BZX84C2V7 RFG
BZX84C2V7 RFG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT23-3
BZX84C2V7 RFG 数据手册
BZX84C2V4- BZX84C39 Taiwan Semiconductor Small Signal Product Surface Mount Zener Diode FEATURES - Zener voltages from : 2.4V - 39V - Planar die construction - Ideally suited for automated assembly processes - Moisture sensitivity : Level 1 per J-STD-020 MECHANICAL DATA SOT-23 - Case : SOT-23, molding plastic - Case material - UL flammibility rating 94V-0 - Polarity : See diagram - Lead free plating - Marking : Marking code - Weight : 0.008 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted) PARAMETER Power Dissipation Forward Voltage IF = 10 mA Thermal Resistance (Junction to Ambient) Junction and Storage Temperature Range (Note 1) SYMBOL PD VALUE UNIT 300 mW VF 0.9 RθJA 417 TJ, TSTG - 65 to +150 V o C/W o C Note 1: Valid provided that device terminals are kept at ambient temerature . Version: E1604 BZX84C2V4-BZX84C39 Taiwan Semiconductor Small Signal Product ELECTRICAL CHARACTERISTICS ( TA= 25oC unless otherwise noted ) Zener Voltage Range (Note 2) Type Number (Note 1) Marking code Nom Min Max BZX84C2V4 Z11 2.4 2.2 2.6 BZX84C2V7 Z12 2.7 2.5 BZX84C3V0 Z13 3.0 2.8 BZX84C3V3 Z14 3.3 BZX84C3V6 Z15 3.6 BZX84C3V9 Z16 BZX84C4V3 Z17 BZX84C4V7 BZX84C5V1 VZ @ IZT Maximum Zener Impedance (Note 3) IZT ZZK @ IZK Maximum Reverse Current IR Typical Temperature Coefficient @ IZT (mV/oC) VR mA ZZT @ IZT Ohms Ohms mA μA V Min Max 5 100 600 1.0 50 1.0 -3.5 0 2.9 5 100 600 1.0 20 1.0 -3.5 0 3.2 5 95 600 1.0 10 1.0 -3.5 0 3.1 3.5 5 95 600 1.0 5.0 1.0 -3.5 0 3.4 3.8 5 90 600 1.0 5.0 1.0 -3.5 0 3.9 3.7 4.1 5 90 600 1.0 3.0 1.0 -3.5 0 4.3 4.0 4.6 5 90 600 1.0 3.0 1.0 -3.5 0.0 Z1 4.7 4.4 5.0 5 80 500 1.0 3.0 2.0 -3.5 0.2 Z2 5.1 4.8 5.4 5 60 480 1.0 2.0 2.0 -2.7 1.2 BZX84C5V6 Z3 5.6 5.2 6.0 5 40 400 1.0 1.0 2.0 -2.0 2.5 BZX84C6V2 Z4 6.2 5.8 6.6 5 10 150 1.0 3.0 4.0 0.4 3.7 BZX84C6V8 Z5 6.8 6.4 7.2 5 15 80 1.0 2.0 4.0 1.2 4.5 BZX84C7V5 Z6 7.5 7.0 7.9 5 15 80 1.0 1.0 5.0 2.5 5.3 BZX84C8V2 Z7 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.1 BZX84C9V1 Z8 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 BZX84C10 Z9 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 BZX84C11 Y1. 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 BZX84C12 Y2. 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6 10.0 BZX84C13 Y3 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7 11.0 BZX84C15 Y4 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 BZX84C16 Y5 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 BZX84C18 Y6 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 BZX84C20 Y7 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 BZX84C22 Y8 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 BZX84C24 Y9 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 BZX84C27 Y10 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 BZX84C30 Y11 30 28 32 2 80 300 0.5 0.1 21.0 24.4 29.4 BZX84C33 Y12 33 31 35 2 80 325 0.5 0.1 23.1 27.4 33.4 BZX84C36 Y13 36 34 38 2 90 350 0.5 0.1 25.2 30.4 37.4 BZX84C39 Y14 39 37 41 2 130 350 0.5 0.1 27.3 33.4 41.2 Notes: 1. Valid provided that device terminals are kept at ambient temerature. 2. Tested with pulses period = 5 ms, pulse width = 300 μs 3. f = 1KHz Version: E1604 BZX84C2V4 -BZX84C39 Taiwan Semiconductor Small Signal Product RATINGS AND CHARACTERISTICS CURVES (TA=25℃ unless otherwise noted) Fig. 2 Zener Breakdown Characteristics Fig. 1 Power Derating Curve 50 PD - Power Passipation (mW) 500 C2V7 Tj=25o C3V9 C5V6 40 IZ , Zener Current (mA) 400 300 200 100 C3V3 30 C4V7 C6V8 C8V2 Test Current IZ 5.0 mA 20 10 line 7 0 0 100 0 200 0 1 TA , Ambient Temperature (oC) 2 3 4 5 6 7 8 9 10 VZ - Zener Voltage (V) Fig. 3 line 1 line 2 Fig. 4 Junction Capacitance VS. Nomial Zener Fig. 3 Zener Breakdown Characteristics 30 line 3 1000 C10 Tj=25oC C12 Test Current IZ 2 mA IZ, Zener Current (mA) C15 20 Test Current IZ 5 mA 10 C1 C22 C27 C33 C36 C39 0 0 10 20 VZ - Zener Voltage (V) 30 40 CJ, Junction Capacitance (pF) Tj=25oC line 4 VR = 1 V line 5 VR = 2 100 line 6 VR = 1 V line 7 VR = 2 V 10 1.0 10.0 100.0 VZ - Nominal Zener Voltage (V) line 8 line 9 Fig. 4 line 1 line 1 end line 2 line 2 end line 3 head Version: E1604 BZX84C2V4 - BZX84C39 Taiwan Semiconductor Small Signal Product ORDERING INFORMATION PART NO. PACKING CODE PACKAGE PACKING BZX84Cxxx (Note1) RF SOT-23 3K / 7" Reel Note 1: "xxx" defines voltage from 2.4V (BZX84C2V4) to 39V (BZX84C39) EXAMPLE EXAMPLE P/N PART NO. PACKING CODE DESCRIPTION BZX84C39 RFG BZX84C39 RF Green compound PACKAGE OUTLINE DIMENSION A F DIM. B E G C D H Unit (mm) Unit (inch) Min Max Min Max A 2.70 3.10 0.106 0.122 B 1.10 1.50 0.043 0.059 C 0.30 0.51 0.012 0.020 D 1.78 2.04 0.070 0.080 E 2.10 2.64 0.083 0.104 F G 0.89 1.30 0.55 REF 0.035 0.051 0.022 REF H 0.10 REF 0.004 REF Unit (mm) Unit (inch) SUGGEST PAD LAYOUT DIM. Typ. Typ. Z 2.90 0.114 X 0.80 0.031 Y 0.90 0.035 C 2.00 0.079 E 1.35 0.053 Version: E1604 BZX84C2V4 - BZX84C39 Taiwan Semiconductor Small Signal Product Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: E1604
BZX84C2V7 RFG 价格&库存
很抱歉,暂时无法提供与“BZX84C2V7 RFG”相匹配的价格&库存,您可以联系我们找货
BZX84C2V7 RFG
  • 3000+0.442773000+0.05745
  • 6000+0.396406000+0.05144
  • 9000+0.372729000+0.04836
  • 15000+0.3461015000+0.04491
  • 21000+0.3303321000+0.04286
  • 30000+0.3149930000+0.04087
库存:4900
BZX84C2V7 RFG
  • 1+2.202671+0.28580
  • 10+1.3375610+0.17355
  • 100+0.82808100+0.10745
  • 500+0.60664500+0.07871
  • 1000+0.534581000+0.06936
库存:4900
