RoHS
DB101S THRU DB107S
COMPLIANT
Bridge Rectifiers
Features
● UL recognition, file #E313149
● Ideal for automated placement
● High surge current capability
● Meets MSL level 1, per J-STD-020, LF maximum
peak of 260 °C
Typical Applications
General purpose use in AC/DC bridge full wave rectification for
SMPS, lighting ballast, adapter, battery charger, home
appliances, office equipment, and telecommunication
applications.
Mechanical Data
● Package: DBS
Molding compound meets UL 94 V-0 flammability
rating, RoHS-compliant, Halogen free
● Terminals: Tin plated leads, solderable per
J-STD-002 and JESD22-B102
● Polarity: As marked on body
■Maximum Ratings (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL
UNIT
Device marking code
DB101S
DB102S
DB103S
DB104S
DB105S
DB106S
DB107S
DB101S
DB102S
DB103S
DB104S
DB105S
DB106S
DB107S
50
100
200
400
600
800
1000
DB106S
DB107S
VRRM
V
IO
A
IFSM
A
It
2
A2s
Storage temperature
Tstg
-55 ~+150
Junction temperature
Tj
-55 ~+150
Repetitive peak reverse voltage
Average rectified output
On glass-epoxi
current @60Hz sine wave,
substrate
R-load, Ta=40℃
Surge(non-repetitive)forward current
@60Hz half sine wave, 1 cycle, Tj=25℃
Current squared time
@1ms≤t≤8.3ms Tj=25℃, Rating of per diode
1.0
30
3.7
■Electrical Characteristics(Ta=25℃ Unless otherwise specified)
PARAMETER
Maximum instantaneous forward
voltage drop per diode
Maximum DC reverse current at
rated DC blocking voltage per diode
SYMBOL UNIT
VF
IRRM
V
TEST
CONDITIONS
DB101S
DB102S
DB103S
DB104S
DB105S
1.00
IFM=0.5A
μA VRM=VRRM
5
1/4
S-S010
Rev. 2.1, 28-Apr-14
Yangzhou Yangjie Electronic Technology Co., Ltd.
www.21yangjie.com
DB101S THRU DB107S
■Thermal Characteristics (Ta=25℃ Unless otherwise specified)
PARAMETER
SYMBOL UNIT
Between junction
and ambient,
On glass-epoxi
substrate
Between junction
and lead
Thermal
Resistance
DB101S
DB102S
DB103S
DB104S
RθJ-A
DB105S
DB106S
DB107S
68.0
℃/W
RθJ-L
15.0
■Ordering Information (Example)
PREFERED P/N
PACKING
CODE
UNIT WEIGHT(g)
MINIIMUM
PACKAGE(pcs)
INNER BOX
QUANTITY(pcs)
DB101~DB107S
B1
Approximate 0.34
50
5000
20000
TUBE
DB101~DB107S
F1
Approximate 0.34
1500
3000
21000
REEL
OUTER CARTON
DELIVERY MODE
QUANTITY(pcs)
FIG2:Surge Forward Current Capability
■ Characteristics(Typical)
35
half sine wave
Peak Forward Surge Current (A)
Average Forward Output Current (A)
30
1.0
0.8
sine wave R-load
free in air
0.6
0.4
0.2
IFSM
FIG1:Io-Ta Curve
1.2
8.3ms 8.3ms
1cycle
25
non-repetitive
Tj=25℃
10
5
80
120
1
160
2
Ambient Temperature (℃)
5
10
Number Of Cycles
50
100
FIG4:Typical Reverse Characteristics
FIG3: Forward Voltage
100
6
Tj=150℃
Instantaneous Reverse Current (uA)
Instantaneous Forward Current (A)
4
2
1
0.5
Ta=25℃
0.1
0.05
10
1.0
Tj=25℃
0.1
0.02
0.01
0.01
0.4
0.6
0.8
1.0
1.2
Instantaneous Forward Voltage (V)
1.4
60
80
100
Percent of Rated Peak Reverse Voltage (%)
2/4
S-S010
Rev. 2.1, 28-Apr-14
www.21yangjie.com
DB101S THRU DB107S
■ Outline Dimensions
DBS
DBS
G
Dim
Min
Max
A
6.20
6.50
B
C
9.60
10.30
5.00
5.20
D
8.13
8.51
E
2.80
3.30
F
1.02
1.2
C
G
0.22
0.33
D
H
1.02
1.53
I
0.076
0.33
J
1.80
2.10
H
I
A
B
J
E
F
Dimensions in millimeters
■ Suggested pad layout
P2
Dim
Min
P1
8.73
P2
5.12
Q1
2.22
Q2
1.2
P1
Q1
Q2
3/4
S-S010
Rev. 2.1, 28-Apr-14
www.21yangjie.com
DB101S THRU DB107S
Disclaimer
The information presented in this document is for reference only. Yangzhou Yangjie Electronic Technology Co., Ltd. reserves the
right to make changes without notice for the specification of the products displayed herein to improve reliability, function or design
or otherwise.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with
equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as
medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), Yangjie or anyone on its behalf, assumes no responsibility or liability for any damages resulting from such improper use
of sale.
This publication supersedes & replaces all information previously supplied. For additional information, please visit our website
http:// www.21yangjie.com , or consult your nearest Yangjie’s sales office for further assistance.
4/4
S-S010
Rev. 2.1, 28-Apr-14
www.21yangjie.com
很抱歉,暂时无法提供与“DB107S-F1-0000HF”相匹配的价格&库存,您可以联系我们找货
