DATA SHEET
High Performance Single-Phase Filters FN2070
Multi-stage Performance AC/DC EMI Filter
Rated currents from 1 to 36 A
Approvals & Compliances
High differential and common-mode
attenuation
High frequency attenuation
Optional medical versions (B type)
Optional safety versions (A type)
Features and Benefits
FN2070 two-stage filters are designed for easy
and fast chassis mounting
FN2070 B versions without capacitors to earth
comply to 1MOP for ME (medical equipment) acc.
IEC 60601-1
FN2070 A version with low capacitance to earth
for safety critical applications with necessity for
low leakage currents
Technical Specifications
Rated voltage*
250 VAC, 50/60 Hz; 250 VDC
Operating frequency
DC to 400 Hz
Rated currents
1 to 36 A @ 40°C max
High potential test voltage
P –> PE 2000 VAC for 2 sec
P –> PE 2500 VAC for 2 sec (B types)
P –> N 1100 VDC for 2 sec
Temperature range (operation and storage)
-25°C to +100°C (25/100/21)**
Certified to
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to
AC and DC applications)
Flammability corresponding to
Laces for -07 version: UL 94 VW-1
Terminal plastic for -06/-08 version: UL 94 V-0
Grommet for -07 version: UL 94V-0
Design corresponding to
Overvoltage category
II acc. IEC 60664-1
Pollution degree
2 acc. IEC 60664-1
Altitude
2000m (above derating applies)**
MTBF @ 40°C/230 V (Mil-HB-217F)
1,550,000 hours
1,600,000 hours (B types)
maximum RMS operating voltage at rated frequency or the maximum DC operating voltage
for dedicated requests exceeding this specification (e.g. -40 °C or higher altitude) please contact
your local
Schaffner Sales office
All filters provide a high conducted attenuation
performance, based on chokes with high
saturation resistance and excellent thermal
behavior
FN2070 two-stage filters are designed for high
FN2070 filters are also available as single- stage
filters (FN2030 series)
FN2070 filters are also available with differential
mode choke (FN2080 series)
Various terminal options allow you to select the
desired connection style
Typical Applications
Electrical and electronic equipment
Consumer goods
Household equipment
Building automation
Industrial applications
Machinery
Medical equipment
Electronic data processing equipment
Office automation and datacom equipment
Various noisy applications requiering good filter
performance
Single Phase Motor Drives
Typical electrical schematic
2
Schaffner Group
DATA SHEET
15. Jun 2022
Filter Selection Table
Filter*
Buy
Rated current
@ 40°C (25°C)
Leakage current**
Power Loss
Inductance***
Capacitance*** Resistance***
@ 250 VAC/50 Hz
@25°C/DC
L
Cx
Cy
R
Input/Output Weight
connections
(@ 120 VAC/60 Hz)
[A]
[mA]
[W]
[mH]
[μF]
[nF]
[kΩ]
[g]
FN2070-1-..
1 (1.2)
0.66 (0.38)
2.4
22
0.33
4.7
1000
-06
-07
190
FN2070-3-..
3 (3.5)
0.66 (0.38)
2.2
9.8
0.47
4.7
470
-06
-07
250
FN2070-6-..
6 (6.9)
0.66 (0.38)
3.2
7.8
1
4.7
220
-06
-07
450
FN2070-10-..
10 (11.5)
0.66 (0.38)
9.1
4.5
1
4.7
220
-06
-07
-08
670
FN2070-12-..
12 (13.8)
0.66 (0.38)
13.1
3.25
1
4.7
220
-06
-07
-08
670
FN2070-16-..
16 (18.4)
0.66 (0.38)
9.6
2.8
1
4.7
220
-06
-07
-08
1000
FN2070-25-08
25 (28.8)
0.66 (0.38)
11.6
2
2.2
4.7
220
-08
760
FN2070-36-08
36 (41.4)
0.66 (0.38)
13.1
1.23
2.2
4.7
220
-08
790
FN2070A-1-..
1 (1.2)
0.07 (0.04)
2.4
22
0.33
0.47
1000
-06
-07
190
FN2070A-3-..
3 (3.5)
0.07 (0.04)
2.2
9.8
0.47
0.47
470
-06
-07
250
FN2070A-6-..
6 (6.9)
0.07 (0.04)
3.2
7.8
1
0.47
220
-06
-07
450
FN2070A-10-..
10 (11.5)
0.07 (0.04)
9.1
4.5
1
0.47
220
-06
-07
-08
670
FN2070A-12-..
12 (13.8)
0.07 (0.04)
13.1
3.25
1
0.47
220
-06
-07
-08
670
FN2070A-16-..
16 (18.4)
0.07 (0.04)
9.6
2.8
1
0.47
220
-06
-07
-08
1000
FN2070A-25-08
25 (28.8)
0.07 (0.04)
11.6
2
2.2
0.47
220
-08
760
FN2070A-36-08
36 (41.4)
0.07 (0.04)
13.1
1.23
2.2
0.47
220
-08
790
FN2070B-1-..
1 (1.2)
0.00
2.4
22
0.33
1000
-06
-07
190
FN2070B-3-..
3 (3.5)
0.00
2.2
9.8
0.47
470
-06
-07
250
FN2070B-6-..
6 (6.9)
0.00
3.2
7.8
1
220
-06
-07
450
FN2070B-10-..
10 (11.5)
0.00
9.1
4.5
1
220
-06
-07
-08
FN2070B-12-..
12 (13.8)
0.00
13.1
3.25
1
220
-06
-07
-08
670
FN2070B-16-..
16 (18.4)
0.00
9.6
2.8
1
220
-06
-07
-08
1000
FN2070B-25-08
25 (28.8)
0.00
11.6
2
2.2
220
-08
760
FN2070B-36-08
36 (41.4)
0.00
13.1
1.23
2.2
220
-08
790
FN2070M-1-06
1 (1.2)
3.69 (2.13)
2.4
22
0.33
47
1000
-06
170
FN2070M-3-06
3 (3.5)
3.69 (2.13)
2.2
9.8
0.47
47
470
-06
250
FN2070M-6-06
6 (6.9)
3.69 (2.13)
3.2
7.8
1
47
220
-06
450
FN2070M-10-..
10 (11.5)
3.69 (2.13)
9.1
4.5
1
47
220
-06
-08
670
FN2070M-12-..
12 (13.8)
3.69 (2.13)
13.1
3.25
1
47
220
-06
-08
670
FN2070M-16-..
16 (18.4)
3.69 (2.13)
9.6
2.8
1
47
220
-06
-08
1000
FN2070M-25-08
25 (28.8)
3.69 (2.13)
11.6
2
2.2
47
220
-08
750
FN2070L-36-08
36 (41.4)
2.59 (1.49)
13.1
1.23
2.2
33
220
-08
790
670
Enhanced performance
* To compile a complete part number, please replace the -.. with the required I/O connection style (e.g. FN 2070-25-08, FN 2070B-10-06).
** Maximum leakage under usual AC operating conditions (acc. IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this
level.
*** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%
3
Schaffner Group
DATA SHEET
15. Jun 2022
Typical Filter Attenuation
Per CISPR 17; CM=50 Ω/50 Ω sym; DM=50 Ω/50 Ω asym;
1 A: Standard type
A type
B type
3 A: Standard type
A type
B type
6 A: Standard type
A type
B type
10 A: Standard type
A type
B type
12 A: Standard type
A type
B type
4
Schaffner Group
DATA SHEET
15. Jun 2022
16 A: Standard type
A type
B type
25 A: Standard type
A type
B type
36 A: Standard type
A type
B type
5
Schaffner Group
DATA SHEET
Product selector
Mechanical Data
Connection style -06, 1 and 3 A types
Connection style -06, 6 to 12 A types
Connection style -06, 16 A types
Connection style -07, 1 to 16 A types (same dimensions as style -06)
Connection style -07, 6 to 12 A types (same dimensions as style -06)
Connection style -07, 16 A types (same dimensions as style -06)
Connection style -08, 16 A type
Connection style -08, 10 A, 12 A, 25 A and 36 A types
15. Jun 2022
6
Schaffner Group
DATA SHEET
15. Jun 2022
Dimensions
1A
3A
6A
10 A
12 A
16 A
25 A
36 A
Tolerances
A
85 ±0.5
85 ±0.5
113.5
156
156
119
156
156
±1
B
54 ±0.5
54 ±0.5
57.5
57.5
57.5
85.5
57.5
57.5
±1
C
30.3 ±0.5
40.3 ±0.5
45.4
45.4
45.4
57.6
45.4
45.4
±1
D
64.8 ±0.5
64.8 ±0.5
94
130.5
130.5
98.5
130.5
130.5
±1
E
49.8
49.8
56
56
56
84.5
56
56
±0.5
F
75
75
103
143
143
109
143
143
±0.3
G
27
27
25
25
25
40
25
25
±0.2
H
12.3
12.3
12.4
12.4
12.4
15.6
12.4
12.4
±0.5
I
20.8
29.8
32.4
32.5
32.5
32.5
32.5
±0.5
J
19.9
11.4
15.5
15.5
15.5
42.25
15.5
15.5
±0.5
K
5.3
5.3
4.4
5.3
5.3
4.4
5.3
5.3
L
6.3
6.3
6
6
6
7.4
6
6
M
0.7
0.7
1
1
1
1.2
1
1
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
6.3 x 0.8
O
8.3
8.3
8.4
8.4
8.4
8.6
±0.5
P
14.9
14.9
18
18
18
42.25
±0.5
AWG type wire
AWG 20
AWG 20
AWG 18
AWG 18
AWG 16
AWG 16
Wire length
140
140
140
140
140
140
M4
M4
M4
Recommended torque (Nm)
1.2 - 1.3
1.2 - 1.3
Earth terminal
1.5 - 1.7
1.5 - 1.7
±0.3
N
+5
N
Q
All dimensions in mm; 1 inch = 25.4 mm
Please visit www.schaffner.com to find more details on filter connections.
M4
M4
1.2 - 1.3
1.2 - 1.3
1.2 - 1.3
1.5 - 1.7
1.5 - 1.7
1.5 - 1.7
51
±0.2
7
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Holding AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road,Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E El
Soto de Moraleja, Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tions are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
15. Jun 2022
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma, Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1, #05-09, Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2, No 97, Section 1, XinTai 5th Road,
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780, 37FL, 98 North-Sathorn Rd,
Silom, Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
