SK56LH
SK56LH
    DY(迪一电子)
    SMB
SK56LH 数据手册
SK54L THRU SK520L 5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS Features SMB/DO-214AA · High current capacity,low VF ·Low Power Loss,High Efficiency · Ideally Suited for Automatic Assembly 0.154(3.90) 0.130(3.30) 0.083(2.11) 0.075(1.91) · For Use in Low Voltage Application · Plastic Case Material has UL Flammability Classification Rating 94V-0 Mechanical Data 0.187(4.75) 0.163(4.15) · Case: Molded plastic SMB 0.012(0.300) 0.004(0.100) · Terminals: Plated leads solderable per MIL-STD-750,Method 2026 guaranteed 0.102(2.60) 0.084(2.13) · Polarity: Color band dentes cathode end · Mounting Position: Any 0.057(1.45) 0.033(0.85) · Making: Type Number 0.008(0.20) 0.004(0.10) 0.008(0.20) 0.002(0.05) 0.217(5.50) 0.197(5.00) · Solder Dip: 260 ℃ /10Sec whole body Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% SYMBOL SK54L SK545L SK55L SK56L SK58L SK510L SK515L SK520L Unit Type Number Maximum Recurrent Peak Reverse Voltage VRRM 40 45 50 60 80 100 150 200 V Maximum RMS Voltage VRMS 28 32 35 42 56 70 105 140 V Maximum DC Blocking Voltage VDC 40 45 50 60 80 100 150 200 V Average Rectified Output Current @TL =90 ℃ IF(AV) Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) IFSM Forward Voltage @IF=5.0A (Note 1) Peak Reverse Current VFM @TA =25 ℃ At Rated DC Blocking Voltage @TA =100 ℃ 2 I t Typical Junction Capacitance (Note 2) CJ Typical Thermal Resistance (Note 3) Rθ JA 120 A 0.6 0.85 0.2 0.05 10 5 2 I t Rating for fusing (t
SK56LH 价格&库存
很抱歉,暂时无法提供与“SK56LH”相匹配的价格&库存,您可以联系我们找货
