EEP108M2WQ70SZSMP
EEP108M2WQ70SZSMP
    MANYUE(万裕科技)
EEP108M2WQ70SZSMP 数据手册
ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SPECIFICATION Rev. EP SERIES Mark Page Date ALTERNATION HISTORY RECORDS Contents Purpose Drafter Approver Specification Sheet – EP Name Version SAMXON 01 Page STANDARD MANUAL 1 MAN YUE ELECTRONICS COMPANY LIMITED Table 1 SAMXON ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES Product Dimensions and Characteristics Z-TYPE ΦD=Φ20~Φ35 L±2.0 F 4.0±1.0 Table 1 No 1 S AM X O N Part No. EEP108M2WQ70SZ**P WV (Vd c) Cap. ( μF ) 450 1000 -20%~+20% -25~105 tanδ (120Hz, 20℃) 0.25 Max Ripple Current at 105℃ 120Hz (A rms) Leakage Current (μA,5min) 2012 1.95 Specification Sheet – EP Issued-date: 2018-05-08 Version Cap. tolerance Temp. range(℃) 01 Page STANDARD MANUAL 2 D i me n s i o n (mm) Load lifetim e (Hrs) D×L F 5000 35X70 10±1.0 Sleeve PET ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON CONTENTS Sheet 1. Application 4 2. Part Number System 4 3. Construction 5 4. Characteristics 4.1 Rated voltage & Surge voltage 4.2 Capacitance (Tolerance) 6~13 4.3. Leakage current 4.4 tanδ 4.5 4.6 Terminal strength Temperature characteristics 4.7 Load life test 4.8 Shelf life test 4.9 Surge test 4.10 Vibration 4.11 Solderability test 4.12 Resistance to solder heat 4.13 Change of temperature 4.14 Damp heat test 4.15 Vent test 4.16 Maximum permissible (ripple current) 5. List of “Environment-related Substances to be Controlled (‘Controlled Substances’)” Attachment: Application Guidelines 15~20 Specification Sheet – EP Name Version 14 01 Page 3 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED 1. SAMXON Application This specification applies to polar Aluminum electrolytic capacitor (foil type) used in electronic equipment. Designed capacitor’s quality meets IEC60384. 2. Part Number System Specification Sheet – EP Name Version 01 Page 4 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON 3. Construction Single ended type to be produced to fix the terminals to anode and cathode foil, and wind together with paper, and then wound element to be impregnated with electrolyte will be enclosed in an aluminum case. Finally sealed up tightly with end seal rubber, then finished by putting on the vinyl sleeve. 5 3 4 2 6 1 7 8 No Component Material 1 Case Aluminum case 2 Sleeve PET 3 Terminal Solder coated copper clad steel 4 Seal Rubber-laminated bakelite 5 Rivet Aluminum 6 Washer Aluminum 7 Tab Aluminum 8 Element Aluminum foil & Electrolyte paper Specification Sheet – EP Name Version 01 Page 5 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON 4. Characteristics Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurements and tests is as follows: Ambient temperature :15°C to 35°C Relative humidity : 45% to 85% Air Pressure : 86kPa to 106kPa If there is any doubt about the results, measurement shall be made within the following conditions: Ambient temperature : 20°C ± 2°C Relative humidity : 60% to 70% Air Pressure : 86kPa to 106kPa Operating temperature range The ambient temperature range at which the capacitor can be operated continuously at rated voltage See table 1 temperature range. As to the detailed information, please refer to table 2 Specification Sheet – EP Name Version 01 Page 6 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON Table 2 ITEM PERFORMANCE Rated voltage (WV) 4.1 Surge voltage (SV) 4.2 Nominal capacitance (Tolerance) WV (V .DC) 10 16 25 35 50 63 80 100 160 SV (V .DC) 13 20 32 44 63 79 100 125 200 WV (V .DC) 180 200 220 250 315 350 400 420 450 500 SV (V .DC) 225 250 270 300 365 400 450 470 500 550 Measuring Frequency : 120Hz±12Hz Measuring Voltage : Not more than 0.5Vrms Measuring Temperature : 20±2℃ Shall be within the specified capacitance tolerance 4.3 Leakage current Connecting the capacitor with a protective resistor (1kΩ±10Ω) in series for 5 minutes, and then, measure Leakage Current. Refer to table 1 See 4.2, Norm Capacitance, for measuring frequency, voltage and temperature. Refer to table 1 4.4 tanδ Specification Sheet – EP Name Version 01 Page 7 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON A static load of 25N (2.5kgf) shall be applied to the lead wire terminal in the axial direction away from the capacitor body for 30s 4.5 Terminal strength There shall be no intermittent contacts, open or short circuit and there shall be no mechanical damage such as terminal damage. < STEP 1 2 3 4 5 Testing Temperature(℃) 20±2 -40(-25) ±3 20±2 105±2 20±2 Time Time to reach thermal equilibrium Time to reach thermal equilibrium Time to reach thermal equilibrium Time to reach thermal equilibrium Time to reach thermal equilibrium tanδshall be within the limit of Item 4.4 The leakage current measured shall not more than 8 times of its specified value. a. In step 5, tanδshall be within the limit of Item 4.4 The leakage current shall not more than the specified value. 4.6 Temperature characteristics b. At-40℃ (-25℃), impedance (Z) ratio shall not exceed the value of the following table. Working voltage (V) Z-25℃/Z+20℃ Z-40℃/Z+20℃ 10 6 15 16 6 15 25 6 15 35 6 15 50 4 15 63~100 3 15 Working voltage (V) 160~450 8 Z-25℃/Z+20℃ Capacitance, tanδand impedance shall be measured at 120Hz. Specification Sheet – EP Name Version 01 Page 8 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON According to IEC60384-4No.4.13methods, The capacitor is stored at a temperature of 105°C ±2 with DC bias voltage plus the rated ripple current for 5000 +48/0 hours. (The sum of DC and ripple peak voltage shall not exceed the rated working voltage) Then the product should be tested after 16 hours recovering time at atmospheric conditions The result should meet the following table: 4.7 Load life test The characteristic shall meet the following requirements. Leakage current Value in 4.3 shall be satisfied Capacitance Change Within ±20% of initial value . Not more than 200% of the specified value. tanδ Appearance There shall be no leakage of electrolyte. The capacitors are then stored with no voltage applied at a temperature of 105±2℃ for 1000+48/0 hours. Following this period the capacitors shall be removed from the test chamber and be allowed to stabilized at room temperature for 4~8 hours. Next they shall be connected to a series limiting resistor(1k±100Ω) with D.C. rated voltage applied for 30min. After which the capacitors shall be discharged, and then, tested the characteristics. 4.8 The characteristic shall meet the following requirements. Leakage current Value in 4.3 shall be satisfied Capacitance Change Within ±15% of initial value . Not more than 150%of the specified value. tanδ Appearance There shall be no leakage of electrolyte. Remark: If the capacitors are stored more than 1 year, the leakage current may increase. Please apply voltage through about 1 kΩresistor, if necessary. Shelf life test Specification Sheet – EP Name Version 01 Page 9 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED 4.9 4.10 Surge test Vibration test SAMXON Applied a surge voltage to the capacitor connected with a (100 ±50)/CR (kΩ) resistor. The capacitor shall be submitted to 1000 cycles, each consisting of charge of 30 ±5s, followed discharge of 5 min 30s. The test temperature shall be 15~35℃. CR :Nominal Capacitance (μF) Leakage current Not more than the specified value. Capacitance Change Within ±15% of initial value . Not more than the specified value. tanδ Appearance There shall be no leakage of electrolyte. Attention: This test simulates over voltage at abnormal situation, and not be hypothesizing that over voltage is always applied. The following conditions shall be applied for 2 hours in each 3 mutually perpendicular directions. Vibration frequency range : 10Hz ~ 55Hz Peak to peak amplitude : 1.5mm Sweep rate : 10Hz ~ 55Hz ~ 10Hz in about 1 minute After the test, the following items shall be tested: No mechanical damage in terminal. No leakage of Appearance electrolyte or swelling of the case. The markings shall be legible. No intermittent contact, open or short circuit. Inner construction No damage of tab terminals or electrodes. Mounting method: The capacitor must be fixed in place with a bracket. Space < 1mm To be soldered Specification Sheet – EP Name Version 01 Page 10 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON The capacitor shall be tested under the following conditions: Soldering temperature : 245±3°C Dipping depth : 2mm Dipping speed : 25±2.5mm/s Dipping time : 3±0.5s 4.11 Solderability test Coating quality A minimum of 95% of the surface being immersed Terminals of the capacitor shall be immersed into solder bath at +1 260±5℃for10±1seconds or 400±10℃for3 - 0 seconds to 1.5~2.0mm from the body of capacitor . Then the capacitor shall be left under the normal temperature and normal humidity for 1~2 hours before measurement. 4.12 Resistance to solder heat test Leakage current Capacitance Change tanδ Appearance Specification Sheet – EP Name Version Not more than the specified value. Within ±10% of initial value . Not more than the specified value. There shall be no leakage of electrolyte. 01 Page 11 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON Temperature cycle: According to IEC60384-4 No.4.7methods, capacitor shall be placed in an oven, the condition according as below: Temperature Time 3 Minutes (1)+20℃ ≤ (2)Rated low temperature(-40℃) (-25℃) 30±2 Minutes (3)Rated high temperature (+105℃) 30±2 Minutes (1) to (3)=1 cycle, total 5 cycle 4.13 Change of temperature test The characteristic shall meet the following requirement Leakage current Not more than the specified value. Not more than the specified value. tanδ Appearance There shall be no leakage of electrolyte. Humidity Test: According to IEC60384-4 No.4.12methods, capacitor shall be exposed for 500±8 hours in an atmosphere of 90~95%R H .at 40±2℃, the characteristic change shall meet the following requirement. 4.14 Damp heat test Leakage current Capacitance Change tanδ Appearance Specification Sheet – EP Name Version Not more than the specified value. Within ±20% of initial value . Not more than 120% of the specified value. There shall be no leakage of electrolyte. 01 Page 12 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON The following test only apply to those products with vent. D.C. test The capacitor is connected with its polarity reversed to a DC power source. Then a current selected from Table 2 is applied. 4.15 Diameter (mm) 22.4 or less Over 22.4 Vent test DC current (A) 1 10 The vent shall operate with no dangerous conditions such as flames or dispersion of pieces of the capacitor and/or case. The maximum permissible ripple current is the maximum A.C current at 120Hz and can be applied at maximum operating temperature Table-3 The combined value of D.C voltage and the peak A.C voltage shall not exceed the rated voltage and shall not reverse voltage. 4.16 Maximum permissible (ripple current) Frequency multipliers: Frequency (Hz) 120 1k 10~50k 10~100V 160~250V 0.90 0.80 1.00 1.00 1.15 1.25 1.25 1.47 315~450V 0.80 1.00 1.30 1.47 Specification Sheet – EP Name Version 60 01 Page 13 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED 5.It refers to the latest document of SAMXON “Environment-related Substances standard”(WI-HSPM-QA-072). Substances Cadmium and cadmium compounds Heavy metals Lead and lead compounds Mercury and mercury compounds Hexavalent chromium compounds Polychlorinated biphenyls (PCB) Chloinated Polychlorinated naphthalenes (PCN) organic Polychlorinated terphenyls (PCT) compounds Short-chain chlorinated paraffins(SCCP) Other chlorinated organic compounds Polybrominated biphenyls (PBB) Brominated organic compounds Polybrominated diphenylethers(PBDE) (including decabromodiphenyl ether[DecaBDE]) Other brominated organic compounds Tributyltin compounds(TBT) Triphenyltin compounds(TPT) Asbestos Specific azo compounds Formaldehyde Polyvinyl chloride (PVC) and PVC blevds Beryllium oxide Beryllium copper Specific phthalates (DEHP,DBP,BBP,DINP,DIDP,DNOP,DNHP) Hydrofluorocarbon (HFC), Perfluorocarbon (PFC) Perfluorooctane sulfonates (PFOS) Specific Benzotriazole Specification Sheet – EP Name Version 01 Page 14 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON Attachment: Application Guidelines 1.Circuit Design 1.1 Operating Temperature and Frequency Electrolytic capacitor electrical parameters are normally specified at 20℃ temperature and 120Hz frequency. These parameters vary with changes in temperature and frequency. Circuit designers should take these changes into consideration. (1) Effects of operating temperature on electrical parameters a) At higher temperatures, leakage current and capacitance increase while equivalent series resistance (ESR) decreases. b) At lower temperatures, leakage current and capacitance decrease while equivalent series resistance (ESR) increases. (2) Effects of frequency on electrical parameters a) At higher frequencies capacitance and impedance decrease while tanδ increases. b) At lower frequencies, ripple current generated heat will rise due to an increase in equivalent series resistance (ESR). 1.2 Operating Temperature and Life Expectancy See the file: Life calculation of aluminum electrolytic capacitor 1.3 Common Application Conditions to Avoid The following misapplication load conditions will cause rapid deterioration to capacitor electrical parameters. In addition, rapid heating and gas generation within the capacitor can occur causing the pressure relief vent to operate and resultant leakage of electrolyte. Under Leaking electrolyte is combustible and electrically conductive. Specification Sheet – EP Name Version 01 Page 15 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON (1) Reverse Voltage DC capacitors have polarity. Verify correct polarity before insertion. For circuits with changing or uncertain polarity, use DC bipolar capacitors. DC bipolar capacitors are not suitable for use in AC circuits. (2) Charge / Discharge Applications Standard capacitors are not suitable for use in repeating charge / discharge applications. For charge / discharge applications consult us and advise actual conditions. (3) Over voltage Do not apply voltages exceeding the maximum specified rated voltage. Voltages up to the surge voltage rating are acceptable for short periods of time. Ensure that the sum of the DC voltage and the superimposed AC ripple voltage does not exceed the rated voltage. (4) Ripple Current Do not apply ripple currents exceeding the maximum specified value. For high ripple current applications, use a capacitor designed for high ripple currents or contact us with your requirements. Ensure that allowable ripple currents superimposed on low DC bias voltages do not cause reverse voltage conditions. 1.4 Using Two or More Capacitors in Series or Parallel (1) Capacitors Connected in Parallel The circuit resistance can closely approximate the series resistance of the capacitor causing an imbalance of ripple current loads within the capacitors. Careful design of wiring methods can minimize the possibility of excessive ripple currents applied to a capacitor. (2) Capacitors Connected in Series Normal DC leakage current differences among capacitors can cause voltage imbalances. The use of voltage divider shunt resistors with consideration to leakage current can prevent capacitor voltage imbalances. 1.5 Capacitor Mounting Considerations (1) Double Sided Circuit Boards Avoid wiring pattern runs, which pass between the mounted capacitor and the circuit board. When dipping into a solder bath, excess solder may collect under the capacitor by capillary action and short circuit the anode and cathode terminals. (2)Circuit Board Hole Positioning The vinyl sleeve of the capacitor can be damaged if solder passes through a lead hole for subsequently processed parts. Special care when locating hole positions in proximity to capacitors is recommended. (3)Circuit Board Hole Spacing The circuit board holes spacing should match the capacitor lead wire spacing within the specified tolerances. Incorrect spacing can cause excessive lead wire stress during the insertion process. This may result in premature capacitor failure due to short or open circuit, increased leakage current, or electrolyte leakage. Specification Sheet – EP Name Version 01 Page 16 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON (4) Clearance for Case Mounted Pressure Relief vents Capacitors with case mounted pressure relief vents require sufficient clearance to allow for proper vent operation. The minimum clearances are dependent on capacitor diameters as proper vent operation. The minimum clearances are dependent on capacitor diameters as follows. φ6.3~φ16mm:2mm minimum, φ18~φ35mm:3mm minimum, φ40mm or greater:5mm minimum. (5) Clearance for Seal Mounted Pressure Relief Vents A hole in the circuit board directly under the seal vent location is required to allow proper release of pressure. (6) Wiring Near the Pressure Relief Vent Avoid locating high voltage or high current wiring or circuit board paths above the pressure relief vent. Flammable, high temperature gas exceeding 100℃ may be released which could dissolve the wire insulation and ignite. (7) Circuit Board patterns Under the Capacitor Avoid circuit board runs under the capacitor as electrolyte leakage could cause an electrical short. (8) Screw Terminal Capacitor Mounting Do not orient the capacitor with the screw terminal side of the capacitor facing downwards. Tighten the terminal and mounting bracket screws within the torque range specified in the specification. 1.6 Electrical Isolation of the Capacitor Completely isolate the capacitor as follows. (1) Between the cathode and the case (except for axially leaded B types) and between the anode terminal and other circuit paths (3) Between the extra mounting terminals (on T types) and the anode terminal, cathode terminal, and other circuit paths. 1.7 The Product characteristic should take the sample as the standard. 1.8 Capacitor Sleeve The vinyl sleeve or laminate coating is intended for marking and identification purposes and is not meant to electrically insulate the capacitor. The sleeve may split or crack if immersed into solvents such as toluene or xylene, and then exposed to high temperatures. CAUTION! Always consider safety when designing equipment and circuits. Plan for worst case failure modes such as short circuits and open circuits which could occur during use. (1) Provide protection circuits and protection devices to allow safe failure modes. (2) Design redundant or secondary circuits where possible to assure continued operation in case of main circuit failure. Specification Sheet – EP Name Version 01 Page 17 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON 2.Capacitor Handling Techniques 2.1 Considerations Before Using (1) Capacitors have a finite life. Do not reuse or recycle capacitors from used equipment. (2) Transient recovery voltage may be generated in the capacitor due to dielectric absorption. If required, this voltage can be discharged with a resistor with a value of about 1kΩ. (3) Capacitors stored for long periods of time may exhibit an increase in leakage current. This can be corrected by gradually applying rated voltage in series with a resistor of approximately 1kΩ. (4) If capacitors are dropped, they can be damaged mechanically or electrically. Avoid using dropped capacitors. (5) Dented or crushed capacitors should not be used. The seal integrity can be compromised and loss of electrolyte / shortened life can result. 2.2 Capacitor Insertion * (1) Verify the correct capacitance and rated voltage of the capacitor. * (2) Verify the correct polarity of the capacitor before inserting. * (3) Verify the correct hole spacing before insertion (land pattern size on chip type) to avoid stress on the terminals. (4) Ensure that the auto insertion equipment lead clinching operation does not stress the capacitor leads where they enter the seal of the capacitor. For chip type capacitors, excessive mounting pressure can cause high leakage current, short circuit, or disconnection. 2.3 Manual Soldering (1) Observe temperature and time soldering specifications or do not exceed temperatures of 400 ℃ for 3 seconds or less. (2) If lead wires must be formed to meet terminal board hole spacing, avoid stress on the lead wire where it enters the capacitor seal. (3) If a soldered capacitor must be removed and reinserted, avoid excessive stress to the capacitor leads. (4) Avoid touching the tip of the soldering iron to the capacitor, to prevent melting of the vinyl sleeve. 2.4 Flow Soldering (1) Do not immerse the capacitor body into the solder bath as excessive internal pressure could result. (2) Observe proper soldering conditions (temperature, time, etc.) Do not exceed the specified limits. (3) Do not allow other parts or components to touch the capacitor during soldering. 2.5 Other Soldering Considerations Rapid temperature rises during the preheat operation and resin bonding operation can cause cracking of the capacitor vinyl sleeve. For heat curing, do not exceed 150℃ for a maximum time of 2 minutes. Specification Sheet – EP Name Version 01 Page 18 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED SAMXON 2.6 Capacitor Handling after Solder (1). Avoid movement of the capacitor after soldering to prevent excessive stress on the lead wires where they enter the seal. (2). Do not use capacitor as a handle when moving the circuit board assembly. (3). Avoid striking the capacitor after assembly to prevent failure due to excessive shock. 2.7 Circuit Board Cleaning * (1 ) Circuit boards can be immersed or ultrasonically cleaned using suitable cleaning solvents for up 5 minutes and up to 60℃ maximum temperatures. The boards should be thoroughly rinsed and dried. The use of ozone depleting cleaning agents is not recommended in the interest of protecting the environment. * (2) Avoid using the following solvent groups unless specifically allowed for in the specification; . Halogenated cleaning solvents: except for solvent resistant capacitor types, halogenated solvents can permeate the seal and cause internal capacitor corrosion and failure. For solvent resistant capacitors, carefully follow the temperature and time requirements of the specification. 1-1-1 trichloroethane should never be used on any aluminum electrolytic capacitor. . Alkali solvents : could attack and dissolve the aluminum case. . Petroleum based solvents: deterioration of the rubber seal could result. . Xylene : deterioration of the rubber seal could result. . Acetone : removal of the ink markings on the vinyl sleeve could result. * (3 ) A thorough drying after cleaning is required to remove residual cleaning solvents which may be trapped between the capacitor and the circuit board. Avoid drying temperatures, which exceed the maximum rated temperature of the capacitor. * (4) Monitor the contamination levels of the cleaning solvents during use by electrical conductivity, pH, specific gravity, or water content. Chlorine levels can rise with contamination and adversely affect the performance of the capacitor. Please consult us for additional information about acceptable cleaning solvents or cleaning methods. 2.8 Mounting Adhesives and Coating Agents When using mounting adhesives or coating agents to control humidity, avoid using materials containing halogenated solvents. Also, avoid the use of chloroprene based polymers. After applying adhesives or coatings, dry thoroughly to prevent residual solvents from being trapped between the capacitor and the circuit board. 3. Precautions for using capacitors 3.1 Environmental Conditions Capacitors should not be stored or used in the following environments. * (1) Temperature exposure above the maximum rated or below the minimum rated temperature of the capacitor. * (2) Direct contact with water, salt water, or oil. * (3) High humidity conditions where water could condense on the capacitor. Specification Sheet – EP Name Version 01 Page 19 STANDARD MANUAL ELECTROLYTIC CAPACITOR SPECIFICATION EP SERIES MAN YUE ELECTRONICS COMPANY LIMITED * * * SAMXON (4) Exposure to toxic gases such as hydrogen sulfide, sulfuric acid, nitric acid chlorine, or ammonia. (5) Exposure to ozone, radiation, or ultraviolet rays. (6) Vibration and shock conditions exceeding specified requirements. 3.2 Electrical Precautions (1) Avoid touching the terminals of the capacitor as possible electric shock could result. The exposed aluminum case is not insulated and could also cause electric shock if touched. (2) Avoid short circuit the area between the capacitor terminals with conductive materials including liquids such as acids or alkaline solutions. 4. Emergency Procedures (1) If the pressure relief vent of the capacitor operates, immediately turn off the equipment and disconnect form the power source. This will minimize additional damage caused by the vaporizing electrolyte. (2) Avoid contact with the escaping electrolyte gas which can exceed 100℃ temperatures. If electrolyte or gas enters the eye, immediately flush the eyes with large amounts of water. If electrolyte or gas is ingested by month, gargle with water. If electrolyte contacts the skin, wash with soap and water. 5. Long Term Storage The characteristics of aluminum electrolytic capacitors degrade when stored in a static condition for long periods of time. The rate of deterioration depends upon temperature and humidity. Capacitors should be stored at the temperature of 5℃ to 35℃, the humidity of less than 75% RH and out of direct sunlight. Leakage current of a capacitor increases with long storage times. The aluminum oxide film deteriorates as a function of temperature and time. If used without reconditioning, an abnormally high current will be required to restore the oxide film. This current surge could cause the circuit or the capacitor to fail. After one year, a capacitor should be reconditioned by applying rated voltage in series with a 1000Ω,current limiting resistor for a time period of 30 minutes . 5.1 Environmental Conditions The capacitor shall be not use in the following condition: (1) Temperature exposure above the maximum rated or below the minimum rated temperature of the capacitor. (2) Direct contact with water, salt water, or oil. (3) High humidity conditions where water could condense on the capacitor. (4) Exposure to toxic gases such as hydrogen sulfide, sulfuric acid, nitric acid, chlorine, or ammonia. (5) Exposure to ozone, radiation, or ultraviolet rays. (6) Vibration and shock conditions exceeding specified requirements. 6. Capacitor Disposal * * When disposing of capacitors, use one of the following methods. Incinerate after crushing the capacitor or puncturing the can wall (to prevent explosion due to internal pressure rise). Capacitors should be incinerated at high temperatures to prevent the release of toxic gases such as chlorine from the polyvinyl chloride sleeve, etc. Dispose of as solid waste. NOTE: Local laws may have specific disposal requirements, which must be followed. Specification Sheet – EP Name Version 01 Page 20 STANDARD MANUAL
EEP108M2WQ70SZSMP
1. 物料型号: - 型号:EEP108M2WQ70SZP - 额定电压(WV):450V - 电容值(Cap):1000μF - 电容公差:-20%~+20% - 尺寸:35mm直径 x 70mm长 - 套管材料:PET,安装孔间距:10±1.0mm
2. 器件简介: - 该资料是电解电容器的规格说明书,适用于电子设备中的极性铝电解电容器(箔式),设计质量满足IEC60384.2标准。
3. 引脚分配: - 引脚通过铝制铆钉连接到铝制的正负极片上,引脚在轴向上施加静态负载25N(2.5kgf)持续30秒。
4. 参数特性: - 工作环境温度范围为-25~105°C。 - 损耗角正切(tanδ)在120Hz、20°C条件下测量不超过0.2012。 - 漏电流(Leakage Current)为1.95uA.5min。 - 最大纹波电流(Max Ripple Cura)为5000A rms。
5. 功能详解: - 电容器的详细特性包括额定电压与浪涌电压、电容值公差、漏电流、损耗角正切、端点强度、温度特性、负载寿命测试、储存寿命测试、浪涌测试、振动测试、焊接性测试、耐焊热测试、温度变化测试、湿热测试、排气测试以及最大允许纹波电流等。
6. 应用信息: - 适用于电子设备中的极性铝电解电容器,电路设计时应考虑电气参数随温度和频率变化的影响。避免在反向电压、快速充放电应用、过电压、超出最大规定纹波电流等误用条件下使用电容器。
7. 封装信息: - 电容器封装包括铝制外壳和PET套管,尺寸和端点材料在规格中有详细说明。
EEP108M2WQ70SZSMP 价格&库存
很抱歉,暂时无法提供与“EEP108M2WQ70SZSMP”相匹配的价格&库存,您可以联系我们找货
