34412 0103000
34412 0103000
    BELDEN
34412 0103000 数据手册
Product: 34412 Lead Wire, #12 Str TC, CSPE Ins, AWM 3191 Product Description Low Temp Rubber Lead Wire, 12AWG (65x30) Tinned Copper, CSPE Insulation, AWM 3191 CSA TYPE CL1053 600V 105C Technical Specifications Physical Characteristics (Overall) Conductor AWG Stranding 12 65x30 Material No. of Conductors TC - Tinned Copper 1 Conductor Count: 1 Insulation Material Nominal Diameter Nominal Wall Thickness Min. Average Wall Thickness CSPE - Chlorosulphonated Polyethylene 0.19 in 0.052 in Electrical Characteristics Voltage UL Voltage Rating 600 V RMS Temperature Range UL Temp Rating: 105°C Operating Temperature Range: -30°C To +105°C Mechanical Characteristics Recommended Max Baking Cycles: 24 Hours @ 300°F (149°C) Bulk Cable Weight: 35 lbs/1000ft Min. Bend Radius/Minor Axis: 0.76 in Standards UL AWM Style Compliance: AWM 3191 CSA Rating: 600 V, 105°C CSA Type: CL1053 Applicable Environmental and Other Programs EU Directive 2000/53/EC (ELV): Yes EU Directive 2003/96/EC (BFR): Yes EU Directive 2011/65/EU (RoHS 2): Yes EU Directive 2012/19/EU (WEEE): Yes 0.045 in EU Directive 2015/863/EU (RoHS 2 amendment): Yes EU Directive Compliance: EU Directive 2003/11/EC (BFR) EU CE Mark: Yes CA Prop 65: Yes MII Order #39 (China RoHS): Yes Flammability, LS0H, Toxicity Testing UL voltage rating: 600 V RMS Plenum/Non-Plenum Plenum (Y/N): No Related Part Numbers Variants Item # Color Put-Up Type Length UPC 34412 010100 Black Reel 100 ft 612825143888 34412 010500 612825143901 Black Reel 500 ft 34412 0103000 Black Reel 3,000 ft 612825143895 34412 008500 Gray Reel 500 ft 34412 005500 Green, Dark Reel 500 ft 612825143871 34412 002500 Red 500 ft 612825143864 Footnote: Reel C - CRATE REEL PUT-UP., F - MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 50'., I - MAY CONTAIN MORE THAN 1 PIECE. MINIMUM LENGTH OF ANY ONE PIECE IS 200'., U - TOPCOAT ADDERS ON STOCK SOLID COLORS. MINIMUM ORDER 10,000' PER COLOR COMBINATION. (SEE TOPCOAT ADDER TABLE) Product Notes Notes: Separator material over conductor. History Update and Revision: Revision Number: 0.354 Revision Date: 11-09-2022 © 2023 Belden, Inc All Rights Reserved. Although Belden makes every reasonable effort to ensure their accuracy at the time of this publication, information and specifications described here in are subject to error or omission and to change without notice, and the listing of such information and specifications does not ensure product availability. Belden provides the information and specifications herein on an "ASIS" basis, with no representations or warranties, whether express, statutory or implied. In no event will Belden be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary damages) whatsoever, even if Belden has been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. All sales of Belden products are subject to Belden's standard terms and conditions of sale. Belden believes this product to be in compliance with all applicable environmental programs as listed in the data sheet. The information provided is correct to the best of Belden's knowledge, information and belief at the date of its publication. This information is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it becomes a part of. The Product Disclosure is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product.
34412 0103000 价格&库存
很抱歉,暂时无法提供与“34412 0103000”相匹配的价格&库存,您可以联系我们找货
