19503 B59250
19503 B59250
    BELDEN
19503 B59250 数据手册
Product: 19503 Portable Cordage, 3 C #18 Str BC, PVC Ins, PVC Jkt, UL Type STOW Product Description Portable Cordage, 3 Conductor 18AWG (42x34) Bare Copper, PVC Insulation, PVC Outer Jacket, UL Type STOW Technical Specifications Construction Details Conductor Element Number of Element Conductor(s) 3 Size Stranding 18 AWG 42x34 Material BC - Bare Copper Insulation Material Nom. Thickness Nom. Insulation Diameter PVC - Polyvinyl Chloride 0.032 in (0.81 mm) 0.110 in (2.79 mm) Color Code Blue, Brown, Green/Yellow Outer Jacket Separator Material Nom. Thickness Nom. Diameter Paper Tape PVC - Polyvinyl Chloride 0.07 in (1.8 mm) 0.38 in Electrical Characteristics Electricals Nom. Conductor DCR 6.97 Ohm/1000ft Max. Current 10 Amps per Conductor at 25ºC (7 Amps over 50 ft) 7 Amps per Conductor at 25ºC (over 50 ft) Voltage UL Voltage Rating 600 V Mechanical Characteristics Temperature UL Temperature 60°C Operating -35°C To +105 °C Max. Pull Tension: 63.9 lbs (29.0 kg) Bulk Cable Weight: 68 lbs/1000ft Standards and Compliance Environmental Suitability: Outdoor, Oil Resistance Flammability / Reaction to Fire: VW-1, FT1 NEC / UL Compliance: Article 400, STOW AWM Compliance: STOW European Directive Compliance: EU CE Mark, EU Directive 2011/65/EU (RoHS 2), EU Directive 2012/19/EU (WEEE) APAC Compliance: China RoHS II (GB/T 26572-2011) Product Notes Notes: Approved as water resistant, oil resistant and outdoor use. History Update and Revision: Revision Number: 0.395 Revision Date: 12-20-2022 Part Numbers Variants Item # Color Putup Type Length 19503 B59250 Black, Matte Reel 250 ft UPC 612825127116 © 2023 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
19503 B59250 价格&库存
很抱歉,暂时无法提供与“19503 B59250”相匹配的价格&库存,您可以联系我们找货
