Datasheet
ANT-5GWWS1-SMA
Cellular Sub-6 5G Antenna
The ANT-5GWWS1-SMA is a dipole, blade-style
antenna for 5G New Radio, LTE, and cellular IoT
(LTE-M, NB-IoT) applications. As a 5G NR antenna,
the 5GWWS1 excels in the 617 MHz to 960 MHz
low band, and 1710 MHz to 2690 MHz and 3300
MHz to 5000 MHz midband ranges for CBRS
private networking, 4.9 GHz public safety and
emerging 2.5 GHz and C-band applications.
The hinged design allows for the antenna to be
positioned for optimum performance and attaches
with an SMA plug (male pin) connector.
Features
Applications
• Performance at 3300 MHz to 3800 MHz
― VSWR: ≤ 1.9
― Peak Gain: 2.7 dBi
― Efficiency: 66%
• Performance at 617 MHz to 960 MHz
― VSWR: ≤ 3.0
― Peak Gain: 0.7 dBi
― Efficiency: 53%
• Hinged design with detents for straight, 45
degree and 90 degree positioning
• SMA plug (male pin) connector
• Worldwide 5G/4G/3G/2G
• Cellular IoT: LTE-M (Cat-M1) and NB-IoT
• Private cellular networks
― Citizens Broadband Radio Service (CBRS)
• 4.9 GHz Public Safety
• Emerging 5G C-Band applications
• Emerging 5G 2.5 GHz EBS applications
• Internet of Things (IoT) devices
Ordering Information
Part Number
ANT-5GWWS1-SMA
Description
Cellular 5G, blade-style antenna with SMA plug (male pin) connector
Available from Linx Technologies and select distributors and representatives.
ANT-5GWWS1-SMA
Datasheet
Table 1. Electrical Specifications
617 MHz to 698 MHz
VSWR
(max.)
3.0
Peak Gain
(dBi)
0.7
Avg. Gain
(dBi)
-3.1
Efficiency
53
698 MHz to 803 MHz
1.9
0.4
-3.0
53
791 MHz to 960 MHz
1553 MHz to 1609 MHz
1710 MHz to 2200 MHz
2300 MHz to 2400 MHz
2496 MHz to 2690 MHz
3550 MHz to 3700 MHz
3700 MHz to 4200 MHz
4940 MHz to 4990 MHz
2.8
1.4
1.9
1.9
2.9
1.9
1.7
3.1
1.9
0.6
3.3
4.0
4.0
4.1
2.7
2.4
2.2
3.5
-4.0
-3.3
-2.0
-3.4
-3.3
-2.1
-1.4
-2.9
-2.6
53
48
68
48
57
66
76
58
56
Bands
71
12, 13, 14, 17, 26, 28, 29, 44,
67, 68, 85, n83
5, 18, 19, 20, 26, 27, n82, n89
24
1, 2, 3, 4, 25, 66
30, 40
7, 41
22, 42, 43, 48, 49, 52
48, CBRS
C-Band
Public Safety
Frequency Range
Polarization
Radiation
Max Power
Wavelength
Electrical Type
Impedance
Linear
Omnidirectional
10 W
1/2-wave
Dipole
50 Ω
Electrical specifications and plots measured with the antenna in a straight orientation.
Table 2. Mechanical Specifications
Parameter
Connection
Operating Temperature Range
Weight
Dimensions
Value
SMA Plug (male pin)
-20 °C to +65 °C
14.9 g (0.53 oz)
135.7 mm x 20.1 mm x 10.0 mm (5.34 in x 0.79 in x 0.39 in)
Packaging Information
The ANT-5GWWS1-SMA antenna is individually sealed in a clear plastic bag. 600 bags per carton, 400 mm x
300 mm x 230 mm (15.7 in x 11.8 in x 9.1 in), total weight 10.1 kgs (22.3 lb). Distribution channels may offer
alternative packaging options.
2
Datasheet
ANT-5GWWS1-SMA
Product Dimensions
Figure 1 provides dimensions of the ANT-5GWWS1-SMA. The antenna whip can be tilted 90 degrees, and
has a detent at 45 degrees enabling the antenna to be oriented in any direction. The rotating base allows for
continuous positioning through 360 degrees even while installed.
Full 360° Rotation
10.0 mm
(0.39 in)
135.7 mm (5.34 in)
114.8 mm (4.52 in)
20.1 mm
(0.79 in)
41.6 mm
(1.64 in)
Ø9.8 mm (0.39 in)
0°, 45°, 90°
Figure 1. ANT-5GWWS1-SMA Antenna Dimensions
Antenna Orientation
The ANT-5GWWS1-SMA antenna is characterized in two antenna orientations as shown in Figure 2. The
antenna straight orientation characterizes use of an antenna attached to an enclosure-mounted connector
which is connected by cable to a printed circuit board. Although the antenna is a dipole not requiring a
ground plane for function, characterization with an adjacent ground plane (102 mm x 102 mm) provides
insight into antenna performance when attached directly to a printed circuit board mounted connector. The
two orientations represent the most common end-product use cases.
Straight, without ground plane
On edge of ground plane, bent 90 degrees
Figure 2. ANT-5GWWS1-SMA Test Orientation
3
ANT-5GWWS1-SMA
Datasheet
Straight, No Ground Plane
The charts on the following pages represent data taken with the antenna oriented straight, as shown in
Figure 3.
Figure 3. ANT-5GWWS1-SMA Straight, No Ground Plane (Straight)
VSWR
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1553
1609
1710
5
617
698
803
960
Figure 4 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes
the power reflected from the antenna back to the radio. A lower VSWR value indicates better antenna
performance at a given frequency. Reflected power is also shown on the right-side vertical axis as a gauge of
the percentage of transmitter power reflected back from the antenna.
VSWR
4
30
3
1
10
600
1000
1400
1800
2200
2600
3000
3400
Frequency (MHz)
3800
4200
4600
Figure 4. ANT-5GWWS1-SMA Antenna VSWR, Straight, with Frequency Band Highlights
4
Reflected Power (%)
40
Datasheet
ANT-5GWWS1-SMA
Return Loss
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1609
1710
617
698
803
960
Return loss (Figure 5), represents the loss in power at the antenna due to reflected signals. Like VSWR, a
lower return loss value indicates better antenna performance at a given frequency.
Return Loss (dB)
-5
-10
-15
-20
-25
600
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 5. ANT-5GWWS1-SMA Antenna Return Loss, Straight, with Frequency Band Highlights
Peak Gain
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1553
1609
1710
10
617
698
803
960
The peak gain across the antenna bandwidth is shown in Figure 6. Peak gain represents the maximum
antenna input power concentration across 3-dimensional space, and therefore peak performance at a given
frequency, but does not consider any directionality in the gain pattern.
Peak Gain (dBi)
5
-10
600
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 6. ANT-5GWWS1-SMA Antenna Peak Gain, Straight, with Frequency Band Highlights
5
ANT-5GWWS1-SMA
Datasheet
Average Gain
Average Gain (dBi)
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
617
698
803
960
10
1553
1609
1710
Average gain (Figure 7), is the average of all antenna gain in 3-dimensional space at each frequency,
providing an indication of overall performance without expressing antenna directionality.
5
-10
600
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 7. ANT-5GWWS1-SMA Antenna Average Gain, Straight, with Frequency Band Highlights
Radiation Efficiency
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1553
1609
1710
100
617
698
803
960
Radiation efficiency (Figure 8), shows the ratio of power delivered to the antenna relative to the power
radiated at the antenna, expressed as a percentage, where a higher percentage indicates better performance
90
80
Efficiency (%)
70
60
50
40
30
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 8. ANT-5GWWS1-SMA Antenna Efficiency, Straight, with Frequency Band Highlights
6
Datasheet
ANT-5GWWS1-SMA
Radiation Patterns
Radiation patterns provide information about the directionality and 3-dimensional gain performance of the
antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns for a
straight orientation are shown in Figure 9 using polar plots covering 360 degrees. The antenna graphic at
the top of the page provides reference to the plane of the column of plots below it. Note: when viewed with
typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail.
Radiation Patterns - Straight
XZ-Plane Gain
YZ-Plane Gain
XY-Plane Gain
617 MHz to 698 MHz (660 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
XZ-Plane Gain
21
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
16
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
610 MHz
660 MHz
700 MHz
XY-Plane Gain
698 MHz to 803 MHz (750 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
XZ-Plane Gain
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
16
690 MHz
750 MHz
800 MHz
XY-Plane Gain
7
ANT-5GWWS1-SMA
Datasheet
791 MHz to 960 MHz (870 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
12
26
25
13
24
15
22
16
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
790 MHz
870 MHz
960 MHz
XY-Plane Gain
1710 MHz to 2200 MHz (1950 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
16
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
1710 MHz
1950 MHz
2200 MHz
XY-Plane Gain
2300 MHz to 2400 MHz (2350 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
13
14
23
15
22
21
18
XZ-Plane Gain
8
30
9
29
10
28
11
27
12
25
24
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
XY-Plane Gain
16
2300 MHz
2350 MHz
2400 MHz
Datasheet
ANT-5GWWS1-SMA
2496 MHz to 2690 MHz (2600 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
12
26
25
13
24
15
22
16
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
2500 MHz
2600 MHz
2700 MHz
XY-Plane Gain
3300 MHz to 3800 MHz (3550 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
16
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
3300 MHz
3550 MHz
3800 MHz
XY-Plane Gain
1553 MHz to 1609 MHz (1580 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
XZ-Plane Gain
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
16
1560 MHz
1580 MHz
1610 MHz
XY-Plane Gain
9
ANT-5GWWS1-SMA
Datasheet
3550 MHz to 3700 MHz (3620 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
16
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
3550 MHz
3620 MHz
3700 MHz
XY-Plane Gain
3700 MHz to 4200 MHz (3950 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
16
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
3700 MHz
3950 MHz
4200 MHz
XY-Plane Gain
4940 MHz to 4990 MHz (4960 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
XZ-Plane Gain
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
XY-Plane Gain
Figure 9. Radiation Patterns for ANT-5GWWS1-SMA, Straight
10
1
16
4940 MHz
4960 MHz
4990 MHz
Datasheet
ANT-5GWWS1-SMA
Edge of Ground Plane, Bent 90 Degrees
The charts on the following pages represent data taken with the antenna oriented at the edge of the ground
plane, bent 90 degrees (Edge-Bent), as shown in Figure 10.
Figure 10. ANT-5GWWS1-SMA on Edge of Ground Plane, Bent 90 Degrees (Edge-Bent)
VSWR
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1553
1609
1710
5
617
698
803
960
Figure 11 provides the voltage standing wave ratio (VSWR) across the antenna bandwidth. VSWR describes
VSWR
4
30
3
1
10
600
1000
1400
1800
2200
2600
3000
3400
Frequency (MHz)
3800
4200
4600
Reflected Power (%)
40
Figure 11. ANT-5GWWS1-SMA Antenna VSWR, Edge-Bent, with Frequency Band Highlights
11
ANT-5GWWS1-SMA
Datasheet
Return Loss
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1609
1710
617
698
803
960
Return loss (Figure 12), represents the loss in power at the antenna due to reflected signals. Like VSWR, a
Return Loss (dB)
-5
-10
-15
-20
-25
600
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 12. ANT-5GWWS1-SMA Antenna Return Loss, Edge-Bent, with Frequency Band Highlights
Peak Gain
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1553
1609
1710
10
617
698
803
960
The peak gain across the antenna bandwidth is shown in Figure 13. Peak gain represents the maximum
Peak Gain (dBi)
5
-10
600
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 13. ANT-5GWWS1-SMA Antenna Peak Gain, Edge-Bent, with Frequency Band Highlights
12
Datasheet
ANT-5GWWS1-SMA
Average Gain
Average Gain (dBi)
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
617
698
803
960
10
1553
1609
1710
Average gain (Figure 14), is the average of all antenna gain in 3-dimensional space at each frequency,
5
-10
600
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 14. ANT-5GWWS1-SMA Antenna Average Gain, Edge-Bent, with Frequency Band Highlights
4940
4990
4200
3550
3700
3800
3300
2690
2200
2300
2400
2496
1553
1609
1710
100
617
698
803
960
Radiation efficiency (Figure 15), shows the ratio of power delivered to the antenna relative to the power
90
80
Efficiency (%)
70
60
50
40
30
1000
1400
1800
2200
2600
3000
Frequency (MHz)
3400
3800
4200
4600
5000
Figure 15. ANT-5GWWS1-SMA Antenna Efficiency, Edge-Bent, with Frequency Band Highlights
13
ANT-5GWWS1-SMA
Datasheet
Radiation Patterns
antenna by plotting gain at specific frequencies in three orthogonal planes. Antenna radiation patterns for an
Edge-Bent orientation are shown in Figure 16 using polar plots covering 360 degrees. The antenna graphic
at the top of the page provides reference to the plane of the column of plots below it. Note: when viewed
with typical PDF viewing software, zooming into radiation patterns is possible to reveal fine detail.
Radiation Patterns - Edge-Bent
XZ-Plane Gain
YZ-Plane Gain
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
XZ-Plane Gain
21
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
16
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
610 MHz
660 MHz
700 MHz
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
13
14
23
15
22
21
18
XZ-Plane Gain
14
30
9
29
10
28
11
27
12
25
24
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
XY-Plane Gain
16
690 MHz
750 MHz
800 MHz
Datasheet
ANT-5GWWS1-SMA
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
16
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
12
26
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
790 MHz
870 MHz
960 MHz
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
16
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
1710 MHz
1950 MHz
2200 MHz
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
XZ-Plane Gain
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
16
2300 MHz
2350 MHz
2400 MHz
XY-Plane Gain
15
ANT-5GWWS1-SMA
Datasheet
2496 MHz to 2690 MHz (3620 MHz)
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
16
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
12
26
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
2500 MHz
2600 MHz
2700 MHz
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
16
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
3300 MHz
3550 MHz
3800 MHz
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
13
14
23
15
22
21
18
XZ-Plane Gain
16
30
9
29
10
28
11
27
12
25
24
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
XY-Plane Gain
16
1560 MHz
1580 MHz
1610 MHz
Datasheet
ANT-5GWWS1-SMA
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
16
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
3550 MHz
3620 MHz
3700 MHz
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
21
18
17
2
3
4
34
5
6
32
7
31
8
30
9
29
10
28
11
27
12
24
21
XZ-Plane Gain
18
17
1
2
3
4
5
6
7
8
9
10
26
12
25
13
24
15
22
16
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
11
14
23
35
33
13
15
22
1
25
14
23
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
26
13
24
35
14
23
16
15
22
21
YZ-Plane Gain
18
17
16
3700 MHz
3950 MHz
4200 MHz
XY-Plane Gain
34
35
33
32
31
30
29
28
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
27
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
XZ-Plane Gain
17
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
34
5
33
6
32
7
31
8
26
30
9
29
10
28
11
27
12
25
13
24
14
23
15
22
21
18
17
YZ-Plane Gain
16
35
36 5
-10
-15
-20
-25
-30
-35
-40
-45
-50
1
2
3
4
5
6
7
8
9
10
11
26
12
25
13
24
14
23
15
22
21
18
17
16
4940 MHz
4960 MHz
4990 MHz
XY-Plane Gain
Figure 16. Radiation Patterns for ANT-5GWWS1-SMA, Edge-Bent
17
ANT-5GWWS1-SMA
Datasheet
Website: http://linxtechnologies.com
Linx Offices: 159 Ort Lane, Merlin, OR, US 97532
Phone:
+1 (541) 471-6256
E-MAIL: info@linxtechnologies.com
Linx Technologies reserves the right to make changes to the product(s) or information contained herein without notice. No liability is assumed as a result of their use
or application. No rights under any patent accompany the sale of any such product(s) or information.
Wireless Made Simple is a registered trademark of Linx Acquisitions LLC. Other product and brand names may be trademarks or registered trademarks of their
respective owners.
Copyright © 2022 Linx Technologies
All Rights Reserved
Doc# DS22100-72ANT Replaces (DS20148-72ANT)
