70160102
    STORMINTERFACE
70160102 数据手册
In a dirty world… 700 Series Storm 700 Series keypads are intended for use in wet or dirty environments. These modular keypads are designed to withstand the ingress of liquids and other contaminants; manufactured to survive the rigours of modern industrial use. 700 Series Tough keypads for tough environments. Keytop legend tiles can be configured to suit individual applications. 700 Series – Sealed & Rugged Keypads The Storm 700 Series keypads are compatible with the Storm RS232 and USB keypad encoders (4, 12 & 16 key keypads only). Interchangeable keytop legend tiles allow the selection of keytop graphics to suit any particular application. A comprehensive range of keytop legend tiles, are available from your local Storm supplier. In demanding or hostile environments, a keyboard operator must be confident that data can be entered quickly and accurately. With this objective the keys move with a positive over-centre action ensuring rapid and reliable data entry even in the most extreme conditions. The keypads can be easily mounted to a flat surface or can be located beneath a suitable aperture in a fascia panel. Storm 700 Series keypads are supplied in 4, 12, 16, and 36 key configurations. The keypad’s unique modular design enables combinations of keypads to be used in the construction of more complex keypanel layouts. The exceptional reliability of Storm keypads is achieved by an ingenious but simple method of construction. A moulded rubber mat is secured around a rigid circuit plate providing its own environmental seal. Storm keypads have been successfully tested after submersion under 1 metre of water for periods in excess of 1 hour. This was achieved without using gaskets or sealing compounds of any kind. DIMENSIONS • • • • • 700 Series 700 Series 700 Series 217 32 16 10.8 16 16 M3 19.5 10.8 19 P 19 8 5.4 M3 M3 Threaded Stud Threaded Stud 96 96 96 96 Threaded Stud 32.5 14 max 10.8 P 19 P 19 19 P 19 14 16 14 max 14 96 14 19 10.8 19 70 14 16 23 Rapid & reliable data entry Sealed against fluids, dust & corrosives Resistant to vibration & shock Interchangeable keytop legends 4, 12 and 16 key formats are compatible with Storm keypad encoders Comprehensive dimensional, fixing and connection details are provided with each Storm 700 Series keypad. 8 8 5.4 5.4 A comprehensive range of interchangeable keytop legend tiles, for use with Storm 700 Series keypads, are availble from your local Storm supplier. All dimensions are in millimetres. ACCESSORIES FOR USE WITH STORM 700/900 SERIES KEYPADS Item Legend Tile Set Part Number Description 70X00101 (X denotes type, "A to F") Under Panel Mounting Clips 7012CL0 7036CL0 For 4, 12 & 16 key keypad. For 36 key keypad. SPECIFICATION & OPERATIONAL PERFORMANCE ELECTRICAL Contact Bounce Contact Resistance Insulation Resistance Breakdown Voltage (to case) Operating Voltage Operating Current 5ms (max) 100 ohm (max) 50 Mohms (min) at 480V DC 500V AC (max 60 seconds) 24V DC (max) 50 mA (max) 20 mA typ 25mA (max) MECHANICAL Operational Life Keytop Travel Actuation Force Sealing Torque Connector MATERIAL Keypad Surface Keypad chassis Contact Circuit ENVIRONMENTAL Water Sealed Humidity Operational Temperature BS5490 Class IP67 / EC529 Class IP67 when panel mounted 90% RH at 40°C (104°F 10 day (max) - Non-condensing -55°C to +125°C (-67°F to +257°F) 2 million cycles (min) 1.5mm nominal 160gms typical 0.14 - 0.16 Nm Locking 0.1" pitch gold-plated square pin connector suitable for use with Molex 2695/6471 or 7720S series or similar female connectors USA Office: Storm Interface 13835 N Tatum Blvd, #9-510 Phoenix AZ, 85032 Tel: +1 (480) 584 3518 Fax: +1 (480)584 67164 Email: sales.usa@storm-keypads.com Engineering grade silicone rubber Coated non-ferrous metal Gold on nickel plated FR4 PCB UK Office: Storm Interface 1 Waterside Court Waterside Drive Langley Berkshire, SL3 6EZ Tel: +44 (0)1895 431421 Fax: +44 (0)1895 431132 Email: sales@storm-interface.com Whilst every effort is made to ensure details are correct at time of print, specifications are subject to change without notice. www.storm-interface.com Storm is a trademark of Keymat Technology Ltd Storm Interface is a trading name of Keymat Technology Ltd UL File reference: E230121 Designed & produced by NIK Design www.nikdesign.co.uk 003 700-LIT-01 Rev 3 Dec 2007 FM 39602 Storm Interface products include technology protected by international patents and design registration. All rights reserved.
70160102 价格&库存
很抱歉,暂时无法提供与“70160102”相匹配的价格&库存,您可以联系我们找货
    • 1+411.20474
    • 100+403.75442
    • 500+389.29698
    库存:1
