MKA10110 7-10
MKA10110 7-10
    RMCIP
    插件
MKA10110 7-10 数据手册
Shenzhen FAST Sensor Co.,LTD MKA10110 Ultra-miniature dry-reed switch hermetically sealed in a gas-filled glass envelope. Single-pole, single-throw (SPST) type, having normally open contacts, and containing two magnetically actuated reeds. The switch is of the double-ended type and may be actuated by an electromagnet, a permanent magnet or a combination of both.The device is intended for use in relays, sensors, pulse counters or similar devices. MKA10110 Features ◆ Ideal for ATE switching ◆ ◆ ◆ ◆ 10 mm glass length Contact layers: gold, sputtered ruthenium Superior glass-to-metal seal and blade alignment Excellent life expectancy and reliability Dimension For MKA10110 Technical Specifications Parameters Contact Form Contact Material Max.Contact Rating Max Switching Voltage Max Switching Current Max Initialcontact Resistance Pull In Value Drop out Volue Min Breakdown Voltage Max Contact Capacitance Min Insulation Resistance Type Resonant Frequency Operation Temperature Test Conditions (energization) Units W V A mΩ AT AT VDC/AC pF mΩ KHz ℃ MKA10110 1A SPST-NO Ru 10 100VDC 0.5 100 7-35 4 150 0.5 6 10 5 -55℃~+125℃
MKA10110 7-10 价格&库存
很抱歉,暂时无法提供与“MKA10110 7-10”相匹配的价格&库存,您可以联系我们找货
