1.5KE SERIES
Taiwan Semiconductor
1500W, 6.8V - 440V Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
AEC-Q101 qualified available
Excellent clamping capability
Low dynamic impedance
1500W surge capability at 10/1000μs waveform
Fast response time: Typically less than 1.0ps from 0 volt to
VBR for unidirectional and 5.0ns for bidirectional
Typical IR less than 1μA above 10V
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
5.5 - 376
V
VBR (uni - directional)
6.12 - 462
V
VBR (bi - directional)
6.12 - 462
V
PPK
1500
W
TJ MAX
175
Package
DO-201
APPLICATIONS
● Protect sensitive circuit from damage by high voltage
transients
● Lighting, ESD transient voltage protection of IC, system
● Inductive switching load protection of IC, system
● Electrical Fast Transient Immunity protection of IC, system
MECHANICAL DATA
Case: DO-201
Molding compound meets UL 94V-0 flammability rating
Terminal: Pure tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.090g (approximately)
DO-201
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PPK
1500
W
PD
5
W
IFSM
200
A
Forward Voltage @ IF = 50A for Uni-directional only
VF
3.5 / 5.0
V
Junction temperature
TJ
- 55 to +175
°C
Storage temperature
TSTG
- 55 to +175
Notes:
1.
Non-repetitive Current Pulse Per Fig.3 and Derated above TA = 25°C Per Fig.2
2.
Mounted on Copper Pad Area of 0.6" x 0.6" (16mm x 16mm)
3.
VF = 3.5V for Devices of VBR ≦ 200V and VF = 5.0V Max. for Devices VBR > 200V
°C
(1)
Peak power dissipation at TA = 25°C, Tp = 1ms
Steady state power dissipation at TL = 75°C
(2)
lead lengths .375", 9.5mm
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load for Uni-directional only
(3)
Devices for Bipolar Applications
1.
For bidirectional use C or CA suffix for types 1.5KE6.8 - Types 1.5KE440
2.
Electrical characteristics apply in both directions
1
Version: O2104
1.5KE SERIES
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
JEDEC
type
number
1N6267
General
part
number
1.5KE6.8
Nominal
Voltage
Breakdown
voltage
VBR@IT
(V)
(Note 1)
Min
Max
Maximum
Working
Test
blocking
stand-off
current
leakage
voltage
IT
current
VWM
(mA)
ID@VWM
(V)
(µA)
Maximum
peak
Maximum
Maximum
impulse clamping
temperature
current
voltage
coefficient
IPP
VC@IPP
of VBR(%/°C)
(A)
(V)
(Note 2)
6.8
6.12
7.48
10
5.50
1000
145
10.8
0.057
1N6267A 1.5KE6.8A
6.8
6.45
7.14
10
5.80
1000
150
10.5
0.057
1N6268
7.5
6.75
8.25
10
6.05
500
134
11.7
0.061
1N6268A 1.5KE7.5A
1.5KE7.5
7.5
7.13
7.88
10
6.40
500
139
11.3
0.061
1N6269
8.2
7.38
9.02
10
6.63
200
126
12.5
0.065
1N6269A 1.5KE8.2A
1.5KE8.2
8.2
7.79
8.61
10
7.02
200
130
12.1
0.065
1N6270
9.1
8.19
10.00
1.0
7.37
50
114
13.8
0.068
1N6270A 1.5KE9.1A
1.5KE9.1
9.1
8.65
9.55
1.0
7.78
50
117
13.4
0.068
1N6271
10
9.00
11.00
1.0
8.10
10
105
15.0
0.073
1N6271A 1.5KE10A
1.5KE10
10
9.50
10.5
1.0
8.55
10
108
14.5
0.073
1N6272
11
9.90
12.1
1.0
8.92
1
97
16.2
0.075
1N6272A 1.5KE11A
1.5KE11
11
10.5
11.6
1.0
9.40
1
100
15.6
0.075
1N6273
12
10.8
13.2
1.0
9.72
1
91
17.3
0.078
1N6273A 1.5KE12A
1.5KE12
12
11.4
12.6
1.0
10.20
1
94
16.7
0.078
1N6274
13
11.7
14.3
1.0
10.50
1
82
19.0
0.081
1N6274A 1.5KE13A
1.5KE13
13
12.4
13.7
1.0
11.10
1
86
18.2
0.081
1N6275
15
13.5
16.5
1.0
12.10
1
71
22.0
0.084
1N6275A 1.5KE15A
1.5KE15
15
14.3
15.8
1.0
12.80
1
74
21.2
0.084
1N6276
16
14.4
17.6
1.0
12.90
1
67
23.5
0.086
1N6276A 1.5KE16A
16
15.2
16.8
1.0
13.60
1
70
22.5
0.086
1N6277
18
16.2
19.8
1.0
14.50
1
59
26.5
0.088
1N6277A 1.5KE18A
18
17.1
18.9
1.0
15.30
1
60
25.5
0.088
1N6278
22.0
1.0
16.20
1
54
29.1
0.090
1N6278A 1.5KE20A
21.0
1.0
17.10
1
56
27.7
0.090
1N6279
22
19.8
24.2
1.0
17.80
1
49
31.9
0.092
1N6279A 1.5KE22A
22
20.9
23.1
1.0
18.80
1
51
30.6
0.092
1N6280
24
21.6
26.4
1.0
19.40
1
45
34.7
0.094
1N6280A 1.5KE24A
24
22.8
25.2
1.0
20.50
1
47
33.2
0.094
1N6281
27
24.3
29.7
1.0
21.80
1
40
39.1
0.096
1N6281A 1.5KE27A
27
25.7
28.4
1.0
23.10
1
42
37.5
0.096
1N6282
30
27.0
33.0
1.0
24.30
1
36
43.5
0.097
1N6282A 1.5KE30A
30
28.5
31.5
1.0
25.60
1
38
41.4
0.097
1N6283
33
29.7
36.3
1.0
26.80
1
33
47.7
0.098
1N6283A 1.5KE33A
33
31.4
34.7
1.0
28.20
1
34
45.7
0.098
1N6284
36
32.4
39.6
1.0
29.10
1
30
52.0
0.099
1N6284A 1.5KE36A
36
34.2
37.8
1.0
30.80
1
31
49.9
0.099
1N6285
39
35.1
42.9
1.0
31.60
1
27
56.4
0.100
1N6285A 1.5KE39A
39
37.1
41.0
1.0
33.30
1
29
53.9
0.100
1N6286
43
38.7
47.3
1.0
34.80
1
25
61.9
0.101
1N6286A 1.5KE43A
43
40.9
45.2
1.0
36.80
1
26
59.3
0.101
1N6287
47
42.3
51.7
1.0
38.10
1
23
67.8
0.101
47
44.7
49.4
1.0
40.20
1
24
64.8
0.101
1.5KE16
1.5KE18
1.5KE20
1.5KE22
1.5KE24
1.5KE27
1.5KE30
1.5KE33
1.5KE36
1.5KE39
1.5KE43
1.5KE47
1N6287A 1.5KE47A
2
Version: O2104
1.5KE SERIES
JEDEC
type
number
1N6288
General
part
number
1.5KE51
Nominal
Voltage
Breakdown
voltage
VBR@IT
(V)
(Note 1)
Min
Max
Maximum
Working
Test
blocking
stand-off
current
leakage
voltage
IT
current
VWM
(mA)
ID@VWM
(V)
(µA)
Maximum
peak
Maximum
Maximum
impulse clamping
temperature
current
voltage
coefficient
IPP
VC@IPP
of VBR(%/°C)
(A)
(V)
(Note 2)
51
45.9
56.1
1.0
41.30
1
21
73.5
0.102
1N6288A 1.5KE51A
51
48.5
53.6
1.0
43.60
1
22
70.1
0.102
1N6289
56
50.4
61.6
1.0
45.40
1
19
80.5
0.103
1N6289A 1.5KE56A
1.5KE56
56
53.2
58.8
1.0
47.80
1
0.103
1N6290
62
55.8
68.2
1.0
50.2
1
17
89.0
0.104
1N6290A 1.5KE62A
1.5KE62
62
58.9
65.1
1.0
53.0
1
18
85.0
0.104
1N6291
68
61.2
74.8
1.0
55.1
1
16
98.0
0.104
1N6291A 1.5KE68A
1.5KE68
68
64.6
71.4
1.0
58.1
1
17
92.0
0.104
1N6292
75
67.5
82.5
1.0
60.7
1
14
108
0.105
1N6292A 1.5KE75A
1.5KE75
75
71.3
78.8
1.0
64.1
1
15
103
0.105
1N6293
82
73.8
90.2
1.0
66.4
1
13
118
0.105
1N6293A 1.5KE82A
1.5KE82
82
77.9
86.1
1.0
70.1
1
13.9
113
0.105
1N6294
91
81.9
100
1.0
73.7
1
12
131
0.106
1N6294A 1.5KE91A
1.5KE91
91
86.5
95.5
1.0
77.8
1
12.6
125
0.106
1N6295
100
90
110
1.0
81.0
1
10.9
144
0.106
1N6295A 1.5KE100A
1.5KE100
100
95
105
1.0
85.5
1
11.4
137
0.106
1N6296
110
99
121
1.0
89.2
1
9.9
158
0.107
1N6296A 1.5KE110A
1.5KE110
110
105
116
1.0
94.0
1
10.3
152
0.107
1N6297
120
108
132
1.0
97.2
1
9.1
173
0.107
1N6297A 1.5KE120A
120
114
126
1.0
102
1
9.5
165
0.107
1N6298
130
117
143
1.0
105
1
8.4
187
0.107
1N6298A 1.5KE130A
130
124
137
1.0
111
1
8.7
179
0.107
1N6299
150
135
165
1.0
121
1
7.3
215
0.108
1N6299A 1.5KE150A
150
143
158
1.0
128
1
7.6
207
0.108
1N6300
160
144
176
1.0
130
1
6.8
230
0.108
1N6300A 1.5KE160A
160
152
168
1.0
136
1
7.1
219
0.108
1N6301
170
153
187
1.0
138
1
6.4
244
0.108
1N6301A 1.5KE170A
170
162
179
1.0
145
1
6.7
234
0.108
1N6302
180
162
198
1.0
146
1
6.1
258
0.108
1N6302A 1.5KE180A
180
171
189
1.0
154
1
6.4
246
0.108
1N6303
200
180
220
1.0
162
1
5.4
287
0.108
1.5KE120
1.5KE130
1.5KE150
1.5KE160
1.5KE170
1.5KE180
1.5KE200
1N6303A 1.5KE200A
200
190
210
1.0
171
1
5.7
274
0.108
1.5KE220
220
198
242
1.0
175
1
4.5
344
0.110
1.5KE220A
220
209
231
1.0
185
1
4.8
328
0.110
1.5KE250
250
225
275
1.0
202
1
4.3
360
0.110
1.5KE250A
250
237
263
1.0
214
1
4.5
344
0.110
1.5KE300
300
270
330
1.0
243
1
3.6
430
0.110
1.5KE300A
300
285
315.0
1.0
256
1
3.8
414
0.110
1.5KE350
350
315
385
1.0
284
1
3.1
504
0.110
1.5KE350A
350
333
368
1.0
300
1
3.2
482
0.110
1.5KE400
400
360
440
1.0
324
1
2.7
574
0.110
1.5KE400A
400
380
420
1.0
342
1
2.8
548
0.110
1.5KE440
440
396
484
1.0
356
1
2.4
631
0.110
3
Version: O2104
1.5KE SERIES
JEDEC
type
number
General
part
number
Nominal
Voltage
1.5KE440A
440
Breakdown
voltage
VBR@IT
(V)
(Note 1)
Min
Max
418
462
Maximum
Working
Test
blocking
stand-off
current
leakage
voltage
IT
current
VWM
(mA)
ID@VWM
(V)
(µA)
1.0
376
1
Maximum
peak
Maximum
Maximum
impulse clamping
temperature
current
voltage
coefficient
IPP
VC@IPP
of VBR(%/°C)
(A)
(V)
(Note 2)
2.5
602
0.110
Notes:
1. VBR measure after IT applied for 30ms, IT = square wave pulse or equivalent.
2. Surge current waveform per Fig.3 and derate per Fig.2.
3. For bipolar types having VWM of 10 volts and under, the ID limit is doubled.
4. All terms and symbols are consistent with ANSI/IEEE C62.35.
ORDERING INFORMATION
ORDERING CODE(1)(2)
PACKAGE
PACKING
1.5KEx
DO-201
1,250 / Tape & Reel
1.5KEx A0G
DO-201
500 / Ammo box
1.5KExH
DO-201
1,250 / Tape & Reel
1.5KExHA0G
DO-201
500 / Ammo box
Notes:
1. "x" defines voltage from 6.8V(1.5KE6.8) to 440V(1.5KE440A)
2. "H" means AEC-Q101 qualified
4
Version: O2104
1.5KE SERIES
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
125
PEAK PULSE POWER(PPP) OR CURRENT (IPP) A
DERATING IN PERCENTAGE (%)
PPPM, PEAK PULSE POWER, KW
100
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in Fig.3
10
1
0.1
0.1
1
10
100
1000
With heat sink
100
75
50
25
Without heat sink
tp, PULSE WIDTH, (μs)
25
50
75
100
125
150
175
TA, AMBIENT TEMPERATURE (°C)
Fig.3 Clamping Power Pulse Waveform
Fig.4 Maximum Non-Repetitive Forward Surge
Current
200
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
120
PEAK FORWARD SURGE CURRENT (A)
IPPM, PEAK PULSE CURRENT (%)
140
Rise time tr=10μs to 100%
100
Peak value
IPPM
80
60
Half value-IPPM/2
10/1000μs, waveform
40
td
1
1.5
2
2.5
3
180
160
140
120
100
8.3ms single half sine wave
UNIDIRECTIONAL ONLY
80
60
40
10
100
NUMBER OF CYCLES AT 60 Hz
t, TIME (ms)
5
Version: O2104
1.5KE SERIES
Fig.5 Typical Junction Capacitance
CJ, JUNCTION CAPACITANCE (pF)
10000
VR=0
1000
100
VR-rated stand-off voltage
f=1.0MHz
Vsig=50mVp-p
10
1
10
100
V(BR), BREAKDOWN VOLTAGE (V)
6
Version: O2104
1.5KE SERIES
PACKAGE OUTLINE DIMENSIONS
DO-201
MARKING DIAGRAM
Cathode band for uni-directional products only
7
P/N
= Marking Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: O2104
1.5KE SERIES
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
8
Version: O2104
很抱歉,暂时无法提供与“1.5KE6.8CA R0”相匹配的价格&库存,您可以联系我们找货
