SMD1210 SERIES
Positive Temperature Coefficient (PTC) Data Sheet
Description
The 1210 series provides miniature surface mount resettable overcurrent protection
with holding current from 0.05A to 2.0A. This series is suitable for wide range of
applications in modern electronics where space is limited.
Features
RoHS compliant and lead-free
Fast response to fault current
Halogen-free
UL/CULE482628
RoHS2011/65/EU
Low profile
Compatible with high temperature solders
Compact design saves board space
TUV B160696048001
Halogen FreeEN 14582:2007
Applications
■ USB hubs, ports and peripherals
■ Set-top-box and HDMI
■ Game console port protection
■ Motherboard USB & IEEE 1394 protection
■ Optical disk drives
■ General electronics
Part Number Code and Marking
SMD 1210 B
TF T /
Special Voltage Rating (Optional)
Thickness Version (Optional)
Lead-Free
Holding Current Rating
Delimiter
Device Dimensions: Length/Width (Unit: 1/100 inch)
Surface Mount Device
Part Number
Marking
Part Number
Marking
Part Number
Marking
SMD1210B005TF
005
SMD1210B075TF
07
SMD1210B150TFT
15
SMD1210B010TF
010
SMD1210B075TF/24
075
SMD1210B150TF/12
52
SMD1210B020TF
02
SMD1210B110TFT
10
SMD1210B150TF/16
56
SMD1210B035TF
03
SMD1210B110TF/12
12
SMD1210B175TF
17
SMD1210B050TF
05
SMD1210B110TF/16
16
SMD1210B200TF
Revision:PPTC-SMD1210 SERIES-001(A2)
http://brightking.pulseelectronics.com
SMD1210 SERIES
Dimensions and PAD-SIZE
C
A
BK Logo
B
Part identification
D
A
E
B
C
D
E
Part
Number
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
Min.
Max.
SMD1210B005TF
3.00
3.43
2.35
2.80
0.75
1.25
0.25
0.75
0.10
0.50
SMD1210B010TF
3.00
3.43
2.35
2.80
0.75
1.25
0.25
0.75
0.10
0.50
SMD1210B020TF
3.00
3.43
2.35
2.80
0.60
1.00
0.25
0.75
0.10
0.50
SMD1210B035TF
3.00
3.43
2.35
2.80
0.50
0.85
0.25
0.75
0.10
0.50
SMD1210B050TF
3.00
3.43
2.35
2.80
0.50
0.85
0.25
0.75
0.10
0.50
SMD1210B075TF
3.00
3.43
2.35
2.80
0.30
0.85
0.25
0.75
0.10
0.50
SMD1210B075TF/24
3.00
3.43
2.35
2.80
1.20
1.80
0.25
0.75
0.10
0.50
SMD1210B110TFT
3.00
3.43
2.35
2.80
0.30
0.85
0.25
0.75
0.10
0.50
SMD1210B110TF/12
3.00
3.43
2.35
2.80
0.50
1.25
0.25
0.75
0.10
0.50
SMD1210B110TF/16
3.00
3.43
2.35
2.80
0.50
1.25
0.25
0.75
0.10
0.50
SMD1210B150TFT
3.00
3.43
2.35
2.80
0.75
1.07
0.25
0.75
0.10
0.50
SMD1210B150TF/12
3.00
3.43
2.35
2.80
0.75
1.80
0.25
0.75
0.10
0.50
SMD1210B150TF/16
3.00
3.43
2.35
2.80
0.75
1.80
0.25
0.75
0.10
0.50
SMD1210B175TF
3.00
3.43
2.35
2.80
0.80
1.60
0.25
0.75
0.10
0.50
SMD1210B200TF
3.00
3.43
2.35
2.80
0.80
1.60
0.25
0.75
0.10
0.50
Recommended Pad Layout (mm)
2.50typ.
2.00typ.
1.00typ.
1.00typ.
Electrical Characteristics
Part
Number
Ihold
(A)
Itrip
(A)
Vmax
(Vdc)
Imax
(A)
Pd typ.
(W)
SMD1210B005TF
0.05
0.15
30.0
10
SMD1210B010TF
0.10
0.30
30.0
SMD1210B020TF
0.20
0.40
SMD1210B035TF
0.35
SMD1210B050TF
SMD1210B075TF
Maximum
Time To Trip
Resistance
Time
(Sec.)
Current
(A)
Rmin
(Ω)
R1max
(Ω)
0.60
1.50
0.25
3.60
50.0
10
0.60
1.50
0.50
1.60
15.0
30.0
10
0.60
0.02
8.00
0.80
5.00
0.70
6.0
100
0.60
0.20
8.00
0.32
1.30
0.50
1.00
13.2
100
0.60
0.05
8.00
0.25
0.90
0.75
1.50
6.0
100
0.60
0.10
8.00
0.07
0.40
SMD1210 SERIES
Part
Number
Ihold
(A)
Itrip
(A)
Vmax
(Vdc)
Imax
(A)
Pd typ.
(W)
SMD1210B075TF/24
0.75
1.50
24
100
SMD1210B110TFT
1.10
2.20
8
SMD1210B110TF/12
1.10
2.20
SMD1210B110TF/16
1.10
SMD1210B150TFT
Maximum
Time To Trip
Resistance
Time
(Sec.)
Current
(A)
Rmin
(Ω)
R1max
(Ω)
0.6
0.1
8.0
0.070
0.400
100
0.6
0.3
8.0
0.050
0.210
12
100
0.6
0.3
8.0
0.050
0.210
2.20
16
100
0.6
0.3
8.0
0.050
0.210
1.50
3.00
6
100
0.8
0.3
8.0
0.030
0.120
SMD1210B150TF/12
1.50
3.00
12
100
0.8
0.3
8.0
0.030
0.120
SMD1210B150TF/16
1.50
3.00
16
100
0.8
0.3
8.0
0.030
0.120
SMD1210B175TF
1.75
3.50
6
100
0.8
1.0
8.0
0.020
0.080
SMD1210B200TF
2.00
4.00
6
100
0.8
1.0
8.0
0.015
0.075
Note on Electrical Characteristics
■ Vocabulary
·Ihold = Hold current: maximum current device will pass without tripping in 23℃ still air.
·Itrip = Trip current: minimum current at which the device will trip in 23℃ still air.
·Vmax = Maximum voltage device can withstand without damage at rated current (Imax)
·Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax)
·Pd typ. = Typical power dissipated from device when in the tripped state at 23℃ still air.
·Rmin = Minimum resistance of device in initial (un-soldered) state.
·R1max = Maximum resistance of device at 23℃ measured one hour after tripping or reflow soldering of 260℃ for 20 sec.
■ Value specified is determined by using the PWB with 0.090”*1.5oz copper traces.
■ Caution: Operation beyond the specified rating may result in damage and possible arcing and flame.
SMD1210 SERIES
Polymeric PTC Selecting Guide
■ Determine the following operating parameters for the circuits:
·Normal operating current (Ihold)
·Maximum interrupt current (Imax)
·Maximum circuit voltage (Vmax)
·Normal operating temperature surrounding device (min℃/max℃)
■ Select the device from factor and dimension suitable for the application
■ Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make sure
the circuit’s requirement does not exceed the device rating.
■ Check that PPTC device’s trip time (time-to-trip) will protect the circuit.
■ Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range.
■ Verify that performance and suitability of the chosen PPTC device in the application.
! WARNING
■ Mechanical Stress
·PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application
where the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate
materials and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and
other kinds of mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied.
■ Chemical Pollutants
·Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices,
■ Electronic and Thermal Effect
·PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature
error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by,
among others, incorrect pin-connection of a connector) or over-extensive trip events may occur.
·PPTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open
circuit, in which case the voltage at such PPTC devices may reach a hazardous level.
·Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to
the PPTC devices.
·Conductive material contamination, such as metal particle, may induce shortage, flame or arcing.
·Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices,
which shall not be used under such circumstances.
■ General
·Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual
applications will be met.
·The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or
mechanical procedures and/or conditions non-conformant to those recommended by manufacturer.
·Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection
To avoid or minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices.
·Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with.
SMD1210 SERIES
Thermal Derating Curve
Percentage of Rated Current
200.00
150.00
100.00
50.00
0.00
-40.00
0.00
40.00
80.00
120.00
Device Ambient Temperature (℃)
Thermal Derating Chart
Recommended Hold Current (A) at Ambient Temperature (℃)
Ambient Operation Temperature
Part
Number
-40℃
-20℃
0℃
23℃
40℃
50℃
60℃
70℃
85℃
SMD1210B005TF
0.08
0.07
0.06
0.05
0.04
0.04
0.03
0.03
0.02
SMD1210B010TF
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.05
SMD1210B020TF
0.29
0.26
0.22
0.20
0.16
0.14
0.13
0.11
0.08
SMD1210B035TF
0.47
0.45
0.40
0.35
0.33
0.28
0.24
0.21
0.18
SMD1210B050TF
0.76
0.67
0.58
0.50
0.43
0.40
0.36
0.32
0.28
SMD1210B075TF
1.00
0.97
0.86
0.75
0.64
0.59
0.54
0.48
0.40
SMD1210B075TF/24
1.00
0.97
0.86
0.75
0.64
0.59
0.54
0.48
0.40
SMD1210B110TFT
1.60
1.42
1.26
1.10
0.94
0.86
0.80
0.70
0.58
SMD1210B110TF/12
1.60
1.42
1.26
1.10
0.94
0.86
0.80
0.70
0.58
SMD1210B110TF/16
1.60
1.42
1.26
1.10
0.94
0.86
0.80
0.70
0.58
SMD1210B150TFT
2.30
2.02
1.76
1.50
1.24
1.11
1.00
0.85
0.65
SMD1210B150TF/12
2.30
2.02
1.76
1.50
1.24
1.11
1.00
0.85
0.65
SMD1210B150TF/16
2.30
2.02
1.76
1.50
1.24
1.11
1.00
0.85
0.65
SMD1210B175TF
2.45
2.22
2.01
1.75
1.45
1.26
1.10
0.98
0.80
SMD1210B200TF
2.60
2.44
2.35
2.00
1.78
1.67
1.50
1.45
1.10
SMD1210 SERIES
Average Time-Current Curve
A
100
B C
DE
F
GH
IJ
A-SMD1210B005TF
B-SMD1210B010TF
C-SMD1210B020TF
D-SMD1210B035TF
E-SMD1210B050TF
F-SMD1210B075TF
SMD1210B075TF/24
G-SMD1210B110TFT
SMD1210B110TF/12
SMD1210B110TF/16
Time to Trip (s)
10
1
H-SMD1210B150TFT
SMD1210B150TF/12
0.1
SMD1210B150TF/16
I-SMD1210B175TF
J-SMD1210B200TF
0.01
1
Fault Current (A)
0.1
10
Soldering Parameters
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TS max to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (TS min to TS max)
150℃
200℃
60-180 seconds
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
20-40 seconds
SMD1210 SERIES
Profile Feature
Pb-Free Assembly
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
0℃~35℃, ≤70%RH
Storage Condition
·Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free
·Recommended maximum paste thickness is 0.25mm (0.010 inch)
·Device can be cleaned using standard industry methods and solvents.
Note 1: All temperature refer to topside of the package, measured on the package body surface.
Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance
requirements.
Environmental Specifications
Operating / Storage temperature
-40℃ to +85℃
Maximum Device Surface Temperature in Tripped State
125℃
Passive Aging
+85℃, 1000 hours
±50% typical resistance change
Humidity Aging
+85℃, 85%RH, 1000 hours
Thermal Shock
MIL-STD-202, Method 107G
+85℃/-40℃ 20 times
-50% typical resistance change
Solvent Resistance
MIL-STD-202, Method 215
No change
Vibration
MIL-STD-883C, Method 2007.1, Condition A
No change
Moisture Level Sensitivity
Level 1, J-STD-020C
Physical Specifications
Terminal Material
Solder-Plated Copper (Solder Material: Matte Tin (Sn))
Terminal Solderability
Meets EIA Specification RS186-9E, ANSI/J-STD-002 Category 3.
SMD1210 SERIES
Packaging
Part Number
Quantity
Part Number
Quantity
Part Number
Quantity
SMD1210B005TF
3000
SMD1210B075TF
4000
SMD1210B150TFT
3000
SMD1210B010TF
3000
SMD1210B075TF/24
2000
SMD1210B150TF/12
2000
SMD1210B020TF
4000
SMD1210B110TFT
4000
SMD1210B150TF/16
2000
SMD1210B035TF
4000
SMD1210B110TF/12
3000
SMD1210B175TF
3000
SMD1210B050TF
4000
SMD1210B110TF/16
3000
SMD1210B200TF
2000
◎ 8mm tape on 7 inch reel per EIA-481 (equivalent to IEC286, part 3)
Tape
Dimensions (mm)
B020TF
B035TF
B050TF
B075TF
B110TFT
B150TFT
B005TF
B010TF
B110TF/12
B110TF/16
B175TF
B075TF/24
W
8.00±0.30
8.00±0.30
8.00+0.30/-0.10
F
3.50±0.05
3.50±0.05
3.50±0.05
E
1.75±0.10
1.75±0.10
1.75±0.10
D0
1.55±0.05
1.55±0.05
1.55±0.05
D1
1.00(MIN)
1.00(MIN)
1.00+0.25/-0
P0
4.00±0.10
4.00±0.10
4.00±0.10
P1
4.00±0.10
4.00±0.10
4.00±0.10
P2
2.00±0.05
2.00±0.05
2.00±0.05
A0
2.82±0.10
2.82±0.10
2.82±0.10
B0
3.46±0.10
3.50±0.10
3.50±0.10
T
0.25±0.10
0.20±0.10
0.25±0.10
K0
1.00±0.10
1.30±0.10
1.80±0.10
Leader min.
390
390
390
Trailer min.
160
160
160
Symbol
P0
D0
T
E
P2
B0
W
F
P1
D1
K0
A0
Reel
C
Φ178.0±1.0
D
Φ60.2±0.5
H
11.0±0.5
W
9.0±1.5
B150TF/12
B150TF/16
B200TF
