6220UL 002500
6220UL 002500
    BELDEN
6220UL 002500 数据手册
Product: 6220UL Fire Alarm, #16-2c BC, FPLP Product Description Fire Alarm Cable, Plenum-FPLP, 2-16 AWG solid bare copper conductors with Flamarrest® insulation, Flamarrest® jacket with ripcord Technical Specifications Product Overview Suitable Applications: Fire Alarm, Monitor/Detection, Circuits: Audio, Control, Initiating, Notification Construction Details Conductor Element Number of Element Size Conductor(s) 2 Stranding 16 AWG Solid Material BC - Bare Copper Insulation Element Material Nom. Thickness Nom. Insulation Diameter Color Code Conductor(s) PVC - Polyvinyl Chloride 0.008 in (0.20 mm) 0.067 in (1.7 mm) Black, Red Outer Jacket Material Nom. Thickness Nom. Diameter Ripcord PVC - Polyvinyl Chloride 0.015 in (0.38 mm) 0.166 in (4.22 mm) Yes Overall Cable Diameter (Nominal): 0.166 in (4.22 mm) Electrical Characteristics Electricals Element Nom. Conductor DCR Nom. Capacitance Cond-to-Cond Conductor(s) 3.85 Ohm/1000ft 37 pF/ft (120 pF/m) Voltage UL Voltage Rating 300 V Mechanical Characteristics Temperature UL Temperature 75°C Operating 0°C to +75°C Bend Radius Stationary Min. Installation Min. 1.32 in (33.5 mm) 1.32 in (33.5 mm) Max. Pull Tension: 62 lbs (28 kg) Bulk Cable Weight: 22 lbs/1000ft Standards and Compliance Max. Current 14.4 Amps per conductor @ 25°C Environmental Suitability: Indoor - Plenum, Indoor Flammability / Reaction to Fire: NFPA 262, UL 910 (Plenum) NEC / UL Compliance: Article 760, FPLP European Directive Compliance: EU CE Mark, EU Directive 2015/863/EU (RoHS 2 amendment), EU Directive 2011/65/EU (RoHS 2), EU Directive 2012/19/EU (WEEE) APAC Compliance: China RoHS II (GB/T 26572-2011) Other Standard Compliance(s): California State Fire Marshall Non-Plenum Number: 5220UL History Update and Revision: Revision Number: 0.397 Revision Date: 11-09-2022 Part Numbers Variants Item # Color 6220UL D15U1000 Blue UPC 612825174370 6220UL 001U1000 Brown 6220UL 003C500 Orange 612825174417 6220UL 003U1000 Orange 612825174424 6220UL 0021000 Red 612825174394 6220UL 002500 Red 612825174400 6220UL 002C500 Red 6220UL 002U1000 Red 612825174387 6220UL 007U1000 Violet 612825174455 6220UL 004C500 Yellow 612825174431 6220UL 004U1000 Yellow 612825174448 © 2023 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
6220UL 002500 价格&库存
很抱歉,暂时无法提供与“6220UL 002500”相匹配的价格&库存,您可以联系我们找货
