RP1235
RP1235
    HAMMONDMANUFACTURING
RP1235 数据手册
1/3/23, 8:54 PM Water-Tight ABS & Polycarbonate Enclosures (RP Series) - Hammond Mfg. Quality Products. Service Excellence. Water-Tight ABS & Polycarbonate Enclosures RP Series Clear Lid and Bottom Flange Options Key Features Ideally suited for mounting printed circuit boards or components. Choice of two materials: General purpose ABS with a flame rating of UL94-HB Polycarbonate with a flame rating of UL94-V2 Gasketed lid with two piece "tongue & groove" construction provides protection against access of oil, dust, and water. Rubber gasket is included and must be field installed. Lid includes smooth recessed area for membrane, label or silkscreen. Designed to meet IP 65. Lid is secured with self captivating M3.5 stainless steel machine screws (included),     threaded into corrosion resistant bushings (for repetitive assembly & disassembly). Lid screws are self captivating (lid holes are threaded with the first installation of lid screws). Internal features are maximized for mounting options: Internal DIN rail mounting tabs PC board mounting posts Options vary with size, please refer to drawings by clicking on the part numbers below. Extra self-tapping M3.5-0.6 x 10mm lid screws: SC619-50 Extra self-tapping M3 x 6mm PC Board screws: SC622-50 Opaque Lid (ABS version shown) Clear Lid (polycarbonate version shown) Shown with integral bottom flange. Some models supplied with deep lids. Hardware includes Features corrosion Internal mounting Internal DIN rail lid screws, PC board screws, and gasket resistant inserts for lid assembly points for PC boards or panels mounting point. https://www.hammfg.com/electronics/small-case/plastic/rp-rit 1/3 1/3/23, 8:54 PM Water-Tight ABS & Polycarbonate Enclosures (RP Series) - Hammond Mfg. RP Series Without Bottom Flange Light Gray ABS Plastic Light Gray ABS Plastic Off-White Polycarbonate Off-White Polycarbonate Height Length Width (Including Lid) Optional Inner Panels (Opaque Lid) (Clear Lid) (Opaque Lid) (Clear Lid) Plastic Aluminum RP1015 RP1015C RP1010 RP1010C 65 60 28 STC102 STA102 RP1025 RP1025C RP1020 RP1020C 65 60 40 STC102 STA102 RP1055 RP1055C RP1050 RP1050C 85 80 40 STC106 STA106 RP1065 RP1065C RP1060 RP1060C 85 80 55 STC106 STA106 RP1035 RP1035C RP1030 RP1030C 95 50 40 STC104 STA104 RP1045 RP1045C RP1040 RP1040C 95 50 50 STC104 STA104 RP1085 RP1085C RP1080 RP1080C 105 75 40 STC109 STA109 RP1095 RP1095C RP1090 RP1090C 105 75 55 STC109 STA109 RP1125 RP1125C RP1120 RP1120C 125 85 40 STC113 STA113 RP1135 RP1135C RP1130 RP1130C 125 85 55 STC113 STA113 RP1145 RP1145C RP1140 RP1140C 125 85 70 STC113 STA113 RP1155 RP1155C RP1150 RP1150C 125 85 85 STC113 STA113 RP1205 RP1205C RP1200 RP1200C 145 105 40 STC121 STA121 RP1215 RP1215C RP1210 RP1210C 145 105 60 STC121 STA121 RP1165 RP1165C RP1160 RP1160C 165 85 40 STC117 STA117 RP1195 RP1195C RP1190 RP1190C 165 85 70 STC117 STA117 RP1175 RP1175C RP1170 RP1170C 165 85 55 STC117 STA117 RP1185 RP1185C RP1180 RP1180C 165 85 85 STC117 STA117 RP1235 RP1235C RP1230 RP1230C 165 125 55 STC124 STA124 RP1245 RP1245C RP1240 RP1240C 165 125 75 STC124 STA124 RP1275 RP1275C RP1270 RP1270C 186 146 55 STC128 STA128 RP1285 RP1285C RP1280 RP1280C 186 146 75 STC128 STA128 RP1375 RP1375C RP1370 RP1370C 186 146 90 STC128 STA128 RP1385 RP1385C RP1380 RP1380C 186 146 110 STC128 STA128 RP1455 RP1455C RP1450 RP1450C 220 165 60 STC146 STA146 RP1465 RP1465C RP1460 RP1460C 220 165 85 STC146 STA146 not available RP1615C RP1610 RP1610C 250 200 95 STC580 STA580 not available RP1635C RP1630 RP1630C 250 200 130 STC580 STA580 RP Series With Bottom Flange Off-White Optional Inner Light Gray ABS Plastic Light Gray ABS Plastic Off White Polycarbonate Polycarbonate Opaque Lid w/ Bottom Clear Lid w/ Bottom Opaque Lid w/ Bottom Clear Lid w/ Bottom Flange Flange Flange Flange Lid) Plastic Aluminum RP1025BF RP1025BFC RP1020BF RP1020BFC 65 60 40 STC102 STA102 RP1055BF RP1055BFC RP1050BF RP1050BFC 85 80 40 STC106 STA106 RP1065BF RP1065BFC RP1060BF RP1060BFC 85 80 55 STC106 STA106 RP1035BF RP1035BFC RP1030BF RP1030BFC 95 50 40 STC104 STA104 RP1045BF RP1045BFC RP1040BF RP1040BFC 95 50 50 STC104 STA104 RP1085BF RP1085BFC RP1080BF RP1080BFC 105 75 40 STC109 STA109 RP1095BF RP1095BFC RP1090BF RP1090BFC 105 75 55 STC109 STA109 RP1125BF RP1125BFC RP1120BF RP1120BFC 125 85 40 STC113 STA113 RP1135BF RP1135BFC RP1130BF RP1130BFC 125 85 55 STC113 STA113 RP1145BF RP1145BFC RP1140BF RP1140BFC 125 85 70 STC113 STA113 RP1155BF RP1155BFC RP1150BF RP1150BFC 125 85 85 STC113 STA113 RP1205BF RP1205BFC RP1200BF RP1200BFC 145 105 40 STC121 STA121 RP1215BF RP1215BFC RP1210BF RP1210BFC 145 105 60 STC121 STA121 RP1165BF RP1165BFC RP1160BF RP1160BFC 165 85 40 STC117 STA117 RP1195BF RP1195BFC RP1190BF RP1190BFC 165 85 70 STC117 STA117 RP1175BF RP1175BFC RP1170BF RP1170BFC 165 85 55 STC117 STA117 RP1185BF RP1185BFC RP1180BF RP1180BFC 165 85 85 STC117 STA117 RP1235BF RP1235BFC RP1230BF RP1230BFC 165 125 55 STC124 STA124 RP1245BF RP1245BFC RP1240BF RP1240BFC 165 125 75 STC124 STA124 https://www.hammfg.com/electronics/small-case/plastic/rp-rit Height Panels (Including Length Width 2/3 1/3/23, 8:54 PM Water-Tight ABS & Polycarbonate Enclosures (RP Series) - Hammond Mfg. Off-White Optional Inner Light Gray ABS Plastic Light Gray ABS Plastic Off White Polycarbonate Polycarbonate Height Opaque Lid w/ Bottom Clear Lid w/ Bottom Opaque Lid w/ Bottom Clear Lid w/ Bottom Panels Flange Flange Flange Flange Lid) Plastic Aluminum RP1275BF RP1275BFC RP1270BF RP1270BFC 186 146 55 STC128 STA128 RP1285BF RP1285BFC RP1280BF RP1280BFC 186 146 75 STC128 STA128 RP1375BF RP1375BFC RP1370BF RP1370BFC 186 146 90 STC128 STA128 RP1385BF RP1385BFC RP1380BF RP1380BFC 186 146 110 STC128 STA128 (Including Length Width Mounting Feet Kits (sets of 4) Part No. Material MF0040 Polycarbonate MF0045 ABS Plastic MF0060 Polycarbonate MF0061 ABS Plastic MF0300 Style Compatible RP Series Enclosures Cross All except RP1450, 1455, 1460, 1465, Shape 1610, 1615, 1630, 1635 Cross All except RP1450, 1455, 1460, 1465, Shape 1610, 1615, 1630, 1635 Closed All except RP1450, 1455, 1460, 1465, Slot 1610, 1615, 1630, 1635 Closed All except RP1450, 1455, 1460, 1465, Slot 1610, 1615, 1630, 1635 Stainless All except RP1450, 1455, 1460, 1465, Steel 1610, 1615, 1630, 1635 MF0050 Polycarbonate Open "U" RP1450, 1455, 1460, 1465, 1610, Slot 1615, 1630 & 1635 only MF0055 ABS Plastic Open "U" RP1450, 1455, 1460, 1465, 1610, Slot 1615, 1630 & 1635 only 50-Pack of PC Board screws Part No. SC622-50 50-pack of Replacement Lid Screws Part No. SC619-50 Data subject to change without notice © 2023. Hammond Manufacturing Ltd. All rights reserved. https://www.hammfg.com/electronics/small-case/plastic/rp-rit 3/3
RP1235 价格&库存
很抱歉,暂时无法提供与“RP1235”相匹配的价格&库存,您可以联系我们找货
