of the module can occur and the reliability of the module may deteriorate EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 8 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 5. Electrical Characteristics Item Symbol Condition Min Typ Max Unit Supply Voltage for Logic VCI Note 2.8 3.0 3.3 V Supply Voltage for Display VCC - 14 14.5 15 V High Level Input VIH - 0.8×VCI - VCI V Low Level Input VIL - 0 - 0.2×VCI V High Level Output VOH - 0.9×VCI - VCI V Low Level Output VOL - 0 - 0.1×VDDIO V VCC =14.5V 23 24 26 mA 50% Check Board operating Current EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 9 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 http://www.lcd-module.de info@lcd-module.de 6. Optical Characteristics Item View Angle Contrast Ratio Response Time Symbol Condition Min Typ Max Unit (V)θ 160 deg (H)φ 160 deg - Dark T rise - 10 μs T fall - 10 μs Display with 50% check Board Brightness 2000:1 Yellow 100 120 cd/m² White 60 80 cd/m² CIEx(Yellow) (CIE1931) 0.45 0.47 0.49 CIEy(Yellow) (CIE1931) 0.48 0.50 0.52 CIEx(White) (CIE1931) 0.26 0.28 0.30 CIEy(White) (CIE1931) 0.30 0.32 0.34 EA W128128-XR - CR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 10 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 7. OLED Lifetime ITEM Conditions Operating Life Time Ta=25℃ / Initial 50% check board brightness Typical Value Min Typ 30,000 Hrs (Yellow) 20,000 Hrs (White) - Remark Note Notes: 1. Life time is defined the amount of time when the luminance has decayed to 50% of initial value. 4. Current consumption: within ± 50% of initial value. APPENDIX: RESIDUE IMAGE Because the pixels are lighted in different time, the luminance of active pixels may reduce or differ from inactive pixels. Therefore, the residue image will occur. To avoid the residue image, every pixel needs to be lighted up uniformly. EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 13 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 9. Inspection specification NO 01 02 03 04 Item Electrical Testing Black or white spots on OLED (display only) OLED black spots, white spots, contamination (non-display) Polarizer bubbles EA W128128-XR Criterion 1.1 Missing vertical, horizontal segment, segment contrast defect. 1.2 Missing character, dot or icon. 1.3 Display malfunction. 1.4 No function or no display. 1.5 Current consumption exceeds product specifications. 1.6 OLED viewing angle defect. 1.7 Mixed product types. 1.8 Contrast defect. 2.1 White and black spots on display ≦0.25mm, no more than three white or black spots present. 2.2 Densely spaced: No more than two spots or lines within 3mm. 3.1 Round type : As SIZE Acceptable Q following drawing TY Φ=( x + y ) / 2 Accept no Φ≦0.10 dense 2 0.10< Φ≦0.20 1 0.20< Φ≦0.25 0 0.25<Φ 3.2 Line type : (As following drawing) Length Width Acceptable Q TY --W≦0.02 Accept no dense L≦3.0 0.02<W≦0.03 2 L≦2.5 0.03<W≦0.05 --0.05<W As round type If bubbles are visible, judge using black spot specifications, not easy to find, must check in specify direction. Size Φ Φ≦0.20 0.20<Φ≦0.50 0.50<Φ≦1.00 1.00<Φ Total Q TY Acceptable Q TY Accept no dense 3 2 0 3 Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. AQL 0.65 2.5 2.5 2.5 2.5 Page 14 of 27 Zeppelinstrasse 19 NO 05 Item Scratches D-82205 Gilching Fon +49-8105-778090 http://www.lcd-module.de info@lcd-module.de Criterion Follow NO.3 OLED black spots, white spots, contamination Symbols Define: x: Chip length y: Chip width z: Chip thickness k: Seal width t: Glass thickness a: OLED side length L: Electrode pad length: AQL 6.1 General glass chip : 6.1.1 Chip on panel surface and crack between panels: 06 Chipped glass y: Chip width x: Chip length Not over viewing x≦1/8a area Not exceed 1/3k 1/2t<z≦2t x≦1/8a ☉If there are 2 or more chips, x is total length of each chip. z: Chip thickness Z≦1/2t 2.5 6.1.2 Corner crack: y: Chip width x: Chip length Not over viewing x≦1/8a area Not exceed 1/3k 1/2t<z≦2t x≦1/8a ☉If there are 2 or more chips, x is the total length of each chip. z: Chip thickness Z≦1/2t EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 15 of 27 Zeppelinstrasse 19 NO Item D-82205 Gilching Fon +49-8105-778090 Criterion Symbols : x: Chip length y: Chip width z: Chip thickness k: Seal width t: Glass thickness a: OLED side length L: Electrode pad length 6.2 Protrusion over terminal : 6.2.1 Chip on electrode pad : y: Chip width x: Chip length y≦0.5mm x≦1/8a 6.2.2 Non-conductive portion: 06 http://www.lcd-module.de info@lcd-module.de AQL z: Chip thickness 0 < z≦t Glass crack 2.5 y: Chip width x: Chip length z: Chip thickness y≦ L x≦1/8a 0 < z≦t ☉If the chipped area touches the ITO terminal, over 2/3 of the ITO must remain and be inspected according to electrode terminal specifications. ☉If the product will be heat sealed by the customer, the alignment mark not be damaged. 6.2.3 Substrate protuberance and internal crack. y: width y≦1/3L EA W128128-XR x: length x≦a Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 16 of 27 Zeppelinstrasse 19 NO 07 08 09 10 11 Item Cracked glass Backlight elements D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de Criterion AQL The OLED with extensive crack is not acceptable. 2.5 8.1 Illumination source flickers when lit. 8.2 Spots or scratched that appear when lit must be judged. Using OLED spot, lines and contamination standards. 8.3 Backlight doesn’t light or color wrong. 0.65 2.5 0.65 Bezel 9.1 Bezel may not have rust, be deformed or have fingerprints, stains or other contamination. 9.2 Bezel must comply with job specifications. 2.5 PCB、COB 10.1 COB seal may not have pinholes larger than 0.2mm or contamination. 10.2 COB seal surface may not have pinholes through to the IC. 10.3 The height of the COB should not exceed the height indicated in the assembly diagram. 10.4 There may not be more than 2mm of sealant outside the seal area on the PCB. And there should be no more than three places. 10.5 No oxidation or contamination PCB terminals. 10.6 Parts on PCB must be the same as on the production characteristic chart. There should be no wrong parts, missing parts or excess parts. 10.7 The jumper on the PCB should conform to the product characteristic chart. 10.8 If solder gets on bezel tab pads, OLED pad, zebra pad or screw hold pad, make sure it is smoothed down. 11.1 No un-melted solder paste may be present on the PCB. 11.2 No cold solder joints, missing solder connections, oxidation or icicle. 11.3 No residue or solder balls on PCB. 11.4 No short circuits in components on PCB. 2.5 2.5 Soldering EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. 2.5 0.65 2.5 0.65 2.5 2.5 0.65 0.65 2.5 2.5 0.65 Page 17 of 27 Zeppelinstrasse 19 NO 12 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de Item Criterion AQL 2.5 General appearance 12.1 No oxidation, contamination, curves or, bends on interface Pin (OLB) of TCP. 12.2 No cracks on interface pin (OLB) of TCP. 12.3 No contamination, solder residue or solder balls on product. 12.4 The IC on the TCP may not be damaged, circuits. 12.5 The uppermost edge of the protective strip on the interface pin must be present or look as if it cause the interface pin to sever. 12.6 The residual rosin or tin oil of soldering (component or chip component) is not burned into brown or black color. 12.7 Sealant on top of the ITO circuit has not hardened. 12.8 Pin type must match type in specification sheet. 12.9 OLED pin loose or missing pins. 12.10 Product packaging must the same as specified on packaging specification sheet. 12.11 Product dimension and structure must conform to product specification sheet. EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. 0.65 2.5 2.5 2.5 2.5 2.5 0.65 0.65 0.65 0.65 Page 18 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 Check Item Classification No Display Major Missing Line Major Pixel Short Major Darker Short Major Wrong Display Major Un-uniform B/A x 100% < 70% A/C x 100% < 70% Major EA W128128-XR info@lcd-module.de http://www.lcd-module.de Criteria Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 19 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de 10. Precautions in use of OLED Modules Modules (1) Avoid applying excessive shocks to module or making any alterations or modifications to it. (2) Don’t make extra holes on the printed circuit board, modify its shape or change the components of OLED display module. (3) Don’t disassemble the OLED display module. (4) Don’t operate it above the absolute maximum rating. (5) Don’t drop, bend or twist OLED display module. (6) Soldering: only to the I/O terminals. (7) Storage: please storage in anti-static electricity container and clean environment. (8) It's pretty common to use "Screen Saver" to extend the lifetime and don't use fix information for long time in real application. (9) Don't use fixed information in OLED panel for long time that will extend "screen burn" effect time. (10) ELECTRONIC ASSEMBLY has the right to change the passive components, including R2and R3 adjust resistors. (Resistors, capacitors and other passive components will have different appearance and color caused by the different supplier.) (11) ELECTRONIC ASSEMBLY have the right to change the PCB Rev. (In order to satisfy the supplying stability, management optimization and the best product performance... etc, under the premise of not affecting the electrical characteristics and external dimensions, ELECTRONIC ASSEMBLY have the right to modify the version.) 10.1. Handling Precautions (1) Since the display panel is being made of glass, do not apply mechanical impacts such us dropping from a high position. (2) If the display panel is broken by some accident and the internal organic substance leaks out, be careful not to inhale nor lick the organic substance. (3) If pressure is applied to the display surface or its neighborhood of the OLED display module, the cell structure may be damaged and be careful not to apply pressure to these sections. (4) The polarizer covering the surface of the OLED display module is soft and easily scratched. Please be careful when handling the OLED display module. (5) When the surface of the polarizer of the OLED display module has soil, clean the surface. It takes advantage of by using following adhesion tape. * Scotch Mending Tape No. 810 or an equivalent Never try to breathe upon the soiled surface nor wipe the surface using cloth containing solvent such as ethyl alcohol, since the surface of the polarizer will become cloudy. Also, pay attention that the following liquid and solvent may spoil the polarizer: * Water * Ketone * Aromatic Solvents (6) Hold OLED display module very carefully when placing OLED display module into the system housing. Do not apply excessive stress or pressure to OLED display module. And, do not over bend the film with electrode pattern layouts. These stresses will influence the display performance. Also, secure sufficient rigidity for the EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 20 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de outer cases. (7) Do not apply stress to the LSI chips and the surrounding molded sections. (8) Do not disassemble nor modify the OLED display module. (9) Do not apply input signals while the logic power is off. (10) Pay sufficient attention to the working environments when handing OLED display modules to prevent occurrence of element breakage accidents by static electricity. * Be sure to make human body grounding when handling OLED display modules. * Be sure to ground tools to use or assembly such as soldering irons. * To suppress generation of static electricity, avoid carrying out assembly work under dry environments. * Protective film is being applied to the surface of the display panel of the OLED display module. Be careful since static electricity may be generated when exfoliating the protective film. (11) Protection film is being applied to the surface of the display panel and removes the protection film before assembling it. At this time, if the OLED display module has been stored for a long period of time, residue adhesive material of the protection film may remain on the surface of the display panel after removed of the film. In such case, remove the residue material by the method introduced in the above Section 5. (12) If electric current is applied when the OLED display module is being dewed or when it is placed under high humidity environments, the electrodes may be corroded and be careful to avoid the above. 10.2. Storage Precautions (1) When storing OLED display modules, put them in static electricity preventive bags avoiding exposure to direct sun light nor to lights of fluorescent lamps. and, also, avoiding high temperature and high humidity environment or low temperature (less than 0°C) environments. (We recommend you to store these modules in the packaged state when they were shipped from ELECTRONIC ASSEMBLY. At that time, be careful not to let water drops adhere to the packages or bags nor let dewing occur with them. (2) If electric current is applied when water drops are adhering to the surface of the OLED display module, when the OLED display module is being dewed or when it is placed under high humidity environments, the electrodes may be corroded and be careful about the above. 10.3. Designing Precautions (1) The absolute maximum ratings are the ratings which cannot be exceeded for OLED display module, and if these values are exceeded, panel damage may be happen. EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 21 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de (2) To prevent occurrence of malfunctioning by noise, pay attention to satisfy the VIL and VIH specifications and, at the same time, to make the signal line cable as short as possible. (3) We recommend you to install excess current preventive unit (fuses, etc.) to the power circuit (VDD). (Recommend value: 0.5A) (4) Pay sufficient attention to avoid occurrence of mutual noise interference with the neighboring devices. (5) As for EMI, take necessary measures on the equipment side basically. (6) When fastening the OLED display module, fasten the external plastic housing section. (7) If power supply to the OLED display module is forcibly shut down by such errors as taking out the main battery while the OLED display panel is in operation, we cannot guarantee the quality of this OLED display module. * Connection (contact) to any other potential than the above may lead to rupture of the IC. 10.4. Precautions when disposing of the OLED display modules 1) Request the qualified companies to handle industrial wastes when disposing of the OLED display modules. Or, when burning them, be sure to observe the environmental and hygienic laws and regulations. 10.5. Other Precautions (1) When an OLED display module is operated for a long of time with fixed pattern may remain as an after image or slight contrast deviation may occur. Nonetheless, if the operation is interrupted and left unused for a while, normal state can be restored. Also, there will be no problem in the reliability of the module. (2) To protect OLED display modules from performance drops by static electricity rapture, etc., do not touch the following sections whenever possible while handling the OLED display modules. * Pins and electrodes * Pattern layouts such as the TCP & FPC (3) With this OLED display module, the OLED driver is being exposed. Generally speaking, semiconductor elements change their characteristics when light is radiated according to the principle of the solar battery. Consequently, if this OLED driver is exposed to light, malfunctioning may occur. * Design the product and installation method so that the OLED driver may be shielded from light in actual usage. * Design the product and installation method so that the OLED driver may be shielded from light during the inspection processes. (4) Although this OLED display module stores the operation state data by the commands and the indication data, when excessive external noise, etc. enters into the module, the internal status may be changed. It therefore is necessary to take appropriate measures to suppress noise generation or to protect from influences of noise on the system design. (5) We recommend you to construct its software to make periodical refreshment of the operation statuses (re-setting of the commands and re-transference of the display data) to cope with catastrophic noise. (6) Resistors, capacitors and other passive components will have different appearance and color caused by the different supplier. EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 22 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de (7) Our company will has the right to upgrade and modify the product function. (8) The limitation of FPC bending 10.6. Precautions when disposing of the OLED display modules (1) Request the qualified companies to handle industrial wastes when disposing of the OLED display modules. Or, when burning them, be sure to observe the environmental and hygienic laws and regulations. EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 23 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 http://www.lcd-module.de info@lcd-module.de 11. Initialization example /********************************************************************************* Global variables *********************************************************************************/ uint8_t buf[20]; //SPI command buffer uint8_t buffer[8192]; //SPI data buffer const uint8_t lookupval[4] = {0x0,0xF,0xF0,0xFF}; //lookup table /********************************************************************************* Function name: initW128128 Description: Initialization of the display *********************************************************************************/ void initW128128(void){ uint16_t i = 0; PORT5.PODR.BIT.B5 = 0; ms_delay(100); PORT5.PODR.BIT.B5 = 1; ms_delay(100); //Reset pin low //100ms delay //Reset pin high //100ms delay buf[i++] = 0xA4; //set normal display mode buf[i++] = 0x81; buf[i++] = 0x7F; //Set contrast to 0x7F (default) buf[i++] = 0xB3; buf[i++] = 0x40; //clock divider/oscillator frequency buf[i++] = 0xAF; //Display on buf[i++] = 0xA0; //set memory addressing mode ... buf[i++] = 0x51; //... to horizontal address increment //..enable column address remap //...enable COM remap //...enable COM split odd even buf[i++] = 0xA1; buf[i++] = 0x00; //set display start line to 0 waitforemptybuffer(); //Waits until SPI buffer is empty PORT5.PODR.BIT.B4 = 0; R_RSPI0_Send(buf,i); //D/C# pin low //send initialization buffer via SPI } EA W128128-XR Printing and typographical errors reserved. ELECTRONIC ASSEMBLY reserves the right to change specification without prior note. Page 24 of 27 Zeppelinstrasse 19 D-82205 Gilching Fon +49-8105-778090 info@lcd-module.de http://www.lcd-module.de /********************************************************************************* Function name: initWindow Description: Initialization of the window in horizontal addressing mode *********************************************************************************/ void initWindow(uint8_t startcol, uint8_t stopcol, uint8_t startrow, uint8_t stoprow){ uint16_t i = 0; buf[i++] = 0x15; buf[i++] = startcol; buf[i++] = stopcol; //set column address //start address //end address buf[i++] = 0x75; buf[i++] = startrow; buf[i++] = stoprow; //set page address //start page //stop page waitforemptybuffer(); PORT5.PODR.BIT.B4 = 0; //waits until SPI buffer is empty //set D/C# pin low R_RSPI0_Send(buf,i); //send data buffer via SPI } /********************************************************************************* Function name: sendDataW128128 Description: Sends data to the display (Initialization of the window before sending data to the display -> initWindow() Display controller provides 4Bit grayscale -> function only use monochrome data *********************************************************************************/ void sendDataW128128 (const uint8_t *tx_buf, uint16_t tx_num){ uint16_t i,j; uint16_t count = 0; uint8_t byte; //convert monochrome pixel data to 4Bit grayscale 0->0000; 1->1111 //see example below for(i=0;i6]; byte = byte
EA W128128-XRLB 价格&库存
很抱歉,暂时无法提供与“EA W128128-XRLB”相匹配的价格&库存,您可以联系我们找货
