BK4005DDS
BK4005DDS
    B&K
BK4005DDS 数据手册
Data Sheet 5 MHz DDS Function Generator Model 4005DDS Model 4005DDS Frequency Characteristics Waveforms Sine, Square, Triangle Range 1 Hz to 5 MHz Resolution 4 digits or 1 Hz Accuracy 0.02% (200 ppm)* Output Characteristics The B&K Precision model 4005DDS is a versatile 5 MHz DDS (direct digital synthesis) function generator with a 4-digit display. The instrument generates sinusoidal, triangular, and square waveforms over the 1 Hz to 5 MHz range. The output voltage can be varied from 0 to 10 Vp-p into 50 ohms or to 20 Vp-p into open circuit. A continuously variable DC offset allows the output to be injected directly into circuits at the correct bias level. These features make the 4005DDS great for education and other applications that need basic waveform generation. Features and Benefits ■ Frequency is selectable from 1 Hz to 5 MHz ■ Sine, square, or triangle waveform output ■ Direct digital synthesis (DDS) architecture ■ Bright, easy-to-read LED display ■ Number pad for quick input of frequency ■ Impedance 50 Ω± 2% Amplitude Range Variable control from 20 mVpp to 20 Vpp (open circuit); 10 mVpp to 10 Vpp (into 50 Ω) Attenuation -20 dB ± 2%, -40 dB ± 2% DC Offset Variable ±10 V (open circuit); ±5 V (into 50 Ω) Duty Cycle Adjustable 20% - 80% to 3 MHz for square Sine Wave Harmonic Distortion -50 dBc, DC to 20 kHz -30 dBc, 20 kHz to 5 MHz Flatness ± 0.3 dB to 1 MHz, ± 1 dB to 5 MHz Square Wave Symmetry ± 2% to 100 kHz, ± 5% to 5 MHz Rise Time ≤ 35 ns Triangle Wave Linearity Level ≥ 3V Rise Time ≤ 25 ns Front panel push button and pull knob can attenuate output by up to 40 dB ≥ 98% to 100 kHz, ≥ 95% to 5 MHz SYNC Output General Kensington security slot helps secure your function generator and prevents theft. AC Input 115/230 VAC, 50/60 Hz Operating Temperature 32 °F to 104 °F (0 °C to 40 °C) Humidity 10% - 80% R.H. Storage Temperature -4 °F to 158 °F (-20 °C to 70 °C) Storage Humidity 0% - 90% R.H. Dimensions (W x H x D) 11” x 4” x 11.7” (279.4 x 101.6 x 297.2 mm) Weight 5.05 lbs (2.3 kg) Included Accessories Instruction manual, power cord, BNC to BNC cable, BNC to alligator clips One-Year Warranty *Applies to frequencies ≥ 1 kHz. Note: All specifications apply to the unit after a temperature stabilization time of 15 minutes. Specifications and information are subject to change without notice. Technical data subject to change © B&K Precision Corp. 2014 v042114 w w w.bk prec ision.c om
BK4005DDS 价格&库存
很抱歉,暂时无法提供与“BK4005DDS”相匹配的价格&库存,您可以联系我们找货
BK4005DDS
  • 1+4126.027551+516.24050
