Datasheet SGP40
Indoor Air Quality Sensor for VOC Measurements
MOx based gas sensor for indoor air quality applications
Outstanding long-term stability and lifetime
I2C interface with digital output signal
Very small 6-pin DFN package: 2.44 x 2.44 x 0.85 mm3
Low power consumption: 2.6 mA at 3.3 V
Tape and reel packaged, reflow solderable
Product Summary
The SGP40 is a digital gas sensor designed for easy
integration into air purifiers or demand-controlled
ventilation systems. Sensirion’s CMOSens® technology
offers a complete, easy-to-use sensor system on a single
chip featuring a digital I2C interface and a temperaturecontrolled micro hotplate, providing a humiditycompensated VOC based indoor air quality signal. The
output signal can be directly processed by Sensirion’s
powerful Gas Index Algorithm to translate the raw signal
into a VOC Index as a robust measure for indoor air
quality. The Gas Index Algorithm automatically adapts to
the environment the sensor is exposed to. Both sensing
element and Gas Index Algorithm feature an unmatched
robustness against contaminating gases present in
real-world applications enabling a unique long-term
stability as well as low drift and device-to-device
variation. The very small 2.44 x 2.44 x 0.85 mm3 DFN
package enables applications in limited spaces.
Sensirion’s state-of-the-art production process
guarantees high reproducibility and reliability. Tape and
reel packaging together with suitability for standard
SMD assembly processes make the SGP40
predestined for high-volume applications.
Figure 1 Functional block diagram of the SGP40.
www.sensirion.com
version 1.2 – February 2022
1/20
Table of Contents
1 Sensor Performance................................................................................................................................................................3
2 Specifications ..........................................................................................................................................................................5
2.1 Electrical Specifications .....................................................................................................................................................5
2.2 Timing Specifications .........................................................................................................................................................5
2.3 Recommended Operating and Storage Conditions ...........................................................................................................5
2.4 Absolute Minimum and Maximum Ratings .........................................................................................................................6
2.5 Hardware Interface Specifications .....................................................................................................................................7
2.6 Environmental Stability ......................................................................................................................................................8
2.7 Material Contents ...............................................................................................................................................................8
3 Sensor Output Signal Description .........................................................................................................................................9
3.1 Raw Signal Measurement ..................................................................................................................................................9
3.2 VOC Index Measurement ..................................................................................................................................................9
3.3 Built-in Self-Test...............................................................................................................................................................10
3.4 Reading out The Sensor Serial Number ..........................................................................................................................10
3.5 Sensor Start-up Behavior .................................................................................................................................................10
4 Digital Interface Description .................................................................................................................................................11
4.1 General Considerations ...................................................................................................................................................11
4.2 I2C Address ......................................................................................................................................................................11
4.3 I2C Voltage Levels............................................................................................................................................................11
4.4 I2C Protocol Speed...........................................................................................................................................................11
4.5 I2C Sequences .................................................................................................................................................................11
4.6 Checksum Calculation .....................................................................................................................................................12
4.7 I2C Commands .................................................................................................................................................................12
5 Mechanical Specifications ....................................................................................................................................................15
5.1 Traceability.......................................................................................................................................................................15
5.2 Package Outline...............................................................................................................................................................15
5.3 Land Pattern ....................................................................................................................................................................16
5.4 Soldering Instructions ......................................................................................................................................................16
6 Ordering Information .............................................................................................................................................................17
6.1 Packaging Information .....................................................................................................................................................17
www.sensirion.com
2/20
Table 1 lists specifications characterizing the gas sensing performance. The SGP40 chip provides a digital raw signal
(SRAW_VOC) which is sensitive to most VOC gases typically present in indoor environments and which is proportional to the
logarithm of the resistance of the sensing material. This signal is intended for further processing by Sensirion’s robust Gas Index
Algorithm, which is available on GitHub (see SGP40 product page on Sensirion’s webpage), to provide a VOC bases output
signal that can be directly used for indoor air quality applications. For the specifications given below, ethanol in clean air has
been used as proxy gas for typical indoor air events.
Parameter
Output signals2
Measurement range
Specified range
Device-to-device
variation
Repeatability
Values1
Comments
Min.
VOC Index, processed value from SRAW_VOC 1
SRAW_VOC, digital raw value
Ethanol in clean air
Ethanol in clear air
0.3
4
VOC Index
Typ.
很抱歉,暂时无法提供与“SGP40-D-R4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+23.20271
- 50+22.72913
- 国内价格 香港价格
- 1+61.313051+7.92945
- 5+55.263905+7.14713
- 10+53.0064010+6.85517
- 25+50.3063625+6.50598
- 50+48.4606850+6.26729
- 100+46.77118100+6.04879
- 500+43.36829500+5.60870
- 1000+43.060391000+5.56888
- 国内价格
- 1+26.22421
- 10+24.19130
- 30+23.34546
